[U-Boot] [PATCH v2 0/2] ARM: AM43xx: Add support for RTC only mode
Kernel stores information to the RTC_SCRATCH0 and RTC_SCRATCH1 registers for wakeup from RTC-only mode. Parse these registers during SPL boot and jump to the kernel resume vector if the device is waking up from RTC-only mode.
The RTC scratch register layout used is:
SCRATCH0 : bits00-31 : kernel resume address SCRATCH1 : bits00-15 : RTC magic value used to detect valid config SCRATCH1 : bits16-31 : board type information populated by bootloader
During the normal boot path the SCRATCH1 : bits16-31 are updated with the eeprom read board type data. In the rtc_only boot path the rtc scratchpad register is read and the board type is determined and correspondingly ddr dpll parameters are set. This is done so as to avoid costly i2c read to eeprom.
RTC-only mode support is currently only enabled for am43xx_evm_rtconly_config. This is not to be used with epos evm builds.
Dave Gerlach (1): am43xx: Do not allow EMIF to control DDR_RESET in rtconly config
Tero Kristo (1): ARM: AM43xx: Add support for RTC only mode
arch/arm/include/asm/arch-am33xx/clock.h | 6 ++ arch/arm/mach-omap2/am33xx/Kconfig | 14 ++++ arch/arm/mach-omap2/am33xx/board.c | 110 +++++++++++++++++++++++++++--- arch/arm/mach-omap2/am33xx/clock.c | 10 +++ arch/arm/mach-omap2/am33xx/clock_am43xx.c | 21 ++++++ arch/arm/mach-omap2/am33xx/emif4.c | 5 ++ board/ti/am43xx/MAINTAINERS | 1 + board/ti/am43xx/board.c | 56 +++++++++++++++ configs/am43xx_evm_rtconly_defconfig | 59 ++++++++++++++++ 9 files changed, 274 insertions(+), 8 deletions(-) create mode 100644 configs/am43xx_evm_rtconly_defconfig
Signed-off-by: Tero Kristo t-kristo@ti.com [j-keerthy@ti.com Rebased to latest u-boot master branch] Signed-off-by: Keerthy j-keerthy@ti.com ---
Changes in v2:
* Added more description to CONFIG Option. * Renamed CONFIG_SPL_RTC_ONLY_SUPPORT to CONFIG_SPL_RTC_DDR_SUPPORT * Added the probable kernel file where RTC Magic value will need to be matched.
arch/arm/include/asm/arch-am33xx/clock.h | 6 ++ arch/arm/mach-omap2/am33xx/Kconfig | 14 ++++ arch/arm/mach-omap2/am33xx/board.c | 110 +++++++++++++++++++++++++++--- arch/arm/mach-omap2/am33xx/clock.c | 10 +++ arch/arm/mach-omap2/am33xx/clock_am43xx.c | 21 ++++++ board/ti/am43xx/MAINTAINERS | 1 + board/ti/am43xx/board.c | 56 +++++++++++++++ configs/am43xx_evm_rtconly_defconfig | 59 ++++++++++++++++ 8 files changed, 269 insertions(+), 8 deletions(-) create mode 100644 configs/am43xx_evm_rtconly_defconfig
diff --git a/arch/arm/include/asm/arch-am33xx/clock.h b/arch/arm/include/asm/arch-am33xx/clock.h index 9dbcd3a..eeebf16 100644 --- a/arch/arm/include/asm/arch-am33xx/clock.h +++ b/arch/arm/include/asm/arch-am33xx/clock.h @@ -122,6 +122,12 @@ void scale_vcores(void); void do_setup_dpll(const struct dpll_regs *, const struct dpll_params *); void prcm_init(void); void enable_basic_clocks(void); + +void rtc_only_update_board_type(u32 btype); +u32 rtc_only_get_board_type(void); +void rtc_only_prcm_init(void); +void rtc_only_enable_basic_clocks(void); + void do_enable_clocks(u32 *const *, u32 *const *, u8); void do_disable_clocks(u32 *const *, u32 *const *, u8);
