[v1 00/17] Add Intel N5X SoC support
This patchset add Intel N5X SoC[1] support.
Intel N5X SoC is with a 64-bit quad core ARM Cortex-A53 MPCore hard processor system (HPS). New IPs in N5X are clock manager and DDR subsystem, other IPs have minor changes compared to Agilex.
Intel N5X SoC supports legacy boot without ATF, ATF boot, and ATF boot with VAB enabled.
[1]: https://www.intel.com/content/www/us/en/products/programmable/asic/easic-dev...
Siew Chin Lim (16): arm: socfpga: Changed base_addr_s10.h to base_addr_soc64.h arm: socfpga: Add base address for Intel N5X device arm: socfpga: Add handoff data support for Intel N5X device drivers: clk: Add clock driver for Intel N5X device arm: socfpga: Get clock manager base address for Intel N5X device drivers: clk: Add memory clock driver for Intel N5X device arm: socfpga: Move cm_get_mpu_clk_hz function declaration to clock_manager.h arm: socfpga: Add clock manager for Intel N5X device arm: socfpga: Changed misc_s10.c to misc_soc64.c arm: socfpga: Add SDRAM driver helper function for Intel N5X device ddr: altera: Add SDRAM driver for Intel N5X device arm: socfpga: Add SPL for Intel N5X device board: intel: Add socdk board support for Intel N5X device arm: dts: Add base dtsi and devkit dts for Intel N5X device include: configs: Add Intel N5X device CONFIGs arm: socfpga: Enable Intel N5X device build
Tien Fong Chee (1): ddr: socfpga: Enable memory test on memory size less than 1GB
arch/arm/dts/Makefile | 1 + arch/arm/dts/socfpga_n5x-u-boot.dtsi | 101 + arch/arm/dts/socfpga_n5x.dtsi | 640 ++++++ arch/arm/dts/socfpga_n5x_socdk-u-boot.dtsi | 67 + arch/arm/dts/socfpga_n5x_socdk.dts | 143 ++ arch/arm/mach-socfpga/Kconfig | 20 +- arch/arm/mach-socfpga/Makefile | 26 +- arch/arm/mach-socfpga/clock_manager_n5x.c | 80 + .../mach/{base_addr_s10.h => base_addr_soc64.h} | 11 +- arch/arm/mach-socfpga/include/mach/clock_manager.h | 3 + .../include/mach/clock_manager_agilex.h | 2 - .../include/mach/clock_manager_arria10.h | 1 - .../mach-socfpga/include/mach/clock_manager_gen5.h | 1 - .../mach-socfpga/include/mach/clock_manager_n5x.h | 12 + .../mach-socfpga/include/mach/clock_manager_s10.h | 1 - arch/arm/mach-socfpga/include/mach/firewall.h | 6 + arch/arm/mach-socfpga/include/mach/handoff_soc64.h | 28 + arch/arm/mach-socfpga/include/mach/misc.h | 4 + .../include/mach/system_manager_soc64.h | 10 +- arch/arm/mach-socfpga/misc.c | 3 + arch/arm/mach-socfpga/{misc_s10.c => misc_soc64.c} | 79 +- arch/arm/mach-socfpga/spl_n5x.c | 94 + arch/arm/mach-socfpga/wrap_handoff_soc64.c | 40 + board/intel/n5x-socdk/MAINTAINERS | 7 + board/intel/n5x-socdk/Makefile | 7 + board/intel/n5x-socdk/socfpga.c | 7 + configs/socfpga_n5x_atf_defconfig | 77 + configs/socfpga_n5x_defconfig | 65 + configs/socfpga_n5x_vab_defconfig | 79 + drivers/clk/altera/Makefile | 4 +- drivers/clk/altera/clk-mem-n5x.c | 136 ++ drivers/clk/altera/clk-mem-n5x.h | 84 + drivers/clk/altera/clk-n5x.c | 489 +++++ drivers/clk/altera/clk-n5x.h | 217 ++ drivers/ddr/altera/Makefile | 3 +- drivers/ddr/altera/sdram_n5x.c | 2316 ++++++++++++++++++++ drivers/ddr/altera/sdram_soc64.c | 28 +- include/configs/socfpga_n5x_socdk.h | 45 + include/configs/socfpga_soc64_common.h | 2 +- include/dt-bindings/clock/n5x-clock.h | 71 + 40 files changed, 4982 insertions(+), 28 deletions(-) create mode 100644 arch/arm/dts/socfpga_n5x-u-boot.dtsi create mode 100644 arch/arm/dts/socfpga_n5x.dtsi create mode 100644 arch/arm/dts/socfpga_n5x_socdk-u-boot.dtsi create mode 100644 arch/arm/dts/socfpga_n5x_socdk.dts create mode 100644 arch/arm/mach-socfpga/clock_manager_n5x.c rename arch/arm/mach-socfpga/include/mach/{base_addr_s10.h => base_addr_soc64.h} (85%) create mode 100644 arch/arm/mach-socfpga/include/mach/clock_manager_n5x.h rename arch/arm/mach-socfpga/{misc_s10.c => misc_soc64.c} (51%) create mode 100644 arch/arm/mach-socfpga/spl_n5x.c create mode 100644 board/intel/n5x-socdk/MAINTAINERS create mode 100644 board/intel/n5x-socdk/Makefile create mode 100644 board/intel/n5x-socdk/socfpga.c create mode 100644 configs/socfpga_n5x_atf_defconfig create mode 100644 configs/socfpga_n5x_defconfig create mode 100644 configs/socfpga_n5x_vab_defconfig create mode 100644 drivers/clk/altera/clk-mem-n5x.c create mode 100644 drivers/clk/altera/clk-mem-n5x.h create mode 100644 drivers/clk/altera/clk-n5x.c create mode 100644 drivers/clk/altera/clk-n5x.h create mode 100644 drivers/ddr/altera/sdram_n5x.c create mode 100644 include/configs/socfpga_n5x_socdk.h create mode 100644 include/dt-bindings/clock/n5x-clock.h
Rename to common file name to used by all SOC64 devices and change "_S10_" to "_SOC64_" in base_addr_soc64.h.
Signed-off-by: Siew Chin Lim elly.siew.chin.lim@intel.com --- .../include/mach/{base_addr_s10.h => base_addr_soc64.h} | 8 ++++---- include/configs/socfpga_soc64_common.h | 2 +- 2 files changed, 5 insertions(+), 5 deletions(-) rename arch/arm/mach-socfpga/include/mach/{base_addr_s10.h => base_addr_soc64.h} (89%)
diff --git a/arch/arm/mach-socfpga/include/mach/base_addr_s10.h b/arch/arm/mach-socfpga/include/mach/base_addr_soc64.h similarity index 89% rename from arch/arm/mach-socfpga/include/mach/base_addr_s10.h rename to arch/arm/mach-socfpga/include/mach/base_addr_soc64.h index d3eca65e97..f89066d771 100644 --- a/arch/arm/mach-socfpga/include/mach/base_addr_s10.h +++ b/arch/arm/mach-socfpga/include/mach/base_addr_soc64.h @@ -1,10 +1,10 @@ /* SPDX-License-Identifier: GPL-2.0 */ /* - * Copyright (C) 2016-2017 Intel Corporation <www.intel.com> + * Copyright (C) 2016-2021 Intel Corporation <www.intel.com> */
-#ifndef _SOCFPGA_S10_BASE_HARDWARE_H_ -#define _SOCFPGA_S10_BASE_HARDWARE_H_ +#ifndef _SOCFPGA_SOC64_BASE_HARDWARE_H_ +#define _SOCFPGA_SOC64_BASE_HARDWARE_H_
#define SOCFPGA_CCU_ADDRESS 0xf7000000 #define SOCFPGA_SDR_SCHEDULER_ADDRESS 0xf8000400 @@ -44,4 +44,4 @@ #define GICD_BASE 0xfffc1000 #define GICC_BASE 0xfffc2000
-#endif /* _SOCFPGA_S10_BASE_HARDWARE_H_ */ +#endif /* _SOCFPGA_SOC64_BASE_HARDWARE_H_ */ diff --git a/include/configs/socfpga_soc64_common.h b/include/configs/socfpga_soc64_common.h index 5afdb10454..f0b7884ebc 100644 --- a/include/configs/socfpga_soc64_common.h +++ b/include/configs/socfpga_soc64_common.h @@ -7,7 +7,7 @@ #ifndef __CONFIG_SOCFPGA_SOC64_COMMON_H__ #define __CONFIG_SOCFPGA_SOC64_COMMON_H__
-#include <asm/arch/base_addr_s10.h> +#include <asm/arch/base_addr_soc64.h> #include <asm/arch/handoff_soc64.h> #include <linux/stringify.h>
-----Original Message----- From: Lim, Elly Siew Chin elly.siew.chin.lim@intel.com Sent: Wednesday, March 31, 2021 10:39 PM To: u-boot@lists.denx.de Cc: Marek Vasut marex@denx.de; Tan, Ley Foon ley.foon.tan@intel.com; See, Chin Liang chin.liang.see@intel.com; Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Chee, Tien Fong tien.fong.chee@intel.com; Westergreen, Dalon dalon.westergreen@intel.com; Simon Glass sjg@chromium.org; Gan, Yau Wai yau.wai.gan@intel.com; Lim, Elly Siew Chin elly.siew.chin.lim@intel.com Subject: [v1 01/17] arm: socfpga: Changed base_addr_s10.h to base_addr_soc64.h
include/configs/socfpga_soc64_common.h | 2 +- 2 files changed, 5 insertions(+), 5 deletions(-) rename arch/arm/mach- socfpga/include/mach/{base_addr_s10.h => base_addr_soc64.h} (89%)
Reviewed-by: Ley Foon Tan ley.foon.tan@intel.com
Reuse base_addr_soc64.h for Intel N5X device, the address is the same as Agilex.
Signed-off-by: Siew Chin Lim elly.siew.chin.lim@intel.com --- arch/arm/mach-socfpga/include/mach/base_addr_soc64.h | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-socfpga/include/mach/base_addr_soc64.h b/arch/arm/mach-socfpga/include/mach/base_addr_soc64.h index f89066d771..3f899fcfa3 100644 --- a/arch/arm/mach-socfpga/include/mach/base_addr_soc64.h +++ b/arch/arm/mach-socfpga/include/mach/base_addr_soc64.h @@ -10,7 +10,8 @@ #define SOCFPGA_SDR_SCHEDULER_ADDRESS 0xf8000400 #define SOCFPGA_HMC_MMR_IO48_ADDRESS 0xf8010000 #define SOCFPGA_SDR_ADDRESS 0xf8011000 -#ifdef CONFIG_TARGET_SOCFPGA_AGILEX +#if IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX) || \ + IS_ENABLED(CONFIG_TARGET_SOCFPGA_N5X) #define SOCFPGA_FW_MPU_DDR_SCR_ADDRESS 0xf8020200 #else #define SOCFPGA_FW_MPU_DDR_SCR_ADDRESS 0xf8020100
-----Original Message----- From: Lim, Elly Siew Chin elly.siew.chin.lim@intel.com Sent: Wednesday, March 31, 2021 10:39 PM To: u-boot@lists.denx.de Cc: Marek Vasut marex@denx.de; Tan, Ley Foon ley.foon.tan@intel.com; See, Chin Liang chin.liang.see@intel.com; Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Chee, Tien Fong tien.fong.chee@intel.com; Westergreen, Dalon dalon.westergreen@intel.com; Simon Glass sjg@chromium.org; Gan, Yau Wai yau.wai.gan@intel.com; Lim, Elly Siew Chin elly.siew.chin.lim@intel.com Subject: [v1 02/17] arm: socfpga: Add base address for Intel N5X device
N5X support both HPS handoff data and DDR handoff data. HPS handoff data support re-use Straix10 and Agilex code. DDR handoff data is newly introduced for N5X.
Signed-off-by: Siew Chin Lim elly.siew.chin.lim@intel.com --- arch/arm/mach-socfpga/include/mach/handoff_soc64.h | 28 +++++++++++++++ arch/arm/mach-socfpga/wrap_handoff_soc64.c | 40 ++++++++++++++++++++++ 2 files changed, 68 insertions(+)
diff --git a/arch/arm/mach-socfpga/include/mach/handoff_soc64.h b/arch/arm/mach-socfpga/include/mach/handoff_soc64.h index 3750216a9a..82e230421f 100644 --- a/arch/arm/mach-socfpga/include/mach/handoff_soc64.h +++ b/arch/arm/mach-socfpga/include/mach/handoff_soc64.h @@ -23,8 +23,36 @@ #define SOC64_HANDOFF_OFFSET_DATA 0x10 #define SOC64_HANDOFF_SIZE 4096
+#if IS_ENABLED(CONFIG_TARGET_SOCFPGA_STRATIX10) || \ + IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX) #define SOC64_HANDOFF_BASE 0xFFE3F000 #define SOC64_HANDOFF_MISC (SOC64_HANDOFF_BASE + 0x610) +#elif IS_ENABLED(CONFIG_TARGET_SOCFPGA_N5X) +#define SOC64_HANDOFF_BASE 0xFFE5F000 +#define SOC64_HANDOFF_MISC (SOC64_HANDOFF_BASE + 0x630) + +/* DDR handoff */ +#define SOC64_HANDOFF_DDR_BASE 0xFFE5C000 +#define SOC64_HANDOFF_DDR_MAGIC 0x48524444 +#define SOC64_HANDOFF_DDR_UMCTL2_MAGIC 0x4C54434D +#define SOC64_HANDOFF_DDR_UMCTL2_DDR4_TYPE 0x34524444 +#define SOC64_HANDOFF_DDR_UMCTL2_LPDDR4_0_TYPE 0x3044504C +#define SOC64_HANDOFF_DDR_UMCTL2_LPDDR4_1_TYPE 0x3144504C +#define SOC64_HANDOFF_DDR_MEMRESET_BASE (SOC64_HANDOFF_DDR_BASE + 0xC) +#define SOC64_HANDOFF_DDR_UMCTL2_SECTION (SOC64_HANDOFF_DDR_BASE + 0x10) +#define SOC64_HANDOFF_DDR_PHY_MAGIC 0x43594850 +#define SOC64_HANDOFF_DDR_PHY_INIT_ENGINE_MAGIC 0x45594850 +#define SOC64_HANDOFF_DDR_PHY_BASE_OFFSET 0x8 +#define SOC64_HANDOFF_DDR_UMCTL2_TYPE_OFFSET 0x8 +#define SOC64_HANDOFF_DDR_UMCTL2_BASE_ADDR_OFFSET 0xC +#define SOC64_HANDOFF_DDR_TRAIN_IMEM_1D_SECTION 0xFFE50000 +#define SOC64_HANDOFF_DDR_TRAIN_DMEM_1D_SECTION 0xFFE58000 +#define SOC64_HANDOFF_DDR_TRAIN_IMEM_2D_SECTION 0xFFE44000 +#define SOC64_HANDOFF_DDR_TRAIN_DMEM_2D_SECTION 0xFFE4C000 +#define SOC64_HANDOFF_DDR_TRAIN_IMEM_LENGTH SZ_32K +#define SOC64_HANDOFF_DDR_TRAIN_DMEM_LENGTH SZ_16K +#endif + #define SOC64_HANDOFF_MUX (SOC64_HANDOFF_BASE + 0x10) #define SOC64_HANDOFF_IOCTL (SOC64_HANDOFF_BASE + 0x1A0) #define SOC64_HANDOFF_FPGA (SOC64_HANDOFF_BASE + 0x330) diff --git a/arch/arm/mach-socfpga/wrap_handoff_soc64.c b/arch/arm/mach-socfpga/wrap_handoff_soc64.c index a7ad7a18ed..37b4c360fb 100644 --- a/arch/arm/mach-socfpga/wrap_handoff_soc64.c +++ b/arch/arm/mach-socfpga/wrap_handoff_soc64.c @@ -60,6 +60,46 @@ int socfpga_handoff_read(void *handoff_address, void *table, u32 table_len, debug("at addr 0x%p\n", (u32 *)handoff_address); return -EPERM; } + } else { +#if IS_ENABLED(CONFIG_TARGET_SOCFPGA_N5X) + temp = readl(handoff_address); + if (temp == SOC64_HANDOFF_DDR_UMCTL2_MAGIC) { + debug("%s: umctl2 handoff data =\n{\n", + __func__); + } else if (temp == SOC64_HANDOFF_DDR_PHY_MAGIC) { + debug("%s: PHY handoff data =\n{\n", + __func__); + } else if (temp == SOC64_HANDOFF_DDR_PHY_INIT_ENGINE_MAGIC) { + debug("%s: PHY engine handoff data =\n{\n", + __func__); + } + + debug("handoff table address = 0x%p table length = 0x%x\n", + table_x32, table_len); + + if (temp == SOC64_HANDOFF_DDR_UMCTL2_MAGIC || + temp == SOC64_HANDOFF_DDR_PHY_MAGIC || + temp == SOC64_HANDOFF_DDR_PHY_INIT_ENGINE_MAGIC) { + for (i = 0; i < table_len; i++) { + *table_x32 = readl(handoff_address + + SOC64_HANDOFF_OFFSET_DATA + + (i * 4)); + + if (!(i % 2)) + debug(" No.%d Addr 0x%08x: ", i, + *table_x32); + else + debug(" 0x%08x\n", *table_x32); + + table_x32++; + } + debug("\n}\n"); + } else { + debug("%s: Cannot find HANDOFF MAGIC ", __func__); + debug("at addr 0x%p\n", (u32 *)handoff_address); + return -EPERM; + } +#endif }
-----Original Message----- From: Lim, Elly Siew Chin elly.siew.chin.lim@intel.com Sent: Wednesday, March 31, 2021 10:39 PM To: u-boot@lists.denx.de Cc: Marek Vasut marex@denx.de; Tan, Ley Foon ley.foon.tan@intel.com; See, Chin Liang chin.liang.see@intel.com; Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Chee, Tien Fong tien.fong.chee@intel.com; Westergreen, Dalon dalon.westergreen@intel.com; Simon Glass sjg@chromium.org; Gan, Yau Wai yau.wai.gan@intel.com; Lim, Elly Siew Chin elly.siew.chin.lim@intel.com Subject: [v1 03/17] arm: socfpga: Add handoff data support for Intel N5X device
- } else {
__func__);
__func__);
} else if (temp ==
__func__);
temp ==
- SOC64_HANDOFF_OFFSET_DATA +
(i * 4));
if (!(i % 2))
*table_x32);
else
table_x32++;
debug("\n}\n");
} else {
__func__);
return -EPERM;
+#endif }
1. Can we auto detect the endianness from the magic word? 2. Can merge or simplify the big and little endian flow? Do swap when it is big endian.
Regards Ley Foon
Regards Ley Foon
Hi Ley Foon,
-----Original Message----- From: Tan, Ley Foon ley.foon.tan@intel.com Sent: Monday, 5 April, 2021 3:17 PM To: Lim, Elly Siew Chin elly.siew.chin.lim@intel.com; u-boot@lists.denx.de Cc: Marek Vasut marex@denx.de; See, Chin Liang chin.liang.see@intel.com; Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Chee, Tien Fong tien.fong.chee@intel.com; Westergreen, Dalon dalon.westergreen@intel.com; Simon Glass sjg@chromium.org; Gan, Yau Wai yau.wai.gan@intel.com Subject: RE: [v1 03/17] arm: socfpga: Add handoff data support for Intel N5X device
- } else {
__func__);
__func__);
} else if (temp ==
__func__);
temp ==
(i * 4));
if (!(i % 2))
*table_x32);
else
table_x32++;
debug("\n}\n");
} else {
__func__);
return -EPERM;
+#endif }
- Can we auto detect the endianness from the magic word?
- Can merge or simplify the big and little endian flow? Do swap when it is big
endian.
Yes, we can do.
Regards, Tien Fong
Regards Ley Foon
Regards Ley Foon
Add clock manager driver for N5X. Provides clock initialization and get_rate functions.
Signed-off-by: Siew Chin Lim elly.siew.chin.lim@intel.com --- drivers/clk/altera/Makefile | 3 +- drivers/clk/altera/clk-n5x.c | 489 ++++++++++++++++++++++++++++++++++ drivers/clk/altera/clk-n5x.h | 217 +++++++++++++++ include/dt-bindings/clock/n5x-clock.h | 71 +++++ 4 files changed, 779 insertions(+), 1 deletion(-) create mode 100644 drivers/clk/altera/clk-n5x.c create mode 100644 drivers/clk/altera/clk-n5x.h create mode 100644 include/dt-bindings/clock/n5x-clock.h
diff --git a/drivers/clk/altera/Makefile b/drivers/clk/altera/Makefile index 96215ad5c4..38cd730685 100644 --- a/drivers/clk/altera/Makefile +++ b/drivers/clk/altera/Makefile @@ -1,7 +1,8 @@ # SPDX-License-Identifier: GPL-2.0+ # -# Copyright (C) 2018 Marek Vasut marex@denx.de +# Copyright (C) 2018-2021 Marek Vasut marex@denx.de #
obj-$(CONFIG_TARGET_SOCFPGA_AGILEX) += clk-agilex.o obj-$(CONFIG_TARGET_SOCFPGA_ARRIA10) += clk-arria10.o +obj-$(CONFIG_TARGET_SOCFPGA_N5X) += clk-n5x.o diff --git a/drivers/clk/altera/clk-n5x.c b/drivers/clk/altera/clk-n5x.c new file mode 100644 index 0000000000..12e6aa9ac2 --- /dev/null +++ b/drivers/clk/altera/clk-n5x.c @@ -0,0 +1,489 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020-2021 Intel Corporation <www.intel.com> + */ + +#include <common.h> +#include <asm/arch/clock_manager.h> +#include <asm/global_data.h> +#include <asm/io.h> +#include <clk-uclass.h> +#include <dm.h> +#include <dm/lists.h> +#include <dm/util.h> +#include <dt-bindings/clock/n5x-clock.h> + +DECLARE_GLOBAL_DATA_PTR; + +struct socfpga_clk_plat { + void __iomem *regs; +}; + +/* + * function to write the bypass register which requires a poll of the + * busy bit + */ +static void clk_write_bypass_mainpll(struct socfpga_clk_plat *plat, u32 val) +{ + CM_REG_WRITEL(plat, val, CLKMGR_MAINPLL_BYPASS); + cm_wait_for_fsm(); +} + +static void clk_write_bypass_perpll(struct socfpga_clk_plat *plat, u32 val) +{ + CM_REG_WRITEL(plat, val, CLKMGR_PERPLL_BYPASS); + cm_wait_for_fsm(); +} + +/* function to write the ctrl register which requires a poll of the busy bit */ +static void clk_write_ctrl(struct socfpga_clk_plat *plat, u32 val) +{ + CM_REG_WRITEL(plat, val, CLKMGR_CTRL); + cm_wait_for_fsm(); +} + +/* + * Setup clocks while making no assumptions about previous state of the clocks. + */ +static void clk_basic_init(struct udevice *dev, + const struct cm_config * const cfg) +{ + struct socfpga_clk_plat *plat = dev_get_plat(dev); + + if (!cfg) + return; + +#if IS_ENABLED(CONFIG_SPL_BUILD) + /* Always force clock manager into boot mode before any configuration */ + clk_write_ctrl(plat, + CM_REG_READL(plat, CLKMGR_CTRL) | CLKMGR_CTRL_BOOTMODE); +#else + /* Skip clock configuration in SSBL if it's not in boot mode */ + if (!(CM_REG_READL(plat, CLKMGR_CTRL) & CLKMGR_CTRL_BOOTMODE)) + return; +#endif + + /* Put both PLLs in bypass */ + clk_write_bypass_mainpll(plat, CLKMGR_BYPASS_MAINPLL_ALL); + clk_write_bypass_perpll(plat, CLKMGR_BYPASS_PERPLL_ALL); + + /* Put both PLLs in Reset */ + CM_REG_SETBITS(plat, CLKMGR_MAINPLL_PLLCTRL, + CLKMGR_PLLCTRL_BYPASS_MASK); + CM_REG_SETBITS(plat, CLKMGR_PERPLL_PLLCTRL, + CLKMGR_PLLCTRL_BYPASS_MASK); + + /* setup main PLL */ + CM_REG_WRITEL(plat, cfg->main_pll_pllglob, CLKMGR_MAINPLL_PLLGLOB); + CM_REG_WRITEL(plat, cfg->main_pll_plldiv, CLKMGR_MAINPLL_PLLDIV); + CM_REG_WRITEL(plat, cfg->main_pll_plloutdiv, CLKMGR_MAINPLL_PLLOUTDIV); + CM_REG_WRITEL(plat, cfg->main_pll_mpuclk, CLKMGR_MAINPLL_MPUCLK); + CM_REG_WRITEL(plat, cfg->main_pll_nocclk, CLKMGR_MAINPLL_NOCCLK); + CM_REG_WRITEL(plat, cfg->main_pll_nocdiv, CLKMGR_MAINPLL_NOCDIV); + + /* setup peripheral */ + CM_REG_WRITEL(plat, cfg->per_pll_pllglob, CLKMGR_PERPLL_PLLGLOB); + CM_REG_WRITEL(plat, cfg->per_pll_plldiv, CLKMGR_PERPLL_PLLDIV); + CM_REG_WRITEL(plat, cfg->per_pll_plloutdiv, CLKMGR_PERPLL_PLLOUTDIV); + CM_REG_WRITEL(plat, cfg->per_pll_emacctl, CLKMGR_PERPLL_EMACCTL); + CM_REG_WRITEL(plat, cfg->per_pll_gpiodiv, CLKMGR_PERPLL_GPIODIV); + + /* Take both PLL out of reset and power up */ + CM_REG_CLRBITS(plat, CLKMGR_MAINPLL_PLLCTRL, + CLKMGR_PLLCTRL_BYPASS_MASK); + CM_REG_CLRBITS(plat, CLKMGR_PERPLL_PLLCTRL, + CLKMGR_PLLCTRL_BYPASS_MASK); + + cm_wait_for_lock(CLKMGR_STAT_ALLPLL_LOCKED_MASK); + + CM_REG_WRITEL(plat, cfg->alt_emacactr, CLKMGR_ALTR_EMACACTR); + CM_REG_WRITEL(plat, cfg->alt_emacbctr, CLKMGR_ALTR_EMACBCTR); + CM_REG_WRITEL(plat, cfg->alt_emacptpctr, CLKMGR_ALTR_EMACPTPCTR); + CM_REG_WRITEL(plat, cfg->alt_gpiodbctr, CLKMGR_ALTR_GPIODBCTR); + CM_REG_WRITEL(plat, cfg->alt_sdmmcctr, CLKMGR_ALTR_SDMMCCTR); + CM_REG_WRITEL(plat, cfg->alt_s2fuser0ctr, CLKMGR_ALTR_S2FUSER0CTR); + CM_REG_WRITEL(plat, cfg->alt_s2fuser1ctr, CLKMGR_ALTR_S2FUSER1CTR); + CM_REG_WRITEL(plat, cfg->alt_psirefctr, CLKMGR_ALTR_PSIREFCTR); + + /* Configure ping pong counters in altera group */ + CM_REG_WRITEL(plat, CLKMGR_LOSTLOCK_SET_MASK, CLKMGR_MAINPLL_LOSTLOCK); + CM_REG_WRITEL(plat, CLKMGR_LOSTLOCK_SET_MASK, CLKMGR_PERPLL_LOSTLOCK); + + CM_REG_WRITEL(plat, CM_REG_READL(plat, CLKMGR_MAINPLL_PLLGLOB) | + CLKMGR_PLLGLOB_CLR_LOSTLOCK_BYPASS_MASK, + CLKMGR_MAINPLL_PLLGLOB); + CM_REG_WRITEL(plat, CM_REG_READL(plat, CLKMGR_PERPLL_PLLGLOB) | + CLKMGR_PLLGLOB_CLR_LOSTLOCK_BYPASS_MASK, + CLKMGR_PERPLL_PLLGLOB); + + /* Take all PLLs out of bypass */ + clk_write_bypass_mainpll(plat, 0); + clk_write_bypass_perpll(plat, 0); + + /* Clear the loss of lock bits (write 1 to clear) */ + CM_REG_CLRBITS(plat, CLKMGR_INTRCLR, + CLKMGR_INTER_PERPLLLOST_MASK | + CLKMGR_INTER_MAINPLLLOST_MASK); + + /* Take all ping pong counters out of reset */ + CM_REG_CLRBITS(plat, CLKMGR_ALTR_EXTCNTRST, + CLKMGR_ALT_EXTCNTRST_ALLCNTRST_MASK); + + /* Out of boot mode */ + clk_write_ctrl(plat, + CM_REG_READL(plat, CLKMGR_CTRL) & ~CLKMGR_CTRL_BOOTMODE); +} + +static u32 clk_get_5_1_clk_src(struct socfpga_clk_plat *plat, u32 reg) +{ + u32 clksrc = CM_REG_READL(plat, reg); + + return (clksrc & CLKMGR_CLKSRC_MASK) >> CLKMGR_CLKSRC_OFFSET; +} + +static u64 clk_get_pll_output_hz(struct socfpga_clk_plat *plat, + u32 pllglob_reg, u32 plldiv_reg) +{ + u64 clock = 0; + u32 clklsrc, divf, divr, divq, power = 1; + + /* Get input clock frequency */ + clklsrc = (CM_REG_READL(plat, pllglob_reg) & + CLKMGR_PLLGLOB_VCO_PSRC_MASK) >> + CLKMGR_PLLGLOB_VCO_PSRC_OFFSET; + + switch (clklsrc) { + case CLKMGR_VCO_PSRC_EOSC1: + clock = cm_get_osc_clk_hz(); + break; + case CLKMGR_VCO_PSRC_INTOSC: + clock = cm_get_intosc_clk_hz(); + break; + case CLKMGR_VCO_PSRC_F2S: + clock = cm_get_fpga_clk_hz(); + break; + } + + /* Calculate pll out clock frequency */ + divf = (CM_REG_READL(plat, plldiv_reg) & + CLKMGR_PLLDIV_FDIV_MASK) >> + CLKMGR_PLLDIV_FDIV_OFFSET; + + divr = (CM_REG_READL(plat, plldiv_reg) & + CLKMGR_PLLDIV_REFCLKDIV_MASK) >> + CLKMGR_PLLDIV_REFCLKDIV_OFFSET; + + divq = (CM_REG_READL(plat, plldiv_reg) & + CLKMGR_PLLDIV_OUTDIV_QDIV_MASK) >> + CLKMGR_PLLDIV_OUTDIV_QDIV_OFFSET; + + while (divq) { + power *= 2; + divq--; + } + + return ((clock * 2 * (divf + 1)) / ((divr + 1) * power)); +} + +static u64 clk_get_clksrc_hz(struct socfpga_clk_plat *plat, u32 clksrc_reg, + u32 main_div, u32 per_div) +{ + u64 clock = 0; + u32 clklsrc = clk_get_5_1_clk_src(plat, clksrc_reg); + + switch (clklsrc) { + case CLKMGR_CLKSRC_MAIN: + clock = clk_get_pll_output_hz(plat, + CLKMGR_MAINPLL_PLLGLOB, + CLKMGR_MAINPLL_PLLDIV); + clock /= 1 + main_div; + break; + + case CLKMGR_CLKSRC_PER: + clock = clk_get_pll_output_hz(plat, + CLKMGR_PERPLL_PLLGLOB, + CLKMGR_PERPLL_PLLDIV); + clock /= 1 + per_div; + break; + + case CLKMGR_CLKSRC_OSC1: + clock = cm_get_osc_clk_hz(); + break; + + case CLKMGR_CLKSRC_INTOSC: + clock = cm_get_intosc_clk_hz(); + break; + + case CLKMGR_CLKSRC_FPGA: + clock = cm_get_fpga_clk_hz(); + break; + default: + return 0; + } + + return clock; +} + +static u64 clk_get_mpu_clk_hz(struct socfpga_clk_plat *plat) +{ + u32 mainpll_c0cnt = (CM_REG_READL(plat, CLKMGR_MAINPLL_PLLOUTDIV) & + CLKMGR_PLLOUTDIV_C0CNT_MASK) >> + CLKMGR_PLLOUTDIV_C0CNT_OFFSET; + + u32 perpll_c0cnt = (CM_REG_READL(plat, CLKMGR_PERPLL_PLLOUTDIV) & + CLKMGR_PLLOUTDIV_C0CNT_MASK) >> + CLKMGR_PLLOUTDIV_C0CNT_OFFSET; + + u64 clock = clk_get_clksrc_hz(plat, CLKMGR_MAINPLL_MPUCLK, + mainpll_c0cnt, perpll_c0cnt); + + clock /= 1 + (CM_REG_READL(plat, CLKMGR_MAINPLL_MPUCLK) & + CLKMGR_CLKCNT_MSK); + + return clock; +} + +static u32 clk_get_l3_main_clk_hz(struct socfpga_clk_plat *plat) +{ + u32 mainpll_c1cnt = (CM_REG_READL(plat, CLKMGR_MAINPLL_PLLOUTDIV) & + CLKMGR_PLLOUTDIV_C1CNT_MASK) >> + CLKMGR_PLLOUTDIV_C1CNT_OFFSET; + + u32 perpll_c1cnt = (CM_REG_READL(plat, CLKMGR_PERPLL_PLLOUTDIV) & + CLKMGR_PLLOUTDIV_C1CNT_MASK) >> + CLKMGR_PLLOUTDIV_C1CNT_OFFSET; + + return clk_get_clksrc_hz(plat, CLKMGR_MAINPLL_NOCCLK, + mainpll_c1cnt, perpll_c1cnt); +} + +static u32 clk_get_l4_main_clk_hz(struct socfpga_clk_plat *plat) +{ + u64 clock = clk_get_l3_main_clk_hz(plat); + + clock /= BIT((CM_REG_READL(plat, CLKMGR_MAINPLL_NOCDIV) >> + CLKMGR_NOCDIV_L4MAIN_OFFSET) & + CLKMGR_NOCDIV_DIVIDER_MASK); + + return clock; +} + +static u32 clk_get_sdmmc_clk_hz(struct socfpga_clk_plat *plat) +{ + u32 mainpll_c3cnt = (CM_REG_READL(plat, CLKMGR_MAINPLL_PLLOUTDIV) & + CLKMGR_PLLOUTDIV_C3CNT_MASK) >> + CLKMGR_PLLOUTDIV_C3CNT_OFFSET; + + u32 perpll_c3cnt = (CM_REG_READL(plat, CLKMGR_PERPLL_PLLOUTDIV) & + CLKMGR_PLLOUTDIV_C3CNT_MASK) >> + CLKMGR_PLLOUTDIV_C3CNT_OFFSET; + + u64 clock = clk_get_clksrc_hz(plat, CLKMGR_ALTR_SDMMCCTR, + mainpll_c3cnt, perpll_c3cnt); + + clock /= 1 + (CM_REG_READL(plat, CLKMGR_ALTR_SDMMCCTR) & + CLKMGR_CLKCNT_MSK); + + return clock / 4; +} + +static u32 clk_get_l4_sp_clk_hz(struct socfpga_clk_plat *plat) +{ + u64 clock = clk_get_l3_main_clk_hz(plat); + + clock /= BIT((CM_REG_READL(plat, CLKMGR_MAINPLL_NOCDIV) >> + CLKMGR_NOCDIV_L4SPCLK_OFFSET) & + CLKMGR_NOCDIV_DIVIDER_MASK); + + return clock; +} + +static u32 clk_get_l4_mp_clk_hz(struct socfpga_clk_plat *plat) +{ + u64 clock = clk_get_l3_main_clk_hz(plat); + + clock /= BIT((CM_REG_READL(plat, CLKMGR_MAINPLL_NOCDIV) >> + CLKMGR_NOCDIV_L4MPCLK_OFFSET) & + CLKMGR_NOCDIV_DIVIDER_MASK); + + return clock; +} + +static u32 clk_get_l4_sys_free_clk_hz(struct socfpga_clk_plat *plat) +{ + if (CM_REG_READL(plat, CLKMGR_STAT) & CLKMGR_STAT_BOOTMODE) + return clk_get_l3_main_clk_hz(plat) / 2; + + return clk_get_l3_main_clk_hz(plat) / 4; +} + +static u32 clk_get_emac_clk_hz(struct socfpga_clk_plat *plat, u32 emac_id) +{ + bool emacsel_a; + u32 ctl; + u32 ctr_reg; + u32 clock; + u32 div; + u32 reg; + + /* Get EMAC clock source */ + ctl = CM_REG_READL(plat, CLKMGR_PERPLL_EMACCTL); + if (emac_id == N5X_EMAC0_CLK) + ctl = (ctl >> CLKMGR_PERPLLGRP_EMACCTL_EMAC0SELB_OFFSET) & + CLKMGR_PERPLLGRP_EMACCTL_EMAC0SELB_MASK; + else if (emac_id == N5X_EMAC1_CLK) + ctl = (ctl >> CLKMGR_PERPLLGRP_EMACCTL_EMAC1SELB_OFFSET) & + CLKMGR_PERPLLGRP_EMACCTL_EMAC1SELB_MASK; + else if (emac_id == N5X_EMAC2_CLK) + ctl = (ctl >> CLKMGR_PERPLLGRP_EMACCTL_EMAC2SELB_OFFSET) & + CLKMGR_PERPLLGRP_EMACCTL_EMAC2SELB_MASK; + else + return 0; + + if (ctl) { + /* EMAC B source */ + emacsel_a = false; + ctr_reg = CLKMGR_ALTR_EMACBCTR; + } else { + /* EMAC A source */ + emacsel_a = true; + ctr_reg = CLKMGR_ALTR_EMACACTR; + } + + reg = CM_REG_READL(plat, ctr_reg); + clock = (reg & CLKMGR_ALT_EMACCTR_SRC_MASK) + >> CLKMGR_ALT_EMACCTR_SRC_OFFSET; + div = (reg & CLKMGR_ALT_EMACCTR_CNT_MASK) + >> CLKMGR_ALT_EMACCTR_CNT_OFFSET; + + switch (clock) { + case CLKMGR_CLKSRC_MAIN: + clock = clk_get_pll_output_hz(plat, + CLKMGR_MAINPLL_PLLGLOB, + CLKMGR_MAINPLL_PLLDIV); + + if (emacsel_a) { + clock /= 1 + ((CM_REG_READL(plat, + CLKMGR_MAINPLL_PLLOUTDIV) & + CLKMGR_PLLOUTDIV_C2CNT_MASK) >> + CLKMGR_PLLOUTDIV_C2CNT_OFFSET); + } else { + clock /= 1 + ((CM_REG_READL(plat, + CLKMGR_MAINPLL_PLLOUTDIV) & + CLKMGR_PLLOUTDIV_C3CNT_MASK) >> + CLKMGR_PLLOUTDIV_C3CNT_OFFSET); + } + break; + + case CLKMGR_CLKSRC_PER: + clock = clk_get_pll_output_hz(plat, + CLKMGR_PERPLL_PLLGLOB, + CLKMGR_PERPLL_PLLDIV); + if (emacsel_a) { + clock /= 1 + ((CM_REG_READL(plat, + CLKMGR_PERPLL_PLLOUTDIV) & + CLKMGR_PLLOUTDIV_C2CNT_MASK) >> + CLKMGR_PLLOUTDIV_C2CNT_OFFSET); + } else { + clock /= 1 + ((CM_REG_READL(plat, + CLKMGR_PERPLL_PLLOUTDIV) & + CLKMGR_PLLOUTDIV_C3CNT_MASK >> + CLKMGR_PLLOUTDIV_C3CNT_OFFSET)); + } + break; + + case CLKMGR_CLKSRC_OSC1: + clock = cm_get_osc_clk_hz(); + break; + + case CLKMGR_CLKSRC_INTOSC: + clock = cm_get_intosc_clk_hz(); + break; + + case CLKMGR_CLKSRC_FPGA: + clock = cm_get_fpga_clk_hz(); + break; + } + + clock /= 1 + div; + + return clock; +} + +static ulong socfpga_clk_get_rate(struct clk *clk) +{ + struct socfpga_clk_plat *plat = dev_get_plat(clk->dev); + + switch (clk->id) { + case N5X_MPU_CLK: + return clk_get_mpu_clk_hz(plat); + case N5X_L4_MAIN_CLK: + return clk_get_l4_main_clk_hz(plat); + case N5X_L4_SYS_FREE_CLK: + return clk_get_l4_sys_free_clk_hz(plat); + case N5X_L4_MP_CLK: + return clk_get_l4_mp_clk_hz(plat); + case N5X_L4_SP_CLK: + return clk_get_l4_sp_clk_hz(plat); + case N5X_SDMMC_CLK: + return clk_get_sdmmc_clk_hz(plat); + case N5X_EMAC0_CLK: + case N5X_EMAC1_CLK: + case N5X_EMAC2_CLK: + return clk_get_emac_clk_hz(plat, clk->id); + case N5X_USB_CLK: + case N5X_NAND_X_CLK: + return clk_get_l4_mp_clk_hz(plat); + case N5X_NAND_CLK: + return clk_get_l4_mp_clk_hz(plat) / 4; + default: + return -ENXIO; + } +} + +static int socfpga_clk_enable(struct clk *clk) +{ + return 0; +} + +static int socfpga_clk_probe(struct udevice *dev) +{ + const struct cm_config *cm_default_cfg = cm_get_default_config(); + + clk_basic_init(dev, cm_default_cfg); + + return 0; +} + +static int socfpga_clk_of_to_plat(struct udevice *dev) +{ + struct socfpga_clk_plat *plat = dev_get_plat(dev); + fdt_addr_t addr; + + addr = devfdt_get_addr(dev); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + plat->regs = (void __iomem *)addr; + + return 0; +} + +static struct clk_ops socfpga_clk_ops = { + .enable = socfpga_clk_enable, + .get_rate = socfpga_clk_get_rate, +}; + +static const struct udevice_id socfpga_clk_match[] = { + { .compatible = "intel,n5x-clkmgr" }, + {} +}; + +U_BOOT_DRIVER(socfpga_n5x_clk) = { + .name = "clk-n5x", + .id = UCLASS_CLK, + .of_match = socfpga_clk_match, + .ops = &socfpga_clk_ops, + .probe = socfpga_clk_probe, + .of_to_plat = socfpga_clk_of_to_plat, + .plat_auto = sizeof(struct socfpga_clk_plat), +}; diff --git a/drivers/clk/altera/clk-n5x.h b/drivers/clk/altera/clk-n5x.h new file mode 100644 index 0000000000..58672d9102 --- /dev/null +++ b/drivers/clk/altera/clk-n5x.h @@ -0,0 +1,217 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2020-2021 Intel Corporation <www.intel.com> + */ + +#ifndef _CLK_N5X_ +#define _CLK_N5X_ + +#ifndef __ASSEMBLY__ +#include <linux/bitops.h> +#endif + +#define CM_REG_READL(plat, reg) \ + readl((plat)->regs + (reg)) + +#define CM_REG_WRITEL(plat, data, reg) \ + writel(data, (plat)->regs + (reg)) + +#define CM_REG_CLRBITS(plat, reg, clear) \ + clrbits_le32((plat)->regs + (reg), (clear)) + +#define CM_REG_SETBITS(plat, reg, set) \ + setbits_le32((plat)->regs + (reg), (set)) + +struct cm_config { + /* main group */ + u32 main_pll_mpuclk; + u32 main_pll_nocclk; + u32 main_pll_nocdiv; + u32 main_pll_pllglob; + u32 main_pll_plldiv; + u32 main_pll_plloutdiv; + u32 spare_1[4]; + + /* peripheral group */ + u32 per_pll_emacctl; + u32 per_pll_gpiodiv; + u32 per_pll_pllglob; + u32 per_pll_plldiv; + u32 per_pll_plloutdiv; + u32 spare_2[4]; + + /* altera group */ + u32 alt_emacactr; + u32 alt_emacbctr; + u32 alt_emacptpctr; + u32 alt_gpiodbctr; + u32 alt_sdmmcctr; + u32 alt_s2fuser0ctr; + u32 alt_s2fuser1ctr; + u32 alt_psirefctr; + + /* incoming clock */ + u32 hps_osc_clk_hz; + u32 fpga_clk_hz; + u32 spare_3[3]; + + /* memory clock group */ + u32 mem_memdiv; + u32 mem_pllglob; + u32 mem_plldiv; + u32 mem_plloutdiv; + u32 spare_4[4]; +}; + +/* Clock Manager registers */ +#define CLKMGR_CTRL 0 +#define CLKMGR_STAT 4 +#define CLKMGR_TESTIOCTRL 8 +#define CLKMGR_INTRGEN 0x0c +#define CLKMGR_INTRMSK 0x10 +#define CLKMGR_INTRCLR 0x14 +#define CLKMGR_INTRSTS 0x18 +#define CLKMGR_INTRSTK 0x1c +#define CLKMGR_INTRRAW 0x20 + +/* Clock Manager Main PPL group registers */ +#define CLKMGR_MAINPLL_EN 0x24 +#define CLKMGR_MAINPLL_ENS 0x28 +#define CLKMGR_MAINPLL_ENR 0x2c +#define CLKMGR_MAINPLL_BYPASS 0x30 +#define CLKMGR_MAINPLL_BYPASSS 0x34 +#define CLKMGR_MAINPLL_BYPASSR 0x38 +#define CLKMGR_MAINPLL_MPUCLK 0x3c +#define CLKMGR_MAINPLL_NOCCLK 0x40 +#define CLKMGR_MAINPLL_NOCDIV 0x44 +#define CLKMGR_MAINPLL_PLLGLOB 0x48 +#define CLKMGR_MAINPLL_PLLCTRL 0x4c +#define CLKMGR_MAINPLL_PLLDIV 0x50 +#define CLKMGR_MAINPLL_PLLOUTDIV 0x54 +#define CLKMGR_MAINPLL_LOSTLOCK 0x58 + +/* Clock Manager Peripheral PPL group registers */ +#define CLKMGR_PERPLL_EN 0x7c +#define CLKMGR_PERPLL_ENS 0x80 +#define CLKMGR_PERPLL_ENR 0x84 +#define CLKMGR_PERPLL_BYPASS 0x88 +#define CLKMGR_PERPLL_BYPASSS 0x8c +#define CLKMGR_PERPLL_BYPASSR 0x90 +#define CLKMGR_PERPLL_EMACCTL 0x94 +#define CLKMGR_PERPLL_GPIODIV 0x98 +#define CLKMGR_PERPLL_PLLGLOB 0x9c +#define CLKMGR_PERPLL_PLLCTRL 0xa0 +#define CLKMGR_PERPLL_PLLDIV 0xa4 +#define CLKMGR_PERPLL_PLLOUTDIV 0xa8 +#define CLKMGR_PERPLL_LOSTLOCK 0xac + +/* Clock Manager Altera group registers */ +#define CLKMGR_ALTR_EMACACTR 0xd4 +#define CLKMGR_ALTR_EMACBCTR 0xd8 +#define CLKMGR_ALTR_EMACPTPCTR 0xdc +#define CLKMGR_ALTR_GPIODBCTR 0xe0 +#define CLKMGR_ALTR_SDMMCCTR 0xe4 +#define CLKMGR_ALTR_S2FUSER0CTR 0xe8 +#define CLKMGR_ALTR_S2FUSER1CTR 0xec +#define CLKMGR_ALTR_PSIREFCTR 0xf0 +#define CLKMGR_ALTR_EXTCNTRST 0xf4 + +#define CLKMGR_CTRL_BOOTMODE BIT(0) + +#define CLKMGR_STAT_BUSY BIT(0) +#define CLKMGR_STAT_MAINPLL_LOCKED BIT(8) +#define CLKMGR_STAT_MAIN_TRANS BIT(9) +#define CLKMGR_STAT_PERPLL_LOCKED BIT(16) +#define CLKMGR_STAT_PERF_TRANS BIT(17) +#define CLKMGR_STAT_BOOTMODE BIT(24) +#define CLKMGR_STAT_BOOTCLKSRC BIT(25) + +#define CLKMGR_STAT_ALLPLL_LOCKED_MASK \ + (CLKMGR_STAT_MAINPLL_LOCKED | CLKMGR_STAT_PERPLL_LOCKED) + +#define CLKMGR_INTER_MAINPLLLOCKED_MASK 0x00000001 +#define CLKMGR_INTER_PERPLLLOCKED_MASK 0x00000002 +#define CLKMGR_INTER_MAINPLLLOST_MASK 0x00000004 +#define CLKMGR_INTER_PERPLLLOST_MASK 0x00000008 + +#define CLKMGR_CLKSRC_MASK GENMASK(18, 16) +#define CLKMGR_CLKSRC_OFFSET 16 +#define CLKMGR_CLKSRC_MAIN 0 +#define CLKMGR_CLKSRC_PER 1 +#define CLKMGR_CLKSRC_OSC1 2 +#define CLKMGR_CLKSRC_INTOSC 3 +#define CLKMGR_CLKSRC_FPGA 4 +#define CLKMGR_CLKCNT_MSK GENMASK(10, 0) + +#define CLKMGR_BYPASS_MAINPLL_ALL 0x7 +#define CLKMGR_BYPASS_PERPLL_ALL 0x7f + +#define CLKMGR_NOCDIV_L4MAIN_OFFSET 0 +#define CLKMGR_NOCDIV_L4MPCLK_OFFSET 8 +#define CLKMGR_NOCDIV_L4SPCLK_OFFSET 16 +#define CLKMGR_NOCDIV_CSATCLK_OFFSET 24 +#define CLKMGR_NOCDIV_CSTRACECLK_OFFSET 26 +#define CLKMGR_NOCDIV_CSPDBGCLK_OFFSET 28 +#define CLKMGR_NOCDIV_DIVIDER_MASK 0x3 + +#define CLKMGR_PLLGLOB_VCO_PSRC_MASK GENMASK(17, 16) +#define CLKMGR_PLLGLOB_VCO_PSRC_OFFSET 16 +#define CLKMGR_PLLGLOB_LOSTLOCK_BYPASS_EN_MASK BIT(28) +#define CLKMGR_PLLGLOB_CLR_LOSTLOCK_BYPASS_MASK BIT(29) + +#define CLKMGR_VCO_PSRC_EOSC1 0 +#define CLKMGR_VCO_PSRC_INTOSC 1 +#define CLKMGR_VCO_PSRC_F2S 2 + +#define CLKMGR_PLLCTRL_BYPASS_MASK BIT(0) +#define CLKMGR_PLLCTRL_RST_N_MASK BIT(1) + +#define CLKMGR_PLLDIV_REFCLKDIV_MASK GENMASK(5, 0) +#define CLKMGR_PLLDIV_FDIV_MASK GENMASK(16, 8) +#define CLKMGR_PLLDIV_OUTDIV_QDIV_MASK GENMASK(26, 24) +#define CLKMGR_PLLDIV_RANGE_MASK GENMASK(30, 28) + +#define CLKMGR_PLLDIV_REFCLKDIV_OFFSET 0 +#define CLKMGR_PLLDIV_FDIV_OFFSET 8 +#define CLKMGR_PLLDIV_OUTDIV_QDIV_OFFSET 24 +#define CLKMGR_PLLDIV_RANGE_OFFSET 28 + +#define CLKMGR_PLLOUTDIV_C0CNT_MASK GENMASK(4, 0) +#define CLKMGR_PLLOUTDIV_C1CNT_MASK GENMASK(12, 8) +#define CLKMGR_PLLOUTDIV_C2CNT_MASK GENMASK(20, 16) +#define CLKMGR_PLLOUTDIV_C3CNT_MASK GENMASK(28, 24) + +#define CLKMGR_PLLOUTDIV_C0CNT_OFFSET 0 +#define CLKMGR_PLLOUTDIV_C1CNT_OFFSET 8 +#define CLKMGR_PLLOUTDIV_C2CNT_OFFSET 16 +#define CLKMGR_PLLOUTDIV_C3CNT_OFFSET 24 + +#define CLKMGR_PLLCX_EN_SET_MSK BIT(27) +#define CLKMGR_PLLCX_MUTE_SET_MSK BIT(28) + +#define CLKMGR_VCOCALIB_MSCNT_MASK GENMASK(23, 16) +#define CLKMGR_VCOCALIB_MSCNT_OFFSET 16 +#define CLKMGR_VCOCALIB_HSCNT_MASK GENMASK(9, 0) +#define CLKMGR_VCOCALIB_MSCNT_CONST 100 +#define CLKMGR_VCOCALIB_HSCNT_CONST 4 + +#define CLKMGR_PLLM_MDIV_MASK GENMASK(9, 0) + +#define CLKMGR_LOSTLOCK_SET_MASK BIT(0) + +#define CLKMGR_PERPLLGRP_EN_SDMMCCLK_MASK BIT(5) +#define CLKMGR_PERPLLGRP_EMACCTL_EMAC0SELB_OFFSET 26 +#define CLKMGR_PERPLLGRP_EMACCTL_EMAC0SELB_MASK BIT(26) +#define CLKMGR_PERPLLGRP_EMACCTL_EMAC1SELB_OFFSET 27 +#define CLKMGR_PERPLLGRP_EMACCTL_EMAC1SELB_MASK BIT(27) +#define CLKMGR_PERPLLGRP_EMACCTL_EMAC2SELB_OFFSET 28 +#define CLKMGR_PERPLLGRP_EMACCTL_EMAC2SELB_MASK BIT(28) + +#define CLKMGR_ALT_EMACCTR_SRC_OFFSET 16 +#define CLKMGR_ALT_EMACCTR_SRC_MASK GENMASK(18, 16) +#define CLKMGR_ALT_EMACCTR_CNT_OFFSET 0 +#define CLKMGR_ALT_EMACCTR_CNT_MASK GENMASK(10, 0) + +#define CLKMGR_ALT_EXTCNTRST_ALLCNTRST_MASK GENMASK(15, 0) + +#endif /* _CLK_N5X_ */ diff --git a/include/dt-bindings/clock/n5x-clock.h b/include/dt-bindings/clock/n5x-clock.h new file mode 100644 index 0000000000..a56e4dba77 --- /dev/null +++ b/include/dt-bindings/clock/n5x-clock.h @@ -0,0 +1,71 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2020-2021, Intel Corporation + */ + +#ifndef __N5X_CLOCK_H +#define __N5X_CLOCK_H + +/* fixed rate clocks */ +#define N5X_OSC1 0 +#define N5X_CB_INTOSC_HS_DIV2_CLK 1 +#define N5X_CB_INTOSC_LS_CLK 2 +#define N5X_L4_SYS_FREE_CLK 3 +#define N5X_F2S_FREE_CLK 4 + +/* PLL clocks */ +#define N5X_MAIN_PLL_CLK 5 +#define N5X_MAIN_PLL_C0_CLK 6 +#define N5X_MAIN_PLL_C1_CLK 7 +#define N5X_MAIN_PLL_C2_CLK 8 +#define N5X_MAIN_PLL_C3_CLK 9 +#define N5X_PERIPH_PLL_CLK 10 +#define N5X_PERIPH_PLL_C0_CLK 11 +#define N5X_PERIPH_PLL_C1_CLK 12 +#define N5X_PERIPH_PLL_C2_CLK 13 +#define N5X_PERIPH_PLL_C3_CLK 14 +#define N5X_MPU_FREE_CLK 15 +#define N5X_MPU_CCU_CLK 16 +#define N5X_BOOT_CLK 17 + +/* fixed factor clocks */ +#define N5X_L3_MAIN_FREE_CLK 18 +#define N5X_NOC_FREE_CLK 19 +#define N5X_S2F_USR0_CLK 20 +#define N5X_NOC_CLK 21 +#define N5X_EMAC_A_FREE_CLK 22 +#define N5X_EMAC_B_FREE_CLK 23 +#define N5X_EMAC_PTP_FREE_CLK 24 +#define N5X_GPIO_DB_FREE_CLK 25 +#define N5X_SDMMC_FREE_CLK 26 +#define N5X_S2F_USER0_FREE_CLK 27 +#define N5X_S2F_USER1_FREE_CLK 28 +#define N5X_PSI_REF_FREE_CLK 29 + +/* Gate clocks */ +#define N5X_MPU_CLK 30 +#define N5X_MPU_PERIPH_CLK 31 +#define N5X_L4_MAIN_CLK 32 +#define N5X_L4_MP_CLK 33 +#define N5X_L4_SP_CLK 34 +#define N5X_CS_AT_CLK 35 +#define N5X_CS_TRACE_CLK 36 +#define N5X_CS_PDBG_CLK 37 +#define N5X_CS_TIMER_CLK 38 +#define N5X_S2F_USER0_CLK 39 +#define N5X_EMAC0_CLK 40 +#define N5X_EMAC1_CLK 41 +#define N5X_EMAC2_CLK 42 +#define N5X_EMAC_PTP_CLK 43 +#define N5X_GPIO_DB_CLK 44 +#define N5X_NAND_CLK 45 +#define N5X_PSI_REF_CLK 46 +#define N5X_S2F_USER1_CLK 47 +#define N5X_SDMMC_CLK 48 +#define N5X_SPI_M_CLK 49 +#define N5X_USB_CLK 50 +#define N5X_NAND_X_CLK 51 +#define N5X_NAND_ECC_CLK 52 +#define N5X_NUM_CLKS 53 + +#endif /* __N5X_CLOCK_H */
-----Original Message----- From: Lim, Elly Siew Chin elly.siew.chin.lim@intel.com Sent: Wednesday, March 31, 2021 10:39 PM To: u-boot@lists.denx.de Cc: Marek Vasut marex@denx.de; Tan, Ley Foon ley.foon.tan@intel.com; See, Chin Liang chin.liang.see@intel.com; Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Chee, Tien Fong tien.fong.chee@intel.com; Westergreen, Dalon dalon.westergreen@intel.com; Simon Glass sjg@chromium.org; Gan, Yau Wai yau.wai.gan@intel.com; Lim, Elly Siew Chin elly.siew.chin.lim@intel.com Subject: [v1 04/17] drivers: clk: Add clock driver for Intel N5X device
- Copyright (C) 2020-2021 Intel Corporation <www.intel.com> */
Sorting the include name.
- /* Take all PLLs out of bypass */
- clk_write_bypass_mainpll(plat, 0);
- clk_write_bypass_perpll(plat, 0);
- /* Clear the loss of lock bits (write 1 to clear) */
- CM_REG_CLRBITS(plat, CLKMGR_INTRCLR,
Comment "write 1 to clear" is valid?
- /* Take all ping pong counters out of reset */
- CM_REG_CLRBITS(plat, CLKMGR_ALTR_EXTCNTRST,
- /* Out of boot mode */
- clk_write_ctrl(plat,
~CLKMGR_CTRL_BOOTMODE); }
- u32 clksrc = CM_REG_READL(plat, reg);
- return (clksrc & CLKMGR_CLKSRC_MASK) >>
CLKMGR_CLKSRC_OFFSET; }
- u64 clock = 0;
- u32 clklsrc, divf, divr, divq, power = 1;
- /* Get input clock frequency */
- clklsrc = (CM_REG_READL(plat, pllglob_reg) &
Redundant () can be removed. Same for other code in this source file.
- switch (clklsrc) {
- case CLKMGR_VCO_PSRC_EOSC1:
break;
- case CLKMGR_VCO_PSRC_INTOSC:
break;
- case CLKMGR_VCO_PSRC_F2S:
break;
Regards Ley Foon
-----Original Message----- From: Tan, Ley Foon ley.foon.tan@intel.com Sent: Monday, April 5, 2021 3:37 PM To: Lim, Elly Siew Chin elly.siew.chin.lim@intel.com; u-boot@lists.denx.de Cc: Marek Vasut marex@denx.de; See, Chin Liang chin.liang.see@intel.com; Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Chee, Tien Fong tien.fong.chee@intel.com; Westergreen, Dalon dalon.westergreen@intel.com; Simon Glass sjg@chromium.org; Gan, Yau Wai yau.wai.gan@intel.com Subject: RE: [v1 04/17] drivers: clk: Add clock driver for Intel N5X device
+static u32 clk_get_5_1_clk_src(struct socfpga_clk_plat *plat, u32 +reg) {
u32 pllglob_reg, u32 plldiv_reg) {
- u64 clock = 0;
break;
break;
break;
Regards Ley Foon
Noted, I will update in next review.
Add N5X clock manager to socfpga_get_managers_addr function.
Signed-off-by: Siew Chin Lim elly.siew.chin.lim@intel.com --- arch/arm/mach-socfpga/misc.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/mach-socfpga/misc.c b/arch/arm/mach-socfpga/misc.c index 64a7c9d652..9305bec38a 100644 --- a/arch/arm/mach-socfpga/misc.c +++ b/arch/arm/mach-socfpga/misc.c @@ -254,6 +254,9 @@ void socfpga_get_managers_addr(void) #ifdef CONFIG_TARGET_SOCFPGA_AGILEX ret = socfpga_get_base_addr("intel,agilex-clkmgr", &socfpga_clkmgr_base); +#elif IS_ENABLED(CONFIG_TARGET_SOCFPGA_N5X) + ret = socfpga_get_base_addr("intel,n5x-clkmgr", + &socfpga_clkmgr_base); #else ret = socfpga_get_base_addr("altr,clk-mgr", &socfpga_clkmgr_base); #endif
-----Original Message----- From: Lim, Elly Siew Chin elly.siew.chin.lim@intel.com Sent: Wednesday, March 31, 2021 10:39 PM To: u-boot@lists.denx.de Cc: Marek Vasut marex@denx.de; Tan, Ley Foon ley.foon.tan@intel.com; See, Chin Liang chin.liang.see@intel.com; Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Chee, Tien Fong tien.fong.chee@intel.com; Westergreen, Dalon dalon.westergreen@intel.com; Simon Glass sjg@chromium.org; Gan, Yau Wai yau.wai.gan@intel.com; Lim, Elly Siew Chin elly.siew.chin.lim@intel.com Subject: [v1 05/17] arm: socfpga: Get clock manager base address for Intel N5X device
- ret = socfpga_get_base_addr("intel,n5x-clkmgr",
#endif
2.13.0
Add memory clock manager driver for N5X. Provides memory clock initialization and enable functions.
Signed-off-by: Siew Chin Lim elly.siew.chin.lim@intel.com --- drivers/clk/altera/Makefile | 1 + drivers/clk/altera/clk-mem-n5x.c | 136 +++++++++++++++++++++++++++++++++++++++ drivers/clk/altera/clk-mem-n5x.h | 84 ++++++++++++++++++++++++ 3 files changed, 221 insertions(+) create mode 100644 drivers/clk/altera/clk-mem-n5x.c create mode 100644 drivers/clk/altera/clk-mem-n5x.h
diff --git a/drivers/clk/altera/Makefile b/drivers/clk/altera/Makefile index 38cd730685..33db092918 100644 --- a/drivers/clk/altera/Makefile +++ b/drivers/clk/altera/Makefile @@ -6,3 +6,4 @@ obj-$(CONFIG_TARGET_SOCFPGA_AGILEX) += clk-agilex.o obj-$(CONFIG_TARGET_SOCFPGA_ARRIA10) += clk-arria10.o obj-$(CONFIG_TARGET_SOCFPGA_N5X) += clk-n5x.o +obj-$(CONFIG_TARGET_SOCFPGA_N5X) += clk-mem-n5x.o diff --git a/drivers/clk/altera/clk-mem-n5x.c b/drivers/clk/altera/clk-mem-n5x.c new file mode 100644 index 0000000000..ca44998641 --- /dev/null +++ b/drivers/clk/altera/clk-mem-n5x.c @@ -0,0 +1,136 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020-2021 Intel Corporation <www.intel.com> + */ + +#include <common.h> +#include <asm/arch/clock_manager.h> +#include <asm/global_data.h> +#include <asm/io.h> +#include "clk-mem-n5x.h" +#include <clk-uclass.h> +#include <dm.h> +#include <dm/lists.h> +#include <dm/util.h> +#include <dt-bindings/clock/n5x-clock.h> + +DECLARE_GLOBAL_DATA_PTR; + +struct socfpga_mem_clk_plat { + void __iomem *regs; +}; + +void clk_mem_wait_for_lock(struct socfpga_mem_clk_plat *plat, u32 mask) +{ + u32 inter_val; + u32 retry = 0; + + do { + inter_val = CM_REG_READL(plat, MEMCLKMGR_STAT) & mask; + + /* Wait for stable lock */ + if (inter_val == mask) + retry++; + else + retry = 0; + + if (retry >= 10) + return; + } while (1); +} + +/* + * function to write the bypass register which requires a poll of the + * busy bit + */ +void clk_mem_write_bypass_mempll(struct socfpga_mem_clk_plat *plat, u32 val) +{ + CM_REG_WRITEL(plat, val, MEMCLKMGR_MEMPLL_BYPASS); +} + +/* + * Setup clocks while making no assumptions about previous state of the clocks. + */ +static void clk_mem_basic_init(struct udevice *dev, + const struct cm_config * const cfg) +{ + struct socfpga_mem_clk_plat *plat = dev_get_plat(dev); + + if (!cfg) + return; + + /* Put PLLs in bypass */ + clk_mem_write_bypass_mempll(plat, MEMCLKMGR_BYPASS_MEMPLL_ALL); + + /* Put PLLs in Reset */ + CM_REG_SETBITS(plat, MEMCLKMGR_MEMPLL_PLLCTRL, + MEMCLKMGR_PLLCTRL_BYPASS_MASK); + + /* setup mem PLL */ + CM_REG_WRITEL(plat, cfg->mem_memdiv, MEMCLKMGR_MEMPLL_MEMDIV); + CM_REG_WRITEL(plat, cfg->mem_pllglob, MEMCLKMGR_MEMPLL_PLLGLOB); + CM_REG_WRITEL(plat, cfg->mem_plldiv, MEMCLKMGR_MEMPLL_PLLDIV); + CM_REG_WRITEL(plat, cfg->mem_plloutdiv, MEMCLKMGR_MEMPLL_PLLOUTDIV); + + /* Take PLL out of reset and power up */ + CM_REG_CLRBITS(plat, MEMCLKMGR_MEMPLL_PLLCTRL, + MEMCLKMGR_PLLCTRL_BYPASS_MASK); +} + +static int socfpga_mem_clk_enable(struct clk *clk) +{ + const struct cm_config *cm_default_cfg = cm_get_default_config(); + struct socfpga_mem_clk_plat *plat = dev_get_plat(clk->dev); + + clk_mem_basic_init(clk->dev, cm_default_cfg); + + clk_mem_wait_for_lock(plat, MEMCLKMGR_STAT_ALLPLL_LOCKED_MASK); + + CM_REG_WRITEL(plat, CM_REG_READL(plat, MEMCLKMGR_MEMPLL_PLLGLOB) | + MEMCLKMGR_PLLGLOB_CLR_LOSTLOCK_BYPASS_MASK, + MEMCLKMGR_MEMPLL_PLLGLOB); + + /* Take all PLLs out of bypass */ + clk_mem_write_bypass_mempll(plat, 0); + + /* Clear the loss of lock bits (write 1 to clear) */ + CM_REG_CLRBITS(plat, MEMCLKMGR_INTRCLR, + MEMCLKMGR_INTER_MEMPLLLOST_MASK); + + /* Take all ping pong counters out of reset */ + CM_REG_CLRBITS(plat, MEMCLKMGR_MEMPLL_EXTCNTRST, + MEMCLKMGR_EXTCNTRST_ALLCNTRST); + + return 0; +} + +static int socfpga_mem_clk_of_to_plat(struct udevice *dev) +{ + struct socfpga_mem_clk_plat *plat = dev_get_plat(dev); + fdt_addr_t addr; + + addr = devfdt_get_addr(dev); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + plat->regs = (void __iomem *)addr; + + return 0; +} + +static struct clk_ops socfpga_mem_clk_ops = { + .enable = socfpga_mem_clk_enable +}; + +static const struct udevice_id socfpga_mem_clk_match[] = { + { .compatible = "intel,n5x-mem-clkmgr" }, + {} +}; + +U_BOOT_DRIVER(socfpga_n5x_mem_clk) = { + .name = "mem-clk-n5x", + .id = UCLASS_CLK, + .of_match = socfpga_mem_clk_match, + .ops = &socfpga_mem_clk_ops, + .of_to_plat = socfpga_mem_clk_of_to_plat, + .plat_auto = sizeof(struct socfpga_mem_clk_plat), +}; diff --git a/drivers/clk/altera/clk-mem-n5x.h b/drivers/clk/altera/clk-mem-n5x.h new file mode 100644 index 0000000000..9c3745f69a --- /dev/null +++ b/drivers/clk/altera/clk-mem-n5x.h @@ -0,0 +1,84 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2020-2021 Intel Corporation <www.intel.com> + */ + +#ifndef _CLK_MEM_N5X_ +#define _CLK_MEM_N5X_ + +#ifndef __ASSEMBLY__ +#include <linux/bitops.h> +#endif + +/* Clock Manager registers */ +#define MEMCLKMGR_STAT 4 +#define MEMCLKMGR_INTRGEN 8 +#define MEMCLKMGR_INTRMSK 0x0C +#define MEMCLKMGR_INTRCLR 0x10 +#define MEMCLKMGR_INTRSTS 0x14 +#define MEMCLKMGR_INTRSTK 0x18 +#define MEMCLKMGR_INTRRAW 0x1C + +/* Memory Clock Manager PPL group registers */ +#define MEMCLKMGR_MEMPLL_EN 0x20 +#define MEMCLKMGR_MEMPLL_ENS 0x24 +#define MEMCLKMGR_MEMPLL_ENR 0x28 +#define MEMCLKMGR_MEMPLL_BYPASS 0x2c +#define MEMCLKMGR_MEMPLL_BYPASSS 0x30 +#define MEMCLKMGR_MEMPLL_BYPASSR 0x34 +#define MEMCLKMGR_MEMPLL_MEMDIV 0x38 +#define MEMCLKMGR_MEMPLL_PLLGLOB 0x3c +#define MEMCLKMGR_MEMPLL_PLLCTRL 0x40 +#define MEMCLKMGR_MEMPLL_PLLDIV 0x44 +#define MEMCLKMGR_MEMPLL_PLLOUTDIV 0x48 +#define MEMCLKMGR_MEMPLL_EXTCNTRST 0x4c + +#define MEMCLKMGR_CTRL_BOOTMODE BIT(0) + +#define MEMCLKMGR_STAT_MEMPLL_LOCKED BIT(8) + +#define MEMCLKMGR_STAT_ALLPLL_LOCKED_MASK \ + (MEMCLKMGR_STAT_MEMPLL_LOCKED) + +#define MEMCLKMGR_INTER_MEMPLLLOCKED_MASK 0x00000001 +#define MEMCLKMGR_INTER_MEMPLLLOST_MASK 0x00000004 + +#define MEMCLKMGR_BYPASS_MEMPLL_ALL 0x1 + +#define MEMCLKMGR_MEMDIV_MPFEDIV_OFFSET 0 +#define MEMCLKMGR_MEMDIV_APBDIV_OFFSET 4 +#define MEMCLKMGR_MEMDIV_DFICTRLDIV_OFFSET 8 +#define MEMCLKMGR_MEMDIV_DFIDIV_OFFSET 12 +#define MEMCLKMGR_MEMDIV_DFICTRLDIV_MASK 0x1 +#define MEMCLKMGR_MEMDIV_DIVIDER_MASK 0x3 + +#define MEMCLKMGR_PLLGLOB_PSRC_MASK GENMASK(17, 16) +#define MEMCLKMGR_PLLGLOB_PSRC_OFFSET 16 +#define MEMCLKMGR_PLLGLOB_LOSTLOCK_BYPASS_EN_MASK BIT(28) +#define MEMCLKMGR_PLLGLOB_CLR_LOSTLOCK_BYPASS_MASK BIT(29) + +#define MEMCLKMGR_PSRC_EOSC1 0 +#define MEMCLKMGR_PSRC_INTOSC 1 +#define MEMCLKMGR_PSRC_F2S 2 + +#define MEMCLKMGR_PLLCTRL_BYPASS_MASK BIT(0) +#define MEMCLKMGR_PLLCTRL_RST_N_MASK BIT(1) + +#define MEMCLKMGR_PLLDIV_DIVR_MASK GENMASK(5, 0) +#define MEMCLKMGR_PLLDIV_DIVF_MASK GENMASK(16, 8) +#define MEMCLKMGR_PLLDIV_DIVQ_MASK GENMASK(26, 24) +#define MEMCLKMGR_PLLDIV_RANGE_MASK GENMASK(30, 28) + +#define MEMCLKMGR_PLLDIV_DIVR_OFFSET 0 +#define MEMCLKMGR_PLLDIV_DIVF_OFFSET 8 +#define MEMCLKMGR_PLLDIV_DIVQ_QDIV_OFFSET 24 +#define MEMCLKMGR_PLLDIV_RANGE_OFFSET 28 + +#define MEMCLKMGR_PLLOUTDIV_C0CNT_MASK GENMASK(4, 0) +#define MEMCLKMGR_PLLOUTDIV_C0CNT_OFFSET 0 + +#define MEMCLKMGR_EXTCNTRST_C0CNTRST BIT(7) +#define MEMCLKMGR_EXTCNTRST_ALLCNTRST \ + (MEMCLKMGR_EXTCNTRST_C0CNTRST) + +#endif /* _CLK_MEM_N5X_ */
-----Original Message----- From: Lim, Elly Siew Chin elly.siew.chin.lim@intel.com Sent: Wednesday, March 31, 2021 10:39 PM To: u-boot@lists.denx.de Cc: Marek Vasut marex@denx.de; Tan, Ley Foon ley.foon.tan@intel.com; See, Chin Liang chin.liang.see@intel.com; Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Chee, Tien Fong tien.fong.chee@intel.com; Westergreen, Dalon dalon.westergreen@intel.com; Simon Glass sjg@chromium.org; Gan, Yau Wai yau.wai.gan@intel.com; Lim, Elly Siew Chin elly.siew.chin.lim@intel.com Subject: [v1 06/17] drivers: clk: Add memory clock driver for Intel N5X device
diff --git a/drivers/clk/altera/Makefile b/drivers/clk/altera/Makefile index 38cd730685..33db092918 100644 --- a/drivers/clk/altera/Makefile +++ b/drivers/clk/altera/Makefile @@ -6,3 +6,4 @@ obj-$(CONFIG_TARGET_SOCFPGA_AGILEX) += clk-agilex.o obj-$(CONFIG_TARGET_SOCFPGA_ARRIA10) += clk-arria10.o obj-$(CONFIG_TARGET_SOCFPGA_N5X) += clk-n5x.o +obj-$(CONFIG_TARGET_SOCFPGA_N5X) += clk-mem-n5x.o diff --git a/drivers/clk/altera/clk-mem-n5x.c b/drivers/clk/altera/clk-mem- n5x.c new file mode 100644 index 0000000000..ca44998641 --- /dev/null +++ b/drivers/clk/altera/clk-mem-n5x.c @@ -0,0 +1,136 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
- void __iomem *regs;
For consistency, use small letter for 0x0C.
Same here.
- (MEMCLKMGR_STAT_MEMPLL_LOCKED)
- (MEMCLKMGR_EXTCNTRST_C0CNTRST)
2.13.0
-----Original Message----- From: Tan, Ley Foon ley.foon.tan@intel.com Sent: Thursday, April 8, 2021 6:32 PM To: Lim, Elly Siew Chin elly.siew.chin.lim@intel.com; u-boot@lists.denx.de Cc: Marek Vasut marex@denx.de; See, Chin Liang chin.liang.see@intel.com; Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Chee, Tien Fong tien.fong.chee@intel.com; Westergreen, Dalon dalon.westergreen@intel.com; Simon Glass sjg@chromium.org; Gan, Yau Wai yau.wai.gan@intel.com Subject: RE: [v1 06/17] drivers: clk: Add memory clock driver for Intel N5X device
Same here.
0
GENMASK(5,
GENMASK(16,
GENMASK(26,
2.13.0
Noted, I will update the code in new review.
Move cm_get_mpu_clk_hz function declaration from individual device's clock manager header file to common clock_manager.h.
Signed-off-by: Siew Chin Lim elly.siew.chin.lim@intel.com --- arch/arm/mach-socfpga/include/mach/clock_manager.h | 1 + arch/arm/mach-socfpga/include/mach/clock_manager_agilex.h | 2 -- arch/arm/mach-socfpga/include/mach/clock_manager_arria10.h | 1 - arch/arm/mach-socfpga/include/mach/clock_manager_gen5.h | 1 - arch/arm/mach-socfpga/include/mach/clock_manager_s10.h | 1 - 5 files changed, 1 insertion(+), 5 deletions(-)
diff --git a/arch/arm/mach-socfpga/include/mach/clock_manager.h b/arch/arm/mach-socfpga/include/mach/clock_manager.h index 2f9b471af3..d0b172a30e 100644 --- a/arch/arm/mach-socfpga/include/mach/clock_manager.h +++ b/arch/arm/mach-socfpga/include/mach/clock_manager.h @@ -12,6 +12,7 @@ phys_addr_t socfpga_get_clkmgr_addr(void); void cm_wait_for_lock(u32 mask); int cm_wait_for_fsm(void); void cm_print_clock_quick_summary(void); +unsigned long cm_get_mpu_clk_hz(void); unsigned int cm_get_qspi_controller_clk_hz(void);
#if defined(CONFIG_TARGET_SOCFPGA_SOC64) diff --git a/arch/arm/mach-socfpga/include/mach/clock_manager_agilex.h b/arch/arm/mach-socfpga/include/mach/clock_manager_agilex.h index 386e82a4e3..4feae3dda9 100644 --- a/arch/arm/mach-socfpga/include/mach/clock_manager_agilex.h +++ b/arch/arm/mach-socfpga/include/mach/clock_manager_agilex.h @@ -6,8 +6,6 @@ #ifndef _CLOCK_MANAGER_AGILEX_ #define _CLOCK_MANAGER_AGILEX_
-unsigned long cm_get_mpu_clk_hz(void); - #include <asm/arch/clock_manager_soc64.h> #include "../../../../../drivers/clk/altera/clk-agilex.h"
diff --git a/arch/arm/mach-socfpga/include/mach/clock_manager_arria10.h b/arch/arm/mach-socfpga/include/mach/clock_manager_arria10.h index 798d3741bd..553ebe660d 100644 --- a/arch/arm/mach-socfpga/include/mach/clock_manager_arria10.h +++ b/arch/arm/mach-socfpga/include/mach/clock_manager_arria10.h @@ -68,7 +68,6 @@ int cm_basic_init(const void *blob);
#include <linux/bitops.h> unsigned int cm_get_l4_sp_clk_hz(void); -unsigned long cm_get_mpu_clk_hz(void);
#endif /* __ASSEMBLY__ */
diff --git a/arch/arm/mach-socfpga/include/mach/clock_manager_gen5.h b/arch/arm/mach-socfpga/include/mach/clock_manager_gen5.h index 4cc1268b4c..d53095a7da 100644 --- a/arch/arm/mach-socfpga/include/mach/clock_manager_gen5.h +++ b/arch/arm/mach-socfpga/include/mach/clock_manager_gen5.h @@ -96,7 +96,6 @@ struct cm_config { #define CLKMGR_PERPLL_EN CLKMGR_GEN5_PERPLL_EN
/* Clock speed accessors */ -unsigned long cm_get_mpu_clk_hz(void); unsigned long cm_get_sdram_clk_hz(void); unsigned int cm_get_l4_sp_clk_hz(void); unsigned int cm_get_mmc_controller_clk_hz(void); diff --git a/arch/arm/mach-socfpga/include/mach/clock_manager_s10.h b/arch/arm/mach-socfpga/include/mach/clock_manager_s10.h index 98c3bf1b03..7f10296dc7 100644 --- a/arch/arm/mach-socfpga/include/mach/clock_manager_s10.h +++ b/arch/arm/mach-socfpga/include/mach/clock_manager_s10.h @@ -11,7 +11,6 @@ #include <linux/bitops.h>
-----Original Message----- From: Lim, Elly Siew Chin elly.siew.chin.lim@intel.com Sent: Wednesday, March 31, 2021 10:39 PM To: u-boot@lists.denx.de Cc: Marek Vasut marex@denx.de; Tan, Ley Foon ley.foon.tan@intel.com; See, Chin Liang chin.liang.see@intel.com; Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Chee, Tien Fong tien.fong.chee@intel.com; Westergreen, Dalon dalon.westergreen@intel.com; Simon Glass sjg@chromium.org; Gan, Yau Wai yau.wai.gan@intel.com; Lim, Elly Siew Chin elly.siew.chin.lim@intel.com Subject: [v1 07/17] arm: socfpga: Move cm_get_mpu_clk_hz function declaration to clock_manager.h
Add clock manager for N5X.
