[PATCH v3 1/2] Revert "kbuild: remove unused dtc-version.sh script"
We need this to make building dtc optional. It makes no sense to build our own dtc if the system one works correctly.
This reverts commit ddb87a0b40262ff99d675e946f57427642303938.
Changes in v3: - Add an SPDX header and MAINTAINERS entry
MAINTAINERS | 1 + scripts/Kbuild.include | 1 + scripts/dtc-version.sh | 22 ++++++++++++++++++++++ 3 files changed, 24 insertions(+) create mode 100755 scripts/dtc-version.sh
diff --git a/MAINTAINERS b/MAINTAINERS index 67c96a60454..294d78b52e2 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -757,6 +757,7 @@ F: include/fdt* F: include/linux/libfdt* F: cmd/fdt.c F: common/fdt_support.c +F: scripts/dtc-version.sh
FREEBSD M: Rafal Jaworowski raj@semihalf.com diff --git a/scripts/Kbuild.include b/scripts/Kbuild.include index a745cc4fccd..09506cb9a7e 100644 --- a/scripts/Kbuild.include +++ b/scripts/Kbuild.include @@ -148,6 +148,7 @@ cc-ifversion = $(shell [ $(cc-version) $(1) $(2) ] && echo $(3) || echo $(4))
# added for U-Boot binutils-version = $(shell $(CONFIG_SHELL) $(srctree)/scripts/binutils-version.sh $(AS)) +dtc-version = $(shell $(CONFIG_SHELL) $(srctree)/scripts/dtc-version.sh $(DTC))
# cc-ldoption # Usage: ldflags += $(call cc-ldoption, -Wl$(comma)--hash-style=both) diff --git a/scripts/dtc-version.sh b/scripts/dtc-version.sh new file mode 100755 index 00000000000..bd4e818e92d --- /dev/null +++ b/scripts/dtc-version.sh @@ -0,0 +1,22 @@ +#!/bin/sh +# SPDX-License-Identifier: GPL-2.0+ +# +# dtc-version dtc-command +# +# Prints the dtc version of `dtc-command' in a canonical 6-digit form +# such as `010404' for dtc 1.4.4 +# + +dtc="$*" + +if [ ${#dtc} -eq 0 ]; then + echo "Error: No dtc command specified." + printf "Usage:\n\t$0 <dtc-command>\n" + exit 1 +fi + +MAJOR=$($dtc -v | head -1 | awk '{print $NF}' | cut -d . -f 1) +MINOR=$($dtc -v | head -1 | awk '{print $NF}' | cut -d . -f 2) +PATCH=$($dtc -v | head -1 | awk '{print $NF}' | cut -d . -f 3 | cut -d - -f 1) + +printf "%02d%02d%02d\n" $MAJOR $MINOR $PATCH
At present U-Boot always builds dtc if CONFIG_OF_CONTROL is defined, even when DTC is provided. The built dtc is not actually used, so this is a waste of time.
Update the Makefile logic to build dtc only if one is not provided to the build with the DTC variable. Add documentation to explain this.
This saves about 3.5 seconds of elapsed time on a clean build of sandbox_spl for me.
Changes in v3: - Use DTC_MIN_VERSION instead of hard-coding in the dtc-version call - Make the logic deterministic, failing if DTC is too old - Move version checks into Makefile to avoid the complicated version script - Add documentation - Update the commit message
Changes in v2: - Add a patch to bring back the dtc-version.sh script - Update the check to make sure libfdt is available if needed
Makefile | 30 ++++++++++++++++++++++++++++-- doc/build/gcc.rst | 21 +++++++++++++++++++++ dts/Kconfig | 4 ---- scripts/Makefile | 1 - scripts/dtc-version.sh | 7 ++++++- 5 files changed, 55 insertions(+), 8 deletions(-)
diff --git a/Makefile b/Makefile index 3014788e14e..74ca48c50c3 100644 --- a/Makefile +++ b/Makefile @@ -415,7 +415,13 @@ PERL = perl PYTHON ?= python PYTHON2 = python2 PYTHON3 ?= python3 -DTC ?= $(objtree)/scripts/dtc/dtc + +# The devicetree compiler and pylibfdt are automatically built unless DTC is +# provided. If DTC is provided, it is assumed the pylibfdt is available too. +DTC_INTREE := $(objtree)/scripts/dtc/dtc +DTC ?= $(DTC_INTREE) +DTC_MIN_VERSION := 010406 + CHECK = sparse