diff --git a/arch/arm/mach-omap2/am33xx/Kconfig b/arch/arm/mach-omap2/am33xx/Kconfig index 9a9ccd7..76da6d9 100644 --- a/arch/arm/mach-omap2/am33xx/Kconfig +++ b/arch/arm/mach-omap2/am33xx/Kconfig @@ -239,6 +239,20 @@ config TARGET_CM_T43
endchoice
+config SPL_RTC_DDR_SUPPORT + bool + depends on SPL + prompt "Enable RTC-DDR ONLY Support" + help + If you want RTC-DDR ONLY Support, say Y. RTC Only with DDR in + self-refresh mode is a special power saving mode where in all + the other voltages are turned off apart from the RTC domain and DDR. + So only RTC is alive and ticking and one can program it to wake + up after a predetermined period. Once RTC alarm fires, the PMIC + powers up all the voltage domains. U-Boot takes a special path + as the DDR has contents is in self-refresh and restore path is + followed. + endif
if AM43XX || AM33XX diff --git a/arch/arm/mach-omap2/am33xx/board.c b/arch/arm/mach-omap2/am33xx/board.c index ea0caba..b970a2b 100644 --- a/arch/arm/mach-omap2/am33xx/board.c +++ b/arch/arm/mach-omap2/am33xx/board.c @@ -147,6 +147,16 @@ int cpu_mmc_init(bd_t *bis) } #endif
+/* + * RTC only mode magic value, checked against during boot to see if we have + * a valid config. This should be in sync with the value that will be in + * drivers/soc/ti/pm33xx.c. + */ +#define RTC_MAGIC_VAL 0x8cd0 + +/* Board type field bit shift for RTC only mode */ +#define RTC_BOARD_TYPE_SHIFT 16 + /* AM33XX has two MUSB controllers which can be host or gadget */ #if (defined(CONFIG_USB_MUSB_GADGET) || defined(CONFIG_USB_MUSB_HOST)) && \ (defined(CONFIG_AM335X_USB0) || defined(CONFIG_AM335X_USB1)) && \ @@ -252,6 +262,48 @@ int arch_misc_init(void) #endif /* CONFIG_USB_MUSB_* && CONFIG_AM335X_USB* && !CONFIG_DM_USB */
#ifndef CONFIG_SKIP_LOWLEVEL_INIT + +#if defined(CONFIG_SPL_AM33XX_ENABLE_RTC32K_OSC) || \ + (defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_RTC_DDR_SUPPORT)) +static void rtc32k_unlock(struct davinci_rtc *rtc) +{ + /* + * Unlock the RTC's registers. For more details please see the + * RTC_SS section of the TRM. In order to unlock we need to + * write these specific values (keys) in this order. + */ + writel(RTC_KICK0R_WE, &rtc->kick0r); + writel(RTC_KICK1R_WE, &rtc->kick1r); +} +#endif + +#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_RTC_DDR_SUPPORT) +/* + * Write contents of the RTC_SCRATCH1 register based on board type + * Two things are passed + * on. First 16 bits (0:15) are written with RTC_MAGIC value. Once the + * control gets to kernel, kernel reads the scratchpad register and gets to + * know that bootloader has rtc_only support. + * + * Second important thing is the board type (16:31). This is needed in the + * rtc_only boot where in we want to avoid costly i2c reads to eeprom to + * identify the board type and we go ahead and copy the board strings to + * am43xx_board_name. + */ +void update_rtc_magic(void) +{ + struct davinci_rtc *rtc = (struct davinci_rtc *)RTC_BASE; + u32 magic = RTC_MAGIC_VAL; + + magic |= (rtc_only_get_board_type() << RTC_BOARD_TYPE_SHIFT); + + rtc32k_unlock(rtc); + + /* write magic */ + writel(magic, &rtc->scratch1); +} +#endif + /* * In the case of non-SPL based booting we'll want to call these * functions a tiny bit later as it will require gd to be set and cleared @@ -261,7 +313,9 @@ int board_early_init_f(void) { prcm_init(); set_mux_conf_regs(); - +#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_RTC_DDR_SUPPORT) + update_rtc_magic(); +#endif return 0; }
@@ -278,13 +332,7 @@ static void rtc32k_enable(void) { struct davinci_rtc *rtc = (struct davinci_rtc *)RTC_BASE;
- /* - * Unlock the RTC's registers. For more details please see the - * RTC_SS section of the TRM. In order to unlock we need to - * write these specific values (keys) in this order. - */ - writel(RTC_KICK0R_WE, &rtc->kick0r); - writel(RTC_KICK1R_WE, &rtc->kick1r); + rtc32k_unlock(rtc);
/* Enable the RTC 32K OSC by setting bits 3 and 6. */ writel((1 << 3) | (1 << 6), &rtc->osc); @@ -321,8 +369,54 @@ static void watchdog_disable(void) ; }
+#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_RTC_DDR_SUPPORT) +/* + * Check if we are executing rtc-only mode, and resume from it if needed + */ +static void rtc_only(void) +{ + struct davinci_rtc *rtc = (struct davinci_rtc *)RTC_BASE; + u32 scratch1; + void (*resume_func)(void); + + scratch1 = readl(&rtc->scratch1); + + /* + * Check RTC scratch against RTC_MAGIC_VAL, RTC_MAGIC_VAL is only + * written to this register when we want to wake up from RTC only + * mode. Contents of the RTC_SCRATCH1: + * bits 0-15: RTC_MAGIC_VAL + * bits 16-31: board type (needed for sdram_init) + */ + if ((scratch1 & 0xffff) != RTC_MAGIC_VAL) + return; + + rtc32k_unlock(rtc); + + /* Clear RTC magic */ + writel(0, &rtc->scratch1); + + /* + * Update board type based on value stored on RTC_SCRATCH1, this + * is done so that we don't need to read the board type from eeprom + * over i2c bus which is expensive + */ + rtc_only_update_board_type(scratch1 >> RTC_BOARD_TYPE_SHIFT); + + rtc_only_prcm_init(); + sdram_init(); + + resume_func = (void *)readl(&rtc->scratch0); + if (resume_func) + resume_func(); +} +#endif + void s_init(void) { +#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_RTC_DDR_SUPPORT) + rtc_only(); +#endif }
void early_system_init(void) diff --git a/arch/arm/mach-omap2/am33xx/clock.c b/arch/arm/mach-omap2/am33xx/clock.c index 3d17698..ad28d20 100644 --- a/arch/arm/mach-omap2/am33xx/clock.c +++ b/arch/arm/mach-omap2/am33xx/clock.c @@ -244,3 +244,13 @@ void prcm_init(void) scale_vcores(); setup_dplls(); } + +void rtc_only_prcm_init(void) +{ + const struct dpll_params *params; + + rtc_only_enable_basic_clocks(); + + params = get_dpll_ddr_params(); + do_setup_dpll(&dpll_ddr_regs, params); +} diff --git a/arch/arm/mach-omap2/am33xx/clock_am43xx.c b/arch/arm/mach-omap2/am33xx/clock_am43xx.c index 73ea955..117a63e 100644 --- a/arch/arm/mach-omap2/am33xx/clock_am43xx.c +++ b/arch/arm/mach-omap2/am33xx/clock_am43xx.c @@ -124,6 +124,27 @@ void enable_basic_clocks(void) writel(0x4, &cmdpll->clkselmacclk); }
