[PATCH v2] arm: Add support for Kobol Helios64 board
The hardware is described in detail on Kobol's wiki at https://wiki.kobol.io/helios64/intro/.
This commit is based on downstream work in Armbian by Aditya Prayoga [1]. The devicetree is taken from Linux v5.12-rc1 and was originally submitted there by Uwe Kleine-Koenig [2].
[1] https://github.com/ukleinek/armbian-build/blob/35c85295d351830aa59b624db524b... [2] https://github.com/torvalds/linux/blob/7a7fd0de4a9804299793e564a555a49c1fc92... --- arch/arm/dts/Makefile | 1 + .../arm/dts/rk3399-kobol-helios64-u-boot.dtsi | 136 +++++++ arch/arm/dts/rk3399-kobol-helios64.dts | 372 ++++++++++++++++++ arch/arm/mach-rockchip/rk3399/Kconfig | 17 + board/kobol/helios64/Kconfig | 24 ++ board/kobol/helios64/MAINTAINERS | 6 + board/kobol/helios64/Makefile | 5 + board/kobol/helios64/helios64.c | 304 ++++++++++++++ board/kobol/helios64/sys_otp.c | 250 ++++++++++++ board/kobol/helios64/sys_otp.h | 12 + configs/helios64-rk3399_defconfig | 147 +++++++ include/configs/helios64.h | 47 +++ 12 files changed, 1321 insertions(+) create mode 100644 arch/arm/dts/rk3399-kobol-helios64-u-boot.dtsi create mode 100644 arch/arm/dts/rk3399-kobol-helios64.dts create mode 100644 board/kobol/helios64/Kconfig create mode 100644 board/kobol/helios64/MAINTAINERS create mode 100644 board/kobol/helios64/Makefile create mode 100644 board/kobol/helios64/helios64.c create mode 100644 board/kobol/helios64/sys_otp.c create mode 100644 board/kobol/helios64/sys_otp.h create mode 100644 configs/helios64-rk3399_defconfig create mode 100644 include/configs/helios64.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 33e483f4fb..2c820bc2b7 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -124,6 +124,7 @@ dtb-$(CONFIG_ROCKCHIP_RK3399) += \ rk3399-ficus.dtb \ rk3399-firefly.dtb \ rk3399-gru-bob.dtb \ + rk3399-kobol-helios64.dtb \ rk3399-khadas-edge.dtb \ rk3399-khadas-edge-captain.dtb \ rk3399-khadas-edge-v.dtb \ diff --git a/arch/arm/dts/rk3399-kobol-helios64-u-boot.dtsi b/arch/arm/dts/rk3399-kobol-helios64-u-boot.dtsi new file mode 100644 index 0000000000..6fe9d59df3 --- /dev/null +++ b/arch/arm/dts/rk3399-kobol-helios64-u-boot.dtsi @@ -0,0 +1,136 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2020 Aditya Prayoga aditya@kobol.io + */ + +#include "rk3399-u-boot.dtsi" +#include "rk3399-sdram-lpddr4-100.dtsi" +/ { + aliases { + spi0 = &spi1; + spi1 = &spi2; + spi2 = &spi5; + ethernet0 = &gmac; + ethernet1 = &usb_lan; + }; + + chosen { + bootargs = "earlycon=uart8250,mmio32,0xff1a0000 earlyprintk"; + stdout-path = "serial2:1500000n8"; + u-boot,spl-boot-order = "same-as-spl", &spiflash, &sdmmc, &sdhci; + }; + + config { + u-boot,spl-payload-offset = <0x80000>; /* @ 512KB */ + }; +}; + +&gpio1 { + usb-mux-hs { + gpio-hog; + gpios = <RK_PA4 GPIO_ACTIVE_HIGH>; + output-low; + line-name = "USB_MUX_HS"; + }; + + usb-mux-oe { + gpio-hog; + gpios = <RK_PB5 GPIO_ACTIVE_LOW>; + output-high; + line-name = "USB_MUX_OE#"; + }; + + soc-flash-wp { + gpio-hog; + gpios = <RK_PC2 GPIO_ACTIVE_LOW>; + output-low; + line-name = "SOC_WP#"; + }; +}; + +&gpio2 { + sata-flash-wp { + gpio-hog; + gpios = <RK_PD0 GPIO_ACTIVE_LOW>; + output-high; + line-name = "SATA_WP#_LV"; + }; +}; + +&gpio4 { + auto-on-en-d { + gpio-hog; + gpios = <RK_PD1 GPIO_ACTIVE_HIGH>; + output-low; + line-name = "AUTO_ON_EN_D"; + }; + + auto-on-en-clk { + gpio-hog; + gpios = <RK_PD2 GPIO_ACTIVE_HIGH>; + output-low; + line-name = "AUTO_ON_EN_CLK"; + }; + + board-rev-id-0 { + gpio-hog; + gpios = <RK_PD5 GPIO_ACTIVE_HIGH>; + input; + }; + + board-rev-id-1 { + gpio-hog; + gpios = <RK_PD6 GPIO_ACTIVE_HIGH>; + input; + }; +}; + +&int_hub { + compatible = "usb-hub"; + usb,device-class = <USB_CLASS_HUB>; +}; + +&pcie_prst { + rockchip,pins = + <2 RK_PD4 RK_FUNC_GPIO &pcfg_output_low>; +}; + +&pcie_pwr_en { + rockchip,pins = + <1 RK_PD0 RK_FUNC_GPIO &pcfg_output_low>; +}; + +&pinctrl { + usb { + usb_mux_hs: usb-mux-hs { + rockchip,pins = + <1 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + usb_mux_oe: usb-mux-oe { + rockchip,pins = + <1 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&spi1 { + spiflash: flash@0 { + compatible = "jedec,spi-nor"; + reg = <0x0>; + spi-max-frequency = <25000000>; + status = "okay"; + m25p,fast-read; + u-boot,dm-pre-reloc; + }; +}; + +&vdd_center { + regulator-min-microvolt = <950000>; + regulator-max-microvolt = <950000>; + regulator-init-microvolt = <950000>; +}; + +&vdd_log { + regulator-init-microvolt = <900000>; +}; diff --git a/arch/arm/dts/rk3399-kobol-helios64.dts b/arch/arm/dts/rk3399-kobol-helios64.dts new file mode 100644 index 0000000000..66c725a342 --- /dev/null +++ b/arch/arm/dts/rk3399-kobol-helios64.dts @@ -0,0 +1,372 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2020 Aditya Prayoga aditya@kobol.io + */ + +/* + * The Kobol Helios64 is a board designed to operate as a NAS and optionally + * ships with an enclosing that can host five 2.5" hard disks. + * + * See https://wiki.kobol.io/helios64/intro/ for further details. + */ + +/dts-v1/; +#include "rk3399.dtsi" +#include "rk3399-opp.dtsi" + +/ { + model = "Kobol Helios64"; + compatible = "kobol,helios64", "rockchip,rk3399"; + + avdd_1v8_s0: avdd-1v8-s0 { + compatible = "regulator-fixed"; + regulator-name = "avdd_1v8_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc3v3_sys_s3>; + }; + + clkin_gmac: external-gmac-clock { + compatible = "fixed-clock"; + clock-frequency = <125000000>; + clock-output-names = "clkin_gmac"; + #clock-cells = <0>; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&sys_grn_led_on &sys_red_led_on>; + + led-0 { + label = "helios64:green:status"; + gpios = <&gpio0 RK_PB4 GPIO_ACTIVE_HIGH>; + default-state = "on"; + }; + + led-1 { + label = "helios64:red:fault"; + gpios = <&gpio0 RK_PB5 GPIO_ACTIVE_HIGH>; + default-state = "keep"; + }; + }; + + vcc1v8_sys_s0: vcc1v8-sys-s0 { + compatible = "regulator-fixed"; + regulator-name = "vcc1v8_sys_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc1v8_sys_s3>; + }; + + vcc3v0_sd: vcc3v0-sd { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio0 RK_PA1 GPIO_ACTIVE_HIGH>; + regulator-name = "vcc3v0_sd"; + regulator-boot-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc0_pwr_h>; + vin-supply = <&vcc3v3_sys_s3>; + }; + + vcc3v3_sys_s3: vcc_lan: vcc3v3-sys-s3 { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_sys_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc5v0_sys>; + + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc5v0_sys: vcc5v0-sys { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc12v_dcin_bkup>; + + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc12v_dcin: vcc12v-dcin { + compatible = "regulator-fixed"; + regulator-name = "vcc12v_dcin"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + }; + + vcc12v_dcin_bkup: vcc12v-dcin-bkup { + compatible = "regulator-fixed"; + regulator-name = "vcc12v_dcin_bkup"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + vin-supply = <&vcc12v_dcin>; + }; +}; + +/* + * The system doesn't run stable with cpu freq enabled, so disallow the lower + * frequencies until this problem is properly understood and resolved. + */ +&cluster0_opp { + /delete-node/ opp00; + /delete-node/ opp01; + /delete-node/ opp02; + /delete-node/ opp03; + /delete-node/ opp04; +}; + +&cluster1_opp { + /delete-node/ opp00; + /delete-node/ opp01; + /delete-node/ opp02; + /delete-node/ opp03; + /delete-node/ opp04; + /delete-node/ opp05; + /delete-node/ opp06; +}; + +&cpu_b0 { + cpu-supply = <&vdd_cpu_b>; +}; + +&cpu_b1 { + cpu-supply = <&vdd_cpu_b>; +}; + +&cpu_l0 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l1 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l2 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l3 { + cpu-supply = <&vdd_cpu_l>; +}; + +&emmc_phy { + status = "okay"; +}; + +&gmac { + assigned-clock-parents = <&clkin_gmac>; + assigned-clocks = <&cru SCLK_RMII_SRC>; + clock_in_out = "input"; + phy-mode = "rgmii"; + phy-supply = <&vcc_lan>; + pinctrl-names = "default"; + pinctrl-0 = <&rgmii_pins &gphy_reset>; + rx_delay = <0x20>; + tx_delay = <0x28>; + snps,reset-active-low; + snps,reset-delays-us = <0 10000 50000>; + snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; + status = "okay"; +}; + +&i2c0 { + clock-frequency = <400000>; + i2c-scl-rising-time-ns = <168>; + i2c-scl-falling-time-ns = <4>; + status = "okay"; + + rk808: pmic@1b { + compatible = "rockchip,rk808"; + reg = <0x1b>; + interrupt-parent = <&gpio0>; + interrupts = <10 IRQ_TYPE_LEVEL_LOW>; + clock-output-names = "xin32k", "rk808-clkout2"; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_int_l>; + vcc1-supply = <&vcc5v0_sys>; + vcc2-supply = <&vcc5v0_sys>; + vcc3-supply = <&vcc5v0_sys>; + vcc4-supply = <&vcc5v0_sys>; + vcc6-supply = <&vcc5v0_sys>; + vcc7-supply = <&vcc5v0_sys>; + vcc8-supply = <&vcc3v3_sys_s3>; + vcc9-supply = <&vcc5v0_sys>; + vcc10-supply = <&vcc5v0_sys>; + vcc11-supply = <&vcc5v0_sys>; + vcc12-supply = <&vcc3v3_sys_s3>; + vddio-supply = <&vcc3v0_s3>; + wakeup-source; + #clock-cells = <1>; + + regulators { + vdd_cpu_l: DCDC_REG2 { + regulator-name = "vdd_cpu_l"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc1v8_sys_s3: DCDC_REG4 { + regulator-name = "vcc1v8_sys_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc_sdio_s0: LDO_REG4 { + regulator-name = "vcc_sdio_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3000000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3000000>; + }; + }; + + vcc3v0_s3: LDO_REG8 { + regulator-name = "vcc3v0_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3000000>; + }; + }; + }; + }; + + vdd_cpu_b: regulator@40 { + compatible = "silergy,syr827"; + reg = <0x40>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_cpu_b"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1500000>; + regulator-ramp-delay = <1000>; + vin-supply = <&vcc5v0_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; +}; + +&i2c2 { + clock-frequency = <400000>; + i2c-scl-rising-time-ns = <160>; + i2c-scl-falling-time-ns = <30>; + status = "okay"; + + temp@4c { + compatible = "national,lm75"; + reg = <0x4c>; + }; +}; + +&io_domains { + audio-supply = <&vcc1v8_sys_s0>; + bt656-supply = <&vcc1v8_sys_s0>; + gpio1830-supply = <&vcc3v0_s3>; + sdmmc-supply = <&vcc_sdio_s0>; + status = "okay"; +}; + +&pinctrl { + gmac { + gphy_reset: gphy-reset { + rockchip,pins = <3 RK_PB7 RK_FUNC_GPIO &pcfg_output_low>; + }; + }; + + leds { + sys_grn_led_on: sys-grn-led-on { + rockchip,pins = <0 RK_PB4 RK_FUNC_GPIO &pcfg_pull_down>; + }; + + sys_red_led_on: sys-red-led-on { + rockchip,pins = <0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_down>; + }; + }; + + pmic { + pmic_int_l: pmic-int-l { + rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + vcc3v0-sd { + sdmmc0_pwr_h: sdmmc0-pwr-h { + rockchip,pins = <0 RK_PA1 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; +}; + +&pmu_io_domains { + pmu1830-supply = <&vcc3v0_s3>; + status = "okay"; +}; + +&sdhci { + bus-width = <8>; + mmc-hs200-1_8v; + non-removable; + vqmmc-supply = <&vcc1v8_sys_s0>; + status = "okay"; +}; + +&sdmmc { + bus-width = <4>; + cap-sd-highspeed; + cd-gpios = <&gpio0 RK_PA7 GPIO_ACTIVE_LOW>; + disable-wp; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_bus4>; + vmmc-supply = <&vcc3v0_sd>; + vqmmc-supply = <&vcc_sdio_s0>; + status = "okay"; +}; + +&uart2 { + status = "okay"; +}; diff --git a/arch/arm/mach-rockchip/rk3399/Kconfig b/arch/arm/mach-rockchip/rk3399/Kconfig index 17628f9171..7890bafe56 100644 --- a/arch/arm/mach-rockchip/rk3399/Kconfig +++ b/arch/arm/mach-rockchip/rk3399/Kconfig @@ -28,6 +28,22 @@ config TARGET_PINEBOOK_PRO_RK3399 with 4Gb RAM, onboard eMMC, USB-C, a USB3 and USB2 port, 1920*1080 screen and all the usual laptop features.