Signed-off-by: Siew Chin Lim elly.siew.chin.lim@intel.com --- ...{clock_manager_agilex.c => clock_manager_n5x.c} | 32 ++++++++++------------ arch/arm/mach-socfpga/include/mach/clock_manager.h | 2 ++ .../mach-socfpga/include/mach/clock_manager_n5x.h | 12 ++++++++ 3 files changed, 29 insertions(+), 17 deletions(-) copy arch/arm/mach-socfpga/{clock_manager_agilex.c => clock_manager_n5x.c} (64%) create mode 100644 arch/arm/mach-socfpga/include/mach/clock_manager_n5x.h
diff --git a/arch/arm/mach-socfpga/clock_manager_agilex.c b/arch/arm/mach-socfpga/clock_manager_n5x.c similarity index 64% copy from arch/arm/mach-socfpga/clock_manager_agilex.c copy to arch/arm/mach-socfpga/clock_manager_n5x.c index e035c09aae..4f098533e7 100644 --- a/arch/arm/mach-socfpga/clock_manager_agilex.c +++ b/arch/arm/mach-socfpga/clock_manager_n5x.c @@ -1,19 +1,18 @@ // SPDX-License-Identifier: GPL-2.0 /* - * Copyright (C) 2019 Intel Corporation <www.intel.com> + * Copyright (C) 2020-2021 Intel Corporation <www.intel.com> * */
-#include <clk.h> #include <common.h> -#include <dm.h> -#include <log.h> -#include <malloc.h> #include <asm/arch/clock_manager.h> #include <asm/arch/system_manager.h> #include <asm/global_data.h> #include <asm/io.h> -#include <dt-bindings/clock/agilex-clock.h> +#include <clk.h> +#include <dm.h> +#include <dt-bindings/clock/n5x-clock.h> +#include <malloc.h>
@@ -25,7 +24,7 @@ static ulong cm_get_rate_dm(u32 id) int ret;
ret = uclass_get_device_by_driver(UCLASS_CLK, - DM_DRIVER_GET(socfpga_agilex_clk), + DM_DRIVER_GET(socfpga_n5x_clk), &dev); if (ret) return 0; @@ -39,8 +38,7 @@ static ulong cm_get_rate_dm(u32 id)
clk_free(&clk);
- if ((rate == (unsigned long)-ENOSYS) || - (rate == (unsigned long)-ENXIO) || + if ((rate == (unsigned long)-ENXIO) || (rate == (unsigned long)-EIO)) { debug("%s id %u: clk_get_rate err: %ld\n", __func__, id, rate); @@ -57,26 +55,26 @@ static u32 cm_get_rate_dm_khz(u32 id)
unsigned long cm_get_mpu_clk_hz(void) { - return cm_get_rate_dm(AGILEX_MPU_CLK); + return cm_get_rate_dm(N5X_MPU_CLK); }
unsigned int cm_get_l4_sys_free_clk_hz(void) { - return cm_get_rate_dm(AGILEX_L4_SYS_FREE_CLK); + return cm_get_rate_dm(N5X_L4_SYS_FREE_CLK); }
void cm_print_clock_quick_summary(void) { printf("MPU %10d kHz\n", - cm_get_rate_dm_khz(AGILEX_MPU_CLK)); + cm_get_rate_dm_khz(N5X_MPU_CLK)); printf("L4 Main %8d kHz\n", - cm_get_rate_dm_khz(AGILEX_L4_MAIN_CLK)); + cm_get_rate_dm_khz(N5X_L4_MAIN_CLK)); printf("L4 sys free %8d kHz\n", - cm_get_rate_dm_khz(AGILEX_L4_SYS_FREE_CLK)); + cm_get_rate_dm_khz(N5X_L4_SYS_FREE_CLK)); printf("L4 MP %8d kHz\n", - cm_get_rate_dm_khz(AGILEX_L4_MP_CLK)); + cm_get_rate_dm_khz(N5X_L4_MP_CLK)); printf("L4 SP %8d kHz\n", - cm_get_rate_dm_khz(AGILEX_L4_SP_CLK)); + cm_get_rate_dm_khz(N5X_L4_SP_CLK)); printf("SDMMC %8d kHz\n", - cm_get_rate_dm_khz(AGILEX_SDMMC_CLK)); + cm_get_rate_dm_khz(N5X_SDMMC_CLK)); } diff --git a/arch/arm/mach-socfpga/include/mach/clock_manager.h b/arch/arm/mach-socfpga/include/mach/clock_manager.h index d0b172a30e..a8cb07a1c4 100644 --- a/arch/arm/mach-socfpga/include/mach/clock_manager.h +++ b/arch/arm/mach-socfpga/include/mach/clock_manager.h @@ -28,6 +28,8 @@ int cm_set_qspi_controller_clk_hz(u32 clk_hz); #include <asm/arch/clock_manager_s10.h> #elif defined(CONFIG_TARGET_SOCFPGA_AGILEX) #include <asm/arch/clock_manager_agilex.h> +#elif IS_ENABLED(CONFIG_TARGET_SOCFPGA_N5X) +#include <asm/arch/clock_manager_n5x.h> #endif
#endif /* _CLOCK_MANAGER_H_ */ diff --git a/arch/arm/mach-socfpga/include/mach/clock_manager_n5x.h b/arch/arm/mach-socfpga/include/mach/clock_manager_n5x.h new file mode 100644 index 0000000000..54615ae8f7 --- /dev/null +++ b/arch/arm/mach-socfpga/include/mach/clock_manager_n5x.h @@ -0,0 +1,12 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2020-2021 Intel Corporation <www.intel.com> + */ + +#ifndef _CLOCK_MANAGER_N5X_ +#define _CLOCK_MANAGER_N5X_ + +#include <asm/arch/clock_manager_soc64.h> +#include "../../../../../drivers/clk/altera/clk-n5x.h" + +#endif /* _CLOCK_MANAGER_N5X_ */
-----Original Message----- From: Lim, Elly Siew Chin elly.siew.chin.lim@intel.com Sent: Wednesday, March 31, 2021 10:39 PM To: u-boot@lists.denx.de Cc: Marek Vasut marex@denx.de; Tan, Ley Foon ley.foon.tan@intel.com; See, Chin Liang chin.liang.see@intel.com; Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Chee, Tien Fong tien.fong.chee@intel.com; Westergreen, Dalon dalon.westergreen@intel.com; Simon Glass sjg@chromium.org; Gan, Yau Wai yau.wai.gan@intel.com; Lim, Elly Siew Chin elly.siew.chin.lim@intel.com Subject: [v1 08/17] arm: socfpga: Add clock manager for Intel N5X device
...{clock_manager_agilex.c => clock_manager_n5x.c} | 32 ++++++++++------- ----- arch/arm/mach-socfpga/include/mach/clock_manager.h | 2 ++ .../mach-socfpga/include/mach/clock_manager_n5x.h | 12 ++++++++ 3 files changed, 29 insertions(+), 17 deletions(-) copy arch/arm/mach- socfpga/{clock_manager_agilex.c => clock_manager_n5x.c} (64%) create mode 100644 arch/arm/mach-socfpga/include/mach/clock_manager_n5x.h
Rename to common file name to used by all SOC64 devices. No functionality change.
Signed-off-by: Siew Chin Lim elly.siew.chin.lim@intel.com --- arch/arm/mach-socfpga/Makefile | 4 ++-- arch/arm/mach-socfpga/{misc_s10.c => misc_soc64.c} | 12 ++++++------ 2 files changed, 8 insertions(+), 8 deletions(-) rename arch/arm/mach-socfpga/{misc_s10.c => misc_soc64.c} (100%)
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index 5779c55621..58afde950f 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -32,7 +32,7 @@ ifdef CONFIG_TARGET_SOCFPGA_STRATIX10 obj-y += clock_manager_s10.o obj-y += lowlevel_init_soc64.o obj-y += mailbox_s10.o -obj-y += misc_s10.o +obj-y += misc_soc64.o obj-y += mmu-arm64_s10.o obj-y += reset_manager_s10.o obj-y += system_manager_soc64.o @@ -45,7 +45,7 @@ ifdef CONFIG_TARGET_SOCFPGA_AGILEX obj-y += clock_manager_agilex.o obj-y += lowlevel_init_soc64.o obj-y += mailbox_s10.o -obj-y += misc_s10.o +obj-y += misc_soc64.o obj-y += mmu-arm64_s10.o obj-y += reset_manager_s10.o obj-$(CONFIG_SOCFPGA_SECURE_VAB_AUTH) += secure_vab.o diff --git a/arch/arm/mach-socfpga/misc_s10.c b/arch/arm/mach-socfpga/misc_soc64.c similarity index 100% rename from arch/arm/mach-socfpga/misc_s10.c rename to arch/arm/mach-socfpga/misc_soc64.c index 50c7f19ae1..7b973a79e8 100644 --- a/arch/arm/mach-socfpga/misc_s10.c +++ b/arch/arm/mach-socfpga/misc_soc64.c @@ -6,16 +6,16 @@
#include <altera.h> #include <common.h> -#include <env.h> -#include <errno.h> -#include <init.h> -#include <log.h> -#include <asm/global_data.h> -#include <asm/io.h> #include <asm/arch/mailbox_s10.h> #include <asm/arch/misc.h> #include <asm/arch/reset_manager.h> #include <asm/arch/system_manager.h> +#include <asm/io.h> +#include <asm/global_data.h> +#include <env.h> +#include <errno.h> +#include <init.h> +#include <log.h>
-----Original Message----- From: Lim, Elly Siew Chin elly.siew.chin.lim@intel.com Sent: Wednesday, March 31, 2021 10:39 PM To: u-boot@lists.denx.de Cc: Marek Vasut marex@denx.de; Tan, Ley Foon ley.foon.tan@intel.com; See, Chin Liang chin.liang.see@intel.com; Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Chee, Tien Fong tien.fong.chee@intel.com; Westergreen, Dalon dalon.westergreen@intel.com; Simon Glass sjg@chromium.org; Gan, Yau Wai yau.wai.gan@intel.com; Lim, Elly Siew Chin elly.siew.chin.lim@intel.com Subject: [v1 09/17] arm: socfpga: Changed misc_s10.c to misc_soc64.c
Add is_ddr_init_skipped function to check if need to skip DDR initialization for N5X. This patch is preparation for N5X DDR driver support.
Signed-off-by: Siew Chin Lim elly.siew.chin.lim@intel.com Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- arch/arm/mach-socfpga/include/mach/misc.h | 4 ++ arch/arm/mach-socfpga/misc_soc64.c | 67 ++++++++++++++++++++++++++++++- 2 files changed, 70 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-socfpga/include/mach/misc.h b/arch/arm/mach-socfpga/include/mach/misc.h index 649d2f6ce2..c41b7c14cd 100644 --- a/arch/arm/mach-socfpga/include/mach/misc.h +++ b/arch/arm/mach-socfpga/include/mach/misc.h @@ -44,6 +44,10 @@ void socfpga_sdram_remap_zero(void); int is_fpga_config_ready(void); #endif
+#if IS_ENABLED(CONFIG_TARGET_SOCFPGA_N5X) +bool is_ddr_init_skipped(void); +#endif + void do_bridge_reset(int enable, unsigned int mask); void socfpga_pl310_clear(void); void socfpga_get_managers_addr(void); diff --git a/arch/arm/mach-socfpga/misc_soc64.c b/arch/arm/mach-socfpga/misc_soc64.c index 7b973a79e8..d3945e55aa 100644 --- a/arch/arm/mach-socfpga/misc_soc64.c +++ b/arch/arm/mach-socfpga/misc_soc64.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0 /* - * Copyright (C) 2016-2018 Intel Corporation <www.intel.com> + * Copyright (C) 2016-2021 Intel Corporation <www.intel.com> * */
@@ -19,6 +19,13 @@
+/* Reset type */ +enum reset_type { + POR_RESET, + WARM_RESET, + COLD_RESET +}; + /* * FPGA programming support for SoC FPGA Stratix 10 */ @@ -88,3 +95,61 @@ void do_bridge_reset(int enable, unsigned int mask)
socfpga_bridges_reset(enable); } + +#if IS_ENABLED(CONFIG_TARGET_SOCFPGA_N5X) +static bool is_ddr_retention_enabled(u32 boot_scratch_cold0_reg) +{ + return boot_scratch_cold0_reg & + ALT_SYSMGR_SCRATCH_REG_0_DDR_RETENTION_MASK; +} + +static bool is_ddr_bitstream_sha_matching(u32 boot_scratch_cold0_reg) +{ + return boot_scratch_cold0_reg & ALT_SYSMGR_SCRATCH_REG_0_DDR_SHA_MASK; +} + +static enum reset_type get_reset_type(u32 boot_scratch_cold0_reg) +{ + return (boot_scratch_cold0_reg & + ALT_SYSMGR_SCRATCH_REG_0_DDR_RESET_TYPE_MASK) >> + ALT_SYSMGR_SCRATCH_REG_0_DDR_RESET_TYPE_SHIFT; +} + +bool is_ddr_init_skipped(void) +{ + u32 reg = readl(socfpga_get_sysmgr_addr() + + SYSMGR_SOC64_BOOT_SCRATCH_COLD0); + + if (get_reset_type(reg) == POR_RESET) { + debug("%s: POR reset is triggered\n", __func__); + debug("%s: DDR init is required\n", __func__); + return false; + } + + if (get_reset_type(reg) == WARM_RESET) { + debug("%s: Warm reset is triggered\n", __func__); + debug("%s: DDR init is skipped\n", __func__); + return true; + } + + if (get_reset_type(reg) == COLD_RESET) { + debug("%s: Cold reset is triggered\n", __func__); + + if (is_ddr_retention_enabled(reg)) { + debug("%s: DDR retention bit is set\n", __func__); + + if (is_ddr_bitstream_sha_matching(reg)) { + debug("%s: Matching in DDR bistream\n", + __func__); + debug("%s: DDR init is skipped\n", __func__); + return true; + } + + debug("%s: Mismatch in DDR bistream\n", __func__); + } + } + + debug("%s: DDR init is required\n", __func__); + return false; +} +#endif
-----Original Message----- From: Lim, Elly Siew Chin elly.siew.chin.lim@intel.com Sent: Wednesday, March 31, 2021 10:39 PM To: u-boot@lists.denx.de Cc: Marek Vasut marex@denx.de; Tan, Ley Foon ley.foon.tan@intel.com; See, Chin Liang chin.liang.see@intel.com; Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Chee, Tien Fong tien.fong.chee@intel.com; Westergreen, Dalon dalon.westergreen@intel.com; Simon Glass sjg@chromium.org; Gan, Yau Wai yau.wai.gan@intel.com; Lim, Elly Siew Chin elly.siew.chin.lim@intel.com Subject: [v1 10/17] arm: socfpga: Add SDRAM driver helper function for Intel N5X device
diff --git a/arch/arm/mach-socfpga/include/mach/misc.h b/arch/arm/mach- socfpga/include/mach/misc.h index 649d2f6ce2..c41b7c14cd 100644 --- a/arch/arm/mach-socfpga/include/mach/misc.h +++ b/arch/arm/mach-socfpga/include/mach/misc.h @@ -44,6 +44,10 @@ void socfpga_sdram_remap_zero(void); int is_fpga_config_ready(void); #endif
void do_bridge_reset(int enable, unsigned int mask); void socfpga_pl310_clear(void); void socfpga_get_managers_addr(void); diff --git a/arch/arm/mach-socfpga/misc_soc64.c b/arch/arm/mach- socfpga/misc_soc64.c index 7b973a79e8..d3945e55aa 100644 --- a/arch/arm/mach-socfpga/misc_soc64.c +++ b/arch/arm/mach-socfpga/misc_soc64.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0 /*
- Copyright (C) 2016-2018 Intel Corporation <www.intel.com>
- Copyright (C) 2016-2021 Intel Corporation <www.intel.com>
@@ -19,6 +19,13 @@
- POR_RESET,
- WARM_RESET,
- COLD_RESET
- FPGA programming support for SoC FPGA Stratix 10
+#if IS_ENABLED(CONFIG_TARGET_SOCFPGA_N5X) +static bool is_ddr_retention_enabled(u32 boot_scratch_cold0_reg) {
- return boot_scratch_cold0_reg &
+static bool is_ddr_bitstream_sha_matching(u32 boot_scratch_cold0_reg) {
+static enum reset_type get_reset_type(u32 boot_scratch_cold0_reg) {
- return (boot_scratch_cold0_reg &
1. This function can move to DDR driver. 2. Change this function return true if need the DDR init, so that doesn't need to invert checking when call to this function, more readable.
- u32 reg = readl(socfpga_get_sysmgr_addr() +
- if (get_reset_type(reg) == POR_RESET) {
Store reset type in a variable, don't call get_reset_type() multiple times.
return false;
- if (get_reset_type(reg) == WARM_RESET) {
return true;
- if (get_reset_type(reg) == COLD_RESET) {
Combine this IF with parent IF with &&.
__func__);
return true;
- debug("%s: DDR init is required\n", __func__);
- return false;
2.13.0
Hi Ley Foon,
-----Original Message----- From: Tan, Ley Foon ley.foon.tan@intel.com Sent: Friday, 9 April, 2021 2:08 PM To: Lim, Elly Siew Chin elly.siew.chin.lim@intel.com; u-boot@lists.denx.de Cc: Marek Vasut marex@denx.de; See, Chin Liang chin.liang.see@intel.com; Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Chee, Tien Fong tien.fong.chee@intel.com; Westergreen, Dalon dalon.westergreen@intel.com; Simon Glass sjg@chromium.org; Gan, Yau Wai yau.wai.gan@intel.com Subject: RE: [v1 10/17] arm: socfpga: Add SDRAM driver helper function for Intel N5X device
@@ -19,6 +19,13 @@
- POR_RESET,
- WARM_RESET,
- COLD_RESET
- This function can move to DDR driver.
- Change this function return true if need the DDR init, so that doesn't need
Okay.
return false;
return true;
Okay.
__func__);
return true;
- return false;
2.13.0
Regards, Tien Fong
Minimum 1GB memory size is required in current memory test, so this patch improves the memory test for processing memory size less than 1GB, and the size in power of two.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- drivers/ddr/altera/sdram_soc64.c | 18 ++++++++++++++++-- 1 file changed, 16 insertions(+), 2 deletions(-)
diff --git a/drivers/ddr/altera/sdram_soc64.c b/drivers/ddr/altera/sdram_soc64.c index a08f0953e5..171cde0e6b 100644 --- a/drivers/ddr/altera/sdram_soc64.c +++ b/drivers/ddr/altera/sdram_soc64.c @@ -182,6 +182,7 @@ void sdram_size_check(struct bd_info *bd) phys_size_t total_ram_check = 0; phys_size_t ram_check = 0; phys_addr_t start = 0; + phys_size_t size, total_size; int bank;
/* Sanity check ensure correct SDRAM size specified */ @@ -189,10 +190,23 @@ void sdram_size_check(struct bd_info *bd)
for (bank = 0; bank < CONFIG_NR_DRAM_BANKS; bank++) { start = bd->bi_dram[bank].start; + total_size = bd->bi_dram[bank].size; while (ram_check < bd->bi_dram[bank].size) { - ram_check += get_ram_size((void *)(start + ram_check), - (phys_size_t)SZ_1G); + size = min((phys_addr_t)SZ_1G, (phys_addr_t)total_size); + + /* + * Ensure the size is power of two, this is requirement to run + * get_ram_size() / memory test + */ + if (size != 0 && ((size & (size - 1)) == 0)) { + ram_check += get_ram_size((void *)(start + ram_check), size); + total_size = bd->bi_dram[bank].size - ram_check; + } else { + puts("DDR: Memory test requires SDRAM size in power of two!\n"); + hang(); + } } + total_ram_check += ram_check; ram_check = 0; }
-----Original Message----- From: Lim, Elly Siew Chin elly.siew.chin.lim@intel.com Sent: Wednesday, March 31, 2021 10:39 PM To: u-boot@lists.denx.de Cc: Marek Vasut marex@denx.de; Tan, Ley Foon ley.foon.tan@intel.com; See, Chin Liang chin.liang.see@intel.com; Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Chee, Tien Fong tien.fong.chee@intel.com; Westergreen, Dalon dalon.westergreen@intel.com; Simon Glass sjg@chromium.org; Gan, Yau Wai yau.wai.gan@intel.com Subject: [v1 11/17] ddr: socfpga: Enable memory test on memory size less than 1GB
- phys_size_t size, total_size;
Use "remaining_size" is more suitable.
int bank;
while (ram_check < bd->bi_dram[bank].size) {total_size = bd->bi_dram[bank].size;
ram_check),
to run
ram_check), size);
ram_check;
} else {
hang();
- total_ram_check += ram_check; ram_check = 0; }
-- 2.13.0
Hi Ley Foon,
-----Original Message----- From: Tan, Ley Foon ley.foon.tan@intel.com Sent: Friday, 9 April, 2021 1:54 PM To: Lim, Elly Siew Chin elly.siew.chin.lim@intel.com; u-boot@lists.denx.de Cc: Marek Vasut marex@denx.de; See, Chin Liang chin.liang.see@intel.com; Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Chee, Tien Fong tien.fong.chee@intel.com; Westergreen, Dalon dalon.westergreen@intel.com; Simon Glass sjg@chromium.org; Gan, Yau Wai yau.wai.gan@intel.com Subject: RE: [v1 11/17] ddr: socfpga: Enable memory test on memory size less than 1GB
Okay
int bank;
ram_check),
to run
ram_check), size);
ram_check;
} else {
hang();
-- 2.13.0
The DDR subsystem in Diamond Mesa is consisted of controller, PHY, memory reset manager and memory clock manager.
Configuration settings of controller, PHY and memory reset manager is come from DDR handoff data in bitstream, which contain the register base addresses and user settings from Quartus.
Configuration settings of memory clock manager is come from the HPS handoff data in bitstream, however the register base address is defined in device tree.
The calibration is fully done in HPS, which requires IMEM and DMEM binaries loading to PHY SRAM for running this calibration, both IMEM and DMEM binaries are also part of bitstream, this bitstream would be loaded to OCRAM by SDM, and configured by DDR driver.
Signed-off-by: Siew Chin Lim elly.siew.chin.lim@intel.com Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- arch/arm/mach-socfpga/include/mach/firewall.h | 6 + .../include/mach/system_manager_soc64.h | 10 +- drivers/ddr/altera/Makefile | 3 +- drivers/ddr/altera/sdram_n5x.c | 2316 ++++++++++++++++++++ drivers/ddr/altera/sdram_soc64.c | 10 +- 5 files changed, 2342 insertions(+), 3 deletions(-) create mode 100644 drivers/ddr/altera/sdram_n5x.c
diff --git a/arch/arm/mach-socfpga/include/mach/firewall.h b/arch/arm/mach-socfpga/include/mach/firewall.h index adab65bc96..5cb7f23f8f 100644 --- a/arch/arm/mach-socfpga/include/mach/firewall.h +++ b/arch/arm/mach-socfpga/include/mach/firewall.h @@ -115,10 +115,16 @@ struct socfpga_firwall_l4_sys { /* Firewall MPU DDR SCR registers */ #define FW_MPU_DDR_SCR_EN 0x00 #define FW_MPU_DDR_SCR_EN_SET 0x04 +#define FW_MPU_DDR_SCR_MPUREGION0ADDR_BASE 0x10 +#define FW_MPU_DDR_SCR_MPUREGION0ADDR_BASEEXT 0x14 #define FW_MPU_DDR_SCR_MPUREGION0ADDR_LIMIT 0x18 #define FW_MPU_DDR_SCR_MPUREGION0ADDR_LIMITEXT 0x1c + +#define FW_MPU_DDR_SCR_NONMPUREGION0ADDR_BASE 0x90 +#define FW_MPU_DDR_SCR_NONMPUREGION0ADDR_BASEEXT 0x94 #define FW_MPU_DDR_SCR_NONMPUREGION0ADDR_LIMIT 0x98 #define FW_MPU_DDR_SCR_NONMPUREGION0ADDR_LIMITEXT 0x9c +#define FW_MPU_DDR_SCR_NONMPUREGION0ADDR_LIMITEXT_FIELD 0xff
#define MPUREGION0_ENABLE BIT(0) #define NONMPUREGION0_ENABLE BIT(8) diff --git a/arch/arm/mach-socfpga/include/mach/system_manager_soc64.h b/arch/arm/mach-socfpga/include/mach/system_manager_soc64.h index fc4e17821b..a8009664fe 100644 --- a/arch/arm/mach-socfpga/include/mach/system_manager_soc64.h +++ b/arch/arm/mach-socfpga/include/mach/system_manager_soc64.h @@ -1,6 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0 */ /* - * Copyright (C) 2019 Intel Corporation <www.intel.com> + * Copyright (C) 2019-2021 Intel Corporation <www.intel.com> */
#ifndef _SYSTEM_MANAGER_SOC64_H_ @@ -28,8 +28,12 @@ void populate_sysmgr_pinmux(void); #define SYSMGR_SOC64_FPGAINTF_EN2 0x6c #define SYSMGR_SOC64_FPGAINTF_EN3 0x70 #define SYSMGR_SOC64_DMA_L3MASTER 0x74 +#if IS_ENABLED(CONFIG_TARGET_SOCFPGA_N5X) +#define SYSMGR_SOC64_DDR_MODE 0xb8 +#else #define SYSMGR_SOC64_HMC_CLK 0xb4 #define SYSMGR_SOC64_IO_PA_CTRL 0xb8 +#endif #define SYSMGR_SOC64_NOC_TIMEOUT 0xc0 #define SYSMGR_SOC64_NOC_IDLEREQ_SET 0xc4 #define SYSMGR_SOC64_NOC_IDLEREQ_CLR 0xc8 @@ -143,4 +147,8 @@ void populate_sysmgr_pinmux(void);
#define SYSMGR_WDDBG_PAUSE_ALL_CPU 0x0F0F0F0F
+#if IS_ENABLED(CONFIG_TARGET_SOCFPGA_N5X) +#define SYSMGR_SOC64_DDR_MODE_MSK BIT(0) +#endif + #endif /* _SYSTEM_MANAGER_SOC64_H_ */ diff --git a/drivers/ddr/altera/Makefile b/drivers/ddr/altera/Makefile index 39dfee5d5a..9fa5d85a27 100644 --- a/drivers/ddr/altera/Makefile +++ b/drivers/ddr/altera/Makefile @@ -4,11 +4,12 @@ # Wolfgang Denk, DENX Software Engineering, wd@denx.de. # # (C) Copyright 2010, Thomas Chou thomas@wytron.com.tw -# Copyright (C) 2014 Altera Corporation <www.altera.com> +# Copyright (C) 2014-2021 Altera Corporation <www.altera.com>
ifdef CONFIG_$(SPL_)ALTERA_SDRAM obj-$(CONFIG_TARGET_SOCFPGA_GEN5) += sdram_gen5.o sequencer.o obj-$(CONFIG_TARGET_SOCFPGA_ARRIA10) += sdram_arria10.o obj-$(CONFIG_TARGET_SOCFPGA_STRATIX10) += sdram_soc64.o sdram_s10.o obj-$(CONFIG_TARGET_SOCFPGA_AGILEX) += sdram_soc64.o sdram_agilex.o +obj-$(CONFIG_TARGET_SOCFPGA_N5X) += sdram_soc64.o sdram_n5x.o endif diff --git a/drivers/ddr/altera/sdram_n5x.c b/drivers/ddr/altera/sdram_n5x.c new file mode 100644 index 0000000000..a50c8f43f4 --- /dev/null +++ b/drivers/ddr/altera/sdram_n5x.c @@ -0,0 +1,2316 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020-2021 Intel Corporation <www.intel.com> + * + */ + +#include <common.h> +#include <asm/arch/firewall.h> +#include <asm/arch/handoff_soc64.h> +#include <asm/arch/misc.h> +#include <asm/arch/reset_manager.h> +#include <asm/arch/system_manager.h> +#include <asm/global_data.h> +#include <asm/io.h> +#include <clk.h> +#include <div64.h> +#include <dm.h> +#include <errno.h> +#include <fdtdec.h> +#include <hang.h> +#include <linux/err.h> +#include <linux/sizes.h> +#include <ram.h> +#include <reset.h> +#include "sdram_soc64.h" +#include <wait_bit.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* MPFE NOC registers */ +#define FPGA2SDRAM_MGR_MAIN_SIDEBANDMGR_FLAGOUTSET0 0xF8024050 + +/* Memory reset manager */ +#define MEM_RST_MGR_STATUS 0x8 + +/* Register and bit in memory reset manager */ +#define MEM_RST_MGR_STATUS_RESET_COMPLETE BIT(0) +#define MEM_RST_MGR_STATUS_PWROKIN_STATUS BIT(1) +#define MEM_RST_MGR_STATUS_CONTROLLER_RST BIT(2) +#define MEM_RST_MGR_STATUS_AXI_RST BIT(3) + +#define TIMEOUT_200MS 200 +#define TIMEOUT_5000MS 5000 + +/* DDR4 umctl2 */ +#define DDR4_MSTR_OFFSET 0x0 +#define DDR4_FREQ_RATIO BIT(22) + +#define DDR4_STAT_OFFSET 0x4 +#define DDR4_STAT_SELFREF_TYPE (BIT(5) | BIT(4)) +#define DDR4_STAT_SELFREF_TYPE_SHIFT 4 +#define DDR4_STAT_OPERATING_MODE (BIT(2) | BIT(1) | BIT(0)) + +#define DDR4_MRCTRL0_OFFSET 0x10 +#define DDR4_MRCTRL0_MR_TYPE BIT(0) +#define DDR4_MRCTRL0_MPR_EN BIT(1) +#define DDR4_MRCTRL0_MR_RANK (BIT(5) | BIT(4)) +#define DDR4_MRCTRL0_MR_RANK_SHIFT 4 +#define DDR4_MRCTRL0_MR_ADDR (BIT(15) | BIT(14) | BIT(13) | BIT(12)) +#define DDR4_MRCTRL0_MR_ADDR_SHIFT 12 +#define DDR4_MRCTRL0_MR_WR BIT(31) + +#define DDR4_MRCTRL1_OFFSET 0x14 +#define DDR4_MRCTRL1_MR_DATA 0x3FFFF + +#define DDR4_MRSTAT_OFFSET 0x18 +#define DDR4_MRSTAT_MR_WR_BUSY BIT(0) + +#define DDR4_MRCTRL2_OFFSET 0x1C + +#define DDR4_PWRCTL_OFFSET 0x30 +#define DDR4_PWRCTL_SELFREF_EN BIT(0) +#define DDR4_PWRCTL_POWERDOWN_EN BIT(1) +#define DDR4_PWRCTL_EN_DFI_DRAM_CLK_DISABLE BIT(3) +#define DDR4_PWRCTL_SELFREF_SW BIT(5) + +#define DDR4_PWRTMG_OFFSET 0x34 +#define DDR4_HWLPCTL_OFFSET 0x38 +#define DDR4_RFSHCTL0_OFFSET 0x50 +#define DDR4_RFSHCTL1_OFFSET 0x54 + +#define DDR4_RFSHCTL3_OFFSET 0x60 +#define DDR4_RFSHCTL3_DIS_AUTO_REFRESH BIT(0) +#define DDR4_RFSHCTL3_REFRESH_MODE (BIT(6) | BIT(5) | BIT(4)) +#define DDR4_RFSHCTL3_REFRESH_MODE_SHIFT 4 + +#define DDR4_ECCCFG0_OFFSET 0x70 +#define DDR4_ECC_MODE (BIT(2) | BIT(1) | BIT(0)) +#define DDR4_DIS_SCRUB BIT(4) +#define LPDDR4_ECCCFG0_ECC_REGION_MAP_GRANU_SHIFT 30 +#define LPDDR4_ECCCFG0_ECC_REGION_MAP_SHIFT 8 + +#define DDR4_ECCCFG1_OFFSET 0x74 +#define LPDDR4_ECCCFG1_ECC_REGIONS_PARITY_LOCK BIT(4) + +#define DDR4_CRCPARCTL0_OFFSET 0xC0 +#define DDR4_CRCPARCTL0_DFI_ALERT_ERR_INIT_CLR BIT(1) + +#define DDR4_CRCPARCTL1_OFFSET 0xC4 +#define DDR4_CRCPARCTL1_CRC_PARITY_RETRY_ENABLE BIT(8) +#define DDR4_CRCPARCTL1_ALERT_WAIT_FOR_SW BIT(9) + +#define DDR4_CRCPARSTAT_OFFSET 0xCC +#define DDR4_CRCPARSTAT_DFI_ALERT_ERR_INT BIT(16) +#define DDR4_CRCPARSTAT_DFI_ALERT_ERR_FATL_INT BIT(17) +#define DDR4_CRCPARSTAT_DFI_ALERT_ERR_NO_SW BIT(19) +#define DDR4_CRCPARSTAT_CMD_IN_ERR_WINDOW BIT(29) + +#define DDR4_INIT0_OFFSET 0xD0 +#define DDR4_INIT0_SKIP_RAM_INIT (BIT(31) | BIT(30)) + +#define DDR4_RANKCTL_OFFSET 0xF4 +#define DDR4_RANKCTL_DIFF_RANK_RD_GAP (BIT(7) | BIT(6) | BIT(5) | \ + BIT(4)) +#define DDR4_RANKCTL_DIFF_RANK_WR_GAP (BIT(11) | BIT(10) | BIT(9) | \ + BIT(8)) +#define DDR4_RANKCTL_DIFF_RANK_RD_GAP_MSB BIT(24) +#define DDR4_RANKCTL_DIFF_RANK_WR_GAP_MSB BIT(26) +#define DDR4_RANKCTL_DIFF_RANK_RD_GAP_SHIFT 4 +#define DDR4_RANKCTL_DIFF_RANK_WR_GAP_SHIFT 8 +#define DDR4_RANKCTL_DIFF_RANK_RD_GAP_MSB_SHIFT 24 +#define DDR4_RANKCTL_DIFF_RANK_WR_GAP_MSB_SHIFT 26 + +#define DDR4_RANKCTL1_OFFSET 0xF8 +#define DDR4_RANKCTL1_WR2RD_DR (BIT(5) | BIT(4) | BIT(3) | BIT(2) | BIT(1) | \ + BIT(0)) + +#define DDR4_DRAMTMG2_OFFSET 0x108 +#define DDR4_DRAMTMG2_WR2RD (BIT(5) | BIT(4) | BIT(3) | BIT(2) | BIT(1) | \ + BIT(0)) +#define DDR4_DRAMTMG2_RD2WR (BIT(13) | BIT(12) | BIT(11) | BIT(10) | \ + BIT(9) | BIT(8)) +#define DDR4_DRAMTMG2_RD2WR_SHIFT 8 + +#define DDR4_DRAMTMG9_OFFSET 0x124 +#define DDR4_DRAMTMG9_W2RD_S (BIT(5) | BIT(4) | BIT(3) | BIT(2) | BIT(1) | \ + BIT(0)) + +#define DDR4_DFITMG1_OFFSET 0x194 +#define DDR4_DFITMG1_DFI_T_WRDATA_DELAY (BIT(20) | BIT(19) | BIT(18) | \ + BIT(17) | BIT(16)) +#define DDR4_DFITMG1_DFI_T_WRDATA_SHIFT 16 + +#define DDR4_DFIMISC_OFFSET 0x1B0 +#define DDR4_DFIMISC_DFI_INIT_COMPLETE_EN BIT(0) +#define DDR4_DFIMISC_DFI_INIT_START BIT(5) + +#define DDR4_DFISTAT_OFFSET 0x1BC +#define DDR4_DFI_INIT_COMPLETE BIT(0) + +#define DDR4_DBG0_OFFSET 0x300 + +#define DDR4_DBG1_OFFSET 0x304 +#define DDR4_DBG1_DISDQ BIT(0) +#define DDR4_DBG1_DIS_HIF BIT(1) + +#define DDR4_DBGCAM_OFFSET 0x308 +#define DDR4_DBGCAM_DBG_RD_Q_EMPTY BIT(25) +#define DDR4_DBGCAM_DBG_WR_Q_EMPTY BIT(26) +#define DDR4_DBGCAM_RD_DATA_PIPELINE_EMPTY BIT(28) +#define DDR4_DBGCAM_WR_DATA_PIPELINE_EMPTY BIT(29) + +#define DDR4_SWCTL_OFFSET 0x320 +#define DDR4_SWCTL_SW_DONE BIT(0) + +#define DDR4_SWSTAT_OFFSET 0x324 +#define DDR4_SWSTAT_SW_DONE_ACK BIT(0) + +#define DDR4_PSTAT_OFFSET 0x3FC +#define DDR4_PSTAT_RD_PORT_BUSY_0 BIT(0) +#define DDR4_PSTAT_WR_PORT_BUSY_0 BIT(16) + +#define DDR4_PCTRL0_OFFSET 0x490 +#define DDR4_PCTRL0_PORT_EN BIT(0) + +#define DDR4_SBRCTL_OFFSET 0xF24 +#define DDR4_SBRCTL_SCRUB_INTERVAL 0x1FFF00 +#define DDR4_SBRCTL_SCRUB_EN BIT(0) +#define DDR4_SBRCTL_SCRUB_WRITE BIT(2) +#define DDR_SBRCTL_SCRUB_BURST_1 BIT(4) + +#define DDR4_SBRSTAT_OFFSET 0xF28 +#define DDR4_SBRSTAT_SCRUB_BUSY BIT(0) +#define DDR4_SBRSTAT_SCRUB_DONE BIT(1) + +#define DDR4_SBRWDATA0_OFFSET 0xF2C +#define DDR4_SBRWDATA1_OFFSET 0xF30 +#define DDR4_SBRSTART0_OFFSET 0xF38 +#define DDR4_SBRSTART1_OFFSET 0xF3C +#define DDR4_SBRRANGE0_OFFSET 0xF40 +#define DDR4_SBRRANGE1_OFFSET 0xF44 + +/* DDR PHY */ +#define DDR_PHY_TXODTDRVSTREN_B0_P0 0x2009A +#define DDR_PHY_RXPBDLYTG0_R0 0x200D0 +#define DDR_PHY_DBYTE0_TXDQDLYTG0_U0_P0 0x201A0 + +#define DDR_PHY_DBYTE0_TXDQDLYTG0_U1_P0 0x203A0 +#define DDR_PHY_DBYTE1_TXDQDLYTG0_U0_P0 0x221A0 +#define DDR_PHY_DBYTE1_TXDQDLYTG0_U1_P0 0x223A0 +#define DDR_PHY_TXDQDLYTG0_COARSE_DELAY (BIT(9) | BIT(8) | BIT(7) | BIT(6)) +#define DDR_PHY_TXDQDLYTG0_COARSE_DELAY_SHIFT 6 + +#define DDR_PHY_CALRATE_OFFSET 0x40110 +#define DDR_PHY_CALZAP_OFFSET 0x40112 +#define DDR_PHY_SEQ0BDLY0_P0_OFFSET 0x40016 +#define DDR_PHY_SEQ0BDLY1_P0_OFFSET 0x40018 +#define DDR_PHY_SEQ0BDLY2_P0_OFFSET 0x4001A +#define DDR_PHY_SEQ0BDLY3_P0_OFFSET 0x4001C + +#define DDR_PHY_MEMRESETL_OFFSET 0x400C0 +#define DDR_PHY_MEMRESETL_VALUE BIT(0) +#define DDR_PHY_PROTECT_MEMRESET BIT(1) + +#define DDR_PHY_CALBUSY_OFFSET 0x4012E +#define DDR_PHY_CALBUSY BIT(0) + +#define DDR_PHY_TRAIN_IMEM_OFFSET 0xA0000 +#define DDR_PHY_TRAIN_DMEM_OFFSET 0xA8000 + +#define DMEM_MB_CDD_RR_1_0_OFFSET 0xA802C +#define DMEM_MB_CDD_RR_0_1_OFFSET 0xA8030 +#define DMEM_MB_CDD_WW_1_0_OFFSET 0xA8038 +#define DMEM_MB_CDD_WW_0_1_OFFSET 0xA803C +#define DMEM_MB_CDD_RW_1_1_OFFSET 0xA8046 +#define DMEM_MB_CDD_RW_1_0_OFFSET 0xA8048 +#define DMEM_MB_CDD_RW_0_1_OFFSET 0xA804A +#define DMEM_MB_CDD_RW_0_0_OFFSET 0xA804C + +#define DMEM_MB_CDD_CHA_RR_1_0_OFFSET 0xA8026 +#define DMEM_MB_CDD_CHA_RR_0_1_OFFSET 0xA8026 +#define DMEM_MB_CDD_CHB_RR_1_0_OFFSET 0xA8058 +#define DMEM_MB_CDD_CHB_RR_0_1_OFFSET 0xA805A +#define DMEM_MB_CDD_CHA_WW_1_0_OFFSET 0xA8030 +#define DMEM_MB_CDD_CHA_WW_0_1_OFFSET 0xA8030 +#define DMEM_MB_CDD_CHB_WW_1_0_OFFSET 0xA8062 +#define DMEM_MB_CDD_CHB_WW_0_1_OFFSET 0xA8064 + +#define DMEM_MB_CDD_CHA_RW_1_1_OFFSET 0xA8028 +#define DMEM_MB_CDD_CHA_RW_1_0_OFFSET 0xA8028 +#define DMEM_MB_CDD_CHA_RW_0_1_OFFSET 0xA802A +#define DMEM_MB_CDD_CHA_RW_0_0_OFFSET 0xA802A + +#define DMEM_MB_CDD_CHB_RW_1_1_OFFSET 0xA805A +#define DMEM_MB_CDD_CHB_RW_1_0_OFFSET 0xA805C +#define DMEM_MB_CDD_CHB_RW_0_1_OFFSET 0xA805c +#define DMEM_MB_CDD_CHB_RW_0_0_OFFSET 0xA805E + +#define DDR_PHY_SEQ0DISABLEFLAG0_OFFSET 0x120018 +#define DDR_PHY_SEQ0DISABLEFLAG1_OFFSET 0x12001A +#define DDR_PHY_SEQ0DISABLEFLAG2_OFFSET 0x12001C +#define DDR_PHY_SEQ0DISABLEFLAG3_OFFSET 0x12001E +#define DDR_PHY_SEQ0DISABLEFLAG4_OFFSET 0x120020 +#define DDR_PHY_SEQ0DISABLEFLAG5_OFFSET 0x120022 +#define DDR_PHY_SEQ0DISABLEFLAG6_OFFSET 0x120024 +#define DDR_PHY_SEQ0DISABLEFLAG7_OFFSET 0x120026 + +#define DDR_PHY_UCCLKHCLKENABLES_OFFSET 0x180100 +#define DDR_PHY_UCCLKHCLKENABLES_UCCLKEN BIT(0) +#define DDR_PHY_UCCLKHCLKENABLES_HCLKEN BIT(1) + +#define DDR_PHY_UCTWRITEPROT_OFFSET 0x180066 +#define DDR_PHY_UCTWRITEPROT BIT(0) + +#define DDR_PHY_APBONLY0_OFFSET 0x1A0000 +#define DDR_PHY_MICROCONTMUXSEL BIT(0) + +#define DDR_PHY_UCTSHADOWREGS_OFFSET 0x1A0008 +#define DDR_PHY_UCTSHADOWREGS_UCTWRITEPROTESHADOW BIT(0) + +#define DDR_PHY_DCTWRITEPROT_OFFSET 0x1A0062 +#define DDR_PHY_DCTWRITEPROT BIT(0) + +#define DDR_PHY_UCTWRITEONLYSHADOW_OFFSET 0x1A0064 +#define DDR_PHY_UCTDATWRITEONLYSHADOW_OFFSET 0x1A0068 + +#define DDR_PHY_MICRORESET_OFFSET 0x1A0132 +#define DDR_PHY_MICRORESET_STALL BIT(0) +#define DDR_PHY_MICRORESET_RESET BIT(3) + +#define DDR_PHY_TXODTDRVSTREN_B0_P1 0x22009A + +/* For firmware training */ +#define HW_DBG_TRACE_CONTROL_OFFSET 0x18 +#define FW_TRAINING_COMPLETED_STAT 0x07 +#define FW_TRAINING_FAILED_STAT 0xFF +#define FW_COMPLETION_MSG_ONLY_MODE 0xFF +#define FW_STREAMING_MSG_ID 0x08 +#define GET_LOWHW_DATA(x) ((x) & 0xFFFF) +#define GET_LOWB_DATA(x) ((x) & 0xFF) +#define GET_HIGHB_DATA(x) (((x) & 0xFF00) >> 8) + +/* Operating mode */ +#define INIT_OPM 0x000 +#define NORMAL_OPM 0x001 +#define PWR_D0WN_OPM 0x010 +#define SELF_SELFREF_OPM 0x011 +#define DDR4_DEEP_PWR_DOWN_OPM 0x100 + +/* Refresh mode */ +#define FIXED_1X 0 +#define FIXED_2X BIT(0) +#define FIXED_4X BIT(4) + +/* Address of mode register */ +#define MR0 0x0000 +#define MR1 0x0001 +#define MR2 0x0010 +#define MR3 0x0011 +#define MR4 0x0100 +#define MR5 0x0101 +#define MR6 0x0110 +#define MR7 