[PATCH v2] lmb: Remove lmb_alloc_flags()
lmb_alloc_flags() & lmb_alloc_base_flags() are just a wrappers for _lmb_alloc_base(). Since the only difference is the max address of the allowed allocation which _lmb_alloc_base() already supports with the LMB_ALLOC_ANYWHERE flag, remove one of them.
Keep the lmb_alloc_base_flags() which also prints an error on failures and adjust efi_allocate_pages() to only use one of them.
While at it clean up the duplicate function description from the header file.
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- changes since v1: - Move the needed lmb defines to lmb.h
include/lmb.h | 29 +++-------------------------- lib/efi_loader/efi_memory.c | 3 ++- lib/lmb.c | 20 -------------------- 3 files changed, 5 insertions(+), 47 deletions(-)
diff --git a/include/lmb.h b/include/lmb.h index e46abf400c68..2201d6f2b67b 100644 --- a/include/lmb.h +++ b/include/lmb.h @@ -14,6 +14,9 @@ * Copyright (C) 2001 Peter Bergner, IBM Corp. */
+#define LMB_ALLOC_ANYWHERE 0 +#define LMB_ALIST_INITIAL_SIZE 4 + /** * enum lmb_flags - definition of memory region attributes * @LMB_NONE: no special request @@ -95,32 +98,6 @@ phys_addr_t lmb_alloc_base(phys_size_t size, ulong align, phys_addr_t max_addr); phys_addr_t lmb_alloc_addr(phys_addr_t base, phys_size_t size); phys_size_t lmb_get_free_size(phys_addr_t addr);
-/** - * lmb_alloc_flags() - Allocate memory region with specified attributes - * @size: Size of the region requested - * @align: Alignment of the memory region requested - * @flags: Memory region attributes to be set - * - * Allocate a region of memory with the attributes specified through the - * parameter. - * - * Return: base address on success, 0 on error - */ -phys_addr_t lmb_alloc_flags(phys_size_t size, ulong align, uint flags); - -/** - * lmb_alloc_base_flags() - Allocate specified memory region with specified attributes - * @size: Size of the region requested - * @align: Alignment of the memory region requested - * @max_addr: Maximum address of the requested region - * @flags: Memory region attributes to be set - * - * Allocate a region of memory with the attributes specified through the - * parameter. The max_addr parameter is used to specify the maximum address - * below which the requested region should be allocated. - * - * Return: base address on success, 0 on error - */ phys_addr_t lmb_alloc_base_flags(phys_size_t size, ulong align, phys_addr_t max_addr, uint flags);
diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c index 3d742fa19150..9f3f08769977 100644 --- a/lib/efi_loader/efi_memory.c +++ b/lib/efi_loader/efi_memory.c @@ -472,7 +472,8 @@ efi_status_t efi_allocate_pages(enum efi_allocate_type type, switch (type) { case EFI_ALLOCATE_ANY_PAGES: /* Any page */ - addr = (u64)lmb_alloc_flags(len, EFI_PAGE_SIZE, flags); + addr = (u64)lmb_alloc_base_flags(len, EFI_PAGE_SIZE, + LMB_ALLOC_ANYWHERE, flags); if (!addr) return EFI_OUT_OF_RESOURCES; break; diff --git a/lib/lmb.c b/lib/lmb.c index 69001ad57373..890e2cbfdf6b 100644 --- a/lib/lmb.c +++ b/lib/lmb.c @@ -27,9 +27,6 @@ DECLARE_GLOBAL_DATA_PTR; #define MAP_OP_FREE (u8)0x2 #define MAP_OP_ADD (u8)0x3
-#define LMB_ALLOC_ANYWHERE 0 -#define LMB_ALIST_INITIAL_SIZE 4 - static struct lmb lmb;
static bool lmb_should_notify(enum lmb_flags flags) @@ -670,23 +667,6 @@ phys_addr_t lmb_alloc(phys_size_t size, ulong align) return lmb_alloc_base(size, align, LMB_ALLOC_ANYWHERE); }
-/** - * lmb_alloc_flags() - Allocate memory region with specified attributes - * @size: Size of the region requested - * @align: Alignment of the memory region requested - * @flags: Memory region attributes to be set - * - * Allocate a region of memory with the attributes specified through the - * parameter. - * - * Return: base address on success, 0 on error - */ -phys_addr_t lmb_alloc_flags(phys_size_t size, ulong align, uint flags) -{ - return _lmb_alloc_base(size, align, LMB_ALLOC_ANYWHERE, - flags); -} - phys_addr_t lmb_alloc_base(phys_size_t size, ulong align, phys_addr_t max_addr) { phys_addr_t alloc; -- 2.45.2
Ilias Apalodimas