+config TARGET_HELIOS64 + bool "Kobol Innovations Helios64" + select BOARD_LATE_INIT + help + Helios64 is a Network Attached Storage board based on Rockchip RK3399. + + Key features of the Helios64 include: + * on-board PCIe to 5 Ports SATA Controller JMB585 + * on-board USB 3.0 hub (3x USB 3.0 host) + * USB Type-C (Support DisplayPort Alt Mode) + * on-board 1 Gigabit Ethernet + * on-board 2.5 Gigabit Ethernet (Realtek RTL8156) + * on-board eMMC + * on-board LPDDR4 + * SPI, I2C, UART, GPIO + config TARGET_PUMA_RK3399 bool "Theobroma Systems RK3399-Q7 (Puma)" help @@ -153,6 +169,7 @@ endif # BOOTCOUNT_LIMIT
source "board/firefly/roc-pc-rk3399/Kconfig" source "board/google/gru/Kconfig" +source "board/kobol/helios64/Kconfig" source "board/pine64/pinebook-pro-rk3399/Kconfig" source "board/pine64/rockpro64_rk3399/Kconfig" source "board/rockchip/evb_rk3399/Kconfig" diff --git a/board/kobol/helios64/Kconfig b/board/kobol/helios64/Kconfig new file mode 100644 index 0000000000..644cdbd8f3 --- /dev/null +++ b/board/kobol/helios64/Kconfig @@ -0,0 +1,24 @@ +if TARGET_HELIOS64 + +config SYS_BOARD + default "helios64" + +config SYS_VENDOR + default "kobol" + +config SYS_CONFIG_NAME + default "helios64" + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + +config ENV_SECT_SIZE + default 0x1000 if ENV_IS_IN_SPI_FLASH + +config ENV_SIZE + default 0x8000 + +config ENV_OFFSET + default 0x460000 if ENV_IS_IN_SPI_FLASH + +endif diff --git a/board/kobol/helios64/MAINTAINERS b/board/kobol/helios64/MAINTAINERS new file mode 100644 index 0000000000..646644d485 --- /dev/null +++ b/board/kobol/helios64/MAINTAINERS @@ -0,0 +1,6 @@ +HELIOS64 BOARD +M: Christian Glombek lorbus@fedoraproject.org +S: Maintained +F: board/kobol/helios64/ +F: include/configs/helios64.h +F: configs/helios64_defconfig diff --git a/board/kobol/helios64/Makefile b/board/kobol/helios64/Makefile new file mode 100644 index 0000000000..ab34245a6d --- /dev/null +++ b/board/kobol/helios64/Makefile @@ -0,0 +1,5 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2020 Aditya Prayoga aditya@kobol.io + +obj-y := helios64.o sys_otp.o diff --git a/board/kobol/helios64/helios64.c b/board/kobol/helios64/helios64.c new file mode 100644 index 0000000000..86349339fb --- /dev/null +++ b/board/kobol/helios64/helios64.c @@ -0,0 +1,304 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2020 Aditya Prayoga aditya@kobol.io + */ + +#include <common.h> +#include <dm.h> +#include <env.h> +#include <log.h> +#include <led.h> +#include <pci.h> +#include <power/regulator.h> +#include <scsi.h> +#include <spl_gpio.h> +#include <syscon.h> +#include <usb.h> +#include <linux/delay.h> +#include <asm/io.h> +#include <asm/gpio.h> +#include <asm/arch-rockchip/clock.h> +#include <asm/arch-rockchip/gpio.h> +#include <asm/arch-rockchip/grf_rk3399.h> +#include <asm/arch-rockchip/hardware.h> +#include <asm/arch-rockchip/misc.h> +#include <asm/arch-rockchip/periph.h> + +#include "sys_otp.h" + +#ifndef CONFIG_TPL_BUILD +int board_early_init_f(void) +{ +#ifdef CONFIG_SPL_BUILD +#define GPIO0_BASE 0xff720000 +#define GRF_BASE 0xff770000 + struct rk3399_grf_regs * const grf = (void *)GRF_BASE; + struct rockchip_gpio_regs * const gpio = (void *)GPIO0_BASE; + + /* Turn ON status LED. At this stage, FDT & DM is not initialized yet */ + spl_gpio_output(gpio, GPIO(BANK_B, 4), 1); +#endif + return 0; +} +#endif + +#ifndef CONFIG_SPL_BUILD +int board_early_init_r(void) +{ + read_otp_data(); + return 0; +} +#endif + +#ifdef CONFIG_MISC_INIT_R +#define GRF_IO_VSEL_BT565_SHIFT 0 +#define GRF_IO_VSEL_AUDIO_SHIFT 1 +#define GRF_IO_VSEL_SDMMC_SHIFT 2 +#define GRF_IO_VSEL_GPIO1830_SHIFT 3 + +#define PMUGRF_CON0_VSEL_SHIFT 8 +#define PMUGRF_CON0_PMU1830_VOL_SHIFT 9 +static void setup_iodomain(void) +{ + struct rk3399_grf_regs *grf = + syscon_get_first_range(ROCKCHIP_SYSCON_GRF); + struct rk3399_pmugrf_regs *pmugrf = + syscon_get_first_range(ROCKCHIP_SYSCON_PMUGRF); + + /* BT565 is in 1.8v domain */ + rk_setreg(&grf->io_vsel, 1 << GRF_IO_VSEL_BT565_SHIFT); + + /* AUDIO is in 1.8v domain */ + rk_setreg(&grf->io_vsel, 1 << GRF_IO_VSEL_AUDIO_SHIFT); + + /* SDMMC is in 3.0v domain */ + rk_setreg(&grf->io_vsel, 0 << GRF_IO_VSEL_SDMMC_SHIFT); + + /* GPIO1830 is in 3.0v domain */ + rk_setreg(&grf->io_vsel, 0 << GRF_IO_VSEL_GPIO1830_SHIFT); + + /* Set GPIO1 1.8v/3.0v source select to PMU1830_VOL */ + rk_setreg(&pmugrf->soc_con0, 1 << PMUGRF_CON0_VSEL_SHIFT); + rk_setreg(&pmugrf->soc_con0, 0 << PMUGRF_CON0_PMU1830_VOL_SHIFT); +} + +/* + * Swap mmc0 and mmc1 in boot_targets if booted from SD-Card. + * + * If bootsource is uSD-card we can assume that we want to use the + * SD-Card instead of the eMMC as first boot_target for distroboot. + * We only want to swap the defaults and not any custom environment a + * user has set. We exit early if a changed boot_targets environment + * is detected. + */ +static int setup_boottargets(void) +{ + const char *boot_device = + ofnode_read_chosen_string("u-boot,spl-boot-device"); + char *env_default, *env; + + if (!boot_device) { + debug("%s: /chosen/u-boot,spl-boot-device not set\n", + __func__); + return -1; + } + debug("%s: booted from %s\n", __func__, boot_device); + + env_default = env_get_default("boot_targets"); + env = env_get("boot_targets"); + if (!env) { + debug("%s: boot_targets does not exist\n", __func__); + return -1; + } + debug("%s: boot_targets current: %s - default: %s\n", + __func__, env, env_default); + + if (strcmp(env_default, env) != 0) { + debug("%s: boot_targets not default, don't change it\n", + __func__); + return 0; + } + + /* + * Only run, if booting from mmc1 (i.e. /mmc@fe320000) and + * only consider cases where the default boot-order first + * tries to boot from mmc0 (eMMC) and then from mmc1 + * (i.e. external SD). + * + * In other words: the SD card will be moved to earlier in the + * order, if U-Boot was also loaded from the SD-card. + */ + if (!strcmp(boot_device, "/mmc@fe320000")) { + char *mmc0, *mmc1; + + debug("%s: booted from SD-Card\n", __func__); + mmc0 = strstr(env, "mmc0"); + mmc1 = strstr(env, "mmc1"); + + if (!mmc0 || !mmc1) { + debug("%s: only one mmc boot_target found\n", __func__); + return -1; + } + + /* + * If mmc0 comes first in the boot order, we need to change + * the strings to make mmc1 first. + */ + if (mmc0 < mmc1) { + mmc0[3] = '1'; + mmc1[3] = '0'; + debug("%s: set boot_targets to: %s\n", __func__, env); + env_set("boot_targets", env); + } + } + + return 0; +} + +static void setup_leds(void) +{ + struct udevice *dev; + + led_get_by_label("helios64::status", &dev); + led_set_state(dev, LEDST_OFF); + mdelay(250); + led_set_state(dev, LEDST_ON); +} + +int misc_init_r(void) +{ + const u32 cpuid_offset = 0x7; + const u32 cpuid_length = 0x10; + u8 cpuid[cpuid_length]; + int ret; + + setup_iodomain(); + set_board_info(); + + ret = rockchip_cpuid_from_efuse(cpuid_offset, cpuid_length, cpuid); + if (ret) + return ret; + + ret = rockchip_cpuid_set(cpuid, cpuid_length); + if (ret) + return ret; + + if (mac_read_from_otp()) + ret = rockchip_setup_macaddr(); + + setup_boottargets(); + setup_leds(); + + return ret; +} +#endif + +#ifdef CONFIG_ROCKCHIP_ADVANCED_RECOVERY +void rockchip_prepare_download_mode(void) +{ + struct gpio_desc *enable, *mux; + + if (gpio_hog_lookup_name("USB_MUX_OE#", &enable)) { + debug("Fail to get USB_MUX_OE\n"); + return; + } + + if (gpio_hog_lookup_name("USB_MUX_HS", &mux)) { + debug("Fail to get USB_MUX_HS\n"); + return; + } + + dm_gpio_set_value(enable, 0); + mdelay(100); + dm_gpio_set_value(mux, 1); + mdelay(100); + dm_gpio_set_value(enable, 1); +} +#endif + +#ifdef CONFIG_LAST_STAGE_INIT +static void auto_power_enable(void) +{ + struct gpio_desc *enable, *clock; + + if (gpio_hog_lookup_name("AUTO_ON_EN_D", &enable)) { + debug("Fail to get AUTO_ON_EN_D\n"); + return; + } + + if (gpio_hog_lookup_name("AUTO_ON_EN_CLK", &clock)) { + debug("Fail to get AUTO_ON_EN_CLK\n"); + return; + } + + dm_gpio_set_value(enable, 1); + dm_gpio_set_value(clock, 1); + mdelay(10); + dm_gpio_set_value(clock, 0); +} + +static void sata_power_enable(void) +{ + struct udevice *rail_a, *rail_b; + int ret; + + ret = regulator_get_by_platname("power_hdd_a", &rail_a); + if (!ret) { + ret = regulator_set_enable(rail_a, true); + if (!ret) + mdelay(10000); + } + + ret = regulator_get_by_platname("power_hdd_b", &rail_b); + if (!ret) + ret = regulator_set_enable(rail_b, true); + +} + +int last_stage_init(void) +{ + auto_power_enable(); + sata_power_enable(); + +#ifdef CONFIG_PCI + scsi_scan(true); +#endif + + return 0; +} +#endif + +#if defined(CONFIG_DISPLAY_BOARDINFO_LATE) +int checkboard(void) +{ + int major, minor; + + printf("Revision: "); + + if (!get_revision(&major, &minor)) + printf("%i.%i - %s\n", major, minor, get_variant()); + else + printf("UNKNOWN\n"); + + return 0; +} +#endif + +#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) +int ft_board_setup(void *blob, struct bd_info *bd) +{ + char *env; + + env = env_get("board_rev"); + if (env) + fdt_setprop_string(blob, fdt_path_offset(blob, "/"), + "kobol,board-rev", env); + + env = env_get("cpuid#"); + if (env) + fdt_setprop_string(blob, fdt_path_offset(blob, "/"), + "kobol,cpu-id", env); + + return 0; +} +#endif diff --git a/board/kobol/helios64/sys_otp.c b/board/kobol/helios64/sys_otp.c new file mode 100644 index 0000000000..8c20693c0e --- /dev/null +++ b/board/kobol/helios64/sys_otp.c @@ -0,0 +1,250 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ + +#include <linux/types.h> +#include <dm.h> +#include <spi.h> +#include <log.h> +#include <net.h> +#include <u-boot/crc.h> + +#include "sys_otp.h" + +#define OTP_DEVICE_BUS 0 +#define OTP_DEVICE_CS 0 +#define MAX_NUM_PORTS 2 + +enum board_variant { + BOARD_VARIANT_INVALID = 0, + BOARD_VARIANT_ENG_SAMPLE, + BOARD_VARIANT_4G_PROD_NO_ECC, + BOARD_VARIANT_MAX +}; + +struct __attribute__ ((__packed__)) otp_data_t { + u8 magic[8]; + u8 part_num[16]; + u8 variant; + u8 revision; + u8 serial_num[6]; + u8 mfg_year[2]; + u8 mfg_month; + u8 mfg_day; + u8 mac_addr[MAX_NUM_PORTS][6]; + u8 reserved[204]; + u32 checksum; +} otp; + +static struct spi_slave *slave; +static int has_been_read = 0; +static int data_valid = 0; + +static inline int is_data_valid(void) +{ + return data_valid; +} + +static inline int is_valid_header(void) +{ + if ((otp.magic[0] == 'H') || (otp.magic[1] == '6') || + (otp.magic[2] == '4') || (otp.magic[3] == 'N') || + (otp.magic[4] == 'P') || (otp.magic[5] == 'V') || + (otp.magic[6] == '1') || (otp.magic[7] == 0)) + + return 1; + + return 0; +} + +static int init_system_otp(int bus, int cs) +{ + int ret; + char name[30], *str; + struct udevice *dev; + + snprintf(name, sizeof(name), "generic_%d:%d", bus, cs); + str = strdup(name); + if (!str) + return -ENOMEM; + ret = spi_get_bus_and_cs(bus, cs, 25000000, CONFIG_DEFAULT_SPI_MODE, "spi_generic_drv", + str, &dev, &slave); + return ret; +} + +#ifdef DEBUG +/** + * show_otp_data - display the contents of the OTP register + */ +static void show_otp_data(void) +{ + u32 i; + u32 crc; + + const char* var_str[BOARD_VARIANT_MAX] = { + "Invalid variant", + "Engineering Sample", + "Production - 4GB non ECC" + }; + + printf("\n"); + printf("Register dump: (%lu bytes)\n", sizeof(otp)); + for (i = 0; i < sizeof(otp); i++) { + if ((i % 16) == 0) + printf("%02X: ", i); + printf("%02X ", ((u8 *)&otp)[i]); + if (((i % 16) == 15) || (i == sizeof(otp) - 1)) + printf("\n"); + } + + if (!is_valid_header()) + return; + + printf("Part Number: %s\n", otp.part_num); + printf("Variant: %s\n", var_str[otp.variant]); + printf("Revision: %x.%x\n", (otp.revision & 0xf0) >> 4, otp.revision & 0x0f); + printf("Serial Number: %012llx\n", *((uint64_t*) otp.serial_num) & + 0xFFFFFFFFFFFF); + printf("Manufacturing Date: %02X-%02X-%04X (DD-MM-YYYY)\n", otp.mfg_day, + otp.mfg_month, *(u16*) otp.mfg_year); + + printf("1GbE MAC Address: %02X:%02X:%02X:%02X:%02X:%02X\n", + otp.mac_addr[0][0], otp.mac_addr[0][1], otp.mac_addr[0][2], + otp.mac_addr[0][3], otp.mac_addr[0][4], otp.mac_addr[0][5]); + + printf("2.5GbE MAC Address: %02X:%02X:%02X:%02X:%02X:%02X\n", + otp.mac_addr[1][0], otp.mac_addr[1][1], otp.mac_addr[1][2], + otp.mac_addr[1][3], otp.mac_addr[1][4], otp.mac_addr[1][5]); + + crc = crc32(0, (void *)&otp, sizeof(otp) - 4); + + if (crc == le32_to_cpu(otp.checksum)) + printf("CRC: %08x\n\n", le32_to_cpu(otp.checksum)); + else + printf("CRC: %08x (should be %08x)\n\n", + le32_to_cpu(otp.checksum), crc); + +} +#endif + +int read_otp_data(void) +{ + int ret; + u8 dout[5]; + + if (has_been_read) { + if (is_data_valid()) + return 0; + else + goto data_invalid; + } + + ret = init_system_otp(OTP_DEVICE_BUS, OTP_DEVICE_CS); + if (ret) + return ret; + + ret = spi_claim_bus(slave); + if (ret) { + debug("SPI: Failed to claim SPI bus: %d\n", ret); + return ret; + } + + dout[0] = 0x48; + dout[1] = 0x00; + dout[2] = 0x10; /* Security Register #1 */ + dout[3] = 0x00; + dout[4] = 0x00; /* Dummy Byte */ + + ret = spi_write_then_read(slave, dout, sizeof(dout), NULL, (u8 *)&otp, + sizeof(otp)); + + spi_release_bus(slave); +#ifdef DEBUG + show_otp_data(); +#endif + + has_been_read = (ret == 0) ? 1 : 0; + if (!is_valid_header()) + goto data_invalid; + + if (crc32(0, (void *)&otp, sizeof(otp) - 4) == + le32_to_cpu(otp.checksum)) + data_valid = 1; + + if (!is_data_valid()) + goto data_invalid; + + return 0; + +data_invalid: + printf("Invalid board ID data!\n"); + return -1; +} + +int get_revision(int *major, int *minor) +{ + if (!is_data_valid()) + return -1; + + *major = (otp.revision & 0xf0) >> 4; + *minor = otp.revision & 0x0f; + + return 0; +} + +const char *get_variant(void) +{ + const char* var_str[BOARD_VARIANT_MAX] = { + "Unknown", + "Engineering Sample", + "4GB non ECC" + }; + + if ((otp.variant < BOARD_VARIANT_ENG_SAMPLE) || + (otp.variant >= BOARD_VARIANT_MAX)) + return var_str[0]; + + return var_str[otp.variant]; +} + +void set_board_info(void) +{ + char env_str[13]; + + if (!is_data_valid()) + return; + + snprintf(env_str, sizeof(env_str), "%i.