[U-Boot-Users] [PATCH] Nios-II Support (6 of 7)
-Add support for Altera Nios-II processors. -Add support for Psyent PCI-5441 board. -Add support for Psyent PK1C20 board.
Regards, --Scott
diff -Naurb u-boot-2004-08-24/lib_nios2/board.c u-boot-nios2/lib_nios2/board.c --- u-boot-2004-08-24/lib_nios2/board.c 1969-12-31 19:00:00.000000000 -0500 +++ u-boot-nios2/lib_nios2/board.c 2004-08-24 05:36:48.000000000 -0400 @@ -0,0 +1,184 @@ +/* + * (C) Copyright 2003, Psyent Corporation <www.psyent.com> + * Scott McNutt smcnutt@psyent.com + * + * (C) Copyright 2000-2002 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <devices.h> +#include <watchdog.h> +#include <net.h> +#ifdef CONFIG_STATUS_LED +#include <status_led.h> +#endif + + +/* + * All attempts to come up with a "common" initialization sequence + * that works for all boards and architectures failed: some of the + * requirements are just _too_ different. To get rid of the resulting + * mess of board dependend #ifdef'ed code we now make the whole + * initialization sequence configurable to the user. + * + * The requirements for any new initalization function is simple: it + * receives a pointer to the "global data" structure as it's only + * argument, and returns an integer return code, where 0 means + * "continue" and != 0 means "fatal error, hang the system". + */ + + +extern void malloc_bin_reloc (void); +typedef int (init_fnc_t) (void); + +/* + * Begin and End of memory area for malloc(), and current "brk" + */ +static ulong mem_malloc_start = 0; +static ulong mem_malloc_end = 0; +static ulong mem_malloc_brk = 0; + +/* + * The Malloc area is immediately below the monitor copy in RAM + */ +static void mem_malloc_init (void) +{ + mem_malloc_start = CFG_MALLOC_BASE; + mem_malloc_end = mem_malloc_start + CFG_MALLOC_LEN; + mem_malloc_brk = mem_malloc_start; + memset ((void *) mem_malloc_start, + 0, + mem_malloc_end - mem_malloc_start); +} + +void *sbrk (ptrdiff_t increment) +{ + ulong old = mem_malloc_brk; + ulong new = old + increment; + + if ((new < mem_malloc_start) || (new > mem_malloc_end)) { + return (NULL); + } + mem_malloc_brk = new; + return ((void *) old); +} + + +/************************************************************************ + * Initialization sequence * + ***********************************************************************/ + +init_fnc_t *init_sequence[] = { + +#if defined(CONFIG_BOARD_EARLY_INIT_F) + board_early_init_f, /* Call board-specific init code early.*/ +#endif + + env_init, + serial_init, + console_init_f, + display_options, + checkcpu, + checkboard, + NULL, /* Terminate this list */ +}; + + +/***********************************************************************/ +void board_init (void) +{ + DECLARE_GLOBAL_DATA_PTR; + + bd_t *bd; + init_fnc_t **init_fnc_ptr; + char *s, *e; + int i; + + /* Pointer is writable since we allocated a register for it. + * Nios treats CFG_GBL_DATA_OFFSET as an address. + */ + gd = (gd_t *)CFG_GBL_DATA_OFFSET; + /* compiler optimization barrier needed for GCC >= 3.4 */ + __asm__ __volatile__("": : :"memory"); + + memset( gd, 0, CFG_GBL_DATA_SIZE ); + + gd->bd = (bd_t *)(gd+1); /* At end of global data */ + gd->baudrate = CONFIG_BAUDRATE; + gd->cpu_clk = CONFIG_SYS_CLK_FREQ; + + bd = gd->bd; + bd->bi_memstart = CFG_SDRAM_BASE; + bd->bi_memsize = CFG_SDRAM_SIZE; + bd->bi_flashstart = CFG_FLASH_BASE; +#if defined(CFG_SRAM_BASE) && defined(CFG_SRAM_SIZE) + bd->bi_sramstart= CFG_SRAM_BASE; + bd->bi_sramsize = CFG_SRAM_SIZE; +#endif + bd->bi_baudrate = CONFIG_BAUDRATE; + + for (init_fnc_ptr = init_sequence; *init_fnc_ptr; ++init_fnc_ptr) { + WATCHDOG_RESET (); + if ((*init_fnc_ptr) () != 0) { + hang (); + } + } + + WATCHDOG_RESET (); + bd->bi_flashsize = flash_init(); + + WATCHDOG_RESET (); + mem_malloc_init(); + malloc_bin_reloc(); + env_relocate(); + + bd->bi_ip_addr = getenv_IPaddr ("ipaddr"); + s = getenv ("ethaddr"); + for (i = 0; i < 6; ++i) { + bd->bi_enetaddr[i] = s ? simple_strtoul (s, &e, 16) : 0; + if (s) s = (*e) ? e + 1 : e; + } + + WATCHDOG_RESET (); + devices_init(); + jumptable_init(); + console_init_r(); + + WATCHDOG_RESET (); + interrupt_init (); + + /* main_loop */ + for (;;) { + WATCHDOG_RESET (); + main_loop (); + } +} + + +/***********************************************************************/ + +void hang (void) +{ + disable_interrupts (); + puts("### ERROR ### Please reset board ###\n"); + for (;;); +} diff -Naurb u-boot-2004-08-24/lib_nios2/cache.S u-boot-nios2/lib_nios2/cache.S --- u-boot-2004-08-24/lib_nios2/cache.S 1969-12-31 19:00:00.000000000 -0500 +++ u-boot-nios2/lib_nios2/cache.S 2004-08-24 05:36:48.000000000 -0400 @@ -0,0 +1,74 @@ +/* + * (C) Copyright 2004, Psyent Corporation <www.psyent.com> + * Scott McNutt smcnutt@psyent.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> + + .text + + .global flush_dcache + +flush_dcache: + add r5, r5, r4 + movhi r8, %hi(CFG_DCACHELINE_SIZE) + ori r8, r8, %lo(CFG_DCACHELINE_SIZE) +0: flushd 0(r4) + add r4, r4, r8 + bltu r4, r5, 0b + ret + + + .global flush_icache + +flush_icache: + add r5, r5, r4 + movhi r8, %hi(CFG_ICACHELINE_SIZE) + ori r8, r8, %lo(CFG_ICACHELINE_SIZE) +1: flushi r4 + add r4, r4, r8 + bltu r4, r5, 1b + ret + + .global flush_cache + +flush_cache: + add r5, r5, r4 + mov r9, r4 + mov r10, r5 + + movhi r8, %hi(CFG_DCACHELINE_SIZE) + ori r8, r8, %lo(CFG_DCACHELINE_SIZE) +0: flushd 0(r4) + add r4, r4, r8 + bltu r4, r5, 0b + + mov r4, r9 + mov r5, r10 + movhi r8, %hi(CFG_ICACHELINE_SIZE) + ori r8, r8, %lo(CFG_ICACHELINE_SIZE) +1: flushi r4 + add r4, r4, r8 + bltu r4, r5, 1b + + sync + flushp + ret diff -Naurb u-boot-2004-08-24/lib_nios2/divmod.c u-boot-nios2/lib_nios2/divmod.c --- u-boot-2004-08-24/lib_nios2/divmod.c 1969-12-31 19:00:00.000000000 -0500 +++ u-boot-nios2/lib_nios2/divmod.c 2004-08-24 05:36:48.000000000 -0400 @@ -0,0 +1,101 @@ +/* + * This file is part of GNU CC. + * + * GNU CC is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published + * by the Free Software Foundation; either version 2, or (at your + * option) any later version. + * + * GNU CC is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public + * License along with GNU CC; see the file COPYING. If not, write + * to the Free Software Foundation, 59 Temple Place - Suite 330, + * Boston, MA 02111-1307, USA. + */ + + +#include "math.h" + +USItype udivmodsi4 (USItype num, USItype den, word_type modwanted) +{ + USItype bit = 1; + USItype res = 0; + + while (den < num && bit && !(den & (1L << 31))) { + den <<= 1; + bit <<= 1; + } + while (bit) { + if (num >= den) { + num -= den; + res |= bit; + } + bit >>= 1; + den >>= 1; + } + if (modwanted) + return num; + return res; +} + + +SItype __divsi3 (SItype a, SItype b) +{ + word_type neg = 0; + SItype res; + + if (a < 0) { + a = -a; + neg = !neg; + } + + if (b < 0) { + b = -b; + neg = !neg; + } + + res = udivmodsi4 (a, b, 0); + + if (neg) + res = -res; + + return res; +} + + +SItype __modsi3 (SItype a, SItype b) +{ + word_type neg = 0; + SItype res; + + if (a < 0) { + a = -a; + neg = 1; + } + + if (b < 0) + b = -b; + + res = udivmodsi4 (a, b, 1); + + if (neg) + res = -res; + + return res; +} + + +SItype __udivsi3 (SItype a, SItype b) +{ + return udivmodsi4 (a, b, 0); +} + + +SItype __umodsi3 (SItype a, SItype b) +{ + return udivmodsi4 (a, b, 1); +} diff -Naurb u-boot-2004-08-24/lib_nios2/Makefile u-boot-nios2/lib_nios2/Makefile --- u-boot-2004-08-24/lib_nios2/Makefile 1969-12-31 19:00:00.000000000 -0500 +++ u-boot-nios2/lib_nios2/Makefile 2004-08-24 