[PATCH V2 1/2] clk: imx8mm: fix clk set parent
Fix clk set parent, so we could still have correct clocks after parent changing.
Signed-off-by: Peng Fan peng.fan@nxp.com ---
V2: Split fix into a single patch of https://patchwork.ozlabs.org/project/uboot/patch/20200503125956.6244-1-peng....
drivers/clk/imx/clk-imx8mm.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/drivers/clk/imx/clk-imx8mm.c b/drivers/clk/imx/clk-imx8mm.c index 66c9601b0c..d609fad7ac 100644 --- a/drivers/clk/imx/clk-imx8mm.c +++ b/drivers/clk/imx/clk-imx8mm.c @@ -191,7 +191,10 @@ static int imx8mm_clk_set_parent(struct clk *clk, struct clk *parent) if (ret) return ret;
- return clk_set_parent(c, cp); + ret = clk_set_parent(c, cp); + c->dev->parent = cp->dev; + + return ret; }
static struct clk_ops imx8mm_clk_ops = {
Add qspi clock
V2: Split a single patch from https://patchwork.ozlabs.org/project/uboot/patch/20200503125956.6244-1-peng....
drivers/clk/imx/clk-imx8mm.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/drivers/clk/imx/clk-imx8mm.c b/drivers/clk/imx/clk-imx8mm.c index d609fad7ac..4743394069 100644 --- a/drivers/clk/imx/clk-imx8mm.c +++ b/drivers/clk/imx/clk-imx8mm.c @@ -119,6 +119,9 @@ static const char *imx8mm_wdog_sels[] = {"clock-osc-24m", "sys_pll1_133m", "sys_ static const char *imx8mm_usdhc3_sels[] = {"clock-osc-24m", "sys_pll1_400m", "sys_pll1_800m", "sys_pll2_500m", "sys_pll3_out", "sys_pll1_266m", "audio_pll2_clk", "sys_pll1_100m", };
+static const char *imx8mm_qspi_sels[] = {"clock-osc-24m", "sys_pll1_400m", "sys_pll2_333m", "sys_pll2_500m", + "audio_pll2_out", "sys_pll1_266m", "sys_pll3_out", "sys_pll1_100m", }; + static ulong imx8mm_clk_get_rate(struct clk *clk) { struct clk *c; @@ -373,6 +376,8 @@ static int imx8mm_clk_probe(struct udevice *dev) clk_dm(IMX8MM_CLK_USDHC3, imx8m_clk_composite("usdhc3", imx8mm_usdhc3_sels, base + 0xbc80)); + clk_dm(IMX8MM_CLK_QSPI, + imx8m_clk_composite("qspi", imx8mm_qspi_sels, base + 0xab80));
clk_dm(IMX8MM_CLK_I2C1_ROOT, imx_clk_gate4("i2c1_root_clk", "i2c1", base + 0x4170, 0)); @@ -396,6 +401,8 @@ static int imx8mm_clk_probe(struct udevice *dev) imx_clk_gate4("wdog3_root_clk", "wdog", base + 0x4550, 0)); clk_dm(IMX8MM_CLK_USDHC3_ROOT, imx_clk_gate4("usdhc3_root_clk", "usdhc3", base + 0x45e0, 0)); + clk_dm(IMX8MM_CLK_QSPI_ROOT, + imx_clk_gate4("qspi_root_clk", "qspi", base + 0x42f0, 0));
/* clks not needed in SPL stage */ #ifndef CONFIG_SPL_BUILD
Peng Fan