0x0111 + +/* MR rank */ +#define RANK0 0x1 +#define RANK1 0x2 +#define ALL_RANK 0x3 + +#define MR5_BIT4 BIT(4) + +/* Value for ecc_region_map */ +#define ALL_PROTECTED 0x7F + +/* Region size for ECCCFG0.ecc_region_map */ +enum region_size { + ONE_EIGHT, + ONE_SIXTEENTH, + ONE_THIRTY_SECOND, + ONE_SIXTY_FOURTH +}; + +enum ddr_type { + DDRTYPE_LPDDR4_0, + DDRTYPE_LPDDR4_1, + DDRTYPE_DDR4, + DDRTYPE_UNKNOWN +}; + +/* DDR handoff structure */ +struct ddr_handoff { + /* Memory reset manager base */ + phys_addr_t mem_reset_base; + + /* First controller attributes */ + phys_addr_t cntlr_handoff_base; + phys_addr_t cntlr_base; + size_t cntlr_total_length; + enum ddr_type cntlr_t; + size_t cntlr_handoff_length; + + /* Second controller attributes*/ + phys_addr_t cntlr2_handoff_base; + phys_addr_t cntlr2_base; + size_t cntlr2_total_length; + enum ddr_type cntlr2_t; + size_t cntlr2_handoff_length; + + /* PHY attributes */ + phys_addr_t phy_handoff_base; + phys_addr_t phy_base; + size_t phy_total_length; + size_t phy_handoff_length; + + /* PHY engine attributes */ + phys_addr_t phy_engine_handoff_base; + size_t phy_engine_total_length; + size_t phy_engine_handoff_length; + + /* Calibration attributes */ + phys_addr_t train_imem_base; + phys_addr_t train_dmem_base; + size_t train_imem_length; + size_t train_dmem_length; +}; + +/* Message mode */ +enum message_mode { + MAJOR_MESSAGE, + STREAMING_MESSAGE +}; + +static int clr_ca_parity_error_status(phys_addr_t umctl2_base) +{ + int ret; + + debug("%s: Clear C/A parity error status in MR5[4]\n", __func__); + + /* Set mode register MRS */ + clrbits_le32(umctl2_base + DDR4_MRCTRL0_OFFSET, DDR4_MRCTRL0_MPR_EN); + + /* Set mode register to write operation */ + setbits_le32(umctl2_base + DDR4_MRCTRL0_OFFSET, DDR4_MRCTRL0_MR_TYPE); + + /* Set the address of mode rgister to 0x101(MR5) */ + setbits_le32(umctl2_base + DDR4_MRCTRL0_OFFSET, + (MR5 << DDR4_MRCTRL0_MR_ADDR_SHIFT) & + DDR4_MRCTRL0_MR_ADDR); + + /* Set MR rank to rank 1 */ + setbits_le32(umctl2_base + DDR4_MRCTRL0_OFFSET, + (RANK1 << DDR4_MRCTRL0_MR_RANK_SHIFT) & + DDR4_MRCTRL0_MR_RANK); + + /* Clear C/A parity error status in MR5[4] */ + clrbits_le32(umctl2_base + DDR4_MRCTRL1_OFFSET, MR5_BIT4); + + /* Trigger mode register read or write operation */ + setbits_le32(umctl2_base + DDR4_MRCTRL0_OFFSET, DDR4_MRCTRL0_MR_WR); + + /* Wait for retry done */ + ret = wait_for_bit_le32((const void *)(umctl2_base + + DDR4_MRSTAT_OFFSET), DDR4_MRSTAT_MR_WR_BUSY, + false, TIMEOUT_200MS, false); + if (ret) { + debug("%s: Timeout while waiting for", __func__); + debug(" no outstanding MR transaction\n"); + return ret; + } + + return 0; +} + +static int ddr_retry_software_sequence(phys_addr_t umctl2_base) +{ + u32 value; + int ret; + + /* Check software can perform MRS/MPR/PDA? */ + value = readl(umctl2_base + DDR4_CRCPARSTAT_OFFSET) & + DDR4_CRCPARSTAT_DFI_ALERT_ERR_NO_SW; + + if (value) { + debug("%s: Software can't perform MRS/MPR/PDA\n", __func__); + + /* Clear interrupt bit for DFI alert error */ + setbits_le32(umctl2_base + DDR4_CRCPARCTL0_OFFSET, + DDR4_CRCPARCTL0_DFI_ALERT_ERR_INIT_CLR); + + /* Wait for retry done */ + ret = wait_for_bit_le32((const void *)(umctl2_base + + DDR4_MRSTAT_OFFSET), + DDR4_MRSTAT_MR_WR_BUSY, + false, TIMEOUT_200MS, false); + if (ret) { + debug("%s: Timeout while waiting for", __func__); + debug(" no outstanding MR transaction\n"); + return ret; + } + + if (clr_ca_parity_error_status(umctl2_base)) + return ret; + } else { + debug("%s: Software can perform MRS/MPR/PDA\n", __func__); + + ret = wait_for_bit_le32((const void *)(umctl2_base + + DDR4_MRSTAT_OFFSET), + DDR4_MRSTAT_MR_WR_BUSY, + false, TIMEOUT_200MS, false); + if (ret) { + debug("%s: Timeout while waiting for", __func__); + debug(" no outstanding MR transaction\n"); + return ret; + } + + if (clr_ca_parity_error_status(umctl2_base)) + return ret; + + /* Clear interrupt bit for DFI alert error */ + setbits_le32(umctl2_base + DDR4_CRCPARCTL0_OFFSET, + DDR4_CRCPARCTL0_DFI_ALERT_ERR_INIT_CLR); + } + + return 0; +} + +static int ensure_retry_procedure_complete(phys_addr_t umctl2_base) +{ + u32 value; + u32 start = get_timer(0); + int ret; + + /* Check parity/crc/error window is emptied ? */ + value = readl(umctl2_base + DDR4_CRCPARSTAT_OFFSET) & + DDR4_CRCPARSTAT_CMD_IN_ERR_WINDOW; + + /* Polling until parity/crc/error window is emptied */ + while (value) { + if (get_timer(start) > TIMEOUT_200MS) { + debug("%s: Timeout while waiting for", + __func__); + debug(" parity/crc/error window empty\n"); + return -ETIMEDOUT; + } + + /* Check software intervention is enabled? */ + value = readl(umctl2_base + DDR4_CRCPARCTL1_OFFSET) & + DDR4_CRCPARCTL1_ALERT_WAIT_FOR_SW; + if (value) { + debug("%s: Software intervention is enabled\n", + __func__); + + /* Check dfi alert error interrupt is set? */ + value = readl(umctl2_base + DDR4_CRCPARSTAT_OFFSET) & + DDR4_CRCPARSTAT_DFI_ALERT_ERR_INT; + + if (value) { + ret = ddr_retry_software_sequence(umctl2_base); + debug("%s: DFI alert error interrupt ", + __func__); + debug("is set\n"); + + if (ret) + return ret; + } + + /* + * Check fatal parity error interrupt is set? + */ + value = readl(umctl2_base + DDR4_CRCPARSTAT_OFFSET) & + DDR4_CRCPARSTAT_DFI_ALERT_ERR_FATL_INT; + if (value) { + printf("%s: Fatal parity error ", + __func__); + printf("interrupt is set, Hang it!!\n"); + hang(); + } + } + + value = readl(umctl2_base + DDR4_CRCPARSTAT_OFFSET) & + DDR4_CRCPARSTAT_CMD_IN_ERR_WINDOW; + + udelay(1); + WATCHDOG_RESET(); + } + + return 0; +} + +static int enable_quasi_dynamic_reg_grp3(phys_addr_t umctl2_base, + enum ddr_type umctl2_type) +{ + u32 i, value, backup; + int ret; + + /* Disable input traffic per port */ + clrbits_le32(umctl2_base + DDR4_PCTRL0_OFFSET, DDR4_PCTRL0_PORT_EN); + + /* Polling AXI port until idle */ + ret = wait_for_bit_le32((const void *)(umctl2_base + + DDR4_PSTAT_OFFSET), + DDR4_PSTAT_WR_PORT_BUSY_0 | + DDR4_PSTAT_RD_PORT_BUSY_0, false, + TIMEOUT_200MS, false); + if (ret) { + debug("%s: Timeout while waiting for", __func__); + debug(" controller idle\n"); + return ret; + } + + /* Backup user setting */ + backup = readl(umctl2_base + DDR4_DBG1_OFFSET); + + /* Disable input traffic to the controller */ + setbits_le32(umctl2_base + DDR4_DBG1_OFFSET, DDR4_DBG1_DIS_HIF); + + /* + * Ensure CAM/data pipelines are empty. + * Poll until CAM/data pipelines are set at least twice, + * timeout at 200ms + */ + for (i = 0; i < 2; i++) { + ret = wait_for_bit_le32((const void *)(umctl2_base + + DDR4_DBGCAM_OFFSET), + DDR4_DBGCAM_WR_DATA_PIPELINE_EMPTY | + DDR4_DBGCAM_RD_DATA_PIPELINE_EMPTY | + DDR4_DBGCAM_DBG_WR_Q_EMPTY | + DDR4_DBGCAM_DBG_RD_Q_EMPTY, true, + TIMEOUT_200MS, false); + if (ret) { + debug("%s: loop(%u): Timeout while waiting for", + __func__, i + 1); + debug(" CAM/data pipelines are empty\n"); + + /* Restore user setting */ + writel(backup, umctl2_base + DDR4_DBG1_OFFSET); + + return ret; + } + } + + if (umctl2_type == DDRTYPE_DDR4) { + /* Check DDR4 retry is enabled ? */ + value = readl(umctl2_base + DDR4_CRCPARCTL1_OFFSET) & + DDR4_CRCPARCTL1_CRC_PARITY_RETRY_ENABLE; + + if (value) { + debug("%s: DDR4 retry is enabled\n", __func__); + + ret = ensure_retry_procedure_complete(umctl2_base); + if (ret) { + debug("%s: Timeout while waiting for", + __func__); + debug(" retry procedure complete\n"); + + /* Restore user setting */ + writel(backup, umctl2_base + DDR4_DBG1_OFFSET); + + return ret; + } + } + } + + /* Restore user setting */ + writel(backup, umctl2_base + DDR4_DBG1_OFFSET); + + debug("%s: Quasi-dynamic group 3 registers are enabled\n", __func__); + + return 0; +} + +static enum ddr_type get_ddr_type(phys_addr_t ddr_type_location) +{ + u32 ddr_type_magic = readl(ddr_type_location); + + if (ddr_type_magic == SOC64_HANDOFF_DDR_UMCTL2_DDR4_TYPE) + return DDRTYPE_DDR4; + + if (ddr_type_magic == SOC64_HANDOFF_DDR_UMCTL2_LPDDR4_0_TYPE) + return DDRTYPE_LPDDR4_0; + + if (ddr_type_magic == SOC64_HANDOFF_DDR_UMCTL2_LPDDR4_1_TYPE) + return DDRTYPE_LPDDR4_1; + + return DDRTYPE_UNKNOWN; +} + +static void use_lpddr4_interleaving(bool set) +{ + if (set) { + printf("Starting LPDDR4 interleaving configuration ...\n"); + setbits_le32(FPGA2SDRAM_MGR_MAIN_SIDEBANDMGR_FLAGOUTSET0, + BIT(5)); + } else { + printf("Starting LPDDR4 non-interleaving configuration ...\n"); + clrbits_le32(FPGA2SDRAM_MGR_MAIN_SIDEBANDMGR_FLAGOUTSET0, + BIT(5)); + } +} + +static void use_ddr4(enum ddr_type type) +{ + if (type == DDRTYPE_DDR4) { + printf("Starting DDR4 configuration ...\n"); + setbits_le32(socfpga_get_sysmgr_addr() + SYSMGR_SOC64_DDR_MODE, + SYSMGR_SOC64_DDR_MODE_MSK); + } else if (type == DDRTYPE_LPDDR4_0) { + printf("Starting LPDDR4 configuration ...\n"); + clrbits_le32(socfpga_get_sysmgr_addr() + SYSMGR_SOC64_DDR_MODE, + SYSMGR_SOC64_DDR_MODE_MSK); + + use_lpddr4_interleaving(false); + } +} + +static int scrubber_ddr_config(phys_addr_t umctl2_base, + enum ddr_type umctl2_type) +{ + u32 backup[9]; + int ret; + + /* Reset to default value, prevent scrubber stop due to lower power */ + writel(0, umctl2_base + DDR4_PWRCTL_OFFSET); + + /* Backup user settings */ + backup[0] = readl(umctl2_base + DDR4_SBRCTL_OFFSET); + backup[1] = readl(umctl2_base + DDR4_SBRWDATA0_OFFSET); + backup[2] = readl(umctl2_base + DDR4_SBRSTART0_OFFSET); + if (umctl2_type == DDRTYPE_DDR4) { + backup[3] = readl(umctl2_base + DDR4_SBRWDATA1_OFFSET); + backup[4] = readl(umctl2_base + DDR4_SBRSTART1_OFFSET); + } + backup[5] = readl(umctl2_base + DDR4_SBRRANGE0_OFFSET); + backup[6] = readl(umctl2_base + DDR4_SBRRANGE1_OFFSET); + backup[7] = readl(umctl2_base + DDR4_ECCCFG0_OFFSET); + backup[8] = readl(umctl2_base + DDR4_ECCCFG1_OFFSET); + + if (umctl2_type != DDRTYPE_DDR4) { + /* Lock ECC region, ensure this regions is not being accessed */ + setbits_le32(umctl2_base + DDR4_ECCCFG1_OFFSET, + LPDDR4_ECCCFG1_ECC_REGIONS_PARITY_LOCK); + } + /* Disable input traffic per port */ + clrbits_le32(umctl2_base + DDR4_PCTRL0_OFFSET, DDR4_PCTRL0_PORT_EN); + /* Disables scrubber */ + clrbits_le32(umctl2_base + DDR4_SBRCTL_OFFSET, DDR4_SBRCTL_SCRUB_EN); + /* Polling all scrub writes data have been sent */ + ret = wait_for_bit_le32((const void *)(umctl2_base + + DDR4_SBRSTAT_OFFSET), DDR4_SBRSTAT_SCRUB_BUSY, + false, TIMEOUT_5000MS, false); + if (ret) { + debug("%s: Timeout while waiting for", __func__); + debug(" sending all scrub data\n"); + return ret; + } + + /* LPDDR4 supports inline ECC only */ + if (umctl2_type != DDRTYPE_DDR4) { + /* + * Setting all regions for protected, this is required for + * srubber to init whole LPDDR4 expect ECC region + */ + writel(((ONE_EIGHT << + LPDDR4_ECCCFG0_ECC_REGION_MAP_GRANU_SHIFT) | + (ALL_PROTECTED << LPDDR4_ECCCFG0_ECC_REGION_MAP_SHIFT)), + umctl2_base + DDR4_ECCCFG0_OFFSET); + } + + /* Scrub_burst = 1, scrub_mode = 1(performs writes) */ + writel(DDR_SBRCTL_SCRUB_BURST_1 | DDR4_SBRCTL_SCRUB_WRITE, + umctl2_base + DDR4_SBRCTL_OFFSET); + + /* Zeroing whole DDR */ + writel(0, umctl2_base + DDR4_SBRWDATA0_OFFSET); + writel(0, umctl2_base + DDR4_SBRSTART0_OFFSET); + if (umctl2_type == DDRTYPE_DDR4) { + writel(0, umctl2_base + DDR4_SBRWDATA1_OFFSET); + writel(0, umctl2_base + DDR4_SBRSTART1_OFFSET); + } + writel(0, umctl2_base + DDR4_SBRRANGE0_OFFSET); + writel(0, umctl2_base + DDR4_SBRRANGE1_OFFSET); + + /* Enables scrubber */ + setbits_le32(umctl2_base + DDR4_SBRCTL_OFFSET, DDR4_SBRCTL_SCRUB_EN); + /* Polling all scrub writes commands have been sent */ + ret = wait_for_bit_le32((const void *)(umctl2_base + + DDR4_SBRSTAT_OFFSET), DDR4_SBRSTAT_SCRUB_DONE, + true, TIMEOUT_5000MS, false); + if (ret) { + debug("%s: Timeout while waiting for", __func__); + debug(" sending all scrub commands\n"); + return ret; + } + + /* Polling all scrub writes data have been sent */ + ret = wait_for_bit_le32((const void *)(umctl2_base + + DDR4_SBRSTAT_OFFSET), DDR4_SBRSTAT_SCRUB_BUSY, + false, TIMEOUT_5000MS, false); + if (ret) { + printf("%s: Timeout while waiting for", __func__); + printf(" sending all scrub data\n"); + return ret; + } + + /* Disables scrubber */ + clrbits_le32(umctl2_base + DDR4_SBRCTL_OFFSET, DDR4_SBRCTL_SCRUB_EN); + + /* Restore user settings */ + writel(backup[0], umctl2_base + DDR4_SBRCTL_OFFSET); + writel(backup[1], umctl2_base + DDR4_SBRWDATA0_OFFSET); + writel(backup[2], umctl2_base + DDR4_SBRSTART0_OFFSET); + if (umctl2_type == DDRTYPE_DDR4) { + writel(backup[3], umctl2_base + DDR4_SBRWDATA1_OFFSET); + writel(backup[4], umctl2_base + DDR4_SBRSTART1_OFFSET); + } + writel(backup[5], umctl2_base + DDR4_SBRRANGE0_OFFSET); + writel(backup[6], umctl2_base + DDR4_SBRRANGE1_OFFSET); + writel(backup[7], umctl2_base + DDR4_ECCCFG0_OFFSET); + writel(backup[8], umctl2_base + DDR4_ECCCFG1_OFFSET); + + /* Enables ECC scrub on scrubber */ + if (!(readl(umctl2_base + DDR4_SBRCTL_OFFSET) & + DDR4_SBRCTL_SCRUB_WRITE)) { + /* Enables scrubber */ + setbits_le32(umctl2_base + DDR4_SBRCTL_OFFSET, + DDR4_SBRCTL_SCRUB_EN); + } + + return 0; +} + +static int init_umctl2(phys_addr_t umctl2_handoff_base, + phys_addr_t umctl2_base, enum ddr_type umctl2_type, + size_t umctl2_handoff_length, + u32 *user_backup) +{ + u32 handoff_table[umctl2_handoff_length]; + u32 i; + int ret; + + if (umctl2_type == DDRTYPE_DDR4) + printf("Initializing DDR4 controller ...\n"); + else if (umctl2_type == DDRTYPE_LPDDR4_0) + printf("Initializing LPDDR4_0 controller ...\n"); + else if (umctl2_type == DDRTYPE_LPDDR4_1) + printf("Initializing LPDDR4_1 controller ...\n"); + + /* Prevent controller from issuing read/write to SDRAM */ + setbits_le32(umctl2_base + DDR4_DBG1_OFFSET, DDR4_DBG1_DISDQ); + + /* Put SDRAM into self-refresh */ + setbits_le32(umctl2_base + DDR4_PWRCTL_OFFSET, DDR4_PWRCTL_SELFREF_EN); + + /* Enable quasi-dynamic programing of the controller registers */ + clrbits_le32(umctl2_base + DDR4_SWCTL_OFFSET, DDR4_SWCTL_SW_DONE); + + /* Ensure the controller is in initialization mode */ + ret = wait_for_bit_le32((const void *)(umctl2_base + DDR4_STAT_OFFSET), + DDR4_STAT_OPERATING_MODE, false, TIMEOUT_200MS, + false); + if (ret) { + debug("%s: Timeout while waiting for", __func__); + debug(" init operating mode\n"); + return ret; + } + + debug("%s: UMCTL2 handoff base address = 0x%p table length = 0x%08x\n", + __func__, (u32 *)umctl2_handoff_base, + (u32)umctl2_handoff_length); + + socfpga_handoff_read((void *)umctl2_handoff_base, handoff_table, + umctl2_handoff_length, LITTLE_ENDIAN); + + for (i = 0; i < umctl2_handoff_length; i = i + 2) { + debug("%s: Absolute addr: 0x%08llx APB offset: 0x%08x", + __func__, handoff_table[i] + umctl2_base, + handoff_table[i]); + debug(" wr = 0x%08x ", handoff_table[i + 1]); + + writel(handoff_table[i + 1], (uintptr_t)(handoff_table[i] + + umctl2_base)); + + debug("rd = 0x%08x\n", readl((uintptr_t)(handoff_table[i] + + umctl2_base))); + } + + /* Backup user settings, restore after DDR up running */ + *user_backup = readl(umctl2_base + DDR4_PWRCTL_OFFSET); + + /* Disable self resfresh */ + clrbits_le32(umctl2_base + DDR4_PWRCTL_OFFSET, DDR4_PWRCTL_SELFREF_EN); + + if (umctl2_type == DDRTYPE_LPDDR4_0 || + umctl2_type == DDRTYPE_LPDDR4_1) { + /* Setting selfref_sw to 1, based on lpddr4 requirement */ + setbits_le32(umctl2_base + DDR4_PWRCTL_OFFSET, + DDR4_PWRCTL_SELFREF_SW); + + /* Backup user settings, restore after DDR up running */ + user_backup++; + *user_backup = readl(umctl2_base + DDR4_INIT0_OFFSET) & + DDR4_INIT0_SKIP_RAM_INIT; + + /* + * Setting INIT0.skip_dram_init to 0x3, based on lpddr4 + * requirement + */ + setbits_le32(umctl2_base + DDR4_INIT0_OFFSET, + DDR4_INIT0_SKIP_RAM_INIT); + } + + /* Complete quasi-dynamic register programming */ + setbits_le32(umctl2_base + DDR4_SWCTL_OFFSET, DDR4_SWCTL_SW_DONE); + + /* Enable controller from issuing read/write to SDRAM */ + clrbits_le32(umctl2_base + DDR4_DBG1_OFFSET, DDR4_DBG1_DISDQ); + + return 0; +} + +static int phy_pre_handoff_config(phys_addr_t umctl2_base, + enum ddr_type umctl2_type) +{ + int ret; + u32 value; + + if (umctl2_type == DDRTYPE_DDR4) { + /* Check DDR4 retry is enabled ? */ + value = readl(umctl2_base + DDR4_CRCPARCTL1_OFFSET) & + DDR4_CRCPARCTL1_CRC_PARITY_RETRY_ENABLE; + + if (value) { + debug("%s: DDR4 retry is enabled\n", __func__); + debug("%s: Disable auto refresh is not supported\n", + __func__); + } else { + /* Disable auto refresh */ + setbits_le32(umctl2_base + DDR4_RFSHCTL3_OFFSET, + DDR4_RFSHCTL3_DIS_AUTO_REFRESH); + } + } + + /* Disable selfref_en & powerdown_en, nvr disable dfi dram clk */ + clrbits_le32(umctl2_base + DDR4_PWRCTL_OFFSET, + DDR4_PWRCTL_EN_DFI_DRAM_CLK_DISABLE | + DDR4_PWRCTL_POWERDOWN_EN | DDR4_PWRCTL_SELFREF_EN); + + /* Enable quasi-dynamic programing of the controller registers */ + clrbits_le32(umctl2_base + DDR4_SWCTL_OFFSET, DDR4_SWCTL_SW_DONE); + + ret = enable_quasi_dynamic_reg_grp3(umctl2_base, umctl2_type); + if (ret) + return ret; + + /* Masking dfi init complete */ + clrbits_le32(umctl2_base + DDR4_DFIMISC_OFFSET, + DDR4_DFIMISC_DFI_INIT_COMPLETE_EN); + + /* Complete quasi-dynamic register programming */ + setbits_le32(umctl2_base + DDR4_SWCTL_OFFSET, DDR4_SWCTL_SW_DONE); + + /* Polling programming done */ + ret = wait_for_bit_le32((const void *)(umctl2_base + + DDR4_SWSTAT_OFFSET), DDR4_SWSTAT_SW_DONE_ACK, + true, TIMEOUT_200MS, false); + if (ret) { + debug("%s: Timeout while waiting for", __func__); + debug(" programming done\n"); + } + + return ret; +} + +static int init_phy(struct ddr_handoff *ddr_handoff_info) +{ + u32 handoff_table[ddr_handoff_info->phy_handoff_length]; + u32 i, value; + int ret; + + printf("Initializing DDR PHY ...\n"); + + if (ddr_handoff_info->cntlr_t == DDRTYPE_DDR4 || + ddr_handoff_info->cntlr_t == DDRTYPE_LPDDR4_0) { + ret = phy_pre_handoff_config(ddr_handoff_info->cntlr_base, + ddr_handoff_info->cntlr_t); + if (ret) + return ret; + } + + if (ddr_handoff_info->cntlr2_t == DDRTYPE_LPDDR4_1) { + ret = phy_pre_handoff_config + (ddr_handoff_info->cntlr2_base, + ddr_handoff_info->cntlr2_t); + if (ret) + return ret; + } + + /* Execute PHY configuration handoff */ + socfpga_handoff_read((void *)ddr_handoff_info->phy_handoff_base, + handoff_table, + (u32)ddr_handoff_info->phy_handoff_length, + LITTLE_ENDIAN); + + for (i = 0; i < ddr_handoff_info->phy_handoff_length; i = i + 2) { + /* + * Convert PHY odd offset to even offset that supported by + * ARM processor. + */ + value = handoff_table[i] << 1; + debug("%s: Absolute addr: 0x%08llx, APB offset: 0x%08x ", + __func__, value + ddr_handoff_info->phy_base, value); + debug("PHY offset: 0x%08x", handoff_table[i]); + debug(" wr = 0x%08x ", handoff_table[i + 1]); + writew(handoff_table[i + 1], (uintptr_t)(value + + ddr_handoff_info->phy_base)); + debug("rd = 0x%08x\n", readw((uintptr_t)(value + + ddr_handoff_info->phy_base))); + } + + printf("DDR PHY configuration is completed\n"); + + return 0; +} + +static void phy_init_engine(struct ddr_handoff *handoff) +{ + u32 i, value; + u32 handoff_table[handoff->phy_engine_handoff_length]; + + printf("Load PHY Init Engine ...\n"); + + /* Execute PIE production code handoff */ + socfpga_handoff_read((void *)handoff->phy_engine_handoff_base, + handoff_table, + (u32)handoff->phy_engine_handoff_length, + LITTLE_ENDIAN); + + for (i = 0; i < handoff->phy_engine_handoff_length; i = i + 2) { + debug("Handoff addr: 0x%8llx ", handoff_table[i] + + handoff->phy_base); + + /* + * Convert PHY odd offset to even offset that supported by + * ARM processor. + */ + value = handoff_table[i] << 1; + debug("%s: Absolute addr: 0x%08llx, APB offset: 0x%08x ", + __func__, value + handoff->phy_base, value); + debug("PHY offset: 0x%08x", handoff_table[i]); + debug(" wr = 0x%08x ", handoff_table[i + 1]); + + writew(handoff_table[i + 1], (uintptr_t)(value + + handoff->phy_base)); + + debug("rd = 0x%08x\n", readw((uintptr_t)(value + + handoff->phy_base))); + } + + printf("End of loading PHY Init Engine\n"); +} + +int populate_ddr_handoff(struct ddr_handoff *handoff) +{ + phys_addr_t next_section_header; + + /* DDR handoff */ + handoff->mem_reset_base = SOC64_HANDOFF_DDR_MEMRESET_BASE; + debug("%s: DDR memory reset base = 0x%x\n", __func__, + (u32)handoff->mem_reset_base); + debug("%s: DDR memory reset address = 0x%x\n", __func__, + readl(handoff->mem_reset_base)); + + /* Beginning of DDR controller handoff */ + handoff->cntlr_handoff_base = SOC64_HANDOFF_DDR_UMCTL2_SECTION; + debug("%s: cntlr handoff base = 0x%x\n", __func__, + (u32)handoff->cntlr_handoff_base); + + /* Get 1st DDR type */ + handoff->cntlr_t = get_ddr_type(handoff->cntlr_handoff_base + + SOC64_HANDOFF_DDR_UMCTL2_TYPE_OFFSET); + if (handoff->cntlr_t == DDRTYPE_LPDDR4_1 || + handoff->cntlr_t == DDRTYPE_UNKNOWN) { + debug("%s: Wrong DDR handoff format, the 1st DDR ", __func__); + debug("type must be DDR4 or LPDDR4_0\n"); + return -ENOEXEC; + } + + /* 1st cntlr base physical address */ + handoff->cntlr_base = readl(handoff->cntlr_handoff_base + + SOC64_HANDOFF_DDR_UMCTL2_BASE_ADDR_OFFSET); + debug("%s: cntlr base = 0x%x\n", __func__, (u32)handoff->cntlr_base); + + /* Get the total length of DDR cntlr handoff section */ + handoff->cntlr_total_length = readl(handoff->cntlr_handoff_base + + SOC64_HANDOFF_OFFSET_LENGTH); + debug("%s: Umctl2 total length in byte = 0x%x\n", __func__, + (u32)handoff->cntlr_total_length); + + /* Get the length of user setting data in DDR cntlr handoff section */ + handoff->cntlr_handoff_length = socfpga_get_handoff_size((void *) + handoff->cntlr_handoff_base, + LITTLE_ENDIAN); + debug("%s: Umctl2 handoff length in word(32-bit) = 0x%x\n", __func__, + (u32)handoff->cntlr_handoff_length); + + /* Wrong format on user setting data */ + if (handoff->cntlr_handoff_length < 0) { + debug("%s: Wrong format on user setting data\n", __func__); + return -ENOEXEC; + } + + /* Get the next handoff section address */ + next_section_header = handoff->cntlr_handoff_base + + handoff->cntlr_total_length; + debug("%s: Next handoff section header location = 0x%llx\n", __func__, + next_section_header); + + /* + * Checking next section handoff is cntlr or PHY, and changing + * subsequent implementation accordingly + */ + if (readl(next_section_header) == SOC64_HANDOFF_DDR_UMCTL2_MAGIC) { + /* Get the next cntlr handoff section address */ + handoff->cntlr2_handoff_base = next_section_header; + debug("%s: umctl2 2nd handoff base = 0x%x\n", __func__, + (u32)handoff->cntlr2_handoff_base); + + /* Get 2nd DDR type */ + handoff->cntlr2_t = get_ddr_type(handoff->cntlr2_handoff_base + + SOC64_HANDOFF_DDR_UMCTL2_TYPE_OFFSET); + if (handoff->cntlr2_t == DDRTYPE_LPDDR4_0 || + handoff->cntlr2_t == DDRTYPE_UNKNOWN) { + debug("%s: Wrong DDR handoff format, the 2nd DDR ", + __func__); + debug("type must be LPDDR4_1\n"); + return -ENOEXEC; + } + + /* 2nd umctl2 base physical address */ + handoff->cntlr2_base = + readl(handoff->cntlr2_handoff_base + + SOC64_HANDOFF_DDR_UMCTL2_BASE_ADDR_OFFSET); + debug("%s: cntlr2 base = 0x%x\n", __func__, + (u32)handoff->cntlr2_base); + + /* Get the total length of 2nd DDR umctl2 handoff section */ + handoff->cntlr2_total_length = + readl(handoff->cntlr2_handoff_base + + SOC64_HANDOFF_OFFSET_LENGTH); + debug("%s: Umctl2_2nd total length in byte = 0x%x\n", __func__, + (u32)handoff->cntlr2_total_length); + + /* + * Get the length of user setting data in DDR umctl2 handoff + * section + */ + handoff->cntlr2_handoff_length = + socfpga_get_handoff_size((void *) + handoff->cntlr2_handoff_base, + LITTLE_ENDIAN); + debug("%s: cntlr2 handoff length in word(32-bit) = 0x%x\n", + __func__, + (u32)handoff->cntlr2_handoff_length); + + /* Wrong format on user setting data */ + if (handoff->cntlr2_handoff_length < 0) { + debug("%s: Wrong format on umctl2 user setting data\n", + __func__); + return -ENOEXEC; + } + + /* Get the next handoff section address */ + next_section_header = handoff->cntlr2_handoff_base + + handoff->cntlr2_total_length; + debug("%s: Next handoff section header location = 0x%llx\n", + __func__, next_section_header); + } + + /* Checking next section handoff is PHY ? */ + if (readl(next_section_header) == SOC64_HANDOFF_DDR_PHY_MAGIC) { + /* DDR PHY handoff */ + handoff->phy_handoff_base = next_section_header; + debug("%s: PHY handoff base = 0x%x\n", __func__, + (u32)handoff->phy_handoff_base); + + /* PHY base physical address */ + handoff->phy_base = readl(handoff->phy_handoff_base + + SOC64_HANDOFF_DDR_PHY_BASE_OFFSET); + debug("%s: PHY base = 0x%x\n", __func__, + (u32)handoff->phy_base); + + /* Get the total length of PHY handoff section */ + handoff->phy_total_length = readl(handoff->phy_handoff_base + + SOC64_HANDOFF_OFFSET_LENGTH); + debug("%s: PHY total length in byte = 0x%x\n", __func__, + (u32)handoff->phy_total_length); + + /* + * Get the length of user setting data in DDR PHY handoff + * section + */ + handoff->phy_handoff_length = socfpga_get_handoff_size((void *) + handoff->phy_handoff_base, + LITTLE_ENDIAN); + debug("%s: PHY handoff length in word(32-bit) = 0x%x\n", + __func__, (u32)handoff->phy_handoff_length); + + /* Wrong format on PHY user setting data */ + if (handoff->phy_handoff_length < 0) { + debug("%s: Wrong format on PHY user setting data\n", + __func__); + return -ENOEXEC; + } + + /* Get the next handoff section address */ + next_section_header = handoff->phy_handoff_base + + handoff->phy_total_length; + debug("%s: Next handoff section header location = 0x%llx\n", + __func__, next_section_header); + } else { + debug("%s: Wrong format for DDR handoff, expect PHY", + __func__); + debug(" handoff section after umctl2 handoff section\n"); + return -ENOEXEC; + } + + /* Checking next section handoff is PHY init Engine ? */ + if (readl(next_section_header) == + SOC64_HANDOFF_DDR_PHY_INIT_ENGINE_MAGIC) { + /* DDR PHY Engine handoff */ + handoff->phy_engine_handoff_base = next_section_header; + debug("%s: PHY init engine handoff base = 0x%x\n", __func__, + (u32)handoff->phy_engine_handoff_base); + + /* Get the total length of PHY init engine handoff section */ + handoff->phy_engine_total_length = + readl(handoff->phy_engine_handoff_base + + SOC64_HANDOFF_OFFSET_LENGTH); + debug("%s: PHY engine total length in byte = 0x%x\n", __func__, + (u32)handoff->phy_engine_total_length); + + /* + * Get the length of user setting data in DDR PHY init engine + * handoff section + */ + handoff->phy_engine_handoff_length = + socfpga_get_handoff_size((void *) + handoff->phy_engine_handoff_base, + LITTLE_ENDIAN); + debug("%s: PHY engine handoff length in word(32-bit) = 0x%x\n", + __func__, (u32)handoff->phy_engine_handoff_length); + + /* Wrong format on PHY init engine setting data */ + if (handoff->phy_engine_handoff_length < 0) { + debug("%s: Wrong format on PHY init engine ", + __func__); + debug("user setting data\n"); + return -ENOEXEC; + } + } else { + debug("%s: Wrong format for DDR handoff, expect PHY", + __func__); + debug(" init engine handoff section after PHY handoff\n"); + debug(" section\n"); + return -ENOEXEC; + } + + handoff->train_imem_base = handoff->phy_base + + DDR_PHY_TRAIN_IMEM_OFFSET; + debug("%s: PHY train IMEM base = 0x%x\n", + __func__, (u32)handoff->train_imem_base); + + handoff->train_dmem_base = handoff->phy_base + + DDR_PHY_TRAIN_DMEM_OFFSET; + debug("%s: PHY train DMEM base = 0x%x\n", + __func__, (u32)handoff->train_dmem_base); + + handoff->train_imem_length = SOC64_HANDOFF_DDR_TRAIN_IMEM_LENGTH; + debug("%s: PHY train IMEM length = 0x%x\n", + __func__, (u32)handoff->train_imem_length); + + handoff->train_dmem_length = SOC64_HANDOFF_DDR_TRAIN_DMEM_LENGTH; + debug("%s: PHY train DMEM length = 0x%x\n", + __func__, (u32)handoff->train_dmem_length); + + return 0; +} + +int enable_ddr_clock(struct udevice *dev) +{ + struct clk *ddr_clk; + int ret; + + /* Enable clock before init DDR */ + ddr_clk = devm_clk_get(dev, "mem_clk"); + if (!IS_ERR(ddr_clk)) { + ret = clk_enable(ddr_clk); + if (ret) { + printf("%s: Failed to enable DDR clock\n", __func__); + return ret; + } + } else { + ret = PTR_ERR(ddr_clk); + debug("%s: Failed to get DDR clock from dts\n", __func__); + return ret; + } + + printf("%s: DDR clock is enabled\n", __func__); + + return 0; +} + +static int ddr_start_dfi_init(phys_addr_t umctl2_base, + enum ddr_type umctl2_type) +{ + int ret; + + debug("%s: Start DFI init\n", __func__); + + /* Enable quasi-dynamic programing of controller registers */ + clrbits_le32(umctl2_base + DDR4_SWCTL_OFFSET, DDR4_SWCTL_SW_DONE); + + ret = enable_quasi_dynamic_reg_grp3(umctl2_base, umctl2_type); + if (ret) + return ret; + + /* Start DFI init sequence */ + setbits_le32(umctl2_base + DDR4_DFIMISC_OFFSET, + DDR4_DFIMISC_DFI_INIT_START); + + /* Complete quasi-dynamic register programming */ + setbits_le32(umctl2_base + DDR4_SWCTL_OFFSET, DDR4_SWCTL_SW_DONE); + + /* Polling programming done */ + ret = wait_for_bit_le32((const void *)(umctl2_base + + DDR4_SWSTAT_OFFSET), + DDR4_SWSTAT_SW_DONE_ACK, true, + TIMEOUT_200MS, false); + if (ret) { + debug("%s: Timeout while waiting for", __func__); + debug(" programming done\n"); + } + + return ret; +} + +static int ddr_check_dfi_init_complete(phys_addr_t umctl2_base, + enum ddr_type umctl2_type) +{ + int ret; + + /* Polling DFI init complete */ + ret = wait_for_bit_le32((const void *)(umctl2_base + + DDR4_DFISTAT_OFFSET), + DDR4_DFI_INIT_COMPLETE, true, + TIMEOUT_200MS, false); + if (ret) { + debug("%s: Timeout while waiting for", __func__); + debug(" DFI init done\n"); + return ret; + } + + debug("%s: DFI init completed.\n", __func__); + + /* Enable quasi-dynamic programing of controller registers */ + clrbits_le32(umctl2_base + DDR4_SWCTL_OFFSET, DDR4_SWCTL_SW_DONE); + + ret = enable_quasi_dynamic_reg_grp3(umctl2_base, umctl2_type); + if (ret) + return ret; + + /* Stop DFI init sequence */ + clrbits_le32(umctl2_base + DDR4_DFIMISC_OFFSET, + DDR4_DFIMISC_DFI_INIT_START); + + /* Complete quasi-dynamic register programming */ + setbits_le32(umctl2_base + DDR4_SWCTL_OFFSET, DDR4_SWCTL_SW_DONE); + + /* Polling programming done */ + ret = wait_for_bit_le32((const void *)(umctl2_base + + DDR4_SWSTAT_OFFSET), + DDR4_SWSTAT_SW_DONE_ACK, true, + TIMEOUT_200MS, false); + if (ret) { + debug("%s: Timeout while waiting for", __func__); + debug(" programming done\n"); + return ret; + } + + debug("%s:DDR programming done\n", __func__); + + return ret; +} + +static int ddr_trigger_sdram_init(phys_addr_t umctl2_base, + enum ddr_type umctl2_type) +{ + int ret; + + /* Enable quasi-dynamic programing of controller registers */ + clrbits_le32(umctl2_base + DDR4_SWCTL_OFFSET, DDR4_SWCTL_SW_DONE); + + ret = enable_quasi_dynamic_reg_grp3(umctl2_base, umctl2_type); + if (ret) + return ret; + + /* Unmasking dfi init complete */ + setbits_le32(umctl2_base + DDR4_DFIMISC_OFFSET, + DDR4_DFIMISC_DFI_INIT_COMPLETE_EN); + + /* Software exit from self-refresh */ + clrbits_le32(umctl2_base + DDR4_PWRCTL_OFFSET, DDR4_PWRCTL_SELFREF_SW); + + /* Complete quasi-dynamic register programming */ + setbits_le32(umctl2_base + DDR4_SWCTL_OFFSET, DDR4_SWCTL_SW_DONE); + + /* Polling programming done */ + ret = wait_for_bit_le32((const void *)(umctl2_base + + DDR4_SWSTAT_OFFSET), + DDR4_SWSTAT_SW_DONE_ACK, true, + TIMEOUT_200MS, false); + if (ret) { + debug("%s: Timeout while waiting for", __func__); + debug(" programming done\n"); + return ret; + } + + debug("%s:DDR programming done\n", __func__); + return ret; +} + +static int ddr_post_handoff_config(phys_addr_t umctl2_base, + enum ddr_type umctl2_type) +{ + int ret = 0; + u32 value; + u32 start = get_timer(0); + + /* Polling until SDRAM entered normal operating mode */ + value = readl(umctl2_base + DDR4_STAT_OFFSET) & + DDR4_STAT_OPERATING_MODE; + while (value != NORMAL_OPM) { + if (get_timer(start) > TIMEOUT_200MS) { + debug("%s: Timeout while waiting for", + __func__); + debug(" DDR enters normal operating mode\n"); + return -ETIMEDOUT; + } + + value = readl(umctl2_base + DDR4_STAT_OFFSET) & + DDR4_STAT_OPERATING_MODE; + + udelay(1); + WATCHDOG_RESET(); + } + + printf("DDR entered normal operating mode\n"); + + /* Enabling auto refresh */ + clrbits_le32(umctl2_base + DDR4_RFSHCTL3_OFFSET, + DDR4_RFSHCTL3_DIS_AUTO_REFRESH); + + /* Checking ECC is enabled? */ + value = readl(umctl2_base + DDR4_ECCCFG0_OFFSET) & DDR4_ECC_MODE; + if (value) { + printf("ECC is enabled\n"); + ret = scrubber_ddr_config(umctl2_base, umctl2_type); + if (ret) + printf("Failed to enable ECC\n"); + } + + return ret; +} + +static int configure_1d_training_firmware(struct ddr_handoff *ddr_handoff_info) +{ + int ret = 0; + + printf("Configuring 1D training firmware ...