[PATCH v2] sandbox: fix a compilation error
With sandbox and sandbox64 configurations:
In file included from .../u-boot/include/test/test.h:156, from .../u-boot/include/test/lib.h:9, from .../u-boot/test/lib/test_crc8.c:8: .../u-boot/arch/sandbox/include/asm/test.h: In function ‘sandbox_sdl_set_bpp’: .../u-boot/arch/sandbox/include/asm/test.h:323:17: error: ‘ENOSYS’ undeclared (first use in this function) 323 | return -ENOSYS; | ^~~~~~
Per Tom Rini's suggestion: move that function prototype over to arch/sandbox/include/asm/sdl.h and make test/dm/video.c include <asm/sdl.h>
Cc: Simon Glass sjg@chromium.org Suggested-by: Tom Rini trini@konsulko.com Signed-off-by: Sergei Antonov saproj@gmail.com ---
v2: * move the function to another file instead of including <errno.h>
arch/sandbox/include/asm/sdl.h | 23 +++++++++++++++++++++++ arch/sandbox/include/asm/test.h | 25 ------------------------- test/dm/video.c | 1 + 3 files changed, 24 insertions(+), 25 deletions(-)
diff --git a/arch/sandbox/include/asm/sdl.h b/arch/sandbox/include/asm/sdl.h index 56dcb84803d3..ee4991f7c24a 100644 --- a/arch/sandbox/include/asm/sdl.h +++ b/arch/sandbox/include/asm/sdl.h @@ -7,6 +7,7 @@ #define __SANDBOX_SDL_H
#include <errno.h> +#include <video.h>
#ifdef CONFIG_SANDBOX_SDL
@@ -87,6 +88,22 @@ int sandbox_sdl_sound_stop(void); */ int sandbox_sdl_sound_init(int rate, int channels);
+/** + * sandbox_sdl_set_bpp() - Set the depth of the sandbox display + * + * The device must not be active when this function is called. It activiates it + * before returning. + * + * This updates the depth value and adjusts a few other settings accordingly. + * It must be called before the display is probed. + * + * @dev: Device to adjust + * @l2bpp: depth to set + * Return: 0 if the device was already active, other error if it fails to probe + * after the change + */ +int sandbox_sdl_set_bpp(struct udevice *dev, enum video_log2_bpp l2bpp); + #else static inline int sandbox_sdl_init_display(int width, int height, int log2_bpp, bool double_size) @@ -134,6 +151,12 @@ static inline int sandbox_sdl_sound_init(int rate, int channels) return -ENODEV; }
+static inline int sandbox_sdl_set_bpp(struct udevice *dev, + enum video_log2_bpp l2bpp) +{ + return -ENOSYS; +} + #endif
#endif diff --git a/arch/sandbox/include/asm/test.h b/arch/sandbox/include/asm/test.h index e482271fe975..17159f8d674a 100644 --- a/arch/sandbox/include/asm/test.h +++ b/arch/sandbox/include/asm/test.h @@ -8,7 +8,6 @@ #ifndef __ASM_TEST_H #define __ASM_TEST_H
-#include <video.h> #include <pci_ids.h>
struct unit_test_state; @@ -300,30 +299,6 @@ void sandbox_cros_ec_set_test_flags(struct udevice *dev, uint flags); */ int sandbox_cros_ec_get_pwm_duty(struct udevice *dev, uint index, uint *duty);
-#if IS_ENABLED(CONFIG_SANDBOX_SDL) -/** - * sandbox_sdl_set_bpp() - Set the depth of the sandbox display - * - * The device must not be active when this function is called. It activiates it - * before returning. - * - * This updates the depth value and adjusts a few other settings accordingly. - * It must be called before the display is probed. - * - * @dev: Device to adjust - * @l2bpp: depth to set - * Return: 0 if the device was already active, other error if it fails to probe - * after the change - */ -int sandbox_sdl_set_bpp(struct udevice *dev, enum video_log2_bpp l2bpp); -#else -static inline int sandbox_sdl_set_bpp(struct udevice *dev, - enum video_log2_bpp l2bpp) -{ - return -ENOSYS; -} -#endif - /** * sandbox_set_fake_efi_mgr_dev() - Control EFI bootmgr producing valid bootflow * diff --git a/test/dm/video.c b/test/dm/video.c index 30778157d940..1c63d16bd28b 100644 --- a/test/dm/video.c +++ b/test/dm/video.c @@ -15,6 +15,7 @@ #include <video.h> #include <video_console.h> #include <asm/test.h> +#include <asm/sdl.h> #include <dm/test.h> #include <dm/uclass-internal.h> #include <test/test.h>
Hi Sergei,
v2:
- move the function to another file instead of including <errno.h>
- sandbox_sdl_set_bpp() - Set the depth of the sandbox display
- The device must not be active when this function is called. It activiates it
- before returning.
- This updates the depth value and adjusts a few other settings accordingly.
- It must be called before the display is probed.
- @dev: Device to adjust
- @l2bpp: depth to set
- Return: 0 if the device was already active, other error if it fails to probe
- after the change
return -ENOSYS;
#endif
- before returning.
- after the change
return -ENOSYS;
-} -#endif
- sandbox_set_fake_efi_mgr_dev() - Control EFI bootmgr producing valid bootflow
The problem with this is it then cannot be built on non-sandbox boards. I think v1 was OK.
2.37.2
On Tue, Jun 13, 2023 at 03:58:25PM +0100, Simon Glass wrote:
Hi Sergei,
v2:
- before returning.
- after the change
return -ENOSYS;
#endif
- before returning.
- after the change
return -ENOSYS;
-} -#endif
I suggested this since the test is sandbox specific (the code itself is full of sandbox_foo).
Before the patch as well as after the patch: if CONFIG_SANDBOX_SDL declaration of sandbox_sdl_set_bpp() else definition of sandbox_sdl_set_bpp() returning error end This patch only moves code to another header file in arch/sandbox/include/asm. How can a non-sandbox build fail because of this patch?
Right, test/dm/video.c is for sandbox-only.
OK, yes.
OK, yes.
Applied to u-boot-dm, thanks!
Sergei Antonov