%i", (otp.revision & 0xf0) >> 4, otp.revision & 0x0f); + env_set("board_rev", env_str); + + sprintf(env_str, "%012llx", *((uint64_t*) otp.serial_num) & + 0xFFFFFFFFFFFF); + + env_set("serial#", env_str); +} + +int mac_read_from_otp(void) +{ + unsigned int i; + int ret; + + if (!is_data_valid()) + return -1; + + for (i = 0; i < MAX_NUM_PORTS; i++) { + char enetvar[9]; + + sprintf(enetvar, i ? "eth%daddr" : "ethaddr", i); + + if (!is_valid_ethaddr(otp.mac_addr[i])) { + debug("Not valid %s!\n", enetvar); + continue; + } + + /* Only initialize environment variables that are blank + * (i.e. have not yet been set) + */ + if (!env_get(enetvar)) + eth_env_set_enetaddr(enetvar, otp.mac_addr[i]); + } + + return ret; +} diff --git a/board/kobol/helios64/sys_otp.h b/board/kobol/helios64/sys_otp.h new file mode 100644 index 0000000000..48273d4a95 --- /dev/null +++ b/board/kobol/helios64/sys_otp.h @@ -0,0 +1,12 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ + +#ifndef __HELIOS64_SYS_OTP_H +#define __HELIOS64_SYS_OTP_H + +int read_otp_data(void); +void set_board_info(void); +int get_revision(int *major, int *minor); +const char *get_variant(void); +int mac_read_from_otp(void); + +#endif diff --git a/configs/helios64-rk3399_defconfig b/configs/helios64-rk3399_defconfig new file mode 100644 index 0000000000..3b4ed62ab6 --- /dev/null +++ b/configs/helios64-rk3399_defconfig @@ -0,0 +1,147 @@ +CONFIG_ARM=y +CONFIG_ARCH_ROCKCHIP=y +CONFIG_SYS_TEXT_BASE=0x00200000 +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_ENV_OFFSET=0x3F8000 +CONFIG_ROCKCHIP_RK3399=y +CONFIG_ROCKCHIP_ADVANCED_RECOVERY=y +CONFIG_ROCKCHIP_ADVANCED_RECOVERY_LED="helios64::status" +# CONFIG_ROCKCHIP_ADVANCED_RECOVERY_ROCKUSB is not set +CONFIG_TARGET_HELIOS64=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_DEBUG_UART_BASE=0xFF1A0000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI_SUPPORT=y +CONFIG_DEBUG_UART=y +CONFIG_AHCI=y +# CONFIG_ANDROID_BOOT_IMAGE is not set +CONFIG_OF_BOARD_SETUP=y +CONFIG_USE_PREBOOT=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-kobol-helios64.dtb" +CONFIG_MISC_INIT_R=y +CONFIG_VERSION_VARIABLE=y +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_BOARD_TYPES=y +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_LAST_STAGE_INIT=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_STACK_R=y +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 +CONFIG_SPL_I2C_SUPPORT=y +CONFIG_SPL_POWER_SUPPORT=y +CONFIG_SPL_SPI_LOAD=y +CONFIG_TPL=y +CONFIG_CMD_CONFIG=y +CONFIG_CMD_BOOTZ=y +# CONFIG_BOOTM_PLAN9 is not set +# CONFIG_BOOTM_RTEMS is not set +# CONFIG_BOOTM_VXWORKS is not set +CONFIG_CMD_BOOTEFI_HELLO=y +CONFIG_CMD_BOOTMENU=y +CONFIG_CRC32_VERIFY=y +CONFIG_CMD_MD5SUM=y +CONFIG_MD5SUM_VERIFY=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MX_CYCLIC=y +CONFIG_CMD_SHA1SUM=y +CONFIG_SHA1SUM_VERIFY=y +CONFIG_CMD_STRINGS=y +CONFIG_CMD_ADC=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_POWEROFF=y +CONFIG_CMD_READ=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +CONFIG_CMD_ROCKUSB=y +CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_EFIDEBUG=y +CONFIG_CMD_EXCEPTION=y +CONFIG_CMD_TIME=y +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_FS_UUID=y +CONFIG_PARTITION_TYPE_GUID=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIVE=y +CONFIG_DEFAULT_DEVICE_TREE="rk3399-kobol-helios64" +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_IP_DEFRAG=y +# CONFIG_DM_DEVICE_REMOVE is not set +CONFIG_SCSI_AHCI=y +CONFIG_AHCI_PCI=y +CONFIG_SPL_FIRMWARE=y +CONFIG_GPIO_HOG=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_DM_PCA953X=y +CONFIG_I2C_SET_DEFAULT_BUS_NUM=y +CONFIG_I2C_DEFAULT_BUS_NUMBER=0x8 +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_LED=y +CONFIG_LED_GPIO=y +CONFIG_MISC=y +CONFIG_ROCKCHIP_EFUSE=y +CONFIG_ROCKCHIP_OTP=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_PHY_REALTEK=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y +CONFIG_PHY_GIGE=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_RGMII=y +CONFIG_MII=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_PCI=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_TYPEC=y +CONFIG_DM_PMIC_FAN53555=y +CONFIG_PMIC_RK8XX=y +CONFIG_SPL_DM_REGULATOR=y +CONFIG_REGULATOR_PWM=y +CONFIG_SPL_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_SPL_DM_REGULATOR_GPIO=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_RAM_RK3399_LPDDR4=y +CONFIG_DM_RESET=y +CONFIG_DM_RNG=y +CONFIG_RNG_ROCKCHIP=y +CONFIG_SCSI=y +CONFIG_DM_SCSI=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_ROCKCHIP_SPI=y +CONFIG_SYSRESET=y +CONFIG_SYSRESET_SYSCON=y +CONFIG_DM_THERMAL=y +CONFIG_USB=y +# CONFIG_SPL_DM_USB is not set +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_USB_GADGET=y +CONFIG_USB_FUNCTION_ROCKUSB=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_RTL8152=y +CONFIG_SPL_TINY_MEMSET=y +CONFIG_ERRNO_STR=y +CONFIG_HEXDUMP=y diff --git a/include/configs/helios64.h b/include/configs/helios64.h new file mode 100644 index 0000000000..6fca9a6be0 --- /dev/null +++ b/include/configs/helios64.h @@ -0,0 +1,47 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2020 Aditya Prayoga aditya@kobol.io + */ + +#ifndef __HELIOS64_H +#define __HELIOS64_H + +#include <configs/rk3399_common.h> + +#define SDRAM_BANK_SIZE (2UL << 30) + +#if defined(CONFIG_ENV_IS_IN_MMC) + #define CONFIG_SYS_MMC_ENV_DEV 0 +#elif defined(CONFIG_ENV_IS_IN_SPI_FLASH) + #define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS + #define CONFIG_ENV_SPI_CS CONFIG_SF_DEFAULT_CS + #define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE + #define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED +#endif + + +#ifndef CONFIG_SPL_BUILD +#if CONFIG_IS_ENABLED(SCSI) + + #define CONFIG_SYS_SCSI_MAX_SCSI_ID 5 + #define CONFIG_SYS_SCSI_MAX_LUN 1 + #define CONFIG_SYS_SCSI_MAX_DEVICE (CONFIG_SYS_SCSI_MAX_SCSI_ID * \ + CONFIG_SYS_SCSI_MAX_LUN) + + #define BOOT_TARGET_SCSI(func) \ + func(SCSI, scsi, 0) +#else + #define BOOT_TARGET_SCSI(func) +#endif + +#undef BOOT_TARGET_DEVICES +#define BOOT_TARGET_DEVICES(func) \ + BOOT_TARGET_MMC(func) \ + BOOT_TARGET_USB(func) \ + BOOT_TARGET_SCSI(func) \ + BOOT_TARGET_PXE(func) \ + BOOT_TARGET_DHCP(func) + +#endif + +#endif
Uwe submitted this board last Thursday
Dennis
On Tue, Mar 2, 2021 at 10:46 AM Christian Glombek lorbus@fedoraproject.org wrote:
- Copyright (c) 2020 Aditya Prayoga aditya@kobol.io
aliases {
spi0 = &spi1;
spi1 = &spi2;
spi2 = &spi5;
ethernet0 = &gmac;
chosen {
config {
+&gpio1 {
usb-mux-hs {
gpio-hog;
output-low;
usb-mux-oe {
gpio-hog;
output-high;
soc-flash-wp {
gpio-hog;
output-low;
+&gpio2 {
sata-flash-wp {
gpio-hog;
output-high;
+&gpio4 {
auto-on-en-d {
gpio-hog;
output-low;
auto-on-en-clk {
gpio-hog;
output-low;
board-rev-id-0 {
gpio-hog;
input;
board-rev-id-1 {
gpio-hog;
input;
+&int_hub {
+&pcie_prst {
rockchip,pins =
+&pcie_pwr_en {
rockchip,pins =
+&pinctrl {
usb {
rockchip,pins =
rockchip,pins =
+&spi1 {
spiflash: flash@0 {
reg = <0x0>;
status = "okay";
m25p,fast-read;
+&vdd_center {
+&vdd_log {
- The Kobol Helios64 is a board designed to operate as a NAS and optionally
- ships with an enclosing that can host five 2.5" hard disks.
