[U-Boot-Users] [PATCH] ColdFire: Add dspi and serial flash support for MCF5445x
Signed-off-by: TsiChung Liew Tsi-Chung.Liew@freescale.com --- board/freescale/m54455evb/flash.c | 449 +++++++++++++++++++++++++++++++------ cpu/mcf5445x/Makefile | 2 +- cpu/mcf5445x/dspi.c | 73 ++++++ include/asm-m68k/coldfire/dspi.h | 10 + include/configs/M54455EVB.h | 28 +++- 5 files changed, 492 insertions(+), 70 deletions(-) create mode 100644 cpu/mcf5445x/dspi.c
diff --git a/board/freescale/m54455evb/flash.c b/board/freescale/m54455evb/flash.c index de2cca8..6b50e8d 100644 --- a/board/freescale/m54455evb/flash.c +++ b/board/freescale/m54455evb/flash.c @@ -95,6 +95,11 @@ typedef volatile unsigned char FLASH_PORT_WIDTHV; #define FLASH_28F256P30T 0x00BD /* Intel 28F256P30T ( 256M = 16M x 16 ) */ #define FLASH_28F256P30B 0x00BE /* Intel 28F256P30B ( 256M = 16M x 16 ) */
+#if defined(CONFIG_SERIAL_FLASH) && defined(CONFIG_CF_DSPI) +#define STM_ID_M25P16 0x20152015 +#define FLASH_M25P16 0x0055 +#endif + #define SYNC __asm__("nop")
/*----------------------------------------------------------------------- @@ -111,6 +116,12 @@ void inline spin_wheel(void); void flash_sync_real_protect(flash_info_t * info); uchar intel_sector_protected(flash_info_t * info, ushort sector);
+#if defined(CONFIG_SERIAL_FLASH) && defined(CONFIG_CF_DSPI) +int write_ser_data(flash_info_t * info, ulong dest, uchar * data, ulong cnt); +int serial_flash_read_status(int chipsel); +static int ser_flash_cs = 0; +#endif + flash_info_t flash_info[CFG_MAX_FLASH_BANKS];
ulong flash_init(void) @@ -119,6 +130,10 @@ ulong flash_init(void) ulong size = 0; ulong fbase = 0;
+#if defined(CONFIG_SERIAL_FLASH) && defined(CONFIG_CF_DSPI) + dspi_init(); +#endif + for (i = 0; i < CFG_MAX_FLASH_BANKS; i++) { memset(&flash_info[i], 0, sizeof(flash_info_t));
@@ -129,6 +144,11 @@ ulong flash_init(void) case 1: fbase = (ulong) CFG_FLASH1_BASE; break; +#if defined(CONFIG_SERIAL_FLASH) && defined(CONFIG_CF_DSPI) + case 2: + fbase = (ulong) CFG_FLASH2_BASE; + break; +#endif }
flash_get_size((FPWV *) fbase, &flash_info[i]); @@ -152,7 +172,6 @@ int flash_get_offsets(ulong base, flash_info_t * info) { int i, j, k; int sectors, bs, banks; - ulong start;
if ((info->flash_id & FLASH_VENDMASK) == FLASH_MAN_ATM) { int sect[] = CFG_ATMEL_SECT; @@ -196,6 +215,15 @@ int flash_get_offsets(ulong base, flash_info_t * info)
*addr16 = (FPW) INTEL_RESET; /* restore read mode */ } +#if defined(CONFIG_SERIAL_FLASH) && defined(CONFIG_CF_DSPI) + if ((info->flash_id & FLASH_VENDMASK) == FLASH_MAN_STM) { + info->start[0] = CFG_FLASH2_BASE; + for (k = 0, i = 0; i < CFG_STM_SECT; i++, k++) { + info->start[k + 1] = info->start[k] + CFG_STM_SECTSZ; + info->protect[k] = 0; + } + } +#endif
