[U-Boot] [PATCH] strings: use puts() rather than printf()
When running `strings` on really long strings, the stack tends to get smashed due to printf(). Switch to puts() instead since we're only passing the data through.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- common/cmd_strings.c | 3 ++- 1 files changed, 2 insertions(+), 1 deletions(-)
diff --git a/common/cmd_strings.c b/common/cmd_strings.c index db54f29..7d05cf8 100644 --- a/common/cmd_strings.c +++ b/common/cmd_strings.c @@ -29,7 +29,8 @@ int do_strings(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[])
char *addr = start_addr; do { - printf("%s\n", addr); + puts(addr); + puts("\n"); addr += strlen(addr) + 1; } while (addr[0] && addr < last_addr);
The current ELF loading function does a lot of work above and beyond a simple "loading". It ignores the real load addresses and loads things into their virtual (runtime) address. This is undesirable when we just want it to load an ELF and let the ELF do the actual C runtime init.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- - add a call to flush_cache() to make sure icache/dcache are in sync
common/cmd_elf.c | 28 ++++++++++++++++++++++++++++ 1 files changed, 28 insertions(+), 0 deletions(-)
diff --git a/common/cmd_elf.c b/common/cmd_elf.c index 3ebb6d9..d0515b9 100644 --- a/common/cmd_elf.c +++ b/common/cmd_elf.c @@ -276,6 +276,33 @@ int valid_elf_image (unsigned long addr) * A very simple elf loader, assumes the image is valid, returns the * entry point address. * ====================================================================== */ +#ifdef CONFIG_ELF_SIMPLE_LOAD +unsigned long load_elf_image (unsigned long addr) +{ + Elf32_Ehdr *ehdr; + Elf32_Phdr *phdr; + unsigned long entry; + size_t i; + + ehdr = (Elf32_Ehdr *) addr; + phdr = (Elf32_Phdr *) (addr + ehdr->e_phoff); + + entry = ehdr->e_entry; + + /* Load each program header */ + for (i = 0; i < ehdr->e_phnum; ++i) { + void *dst = (void *) phdr->p_paddr; + void *src = (void *) addr + phdr->p_offset; + printf ("Loading phdr %i to 0x%p (%i bytes)\n", + i, dst, phdr->p_filesz); + memcpy (dst, src, phdr->p_filesz); + flush_cache ((unsigned long)dst, phdr->p_filesz); + ++phdr; + } + + return entry; +} +#else unsigned long load_elf_image (unsigned long addr) { Elf32_Ehdr *ehdr; /* Elf header structure pointer */ @@ -327,6 +354,7 @@ unsigned long load_elf_image (unsigned long addr)
return ehdr->e_entry; } +#endif
/* ====================================================================== */ U_BOOT_CMD(
Dear Mike Frysinger,
Applied, thanks.
Mike Frysinger
Scott Wood