- See https://wiki.kobol.io/helios64/intro/ for further details.
regulator-boot-on;
#clock-cells = <0>;
leds {
led-0 {
led-1 {
regulator-boot-on;
enable-active-high;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
- The system doesn't run stable with cpu freq enabled, so disallow the lower
- frequencies until this problem is properly understood and resolved.
+&cluster0_opp {
+&cluster1_opp {
+&cpu_b0 {
+&cpu_b1 {
+&cpu_l0 {
+&cpu_l1 {
+&cpu_l2 {
+&cpu_l3 {
+&emmc_phy {
status = "okay";
+&gmac {
phy-mode = "rgmii";
rx_delay = <0x20>;
tx_delay = <0x28>;
status = "okay";
+&i2c0 {
status = "okay";
rk808: pmic@1b {
reg = <0x1b>;
wakeup-source;
#clock-cells = <1>;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
reg = <0x40>;
regulator-boot-on;
+&i2c2 {
status = "okay";
temp@4c {
reg = <0x4c>;
+&io_domains {
status = "okay";
+&pinctrl {
gmac {
leds {
pmic {
vcc3v0-sd {
+&pmu_io_domains {
status = "okay";
+&sdhci {
bus-width = <8>;
mmc-hs200-1_8v;
non-removable;
status = "okay";
+&sdmmc {
bus-width = <4>;
cap-sd-highspeed;
disable-wp;
status = "okay";
+&uart2 {
status = "okay";
help
* on-board eMMC
* on-board LPDDR4
+config SYS_BOARD
default "helios64"
+config SYS_VENDOR
default "kobol"
default "helios64"
def_bool y
+config ENV_SIZE
default 0x8000
+config ENV_OFFSET
- (C) Copyright 2020 Aditya Prayoga aditya@kobol.io
+} +#endif
read_otp_data();
+} +#endif
- Swap mmc0 and mmc1 in boot_targets if booted from SD-Card.
- If bootsource is uSD-card we can assume that we want to use the
- SD-Card instead of the eMMC as first boot_target for distroboot.
- We only want to swap the defaults and not any custom environment a
- user has set. We exit early if a changed boot_targets environment
- is detected.
if (!boot_device) {
__func__);
return -1;
if (!env) {
return -1;
__func__);
char *mmc0, *mmc1;
return -1;
if (mmc0 < mmc1) {
mmc0[3] = '1';
mmc1[3] = '0';
mdelay(250);
int ret;
setup_iodomain();
set_board_info();
if (ret)
return ret;
if (ret)
return ret;
setup_leds();
return ret;
+} +#endif
return;
return;
mdelay(100);
mdelay(100);
+} +#endif
return;
return;
mdelay(10);
int ret;
if (!ret) {
if (!ret)
mdelay(10000);
if (!ret)
+#ifdef CONFIG_PCI
scsi_scan(true);
+} +#endif
int major, minor;
else
+} +#endif
char *env;
if (env)
if (env)
BOARD_VARIANT_MAX
u8 magic[8];
u8 part_num[16];
u8 variant;
u8 revision;
u8 serial_num[6];
u8 mfg_year[2];
u8 mfg_month;
u8 mfg_day;
u8 reserved[204];
u32 checksum;
+} otp;
return data_valid;
return 1;
int ret;
str = strdup(name);
if (!str)
return -ENOMEM;
str, &dev, &slave);
return ret;
+#ifdef DEBUG +/**
- show_otp_data - display the contents of the OTP register
u32 i;
u32 crc;
"Invalid variant",
printf("\n");
if ((i % 16) == 0)
printf("\n");
return;
0xFFFFFFFFFFFF);
else
+} +#endif
int ret;
u8 dout[5];
else
goto data_invalid;
if (ret)
return ret;
if (ret) {
return ret;
dout[0] = 0x48;
dout[1] = 0x00;
dout[3] = 0x00;
sizeof(otp));
+#ifdef DEBUG
show_otp_data();
goto data_invalid;
data_valid = 1;
goto data_invalid;
+data_invalid:
return -1;
return -1;
"Unknown",
"4GB non ECC"
return var_str[0];
char env_str[13];
return;
0xFFFFFFFFFFFF);
unsigned int i;
int ret;
return -1;
char enetvar[9];
continue;
return ret;
func(SCSI, scsi, 0)
+#else
2.29.2
Oh, thanks for the pointer! I guess I should've had another look at the archive before posting the patch.
If you see this Uwe, thanks for taking it on :)
On Tue, Mar 2, 2021 at 7:27 PM Dennis Gilmore dgilmore@fedoraproject.org wrote:
Dennis
submitted there by
[1]
[2]
aliases {
spi0 = &spi1;
spi1 = &spi2;
spi2 = &spi5;
ethernet0 = &gmac;
chosen {
earlyprintk";
&sdmmc, &sdhci;
config {
+&gpio1 {
usb-mux-hs {
gpio-hog;
output-low;
usb-mux-oe {
gpio-hog;
output-high;
soc-flash-wp {
gpio-hog;
output-low;
+&gpio2 {
sata-flash-wp {
gpio-hog;
output-high;
+&gpio4 {
auto-on-en-d {
gpio-hog;
output-low;
auto-on-en-clk {
gpio-hog;
output-low;
board-rev-id-0 {
gpio-hog;
input;
board-rev-id-1 {
gpio-hog;
input;
+&int_hub {
+&pcie_prst {
rockchip,pins =
+&pcie_pwr_en {
rockchip,pins =
+&pinctrl {
usb {
rockchip,pins =
rockchip,pins =
+&spi1 {
spiflash: flash@0 {
reg = <0x0>;
status = "okay";
m25p,fast-read;
+&vdd_center {
+&vdd_log {
optionally
regulator-boot-on;
#clock-cells = <0>;
leds {
led-0 {
led-1 {
regulator-boot-on;
enable-active-high;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
lower
+&cluster0_opp {
+&cluster1_opp {
+&cpu_b0 {
+&cpu_b1 {
+&cpu_l0 {
+&cpu_l1 {
+&cpu_l2 {
+&cpu_l3 {
+&emmc_phy {
status = "okay";
+&gmac {
phy-mode = "rgmii";
rx_delay = <0x20>;
tx_delay = <0x28>;
status = "okay";
+&i2c0 {
status = "okay";
rk808: pmic@1b {
reg = <0x1b>;
wakeup-source;
#clock-cells = <1>;
regulators {
regulator-boot-on;
regulator-boot-on;
<1800000>;
regulator-boot-on;
<3000000>;
regulator-boot-on;
<3000000>;
reg = <0x40>;
regulator-boot-on;
+&i2c2 {
status = "okay";
temp@4c {
reg = <0x4c>;
+&io_domains {
status = "okay";
+&pinctrl {
gmac {
&pcfg_output_low>;
leds {
&pcfg_pull_down>;
&pcfg_pull_down>;
pmic {
&pcfg_pull_none>;
vcc3v0-sd {
&pcfg_pull_up>;
+&pmu_io_domains {
status = "okay";
+&sdhci {
bus-width = <8>;
mmc-hs200-1_8v;
non-removable;
status = "okay";
+&sdmmc {
bus-width = <4>;
cap-sd-highspeed;
disable-wp;
status = "okay";
+&uart2 {
status = "okay";
help
RK3399.