CHECKFLAGS := -D__linux__ -Dlinux -D__STDC__ -Dunix -D__unix__ \ @@ -1973,9 +1979,29 @@ endif
endif
+# Check dtc and pylibfdt, if DTC is provided, else build them PHONY += scripts_dtc scripts_dtc: scripts_basic - $(Q)$(MAKE) $(build)=scripts/dtc + $(Q)if test "$(DTC)" = "$(DTC_INTREE)"; then \ + $(MAKE) $(build)=scripts/dtc; \ + else \ + if ! $(DTC) -v >/dev/null; then \ + echo '*** Failed to check dtc version: $(DTC)'; \ + false; \ + else \ + if test "$(call dtc-version)" -lt $(DTC_MIN_VERSION); then \ + echo '*** Your dtc is too old, please upgrade to dtc $(DTC_MIN_VERSION) or newer'; \ + false; \ + else \ + if [ -n "$(CONFIG_PYLIBFDT)" ]; then \ + if ! echo "import libfdt" | $(PYTHON3) 2>/dev/null; then \ + echo '*** pylibfdt does not seem to be available with $(PYTHON3)'; \ + false; \ + fi; \ + fi; \ + fi; \ + fi; \ + fi
# --------------------------------------------------------------------------- quiet_cmd_cpp_lds = LDS $@ diff --git a/doc/build/gcc.rst b/doc/build/gcc.rst index 0cdc307d57b..6c4b4ad7a05 100644 --- a/doc/build/gcc.rst +++ b/doc/build/gcc.rst @@ -120,6 +120,27 @@ Further important build parameters are * O=<dir> - generate all output files in directory <dir>, including .config * V=1 - verbose build
+Devicetree compiler +~~~~~~~~~~~~~~~~~~~ + +Boards that use `CONFIG_OF_CONTROL` (i.e. almost all of them) need the +devicetree compiler (dtc). Those with `CONFIG_PYLIBFDT` need pylibfdt, a Python +library for accessing devicetree data. Suitable versions of these are included +in the U-Boot tree in `scripts/dtc` and built automatically as needed. + +To use the system versions of these, use the DTC parameter, for example + +.. code-block:: bash + + DTC=/usr/bin/dtc make + +In this case, dtc and pylibfdt are not built. The build checks that the version +of dtc is new enough. It also makes sure that pylibfdt is present, if needed +(see `scripts_dtc` in the Makefile). + +Note that the :doc:`tools` are always built with the included version of libfdt +so it is not possible to build U-Boot tools with a system libfdt, at present. + Other build targets ~~~~~~~~~~~~~~~~~~~
diff --git a/dts/Kconfig b/dts/Kconfig index dabe0080c1e..85d9d397e58 100644 --- a/dts/Kconfig +++ b/dts/Kconfig @@ -5,9 +5,6 @@ config SUPPORT_OF_CONTROL bool
-config DTC - bool - config PYLIBFDT bool
@@ -42,7 +39,6 @@ menu "Device Tree Control"
config OF_CONTROL bool "Run-time configuration via Device Tree" - select DTC select OF_LIBFDT if !OF_PLATDATA help This feature provides for run-time configuration of U-Boot diff --git a/scripts/Makefile b/scripts/Makefile index e7b353f77f4..cfe9fef8044 100644 --- a/scripts/Makefile +++ b/scripts/Makefile @@ -10,4 +10,3 @@ always := $(hostprogs-y)
# Let clean descend into subdirs subdir- += basic kconfig -subdir-$(CONFIG_DTC) += dtc diff --git a/scripts/dtc-version.sh b/scripts/dtc-version.sh index bd4e818e92d..bfb514e179f 100755 --- a/scripts/dtc-version.sh +++ b/scripts/dtc-version.sh @@ -10,11 +10,16 @@ dtc="$*"
if [ ${#dtc} -eq 0 ]; then - echo "Error: No dtc command specified." + echo "Error: No dtc command specified" printf "Usage:\n\t$0 <dtc-command>\n" exit 1 fi
+if ! which $dtc >/dev/null ; then + echo "Error: Cannot find dtc: $dtc" + exit 1 +fi + MAJOR=$($dtc -v | head -1 | awk '{print $NF}' | cut -d . -f 1) MINOR=$($dtc -v | head -1 | awk '{print $NF}' | cut -d . -f 2) PATCH=$($dtc -v | head -1 | awk '{print $NF}' | cut -d . -f 3 | cut -d - -f 1)