return ERR_OK; } @@ -211,6 +239,11 @@ void flash_print_info(flash_info_t * info) case FLASH_MAN_ATM: printf("ATMEL "); break; +#if defined(CONFIG_SERIAL_FLASH) && defined(CONFIG_CF_DSPI) + case FLASH_MAN_STM: + printf("ST "); + break; +#endif default: printf("Unknown Vendor "); break; @@ -221,8 +254,13 @@ void flash_print_info(flash_info_t * info) printf("AT49BV040A\n"); break; case FLASH_28F128J3A: - printf("Intel 28F128J3A\n"); + printf("28F128J3A\n"); + break; +#if defined(CONFIG_SERIAL_FLASH) && defined(CONFIG_CF_DSPI) + case FLASH_M25P16: + printf("M25P16\n"); break; +#endif default: printf("Unknown Chip Type\n"); return; @@ -267,6 +305,45 @@ ulong flash_get_size(FPWV * addr, flash_info_t * info) u16 value; int i;
+#if defined(CONFIG_SERIAL_FLASH) && defined(CONFIG_CF_DSPI) + if ((ulong) addr == CFG_FLASH2_BASE) { + int manufactId = 0; + int deviceId = 0; + + ser_flash_cs = 1; + + dspi_tx(ser_flash_cs, 0x80, SER_RDID); + dspi_tx(ser_flash_cs, 0x80, 0); + dspi_tx(ser_flash_cs, 0x80, 0); + dspi_tx(ser_flash_cs, 0x80, 0); + + dspi_rx(); + manufactId = dspi_rx(); + deviceId = dspi_rx() << 8; + deviceId |= dspi_rx(); + + dspi_tx(ser_flash_cs, 0x00, 0); + dspi_rx(); + + switch (manufactId) { + case (u8) STM_MANUFACT: + info->flash_id = FLASH_MAN_STM; + break; + } + + switch (deviceId) { + case (u16) STM_ID_M25P16: + info->flash_id += FLASH_M25P16; + break; + } + + info->sector_count = CFG_STM_SECT; + info->size = CFG_STM_SECT * CFG_STM_SECTSZ; + + return (info->size); + } +#endif + addr[FLASH_CYCLE1] = (FPWV) 0x00AA00AA; /* for Atmel, Intel ignores this */ addr[FLASH_CYCLE2] = (FPWV) 0x00550055; /* for Atmel, Intel ignores this */ addr[FLASH_CYCLE1] = (FPWV) 0x00900090; /* selects Intel or Atmel */ @@ -383,6 +460,21 @@ int flash_cmd_rd(volatile u16 * addr, int index) return (int)addr[index]; }
+#if defined(CONFIG_SERIAL_FLASH) && defined(CONFIG_CF_DSPI) +int serial_flash_read_status(int chipsel) +{ + u16 status; + + dspi_tx(chipsel, 0x80, SER_RDSR); + dspi_rx(); + + dspi_tx(chipsel, 0x00, 0); + status = dspi_rx(); + + return status; +} +#endif + /* * This function gets the u-boot flash sector protection status * (flash_info_t.protect[]) in sync with the sector protection @@ -462,8 +554,11 @@ int flash_erase(flash_info_t * info, int s_first, int s_last) { int flag, prot, sect; ulong type, start, last; - int rcode = 0, intel = 0; - + int rcode = 0, flashtype = 0; +#if defined(CONFIG_SERIAL_FLASH) && defined(CONFIG_CF_DSPI) + int count; + u16 status; +#endif if ((s_first < 0) || (s_first > s_last)) { if (info->flash_id == FLASH_UNKNOWN) printf("- missing\n"); @@ -474,19 +569,25 @@ int flash_erase(flash_info_t * info, int s_first, int s_last)
type = (info->flash_id & FLASH_VENDMASK);