* on-board eMMC
* on-board LPDDR4
+config SYS_BOARD
default "helios64"
+config SYS_VENDOR
default "kobol"
default "helios64"
def_bool y
+config ENV_SIZE
default 0x8000
+config ENV_OFFSET
initialized yet */
+} +#endif
read_otp_data();
+} +#endif
- is detected.
if (!boot_device) {
__func__);
return -1;
if (!env) {
return -1;
__func__);
char *mmc0, *mmc1;
__func__);
return -1;
change
if (mmc0 < mmc1) {
mmc0[3] = '1';
mmc1[3] = '0';
env);
mdelay(250);
int ret;
setup_iodomain();
set_board_info();
cpuid);
if (ret)
return ret;
if (ret)
return ret;
setup_leds();
return ret;
+} +#endif
return;
return;
mdelay(100);
mdelay(100);
+} +#endif
return;
return;
mdelay(10);
int ret;
if (!ret) {
if (!ret)
mdelay(10000);
if (!ret)
+#ifdef CONFIG_PCI
scsi_scan(true);
+} +#endif
int major, minor;
else
+} +#endif
char *env;
if (env)
if (env)
BOARD_VARIANT_MAX
u8 magic[8];
u8 part_num[16];
u8 variant;
u8 revision;
u8 serial_num[6];
u8 mfg_year[2];
u8 mfg_month;
u8 mfg_day;
u8 reserved[204];
u32 checksum;
+} otp;
return data_valid;
return 1;
int ret;
str = strdup(name);
if (!str)
return -ENOMEM;
str, &dev, &slave);
return ret;
+#ifdef DEBUG +/**
u32 i;
u32 crc;
"Invalid variant",
printf("\n");
if ((i % 16) == 0)
printf("\n");
return;
0xFFFFFFFFFFFF);
otp.mfg_day,
otp.mac_addr[0][2],
otp.mac_addr[1][2],
else
+} +#endif
int ret;
u8 dout[5];
else
goto data_invalid;
if (ret)
return ret;
if (ret) {
return ret;
dout[0] = 0x48;
dout[1] = 0x00;
dout[3] = 0x00;
*)&otp,
sizeof(otp));
+#ifdef DEBUG
show_otp_data();
goto data_invalid;
data_valid = 1;
goto data_invalid;
+data_invalid:
return -1;
return -1;
"Unknown",
"4GB non ECC"
return var_str[0];
char env_str[13];
return;
0xFFFFFFFFFFFF);
unsigned int i;
int ret;
return -1;
char enetvar[9];
continue;
return ret;
func(SCSI, scsi, 0)
+#else
2.29.2
Hi Christian,
Thanks for your patch,
We need the dts from mainline kernel instead of github.
And you'd better split the dts and board support into different patches.
Thanks,
- Kever
- rk3399-kobol-helios64.dtb \ rk3399-khadas-edge.dtb \ rk3399-khadas-edge-captain.dtb \ rk3399-khadas-edge-v.dtb \
- aliases {
spi0 = &spi1;
spi1 = &spi2;
spi2 = &spi5;
ethernet0 = &gmac;
- chosen {
- config {
+&gpio1 {
- usb-mux-hs {
gpio-hog;
output-low;
- usb-mux-oe {
gpio-hog;
output-high;
- soc-flash-wp {
gpio-hog;
output-low;
+&gpio2 {
- sata-flash-wp {
gpio-hog;
output-high;
+&gpio4 {
- auto-on-en-d {
gpio-hog;
output-low;
- auto-on-en-clk {
gpio-hog;
output-low;
- board-rev-id-0 {
gpio-hog;
input;
- board-rev-id-1 {
gpio-hog;
input;
+&int_hub {
- compatible = "usb-hub";
- usb,device-class = <USB_CLASS_HUB>;
+&pcie_prst {
- rockchip,pins =
+&pcie_pwr_en {
- rockchip,pins =
+&pinctrl {
- usb {
rockchip,pins =
rockchip,pins =
+&spi1 {
- spiflash: flash@0 {
reg = <0x0>;
status = "okay";
m25p,fast-read;
+&vdd_center {
- regulator-min-microvolt = <950000>;
- regulator-max-microvolt = <950000>;
- regulator-init-microvolt = <950000>;
+&vdd_log {
- regulator-init-microvolt = <900000>;
- model = "Kobol Helios64";
- compatible = "kobol,helios64", "rockchip,rk3399";
- avdd_1v8_s0: avdd-1v8-s0 {
regulator-boot-on;
- clkin_gmac: external-gmac-clock {
#clock-cells = <0>;
- leds {
led-0 {
led-1 {
- vcc1v8_sys_s0: vcc1v8-sys-s0 {
regulator-boot-on;
- vcc3v0_sd: vcc3v0-sd {
enable-active-high;
regulator-boot-on;
- vcc3v3_sys_s3: vcc_lan: vcc3v3-sys-s3 {
regulator-boot-on;
- vcc5v0_sys: vcc5v0-sys {
regulator-boot-on;
- vcc12v_dcin: vcc12v-dcin {
regulator-boot-on;
- vcc12v_dcin_bkup: vcc12v-dcin-bkup {
regulator-boot-on;
+&cluster0_opp {
- /delete-node/ opp00;
- /delete-node/ opp01;
- /delete-node/ opp02;
- /delete-node/ opp03;
- /delete-node/ opp04;
+&cluster1_opp {
- /delete-node/ opp05;
- /delete-node/ opp06;
+&cpu_b0 {
- cpu-supply = <&vdd_cpu_b>;
+&cpu_b1 {
+&cpu_l0 {
- cpu-supply = <&vdd_cpu_l>;
+&cpu_l1 {
+&cpu_l2 {
+&cpu_l3 {
+&emmc_phy {
- status = "okay";
+&gmac {
- assigned-clock-parents = <&clkin_gmac>;
- assigned-clocks = <&cru SCLK_RMII_SRC>;
- clock_in_out = "input";
- phy-mode = "rgmii";
- phy-supply = <&vcc_lan>;
- pinctrl-names = "default";
- pinctrl-0 = <&rgmii_pins &gphy_reset>;
- rx_delay = <0x20>;
- tx_delay = <0x28>;
- snps,reset-active-low;
- snps,reset-delays-us = <0 10000 50000>;
- snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>;
- status = "okay";
+&i2c0 {
- clock-frequency = <400000>;
- i2c-scl-rising-time-ns = <168>;
- i2c-scl-falling-time-ns = <4>;
- status = "okay";
- rk808: pmic@1b {
reg = <0x1b>;
wakeup-source;
#clock-cells = <1>;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
- vdd_cpu_b: regulator@40 {
reg = <0x40>;
regulator-boot-on;
+&i2c2 {
- i2c-scl-rising-time-ns = <160>;
- i2c-scl-falling-time-ns = <30>;
- status = "okay";
- temp@4c {
reg = <0x4c>;
+&io_domains {
- audio-supply = <&vcc1v8_sys_s0>;
- bt656-supply = <&vcc1v8_sys_s0>;
- gpio1830-supply = <&vcc3v0_s3>;
- sdmmc-supply = <&vcc_sdio_s0>;
- status = "okay";
+&pinctrl {
- gmac {
- leds {
- pmic {
- vcc3v0-sd {
+&pmu_io_domains {
- pmu1830-supply = <&vcc3v0_s3>;
- status = "okay";
+&sdhci {
- bus-width = <8>;
- mmc-hs200-1_8v;
- non-removable;
- vqmmc-supply = <&vcc1v8_sys_s0>;
- status = "okay";
+&sdmmc {
- bus-width = <4>;
- cap-sd-highspeed;
- cd-gpios = <&gpio0 RK_PA7 GPIO_ACTIVE_LOW>;
- disable-wp;
- pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_bus4>;
- vmmc-supply = <&vcc3v0_sd>;
- vqmmc-supply = <&vcc_sdio_s0>;
- status = "okay";
+&uart2 {
- status = "okay";
- bool "Kobol Innovations Helios64"
- select BOARD_LATE_INIT
- help
* on-board eMMC
* on-board LPDDR4
- config TARGET_PUMA_RK3399 bool "Theobroma Systems RK3399-Q7 (Puma)" help
+config SYS_BOARD
- default "helios64"
+config SYS_VENDOR
- default "kobol"
- def_bool y
- default 0x1000 if ENV_IS_IN_SPI_FLASH
+config ENV_SIZE
- default 0x8000
+config ENV_OFFSET
- default 0x460000 if ENV_IS_IN_SPI_FLASH
- struct rk3399_grf_regs * const grf = (void *)GRF_BASE;
- struct rockchip_gpio_regs * const gpio = (void *)GPIO0_BASE;
- /* Turn ON status LED. At this stage, FDT & DM is not initialized yet */
- spl_gpio_output(gpio, GPIO(BANK_B, 4), 1);
+} +#endif
- read_otp_data();
+} +#endif
- struct rk3399_grf_regs *grf =
- struct rk3399_pmugrf_regs *pmugrf =
- /* BT565 is in 1.8v domain */
- rk_setreg(&grf->io_vsel, 1 << GRF_IO_VSEL_BT565_SHIFT);
- /* AUDIO is in 1.8v domain */
- rk_setreg(&grf->io_vsel, 1 << GRF_IO_VSEL_AUDIO_SHIFT);
- /* SDMMC is in 3.0v domain */
- rk_setreg(&grf->io_vsel, 0 << GRF_IO_VSEL_SDMMC_SHIFT);
- /* GPIO1830 is in 3.0v domain */
- rk_setreg(&grf->io_vsel, 0 << GRF_IO_VSEL_GPIO1830_SHIFT);
- /* Set GPIO1 1.8v/3.0v source select to PMU1830_VOL */
- rk_setreg(&pmugrf->soc_con0, 1 << PMUGRF_CON0_VSEL_SHIFT);
- rk_setreg(&pmugrf->soc_con0, 0 << PMUGRF_CON0_PMU1830_VOL_SHIFT);
- is detected.