\n"); + + /* Reset SDRAM */ + writew(DDR_PHY_PROTECT_MEMRESET, + (uintptr_t)(ddr_handoff_info->phy_base + + DDR_PHY_MEMRESETL_OFFSET)); + + /* Enable access to the PHY configuration registers */ + clrbits_le16(ddr_handoff_info->phy_base + DDR_PHY_APBONLY0_OFFSET, + DDR_PHY_MICROCONTMUXSEL); + + /* Copy 1D train IMEM bin */ + memcpy((void *)ddr_handoff_info->train_imem_base, + (const void *)SOC64_HANDOFF_DDR_TRAIN_IMEM_1D_SECTION, + ddr_handoff_info->train_imem_length); + + ret = memcmp((void *)ddr_handoff_info->train_imem_base, + (const void *)SOC64_HANDOFF_DDR_TRAIN_IMEM_1D_SECTION, + ddr_handoff_info->train_imem_length); + if (ret) { + debug("%s: Failed to copy 1D train IMEM binary\n", __func__); + /* Isolate the APB access from internal CSRs */ + setbits_le16(ddr_handoff_info->phy_base + + DDR_PHY_APBONLY0_OFFSET, DDR_PHY_MICROCONTMUXSEL); + return ret; + } + + memcpy((void *)ddr_handoff_info->train_dmem_base, + (const void *)SOC64_HANDOFF_DDR_TRAIN_DMEM_1D_SECTION, + ddr_handoff_info->train_dmem_length); + + ret = memcmp((void *)ddr_handoff_info->train_dmem_base, + (const void *)SOC64_HANDOFF_DDR_TRAIN_DMEM_1D_SECTION, + ddr_handoff_info->train_dmem_length); + if (ret) + debug("%s: Failed to copy 1D train DMEM binary\n", __func__); + + /* Isolate the APB access from internal CSRs */ + setbits_le16(ddr_handoff_info->phy_base + DDR_PHY_APBONLY0_OFFSET, + DDR_PHY_MICROCONTMUXSEL); + + return ret; +} + +static int configure_2d_training_firmware(struct ddr_handoff *ddr_handoff_info) +{ + int ret = 0; + + printf("Configuring 2D training firmware ...\n"); + + /* Reset SDRAM */ + writew(DDR_PHY_PROTECT_MEMRESET, + (uintptr_t)(ddr_handoff_info->phy_base + + DDR_PHY_MEMRESETL_OFFSET)); + + /* Enable access to the PHY configuration registers */ + clrbits_le16(ddr_handoff_info->phy_base + DDR_PHY_APBONLY0_OFFSET, + DDR_PHY_MICROCONTMUXSEL); + + /* Copy 2D train IMEM bin */ + memcpy((void *)ddr_handoff_info->train_imem_base, + (const void *)SOC64_HANDOFF_DDR_TRAIN_IMEM_2D_SECTION, + ddr_handoff_info->train_imem_length); + + ret = memcmp((void *)ddr_handoff_info->train_imem_base, + (const void *)SOC64_HANDOFF_DDR_TRAIN_IMEM_2D_SECTION, + ddr_handoff_info->train_imem_length); + if (ret) { + debug("%s: Failed to copy 2D train IMEM binary\n", __func__); + /* Isolate the APB access from internal CSRs */ + setbits_le16(ddr_handoff_info->phy_base + + DDR_PHY_APBONLY0_OFFSET, DDR_PHY_MICROCONTMUXSEL); + return ret; + } + + memcpy((void *)ddr_handoff_info->train_dmem_base, + (const void *)SOC64_HANDOFF_DDR_TRAIN_DMEM_2D_SECTION, + ddr_handoff_info->train_dmem_length); + + ret = memcmp((void *)ddr_handoff_info->train_dmem_base, + (const void *)SOC64_HANDOFF_DDR_TRAIN_DMEM_2D_SECTION, + ddr_handoff_info->train_dmem_length); + if (ret) + debug("%s: Failed to copy 2D train DMEM binary\n", __func__); + + /* Isolate the APB access from internal CSRs */ + setbits_le16(ddr_handoff_info->phy_base + DDR_PHY_APBONLY0_OFFSET, + DDR_PHY_MICROCONTMUXSEL); + + return ret; +} + +static void calibrating_sdram(struct ddr_handoff *ddr_handoff_info) +{ + /* Init mailbox protocol */ + setbits_le16(ddr_handoff_info->phy_base + DDR_PHY_DCTWRITEPROT_OFFSET, + DDR_PHY_DCTWRITEPROT); + + /* Init mailbox protocol */ + setbits_le16(ddr_handoff_info->phy_base + DDR_PHY_UCTWRITEPROT_OFFSET, + DDR_PHY_UCTWRITEPROT); + + /* Reset and stalling ARC processor */ + setbits_le16(ddr_handoff_info->phy_base + DDR_PHY_MICRORESET_OFFSET, + DDR_PHY_MICRORESET_RESET | DDR_PHY_MICRORESET_STALL); + + /* Release ARC processor */ + clrbits_le16(ddr_handoff_info->phy_base + DDR_PHY_MICRORESET_OFFSET, + DDR_PHY_MICRORESET_RESET); + + /* Starting PHY firmware execution */ + clrbits_le16(ddr_handoff_info->phy_base + DDR_PHY_MICRORESET_OFFSET, + DDR_PHY_MICRORESET_STALL); +} + +static int get_mail(struct ddr_handoff *handoff, enum message_mode mode, + u32 *message_id) +{ + int ret; + + /* Polling major messages from PMU */ + ret = wait_for_bit_le16((const void *)(handoff->phy_base + + DDR_PHY_UCTSHADOWREGS_OFFSET), + DDR_PHY_UCTSHADOWREGS_UCTWRITEPROTESHADOW, + false, TIMEOUT_200MS, false); + if (ret) { + debug("%s: Timeout while waiting for", + __func__); + debug(" major messages from PMU\n"); + return ret; + } + + *message_id = readw((uintptr_t)(handoff->phy_base + + DDR_PHY_UCTWRITEONLYSHADOW_OFFSET)); + + if (mode == STREAMING_MESSAGE) + *message_id |= readw((uintptr_t)((handoff->phy_base + + DDR_PHY_UCTDATWRITEONLYSHADOW_OFFSET))) << + SZ_16; + + /* Ack the receipt of the major message */ + clrbits_le16(handoff->phy_base + DDR_PHY_DCTWRITEPROT_OFFSET, + DDR_PHY_DCTWRITEPROT); + + ret = wait_for_bit_le16((const void *)(handoff->phy_base + + DDR_PHY_UCTSHADOWREGS_OFFSET), + DDR_PHY_UCTSHADOWREGS_UCTWRITEPROTESHADOW, + true, TIMEOUT_200MS, false); + if (ret) { + debug("%s: Timeout while waiting for", + __func__); + debug(" ack the receipt of the major message completed\n"); + return ret; + } + + /* Complete protocol */ + setbits_le16(handoff->phy_base + DDR_PHY_DCTWRITEPROT_OFFSET, + DDR_PHY_DCTWRITEPROT); + + return ret; +} + +static int get_mail_streaming(struct ddr_handoff *handoff, + enum message_mode mode, u32 *index) +{ + int ret; + + *index = readw((uintptr_t)(handoff->phy_base + + DDR_PHY_UCTWRITEONLYSHADOW_OFFSET)); + + if (mode == STREAMING_MESSAGE) + *index |= readw((uintptr_t)((handoff->phy_base + + DDR_PHY_UCTDATWRITEONLYSHADOW_OFFSET))) << + SZ_16; + + /* Ack the receipt of the major message */ + clrbits_le16(handoff->phy_base + DDR_PHY_DCTWRITEPROT_OFFSET, + DDR_PHY_DCTWRITEPROT); + + ret = wait_for_bit_le16((const void *)(handoff->phy_base + + DDR_PHY_UCTSHADOWREGS_OFFSET), + DDR_PHY_UCTSHADOWREGS_UCTWRITEPROTESHADOW, + true, TIMEOUT_200MS, false); + if (ret) { + debug("%s: Timeout while waiting for", + __func__); + debug(" ack the receipt of the major message completed\n"); + return ret; + } + + /* Complete protocol */ + setbits_le16(handoff->phy_base + DDR_PHY_DCTWRITEPROT_OFFSET, + DDR_PHY_DCTWRITEPROT); + + return 0; +} + +static int decode_streaming_message(struct ddr_handoff *ddr_handoff_info, + u32 *streaming_index) +{ + int i = 0, ret; + u32 temp; + + temp = *streaming_index; + + while (i < GET_LOWHW_DATA(temp)) { + ret = get_mail(ddr_handoff_info, STREAMING_MESSAGE, + streaming_index); + if (ret) + return ret; + + printf("args[%d]: 0x%x ", i, *streaming_index); + i++; + } + + return 0; +} + +static int poll_for_training_complete(struct ddr_handoff *ddr_handoff_info) +{ + int ret; + u32 message_id = 0; + u32 streaming_index = 0; + + while ((message_id != FW_TRAINING_COMPLETED_STAT) && + (message_id != FW_TRAINING_FAILED_STAT)) { + ret = get_mail(ddr_handoff_info, MAJOR_MESSAGE, &message_id); + if (ret) + return ret; + + printf("Major message id = 0%x\n", message_id); + + if (message_id == FW_STREAMING_MSG_ID) { + ret = get_mail_streaming(ddr_handoff_info, + STREAMING_MESSAGE, + &streaming_index); + if (ret) + return ret; + + printf("streaming index 0%x : ", streaming_index); + + decode_streaming_message(ddr_handoff_info, + &streaming_index); + + printf("\n"); + } + } + + if (message_id == FW_TRAINING_COMPLETED_STAT) { + printf("DDR firmware training completed\n"); + } else if (message_id == FW_TRAINING_FAILED_STAT) { + printf("DDR firmware training failed\n"); + hang(); + } + + return 0; +} + +static void enable_phy_clk_for_csr_access(struct ddr_handoff *handoff, + bool enable) +{ + if (enable) { + /* Enable PHY clk */ + setbits_le16((uintptr_t)(handoff->phy_base + + DDR_PHY_UCCLKHCLKENABLES_OFFSET), + DDR_PHY_UCCLKHCLKENABLES_UCCLKEN | + DDR_PHY_UCCLKHCLKENABLES_HCLKEN); + } else { + /* Disable PHY clk */ + clrbits_le16((uintptr_t)(handoff->phy_base + + DDR_PHY_UCCLKHCLKENABLES_OFFSET), + DDR_PHY_UCCLKHCLKENABLES_UCCLKEN | + DDR_PHY_UCCLKHCLKENABLES_HCLKEN); + } +} + +/* helper function for updating train result to umctl2 RANKCTL register */ +static void set_cal_res_to_rankctrl(u32 reg_addr, u16 update_value, + u32 mask, u32 msb_mask, u32 shift) +{ + u32 reg, value; + + reg = readl((uintptr_t)reg_addr); + + debug("max value divided by 2 is 0x%x\n", update_value); + debug("umclt2 register 0x%x value is 0%x before ", reg_addr, reg); + debug("update with train result\n"); + + value = (reg & mask) >> shift; + + value += update_value + 3; + + /* reg value greater than 0xF, set one to diff_rank_wr_gap_msb */ + if (value > 0xF) + setbits_le32((u32 *)(uintptr_t)reg_addr, msb_mask); + else + clrbits_le32((u32 *)(uintptr_t)reg_addr, msb_mask); + + reg = readl((uintptr_t)reg_addr); + + value = (value << shift) & mask; + + /* update register */ + writel((reg & (~mask)) | value, (uintptr_t)reg_addr); + + reg = readl((uintptr_t)reg_addr); + debug("umclt2 register 0x%x value is 0%x before ", reg_addr, reg); + debug("update with train result\n"); +} + +/* helper function for updating train result to register */ +static void set_cal_res_to_reg(u32 reg_addr, u16 update_value, u32 mask, + u32 shift) +{ + u32 reg, value; + + reg = readl((uintptr_t)reg_addr); + + debug("max value divided by 2 is 0x%x\n", update_value); + debug("umclt2 register 0x%x value is 0%x before ", reg_addr, reg); + debug("update with train result\n"); + + value = (reg & mask) >> shift; + + value = ((value + update_value + 3) << shift) & mask; + + /* update register */ + writel((reg & (~mask)) | value, (uintptr_t)reg_addr); + + reg = readl((uintptr_t)reg_addr); + debug("umclt2 register 0x%x value is 0%x before ", reg_addr, reg); + debug("update with train result\n"); +} + +static u16 get_max_txdqsdlytg0_ux_p0(struct ddr_handoff *handoff, u32 reg, + u8 numdbyte, u16 upd_val) +{ + u32 b_addr; + u16 val; + u8 byte; + + /* Getting max value from DBYTEx TxDqsDlyTg0_ux_p0 */ + for (byte = 0; byte < numdbyte; byte++) { + b_addr = byte << 13; + + /* TxDqsDlyTg0[9:6] is the coarse delay */ + val = (readw((uintptr_t)(handoff->phy_base + + reg + b_addr)) & + DDR_PHY_TXDQDLYTG0_COARSE_DELAY) >> + DDR_PHY_TXDQDLYTG0_COARSE_DELAY_SHIFT; + + upd_val = max(val, upd_val); + } + + return upd_val; +} + +static int set_cal_res_to_umctl2(struct ddr_handoff *handoff, + phys_addr_t umctl2_base, + enum ddr_type umctl2_type) +{ + int ret; + u8 numdbyte = 0x8; + u16 upd_val, val; + u32 dramtmg2_reg_addr, rankctl_reg_addr, reg_addr; + + /* Enable quasi-dynamic programing of the controller registers */ + clrbits_le32(umctl2_base + DDR4_SWCTL_OFFSET, DDR4_SWCTL_SW_DONE); + + ret = enable_quasi_dynamic_reg_grp3(umctl2_base, umctl2_type); + if (ret) + return ret; + + /* Enable access to the PHY configuration registers */ + clrbits_le16(handoff->phy_base + DDR_PHY_APBONLY0_OFFSET, + DDR_PHY_MICROCONTMUXSEL); + + if (umctl2_type == DDRTYPE_DDR4) { + val = GET_HIGHB_DATA(readw((uintptr_t)(handoff->phy_base + + DMEM_MB_CDD_WW_1_0_OFFSET))); + + upd_val = GET_LOWB_DATA(readw((uintptr_t)(handoff->phy_base + + DMEM_MB_CDD_WW_0_1_OFFSET))); + } else if (umctl2_type == DDRTYPE_LPDDR4_0) { + val = GET_LOWB_DATA(readw((uintptr_t)(handoff->phy_base + + DMEM_MB_CDD_CHA_WW_1_0_OFFSET))); + + upd_val = GET_HIGHB_DATA(readw((uintptr_t)(handoff->phy_base + + DMEM_MB_CDD_CHA_WW_0_1_OFFSET))); + } else if (umctl2_type == DDRTYPE_LPDDR4_1) { + val = GET_HIGHB_DATA(readw((uintptr_t)(handoff->phy_base + + DMEM_MB_CDD_CHB_WW_1_0_OFFSET))); + + upd_val = GET_LOWB_DATA(readw((uintptr_t)(handoff->phy_base + + DMEM_MB_CDD_CHB_WW_0_1_OFFSET))); + } + + upd_val = max(val, upd_val); + debug("max value is 0x%x\n", upd_val); + + /* Divided by two is required when running in freq ratio 1:2 */ + if (!(readl(umctl2_base + DDR4_MSTR_OFFSET) & DDR4_FREQ_RATIO)) + upd_val = DIV_ROUND_CLOSEST(upd_val, 2); + + debug("Update train value to umctl2 RANKCTL.diff_rank_wr_gap\n"); + rankctl_reg_addr = umctl2_base + DDR4_RANKCTL_OFFSET; + /* Update train value to umctl2 RANKCTL.diff_rank_wr_gap */ + set_cal_res_to_rankctrl(rankctl_reg_addr, upd_val, + DDR4_RANKCTL_DIFF_RANK_WR_GAP, + DDR4_RANKCTL_DIFF_RANK_WR_GAP_MSB, + DDR4_RANKCTL_DIFF_RANK_WR_GAP_SHIFT); + + debug("Update train value to umctl2 DRAMTMG2.W2RD\n"); + dramtmg2_reg_addr = umctl2_base + DDR4_DRAMTMG2_OFFSET; + /* Update train value to umctl2 dramtmg2.wr2rd */ + set_cal_res_to_reg(dramtmg2_reg_addr, upd_val, DDR4_DRAMTMG2_WR2RD, 0); + + if (umctl2_type == DDRTYPE_DDR4) { + debug("Update train value to umctl2 DRAMTMG9.W2RD_S\n"); + reg_addr = umctl2_base + DDR4_DRAMTMG9_OFFSET; + /* Update train value to umctl2 dramtmg9.wr2rd_s */ + set_cal_res_to_reg(reg_addr, upd_val, DDR4_DRAMTMG9_W2RD_S, 0); + } + + if (umctl2_type == DDRTYPE_DDR4) { + val = GET_HIGHB_DATA(readw((uintptr_t)(handoff->phy_base + + DMEM_MB_CDD_RR_1_0_OFFSET))); + + upd_val = GET_LOWB_DATA(readw((uintptr_t)(handoff->phy_base + + DMEM_MB_CDD_RR_0_1_OFFSET))); + } else if (umctl2_type == DDRTYPE_LPDDR4_0) { + val = GET_LOWB_DATA(readw((uintptr_t)(handoff->phy_base + + DMEM_MB_CDD_CHA_RR_1_0_OFFSET))); + + upd_val = GET_HIGHB_DATA(readw((uintptr_t)(handoff->phy_base + + DMEM_MB_CDD_CHA_RR_0_1_OFFSET))); + } else if (umctl2_type == DDRTYPE_LPDDR4_1) { + val = GET_HIGHB_DATA(readw((uintptr_t)(handoff->phy_base + + DMEM_MB_CDD_CHB_RR_1_0_OFFSET))); + + upd_val = GET_LOWB_DATA(readw((uintptr_t)(handoff->phy_base + + DMEM_MB_CDD_CHB_RR_0_1_OFFSET))); + } + + upd_val = max(val, upd_val); + debug("max value is 0x%x\n", upd_val); + + /* Divided by two is required when running in freq ratio 1:2 */ + if (!(readl(umctl2_base + DDR4_MSTR_OFFSET) & DDR4_FREQ_RATIO)) + upd_val = DIV_ROUND_CLOSEST(upd_val, 2); + + debug("Update train value to umctl2 RANKCTL.diff_rank_rd_gap\n"); + /* Update train value to umctl2 RANKCTL.diff_rank_rd_gap */ + set_cal_res_to_rankctrl(rankctl_reg_addr, upd_val, + DDR4_RANKCTL_DIFF_RANK_RD_GAP, + DDR4_RANKCTL_DIFF_RANK_RD_GAP_MSB, + DDR4_RANKCTL_DIFF_RANK_RD_GAP_SHIFT); + + if (umctl2_type == DDRTYPE_DDR4) { + val = GET_HIGHB_DATA(readw((uintptr_t)(handoff->phy_base + + DMEM_MB_CDD_RW_1_1_OFFSET))); + + upd_val = GET_LOWB_DATA(readw((uintptr_t)(handoff->phy_base + + DMEM_MB_CDD_RW_1_0_OFFSET))); + + upd_val = max(val, upd_val); + + val = GET_HIGHB_DATA(readw((uintptr_t)(handoff->phy_base + + DMEM_MB_CDD_RW_0_1_OFFSET))); + + upd_val = max(val, upd_val); + + val = GET_LOWB_DATA(readw((uintptr_t)(handoff->phy_base + + DMEM_MB_CDD_RW_0_0_OFFSET))); + + upd_val = max(val, upd_val); + } else if (umctl2_type == DDRTYPE_LPDDR4_0) { + val = GET_LOWB_DATA(readw((uintptr_t)(handoff->phy_base + + DMEM_MB_CDD_CHA_RW_1_1_OFFSET))); + + upd_val = GET_HIGHB_DATA(readw((uintptr_t)(handoff->phy_base + + DMEM_MB_CDD_CHA_RW_1_0_OFFSET))); + + upd_val = max(val, upd_val); + + val = GET_LOWB_DATA(readw((uintptr_t)(handoff->phy_base + + DMEM_MB_CDD_CHA_RW_0_1_OFFSET))); + + upd_val = max(val, upd_val); + + val = GET_HIGHB_DATA(readw((uintptr_t)(handoff->phy_base + + DMEM_MB_CDD_CHA_RW_0_0_OFFSET))); + + upd_val = max(val, upd_val); + } else if (umctl2_type == DDRTYPE_LPDDR4_1) { + val = GET_HIGHB_DATA(readw((uintptr_t)(handoff->phy_base + + DMEM_MB_CDD_CHB_RW_1_1_OFFSET))); + + upd_val = GET_LOWB_DATA(readw((uintptr_t)(handoff->phy_base + + DMEM_MB_CDD_CHB_RW_1_0_OFFSET))); + + upd_val = max(val, upd_val); + + val = GET_HIGHB_DATA(readw((uintptr_t)(handoff->phy_base + + DMEM_MB_CDD_CHB_RW_0_1_OFFSET))); + + upd_val = max(val, upd_val); + + val = GET_LOWB_DATA(readw((uintptr_t)(handoff->phy_base + + DMEM_MB_CDD_CHB_RW_0_0_OFFSET))); + + upd_val = max(val, upd_val); + } + + debug("max value is 0x%x\n", upd_val); + + /* Divided by two is required when running in freq ratio 1:2 */ + if (!(readl(umctl2_base + DDR4_MSTR_OFFSET) & DDR4_FREQ_RATIO)) + upd_val = DIV_ROUND_CLOSEST(upd_val, 2); + + debug("Update train value to umctl2 dramtmg2.rd2wr\n"); + /* Update train value to umctl2 dramtmg2.rd2wr */ + set_cal_res_to_reg(dramtmg2_reg_addr, upd_val, DDR4_DRAMTMG2_RD2WR, + DDR4_DRAMTMG2_RD2WR_SHIFT); + + /* Checking ECC is enabled?, lpddr4 using inline ECC */ + val = readl(umctl2_base + DDR4_ECCCFG0_OFFSET) & DDR4_ECC_MODE; + if (val && umctl2_type == DDRTYPE_DDR4) + numdbyte = 0x9; + + upd_val = 0; + + /* Getting max value from DBYTEx TxDqsDlyTg0_u0_p0 */ + upd_val = get_max_txdqsdlytg0_ux_p0(handoff, + DDR_PHY_DBYTE0_TXDQDLYTG0_U0_P0, + numdbyte, upd_val); + + /* Getting max value from DBYTEx TxDqsDlyTg0_u1_p0 */ + upd_val = get_max_txdqsdlytg0_ux_p0(handoff, + DDR_PHY_DBYTE0_TXDQDLYTG0_U1_P0, + numdbyte, upd_val); + + debug("TxDqsDlyTg0 max value is 0x%x\n", upd_val); + + /* Divided by two is required when running in freq ratio 1:2 */ + if (!(readl(umctl2_base + DDR4_MSTR_OFFSET) & DDR4_FREQ_RATIO)) + upd_val = DIV_ROUND_CLOSEST(upd_val, 2); + + reg_addr = umctl2_base + DDR4_DFITMG1_OFFSET; + /* Update train value to umctl2 dfitmg1.dfi_wrdata_delay */ + set_cal_res_to_reg(reg_addr, upd_val, DDR4_DFITMG1_DFI_T_WRDATA_DELAY, + DDR4_DFITMG1_DFI_T_WRDATA_SHIFT); + + /* Complete quasi-dynamic register programming */ + setbits_le32(umctl2_base + DDR4_SWCTL_OFFSET, DDR4_SWCTL_SW_DONE); + + /* Polling programming done */ + ret = wait_for_bit_le32((const void *)(umctl2_base + + DDR4_SWSTAT_OFFSET), DDR4_SWSTAT_SW_DONE_ACK, + true, TIMEOUT_200MS, false); + if (ret) { + debug("%s: Timeout while waiting for", __func__); + debug(" programming done\n"); + } + + /* Isolate the APB access from internal CSRs */ + setbits_le16(handoff->phy_base + DDR_PHY_APBONLY0_OFFSET, + DDR_PHY_MICROCONTMUXSEL); + + return ret; +} + +static int start_ddr_calibration(struct ddr_handoff *ddr_handoff_info) +{ + int ret; + + /* Implement 1D training firmware */ + ret = configure_1d_training_firmware(ddr_handoff_info); + if (ret) { + debug("%s: Failed to configure 1D training firmware\n", + __func__); + return ret; + } + + calibrating_sdram(ddr_handoff_info); + + ret = poll_for_training_complete(ddr_handoff_info); + if (ret) { + debug("%s: Failed to get FW training completed\n", + __func__); + return ret; + } + + /* Updating training result to DDR controller */ + if (ddr_handoff_info->cntlr_t == DDRTYPE_DDR4) { + ret = set_cal_res_to_umctl2(ddr_handoff_info, + ddr_handoff_info->cntlr_base, + ddr_handoff_info->cntlr_t); + if (ret) { + debug("%s: Failed to update train result to ", + __func__); + debug("DDR controller\n"); + return ret; + } + } + + /* Implement 2D training firmware */ + ret = configure_2d_training_firmware(ddr_handoff_info); + if (ret) { + if (ret) { + debug("%s: Failed to update train result to ", + __func__); + debug("DDR controller\n"); + return ret; + } + } + + calibrating_sdram(ddr_handoff_info); + + ret = poll_for_training_complete(ddr_handoff_info); + if (ret) + debug("%s: Failed to get FW training completed\n", + __func__); + + return ret; +} + +static int init_controller(struct ddr_handoff *ddr_handoff_info, + u32 *user_backup, u32 *user_backup_2nd) +{ + int ret = 0; + + if (ddr_handoff_info->cntlr_t == DDRTYPE_DDR4 || + ddr_handoff_info->cntlr_t == DDRTYPE_LPDDR4_0) { + /* Initialize 1st DDR controller */ + ret = init_umctl2(ddr_handoff_info->cntlr_handoff_base, + ddr_handoff_info->cntlr_base, + ddr_handoff_info->cntlr_t, + ddr_handoff_info->cntlr_handoff_length, + user_backup); + if (ret) { + debug("%s: Failed to inilialize first controller\n", + __func__); + return ret; + } + } + + if (ddr_handoff_info->cntlr2_t == DDRTYPE_LPDDR4_1) { + /* Initialize 2nd DDR controller */ + ret = init_umctl2(ddr_handoff_info->cntlr2_handoff_base, + ddr_handoff_info->cntlr2_base, + ddr_handoff_info->cntlr2_t, + ddr_handoff_info->cntlr2_handoff_length, + user_backup_2nd); + if (ret) + debug("%s: Failed to inilialize 2nd controller\n", + __func__); + } + + return ret; +} + +static int dfi_init(struct ddr_handoff *ddr_handoff_info) +{ + int ret; + + ret = ddr_start_dfi_init(ddr_handoff_info->cntlr_base, + ddr_handoff_info->cntlr_t); + if (ret) + return ret; + + if (ddr_handoff_info->cntlr2_t == DDRTYPE_LPDDR4_1) + ret = ddr_start_dfi_init(ddr_handoff_info->cntlr2_base, + ddr_handoff_info->cntlr2_t); + + return ret; +} + +static int check_dfi_init(struct ddr_handoff *handoff) +{ + int ret; + + ret = ddr_check_dfi_init_complete(handoff->cntlr_base, + handoff->cntlr_t); + if (ret) + return ret; + + if (handoff->cntlr2_t == DDRTYPE_LPDDR4_1) + ret = ddr_check_dfi_init_complete(handoff->cntlr2_base, + handoff->cntlr2_t); + + return ret; +} + +static int trigger_sdram_init(struct ddr_handoff *handoff) +{ + int ret; + + ret = ddr_trigger_sdram_init(handoff->cntlr_base, + handoff->cntlr_t); + if (ret) + return ret; + + if (handoff->cntlr2_t == DDRTYPE_LPDDR4_1) + ret = ddr_trigger_sdram_init(handoff->cntlr2_base, + handoff->cntlr2_t); + + return ret; +} + +static int ddr_post_config(struct ddr_handoff *handoff) +{ + int ret; + + ret = ddr_post_handoff_config(handoff->cntlr_base, + handoff->cntlr_t); + if (ret) + return ret; + + if (handoff->cntlr2_t == DDRTYPE_LPDDR4_1) + ret = ddr_post_handoff_config(handoff->cntlr2_base, + handoff->cntlr2_t); + + return ret; +} + +int sdram_mmr_init_full(struct udevice *dev) +{ + u32 user_backup[2], user_backup_2nd[2]; + int ret; + struct bd_info bd; + struct ddr_handoff ddr_handoff_info; + struct altera_sdram_priv *priv = dev_get_priv(dev); + + printf("Checking SDRAM configuration in progress ...\n"); + ret = populate_ddr_handoff(&ddr_handoff_info); + if (ret) { + debug("%s: Failed to populate DDR handoff\n", + __func__); + return ret; + } + + /* Set the MPFE NoC mux to correct DDR controller type */ + use_ddr4(ddr_handoff_info.cntlr_t); + + if (!is_ddr_init_skipped()) { + printf("SDRAM init in progress ...\n"); + + /* + * Polling reset complete, must be high to ensure DDR subsystem + * in complete reset state before init DDR clock and DDR + * controller + */ + ret = wait_for_bit_le32((const void *)((uintptr_t)(readl + (ddr_handoff_info.mem_reset_base) + + MEM_RST_MGR_STATUS)), + MEM_RST_MGR_STATUS_RESET_COMPLETE, + true, TIMEOUT_200MS, false); + if (ret) { + debug("%s: Timeout while waiting for", __func__); + debug(" reset complete done\n"); + return ret; + } + + ret = enable_ddr_clock(dev); + if (ret) + return ret; + + ret = init_controller(&ddr_handoff_info, user_backup, + user_backup_2nd); + if (ret) { + debug("%s: Failed to inilialize DDR controller\n", + __func__); + return ret; + } + + /* Release the controller from reset */ + setbits_le32((uintptr_t) + (readl(ddr_handoff_info.mem_reset_base) + + MEM_RST_MGR_STATUS), MEM_RST_MGR_STATUS_AXI_RST | + MEM_RST_MGR_STATUS_CONTROLLER_RST | + MEM_RST_MGR_STATUS_RESET_COMPLETE); + + printf("DDR controller configuration is completed\n"); + + /* Initialize DDR PHY */ + ret = init_phy(&ddr_handoff_info); + if (ret) { + debug("%s: Failed to inilialize DDR PHY\n", __func__); + return ret; + } + + enable_phy_clk_for_csr_access(&ddr_handoff_info, true); + + ret = start_ddr_calibration(&ddr_handoff_info); + if (ret) { + debug("%s: Failed to calibrate DDR\n", __func__); + return ret; + } + + enable_phy_clk_for_csr_access(&ddr_handoff_info, false); + + /* Reset ARC processor when no using for security purpose */ + setbits_le16(ddr_handoff_info.phy_base + + DDR_PHY_MICRORESET_OFFSET, + DDR_PHY_MICRORESET_RESET); + + /* DDR freq set to support DDR4-3200 */ + phy_init_engine(&ddr_handoff_info); + + ret = dfi_init(&ddr_handoff_info); + if (ret) + return ret; + + ret = check_dfi_init(&ddr_handoff_info); + if (ret) + return ret; + + ret = trigger_sdram_init(&ddr_handoff_info); + if (ret) + return ret; + + ret = ddr_post_config(&ddr_handoff_info); + if (ret) + return ret; + + /* Restore user settings */ + writel(user_backup[0], ddr_handoff_info.cntlr_base + + DDR4_PWRCTL_OFFSET); + + if (ddr_handoff_info.cntlr2_t == DDRTYPE_LPDDR4_0) + setbits_le32(ddr_handoff_info.cntlr_base + + DDR4_INIT0_OFFSET, user_backup[1]); + + if (ddr_handoff_info.cntlr2_t == DDRTYPE_LPDDR4_1) { + /* Restore user settings */ + writel(user_backup_2nd[0], + ddr_handoff_info.cntlr2_base + + DDR4_PWRCTL_OFFSET); + + setbits_le32(ddr_handoff_info.cntlr2_base + + DDR4_INIT0_OFFSET, user_backup_2nd[1]); + } + + /* Enable input traffic per port */ + setbits_le32(ddr_handoff_info.cntlr_base + DDR4_PCTRL0_OFFSET, + DDR4_PCTRL0_PORT_EN); + + if (ddr_handoff_info.cntlr2_t == DDRTYPE_LPDDR4_1) { + /* Enable input traffic per port */ + setbits_le32(ddr_handoff_info.cntlr2_base + + DDR4_PCTRL0_OFFSET, DDR4_PCTRL0_PORT_EN); + } + + printf("DDR init success\n"); + } + + /* Get bank configuration from devicetree */ + ret = fdtdec_decode_ram_size(gd->fdt_blob, NULL, 0, NULL, + (phys_size_t *)&gd->ram_size, &bd); + if (ret) { + debug("%s: Failed to decode memory node\n", __func__); + return -1; + } + + printf("DDR: %lld MiB\n", gd->ram_size >> 20); + + priv->info.base = bd.bi_dram[0].start; + priv->info.size = gd->ram_size; + + sdram_size_check(&bd); + + /* This enables nonsecure access to DDR */ + /* mpuregion0addr_limit */ + FW_MPU_DDR_SCR_WRITEL(gd->ram_size - 1, + FW_MPU_DDR_SCR_MPUREGION0ADDR_LIMIT); + FW_MPU_DDR_SCR_WRITEL(0x1F, FW_MPU_DDR_SCR_MPUREGION0ADDR_LIMITEXT); + + /* nonmpuregion0addr_limit */ + FW_MPU_DDR_SCR_WRITEL(gd->ram_size - 1, + FW_MPU_DDR_SCR_NONMPUREGION0ADDR_LIMIT); + + /* Enable mpuregion0enable and nonmpuregion0enable */ + FW_MPU_DDR_SCR_WRITEL(MPUREGION0_ENABLE | NONMPUREGION0_ENABLE, + FW_MPU_DDR_SCR_EN_SET); + + return 0; +} diff --git a/drivers/ddr/altera/sdram_soc64.c b/drivers/ddr/altera/sdram_soc64.c index 171cde0e6b..002aa08673 100644 --- a/drivers/ddr/altera/sdram_soc64.c +++ b/drivers/ddr/altera/sdram_soc64.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0 /* - * Copyright (C) 2016-2019 Intel Corporation <www.intel.com> + * Copyright (C) 2016-2021 Intel Corporation <www.intel.com> * */
@@ -100,12 +100,14 @@ int emif_reset(struct altera_sdram_plat *plat) return 0; }
+#if !IS_ENABLED(CONFIG_TARGET_SOCFPGA_N5X) int poll_hmc_clock_status(void) { return wait_for_bit_le32((const void *)(socfpga_get_sysmgr_addr() + SYSMGR_SOC64_HMC_CLK), SYSMGR_HMC_CLK_STATUS_MSK, true, 1000, false); } +#endif
void sdram_clear_mem(phys_addr_t addr, phys_size_t size) { @@ -250,6 +252,11 @@ static int altera_sdram_of_to_plat(struct udevice *dev) struct altera_sdram_plat *plat = dev_get_plat(dev); fdt_addr_t addr;
+ /* These regs info are part of DDR handoff in bitstream */ +#if IS_ENABLED(CONFIG_TARGET_SOCFPGA_N5X) + return 0; +#endif + addr = dev_read_addr_index(dev, 0); if (addr == FDT_ADDR_T_NONE) return -EINVAL; @@ -310,6 +317,7 @@ static struct ram_ops altera_sdram_ops = { static const struct udevice_id altera_sdram_ids[] = { { .compatible = "altr,sdr-ctl-s10" }, { .compatible = "intel,sdr-ctl-agilex" }, + { .compatible = "intel,sdr-ctl-dm" }, { /* sentinel */ } };
-----Original Message----- From: Lim, Elly Siew Chin elly.siew.chin.lim@intel.com Sent: Wednesday, March 31, 2021 10:39 PM To: u-boot@lists.denx.de Cc: Marek Vasut marex@denx.de; Tan, Ley Foon ley.foon.tan@intel.com; See, Chin Liang chin.liang.see@intel.com; Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Chee, Tien Fong tien.fong.chee@intel.com; Westergreen, Dalon dalon.westergreen@intel.com; Simon Glass sjg@chromium.org; Gan, Yau Wai yau.wai.gan@intel.com; Lim, Elly Siew Chin elly.siew.chin.lim@intel.com Subject: [v1 12/17] ddr: altera: Add SDRAM driver for Intel N5X device
The DDR subsystem in Diamond Mesa is consisted of controller, PHY, memory reset manager and memory clock manager.
Configuration settings of controller, PHY and memory reset manager is come from DDR handoff data in bitstream, which contain the register base addresses and user settings from Quartus.
Configuration settings of memory clock manager is come from the HPS handoff data in bitstream, however the register base address is defined in device tree.
The calibration is fully done in HPS, which requires IMEM and DMEM binaries loading to PHY SRAM for running this calibration, both IMEM and DMEM binaries are also part of bitstream, this bitstream would be loaded to OCRAM by SDM, and configured by DDR driver.
Signed-off-by: Siew Chin Lim elly.siew.chin.lim@intel.com Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com
arch/arm/mach-socfpga/include/mach/firewall.h | 6 + .../include/mach/system_manager_soc64.h | 10 +- drivers/ddr/altera/Makefile | 3 +- drivers/ddr/altera/sdram_n5x.c | 2316 ++++++++++++++++++++ drivers/ddr/altera/sdram_soc64.c | 10 +- 5 files changed, 2342 insertions(+), 3 deletions(-) create mode 100644 drivers/ddr/altera/sdram_n5x.c
--- /dev/null +++ b/drivers/ddr/altera/sdram_n5x.c @@ -0,0 +1,2316 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
- Copyright (C) 2020-2021 Intel Corporation <www.intel.com>
+#include <common.h>
Sorting this.
+#include <asm/arch/firewall.h> +#include <asm/arch/handoff_soc64.h> +#include <asm/arch/misc.h> +#include <asm/arch/reset_manager.h> +#include <asm/arch/system_manager.h> +#include <asm/global_data.h> +#include <asm/io.h> +#include <clk.h> +#include <div64.h> +#include <dm.h> +#include <errno.h> +#include <fdtdec.h> +#include <hang.h> +#include <linux/err.h> +#include <linux/sizes.h> +#include <ram.h> +#include <reset.h> +#include "sdram_soc64.h" +#include <wait_bit.h>
+DECLARE_GLOBAL_DATA_PTR;
+/* MPFE NOC registers */ +#define FPGA2SDRAM_MGR_MAIN_SIDEBANDMGR_FLAGOUTSET0 0xF8024050
+/* Memory reset manager */ +#define MEM_RST_MGR_STATUS 0x8
+/* Register and bit in memory reset manager */ +#define MEM_RST_MGR_STATUS_RESET_COMPLETE BIT(0) +#define MEM_RST_MGR_STATUS_PWROKIN_STATUS BIT(1) +#define MEM_RST_MGR_STATUS_CONTROLLER_RST BIT(2) +#define MEM_RST_MGR_STATUS_AXI_RST BIT(3)
+#define TIMEOUT_200MS 200 +#define TIMEOUT_5000MS 5000
+/* DDR4 umctl2 */ +#define DDR4_MSTR_OFFSET 0x0 +#define DDR4_FREQ_RATIO BIT(22)
+#define DDR4_STAT_OFFSET 0x4 +#define DDR4_STAT_SELFREF_TYPE (BIT(5) | BIT(4)) +#define DDR4_STAT_SELFREF_TYPE_SHIFT 4 +#define DDR4_STAT_OPERATING_MODE (BIT(2) | BIT(1) | BIT(0))
+#define DDR4_MRCTRL0_OFFSET 0x10 +#define DDR4_MRCTRL0_MR_TYPE BIT(0) +#define DDR4_MRCTRL0_MPR_EN BIT(1) +#define DDR4_MRCTRL0_MR_RANK (BIT(5) | BIT(4)) +#define DDR4_MRCTRL0_MR_RANK_SHIFT 4 +#define DDR4_MRCTRL0_MR_ADDR (BIT(15) | BIT(14) | BIT(13) | BIT(12))
This is mask value? If yes, can use GENMASK() macro. Same for the defines below.
