[U-Boot] [PATCH] efi_loader: Fix efi_exit gd clobbering
Commit f494950b (efi_loader: call __efi_exit_check in efi_exit) added a call to __efi_exit_check inside efi_exit to account for the fact that we're exiting the efi_exit function via a longjmp call.
However, __efi_exit_check also swizzles gd to the application gd while the longjmp will put us back into EFI context, so we need the efi (u-boot) gd.
This patch fixes that up by explicitly setting gd back to efi_gd before doing the longjmp. It also adds a few comments on why it does that.
Signed-off-by: Alexander Graf agraf@suse.de --- lib/efi_loader/efi_boottime.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index 99c5a6ee0c..90e9ead7b2 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -798,8 +798,15 @@ static efi_status_t EFIAPI efi_exit(efi_handle_t image_handle, EFI_ENTRY("%p, %ld, %ld, %p", image_handle, exit_status, exit_data_size, exit_data);
+ /* Make sure entry/exit counts for EFI world cross-overs match */ __efi_exit_check();
+ /* + * But longjmp out with the U-Boot gd, not the application's, as + * the other end is a setjmp call inside EFI context. + */ + efi_restore_gd(); + loaded_image_info->exit_status = exit_status; longjmp(&loaded_image_info->exit_jmp, 1);
Alexander Graf