05:36:48.000000000 -0400 @@ -0,0 +1,44 @@ +# +# (C) Copyright 2000 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = lib$(ARCH).a + +AOBJS = cache.o + +COBJS = board.o divmod.o nios_linux.o mult.o time.o + +OBJS = $(AOBJS) $(COBJS) + +$(LIB): .depend $(OBJS) + $(AR) crv $@ $(OBJS) + +######################################################################### + +.depend: Makefile $(AOBJS:.o=.S) $(COBJS:.o=.c) + $(CC) -M $(CFLAGS) $(AOBJS:.o=.S) $(COBJS:.o=.c) > $@ + +sinclude .depend + +######################################################################### diff -Naurb u-boot-2004-08-24/lib_nios2/math.h u-boot-nios2/lib_nios2/math.h --- u-boot-2004-08-24/lib_nios2/math.h 1969-12-31 19:00:00.000000000 -0500 +++ u-boot-nios2/lib_nios2/math.h 2004-08-24 05:36:48.000000000 -0400 @@ -0,0 +1,16 @@ +#define BITS_PER_UNIT 8 + +typedef int HItype __attribute__ ((mode (HI))); +typedef unsigned int UHItype __attribute__ ((mode (HI))); + +typedef int SItype __attribute__ ((mode (SI))); +typedef unsigned int USItype __attribute__ ((mode (SI))); + +typedef int word_type __attribute__ ((mode (__word__))); + +struct SIstruct {HItype low, high;}; + +typedef union { + struct SIstruct s; + SItype ll; +} SIunion; diff -Naurb u-boot-2004-08-24/lib_nios2/mult.c u-boot-nios2/lib_nios2/mult.c --- u-boot-2004-08-24/lib_nios2/mult.c 1969-12-31 19:00:00.000000000 -0500 +++ u-boot-nios2/lib_nios2/mult.c 2004-08-24 05:36:48.000000000 -0400 @@ -0,0 +1,56 @@ +/* + * This file is part of GNU CC. + * + * GNU CC is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published + * by the Free Software Foundation; either version 2, or (at your + * option) any later version. + * + * GNU CC is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public + * License along with GNU CC; see the file COPYING. If not, write + * to the Free Software Foundation, 59 Temple Place - Suite 330, + * Boston, MA 02111-1307, USA. + */ + + +#include <common.h> + +#if !defined(CFG_NIOS_MULT_HW) && !defined(CFG_NIOS_MULT_MSTEP) + +#include "math.h" + +USItype __mulsi3 (USItype a, USItype b) +{ + USItype c = 0; + + while (a != 0) { + if (a & 1) + c += b; + a >>= 1; + b <<= 1; + } + + return c; +} + + +UHItype __mulhi3 (UHItype a, UHItype b) +{ + UHItype c = 0; + + while (a != 0) { + if (a & 1) + c += b; + a >>= 1; + b <<= 1; + } + + return c; +} + +#endif /*!defined(CFG_NIOS_MULT_HW) && !defined(CFG_NIOS_MULT_MSTEP) */ diff -Naurb u-boot-2004-08-24/lib_nios2/nios_linux.c u-boot-nios2/lib_nios2/nios_linux.c --- u-boot-2004-08-24/lib_nios2/nios_linux.c 1969-12-31 19:00:00.000000000 -0500 +++ u-boot-nios2/lib_nios2/nios_linux.c 2004-08-24 05:36:48.000000000 -0400 @@ -0,0 +1,32 @@ +/* + * (C) Copyright 2003, Psyent Corporation <www.psyent.com> + * Scott McNutt smcnutt@psyent.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> + +/* TODO + */ +void do_bootm_linux(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[], + ulong addr, ulong *len_ptr, int verify) +{ +} diff -Naurb u-boot-2004-08-24/lib_nios2/time.c u-boot-nios2/lib_nios2/time.c --- u-boot-2004-08-24/lib_nios2/time.c 1969-12-31 19:00:00.000000000 -0500 +++ u-boot-nios2/lib_nios2/time.c 2004-08-24 05:36:48.000000000 -0400 @@ -0,0 +1,39 @@ +/* + * (C) Copyright 2003, Psyent Corporation <www.psyent.com> + * Scott McNutt smcnutt@psyent.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <watchdog.h> + + +extern void dly_clks( unsigned long ticks ); + +void udelay(unsigned long usec) +{ + /* The Nios core doesn't have a timebase, so we do our + * best for now and call a low-level loop that counts + * cpu clocks. + */ + unsigned long cnt = (CONFIG_SYS_CLK_FREQ/1000000) * usec; + WATCHDOG_RESET (); /* trigger watchdog if needed */ + dly_clks (cnt); +}
Added, thanks.
Scott McNutt