+#define DDR4_MRCTRL0_MR_ADDR_SHIFT 12 +#define DDR4_MRCTRL0_MR_WR BIT(31)
+#define DDR4_MRCTRL1_OFFSET 0x14 +#define DDR4_MRCTRL1_MR_DATA 0x3FFFF
+#define DDR4_MRSTAT_OFFSET 0x18 +#define DDR4_MRSTAT_MR_WR_BUSY BIT(0)
+#define DDR4_MRCTRL2_OFFSET 0x1C
+#define DDR4_PWRCTL_OFFSET 0x30 +#define DDR4_PWRCTL_SELFREF_EN BIT(0) +#define DDR4_PWRCTL_POWERDOWN_EN BIT(1) +#define DDR4_PWRCTL_EN_DFI_DRAM_CLK_DISABLE BIT(3) +#define DDR4_PWRCTL_SELFREF_SW BIT(5)
+#define DDR4_PWRTMG_OFFSET 0x34 +#define DDR4_HWLPCTL_OFFSET 0x38 +#define DDR4_RFSHCTL0_OFFSET 0x50 +#define DDR4_RFSHCTL1_OFFSET 0x54
+#define DDR4_RFSHCTL3_OFFSET 0x60 +#define DDR4_RFSHCTL3_DIS_AUTO_REFRESH BIT(0) +#define DDR4_RFSHCTL3_REFRESH_MODE (BIT(6) | BIT(5) | BIT(4)) +#define DDR4_RFSHCTL3_REFRESH_MODE_SHIFT 4
+#define DDR4_ECCCFG0_OFFSET 0x70 +#define DDR4_ECC_MODE (BIT(2) | BIT(1) | BIT(0)) +#define DDR4_DIS_SCRUB BIT(4) +#define LPDDR4_ECCCFG0_ECC_REGION_MAP_GRANU_SHIFT 30 +#define LPDDR4_ECCCFG0_ECC_REGION_MAP_SHIFT 8
+#define DDR4_ECCCFG1_OFFSET 0x74 +#define LPDDR4_ECCCFG1_ECC_REGIONS_PARITY_LOCK BIT(4)
+#define DDR4_CRCPARCTL0_OFFSET 0xC0 +#define DDR4_CRCPARCTL0_DFI_ALERT_ERR_INIT_CLR BIT(1)
+#define DDR4_CRCPARCTL1_OFFSET 0xC4 +#define DDR4_CRCPARCTL1_CRC_PARITY_RETRY_ENABLE BIT(8) +#define DDR4_CRCPARCTL1_ALERT_WAIT_FOR_SW BIT(9)
+#define DDR4_CRCPARSTAT_OFFSET 0xCC +#define DDR4_CRCPARSTAT_DFI_ALERT_ERR_INT BIT(16) +#define DDR4_CRCPARSTAT_DFI_ALERT_ERR_FATL_INT BIT(17) +#define DDR4_CRCPARSTAT_DFI_ALERT_ERR_NO_SW BIT(19) +#define DDR4_CRCPARSTAT_CMD_IN_ERR_WINDOW BIT(29)
+#define DDR4_INIT0_OFFSET 0xD0 +#define DDR4_INIT0_SKIP_RAM_INIT (BIT(31) | BIT(30))
+#define DDR4_RANKCTL_OFFSET 0xF4 +#define DDR4_RANKCTL_DIFF_RANK_RD_GAP (BIT(7) | BIT(6) | BIT(5) | \
BIT(4))
+#define DDR4_RANKCTL_DIFF_RANK_WR_GAP (BIT(11) | BIT(10) | BIT(9) | \
BIT(8))
+#define DDR4_RANKCTL_DIFF_RANK_RD_GAP_MSB BIT(24) +#define DDR4_RANKCTL_DIFF_RANK_WR_GAP_MSB BIT(26) +#define DDR4_RANKCTL_DIFF_RANK_RD_GAP_SHIFT 4 +#define DDR4_RANKCTL_DIFF_RANK_WR_GAP_SHIFT 8 +#define DDR4_RANKCTL_DIFF_RANK_RD_GAP_MSB_SHIFT 24 +#define DDR4_RANKCTL_DIFF_RANK_WR_GAP_MSB_SHIFT 26
+#define DDR4_RANKCTL1_OFFSET 0xF8 +#define DDR4_RANKCTL1_WR2RD_DR (BIT(5) | BIT(4) | BIT(3) | BIT(2) | BIT(1) | \
BIT(0))
+#define DDR4_DRAMTMG2_OFFSET 0x108 +#define DDR4_DRAMTMG2_WR2RD (BIT(5) | BIT(4) | BIT(3) | BIT(2) | BIT(1) | \
BIT(0))
+#define DDR4_DRAMTMG2_RD2WR (BIT(13) | BIT(12) | BIT(11) | BIT(10) | \
BIT(9) | BIT(8))
+#define DDR4_DRAMTMG2_RD2WR_SHIFT 8
+#define DDR4_DRAMTMG9_OFFSET 0x124 +#define DDR4_DRAMTMG9_W2RD_S (BIT(5) | BIT(4) | BIT(3) | BIT(2) | BIT(1) | \
BIT(0))
+#define DDR4_DFITMG1_OFFSET 0x194 +#define DDR4_DFITMG1_DFI_T_WRDATA_DELAY (BIT(20) | BIT(19) | BIT(18) | \
BIT(17) | BIT(16))
+#define DDR4_DFITMG1_DFI_T_WRDATA_SHIFT 16
+#define DDR4_DFIMISC_OFFSET 0x1B0 +#define DDR4_DFIMISC_DFI_INIT_COMPLETE_EN BIT(0) +#define DDR4_DFIMISC_DFI_INIT_START BIT(5)
+#define DDR4_DFISTAT_OFFSET 0x1BC +#define DDR4_DFI_INIT_COMPLETE BIT(0)
+#define DDR4_DBG0_OFFSET 0x300
+#define DDR4_DBG1_OFFSET 0x304 +#define DDR4_DBG1_DISDQ BIT(0) +#define DDR4_DBG1_DIS_HIF BIT(1)
+#define DDR4_DBGCAM_OFFSET 0x308 +#define DDR4_DBGCAM_DBG_RD_Q_EMPTY BIT(25) +#define DDR4_DBGCAM_DBG_WR_Q_EMPTY BIT(26) +#define DDR4_DBGCAM_RD_DATA_PIPELINE_EMPTY BIT(28) +#define DDR4_DBGCAM_WR_DATA_PIPELINE_EMPTY BIT(29)
+#define DDR4_SWCTL_OFFSET 0x320 +#define DDR4_SWCTL_SW_DONE BIT(0)
+#define DDR4_SWSTAT_OFFSET 0x324 +#define DDR4_SWSTAT_SW_DONE_ACK BIT(0)
+#define DDR4_PSTAT_OFFSET 0x3FC +#define DDR4_PSTAT_RD_PORT_BUSY_0 BIT(0) +#define DDR4_PSTAT_WR_PORT_BUSY_0 BIT(16)
+#define DDR4_PCTRL0_OFFSET 0x490 +#define DDR4_PCTRL0_PORT_EN BIT(0)
+#define DDR4_SBRCTL_OFFSET 0xF24 +#define DDR4_SBRCTL_SCRUB_INTERVAL 0x1FFF00 +#define DDR4_SBRCTL_SCRUB_EN BIT(0) +#define DDR4_SBRCTL_SCRUB_WRITE BIT(2) +#define DDR_SBRCTL_SCRUB_BURST_1 BIT(4)
This should be "DDR4" prefix?
+#define DDR4_SBRSTAT_OFFSET 0xF28 +#define DDR4_SBRSTAT_SCRUB_BUSY BIT(0) +#define DDR4_SBRSTAT_SCRUB_DONE BIT(1)
+#define DDR4_SBRWDATA0_OFFSET 0xF2C +#define DDR4_SBRWDATA1_OFFSET 0xF30 +#define DDR4_SBRSTART0_OFFSET 0xF38 +#define DDR4_SBRSTART1_OFFSET 0xF3C +#define DDR4_SBRRANGE0_OFFSET 0xF40 +#define DDR4_SBRRANGE1_OFFSET 0xF44
+/* DDR PHY */ +#define DDR_PHY_TXODTDRVSTREN_B0_P0 0x2009A +#define DDR_PHY_RXPBDLYTG0_R0 0x200D0 +#define DDR_PHY_DBYTE0_TXDQDLYTG0_U0_P0 0x201A0
+#define DDR_PHY_DBYTE0_TXDQDLYTG0_U1_P0 0x203A0 +#define DDR_PHY_DBYTE1_TXDQDLYTG0_U0_P0 0x221A0 +#define DDR_PHY_DBYTE1_TXDQDLYTG0_U1_P0 0x223A0 +#define DDR_PHY_TXDQDLYTG0_COARSE_DELAY (BIT(9) | BIT(8) | BIT(7) | BIT(6)) +#define DDR_PHY_TXDQDLYTG0_COARSE_DELAY_SHIFT 6
+#define DDR_PHY_CALRATE_OFFSET 0x40110 +#define DDR_PHY_CALZAP_OFFSET 0x40112 +#define DDR_PHY_SEQ0BDLY0_P0_OFFSET 0x40016 +#define DDR_PHY_SEQ0BDLY1_P0_OFFSET 0x40018 +#define DDR_PHY_SEQ0BDLY2_P0_OFFSET 0x4001A +#define DDR_PHY_SEQ0BDLY3_P0_OFFSET 0x4001C
+#define DDR_PHY_MEMRESETL_OFFSET 0x400C0 +#define DDR_PHY_MEMRESETL_VALUE BIT(0) +#define DDR_PHY_PROTECT_MEMRESET BIT(1)
+#define DDR_PHY_CALBUSY_OFFSET 0x4012E +#define DDR_PHY_CALBUSY BIT(0)
+#define DDR_PHY_TRAIN_IMEM_OFFSET 0xA0000 +#define DDR_PHY_TRAIN_DMEM_OFFSET 0xA8000
+#define DMEM_MB_CDD_RR_1_0_OFFSET 0xA802C +#define DMEM_MB_CDD_RR_0_1_OFFSET 0xA8030 +#define DMEM_MB_CDD_WW_1_0_OFFSET 0xA8038 +#define DMEM_MB_CDD_WW_0_1_OFFSET 0xA803C +#define DMEM_MB_CDD_RW_1_1_OFFSET 0xA8046 +#define DMEM_MB_CDD_RW_1_0_OFFSET 0xA8048 +#define DMEM_MB_CDD_RW_0_1_OFFSET 0xA804A +#define DMEM_MB_CDD_RW_0_0_OFFSET 0xA804C
+#define DMEM_MB_CDD_CHA_RR_1_0_OFFSET 0xA8026 +#define DMEM_MB_CDD_CHA_RR_0_1_OFFSET 0xA8026 +#define DMEM_MB_CDD_CHB_RR_1_0_OFFSET 0xA8058 +#define DMEM_MB_CDD_CHB_RR_0_1_OFFSET 0xA805A +#define DMEM_MB_CDD_CHA_WW_1_0_OFFSET 0xA8030 +#define DMEM_MB_CDD_CHA_WW_0_1_OFFSET 0xA8030 +#define DMEM_MB_CDD_CHB_WW_1_0_OFFSET 0xA8062 +#define DMEM_MB_CDD_CHB_WW_0_1_OFFSET 0xA8064
+#define DMEM_MB_CDD_CHA_RW_1_1_OFFSET 0xA8028 +#define DMEM_MB_CDD_CHA_RW_1_0_OFFSET 0xA8028 +#define DMEM_MB_CDD_CHA_RW_0_1_OFFSET 0xA802A +#define DMEM_MB_CDD_CHA_RW_0_0_OFFSET 0xA802A
+#define DMEM_MB_CDD_CHB_RW_1_1_OFFSET 0xA805A +#define DMEM_MB_CDD_CHB_RW_1_0_OFFSET 0xA805C +#define DMEM_MB_CDD_CHB_RW_0_1_OFFSET 0xA805c +#define DMEM_MB_CDD_CHB_RW_0_0_OFFSET 0xA805E
+#define DDR_PHY_SEQ0DISABLEFLAG0_OFFSET 0x120018 +#define DDR_PHY_SEQ0DISABLEFLAG1_OFFSET 0x12001A +#define DDR_PHY_SEQ0DISABLEFLAG2_OFFSET 0x12001C +#define DDR_PHY_SEQ0DISABLEFLAG3_OFFSET 0x12001E +#define DDR_PHY_SEQ0DISABLEFLAG4_OFFSET 0x120020 +#define DDR_PHY_SEQ0DISABLEFLAG5_OFFSET 0x120022 +#define DDR_PHY_SEQ0DISABLEFLAG6_OFFSET 0x120024 +#define DDR_PHY_SEQ0DISABLEFLAG7_OFFSET 0x120026
+#define DDR_PHY_UCCLKHCLKENABLES_OFFSET 0x180100 +#define DDR_PHY_UCCLKHCLKENABLES_UCCLKEN BIT(0) +#define DDR_PHY_UCCLKHCLKENABLES_HCLKEN BIT(1)
+#define DDR_PHY_UCTWRITEPROT_OFFSET 0x180066 +#define DDR_PHY_UCTWRITEPROT BIT(0)
+#define DDR_PHY_APBONLY0_OFFSET 0x1A0000 +#define DDR_PHY_MICROCONTMUXSEL BIT(0)
+#define DDR_PHY_UCTSHADOWREGS_OFFSET 0x1A0008 +#define DDR_PHY_UCTSHADOWREGS_UCTWRITEPROTESHADOW BIT(0)
+#define DDR_PHY_DCTWRITEPROT_OFFSET 0x1A0062 +#define DDR_PHY_DCTWRITEPROT BIT(0)
+#define DDR_PHY_UCTWRITEONLYSHADOW_OFFSET 0x1A0064 +#define DDR_PHY_UCTDATWRITEONLYSHADOW_OFFSET 0x1A0068
+#define DDR_PHY_MICRORESET_OFFSET 0x1A0132 +#define DDR_PHY_MICRORESET_STALL BIT(0) +#define DDR_PHY_MICRORESET_RESET BIT(3)
+#define DDR_PHY_TXODTDRVSTREN_B0_P1 0x22009A
+/* For firmware training */ +#define HW_DBG_TRACE_CONTROL_OFFSET 0x18 +#define FW_TRAINING_COMPLETED_STAT 0x07 +#define FW_TRAINING_FAILED_STAT 0xFF +#define FW_COMPLETION_MSG_ONLY_MODE 0xFF +#define FW_STREAMING_MSG_ID 0x08 +#define GET_LOWHW_DATA(x) ((x) & 0xFFFF) +#define GET_LOWB_DATA(x) ((x) & 0xFF) +#define GET_HIGHB_DATA(x) (((x) & 0xFF00) >> 8)
+/* Operating mode */ +#define INIT_OPM 0x000 +#define NORMAL_OPM 0x001 +#define PWR_D0WN_OPM 0x010 +#define SELF_SELFREF_OPM 0x011 +#define DDR4_DEEP_PWR_DOWN_OPM 0x100
+/* Refresh mode */ +#define FIXED_1X 0 +#define FIXED_2X BIT(0) +#define FIXED_4X BIT(4)
+/* Address of mode register */ +#define MR0 0x0000 +#define MR1 0x0001 +#define MR2 0x0010 +#define MR3 0x0011 +#define MR4 0x0100 +#define MR5 0x0101 +#define MR6 0x0110 +#define MR7 0x0111
+/* MR rank */ +#define RANK0 0x1 +#define RANK1 0x2 +#define ALL_RANK 0x3
+#define MR5_BIT4 BIT(4)
+/* Value for ecc_region_map */ +#define ALL_PROTECTED 0x7F
+/* Region size for ECCCFG0.ecc_region_map */ +enum region_size {
- ONE_EIGHT,
- ONE_SIXTEENTH,
- ONE_THIRTY_SECOND,
- ONE_SIXTY_FOURTH
+enum ddr_type {
- DDRTYPE_LPDDR4_0,
- DDRTYPE_LPDDR4_1,
- DDRTYPE_DDR4,
- DDRTYPE_UNKNOWN
+/* DDR handoff structure */ +struct ddr_handoff {
- /* Memory reset manager base */
- phys_addr_t mem_reset_base;
- /* First controller attributes */
- phys_addr_t cntlr_handoff_base;
- phys_addr_t cntlr_base;
- size_t cntlr_total_length;
- enum ddr_type cntlr_t;
- size_t cntlr_handoff_length;
- /* Second controller attributes*/
- phys_addr_t cntlr2_handoff_base;
- phys_addr_t cntlr2_base;
- size_t cntlr2_total_length;
- enum ddr_type cntlr2_t;
- size_t cntlr2_handoff_length;
- /* PHY attributes */
- phys_addr_t phy_handoff_base;
- phys_addr_t phy_base;
- size_t phy_total_length;
- size_t phy_handoff_length;
- /* PHY engine attributes */
- phys_addr_t phy_engine_handoff_base;
- size_t phy_engine_total_length;
- size_t phy_engine_handoff_length;
- /* Calibration attributes */
- phys_addr_t train_imem_base;
- phys_addr_t train_dmem_base;
- size_t train_imem_length;
- size_t train_dmem_length;
+/* Message mode */ +enum message_mode {
- MAJOR_MESSAGE,
- STREAMING_MESSAGE
+static int clr_ca_parity_error_status(phys_addr_t umctl2_base) +{
- int ret;
- debug("%s: Clear C/A parity error status in MR5[4]\n", __func__);
- /* Set mode register MRS */
- clrbits_le32(umctl2_base + DDR4_MRCTRL0_OFFSET,
DDR4_MRCTRL0_MPR_EN);
- /* Set mode register to write operation */
- setbits_le32(umctl2_base + DDR4_MRCTRL0_OFFSET,
DDR4_MRCTRL0_MR_TYPE);
- /* Set the address of mode rgister to 0x101(MR5) */
(MR5 << DDR4_MRCTRL0_MR_ADDR_SHIFT) &
DDR4_MRCTRL0_MR_ADDR);
- /* Set MR rank to rank 1 */
(RANK1 << DDR4_MRCTRL0_MR_RANK_SHIFT) &
DDR4_MRCTRL0_MR_RANK);
- /* Clear C/A parity error status in MR5[4] */
- clrbits_le32(umctl2_base + DDR4_MRCTRL1_OFFSET, MR5_BIT4);
- /* Trigger mode register read or write operation */
DDR4_MRCTRL0_MR_WR);
- /* Wait for retry done */
- ret = wait_for_bit_le32((const void *)(umctl2_base +
DDR4_MRSTAT_OFFSET),
DDR4_MRSTAT_MR_WR_BUSY,
- if (ret) {
debug(" no outstanding MR transaction\n");
return ret;
+static int ddr_retry_software_sequence(phys_addr_t umctl2_base) +{
- u32 value;
- int ret;
- /* Check software can perform MRS/MPR/PDA? */
- value = readl(umctl2_base + DDR4_CRCPARSTAT_OFFSET) &
DDR4_CRCPARSTAT_DFI_ALERT_ERR_NO_SW;
- if (value) {
debug("%s: Software can't perform MRS/MPR/PDA\n",
__func__);
/* Clear interrupt bit for DFI alert error */
setbits_le32(umctl2_base + DDR4_CRCPARCTL0_OFFSET,
DDR4_CRCPARCTL0_DFI_ALERT_ERR_INIT_CLR);
if (ret) {
return ret;
if (clr_ca_parity_error_status(umctl2_base))
return ret;
Should return return value from clr_ca_parity_error_status()?
- } else {
debug("%s: Software can perform MRS/MPR/PDA\n",
__func__);
if (ret) {
return ret;
return ret;
Same here.
Can combine if...else ?
+static int ensure_retry_procedure_complete(phys_addr_t umctl2_base) +{
- u32 value;
- u32 start = get_timer(0);
- int ret;
- /* Check parity/crc/error window is emptied ? */
DDR4_CRCPARSTAT_CMD_IN_ERR_WINDOW;
- /* Polling until parity/crc/error window is emptied */
- while (value) {
__func__);
debug(" parity/crc/error window empty\n");
return -ETIMEDOUT;
/* Check software intervention is enabled? */
DDR4_CRCPARCTL1_ALERT_WAIT_FOR_SW;
if (value) {
debug("%s: Software intervention is enabled\n",
__func__);
/* Check dfi alert error interrupt is set? */
DDR4_CRCPARSTAT_DFI_ALERT_ERR_INT;
if (value) {
ret =
ddr_retry_software_sequence(umctl2_base);
debug("%s: DFI alert error interrupt ",
__func__);
debug("is set\n");
if (ret)
return ret;
* Check fatal parity error interrupt is set?
DDR4_CRCPARSTAT_DFI_ALERT_ERR_FATL_INT;
if (value) {
printf("%s: Fatal parity error ",
__func__);
printf("interrupt is set, Hang it!!\n");
hang();
udelay(1);
WATCHDOG_RESET();
+static int enable_quasi_dynamic_reg_grp3(phys_addr_t umctl2_base,
- u32 i, value, backup;
- int ret;
- /* Disable input traffic per port */
- clrbits_le32(umctl2_base + DDR4_PCTRL0_OFFSET,
- /* Polling AXI port until idle */
DDR4_PSTAT_OFFSET),
DDR4_PSTAT_WR_PORT_BUSY_0 |
DDR4_PSTAT_RD_PORT_BUSY_0, false,
- if (ret) {
debug(" controller idle\n");
return ret;
- /* Backup user setting */
- backup = readl(umctl2_base + DDR4_DBG1_OFFSET);
- /* Disable input traffic to the controller */
- setbits_le32(umctl2_base + DDR4_DBG1_OFFSET,
DDR4_DBG1_DIS_HIF);
* Ensure CAM/data pipelines are empty.
* Poll until CAM/data pipelines are set at least twice,
* timeout at 200ms
- for (i = 0; i < 2; i++) {
DDR4_DBGCAM_OFFSET),
- DDR4_DBGCAM_WR_DATA_PIPELINE_EMPTY |
- DDR4_DBGCAM_RD_DATA_PIPELINE_EMPTY |
DDR4_DBGCAM_DBG_RD_Q_EMPTY,
true,
if (ret) {
debug("%s: loop(%u): Timeout while waiting for",
__func__, i + 1);
debug(" CAM/data pipelines are empty\n");
/* Restore user setting */
writel(backup, umctl2_base + DDR4_DBG1_OFFSET);
Can use goto, go route to same exit path that include restore user setting.
return ret;
- if (umctl2_type == DDRTYPE_DDR4) {
if (value) {
ret =
ensure_retry_procedure_complete(umctl2_base);
if (ret) {
__func__);
debug(" retry procedure complete\n");
DDR4_DBG1_OFFSET);
Same here.
return ret;
- /* Restore user setting */
- writel(backup, umctl2_base + DDR4_DBG1_OFFSET);
- debug("%s: Quasi-dynamic group 3 registers are enabled\n",
__func__);
+static enum ddr_type get_ddr_type(phys_addr_t ddr_type_location) +{
- u32 ddr_type_magic = readl(ddr_type_location);
- if (ddr_type_magic == SOC64_HANDOFF_DDR_UMCTL2_DDR4_TYPE)
return DDRTYPE_DDR4;
SOC64_HANDOFF_DDR_UMCTL2_LPDDR4_0_TYPE)
return DDRTYPE_LPDDR4_0;
SOC64_HANDOFF_DDR_UMCTL2_LPDDR4_1_TYPE)
return DDRTYPE_LPDDR4_1;
- return DDRTYPE_UNKNOWN;
+static void use_lpddr4_interleaving(bool set) +{
- if (set) {
printf("Starting LPDDR4 interleaving configuration ...\n");
- setbits_le32(FPGA2SDRAM_MGR_MAIN_SIDEBANDMGR_FLAGOUT
SET0,
BIT(5));
- } else {
printf("Starting LPDDR4 non-interleaving configuration ...\n");
- clrbits_le32(FPGA2SDRAM_MGR_MAIN_SIDEBANDMGR_FLAGOUTS
ET0,
BIT(5));
+static void use_ddr4(enum ddr_type type) +{
- if (type == DDRTYPE_DDR4) {
printf("Starting DDR4 configuration ...\n");
setbits_le32(socfpga_get_sysmgr_addr() +
SYSMGR_SOC64_DDR_MODE,
SYSMGR_SOC64_DDR_MODE_MSK);
- } else if (type == DDRTYPE_LPDDR4_0) {
printf("Starting LPDDR4 configuration ...\n");
clrbits_le32(socfpga_get_sysmgr_addr() +
use_lpddr4_interleaving(false);
+static int scrubber_ddr_config(phys_addr_t umctl2_base,
- u32 backup[9];
- int ret;
- /* Reset to default value, prevent scrubber stop due to lower power
- writel(0, umctl2_base + DDR4_PWRCTL_OFFSET);
- /* Backup user settings */
- backup[0] = readl(umctl2_base + DDR4_SBRCTL_OFFSET);
- backup[1] = readl(umctl2_base + DDR4_SBRWDATA0_OFFSET);
- backup[2] = readl(umctl2_base + DDR4_SBRSTART0_OFFSET);
backup[3] = readl(umctl2_base +
DDR4_SBRWDATA1_OFFSET);
backup[4] = readl(umctl2_base + DDR4_SBRSTART1_OFFSET);
- backup[5] = readl(umctl2_base + DDR4_SBRRANGE0_OFFSET);
- backup[6] = readl(umctl2_base + DDR4_SBRRANGE1_OFFSET);
- backup[7] = readl(umctl2_base + DDR4_ECCCFG0_OFFSET);
- backup[8] = readl(umctl2_base + DDR4_ECCCFG1_OFFSET);
- if (umctl2_type != DDRTYPE_DDR4) {
/* Lock ECC region, ensure this regions is not being accessed
setbits_le32(umctl2_base + DDR4_ECCCFG1_OFFSET,
LPDDR4_ECCCFG1_ECC_REGIONS_PARITY_LOCK);
- /* Disables scrubber */
- clrbits_le32(umctl2_base + DDR4_SBRCTL_OFFSET,
DDR4_SBRCTL_SCRUB_EN);
- /* Polling all scrub writes data have been sent */
DDR4_SBRSTAT_OFFSET),
DDR4_SBRSTAT_SCRUB_BUSY,
false, TIMEOUT_5000MS, false);
- if (ret) {
debug(" sending all scrub data\n");
return ret;
- /* LPDDR4 supports inline ECC only */
* Setting all regions for protected, this is required for
* srubber to init whole LPDDR4 expect ECC region
writel(((ONE_EIGHT <<
LPDDR4_ECCCFG0_ECC_REGION_MAP_GRANU_SHIFT) |
(ALL_PROTECTED <<
LPDDR4_ECCCFG0_ECC_REGION_MAP_SHIFT)),
- /* Scrub_burst = 1, scrub_mode = 1(performs writes) */
- writel(DDR_SBRCTL_SCRUB_BURST_1 |
DDR4_SBRCTL_SCRUB_WRITE,
- /* Zeroing whole DDR */
- writel(0, umctl2_base + DDR4_SBRWDATA0_OFFSET);
- writel(0, umctl2_base + DDR4_SBRSTART0_OFFSET);
writel(0, umctl2_base + DDR4_SBRWDATA1_OFFSET);
writel(0, umctl2_base + DDR4_SBRSTART1_OFFSET);
- writel(0, umctl2_base + DDR4_SBRRANGE0_OFFSET);
- writel(0, umctl2_base + DDR4_SBRRANGE1_OFFSET);
- /* Enables scrubber */
- setbits_le32(umctl2_base + DDR4_SBRCTL_OFFSET,
- /* Polling all scrub writes commands have been sent */
DDR4_SBRSTAT_SCRUB_DONE,
true, TIMEOUT_5000MS, false);
- if (ret) {
debug(" sending all scrub commands\n");
return ret;
- if (ret) {
printf("%s: Timeout while waiting for", __func__);
printf(" sending all scrub data\n");
return ret;
- /* Restore user settings */
- writel(backup[0], umctl2_base + DDR4_SBRCTL_OFFSET);
- writel(backup[1], umctl2_base + DDR4_SBRWDATA0_OFFSET);
- writel(backup[2], umctl2_base + DDR4_SBRSTART0_OFFSET);
writel(backup[3], umctl2_base +
writel(backup[4], umctl2_base + DDR4_SBRSTART1_OFFSET);
- writel(backup[5], umctl2_base + DDR4_SBRRANGE0_OFFSET);
- writel(backup[6], umctl2_base + DDR4_SBRRANGE1_OFFSET);
- writel(backup[7], umctl2_base + DDR4_ECCCFG0_OFFSET);
- writel(backup[8], umctl2_base + DDR4_ECCCFG1_OFFSET);
- /* Enables ECC scrub on scrubber */
- if (!(readl(umctl2_base + DDR4_SBRCTL_OFFSET) &
DDR4_SBRCTL_SCRUB_WRITE)) {
+static int init_umctl2(phys_addr_t umctl2_handoff_base,
phys_addr_t umctl2_base, enum ddr_type umctl2_type,
size_t umctl2_handoff_length,
u32 *user_backup)
- u32 handoff_table[umctl2_handoff_length];
- u32 i;
- int ret;
printf("Initializing DDR4 controller ...\n");
- else if (umctl2_type == DDRTYPE_LPDDR4_0)
printf("Initializing LPDDR4_0 controller ...\n");
- else if (umctl2_type == DDRTYPE_LPDDR4_1)
printf("Initializing LPDDR4_1 controller ...\n");
- /* Prevent controller from issuing read/write to SDRAM */
DDR4_DBG1_DISDQ);
- /* Put SDRAM into self-refresh */
- setbits_le32(umctl2_base + DDR4_PWRCTL_OFFSET,
DDR4_PWRCTL_SELFREF_EN);
- /* Enable quasi-dynamic programing of the controller registers */
- clrbits_le32(umctl2_base + DDR4_SWCTL_OFFSET,
- /* Ensure the controller is in initialization mode */
DDR4_STAT_OFFSET),
DDR4_STAT_OPERATING_MODE, false,
TIMEOUT_200MS,
false);
- if (ret) {
debug(" init operating mode\n");
return ret;
- debug("%s: UMCTL2 handoff base address = 0x%p table length =
0x%08x\n",
__func__, (u32 *)umctl2_handoff_base,
(u32)umctl2_handoff_length);
- socfpga_handoff_read((void *)umctl2_handoff_base, handoff_table,
umctl2_handoff_length, LITTLE_ENDIAN);
- for (i = 0; i < umctl2_handoff_length; i = i + 2) {
debug("%s: Absolute addr: 0x%08llx APB offset: 0x%08x",
__func__, handoff_table[i] + umctl2_base,
handoff_table[i]);
debug(" wr = 0x%08x ", handoff_table[i + 1]);
writel(handoff_table[i + 1], (uintptr_t)(handoff_table[i] +
umctl2_base));
debug("rd = 0x%08x\n", readl((uintptr_t)(handoff_table[i] +
umctl2_base)));
- /* Backup user settings, restore after DDR up running */
- *user_backup = readl(umctl2_base + DDR4_PWRCTL_OFFSET);
- /* Disable self resfresh */
- clrbits_le32(umctl2_base + DDR4_PWRCTL_OFFSET,
- if (umctl2_type == DDRTYPE_LPDDR4_0 ||
/* Setting selfref_sw to 1, based on lpddr4 requirement */
user_backup++;
*user_backup = readl(umctl2_base + DDR4_INIT0_OFFSET) &
DDR4_INIT0_SKIP_RAM_INIT;
* Setting INIT0.skip_dram_init to 0x3, based on lpddr4
* requirement
setbits_le32(umctl2_base + DDR4_INIT0_OFFSET,
DDR4_INIT0_SKIP_RAM_INIT);
- /* Complete quasi-dynamic register programming */
- setbits_le32(umctl2_base + DDR4_SWCTL_OFFSET,
- /* Enable controller from issuing read/write to SDRAM */
- clrbits_le32(umctl2_base + DDR4_DBG1_OFFSET,
DDR4_DBG1_DISDQ);
+static int phy_pre_handoff_config(phys_addr_t umctl2_base,
- int ret;
- u32 value;
/* Check DDR4 retry is enabled ? */
value = readl(umctl2_base + DDR4_CRCPARCTL1_OFFSET) &
DDR4_CRCPARCTL1_CRC_PARITY_RETRY_ENABLE;
if (value) {
debug("%s: DDR4 retry is enabled\n", __func__);
debug("%s: Disable auto refresh is not supported\n",
__func__);
} else {
/* Disable auto refresh */
setbits_le32(umctl2_base + DDR4_RFSHCTL3_OFFSET,
- /* Disable selfref_en & powerdown_en, nvr disable dfi dram clk */
DDR4_PWRCTL_EN_DFI_DRAM_CLK_DISABLE |
DDR4_PWRCTL_POWERDOWN_EN |
- ret = enable_quasi_dynamic_reg_grp3(umctl2_base, umctl2_type);
- if (ret)
return ret;
- /* Masking dfi init complete */
- clrbits_le32(umctl2_base + DDR4_DFIMISC_OFFSET,
- /* Polling programming done */
- if (ret) {
- return ret;
+static int init_phy(struct ddr_handoff *ddr_handoff_info) +{
- u32 handoff_table[ddr_handoff_info->phy_handoff_length];
- u32 i, value;
- int ret;
- printf("Initializing DDR PHY ...\n");
- if (ddr_handoff_info->cntlr_t == DDRTYPE_DDR4 ||
ret = phy_pre_handoff_config(ddr_handoff_info-
cntlr_base,
if (ret)
return ret;
- if (ddr_handoff_info->cntlr2_t == DDRTYPE_LPDDR4_1) {
If it is DDRTYPE_DDR4 Or DDRTYPE_LPDDR4_0, it shouldn't DDRTYPE_LPDDR4_1 anymore? If yes, then can use "if...else".
if (ret)
return ret;
- /* Execute PHY configuration handoff */
- socfpga_handoff_read((void *)ddr_handoff_info-
phy_handoff_base,
handoff_table,
(u32)ddr_handoff_info->phy_handoff_length,
LITTLE_ENDIAN);
- for (i = 0; i < ddr_handoff_info->phy_handoff_length; i = i + 2) {
* Convert PHY odd offset to even offset that supported by
* ARM processor.
value = handoff_table[i] << 1;
debug("%s: Absolute addr: 0x%08llx, APB offset: 0x%08x ",
__func__, value + ddr_handoff_info->phy_base, value);
debug("PHY offset: 0x%08x", handoff_table[i]);
writew(handoff_table[i + 1], (uintptr_t)(value +
ddr_handoff_info->phy_base));
debug("rd = 0x%08x\n", readw((uintptr_t)(value +
ddr_handoff_info->phy_base)));
- printf("DDR PHY configuration is completed\n");
+static void phy_init_engine(struct ddr_handoff *handoff) +{
- u32 i, value;
- u32 handoff_table[handoff->phy_engine_handoff_length];
- printf("Load PHY Init Engine ...\n");
- /* Execute PIE production code handoff */
- socfpga_handoff_read((void *)handoff->phy_engine_handoff_base,
handoff_table,
(u32)handoff->phy_engine_handoff_length,
LITTLE_ENDIAN);
- for (i = 0; i < handoff->phy_engine_handoff_length; i = i + 2) {
debug("Handoff addr: 0x%8llx ", handoff_table[i] +
handoff->phy_base);
* ARM processor.
__func__, value + handoff->phy_base, value);
handoff->phy_base));
handoff->phy_base)));
- printf("End of loading PHY Init Engine\n");
+int populate_ddr_handoff(struct ddr_handoff *handoff) +{
- phys_addr_t next_section_header;
- /* DDR handoff */
- handoff->mem_reset_base =
SOC64_HANDOFF_DDR_MEMRESET_BASE;
- debug("%s: DDR memory reset base = 0x%x\n", __func__,
(u32)handoff->mem_reset_base);
- debug("%s: DDR memory reset address = 0x%x\n", __func__,
readl(handoff->mem_reset_base));
- /* Beginning of DDR controller handoff */
- handoff->cntlr_handoff_base =
SOC64_HANDOFF_DDR_UMCTL2_SECTION;
- debug("%s: cntlr handoff base = 0x%x\n", __func__,
(u32)handoff->cntlr_handoff_base);
- /* Get 1st DDR type */
- handoff->cntlr_t = get_ddr_type(handoff->cntlr_handoff_base +
- SOC64_HANDOFF_DDR_UMCTL2_TYPE_OFFSET);
- if (handoff->cntlr_t == DDRTYPE_LPDDR4_1 ||
handoff->cntlr_t == DDRTYPE_UNKNOWN) {
debug("%s: Wrong DDR handoff format, the 1st DDR ",
__func__);
debug("type must be DDR4 or LPDDR4_0\n");
return -ENOEXEC;
- /* 1st cntlr base physical address */
- handoff->cntlr_base = readl(handoff->cntlr_handoff_base +
SOC64_HANDOFF_DDR_UMCTL2_BASE_ADDR_OFFSET);
- debug("%s: cntlr base = 0x%x\n", __func__, (u32)handoff-
cntlr_base);
- /* Get the total length of DDR cntlr handoff section */
- handoff->cntlr_total_length = readl(handoff->cntlr_handoff_base +
SOC64_HANDOFF_OFFSET_LENGTH);
- debug("%s: Umctl2 total length in byte = 0x%x\n", __func__,
(u32)handoff->cntlr_total_length);
- /* Get the length of user setting data in DDR cntlr handoff section */
- handoff->cntlr_handoff_length = socfpga_get_handoff_size((void *)
handoff-
cntlr_handoff_base,
LITTLE_ENDIAN);
- debug("%s: Umctl2 handoff length in word(32-bit) = 0x%x\n",
__func__,
(u32)handoff->cntlr_handoff_length);
- /* Wrong format on user setting data */
- if (handoff->cntlr_handoff_length < 0) {
debug("%s: Wrong format on user setting data\n",
__func__);
return -ENOEXEC;
- /* Get the next handoff section address */
- next_section_header = handoff->cntlr_handoff_base +
handoff->cntlr_total_length;
- debug("%s: Next handoff section header location = 0x%llx\n",
__func__,
next_section_header);
* Checking next section handoff is cntlr or PHY, and changing
* subsequent implementation accordingly
- if (readl(next_section_header) ==
SOC64_HANDOFF_DDR_UMCTL2_MAGIC) {
/* Get the next cntlr handoff section address */
handoff->cntlr2_handoff_base = next_section_header;
debug("%s: umctl2 2nd handoff base = 0x%x\n", __func__,
(u32)handoff->cntlr2_handoff_base);
/* Get 2nd DDR type */
handoff->cntlr2_t = get_ddr_type(handoff-
cntlr2_handoff_base +
if (handoff->cntlr2_t == DDRTYPE_LPDDR4_0 ||
handoff->cntlr2_t == DDRTYPE_UNKNOWN) {
debug("%s: Wrong DDR handoff format, the 2nd DDR
__func__);
debug("type must be LPDDR4_1\n");
return -ENOEXEC;
/* 2nd umctl2 base physical address */
handoff->cntlr2_base =
readl(handoff->cntlr2_handoff_base +
debug("%s: cntlr2 base = 0x%x\n", __func__,
(u32)handoff->cntlr2_base);
/* Get the total length of 2nd DDR umctl2 handoff section */
handoff->cntlr2_total_length =
debug("%s: Umctl2_2nd total length in byte = 0x%x\n",
__func__,
(u32)handoff->cntlr2_total_length);
* Get the length of user setting data in DDR umctl2 handoff
* section
handoff->cntlr2_handoff_length =
handoff-
LITTLE_ENDIAN);
debug("%s: cntlr2 handoff length in word(32-bit) = 0x%x\n",
__func__,
(u32)handoff->cntlr2_handoff_length);
if (handoff->cntlr2_handoff_length < 0) {
debug("%s: Wrong format on umctl2 user setting
data\n",
__func__);
return -ENOEXEC;
next_section_header = handoff->cntlr2_handoff_base +
handoff->cntlr2_total_length;
__func__, next_section_header);
- /* Checking next section handoff is PHY ? */
SOC64_HANDOFF_DDR_PHY_MAGIC) {
/* DDR PHY handoff */
handoff->phy_handoff_base = next_section_header;
debug("%s: PHY handoff base = 0x%x\n", __func__,
(u32)handoff->phy_handoff_base);
/* PHY base physical address */
handoff->phy_base = readl(handoff->phy_handoff_base +
- SOC64_HANDOFF_DDR_PHY_BASE_OFFSET);
debug("%s: PHY base = 0x%x\n", __func__,
(u32)handoff->phy_base);
/* Get the total length of PHY handoff section */
handoff->phy_total_length = readl(handoff-
phy_handoff_base +
- SOC64_HANDOFF_OFFSET_LENGTH);
debug("%s: PHY total length in byte = 0x%x\n", __func__,
(u32)handoff->phy_total_length);
* Get the length of user setting data in DDR PHY handoff
* section
handoff->phy_handoff_length =
handoff->phy_handoff_base,
LITTLE_ENDIAN);
debug("%s: PHY handoff length in word(32-bit) = 0x%x\n",
__func__, (u32)handoff->phy_handoff_length);
/* Wrong format on PHY user setting data */
if (handoff->phy_handoff_length < 0) {
debug("%s: Wrong format on PHY user setting
data\n",
__func__);
return -ENOEXEC;
next_section_header = handoff->phy_handoff_base +
handoff->phy_total_length;
- } else {
debug("%s: Wrong format for DDR handoff, expect PHY",
__func__);
debug(" handoff section after umctl2 handoff section\n");
return -ENOEXEC;
- /* Checking next section handoff is PHY init Engine ? */
SOC64_HANDOFF_DDR_PHY_INIT_ENGINE_MAGIC) {
/* DDR PHY Engine handoff */
handoff->phy_engine_handoff_base =
debug("%s: PHY init engine handoff base = 0x%x\n",
__func__,
(u32)handoff->phy_engine_handoff_base);
/* Get the total length of PHY init engine handoff section */
handoff->phy_engine_total_length =
readl(handoff->phy_engine_handoff_base +
debug("%s: PHY engine total length in byte = 0x%x\n",
__func__,
(u32)handoff->phy_engine_total_length);
* Get the length of user setting data in DDR PHY init engine
* handoff section
handoff->phy_engine_handoff_length =
handoff-
LITTLE_ENDIAN);
debug("%s: PHY engine handoff length in word(32-bit) =
0x%x\n",
__func__, (u32)handoff->phy_engine_handoff_length);
/* Wrong format on PHY init engine setting data */
if (handoff->phy_engine_handoff_length < 0) {
debug("%s: Wrong format on PHY init engine ",
__func__);
debug("user setting data\n");
return -ENOEXEC;
- } else {
__func__);
debug(" init engine handoff section after PHY handoff\n");
debug(" section\n");
return -ENOEXEC;
- handoff->train_imem_base = handoff->phy_base +
- DDR_PHY_TRAIN_IMEM_OFFSET;
- debug("%s: PHY train IMEM base = 0x%x\n",
__func__, (u32)handoff->train_imem_base);
- handoff->train_dmem_base = handoff->phy_base +
- DDR_PHY_TRAIN_DMEM_OFFSET;
- debug("%s: PHY train DMEM base = 0x%x\n",
__func__, (u32)handoff->train_dmem_base);
- handoff->train_imem_length =
SOC64_HANDOFF_DDR_TRAIN_IMEM_LENGTH;
- debug("%s: PHY train IMEM length = 0x%x\n",
__func__, (u32)handoff->train_imem_length);
- handoff->train_dmem_length =
SOC64_HANDOFF_DDR_TRAIN_DMEM_LENGTH;
- debug("%s: PHY train DMEM length = 0x%x\n",
__func__, (u32)handoff->train_dmem_length);
+int enable_ddr_clock(struct udevice *dev) +{
- struct clk *ddr_clk;
- int ret;
- /* Enable clock before init DDR */
- ddr_clk = devm_clk_get(dev, "mem_clk");
- if (!IS_ERR(ddr_clk)) {
ret = clk_enable(ddr_clk);
if (ret) {
printf("%s: Failed to enable DDR clock\n", __func__);
return ret;
- } else {
ret = PTR_ERR(ddr_clk);
debug("%s: Failed to get DDR clock from dts\n", __func__);
return ret;
- printf("%s: DDR clock is enabled\n", __func__);
+static int ddr_start_dfi_init(phys_addr_t umctl2_base,
- int ret;
- debug("%s: Start DFI init\n", __func__);
- /* Enable quasi-dynamic programing of controller registers */
- if (ret)
return ret;
- /* Start DFI init sequence */
- setbits_le32(umctl2_base + DDR4_DFIMISC_OFFSET,
DDR4_DFIMISC_DFI_INIT_START);
DDR4_SWSTAT_SW_DONE_ACK, true,
- if (ret) {
- return ret;
+static int ddr_check_dfi_init_complete(phys_addr_t umctl2_base,
- int ret;
- /* Polling DFI init complete */
DDR4_DFISTAT_OFFSET),
DDR4_DFI_INIT_COMPLETE, true,
- if (ret) {
debug(" DFI init done\n");
return ret;
- debug("%s: DFI init completed.\n", __func__);
- if (ret)
return ret;
- /* Stop DFI init sequence */
- if (ret) {
return ret;
- debug("%s:DDR programming done\n", __func__);
- return ret;
+static int ddr_trigger_sdram_init(phys_addr_t umctl2_base,
- int ret;
- if (ret)
return ret;
- /* Unmasking dfi init complete */
DDR4_DFIMISC_DFI_INIT_COMPLETE_EN);
- /* Software exit from self-refresh */
DDR4_PWRCTL_SELFREF_SW);
- if (ret) {
return ret;
- return ret;
+static int ddr_post_handoff_config(phys_addr_t umctl2_base,
- int ret = 0;
- u32 value;
- /* Polling until SDRAM entered normal operating mode */
- value = readl(umctl2_base + DDR4_STAT_OFFSET) &
DDR4_STAT_OPERATING_MODE;
- while (value != NORMAL_OPM) {
if (get_timer(start) > TIMEOUT_200MS) {
__func__);
debug(" DDR enters normal operating mode\n");
return -ETIMEDOUT;
udelay(1);
WATCHDOG_RESET();
- printf("DDR entered normal operating mode\n");
- /* Enabling auto refresh */
- clrbits_le32(umctl2_base + DDR4_RFSHCTL3_OFFSET,
DDR4_RFSHCTL3_DIS_AUTO_REFRESH);
- /* Checking ECC is enabled? */
- value = readl(umctl2_base + DDR4_ECCCFG0_OFFSET) &
DDR4_ECC_MODE;
- if (value) {
printf("ECC is enabled\n");
ret = scrubber_ddr_config(umctl2_base, umctl2_type);
if (ret)
printf("Failed to enable ECC\n");
- return ret;
+static int configure_1d_training_firmware(struct ddr_handoff *ddr_handoff_info)
Can merge with configure_2d_training_firmware():
- int ret = 0;
- printf("Configuring 1D training firmware ...\n");
- /* Reset SDRAM */
- writew(DDR_PHY_PROTECT_MEMRESET,
(uintptr_t)(ddr_handoff_info->phy_base +
DDR_PHY_MEMRESETL_OFFSET));
- /* Enable access to the PHY configuration registers */
- clrbits_le16(ddr_handoff_info->phy_base +
- /* Copy 1D train IMEM bin */
- memcpy((void *)ddr_handoff_info->train_imem_base,
(const void *)SOC64_HANDOFF_DDR_TRAIN_IMEM_1D_SECTION,
ddr_handoff_info->train_imem_length);
- ret = memcmp((void *)ddr_handoff_info->train_imem_base,
(const void
- if (ret) {
debug("%s: Failed to copy 1D train IMEM binary\n",
__func__);
return ret;
- memcpy((void *)ddr_handoff_info->train_dmem_base,
(const void
*)SOC64_HANDOFF_DDR_TRAIN_DMEM_1D_SECTION,
- ret = memcmp((void *)ddr_handoff_info->train_dmem_base,
(const void
- if (ret)
debug("%s: Failed to copy 1D train DMEM binary\n",
__func__);
- /* Isolate the APB access from internal CSRs */
- setbits_le16(ddr_handoff_info->phy_base +
- return ret;
+static int configure_2d_training_firmware(struct ddr_handoff *ddr_handoff_info) +{
- int ret = 0;
- printf("Configuring 2D training firmware ...\n");
- /* Reset SDRAM */
- /* Copy 2D train IMEM bin */
(const void *)SOC64_HANDOFF_DDR_TRAIN_IMEM_2D_SECTION,
(const void
- if (ret) {
debug("%s: Failed to copy 2D train IMEM binary\n",
__func__);
return ret;
(const void
*)SOC64_HANDOFF_DDR_TRAIN_DMEM_2D_SECTION,
ddr_handoff_info->train_dmem_length);
(const void
- if (ret)
debug("%s: Failed to copy 2D train DMEM binary\n",
__func__);
- return ret;
+static void calibrating_sdram(struct ddr_handoff *ddr_handoff_info) +{
- /* Init mailbox protocol */
This same with previous? Also init mailbox?