+void rtc_only_enable_basic_clocks(void) +{ + u32 *const clk_domains[] = { + &cmper->emifclkstctrl, + 0 + }; + + u32 *const clk_modules_explicit_en[] = { + &cmper->gpio5clkctrl, + &cmper->emiffwclkctrl, + &cmper->emifclkctrl, + &cmper->otfaemifclkctrl, + 0 + }; + + do_enable_clocks(clk_domains, clk_modules_explicit_en, 1); + + /* Select the Master osc clk as Timer2 clock source */ + writel(0x1, &cmdpll->clktimer2clk); +} + #ifdef CONFIG_TI_EDMA3 void enable_edma3_clocks(void) { diff --git a/board/ti/am43xx/MAINTAINERS b/board/ti/am43xx/MAINTAINERS index 83645ac..bf09806 100644 --- a/board/ti/am43xx/MAINTAINERS +++ b/board/ti/am43xx/MAINTAINERS @@ -7,4 +7,5 @@ F: configs/am43xx_evm_defconfig F: configs/am43xx_evm_ethboot_defconfig F: configs/am43xx_evm_qspiboot_defconfig F: configs/am43xx_evm_usbhost_boot_defconfig +F: configs/am43xx_evm_rtconly_defconfig F: configs/am43xx_hs_evm_defconfig diff --git a/board/ti/am43xx/board.c b/board/ti/am43xx/board.c index 715960a..3a6cc05 100644 --- a/board/ti/am43xx/board.c +++ b/board/ti/am43xx/board.c @@ -520,6 +520,62 @@ static void enable_vtt_regulator(void) writel(temp, AM33XX_GPIO5_BASE + OMAP_GPIO_OE); }
+enum { + RTC_BOARD_EPOS = 1, + RTC_BOARD_EVM14, + RTC_BOARD_EVM12, + RTC_BOARD_GPEVM, + RTC_BOARD_SK, +}; + +/* + * In the rtc_only boot path we have the board type info in the rtc scratch pad + * register hence we bypass the costly i2c reads to eeprom and directly program + * the board name string + */ +void rtc_only_update_board_type(u32 btype) +{ + const char *name = ""; + const char *rev = "1.0"; + + switch (btype) { + case RTC_BOARD_EPOS: + name = "AM43EPOS"; + break; + case RTC_BOARD_EVM14: + name = "AM43__GP"; + rev = "1.4"; + break; + case RTC_BOARD_EVM12: + name = "AM43__GP"; + rev = "1.2"; + break; + case RTC_BOARD_GPEVM: + name = "AM43__GP"; + break; + case RTC_BOARD_SK: + name = "AM43__SK"; + break; + } + ti_i2c_eeprom_am_set(name, rev); +} + +u32 rtc_only_get_board_type(void) +{ + if (board_is_eposevm()) + return RTC_BOARD_EPOS; + else if (board_is_evm_14_or_later()) + return RTC_BOARD_EVM14; + else if (board_is_evm_12_or_later()) + return RTC_BOARD_EVM12; + else if (board_is_gpevm()) + return RTC_BOARD_GPEVM; + else if (board_is_sk()) + return RTC_BOARD_SK; + + return 0; +} + void sdram_init(void) { /* diff --git a/configs/am43xx_evm_rtconly_defconfig b/configs/am43xx_evm_rtconly_defconfig new file mode 100644 index 0000000..ab0be10 --- /dev/null +++ b/configs/am43xx_evm_rtconly_defconfig @@ -0,0 +1,59 @@ +CONFIG_ARM=y +CONFIG_ARCH_OMAP2PLUS=y +CONFIG_TI_COMMON_CMD_OPTIONS=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_AM43XX=y +CONFIG_DEFAULT_DEVICE_TREE="am437x-gp-evm" +CONFIG_DISTRO_DEFAULTS=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1" +# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_VERSION_VARIABLE=y +CONFIG_SPL=y +CONFIG_SPL_RTC_DDR_SUPPORT=y +CONFIG_SPL_MTD_SUPPORT=y +CONFIG_SPL_OS_BOOT=y +CONFIG_CMD_SPL=y +CONFIG_CMD_SPL_NAND_OFS=0x00100000 +CONFIG_CMD_SPL_WRITE_SIZE=0x40000 +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_NAND=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MTDPARTS=y +CONFIG_MTDIDS_DEFAULT="nand0=nand.0" +CONFIG_MTDPARTS_DEFAULT="mtdparts=nand.0:256k(NAND.SPL),256k(NAND.SPL.backup1),256k(NAND.SPL.backup2),256k(NAND.SPL.backup3),512k(NAND.u-boot-spl-os),1m(NAND.u-boot),256k(NAND.u-boot-env),256k(NAND.u-boot-env.backup1),7m(NAND.kernel),-(NAND.file-system)" +CONFIG_OF_CONTROL=y +CONFIG_OF_LIST="am437x-gp-evm am437x-sk-evm am43x-epos-evm am437x-idk-evm" +CONFIG_DM=y +# CONFIG_BLK is not set +CONFIG_DFU_MMC=y +CONFIG_DFU_RAM=y +CONFIG_DFU_SF=y +CONFIG_DM_GPIO=y +CONFIG_DM_MMC=y +CONFIG_MMC_OMAP_HS=y +CONFIG_NAND=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_PHYLIB=y +CONFIG_PHY_GIGE=y +CONFIG_DM_SERIAL=y +CONFIG_SYS_NS16550=y +CONFIG_TI_QSPI=y +CONFIG_TIMER=y +CONFIG_OMAP_TIMER=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GADGET=y +CONFIG_USB_DWC3_OMAP=y +CONFIG_USB_DWC3_PHY_OMAP=y +CONFIG_OMAP_USB_PHY=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" +CONFIG_USB_GADGET_VENDOR_NUM=0x0403 +CONFIG_USB_GADGET_PRODUCT_NUM=0xbd00 +CONFIG_USB_GADGET_DOWNLOAD=y
Hi Keerthy,
I think you should replace all the references in this patch for RTC only mode to RTC-only + DDR; that is more valid term of the mode implemented. For u-boot, pure rtc-only mode is a don't care, it is visible as just a normal boot-up with RTC being the boot source.
In the case handled by this patch, the power mode of the SoC itself is RTC-only which is documented in TRM. DDR is programmed to self-refresh and held there with support of some external components (basically a pull on CKE line.) Dave, any thoughts on that?
-Tero
Changes in v2:
- Added more description to CONFIG Option.
- Renamed CONFIG_SPL_RTC_ONLY_SUPPORT to CONFIG_SPL_RTC_DDR_SUPPORT
- Added the probable kernel file where RTC Magic value will need to be matched.
- void do_enable_clocks(u32 *const *, u32 *const *, u8); void do_disable_clocks(u32 *const *, u32 *const *, u8);
endchoice
bool
depends on SPL
help
followed.
endif
if AM43XX || AM33XX
- RTC only mode magic value, checked against during boot to see if we have
- a valid config. This should be in sync with the value that will be in
- drivers/soc/ti/pm33xx.c.
- /* AM33XX has two MUSB controllers which can be host or gadget */ #if (defined(CONFIG_USB_MUSB_GADGET) || defined(CONFIG_USB_MUSB_HOST)) && \ (defined(CONFIG_AM335X_USB0) || defined(CONFIG_AM335X_USB1)) && \
- (defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_RTC_DDR_SUPPORT))
+} +#endif
- Write contents of the RTC_SCRATCH1 register based on board type
- Two things are passed
- on. First 16 bits (0:15) are written with RTC_MAGIC value. Once the
- control gets to kernel, kernel reads the scratchpad register and gets to
- know that bootloader has rtc_only support.
- Second important thing is the board type (16:31). This is needed in the
- rtc_only boot where in we want to avoid costly i2c reads to eeprom to
- identify the board type and we go ahead and copy the board strings to
- am43xx_board_name.
