[U-Boot] freebsd 8 installer on MPC8349E-mITX
Hi am trying to boot, freebsd 8 instalelr on the MPC8349E-mITX.
I loaded the ubldr: MPC8349E-mITX> tftpboot $loadaddr freebsd8/boot/ubldr Speed: 100, full duplex Using TSEC0 device TFTP from server 192.168.0.194; our IP address is 192.168.0.248 Filename 'freebsd8/boot/ubldr'. Load address: 0x800000 Loading: ############# done Bytes transferred = 177964 (2b72c hex)
and than trying to boot: MPC8349E-mITX> bootelf $loadaddr ## Starting application at 0x00010080 ... Bad trap at PC: 2ee08, SR: 3032, vector=300 NIP: 0002EE08 XER: 20000000 LR: 0002A2DC REGS: 0ff52b18 TRAP: 0300 DAR: 10000000 MSR: 00003032 EE: 0 PR: 0 FP: 1 ME: 1 IR/DR: 11
GPR00: 00000000 0FF52C08 0FF52F50 10000000 00035EF8 00000008 00000000 00000000 GPR08: 00000000 00000055 00000021 00003032 48044042 0D1A0082 00000000 00000000 GPR16: 0FFB5A14 0FFBC2C0 00000000 00000000 00000000 00000000 00000000 00000000 GPR24: 00000000 0FF52C24 0FF52C10 00035EF8 0FF52C60 101FFFF8 00032A8C 10000000 Call backtrace: 0FF55338 00017C78 0FF84100 0FF841BC 0FF94CBC 0FF943D0 0FF9461C 0FF94BFC 0FF943D0 0FF94540 0FF97074 0FF79A24 0FF78600 Exception in kernel pc 2ee08 signal 0 Resetting the board.
U-Boot 2010.03 (Jun 22 2010 - 15:17:07) MPC83XX .. . . . . . . . . .
any idea ?
any idea ?
Just making sure: have you got CONFIG_API enabled in your U-Boot config?
Rafal
NO I'll build another one, and come back. thx for the tip
getting better with CONFIG_API enabled
MPC8349E-mITX> bootelf $loadaddr ## Starting application at 0x00010080 ... Consoles: U-Boot console Compatible API signature found @ff520c8 Number of U-Boot devices: 4
FreeBSD/powerpc U-Boot loader, Revision 1.0 (root@xserve.lan.xcllnt.net, Sat Nov 21 19:22:49 UTC 2009) DRAM: 512MB FLASH: 16MB Speed: 100, full duplex Speed: 100, full duplex Speed: 100, full duplex
Speed: 100, full duplex Speed: 100, full duplex Speed: 100, full duplex Speed: 100, full duplex Speed: 100, full duplex Speed: 100, full duplex can't load 'kernel'
Type '?' for a list of commands, 'help' for more detailed help. loader>
it's a matter of NFS now, isn't ?
-- Zied FAKHFAKH Dot TN - CTO
@: fzied@dottn.com t: +216 71 82 89 58 f: +216 71 82 89 58 w: http://www.dottn.com a: Centre Molka, Esc E, Bur 17 - Manar 2 - 2092 - Tunis - Tunisia
We are progressing, after fixing the dhcp parameters: host mpc8349e-mitx { hardware ethernet 08:00:3e:03:01:10; fixed-address 192.168.0.195; option root-path "/var/ftp/pub/freebsd8"; filename "/boot/loader"; } we are able to load kernel, but crashes when looking for mfsroot. ........................... Speed: 100, full duplex Loading /boot/defaults/loader.conf Speed: 100, full duplex Speed: 100, full duplex Speed: 100, full duplex Speed: 100, full duplex Speed: 100, full duplex Speed: 100, full duplex Speed: 100, full duplex Speed: 100, full duplex Speed: 100, full duplex /boot/kernel/kernel text=0x6cf6d4 data=0x40af4+0x3e43c syms=[0x4+0x592e0+0x4+0x7b3d4] Speed: 100, full duplex Speed: 100, full duplex
Hit [Enter] to boot immediately, or any other key for command prompt. Booting [/boot/kernel/kernel]... Kernel entry at 0x100100 ... Machine check in kernel mode. Caused by (from msr): regs 007d1eb0 Unknown values in msr NIP: 0032781C XER: 00000000 LR: 0058AAD8 REGS: 007d1eb0 TRAP: 0200 DAR: 00000000 MSR: 00003030 EE: 0 PR: 0 FP: 1 ME: 1 IR/DR: 11
GPR00: FFFFDF7B 007D1FA0 0FF4FF50 007B25EC 0084EF30 0084EF30 00000010 00000000 GPR08: 007D0000 FFFFDF84 00000010 0083BC9C 24024028 4D981482 00000000 00000000 GPR16: 0FFB41C4 0FFBA33C 00000000 00000000 00000010 00000000 00000000 00000000 GPR24: 00034680 0084EF30 00100100 0003670C 007B25EC 00000000 FFFFDF9C FFFFDF9C Call backtrace: 00000000 0058AAD8 0010018C machine check Resetting the board.
Actually there's mfsroot.gz, and loader.conf is: mfsroot_load="YES" mfsroot_type="mfs_root" mfsroot_name="/boot/mfsroot" vfs.root.mountfrom="ufs:/dev/md0"
- do I must tell him to load the gzipped mfsroot ? - not to load it ? - or gunzip it for him ??
Rafal Jaworowski
Zied Fakhfakh