DDR_PHY_UCTWRITEPROT_OFFSET,
DDR_PHY_UCTWRITEPROT);
- /* Reset and stalling ARC processor */
DDR_PHY_MICRORESET_RESET |
- /* Release ARC processor */
- /* Starting PHY firmware execution */
u32 *message_id)
- int ret;
- /* Polling major messages from PMU */
- ret = wait_for_bit_le16((const void *)(handoff->phy_base +
- DDR_PHY_UCTSHADOWREGS_UCTWRITEPROTESHADOW,
- if (ret) {
__func__);
return ret;
- *message_id = readw((uintptr_t)(handoff->phy_base +
- if (mode == STREAMING_MESSAGE)
SZ_16;
- /* Ack the receipt of the major message */
- clrbits_le16(handoff->phy_base +
- if (ret) {
__func__);
return ret;
- /* Complete protocol */
- setbits_le16(handoff->phy_base +
- return ret;
- int ret;
- *index = readw((uintptr_t)(handoff->phy_base +
- DDR_PHY_UCTDATWRITEONLYSHADOW_OFFSET))) <<
SZ_16;
- if (ret) {
__func__);
return ret;
- int i = 0, ret;
- u32 temp;
- temp = *streaming_index;
- while (i < GET_LOWHW_DATA(temp)) {
You want to read again temp = *streaming_index? Otherwise, temp is always constants.
streaming_index);
if (ret)
return ret;
i++;
- int ret;
- u32 message_id = 0;
- u32 streaming_index = 0;
- while ((message_id != FW_TRAINING_COMPLETED_STAT) &&
Should use do...while since message_id is default 0.
&message_id);
if (ret)
return ret;
STREAMING_MESSAGE,
&streaming_index);
if (ret)
return ret;
&streaming_index);
What is the usage of streaming_index after you got the value?
printf("\n");
- if (message_id == FW_TRAINING_COMPLETED_STAT) {
- } else if (message_id == FW_TRAINING_FAILED_STAT) {
hang();
bool enable)
- if (enable) {
- } else {
- u32 reg, value;
- reg = readl((uintptr_t)reg_addr);
- debug("max value divided by 2 is 0x%x\n", update_value);
- debug("umclt2 register 0x%x value is 0%x before ", reg_addr, reg);
- debug("update with train result\n");
- value = (reg & mask) >> shift;
- value += update_value + 3;
- /* reg value greater than 0xF, set one to diff_rank_wr_gap_msb */
- if (value > 0xF)
- else
- value = (value << shift) & mask;
- /* update register */
- writel((reg & (~mask)) | value, (uintptr_t)reg_addr);
u32 shift)
- u32 reg, value;
- value = ((value + update_value + 3) << shift) & mask;
- u32 b_addr;
- u16 val;
- u8 byte;
- /* Getting max value from DBYTEx TxDqsDlyTg0_ux_p0 */
- for (byte = 0; byte < numdbyte; byte++) {
reg + b_addr)) &
- return upd_val;
- int ret;
- u8 numdbyte = 0x8;
- u16 upd_val, val;
- u32 dramtmg2_reg_addr, rankctl_reg_addr, reg_addr;
- if (ret)
return ret;
- clrbits_le16(handoff->phy_base + DDR_PHY_APBONLY0_OFFSET,
phy_base +
phy_base +
- DMEM_MB_CDD_WW_0_1_OFFSET)));
- } else if (umctl2_type == DDRTYPE_LPDDR4_0) {
phy_base +
phy_base +
- } else if (umctl2_type == DDRTYPE_LPDDR4_1) {
phy_base +
phy_base +
- DMEM_MB_CDD_CHB_WW_0_1_OFFSET)));
- upd_val = max(val, upd_val);
- debug("max value is 0x%x\n", upd_val);
- /* Divided by two is required when running in freq ratio 1:2 */
- if (!(readl(umctl2_base + DDR4_MSTR_OFFSET) &
DDR4_FREQ_RATIO))
- debug("Update train value to umctl2 RANKCTL.diff_rank_wr_gap\n");
- rankctl_reg_addr = umctl2_base + DDR4_RANKCTL_OFFSET;
- /* Update train value to umctl2 RANKCTL.diff_rank_wr_gap */
- set_cal_res_to_rankctrl(rankctl_reg_addr, upd_val,
- DDR4_RANKCTL_DIFF_RANK_WR_GAP_SHIFT);
- debug("Update train value to umctl2 DRAMTMG2.W2RD\n");
- dramtmg2_reg_addr = umctl2_base + DDR4_DRAMTMG2_OFFSET;
- /* Update train value to umctl2 dramtmg2.wr2rd */
- set_cal_res_to_reg(dramtmg2_reg_addr, upd_val,
phy_base +
phy_base +
phy_base +
phy_base +
phy_base +
phy_base +
- DMEM_MB_CDD_CHB_RR_0_1_OFFSET)));
DDR4_FREQ_RATIO))
- debug("Update train value to umctl2 RANKCTL.diff_rank_rd_gap\n");
- /* Update train value to umctl2 RANKCTL.diff_rank_rd_gap */
- DDR4_RANKCTL_DIFF_RANK_RD_GAP_SHIFT);
phy_base +
phy_base +
- DMEM_MB_CDD_RW_1_0_OFFSET)));
phy_base +
phy_base +
phy_base +
phy_base +
phy_base +
phy_base +
phy_base +
phy_base +
- DMEM_MB_CDD_CHB_RW_1_0_OFFSET)));
phy_base +
phy_base +
DDR4_FREQ_RATIO))
- debug("Update train value to umctl2 dramtmg2.rd2wr\n");
- /* Update train value to umctl2 dramtmg2.rd2wr */
- /* Checking ECC is enabled?, lpddr4 using inline ECC */
- val = readl(umctl2_base + DDR4_ECCCFG0_OFFSET) &
DDR4_ECC_MODE;
- if (val && umctl2_type == DDRTYPE_DDR4)
numdbyte = 0x9;
- upd_val = 0;
- /* Getting max value from DBYTEx TxDqsDlyTg0_u0_p0 */
- upd_val = get_max_txdqsdlytg0_ux_p0(handoff,
numdbyte, upd_val);
- /* Getting max value from DBYTEx TxDqsDlyTg0_u1_p0 */
numdbyte, upd_val);
- debug("TxDqsDlyTg0 max value is 0x%x\n", upd_val);
DDR4_FREQ_RATIO))
- reg_addr = umctl2_base + DDR4_DFITMG1_OFFSET;
- /* Update train value to umctl2 dfitmg1.dfi_wrdata_delay */
- set_cal_res_to_reg(reg_addr, upd_val,
- if (ret) {
- setbits_le16(handoff->phy_base + DDR_PHY_APBONLY0_OFFSET,
- return ret;
- int ret;
- /* Implement 1D training firmware */
- ret = configure_1d_training_firmware(ddr_handoff_info);
- if (ret) {
__func__);
return ret;
- calibrating_sdram(ddr_handoff_info);
- ret = poll_for_training_complete(ddr_handoff_info);
- if (ret) {
__func__);
return ret;
- /* Updating training result to DDR controller */
- if (ddr_handoff_info->cntlr_t == DDRTYPE_DDR4) {
if (ret) {
__func__);
return ret;
- /* Implement 2D training firmware */
- ret = configure_2d_training_firmware(ddr_handoff_info);
- if (ret) {
if (ret) {
__func__);
return ret;
- if (ret)
__func__);
- return ret;
- int ret = 0;
user_backup);
if (ret) {
__func__);
return ret;
user_backup_2nd);
if (ret)
__func__);
- return ret;
- int ret;
- ret = ddr_start_dfi_init(ddr_handoff_info->cntlr_base,
- if (ret)
return ret;
- return ret;
- int ret;
- ret = ddr_check_dfi_init_complete(handoff->cntlr_base,
handoff->cntlr_t);
- if (ret)
return ret;
- if (handoff->cntlr2_t == DDRTYPE_LPDDR4_1)
handoff->cntlr2_t);
- return ret;
- int ret;
- ret = ddr_trigger_sdram_init(handoff->cntlr_base,
handoff->cntlr_t);
- if (ret)
return ret;
handoff->cntlr2_t);
- return ret;
- int ret;
- ret = ddr_post_handoff_config(handoff->cntlr_base,
handoff->cntlr_t);
- if (ret)
return ret;
handoff->cntlr2_t);
- return ret;
- u32 user_backup[2], user_backup_2nd[2];
- int ret;
- struct bd_info bd;
- struct ddr_handoff ddr_handoff_info;
- struct altera_sdram_priv *priv = dev_get_priv(dev);
- printf("Checking SDRAM configuration in progress ...\n");
- ret = populate_ddr_handoff(&ddr_handoff_info);
if (ret) {
__func__);
return ret;
- /* Set the MPFE NoC mux to correct DDR controller type */
- use_ddr4(ddr_handoff_info.cntlr_t);
- if (!is_ddr_init_skipped()) {
subsystem
* controller
- MEM_RST_MGR_STATUS_RESET_COMPLETE,
if (ret) {
return ret;
if (ret)
return ret;
user_backup_2nd);
if (ret) {
__func__);
return ret;
if (ret) {
return ret;
if (ret) {
return ret;
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
DDR4_INIT0_OFFSET,
DDR4_PCTRL0_OFFSET,
DDR4_PCTRL0_OFFSET,
- /* Get bank configuration from devicetree */
- ret = fdtdec_decode_ram_size(gd->fdt_blob, NULL, 0, NULL,
- if (ret) {
return -1;
- printf("DDR: %lld MiB\n", gd->ram_size >> 20);
- priv->info.base = bd.bi_dram[0].start;
- priv->info.size = gd->ram_size;
- sdram_size_check(&bd);
- /* This enables nonsecure access to DDR */
- /* mpuregion0addr_limit */
- FW_MPU_DDR_SCR_WRITEL(gd->ram_size - 1,
- FW_MPU_DDR_SCR_WRITEL(0x1F,
gd->ram_size - 1 is wrong because we use alias address for second bank.
- /* nonmpuregion0addr_limit */
- /* Enable mpuregion0enable and nonmpuregion0enable */
- FW_MPU_DDR_SCR_WRITEL(MPUREGION0_ENABLE |
- Copyright (C) 2016-2019 Intel Corporation <www.intel.com>
- Copyright (C) 2016-2021 Intel Corporation <www.intel.com>
- /* These regs info are part of DDR handoff in bitstream */
- addr = dev_read_addr_index(dev, 0); if (addr == FDT_ADDR_T_NONE) return -EINVAL;
- { .compatible = "intel,sdr-ctl-dm" },
Should change dm to n5x.
-- 2.13.0
-----Original Message----- From: Tan, Ley Foon ley.foon.tan@intel.com Sent: Wednesday, 14 April, 2021 6:30 PM To: Lim, Elly Siew Chin elly.siew.chin.lim@intel.com; u-boot@lists.denx.de Cc: Marek Vasut marex@denx.de; See, Chin Liang chin.liang.see@intel.com; Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Chee, Tien Fong tien.fong.chee@intel.com; Westergreen, Dalon dalon.westergreen@intel.com; Simon Glass sjg@chromium.org; Gan, Yau Wai yau.wai.gan@intel.com Subject: RE: [v1 12/17] ddr: altera: Add SDRAM driver for Intel N5X device
Sorting this.
BIT(13) |
BIT(12))
Okay.
BIT(4))
BIT(8))
BIT(0))
BIT(2) |
BIT(1) | \
BIT(0))
BIT(10) |
BIT(9) | BIT(8))
BIT(2) |
BIT(1) | \
BIT(0))
BIT(17) | BIT(16))
Okay, I will fix typo.
- ONE_EIGHT,
- ONE_SIXTEENTH,
- ONE_SIXTY_FOURTH
+enum ddr_type {
- DDRTYPE_LPDDR4_0,
- DDRTYPE_LPDDR4_1,
- DDRTYPE_DDR4,
- DDRTYPE_UNKNOWN
- MAJOR_MESSAGE,
- STREAMING_MESSAGE
- int ret;
false, TIMEOUT_200MS, false);
- if (ret) {
return ret;
- u32 value;
- int ret;
- if (value) {
__func__);
if (ret) {
return ret;
return ret;
Okay
- } else {
__func__);
if (ret) {
return ret;
return ret;
Same here.
Okay
Okay
- u32 value;
- int ret;
- while (value) {
__func__);
return -ETIMEDOUT;
if (value) {
__func__);
if (value) {
ret =
__func__);
debug("is set\n");
if (ret)
return ret;
if (value) {
__func__);
hang();
udelay(1);
WATCHDOG_RESET();
enum ddr_type umctl2_type)
- int ret;
DDR4_PSTAT_OFFSET),
- if (ret) {
return ret;
DDR4_DBG1_DIS_HIF);
* timeout at 200ms
true,
if (ret) {
__func__, i + 1);
Okay
return ret;
if (value) {
ret =
if (ret) {
__func__);
DDR4_DBG1_OFFSET);
Same here.
Okay
return ret;
__func__);
- if (set) {
SET0,
BIT(5));
- } else {
ET0,
BIT(5));
- u32 backup[9];
- int ret;
- if (ret) {
return ret;
(ALL_PROTECTED <<
- if (ret) {
return ret;
- if (ret) {
return ret;
u32 *user_backup)
- u32 i;
- int ret;
DDR4_DBG1_DISDQ);
DDR4_STAT_OFFSET),
TIMEOUT_200MS,
false);
- if (ret) {
return ret;
0x%08x\n",
handoff_table[i]);
umctl2_base));
umctl2_base)));
user_backup++;
* requirement
DDR4_DBG1_DISDQ);
- int ret;
- u32 value;
if (value) {
__func__);
} else {
- if (ret)
return ret;
- if (ret) {
- return ret;
- u32 i, value;
- int ret;
cntlr_base,
if (ret)
return ret;
Both LPDDR4_0 and LPDDR4_1 can coexist together. So you only see the if else for DDR4 and LPDDR4_0.
if (ret)
return ret;
phy_handoff_base,
handoff_table,
LITTLE_ENDIAN);
* ARM processor.
- u32 i, value;
handoff_table,
LITTLE_ENDIAN);
handoff->phy_base);
* ARM processor.
- /* DDR handoff */
__func__);
return -ENOEXEC;
cntlr_base);
handoff-
cntlr_handoff_base,
LITTLE_ENDIAN);
__func__,
__func__);
return -ENOEXEC;
__func__,
__func__);
return -ENOEXEC;
__func__,
* section
handoff-
LITTLE_ENDIAN);
__func__,
data\n",
__func__);
return -ENOEXEC;
phy_handoff_base +
* section
LITTLE_ENDIAN);
data\n",
__func__);
return -ENOEXEC;
- } else {
__func__);
return -ENOEXEC;
__func__,
__func__,
* handoff section
handoff-
LITTLE_ENDIAN);
0x%x\n",
__func__);
return -ENOEXEC;
- } else {
__func__);
return -ENOEXEC;
- int ret;
if (ret) {
return ret;
- } else {
return ret;
- int ret;
- if (ret)
return ret;
- if (ret) {
- return ret;
- int ret;
- if (ret) {
return ret;
- if (ret)
return ret;
- if (ret) {
return ret;
- return ret;
- int ret;
- if (ret)
return ret;
- if (ret) {
return ret;
- return ret;
- int ret = 0;
- u32 value;
__func__);
return -ETIMEDOUT;
udelay(1);
WATCHDOG_RESET();
DDR4_ECC_MODE;
- if (value) {
if (ret)
- return ret;
Okay
- int ret = 0;
- /* Reset SDRAM */
(const void
- if (ret) {
__func__);
return ret;
(const void
(const void
- if (ret)
__func__);
- return ret;
- int ret = 0;
- /* Reset SDRAM */
(const void
- if (ret) {
__func__);
return ret;
(const void
(const void
- if (ret)
__func__);
- return ret;
DDR_PHY_DCTWRITEPROT_OFFSET,
DDR_PHY_DCTWRITEPROT);
Yes, I will remove this redundancy
DDR_PHY_MICRORESET_STALL);
+static int get_mail(struct ddr_handoff *handoff, enum message_mode mode,
u32 *message_id)
- int ret;
DDR_PHY_UCTSHADOWREGS_OFFSET),
- if (ret) {
__func__);
debug(" major messages from PMU\n");
return ret;
DDR_PHY_UCTWRITEONLYSHADOW_OFFSET));
*message_id |= readw((uintptr_t)((handoff->phy_base +
SZ_16;
- if (ret) {
__func__);
debug(" ack the receipt of the major message completed\n");
return ret;
- return ret;
+static int get_mail_streaming(struct ddr_handoff *handoff,
enum message_mode mode, u32 *index)
- int ret;
*index |= readw((uintptr_t)((handoff->phy_base +
SZ_16;
- if (ret) {
__func__);
return ret;
+static int decode_streaming_message(struct ddr_handoff *ddr_handoff_info,
u32 *streaming_index)
- int i = 0, ret;
- u32 temp;
Yes, const value is expected, GET_LOWHW_DATA Is used to read the half word from temp to know how long the log message is.
ret = get_mail(ddr_handoff_info, STREAMING_MESSAGE,
streaming_index);
if (ret)
return ret;
printf("args[%d]: 0x%x ", i, *streaming_index);
i++;
+static int poll_for_training_complete(struct ddr_handoff *ddr_handoff_info) +{
- int ret;
(message_id != FW_TRAINING_FAILED_STAT)) {
Okay
ret = get_mail(ddr_handoff_info, MAJOR_MESSAGE,
&message_id);
if (ret)
return ret;
printf("Major message id = 0%x\n", message_id);
if (message_id == FW_STREAMING_MSG_ID) {
ret = get_mail_streaming(ddr_handoff_info,
STREAMING_MESSAGE,
&streaming_index);
if (ret)
return ret;
printf("streaming index 0%x : ", streaming_index);
decode_streaming_message(ddr_handoff_info,
&streaming_index);
That value telling us how many 16 bits data the log message is consisted. Then only 16 bits log data can be retrieved at one time through mailbox, so we need to repeat this retrieving until full log data is received.
printf("\n");
printf("DDR firmware training completed\n");
printf("DDR firmware training failed\n");
hang();
+static void enable_phy_clk_for_csr_access(struct ddr_handoff *handoff,
bool enable)
- if (enable) {
/* Enable PHY clk */
setbits_le16((uintptr_t)(handoff->phy_base +
DDR_PHY_UCCLKHCLKENABLES_OFFSET),
DDR_PHY_UCCLKHCLKENABLES_UCCLKEN |
DDR_PHY_UCCLKHCLKENABLES_HCLKEN);
- } else {
/* Disable PHY clk */
clrbits_le16((uintptr_t)(handoff->phy_base +
+/* helper function for updating train result to umctl2 RANKCTL register */ +static void set_cal_res_to_rankctrl(u32 reg_addr, u16 update_value,
u32 mask, u32 msb_mask, u32 shift)
- u32 reg, value;
- if (value > 0xF)
setbits_le32((u32 *)(uintptr_t)reg_addr, msb_mask);
- else
clrbits_le32((u32 *)(uintptr_t)reg_addr, msb_mask);
+/* helper function for updating train result to register */ +static void set_cal_res_to_reg(u32 reg_addr, u16 update_value, u32 mask,
u32 shift)
- u32 reg, value;
+static u16 get_max_txdqsdlytg0_ux_p0(struct ddr_handoff *handoff, u32 reg,
u8 numdbyte, u16 upd_val)
- u32 b_addr;
- u16 val;
- u8 byte;
b_addr = byte << 13;
/* TxDqsDlyTg0[9:6] is the coarse delay */
val = (readw((uintptr_t)(handoff->phy_base +
reg + b_addr)) &
DDR_PHY_TXDQDLYTG0_COARSE_DELAY) >>
DDR_PHY_TXDQDLYTG0_COARSE_DELAY_SHIFT;
- return upd_val;
+static int set_cal_res_to_umctl2(struct ddr_handoff *handoff,
- int ret;
- u16 upd_val, val;
DDR4_SWCTL_SW_DONE);
- if (ret)
return ret;
DDR_PHY_MICROCONTMUXSEL);
val = GET_HIGHB_DATA(readw((uintptr_t)(handoff-
phy_base +
DMEM_MB_CDD_WW_1_0_OFFSET)));
upd_val = GET_LOWB_DATA(readw((uintptr_t)(handoff-
phy_base +
phy_base +
DMEM_MB_CDD_CHA_WW_1_0_OFFSET)));
upd_val = GET_HIGHB_DATA(readw((uintptr_t)(handoff-
phy_base +
DMEM_MB_CDD_CHA_WW_0_1_OFFSET)));
phy_base +
DMEM_MB_CDD_CHB_WW_1_0_OFFSET)));
phy_base +
DDR4_FREQ_RATIO))
upd_val = DIV_ROUND_CLOSEST(upd_val, 2);
DDR4_RANKCTL_DIFF_RANK_WR_GAP,
DDR4_RANKCTL_DIFF_RANK_WR_GAP_MSB,
DDR4_DRAMTMG2_WR2RD, 0);
DRAMTMG9.W2RD_S\n");
reg_addr = umctl2_base + DDR4_DRAMTMG9_OFFSET;
/* Update train value to umctl2 dramtmg9.wr2rd_s */
DDR4_DRAMTMG9_W2RD_S, 0);
phy_base +
DMEM_MB_CDD_RR_1_0_OFFSET)));
phy_base +
DMEM_MB_CDD_RR_0_1_OFFSET)));
phy_base +
DMEM_MB_CDD_CHA_RR_1_0_OFFSET)));
phy_base +
DMEM_MB_CDD_CHA_RR_0_1_OFFSET)));
phy_base +
DMEM_MB_CDD_CHB_RR_1_0_OFFSET)));
phy_base +
DDR4_FREQ_RATIO))
DDR4_RANKCTL_DIFF_RANK_RD_GAP,
DDR4_RANKCTL_DIFF_RANK_RD_GAP_MSB,
phy_base +
DMEM_MB_CDD_RW_1_1_OFFSET)));
phy_base +
phy_base +
DMEM_MB_CDD_RW_0_1_OFFSET)));
phy_base +
DMEM_MB_CDD_RW_0_0_OFFSET)));
phy_base +
DMEM_MB_CDD_CHA_RW_1_1_OFFSET)));
phy_base +
DMEM_MB_CDD_CHA_RW_1_0_OFFSET)));
phy_base +
DMEM_MB_CDD_CHA_RW_0_1_OFFSET)));
phy_base +
DMEM_MB_CDD_CHA_RW_0_0_OFFSET)));
phy_base +
DMEM_MB_CDD_CHB_RW_1_1_OFFSET)));
phy_base +
phy_base +
DMEM_MB_CDD_CHB_RW_0_1_OFFSET)));
phy_base +
DMEM_MB_CDD_CHB_RW_0_0_OFFSET)));
DDR4_FREQ_RATIO))
DDR4_DRAMTMG2_RD2WR,
DDR4_DRAMTMG2_RD2WR_SHIFT);
DDR4_ECC_MODE;
numdbyte = 0x9;
- upd_val = 0;
DDR_PHY_DBYTE0_TXDQDLYTG0_U0_P0,
numdbyte, upd_val);
DDR_PHY_DBYTE0_TXDQDLYTG0_U1_P0,
numdbyte, upd_val);
DDR4_FREQ_RATIO))
DDR4_DFITMG1_DFI_T_WRDATA_DELAY,
DDR4_DFITMG1_DFI_T_WRDATA_SHIFT);
DDR4_SWSTAT_OFFSET),
- if (ret) {
debug(" programming done\n");
- return ret;
+static int start_ddr_calibration(struct ddr_handoff *ddr_handoff_info) +{
- int ret;
- if (ret) {
debug("%s: Failed to configure 1D training firmware\n",
__func__);
return ret;
- if (ret) {
debug("%s: Failed to get FW training completed\n",
__func__);
return ret;
ret = set_cal_res_to_umctl2(ddr_handoff_info,
ddr_handoff_info->cntlr_t);
if (ret) {
debug("%s: Failed to update train result to ",
__func__);
debug("DDR controller\n");
return ret;
- if (ret) {
if (ret) {
__func__);
return ret;
- if (ret)
__func__);
- return ret;
+static int init_controller(struct ddr_handoff *ddr_handoff_info,
u32 *user_backup, u32 *user_backup_2nd)
- int ret = 0;
ddr_handoff_info->cntlr_t == DDRTYPE_LPDDR4_0) {
/* Initialize 1st DDR controller */
ret = init_umctl2(ddr_handoff_info->cntlr_handoff_base,
ddr_handoff_info->cntlr_t,
ddr_handoff_info->cntlr_handoff_length,
user_backup);
if (ret) {
debug("%s: Failed to inilialize first controller\n",
__func__);
return ret;
/* Initialize 2nd DDR controller */
ret = init_umctl2(ddr_handoff_info->cntlr2_handoff_base,
ddr_handoff_info->cntlr2_base,
ddr_handoff_info->cntlr2_t,
ddr_handoff_info->cntlr2_handoff_length,
user_backup_2nd);
if (ret)
debug("%s: Failed to inilialize 2nd controller\n",
__func__);
- return ret;
+static int dfi_init(struct ddr_handoff *ddr_handoff_info) +{
- int ret;
- if (ret)
return ret;
ret = ddr_start_dfi_init(ddr_handoff_info->cntlr2_base,
ddr_handoff_info->cntlr2_t);
- return ret;
+static int check_dfi_init(struct ddr_handoff *handoff) +{
- int ret;
handoff->cntlr_t);
- if (ret)
return ret;
ret = ddr_check_dfi_init_complete(handoff->cntlr2_base,
handoff->cntlr2_t);
- return ret;
+static int trigger_sdram_init(struct ddr_handoff *handoff) +{
- int ret;
handoff->cntlr_t);
- if (ret)
return ret;
ret = ddr_trigger_sdram_init(handoff->cntlr2_base,
handoff->cntlr2_t);
- return ret;
+static int ddr_post_config(struct ddr_handoff *handoff) +{
- int ret;
handoff->cntlr_t);
- if (ret)
return ret;
ret = ddr_post_handoff_config(handoff->cntlr2_base,
handoff->cntlr2_t);
- return ret;
+int sdram_mmr_init_full(struct udevice *dev) +{
- int ret;
if (ret) {
debug("%s: Failed to populate DDR handoff\n",
__func__);
return ret;
printf("SDRAM init in progress ...\n");
* Polling reset complete, must be high to ensure DDR
subsystem
* in complete reset state before init DDR clock and DDR
* controller
ret = wait_for_bit_le32((const void *)((uintptr_t)(readl
(ddr_handoff_info.mem_reset_base)
MEM_RST_MGR_STATUS)),
true, TIMEOUT_200MS, false);
if (ret) {
debug("%s: Timeout while waiting for", __func__);
debug(" reset complete done\n");
return ret;
ret = enable_ddr_clock(dev);
if (ret)
return ret;
ret = init_controller(&ddr_handoff_info, user_backup,
user_backup_2nd);
if (ret) {
debug("%s: Failed to inilialize DDR controller\n",
__func__);
return ret;
/* Release the controller from reset */
setbits_le32((uintptr_t)
(readl(ddr_handoff_info.mem_reset_base) +
MEM_RST_MGR_STATUS),
MEM_RST_MGR_STATUS_AXI_RST |
MEM_RST_MGR_STATUS_CONTROLLER_RST |
MEM_RST_MGR_STATUS_RESET_COMPLETE);
printf("DDR controller configuration is completed\n");
/* Initialize DDR PHY */
ret = init_phy(&ddr_handoff_info);
if (ret) {
debug("%s: Failed to inilialize DDR PHY\n", __func__);
return ret;
enable_phy_clk_for_csr_access(&ddr_handoff_info, true);
ret = start_ddr_calibration(&ddr_handoff_info);
if (ret) {
debug("%s: Failed to calibrate DDR\n", __func__);
return ret;
enable_phy_clk_for_csr_access(&ddr_handoff_info, false);
/* Reset ARC processor when no using for security purpose
setbits_le16(ddr_handoff_info.phy_base +
DDR_PHY_MICRORESET_OFFSET,
DDR_PHY_MICRORESET_RESET);
/* DDR freq set to support DDR4-3200 */
phy_init_engine(&ddr_handoff_info);
ret = dfi_init(&ddr_handoff_info);
if (ret)
return ret;
ret = check_dfi_init(&ddr_handoff_info);
if (ret)
return ret;
ret = trigger_sdram_init(&ddr_handoff_info);
if (ret)
return ret;
ret = ddr_post_config(&ddr_handoff_info);
if (ret)
return ret;
writel(user_backup[0], ddr_handoff_info.cntlr_base +
if (ddr_handoff_info.cntlr2_t == DDRTYPE_LPDDR4_0)
setbits_le32(ddr_handoff_info.cntlr_base +
DDR4_INIT0_OFFSET, user_backup[1]);
if (ddr_handoff_info.cntlr2_t == DDRTYPE_LPDDR4_1) {
writel(user_backup_2nd[0],
ddr_handoff_info.cntlr2_base +
setbits_le32(ddr_handoff_info.cntlr2_base +
DDR4_INIT0_OFFSET,
user_backup_2nd[1]);
/* Enable input traffic per port */
DDR4_PCTRL0_OFFSET,
DDR4_PCTRL0_PORT_EN);
DDR4_PCTRL0_OFFSET,
printf("DDR init success\n");
(phys_size_t *)&gd->ram_size, &bd);
- if (ret) {
debug("%s: Failed to decode memory node\n", __func__);
return -1;
FW_MPU_DDR_SCR_MPUREGION0ADDR_LIMIT);
FW_MPU_DDR_SCR_MPUREGION0ADDR_LIMITEXT);
Yes, I have no idea why these codes here, may be these unintentionally leaving here when resolving conflict from code rebase. I will remove it.
FW_MPU_DDR_SCR_NONMPUREGION0ADDR_LIMIT);
NONMPUREGION0_ENABLE,
FW_MPU_DDR_SCR_EN_SET);
+} diff --git a/drivers/ddr/altera/sdram_soc64.c b/drivers/ddr/altera/sdram_soc64.c index 171cde0e6b..002aa08673 100644 --- a/drivers/ddr/altera/sdram_soc64.c +++ b/drivers/ddr/altera/sdram_soc64.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0 /*
@@ -100,12 +100,14 @@ int emif_reset(struct altera_sdram_plat *plat) return 0; }
+#if !IS_ENABLED(CONFIG_TARGET_SOCFPGA_N5X) int poll_hmc_clock_status(void) { return wait_for_bit_le32((const void *)(socfpga_get_sysmgr_addr()
SYSMGR_SOC64_HMC_CLK), SYSMGR_HMC_CLK_STATUS_MSK, true,
1000, false); } +#endif
void sdram_clear_mem(phys_addr_t addr, phys_size_t size) { @@ -250,6 +252,11 @@ static int altera_sdram_of_to_plat(struct udevice *dev) struct altera_sdram_plat *plat = dev_get_plat(dev); fdt_addr_t addr;
Yes, need to change that
-- 2.13.0
Add SPL for N5X.
Signed-off-by: Siew Chin Lim elly.siew.chin.lim@intel.com --- arch/arm/mach-socfpga/{spl_agilex.c => spl_n5x.c} | 37 ++++++++++++++--------- 1 file changed, 22 insertions(+), 15 deletions(-) copy arch/arm/mach-socfpga/{spl_agilex.c => spl_n5x.c} (83%)
diff --git a/arch/arm/mach-socfpga/spl_agilex.c b/arch/arm/mach-socfpga/spl_n5x.c similarity index 83% copy from arch/arm/mach-socfpga/spl_agilex.c copy to arch/arm/mach-socfpga/spl_n5x.c index ee5a9dc1e2..d056871d29 100644 --- a/arch/arm/mach-socfpga/spl_agilex.c +++ b/arch/arm/mach-socfpga/spl_n5x.c @@ -1,27 +1,26 @@ // SPDX-License-Identifier: GPL-2.0 /* - * Copyright (C) 2019 Intel Corporation <www.intel.com> + * Copyright (C) 2020-2021 Intel Corporation <www.intel.com> * */
-#include <init.h> -#include <log.h> -#include <asm/global_data.h> -#include <asm/io.h> -#include <asm/u-boot.h> -#include <asm/utils.h> #include <common.h> -#include <hang.h> -#include <image.h> -#include <spl.h> #include <asm/arch/clock_manager.h> #include <asm/arch/firewall.h> #include <asm/arch/mailbox_s10.h> #include <asm/arch/misc.h> #include <asm/arch/reset_manager.h> #include <asm/arch/system_manager.h> -#include <watchdog.h> +#include <asm/global_data.h> +#include <asm/io.h> +#include <asm/u-boot.h> +#include <asm/utils.h> #include <dm/uclass.h> +#include <hang.h> +#include <image.h> +#include <init.h> +#include <spl.h> +#include <watchdog.h>
@@ -54,27 +53,35 @@ void board_init_f(ulong dummy)
sysmgr_pinmux_init();
+ preloader_console_init(); + ret = uclass_get_device(UCLASS_CLK, 0, &dev); if (ret) { - debug("Clock init failed: %d\n", ret); + printf("Clock init failed: %d\n", ret); + hang(); + } + + ret = uclass_get_device(UCLASS_CLK, 1, &dev); + if (ret) { + printf("Memory clock init failed: %d\n", ret); hang(); }
- preloader_console_init(); print_reset_info(); cm_print_clock_quick_summary();
firewall_setup(); + ret = uclass_get_device(UCLASS_CACHE, 0, &dev); if (ret) { - debug("CCU init failed: %d\n", ret); + printf("CCU init failed: %d\n", ret); hang(); }
#if CONFIG_IS_ENABLED(ALTERA_SDRAM) ret = uclass_get_device(UCLASS_RAM, 0, &dev); if (ret) { - debug("DRAM init failed: %d\n", ret); + printf("DRAM init failed: %d\n", ret); hang(); } #endif
-----Original Message----- From: Lim, Elly Siew Chin elly.siew.chin.lim@intel.com Sent: Wednesday, March 31, 2021 10:39 PM To: u-boot@lists.denx.de Cc: Marek Vasut marex@denx.de; Tan, Ley Foon ley.foon.tan@intel.com; See, Chin Liang chin.liang.see@intel.com; Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Chee, Tien Fong tien.fong.chee@intel.com; Westergreen, Dalon dalon.westergreen@intel.com; Simon Glass sjg@chromium.org; Gan, Yau Wai yau.wai.gan@intel.com; Lim, Elly Siew Chin elly.siew.chin.lim@intel.com Subject: [v1 13/17] arm: socfpga: Add SPL for Intel N5X device
Add SPL for N5X.
1 file changed, 22 insertions(+), 15 deletions(-) copy arch/arm/mach- socfpga/{spl_agilex.c => spl_n5x.c} (83%)
diff --git a/arch/arm/mach-socfpga/spl_agilex.c b/arch/arm/mach- socfpga/spl_n5x.c similarity index 83% copy from arch/arm/mach- socfpga/spl_agilex.c copy to arch/arm/mach-socfpga/spl_n5x.c index ee5a9dc1e2..d056871d29 100644 --- a/arch/arm/mach-socfpga/spl_agilex.c +++ b/arch/arm/mach-socfpga/spl_n5x.c @@ -1,27 +1,26 @@ // SPDX-License-Identifier: GPL-2.0 /*
- Copyright (C) 2019 Intel Corporation <www.intel.com>
- Copyright (C) 2020-2021 Intel Corporation <www.intel.com>
Sort this.