- if (type != (FLASH_MAN_INTEL & FLASH_VENDMASK)) { - if (type != (FLASH_MAN_ATM & FLASH_VENDMASK)) { - type = (info->flash_id & FLASH_VENDMASK); - printf - ("Can't erase unknown flash type %08lx - aborted\n", - info->flash_id); - return 1; - } + switch (type) { + case FLASH_MAN_ATM: + flashtype = 1; + break; + case FLASH_MAN_INTEL: + flashtype = 2; + break; +#if defined(CONFIG_SERIAL_FLASH) && defined(CONFIG_CF_DSPI) + case FLASH_MAN_STM: + flashtype = 3; + break; +#endif + default: + type = (info->flash_id & FLASH_VENDMASK); + printf("Can't erase unknown flash type %08lx - aborted\n", + info->flash_id); + return 1; }
- if (type == FLASH_MAN_INTEL) - intel = 1; - prot = 0; for (sect = s_first; sect <= s_last; ++sect) { if (info->protect[sect]) { @@ -503,6 +604,51 @@ int flash_erase(flash_info_t * info, int s_first, int s_last) start = get_timer(0); last = start;
+#if defined(CONFIG_SERIAL_FLASH) && defined(CONFIG_CF_DSPI) + /* Perform bulk erase */ + if (flashtype == 3) { + if ((s_last - s_first) == (CFG_STM_SECT - 1)) { + if (prot == 0) { + dspi_tx(ser_flash_cs, 0x00, SER_WREN); + dspi_rx(); + + status = serial_flash_read_status(ser_flash_cs); + if (((status & 0x9C) != 0) + && ((status & 0x02) != 0x02)) { + printf("Can't erase flash\n"); + return 1; + } + + dspi_tx(ser_flash_cs, 0x00, SER_BULK_ERASE); + dspi_rx(); + + count = 0; + start = get_timer(0); + do { + status = + serial_flash_read_status + (ser_flash_cs); + + if (count++ > 0x10000) { + spin_wheel(); + count = 0; + } + + if (get_timer(start) > + CFG_FLASH_ERASE_TOUT) { + printf("Timeout\n"); + return 1; + } + } while (status & 0x01); + + printf("\b. done\n"); + return 0; + } else if (prot == CFG_STM_SECT) { + return 1; + } + } + } +#endif /* Start erase on unprotected sectors */ for (sect = s_first; sect <= s_last; sect++) { if (info->protect[sect] == 0) { /* not protected */ @@ -515,65 +661,116 @@ int flash_erase(flash_info_t * info, int s_first, int s_last) /* arm simple, non interrupt dependent timer */ start = get_timer(0);
- if (intel) { - *addr = (FPW) INTEL_READID; - min = addr[INTEL_CFI_TERB] & 0xff; - min = 1 << min; /* ms */ - min = (min / info->sector_count) * 1000; - - /* start erase block */ - *addr = (FPW) INTEL_CLEAR; /* clear status register */ - *addr = (FPW) INTEL_ERASE; /* erase setup */ - *addr = (FPW) INTEL_CONFIRM; /* erase confirm */ - - while ((*addr & (FPW) INTEL_FINISHED) != - (FPW) INTEL_FINISHED) { - - if (get_timer(start) > - CFG_FLASH_ERASE_TOUT) { - printf("Timeout\n"); - *addr = (FPW) INTEL_SUSERASE; /* suspend erase */ - *addr = (FPW) INTEL_RESET; /* reset to read mode */ - - rcode = 1; - break; + switch (flashtype) { + case 1: + { + FPWV *base; /* first address in bank */ + FPWV *atmeladdr; + + flag = disable_interrupts(); + + atmeladdr = (FPWV *) addr; /* concatenate to 8 bit */ + base = (FPWV *) (CFG_ATMEL_BASE); /* First sector */ + + base[FLASH_CYCLE1] = (u8) 0x00AA00AA; /* unlock */ + base[FLASH_CYCLE2] = (u8) 0x00550055; /* unlock */ + base[FLASH_CYCLE1] = (u8) 0x00800080; /* erase mode */ + base[FLASH_CYCLE1] = (u8) 0x00AA00AA; /* unlock */ + base[FLASH_CYCLE2] = (u8) 0x00550055; /* unlock */ + *atmeladdr = (u8) 0x00300030; /* erase sector */ + + if (flag) + enable_interrupts(); + + while ((*atmeladdr & (u8) 0x00800080) != + (u8) 0x00800080) { + if (get_timer(start) > + CFG_FLASH_ERASE_TOUT) { + printf("Timeout\n"); + *atmeladdr = (u8) 0x00F000F0; /* reset to read mode */ + + rcode = 1; + break; + } } - } - - *addr = (FPW) INTEL_RESET; /* resest to read mode */ - } else { - FPWV *base; /* first address in bank */ - FPWV *atmeladdr; - - flag = disable_interrupts();
- atmeladdr = (FPWV *) addr; /* concatenate to 8 bit */ - base = (FPWV *) (CFG_ATMEL_BASE); /* First sector */ - - base[FLASH_CYCLE1] = (u8) 0x00AA00AA; /* unlock */ - base[FLASH_CYCLE2] = (u8) 0x00550055; /* unlock */ - base[FLASH_CYCLE1] = (u8) 0x00800080; /* erase mode */ - base[FLASH_CYCLE1] = (u8) 0x00AA00AA; /* unlock */ - base[FLASH_CYCLE2] = (u8) 0x00550055; /* unlock */ - *atmeladdr = (u8) 0x00300030; /* erase sector */ + *atmeladdr = (u8) 0x00F000F0; /* reset to read mode */ + break; + }
- if (flag) - enable_interrupts(); + case 2: + { + *addr = (FPW) INTEL_READID; + min = addr[INTEL_CFI_TERB] & 0xff; + min = 1 << min; /* ms */ + min = (min / info->sector_count) * 1000; + + /* start erase block */ + *addr = (FPW) INTEL_CLEAR; /* clear status register */ + *addr = (FPW) INTEL_ERASE; /* erase setup */ + *addr = (FPW) INTEL_CONFIRM; /* erase confirm */ + + while ((*addr & (FPW) INTEL_FINISHED) != + (FPW) INTEL_FINISHED) { + + if (get_timer(start) > + CFG_FLASH_ERASE_TOUT) { + printf("Timeout\n"); + *addr = (FPW) INTEL_SUSERASE; /* suspend erase */ + *addr = (FPW) INTEL_RESET; /* reset to read mode */ + + rcode = 1; + break; + } + }
- while ((*atmeladdr & (u8) 0x00800080) != - (u8) 0x00800080) { - if (get_timer(start) > - CFG_FLASH_ERASE_TOUT) { - printf("Timeout\n"); - *atmeladdr = (u8) 0x00F000F0; /* reset to read mode */ + *addr = (FPW) INTEL_RESET; /* resest to read mode */ + break; + }
- rcode = 1; - break; +#if defined(CONFIG_SERIAL_FLASH) && defined(CONFIG_CF_DSPI) + case 3: + { + u8 sec = ((ulong) addr >> 16) & 0xFF; + + dspi_tx(ser_flash_cs, 0x00, SER_WREN); + dspi_rx(); + status = + serial_flash_read_status + (ser_flash_cs); + if (((status & 0x9C) != 0) + && ((status & 0x02) != 0x02)) { + printf("Error Programming\n"); + return 1; } - }
