[U-Boot] [PATCH] omap3: fix bi_dram initialization when CONFIG_NR_DRAM_BANKS is 1
When CONFIG_NR_DRAM_BANKS is 1 gd->bd->bi_dram[1] assignment exceeds bi_dram array bounds. Perform it only if CONFIG_NR_DRAM_BANKS is greater than 1.
Signed-off-by: Mike Rapoport mike@compulab.co.il --- cpu/arm_cortexa8/omap3/board.c | 3 +++ 1 files changed, 3 insertions(+), 0 deletions(-)
diff --git a/cpu/arm_cortexa8/omap3/board.c b/cpu/arm_cortexa8/omap3/board.c index dd2c940..0b3805a 100644 --- a/cpu/arm_cortexa8/omap3/board.c +++ b/cpu/arm_cortexa8/omap3/board.c @@ -291,8 +291,11 @@ int dram_init(void)
gd->bd->bi_dram[0].start = PHYS_SDRAM_1; gd->bd->bi_dram[0].size = size0; + +#if (CONFIG_NR_DRAM_BANKS > 1) gd->bd->bi_dram[1].start = PHYS_SDRAM_1 + get_sdr_cs_offset(CS1); gd->bd->bi_dram[1].size = size1; +#endif
return 0; }
return 0; }
This is fine with me. The only issue is of late we have been having issues with OAMP3 boards not booting properly. This is probably due to changes that were made when some patches were added to u-boot-ti.
I think I'll add this when we get to the bottom of the above issues.
Thanks, Sandeep
Mike Rapoport
Paulraj, Sandeep