Regards Ley Foon
Add N5X SoC devkit board.
Signed-off-by: Siew Chin Lim elly.siew.chin.lim@intel.com --- board/intel/n5x-socdk/MAINTAINERS | 7 +++++++ board/{altera/stratix10-socdk => intel/n5x-socdk}/Makefile | 2 +- board/{altera/stratix10-socdk => intel/n5x-socdk}/socfpga.c | 2 +- 3 files changed, 9 insertions(+), 2 deletions(-) create mode 100644 board/intel/n5x-socdk/MAINTAINERS copy board/{altera/stratix10-socdk => intel/n5x-socdk}/Makefile (50%) copy board/{altera/stratix10-socdk => intel/n5x-socdk}/socfpga.c (52%)
diff --git a/board/intel/n5x-socdk/MAINTAINERS b/board/intel/n5x-socdk/MAINTAINERS new file mode 100644 index 0000000000..c1059f092c --- /dev/null +++ b/board/intel/n5x-socdk/MAINTAINERS @@ -0,0 +1,7 @@ +SOCFPGA BOARD +M: Chee Tien Fong tien.fong.chee@intel.com +M: Lim Siew Chin elly.siew.chin.lim@intel.com +S: Maintained +F: board/intel/n5x-socdk/ +F: include/configs/socfpga_n5x_socdk.h +F: configs/socfpga_n5x_atf_defconfig diff --git a/board/altera/stratix10-socdk/Makefile b/board/intel/n5x-socdk/Makefile similarity index 50% copy from board/altera/stratix10-socdk/Makefile copy to board/intel/n5x-socdk/Makefile index 02a9cadf76..accfdcddcb 100644 --- a/board/altera/stratix10-socdk/Makefile +++ b/board/intel/n5x-socdk/Makefile @@ -1,5 +1,5 @@ # -# Copyright (C) 2016-2017 Intel Corporation <www.intel.com> +# Copyright (C) 2020-2021 Intel Corporation <www.intel.com> # # SPDX-License-Identifier: GPL-2.0 # diff --git a/board/altera/stratix10-socdk/socfpga.c b/board/intel/n5x-socdk/socfpga.c similarity index 52% copy from board/altera/stratix10-socdk/socfpga.c copy to board/intel/n5x-socdk/socfpga.c index 043fc543f1..985ba190d0 100644 --- a/board/altera/stratix10-socdk/socfpga.c +++ b/board/intel/n5x-socdk/socfpga.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0 /* - * Copyright (C) 2016-2018 Intel Corporation <www.intel.com> + * Copyright (C) 2020-2021 Intel Corporation <www.intel.com> * */
-----Original Message----- From: Lim, Elly Siew Chin elly.siew.chin.lim@intel.com Sent: Wednesday, March 31, 2021 10:39 PM To: u-boot@lists.denx.de Cc: Marek Vasut marex@denx.de; Tan, Ley Foon ley.foon.tan@intel.com; See, Chin Liang chin.liang.see@intel.com; Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Chee, Tien Fong tien.fong.chee@intel.com; Westergreen, Dalon dalon.westergreen@intel.com; Simon Glass sjg@chromium.org; Gan, Yau Wai yau.wai.gan@intel.com; Lim, Elly Siew Chin elly.siew.chin.lim@intel.com Subject: [v1 14/17] board: intel: Add socdk board support for Intel N5X device
diff --git a/board/intel/n5x-socdk/MAINTAINERS b/board/intel/n5x- socdk/MAINTAINERS new file mode 100644 index 0000000000..c1059f092c --- /dev/null +++ b/board/intel/n5x-socdk/MAINTAINERS @@ -0,0 +1,7 @@ +SOCFPGA BOARD +M: Chee Tien Fong tien.fong.chee@intel.com +M: Lim Siew Chin elly.siew.chin.lim@intel.com +S: Maintained +F: board/intel/n5x-socdk/ +F: include/configs/socfpga_n5x_socdk.h +F: configs/socfpga_n5x_atf_defconfig diff --git a/board/altera/stratix10-socdk/Makefile b/board/intel/n5x- socdk/Makefile similarity index 50% copy from board/altera/stratix10- socdk/Makefile copy to board/intel/n5x-socdk/Makefile index 02a9cadf76..accfdcddcb 100644 --- a/board/altera/stratix10-socdk/Makefile +++ b/board/intel/n5x-socdk/Makefile @@ -1,5 +1,5 @@ # -# Copyright (C) 2016-2017 Intel Corporation <www.intel.com> +# Copyright (C) 2020-2021 Intel Corporation <www.intel.com> # # SPDX-License-Identifier: GPL-2.0 # diff --git a/board/altera/stratix10-socdk/socfpga.c b/board/intel/n5x- socdk/socfpga.c similarity index 52% copy from board/altera/stratix10- socdk/socfpga.c copy to board/intel/n5x-socdk/socfpga.c index 043fc543f1..985ba190d0 100644 --- a/board/altera/stratix10-socdk/socfpga.c +++ b/board/intel/n5x-socdk/socfpga.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0 /*
- Copyright (C) 2016-2018 Intel Corporation <www.intel.com>
Reviewed-by: Ley Foon Tan ley.foon.tan@intel.com
Add device tree for N5X.
Signed-off-by: Siew Chin Lim elly.siew.chin.lim@intel.com Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- arch/arm/dts/Makefile | 1 + ..._agilex-u-boot.dtsi => socfpga_n5x-u-boot.dtsi} | 13 ++-- .../dts/{socfpga_agilex.dtsi => socfpga_n5x.dtsi} | 90 +++++++++++++--------- arch/arm/dts/socfpga_n5x_socdk-u-boot.dtsi | 67 ++++++++++++++++ ...fpga_agilex_socdk.dts => socfpga_n5x_socdk.dts} | 10 ++- 5 files changed, 135 insertions(+), 46 deletions(-) copy arch/arm/dts/{socfpga_agilex-u-boot.dtsi => socfpga_n5x-u-boot.dtsi} (85%) copy arch/arm/dts/{socfpga_agilex.dtsi => socfpga_n5x.dtsi} (88%) create mode 100644 arch/arm/dts/socfpga_n5x_socdk-u-boot.dtsi copy arch/arm/dts/{socfpga_agilex_socdk.dts => socfpga_n5x_socdk.dts} (92%)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index c6710826a0..7443fde97d 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -380,6 +380,7 @@ dtb-$(CONFIG_ARCH_SOCFPGA) += \ socfpga_cyclone5_socrates.dtb \ socfpga_cyclone5_sr1500.dtb \ socfpga_cyclone5_vining_fpga.dtb \ + socfpga_n5x_socdk.dtb \ socfpga_stratix10_socdk.dtb
dtb-$(CONFIG_TARGET_DRA7XX_EVM) += dra72-evm.dtb dra7-evm.dtb \ diff --git a/arch/arm/dts/socfpga_agilex-u-boot.dtsi b/arch/arm/dts/socfpga_n5x-u-boot.dtsi similarity index 85% copy from arch/arm/dts/socfpga_agilex-u-boot.dtsi copy to arch/arm/dts/socfpga_n5x-u-boot.dtsi index 08f7cf7f7a..7ded8ceb9a 100644 --- a/arch/arm/dts/socfpga_agilex-u-boot.dtsi +++ b/arch/arm/dts/socfpga_n5x-u-boot.dtsi @@ -2,7 +2,7 @@ /* * U-Boot additions * - * Copyright (C) 2019-2020 Intel Corporation <www.intel.com> + * Copyright (C) 2020-2021 Intel Corporation <www.intel.com> */
#include "socfpga_soc64_fit-u-boot.dtsi" @@ -53,6 +53,10 @@ reset-names = "i2c"; };
+&memclkmgr { + u-boot,dm-pre-reloc; +}; + &mmc { resets = <&rst SDMMC_RESET>, <&rst SDMMC_OCP_RESET>; }; @@ -76,11 +80,10 @@ };
&sdr { - compatible = "intel,sdr-ctl-agilex"; - reg = <0xf8000400 0x80>, - <0xf8010000 0x190>, - <0xf8011000 0x500>; + compatible = "intel,sdr-ctl-dm"; resets = <&rst DDRSCH_RESET>; + clocks = <&memclkmgr>; + clock-names = "mem_clk"; u-boot,dm-pre-reloc; };
diff --git a/arch/arm/dts/socfpga_agilex.dtsi b/arch/arm/dts/socfpga_n5x.dtsi similarity index 88% copy from arch/arm/dts/socfpga_agilex.dtsi copy to arch/arm/dts/socfpga_n5x.dtsi index c3ead2d72b..984524c79a 100644 --- a/arch/arm/dts/socfpga_agilex.dtsi +++ b/arch/arm/dts/socfpga_n5x.dtsi @@ -1,15 +1,15 @@ // SPDX-License-Identifier: GPL-2.0 /* - * Copyright (C) 2019, Intel Corporation + * Copyright (C) 2020-2021, Intel Corporation */
/dts-v1/; #include <dt-bindings/reset/altr,rst-mgr-s10.h> #include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/clock/agilex-clock.h> +#include <dt-bindings/clock/n5x-clock.h>
/ { - compatible = "intel,socfpga-agilex"; + compatible = "intel,socfpga-n5x"; #address-cells = <2>; #size-cells = <2>;
@@ -103,7 +103,7 @@ };
clkmgr: clock-controller@ffd10000 { - compatible = "intel,agilex-clkmgr"; + compatible = "intel,n5x-clkmgr"; reg = <0xffd10000 0x1000>; #clock-cells = <1>; }; @@ -124,6 +124,11 @@ compatible = "fixed-clock"; };
+ dram_eosc_clk: dram-eosc-clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + }; + osc1: osc1 { #clock-cells = <0>; compatible = "fixed-clock"; @@ -136,7 +141,9 @@ }; }; gmac0: ethernet@ff800000 { - compatible = "altr,socfpga-stmmac", "snps,dwmac-3.74a", "snps,dwmac"; + compatible = "altr,socfpga-stmmac", + "snps,dwmac-3.74a", + "snps,dwmac"; reg = <0xff800000 0x2000>; interrupts = <0 90 4>; interrupt-names = "macirq"; @@ -148,13 +155,15 @@ snps,multicast-filter-bins = <256>; iommus = <&smmu 1>; altr,sysmgr-syscon = <&sysmgr 0x44 0>; - clocks = <&clkmgr AGILEX_EMAC0_CLK>; + clocks = <&clkmgr N5X_EMAC0_CLK>; clock-names = "stmmaceth"; status = "disabled"; };
gmac1: ethernet@ff802000 { - compatible = "altr,socfpga-stmmac", "snps,dwmac-3.74a", "snps,dwmac"; + compatible = "altr,socfpga-stmmac", + "snps,dwmac-3.74a", + "snps,dwmac"; reg = <0xff802000 0x2000>; interrupts = <0 91 4>; interrupt-names = "macirq"; @@ -166,13 +175,15 @@ snps,multicast-filter-bins = <256>; iommus = <&smmu 2>; altr,sysmgr-syscon = <&sysmgr 0x48 8>; - clocks = <&clkmgr AGILEX_EMAC1_CLK>; + clocks = <&clkmgr N5X_EMAC1_CLK>; clock-names = "stmmaceth"; status = "disabled"; };
gmac2: ethernet@ff804000 { - compatible = "altr,socfpga-stmmac", "snps,dwmac-3.74a", "snps,dwmac"; + compatible = "altr,socfpga-stmmac", + "snps,dwmac-3.74a", + "snps,dwmac"; reg = <0xff804000 0x2000>; interrupts = <0 92 4>; interrupt-names = "macirq"; @@ -184,7 +195,7 @@ snps,multicast-filter-bins = <256>; iommus = <&smmu 3>; altr,sysmgr-syscon = <&sysmgr 0x4c 16>; - clocks = <&clkmgr AGILEX_EMAC2_CLK>; + clocks = <&clkmgr N5X_EMAC2_CLK>; clock-names = "stmmaceth"; status = "disabled"; }; @@ -236,7 +247,7 @@ reg = <0xffc02800 0x100>; interrupts = <0 103 4>; resets = <&rst I2C0_RESET>; - clocks = <&clkmgr AGILEX_L4_SP_CLK>; + clocks = <&clkmgr N5X_L4_SP_CLK>; status = "disabled"; };
@@ -247,7 +258,7 @@ reg = <0xffc02900 0x100>; interrupts = <0 104 4>; resets = <&rst I2C1_RESET>; - clocks = <&clkmgr AGILEX_L4_SP_CLK>; + clocks = <&clkmgr N5X_L4_SP_CLK>; status = "disabled"; };
@@ -258,7 +269,7 @@ reg = <0xffc02a00 0x100>; interrupts = <0 105 4>; resets = <&rst I2C2_RESET>; - clocks = <&clkmgr AGILEX_L4_SP_CLK>; + clocks = <&clkmgr N5X_L4_SP_CLK>; status = "disabled"; };
@@ -269,7 +280,7 @@ reg = <0xffc02b00 0x100>; interrupts = <0 106 4>; resets = <&rst I2C3_RESET>; - clocks = <&clkmgr AGILEX_L4_SP_CLK>; + clocks = <&clkmgr N5X_L4_SP_CLK>; status = "disabled"; };
@@ -280,10 +291,17 @@ reg = <0xffc02c00 0x100>; interrupts = <0 107 4>; resets = <&rst I2C4_RESET>; - clocks = <&clkmgr AGILEX_L4_SP_CLK>; + clocks = <&clkmgr N5X_L4_SP_CLK>; status = "disabled"; };
+ memclkmgr: mem-clock-controller@f8040000 { + compatible = "intel,n5x-mem-clkmgr"; + reg = <0xf8040000 0x1000>; + #clock-cells = <0>; + clocks = <&dram_eosc_clk>, <&f2s_free_clk>; + }; + mmc: dwmmc0@ff808000 { #address-cells = <1>; #size-cells = <0>; @@ -293,8 +311,8 @@ fifo-depth = <0x400>; resets = <&rst SDMMC_RESET>; reset-names = "reset"; - clocks = <&clkmgr AGILEX_L4_MP_CLK>, - <&clkmgr AGILEX_SDMMC_CLK>; + clocks = <&clkmgr N5X_L4_MP_CLK>, + <&clkmgr N5X_SDMMC_CLK>; clock-names = "biu", "ciu"; iommus = <&smmu 5>; status = "disabled"; @@ -334,13 +352,13 @@ #dma-requests = <32>; resets = <&rst DMA_RESET>, <&rst DMA_OCP_RESET>; reset-names = "dma", "dma-ocp"; - clocks = <&clkmgr AGILEX_L4_MAIN_CLK>; + clocks = <&clkmgr N5X_L4_MAIN_CLK>; clock-names = "apb_pclk"; };
rst: rstmgr@ffd11000 { #reset-cells = <1>; - compatible = "altr,stratix10-rst-mgr"; + compatible = "altr,rst-mgr"; reg = <0xffd11000 0x100>; };
@@ -366,8 +384,7 @@ };
spi0: spi@ffda4000 { - compatible = "intel,agilex-spi", - "snps,dw-apb-ssi-4.00a", "snps,dw-apb-ssi"; + compatible = "snps,dw-apb-ssi"; #address-cells = <1>; #size-cells = <0>; reg = <0xffda4000 0x1000>; @@ -375,13 +392,12 @@ resets = <&rst SPIM0_RESET>; reg-io-width = <4>; num-cs = <4>; - clocks = <&clkmgr AGILEX_L4_MAIN_CLK>; + clocks = <&clkmgr N5X_L4_MAIN_CLK>; status = "disabled"; };
spi1: spi@ffda5000 { - compatible = "intel,agilex-spi", - "snps,dw-apb-ssi-4.00a", "snps,dw-apb-ssi"; + compatible = "snps,dw-apb-ssi"; #address-cells = <1>; #size-cells = <0>; reg = <0xffda5000 0x1000>; @@ -389,7 +405,7 @@ resets = <&rst SPIM1_RESET>; reg-io-width = <4>; num-cs = <4>; - clocks = <&clkmgr AGILEX_L4_MAIN_CLK>; + clocks = <&clkmgr N5X_L4_MAIN_CLK>; status = "disabled"; };
@@ -411,7 +427,7 @@ compatible = "snps,dw-apb-timer"; interrupts = <0 113 4>; reg = <0xffc03000 0x100>; - clocks = <&clkmgr AGILEX_L4_SP_CLK>; + clocks = <&clkmgr N5X_L4_SP_CLK>; clock-names = "timer"; };
@@ -419,7 +435,7 @@ compatible = "snps,dw-apb-timer"; interrupts = <0 114 4>; reg = <0xffc03100 0x100>; - clocks = <&clkmgr AGILEX_L4_SP_CLK>; + clocks = <&clkmgr N5X_L4_SP_CLK>; clock-names = "timer"; };
@@ -427,7 +443,7 @@ compatible = "snps,dw-apb-timer"; interrupts = <0 115 4>; reg = <0xffd00000 0x100>; - clocks = <&clkmgr AGILEX_L4_SP_CLK>; + clocks = <&clkmgr N5X_L4_SP_CLK>; clock-names = "timer"; };
@@ -435,7 +451,7 @@ compatible = "snps,dw-apb-timer"; interrupts = <0 116 4>; reg = <0xffd00100 0x100>; - clocks = <&clkmgr AGILEX_L4_SP_CLK>; + clocks = <&clkmgr N5X_L4_SP_CLK>; clock-names = "timer"; };
@@ -447,7 +463,7 @@ reg-io-width = <4>; resets = <&rst UART0_RESET>; status = "disabled"; - clocks = <&clkmgr AGILEX_L4_SP_CLK>; + clocks = <&clkmgr N5X_L4_SP_CLK>; clock-frequency = <100000000>; };
@@ -458,7 +474,7 @@ reg-shift = <2>; reg-io-width = <4>; resets = <&rst UART1_RESET>; - clocks = <&clkmgr AGILEX_L4_SP_CLK>; + clocks = <&clkmgr N5X_L4_SP_CLK>; status = "disabled"; };
@@ -476,7 +492,7 @@ phy-names = "usb2-phy"; resets = <&rst USB0_RESET>, <&rst USB0_OCP_RESET>; reset-names = "dwc2", "dwc2-ecc"; - clocks = <&clkmgr AGILEX_USB_CLK>; + clocks = <&clkmgr N5X_USB_CLK>; iommus = <&smmu 6>; status = "disabled"; }; @@ -490,7 +506,7 @@ resets = <&rst USB1_RESET>, <&rst USB1_OCP_RESET>; reset-names = "dwc2", "dwc2-ecc"; iommus = <&smmu 7>; - clocks = <&clkmgr AGILEX_USB_CLK>; + clocks = <&clkmgr N5X_USB_CLK>; status = "disabled"; };
@@ -499,7 +515,7 @@ reg = <0xffd00200 0x100>; interrupts = <0 117 4>; resets = <&rst WATCHDOG0_RESET>; - clocks = <&clkmgr AGILEX_L4_SYS_FREE_CLK>; + clocks = <&clkmgr N5X_L4_SYS_FREE_CLK>; status = "disabled"; };
@@ -508,7 +524,7 @@ reg = <0xffd00300 0x100>; interrupts = <0 118 4>; resets = <&rst WATCHDOG1_RESET>; - clocks = <&clkmgr AGILEX_L4_SYS_FREE_CLK>; + clocks = <&clkmgr N5X_L4_SYS_FREE_CLK>; status = "disabled"; };
@@ -517,7 +533,7 @@ reg = <0xffd00400 0x100>; interrupts = <0 125 4>; resets = <&rst WATCHDOG2_RESET>; - clocks = <&clkmgr AGILEX_L4_SYS_FREE_CLK>; + clocks = <&clkmgr N5X_L4_SYS_FREE_CLK>; status = "disabled"; };
@@ -526,7 +542,7 @@ reg = <0xffd00500 0x100>; interrupts = <0 126 4>; resets = <&rst WATCHDOG3_RESET>; - clocks = <&clkmgr AGILEX_L4_SYS_FREE_CLK>; + clocks = <&clkmgr N5X_L4_SYS_FREE_CLK>; status = "disabled"; };
diff --git a/arch/arm/dts/socfpga_n5x_socdk-u-boot.dtsi b/arch/arm/dts/socfpga_n5x_socdk-u-boot.dtsi new file mode 100644 index 0000000000..57509f083e --- /dev/null +++ b/arch/arm/dts/socfpga_n5x_socdk-u-boot.dtsi @@ -0,0 +1,67 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * U-Boot additions + * + * Copyright (C) 2020-2021 Intel Corporation <www.intel.com> + */ + +#include "socfpga_n5x-u-boot.dtsi" + +/{ + aliases { + spi0 = &qspi; + i2c0 = &i2c1; + }; + + memory { + /* + * Memory type: DDR4 + * 16GB + * <0 0x00000000 0 0x80000000>, + * <4 0x80000000 3 0x80000000>; + * + * 8GB + * <0 0x00000000 0 0x80000000>, + * <2 0x80000000 1 0x80000000>; + * + * 4GB + * <0 0x00000000 0 0x80000000>, + * <1 0x80000000 0 0x80000000>; + * + * Memory type: LPDDR4 (non-interleaving mode) + * Total memory size 3GB, usable = 2.5GB, 0.5GB trade off for secure + * region. + */ + reg = <0 0x00000000 0 0x60000000>, + <0x10 0x00100000 0 0x40000000>; + }; +}; + +&flash0 { + compatible = "jedec,spi-nor"; + spi-tx-bus-width = <4>; + spi-rx-bus-width = <4>; + u-boot,dm-pre-reloc; +}; + +&i2c1 { + status = "okay"; +}; + +&nand { + u-boot,dm-pre-reloc; +}; + +&mmc { + drvsel = <3>; + smplsel = <0>; + u-boot,dm-pre-reloc; +}; + +&qspi { + status = "okay"; +}; + +&watchdog0 { + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/socfpga_agilex_socdk.dts b/arch/arm/dts/socfpga_n5x_socdk.dts similarity index 92% copy from arch/arm/dts/socfpga_agilex_socdk.dts copy to arch/arm/dts/socfpga_n5x_socdk.dts index bcdeecc0e0..bf74414c9e 100644 --- a/arch/arm/dts/socfpga_agilex_socdk.dts +++ b/arch/arm/dts/socfpga_n5x_socdk.dts @@ -1,11 +1,11 @@ // SPDX-License-Identifier: GPL-2.0 /* - * Copyright (C) 2019, Intel Corporation + * Copyright (C) 2020-2021, Intel Corporation */ -#include "socfpga_agilex.dtsi" +#include "socfpga_n5x.dtsi"
/ { - model = "SoCFPGA Agilex SoCDK"; + model = "SoCFPGA N5X SoCDK";
aliases { serial0 = &uart0; @@ -16,6 +16,7 @@
chosen { stdout-path = "serial0:115200n8"; + u-boot,boot0 = <&mmc>; };
leds { @@ -106,6 +107,7 @@ };
&qspi { + status = "okay"; flash0: flash@0 { #address-cells = <1>; #size-cells = <1>; @@ -116,7 +118,7 @@ m25p,fast-read; cdns,page-size = <256>; cdns,block-size = <16>; - cdns,read-delay = <1>; + cdns,read-delay = <3>; cdns,tshsl-ns = <50>; cdns,tsd2d-ns = <50>; cdns,tchsh-ns = <4>;
-----Original Message----- From: Lim, Elly Siew Chin elly.siew.chin.lim@intel.com Sent: Wednesday, March 31, 2021 10:39 PM To: u-boot@lists.denx.de Cc: Marek Vasut marex@denx.de; Tan, Ley Foon ley.foon.tan@intel.com; See, Chin Liang chin.liang.see@intel.com; Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Chee, Tien Fong tien.fong.chee@intel.com; Westergreen, Dalon dalon.westergreen@intel.com; Simon Glass sjg@chromium.org; Gan, Yau Wai yau.wai.gan@intel.com; Lim, Elly Siew Chin elly.siew.chin.lim@intel.com Subject: [v1 15/17] arm: dts: Add base dtsi and devkit dts for Intel N5X device
Port dts/dtsi from Linux, then overwrite U-Boot specific settings with u-boot.dtsi.
Uboot dts got a lot differences compare to Linux dts now. Example, Linux reuse socfpga_agilex.dtsi.
Add CONFIGs for N5X.
Signed-off-by: Siew Chin Lim elly.siew.chin.lim@intel.com --- include/configs/socfpga_n5x_socdk.h | 45 +++++++++++++++++++++++++++++++++++++ 1 file changed, 45 insertions(+) create mode 100644 include/configs/socfpga_n5x_socdk.h
diff --git a/include/configs/socfpga_n5x_socdk.h b/include/configs/socfpga_n5x_socdk.h new file mode 100644 index 0000000000..c295e91e3d --- /dev/null +++ b/include/configs/socfpga_n5x_socdk.h @@ -0,0 +1,45 @@ +/* SPDX-License-Identifier: GPL-2.0 + * + * Copyright (C) 2020-2021 Intel Corporation <www.intel.com> + * + */ + +#ifndef __CONFIG_SOCFGPA_N5X_H__ +#define __CONFIG_SOCFGPA_N5X_H__ + +#include <configs/socfpga_soc64_common.h> + +#undef CONFIG_EXTRA_ENV_SETTINGS +#define CONFIG_EXTRA_ENV_SETTINGS \ + "loadaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ + "bootfile=" CONFIG_BOOTFILE "\0" \ + "fdt_addr=1100000\0" \ + "fdtimage=" CONFIG_DEFAULT_DEVICE_TREE ".dtb\0" \ + "mmcroot=/dev/mmcblk0p2\0" \ + "mmcboot=setenv bootargs " CONFIG_BOOTARGS \ + " root=${mmcroot} rw rootwait;" \ + "booti ${loadaddr} - ${fdt_addr}\0" \ + "mmcload=mmc rescan;" \ + "load mmc 0:1 ${loadaddr} ${bootfile};" \ + "load mmc 0:1 ${fdt_addr} ${fdtimage}\0" \ + "mmcfitboot=setenv bootargs " CONFIG_BOOTARGS \ + " root=${mmcroot} rw rootwait;" \ + "bootm ${loadaddr}\0" \ + "mmcfitload=mmc rescan;" \ + "load mmc 0:1 ${loadaddr} ${bootfile}\0" \ + "ramboot=setenv bootargs " CONFIG_BOOTARGS";" \ + "booti ${loadaddr} - ${fdt_addr}\0" \ + "linux_qspi_enable=if sf probe; then " \ + "echo Enabling QSPI at Linux DTB...;" \ + "fdt addr ${fdt_addr}; fdt resize;" \ + "fdt set /soc/spi@ff8d2000 status okay;" \ + "if fdt set /soc/clocks/qspi-clk clock-frequency" \ + " ${qspi_clock}; then" \ + " else fdt set /soc/clkmgr/clocks/qspi_clk clock-frequency" \ + " ${qspi_clock}; fi; fi\0" \ + "scriptaddr=0x02100000\0" \ + "scriptfile=u-boot.scr\0" \ + "fatscript=if fatload mmc 0:1 ${scriptaddr} ${scriptfile};" \ + "then source ${scriptaddr}; fi\0" + +#endif /* __CONFIG_SOCFGPA_N5X_H__ */
-----Original Message----- From: Lim, Elly Siew Chin elly.siew.chin.lim@intel.com Sent: Wednesday, March 31, 2021 10:39 PM To: u-boot@lists.denx.de Cc: Marek Vasut marex@denx.de; Tan, Ley Foon ley.foon.tan@intel.com; See, Chin Liang chin.liang.see@intel.com; Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Chee, Tien Fong tien.fong.chee@intel.com; Westergreen, Dalon dalon.westergreen@intel.com; Simon Glass sjg@chromium.org; Gan, Yau Wai yau.wai.gan@intel.com; Lim, Elly Siew Chin elly.siew.chin.lim@intel.com Subject: [v1 16/17] include: configs: Add Intel N5X device CONFIGs
- "loadaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \
- "bootfile=" CONFIG_BOOTFILE "\0" \
- "fdt_addr=1100000\0" \
- "fdtimage=" CONFIG_DEFAULT_DEVICE_TREE ".dtb\0" \
- "mmcroot=/dev/mmcblk0p2\0" \
- "mmcboot=setenv bootargs " CONFIG_BOOTARGS \
- "mmcload=mmc rescan;" \
- "mmcfitboot=setenv bootargs " CONFIG_BOOTARGS \
- "mmcfitload=mmc rescan;" \
- "ramboot=setenv bootargs " CONFIG_BOOTARGS";" \
- "linux_qspi_enable=if sf probe; then " \
- "scriptaddr=0x02100000\0" \
- "scriptfile=u-boot.scr\0" \
- "fatscript=if fatload mmc 0:1 ${scriptaddr} ${scriptfile};" \
Add defconfig for N5X to support legacy, ATF and VAB boot flow.
Signed-off-by: Siew Chin Lim elly.siew.chin.lim@intel.com --- arch/arm/mach-socfpga/Kconfig | 20 +++++++++++++++++++- arch/arm/mach-socfpga/Makefile | 22 +++++++++++++++++++++- ...lex_atf_defconfig => socfpga_n5x_atf_defconfig} | 10 +++++----- ...fpga_agilex_defconfig => socfpga_n5x_defconfig} | 15 ++++++--------- ...lex_vab_defconfig => socfpga_n5x_vab_defconfig} | 10 +++++----- 5 files changed, 56 insertions(+), 21 deletions(-) copy configs/{socfpga_agilex_atf_defconfig => socfpga_n5x_atf_defconfig} (89%) copy configs/{socfpga_agilex_defconfig => socfpga_n5x_defconfig} (80%) copy configs/{socfpga_agilex_vab_defconfig => socfpga_n5x_vab_defconfig} (89%)
diff --git a/arch/arm/mach-socfpga/Kconfig b/arch/arm/mach-socfpga/Kconfig index 0c35406232..e773029595 100644 --- a/arch/arm/mach-socfpga/Kconfig +++ b/arch/arm/mach-socfpga/Kconfig @@ -8,7 +8,7 @@ config NR_DRAM_BANKS
config SOCFPGA_SECURE_VAB_AUTH bool "Enable boot image authentication with Secure Device Manager" - depends on TARGET_SOCFPGA_AGILEX + depends on TARGET_SOCFPGA_AGILEX || TARGET_SOCFPGA_N5X select FIT_IMAGE_POST_PROCESS select SHA384 select SHA512_ALGO @@ -91,6 +91,21 @@ config TARGET_SOCFPGA_GEN5 imply SPL_SYS_MALLOC_SIMPLE imply SPL_USE_TINY_PRINTF
+config TARGET_SOCFPGA_N5X + bool + select ARMV8_MULTIENTRY + select ARMV8_SET_SMPEN + select BINMAN if SPL_ATF + select CLK + select NCORE_CACHE + select SPL_ALTERA_SDRAM + select SPL_CLK if SPL + select TARGET_SOCFPGA_SOC64 + +config TARGET_SOCFPGA_N5X_SOCDK + bool "Intel SOCFPGA SoCDK (N5X)" + select TARGET_SOCFPGA_N5X + config TARGET_SOCFPGA_SOC64 bool
@@ -183,6 +198,7 @@ config SYS_BOARD default "de0-nano-soc" if TARGET_SOCFPGA_TERASIC_DE0_NANO default "de1-soc" if TARGET_SOCFPGA_TERASIC_DE1_SOC default "de10-nano" if TARGET_SOCFPGA_TERASIC_DE10_NANO + default "n5x-socdk" if TARGET_SOCFPGA_N5X_SOCDK default "is1" if TARGET_SOCFPGA_IS1 default "mcvevk" if TARGET_SOCFPGA_ARIES_MCVEVK default "secu1" if TARGET_SOCFPGA_ARRIA5_SECU1 @@ -194,6 +210,7 @@ config SYS_BOARD
config SYS_VENDOR default "intel" if TARGET_SOCFPGA_AGILEX_SOCDK + default "intel" if TARGET_SOCFPGA_N5X_SOCDK default "altera" if TARGET_SOCFPGA_ARRIA5_SOCDK default "altera" if TARGET_SOCFPGA_ARRIA10_SOCDK default "altera" if TARGET_SOCFPGA_CYCLONE5_SOCDK @@ -221,6 +238,7 @@ config SYS_CONFIG_NAME default "socfpga_de0_nano_soc" if TARGET_SOCFPGA_TERASIC_DE0_NANO default "socfpga_de1_soc" if TARGET_SOCFPGA_TERASIC_DE1_SOC default "socfpga_de10_nano" if TARGET_SOCFPGA_TERASIC_DE10_NANO + default "socfpga_n5x_socdk" if TARGET_SOCFPGA_N5X_SOCDK default "socfpga_is1" if TARGET_SOCFPGA_IS1 default "socfpga_mcvevk" if TARGET_SOCFPGA_ARIES_MCVEVK default "socfpga_sockit" if TARGET_SOCFPGA_TERASIC_SOCKIT diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index 58afde950f..8f6e88a161 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -4,7 +4,7 @@ # Wolfgang Denk, DENX Software Engineering, wd@denx.de. # # Copyright (C) 2012-2017 Altera Corporation <www.altera.com> -# Copyright (C) 2017-2020 Intel Corporation <www.intel.com> +# Copyright (C) 2017-2021 Intel Corporation <www.intel.com>
obj-y += board.o obj-y += clock_manager.o @@ -56,6 +56,21 @@ obj-y += wrap_handoff_soc64.o obj-y += wrap_pll_config_soc64.o endif
+ifdef CONFIG_TARGET_SOCFPGA_N5X +obj-y += clock_manager_n5x.o +obj-y += lowlevel_init_soc64.o +obj-y += mailbox_s10.o +obj-y += misc_soc64.o +obj-y += mmu-arm64_s10.o +obj-y += reset_manager_s10.o +obj-$(CONFIG_SOCFPGA_SECURE_VAB_AUTH) += secure_vab.o +obj-y += system_manager_soc64.o +obj-y += timer_s10.o +obj-$(CONFIG_SOCFPGA_SECURE_VAB_AUTH) += vab.o +obj-y += wrap_handoff_soc64.o +obj-y += wrap_pll_config_soc64.o +endif + ifdef CONFIG_SPL_BUILD ifdef CONFIG_TARGET_SOCFPGA_GEN5 obj-y += spl_gen5.o @@ -77,6 +92,11 @@ obj-y += firewall.o obj-y += spl_agilex.o obj-y += spl_soc64.o endif +ifdef CONFIG_TARGET_SOCFPGA_N5X +obj-y += firewall.o +obj-y += spl_n5x.o +obj-y += spl_soc64.o +endif else obj-$(CONFIG_SPL_ATF) += secure_reg_helper.o obj-$(CONFIG_SPL_ATF) += smc_api.o diff --git a/configs/socfpga_agilex_atf_defconfig b/configs/socfpga_n5x_atf_defconfig similarity index 89% copy from configs/socfpga_agilex_atf_defconfig copy to configs/socfpga_n5x_atf_defconfig index e5b7f4b52a..12c50f5c33 100644 --- a/configs/socfpga_agilex_atf_defconfig +++ b/configs/socfpga_n5x_atf_defconfig @@ -9,10 +9,10 @@ CONFIG_ENV_OFFSET=0x200 CONFIG_SYS_SPI_U_BOOT_OFFS=0x02000000 CONFIG_DM_GPIO=y CONFIG_SPL_TEXT_BASE=0xFFE00000 -CONFIG_TARGET_SOCFPGA_AGILEX_SOCDK=y -CONFIG_IDENT_STRING="socfpga_agilex" +CONFIG_TARGET_SOCFPGA_N5X_SOCDK=y +CONFIG_IDENT_STRING="socfpga_n5x" CONFIG_SPL_FS_FAT=y -CONFIG_DEFAULT_DEVICE_TREE="socfpga_agilex_socdk" +CONFIG_DEFAULT_DEVICE_TREE="socfpga_n5x_socdk" CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_SIGNATURE_MAX_SIZE=0x10000000 @@ -23,7 +23,7 @@ CONFIG_SPL_LOAD_FIT_ADDRESS=0x02000000 # CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_BOOTDELAY=5 CONFIG_USE_BOOTARGS=y -CONFIG_BOOTARGS="earlycon" +CONFIG_BOOTARGS="earlycon panic=-1 earlyprintk=ttyS0,115200" CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run fatscript; run mmcfitload; run linux_qspi_enable; run mmcfitboot" CONFIG_SPL_CACHE=y @@ -31,7 +31,7 @@ CONFIG_SPL_SPI_LOAD=y CONFIG_SPL_ATF=y CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y CONFIG_HUSH_PARSER=y -CONFIG_SYS_PROMPT="SOCFPGA_AGILEX # " +CONFIG_SYS_PROMPT="SOCFPGA_N5X # " CONFIG_CMD_MEMTEST=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y diff --git a/configs/socfpga_agilex_defconfig b/configs/socfpga_n5x_defconfig similarity index 80% copy from configs/socfpga_agilex_defconfig copy to configs/socfpga_n5x_defconfig index 3d5d39fe0f..d5cc89c4d4 100644 --- a/configs/socfpga_agilex_defconfig +++ b/configs/socfpga_n5x_defconfig @@ -3,27 +3,25 @@ CONFIG_ARCH_SOCFPGA=y CONFIG_SYS_TEXT_BASE=0x1000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_NR_DRAM_BANKS=2 -CONFIG_SYS_MEMTEST_START=0x00000000 -CONFIG_SYS_MEMTEST_END=0x3fe00000 CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x200 -CONFIG_SYS_SPI_U_BOOT_OFFS=0x3c00000 +CONFIG_SYS_SPI_U_BOOT_OFFS=0x02000000 CONFIG_DM_GPIO=y CONFIG_SPL_TEXT_BASE=0xFFE00000 -CONFIG_TARGET_SOCFPGA_AGILEX_SOCDK=y -CONFIG_IDENT_STRING="socfpga_agilex" +CONFIG_TARGET_SOCFPGA_N5X_SOCDK=y +CONFIG_IDENT_STRING="socfpga_n5x" CONFIG_SPL_FS_FAT=y # CONFIG_PSCI_RESET is not set -CONFIG_DEFAULT_DEVICE_TREE="socfpga_agilex_socdk" +CONFIG_DEFAULT_DEVICE_TREE="socfpga_n5x_socdk" CONFIG_BOOTDELAY=5 CONFIG_USE_BOOTARGS=y -CONFIG_BOOTARGS="earlycon" +CONFIG_BOOTARGS="earlycon panic=-1 earlyprintk=ttyS0,115200" CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run fatscript; run mmcload; run linux_qspi_enable; run mmcboot" CONFIG_SPL_CACHE=y CONFIG_SPL_SPI_LOAD=y CONFIG_HUSH_PARSER=y -CONFIG_SYS_PROMPT="SOCFPGA_AGILEX # " +CONFIG_SYS_PROMPT="SOCFPGA_N5X # " CONFIG_CMD_MEMTEST=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y @@ -40,7 +38,6 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_MMC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y -CONFIG_SPL_ALTERA_SDRAM=y CONFIG_DWAPB_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_DW=y diff --git a/configs/socfpga_agilex_vab_defconfig b/configs/socfpga_n5x_vab_defconfig similarity index 89% copy from configs/socfpga_agilex_vab_defconfig copy to configs/socfpga_n5x_vab_defconfig index fac9cf72e5..801460ee13 100644 --- a/configs/socfpga_agilex_vab_defconfig +++ b/configs/socfpga_n5x_vab_defconfig @@ -10,10 +10,10 @@ CONFIG_SYS_SPI_U_BOOT_OFFS=0x02000000 CONFIG_DM_GPIO=y CONFIG_SPL_TEXT_BASE=0xFFE00000 CONFIG_SOCFPGA_SECURE_VAB_AUTH=y -CONFIG_TARGET_SOCFPGA_AGILEX_SOCDK=y -CONFIG_IDENT_STRING="socfpga_agilex" +CONFIG_TARGET_SOCFPGA_N5X_SOCDK=y +CONFIG_IDENT_STRING="socfpga_n5x" CONFIG_SPL_FS_FAT=y -CONFIG_DEFAULT_DEVICE_TREE="socfpga_agilex_socdk" +CONFIG_DEFAULT_DEVICE_TREE="socfpga_n5x_socdk" CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_SIGNATURE_MAX_SIZE=0x10000000 @@ -25,7 +25,7 @@ CONFIG_SPL_LOAD_FIT_ADDRESS=0x02000000 # CONFIG_LEGACY_IMAGE_FORMAT is not set CONFIG_BOOTDELAY=5 CONFIG_USE_BOOTARGS=y -CONFIG_BOOTARGS="earlycon" +CONFIG_BOOTARGS="earlycon panic=-1 earlyprintk=ttyS0,115200" CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run fatscript; run mmcfitload; run mmcfitboot" CONFIG_SPL_CACHE=y @@ -33,7 +33,7 @@ CONFIG_SPL_SPI_LOAD=y CONFIG_SPL_ATF=y CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y CONFIG_HUSH_PARSER=y -CONFIG_SYS_PROMPT="SOCFPGA_AGILEX # " +CONFIG_SYS_PROMPT="SOCFPGA_N5X # " CONFIG_CMD_MEMTEST=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y
-----Original Message----- From: Lim, Elly Siew Chin elly.siew.chin.lim@intel.com Sent: Wednesday, March 31, 2021 10:39 PM To: u-boot@lists.denx.de Cc: Marek Vasut marex@denx.de; Tan, Ley Foon ley.foon.tan@intel.com; See, Chin Liang chin.liang.see@intel.com; Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Chee, Tien Fong tien.fong.chee@intel.com; Westergreen, Dalon dalon.westergreen@intel.com; Simon Glass sjg@chromium.org; Gan, Yau Wai yau.wai.gan@intel.com; Lim, Elly Siew Chin elly.siew.chin.lim@intel.com Subject: [v1 17/17] arm: socfpga: Enable Intel N5X device build
Chee, Tien Fong
Lim, Elly Siew Chin
Siew Chin Lim
Tan, Ley Foon