- *atmeladdr = (u8) 0x00F000F0; /* reset to read mode */ - } /* Atmel or Intel */ + dspi_tx(ser_flash_cs, 0x80, + SER_SECT_ERASE); + dspi_tx(ser_flash_cs, 0x80, sec); + dspi_tx(ser_flash_cs, 0x80, 0); + dspi_tx(ser_flash_cs, 0x00, 0); + + dspi_rx(); + dspi_rx(); + dspi_rx(); + dspi_rx(); + + do { + status = + serial_flash_read_status + (ser_flash_cs); + + if (get_timer(start) > + CFG_FLASH_ERASE_TOUT) { + printf("Timeout\n"); + return 1; + } + } while (status & 0x01); + + break; + } +#endif + } /* switch (flashtype) */ } } printf(" done\n"); @@ -583,6 +780,8 @@ int flash_erase(flash_info_t * info, int s_first, int s_last)
int write_buff(flash_info_t * info, uchar * src, ulong addr, ulong cnt) { + int count; + if (info->flash_id == FLASH_UNKNOWN) return 4;
@@ -623,7 +822,7 @@ int write_buff(flash_info_t * info, uchar * src, ulong addr, ulong cnt) { ulong cp, wp; u16 data; - int count, i, l, rc, port_width; + int i, l, rc, port_width;
/* get lower word aligned address */ wp = addr; @@ -724,6 +923,51 @@ int write_buff(flash_info_t * info, uchar * src, ulong addr, ulong cnt)
} /* case FLASH_MAN_INTEL */
+#if defined(CONFIG_SERIAL_FLASH) && defined(CONFIG_CF_DSPI) + case FLASH_MAN_STM: + { + ulong wp; + u8 *data = (u8 *) src; + int left; /* number of bytes left to program */ + + wp = addr; + + /* page align, each page is 256 bytes */ + if ((wp % 0x100) != 0) { + left = (0x100 - (wp & 0xFF)); + write_ser_data(info, wp, data, left); + cnt -= left; + wp += left; + data += left; + } + + /* page program - 256 bytes at a time */ + if (cnt > 255) { + count = 0; + while (cnt >= 0x100) { + write_ser_data(info, wp, data, 0x100); + cnt -= 0x100; + wp += 0x100; + data += 0x100; + + if (count++ > 0x400) { + spin_wheel(); + count = 0; + } + } + } + + /* remainint bytes */ + if (cnt && (cnt < 256)) { + write_ser_data(info, wp, data, cnt); + wp += cnt; + data += cnt; + cnt -= cnt; + } + + printf("\b."); + } +#endif } /* switch */
return ERR_OK; @@ -844,6 +1088,75 @@ int write_data(flash_info_t * info, ulong dest, FPW data) return (0); }
+#if defined(CONFIG_SERIAL_FLASH) && defined(CONFIG_CF_DSPI) +int write_ser_data(flash_info_t * info, ulong dest, uchar * data, ulong cnt) +{ + ulong start; + int status, i; + u8 flashdata; + + /* Check if Flash is (sufficiently) erased */ + dspi_tx(ser_flash_cs, 0x80, SER_READ); + dspi_tx(ser_flash_cs, 0x80, (dest >> 16) & 0xFF); + dspi_tx(ser_flash_cs, 0x80, (dest >> 8) & 0xFF); + dspi_tx(ser_flash_cs, 0x80, dest & 0xFF); + dspi_rx(); + dspi_rx(); + dspi_rx(); + dspi_rx(); + dspi_tx(ser_flash_cs, 0x80, 0); + flashdata = dspi_rx(); + dspi_tx(ser_flash_cs, 0x00, 0); + dspi_rx(); + + if ((flashdata & *data) != *data) { + printf("not erased at %08lx (%lx)\n", (ulong) dest, + (ulong) flashdata); + return (2); + } + + dspi_tx(ser_flash_cs, 0x00, SER_WREN); + dspi_rx(); + + status = serial_flash_read_status(ser_flash_cs); + if (((status & 0x9C) != 0) && ((status & 0x02) != 0x02)) { + printf("Error