[PATCH] rockchip: Set default LNX_KRNL_IMG_TEXT_OFFSET_BASE to SYS_TEXT_BASE
U-Boot can be chainloaded from vendor firmware on ARM64 chromebooks from a GPT partition (roughly the same as in doc/chromium/chainload.rst), but an appropriate image header must be built-in to the U-Boot binary by enabling LINUX_KERNEL_IMAGE_HEADER.
This header has a field for an image load offset from 2MiB alignment which must also be customized through LNX_KRNL_IMG_TEXT_OFFSET_BASE. Set it equal to SYS_TEXT_BASE by default for Rockchip boards, which happens to make this offset zero and works fine on chromebook_kevin both for chainloading and bare-metal use.
Signed-off-by: Alper Nebi Yasak alpernebiyasak@gmail.com --- Looks like ARM64 chromebooks also need POSITION_INDEPENDENT=y to chainload that way, but I'm not enabling the configs here. I'm thinking of selecting these from new configs that also enable binman definitions for the kernel partition and legacy boot images.
arch/arm/mach-rockchip/Kconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index 92f35309e4a6..308dc09b0389 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -390,6 +390,9 @@ config ROCKCHIP_SPI_IMAGE containing U-Boot. The image is built by binman. U-Boot sits near the start of the image.
+config LNX_KRNL_IMG_TEXT_OFFSET_BASE + default SYS_TEXT_BASE + source "arch/arm/mach-rockchip/px30/Kconfig" source "arch/arm/mach-rockchip/rk3036/Kconfig" source "arch/arm/mach-rockchip/rk3128/Kconfig"
On Sat, 29 Jan 2022 at 08:28, Alper Nebi Yasak alpernebiyasak@gmail.com wrote:
Hi Alper,
Alper Nebi Yasak alpernebiyasak@gmail.com 于2022年1月29日周六 23:28写道:
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
source "arch/arm/mach-rockchip/px30/Kconfig" source "arch/arm/mach-rockchip/rk3036/Kconfig" source "arch/arm/mach-rockchip/rk3128/Kconfig" -- 2.34.1
Alper Nebi Yasak
Kever Yang