- const char *boot_device =
- char *env_default, *env;
- if (!boot_device) {
__func__);
return -1;
- debug("%s: booted from %s\n", __func__, boot_device);
- env_default = env_get_default("boot_targets");
- env = env_get("boot_targets");
- if (!env) {
return -1;
- debug("%s: boot_targets current: %s - default: %s\n",
- if (strcmp(env_default, env) != 0) {
__func__);
- if (!strcmp(boot_device, "/mmc@fe320000")) {
char *mmc0, *mmc1;
return -1;
if (mmc0 < mmc1) {
mmc0[3] = '1';
mmc1[3] = '0';
- struct udevice *dev;
- led_get_by_label("helios64::status", &dev);
- led_set_state(dev, LEDST_OFF);
- mdelay(250);
- led_set_state(dev, LEDST_ON);
- const u32 cpuid_offset = 0x7;
- const u32 cpuid_length = 0x10;
- u8 cpuid[cpuid_length];
- int ret;
- setup_iodomain();
- set_board_info();
- ret = rockchip_cpuid_from_efuse(cpuid_offset, cpuid_length, cpuid);
- if (ret)
return ret;
- ret = rockchip_cpuid_set(cpuid, cpuid_length);
- if (ret)
return ret;
- if (mac_read_from_otp())
- setup_boottargets();
- setup_leds();
- return ret;
+} +#endif
- struct gpio_desc *enable, *mux;
- if (gpio_hog_lookup_name("USB_MUX_OE#", &enable)) {
return;
- if (gpio_hog_lookup_name("USB_MUX_HS", &mux)) {
return;
- dm_gpio_set_value(enable, 0);
- mdelay(100);
- dm_gpio_set_value(mux, 1);
- mdelay(100);
- dm_gpio_set_value(enable, 1);
+} +#endif
- struct gpio_desc *enable, *clock;
- if (gpio_hog_lookup_name("AUTO_ON_EN_D", &enable)) {
return;
- if (gpio_hog_lookup_name("AUTO_ON_EN_CLK", &clock)) {
return;
- dm_gpio_set_value(clock, 1);
- mdelay(10);
- dm_gpio_set_value(clock, 0);
- struct udevice *rail_a, *rail_b;
- int ret;
- ret = regulator_get_by_platname("power_hdd_a", &rail_a);
- if (!ret) {
if (!ret)
mdelay(10000);
- ret = regulator_get_by_platname("power_hdd_b", &rail_b);
- if (!ret)
- auto_power_enable();
- sata_power_enable();
+#ifdef CONFIG_PCI
- scsi_scan(true);
+} +#endif
- int major, minor;
- printf("Revision: ");
- if (!get_revision(&major, &minor))
- else
+} +#endif
- char *env;
- env = env_get("board_rev");
- if (env)
- env = env_get("cpuid#");
- if (env)
- BOARD_VARIANT_INVALID = 0,
- BOARD_VARIANT_ENG_SAMPLE,
- BOARD_VARIANT_4G_PROD_NO_ECC,
- BOARD_VARIANT_MAX
- u8 magic[8];
- u8 part_num[16];
- u8 variant;
- u8 revision;
- u8 serial_num[6];
- u8 mfg_year[2];
- u8 mfg_month;
- u8 mfg_day;
- u8 mac_addr[MAX_NUM_PORTS][6];
- u8 reserved[204];
- u32 checksum;
+} otp;
- return data_valid;
- if ((otp.magic[0] == 'H') || (otp.magic[1] == '6') ||
return 1;
- int ret;
- char name[30], *str;
- snprintf(name, sizeof(name), "generic_%d:%d", bus, cs);
- str = strdup(name);
- if (!str)
return -ENOMEM;
- ret = spi_get_bus_and_cs(bus, cs, 25000000, CONFIG_DEFAULT_SPI_MODE, "spi_generic_drv",
str, &dev, &slave);
- return ret;
+#ifdef DEBUG +/**
- u32 i;
- u32 crc;
- const char* var_str[BOARD_VARIANT_MAX] = {
"Invalid variant",
- printf("\n");
- printf("Register dump: (%lu bytes)\n", sizeof(otp));
- for (i = 0; i < sizeof(otp); i++) {
if ((i % 16) == 0)
printf("\n");
- if (!is_valid_header())
return;
- printf("Part Number: %s\n", otp.part_num);
- printf("Variant: %s\n", var_str[otp.variant]);
- printf("Revision: %x.%x\n", (otp.revision & 0xf0) >> 4, otp.revision & 0x0f);
- printf("Serial Number: %012llx\n", *((uint64_t*) otp.serial_num) &
0xFFFFFFFFFFFF);
- printf("Manufacturing Date: %02X-%02X-%04X (DD-MM-YYYY)\n", otp.mfg_day,
- printf("1GbE MAC Address: %02X:%02X:%02X:%02X:%02X:%02X\n",
- printf("2.5GbE MAC Address: %02X:%02X:%02X:%02X:%02X:%02X\n",
- crc = crc32(0, (void *)&otp, sizeof(otp) - 4);
- if (crc == le32_to_cpu(otp.checksum))
- else
+} +#endif
- int ret;
- u8 dout[5];
- if (has_been_read) {
else
goto data_invalid;
- ret = init_system_otp(OTP_DEVICE_BUS, OTP_DEVICE_CS);
- if (ret)
return ret;
- ret = spi_claim_bus(slave);
- if (ret) {
return ret;
- dout[0] = 0x48;
- dout[1] = 0x00;
- dout[2] = 0x10; /* Security Register #1 */
- dout[3] = 0x00;
- dout[4] = 0x00; /* Dummy Byte */
- ret = spi_write_then_read(slave, dout, sizeof(dout), NULL, (u8 *)&otp,
sizeof(otp));
- spi_release_bus(slave);
+#ifdef DEBUG
- show_otp_data();
- has_been_read = (ret == 0) ? 1 : 0;
goto data_invalid;
- if (crc32(0, (void *)&otp, sizeof(otp) - 4) ==
data_valid = 1;
- if (!is_data_valid())
goto data_invalid;
+data_invalid:
- printf("Invalid board ID data!\n");
- return -1;
return -1;
- *major = (otp.revision & 0xf0) >> 4;
- *minor = otp.revision & 0x0f;
"Unknown",
"4GB non ECC"
- if ((otp.variant < BOARD_VARIANT_ENG_SAMPLE) ||
return var_str[0];
- return var_str[otp.variant];
- char env_str[13];
return;
- snprintf(env_str, sizeof(env_str), "%i.%i", (otp.revision & 0xf0) >> 4, otp.revision & 0x0f);
- env_set("board_rev", env_str);
- sprintf(env_str, "%012llx", *((uint64_t*) otp.serial_num) &
0xFFFFFFFFFFFF);
- env_set("serial#", env_str);
- unsigned int i;
- int ret;
return -1;
- for (i = 0; i < MAX_NUM_PORTS; i++) {
char enetvar[9];
continue;
- return ret;
- #define CONFIG_SYS_MMC_ENV_DEV 0
- #define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS
- #define CONFIG_ENV_SPI_CS CONFIG_SF_DEFAULT_CS
- #define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE
- #define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED
- #define CONFIG_SYS_SCSI_MAX_SCSI_ID 5
- #define CONFIG_SYS_SCSI_MAX_LUN 1
- #define CONFIG_SYS_SCSI_MAX_DEVICE (CONFIG_SYS_SCSI_MAX_SCSI_ID * \
- #define BOOT_TARGET_SCSI(func) \
func(SCSI, scsi, 0)
+#else
- BOOT_TARGET_MMC(func) \
- BOOT_TARGET_USB(func) \
- BOOT_TARGET_SCSI(func) \
- BOOT_TARGET_PXE(func) \
- BOOT_TARGET_DHCP(func)
Christian Glombek
Dennis Gilmore
Kever Yang