Programming\n"); + return 1; + } + + start = get_timer(0); + + dspi_tx(ser_flash_cs, 0x80, SER_PAGE_PROG); + dspi_tx(ser_flash_cs, 0x80, ((dest & 0xFF0000) >> 16)); + dspi_tx(ser_flash_cs, 0x80, ((dest & 0xFF00) >> 8)); + dspi_tx(ser_flash_cs, 0x80, (dest & 0xFF)); + dspi_rx(); + dspi_rx(); + dspi_rx(); + dspi_rx(); + + for (i = 0; i < (cnt - 1); i++) { + dspi_tx(ser_flash_cs, 0x80, *data); + dspi_rx(); + data++; + } + + dspi_tx(ser_flash_cs, 0x00, *data); + dspi_rx(); + + do { + status = serial_flash_read_status(ser_flash_cs); + + if (get_timer(start) > CFG_FLASH_ERASE_TOUT) { + printf("Timeout\n"); + return 1; + } + } while (status & 0x01); + + return (0); +} +#endif + /*----------------------------------------------------------------------- * Write a word to Flash for ATMEL FLASH * A word is 16 bits, whichever the bus width of the flash bank diff --git a/cpu/mcf5445x/Makefile b/cpu/mcf5445x/Makefile index 26ec298..a549fdd 100644 --- a/cpu/mcf5445x/Makefile +++ b/cpu/mcf5445x/Makefile @@ -28,7 +28,7 @@ include $(TOPDIR)/config.mk LIB = lib$(CPU).a
START = start.o -COBJS = cpu.o speed.o cpu_init.o interrupts.o pci.o +COBJS = cpu.o speed.o cpu_init.o interrupts.o pci.o dspi.o
SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) diff --git a/cpu/mcf5445x/dspi.c b/cpu/mcf5445x/dspi.c new file mode 100644 index 0000000..44d8505 --- /dev/null +++ b/cpu/mcf5445x/dspi.c @@ -0,0 +1,73 @@ +/* + * + * (C) Copyright 2000-2003 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * Copyright (C) 2004-2008 Freescale Semiconductor, Inc. + * TsiChung Liew (Tsi-Chung.Liew@freescale.com) + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <spi.h> + +#if defined(CONFIG_CF_DSPI) +#include <asm/immap.h> +void dspi_init(void) +{ + volatile gpio_t *gpio = (gpio_t *) MMAP_GPIO; + volatile dspi_t *dspi = (dspi_t *) MMAP_DSPI; + + gpio->par_dspi = GPIO_PAR_DSPI_PCS5_PCS5 | GPIO_PAR_DSPI_PCS2_PCS2 | + GPIO_PAR_DSPI_PCS1_PCS1 | GPIO_PAR_DSPI_PCS0_PCS0 | + GPIO_PAR_DSPI_SIN_SIN | GPIO_PAR_DSPI_SOUT_SOUT | + GPIO_PAR_DSPI_SCK_SCK; + + dspi->dmcr = DSPI_DMCR_MSTR | DSPI_DMCR_CSIS7 | DSPI_DMCR_CSIS6 | + DSPI_DMCR_CSIS5 | DSPI_DMCR_CSIS4 | DSPI_DMCR_CSIS3 | + DSPI_DMCR_CSIS2 | DSPI_DMCR_CSIS1 | DSPI_DMCR_CSIS0 | + DSPI_DMCR_CRXF | DSPI_DMCR_CTXF; + + dspi->dctar0 = DSPI_DCTAR_TRSZ(7) | DSPI_DCTAR_CPOL | DSPI_DCTAR_CPHA | + DSPI_DCTAR_PCSSCK_1CLK | DSPI_DCTAR_PASC(0) | + DSPI_DCTAR_PDT(0) | DSPI_DCTAR_CSSCK(0) | + DSPI_DCTAR_ASC(0) | DSPI_DCTAR_PBR(0) | + DSPI_DCTAR_DT(1) | DSPI_DCTAR_BR(1); +} + +void dspi_tx(int chipsel, u8 attrib, u16 data) +{ + volatile dspi_t *dspi = (dspi_t *) MMAP_DSPI; + + while ((dspi->dsr & 0x0000F000) >= 4) ; + + dspi->dtfr = (attrib << 24) | ((1 << chipsel) << 16) | data; +} + +u16 dspi_rx(void) +{ + volatile dspi_t *dspi = (dspi_t *) MMAP_DSPI; + + while ((dspi->dsr & 0x000000F0) == 0) ; + + return (dspi->drfr & 0xFFFF); +} + +#endif /* CONFIG_HARD_SPI */ diff --git a/include/asm-m68k/coldfire/dspi.h b/include/asm-m68k/coldfire/dspi.h index 3c579d3..8327e1b 100644 --- a/include/asm-m68k/coldfire/dspi.h +++ b/include/asm-m68k/coldfire/dspi.h @@ -64,10 +64,15 @@ typedef struct dspi { #define DSPI_DMCR_CTXF (0x00000800) #define DSPI_DMCR_DRXF (0x00001000) #define DSPI_DMCR_DTXF (0x00002000) +#define DSPI_DMCR_MDIS (0x00004000) #define DSPI_DMCR_CSIS0 (0x00010000) +#define DSPI_DMCR_CSIS1 (0x00020000) #define DSPI_DMCR_CSIS2 (0x00040000) #define DSPI_DMCR_CSIS3 (0x00080000) +#define DSPI_DMCR_CSIS4 (0x00100000) #define DSPI_DMCR_CSIS5 (0x00200000) +#define DSPI_DMCR_CSIS6 (0x00400000) +#define DSPI_DMCR_CSIS7 (0x00800000) #define DSPI_DMCR_ROOE (0x01000000) #define DSPI_DMCR_PCSSE (0x02000000) #define DSPI_DMCR_MTFE (0x04000000) @@ -92,6 +97,7 @@ typedef struct dspi { #define DSPI_DCTAR_CPHA (0x02000000) #define DSPI_DCTAR_CPOL (0x04000000) #define DSPI_DCTAR_TRSZ(x) (((x)&0x0000000F)<<27) +#define DSPI_DCTAR_DBR (0x80000000) #define DSPI_DCTAR_PCSSCK_1CLK (0x00000000) #define DSPI_DCTAR_PCSSCK_3CLK (0x00400000) #define DSPI_DCTAR_PCSSCK_5CLK (0x00800000) @@ -153,4 +159,8 @@ typedef struct dspi { /* Bit definitions and macros for DRFDR group */ #define DSPI_DRFDR_RXDATA(x) (((x)&0x0000FFFF))
+void dspi_init(void); +void dspi_tx(int chipsel, u8 attrib, u16 data); +u16 dspi_rx(void); + #endif /* __DSPI_H__ */ diff --git a/include/configs/M54455EVB.h b/include/configs/M54455EVB.h index f5edddf..a3c71e3 100644 --- a/include/configs/M54455EVB.h +++ b/include/configs/M54455EVB.h @@ -171,6 +171,10 @@ #define CFG_I2C_OFFSET 0x58000 #define CFG_IMMR CFG_MBAR
+/* DSPI and Serial Flash */ +#define CONFIG_CF_DSPI +#define CONFIG_SERIAL_FLASH + /* PCI */ #ifdef CONFIG_CMD_PCI #define CONFIG_PCI 1 @@ -309,7 +313,7 @@
#else
-# define CFG_MAX_FLASH_BANKS 2 /* max number of memory banks */ +# define CFG_MAX_FLASH_BANKS 3 /* max number of memory banks */
# define CFG_ATMEL_REGION 4 # define CFG_ATMEL_TOTALSECT 11 @@ -326,6 +330,28 @@ # define CFG_FLASH_PROTECTION /* "Real" (hardware) sectors protection */ # define CFG_FLASH_CHECKSUM
+#ifdef CONFIG_SERIAL_FLASH +# define CFG_FLASH2_BASE 0x01000000 +# define CFG_STM_SECT 32 +# define CFG_STM_SECTSZ 0x10000 + +# undef CFG_FLASH_ERASE_TOUT +# define CFG_FLASH_ERASE_TOUT 20000 + +# define SER_WREN 0x06 +# define SER_WRDI 0x04 +# define SER_RDID 0x9F +# define SER_RDSR 0x05 +# define SER_WRSR 0x01 +# define SER_READ 0x03 +# define SER_F_READ 0x0B +# define SER_PAGE_PROG 0x02 +# define SER_SECT_ERASE 0xD8 +# define SER_BULK_ERASE 0xC7 +# define SER_DEEP_PWRDN 0xB9 +# define SER_RES 0xAB +#endif + #endif
Tsi-Chung Liew