- struct davinci_rtc *rtc = (struct davinci_rtc *)RTC_BASE;
- u32 magic = RTC_MAGIC_VAL;
- magic |= (rtc_only_get_board_type() << RTC_BOARD_TYPE_SHIFT);
- rtc32k_unlock(rtc);
- /* write magic */
- writel(magic, &rtc->scratch1);
+} +#endif
- In the case of non-SPL based booting we'll want to call these
- functions a tiny bit later as it will require gd to be set and cleared
- update_rtc_magic();
+#endif return 0; }
rtc32k_unlock(rtc);
- Check if we are executing rtc-only mode, and resume from it if needed
- u32 scratch1;
- void (*resume_func)(void);
- scratch1 = readl(&rtc->scratch1);
- if ((scratch1 & 0xffff) != RTC_MAGIC_VAL)
return;
- /* Clear RTC magic */
- writel(0, &rtc->scratch1);
- rtc_only_update_board_type(scratch1 >> RTC_BOARD_TYPE_SHIFT);
- rtc_only_prcm_init();
- sdram_init();
- resume_func = (void *)readl(&rtc->scratch0);
- if (resume_func)
resume_func();
+} +#endif
- void s_init(void) {
- rtc_only();
+#endif }
- const struct dpll_params *params;
- rtc_only_enable_basic_clocks();
- params = get_dpll_ddr_params();
- do_setup_dpll(&dpll_ddr_regs, params);
- u32 *const clk_domains[] = {
0
- u32 *const clk_modules_explicit_en[] = {
0
- do_enable_clocks(clk_domains, clk_modules_explicit_en, 1);
- /* Select the Master osc clk as Timer2 clock source */
- writel(0x1, &cmdpll->clktimer2clk);
- #ifdef CONFIG_TI_EDMA3 void enable_edma3_clocks(void) {
+enum {
- RTC_BOARD_EPOS = 1,
- RTC_BOARD_EVM14,
- RTC_BOARD_EVM12,
- RTC_BOARD_GPEVM,
- RTC_BOARD_SK,
- In the rtc_only boot path we have the board type info in the rtc scratch pad
- register hence we bypass the costly i2c reads to eeprom and directly program
- the board name string
- const char *name = "";
- const char *rev = "1.0";
- switch (btype) {
- case RTC_BOARD_EPOS:
name = "AM43EPOS";
break;
- case RTC_BOARD_EVM14:
name = "AM43__GP";
rev = "1.4";
break;
- case RTC_BOARD_EVM12:
name = "AM43__GP";
rev = "1.2";
break;
- case RTC_BOARD_GPEVM:
name = "AM43__GP";
break;
- case RTC_BOARD_SK:
name = "AM43__SK";
break;
- ti_i2c_eeprom_am_set(name, rev);
- if (board_is_eposevm())
- else if (board_is_evm_14_or_later())
- else if (board_is_evm_12_or_later())
- else if (board_is_gpevm())
- else if (board_is_sk())
- void sdram_init(void) { /*
-- Texas Instruments Finland Oy, Porkkalankatu 22, 00180 Helsinki. Y-tunnus/Business ID: 0615521-4. Kotipaikka/Domicile: Helsinki
Prevent EMIF control of DDR_RESET line on DDR3 am43xx platforms for am43xx_evm_rtconly_config. Without this DDR is unstable and can become corrupted after multiple iterations of RTC+DDR mode.
Signed-off-by: Dave Gerlach d-gerlach@ti.com [j-keerthy@ti.com Ported to latest master branch] Signed-off-by: Keerthy j-keerthy@ti.com Reviewed-by: Tom Rini trini@konsulko.com ---
Changes in v2:
* Added Tom's Reviewed-by
arch/arm/mach-omap2/am33xx/emif4.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/arm/mach-omap2/am33xx/emif4.c b/arch/arm/mach-omap2/am33xx/emif4.c index 68c7705..54e11d3 100644 --- a/arch/arm/mach-omap2/am33xx/emif4.c +++ b/arch/arm/mach-omap2/am33xx/emif4.c @@ -95,8 +95,13 @@ void config_ddr(unsigned int pll, const struct ctrl_ioregs *ioregs, writel(DDR_CKE_CTRL_NORMAL, &ddrctrl->ddrckectrl);
if (emif_sdram_type(regs->sdram_config) == EMIF_SDRAM_TYPE_DDR3) +#ifndef CONFIG_SPL_RTC_ONLY_SUPPORT /* Allow EMIF to control DDR_RESET */ writel(0x00000000, &ddrctrl->ddrioctrl); +#else + /* Override EMIF DDR_RESET control */ + writel(0x80000000, &ddrctrl->ddrioctrl); +#endif /* CONFIG_SPL_RTC_ONLY_SUPPORT */ #endif
/* Program EMIF instance */
Keerthy
Tero Kristo
