[U-Boot] Dragonboard410c and Dragonboard820c patchset
The following version fixes some nasty compiler warnings present in the previous version. Sorry about it.
For example to store the environment in a file named "/uboot.env" in MMC "0", where partition "1" contains the EXT4 filesystem, the following configs should be added to the board's default config:
CONFIG_ENV_IS_IN_EXT4=y CONFIG_ENV_EXT4_DEVICE_AND_PART="0:1" CONFIG_ENV_EXT4_FILE="/uboot.env" CONFIG_ENV_EXT4_INTERFACE="mmc"
Signed-off-by: Jorge Ramirez-Ortiz jorge.ramirez-ortiz@linaro.org --- env/Kconfig | 39 +++++++++++++++++++++++++++++++++++++++ env/env.c | 2 ++ env/ext4.c | 20 ++++++++++---------- 3 files changed, 51 insertions(+), 10 deletions(-)
diff --git a/env/Kconfig b/env/Kconfig index 2477bf8..71529b2 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -81,6 +81,13 @@ config ENV_IS_IN_FAT - CONFIG_FAT_WRITE: This must be enabled. Otherwise it cannot save the environment file.
+config ENV_IS_IN_EXT4 + bool "Environment is in a EXT4 filesystem" + depends on !CHAIN_OF_TRUST + select EXT4_WRITE + help + Define this if you want to use the EXT4 file system for the environment. + config ENV_IS_IN_FLASH bool "Environment in flash memory" depends on !CHAIN_OF_TRUST @@ -396,6 +403,38 @@ config ENV_FAT_FILE It's a string of the FAT file name. This file use to store the environment.
+config ENV_EXT4_INTERFACE + string "Name of the block device for the environment" + depends on ENV_IS_IN_EXT4 + help + Define this to a string that is the name of the block device. + +config ENV_EXT4_DEVICE_AND_PART + string "Device and partition for where to store the environemt in EXT4" + depends on ENV_IS_IN_EXT4 + help + Define this to a string to specify the partition of the device. It can + be as following: + + "D:P", "D:0", "D", "D:" or "D:auto" (D, P are integers. And P >= 1) + - "D:P": device D partition P. Error occurs if device D has no + partition table. + - "D:0": device D. + - "D" or "D:": device D partition 1 if device D has partition + table, or the whole device D if has no partition + table. + - "D:auto": first partition in device D with bootable flag set. + If none, first valid partition in device D. If no + partition table then means device D. + +config ENV_EXT4_FILE + string "Name of the EXT4 file to use for the environemnt" + depends on ENV_IS_IN_EXT4 + default "uboot.env" + help + It's a string of the EXT4 file name. This file use to store the + environment (explicit path to the file) + if ARCH_SUNXI
config ENV_OFFSET diff --git a/env/env.c b/env/env.c index 76a5608..7455632 100644 --- a/env/env.c +++ b/env/env.c @@ -32,6 +32,8 @@ static enum env_location env_get_default_location(void) return ENVL_EEPROM; else if IS_ENABLED(CONFIG_ENV_IS_IN_FAT) return ENVL_FAT; + else if IS_ENABLED(CONFIG_ENV_IS_IN_EXT4) + return ENVL_EXT4; else if IS_ENABLED(CONFIG_ENV_IS_IN_FLASH) return ENVL_FLASH; else if IS_ENABLED(CONFIG_ENV_IS_IN_MMC) diff --git a/env/ext4.c b/env/ext4.c index 6520221..07fd061 100644 --- a/env/ext4.c +++ b/env/ext4.c @@ -46,8 +46,8 @@ static int env_ext4_save(void) if (err) return err;
- part = blk_get_device_part_str(EXT4_ENV_INTERFACE, - EXT4_ENV_DEVICE_AND_PART, + part = blk_get_device_part_str(CONFIG_ENV_EXT4_INTERFACE, + CONFIG_ENV_EXT4_DEVICE_AND_PART, &dev_desc, &info, 1); if (part < 0) return 1; @@ -57,16 +57,16 @@ static int env_ext4_save(void)
if (!ext4fs_mount(info.size)) { printf("\n** Unable to use %s %s for saveenv **\n", - EXT4_ENV_INTERFACE, EXT4_ENV_DEVICE_AND_PART); + CONFIG_ENV_EXT4_INTERFACE, CONFIG_ENV_EXT4_DEVICE_AND_PART); return 1; }
- err = ext4fs_write(EXT4_ENV_FILE, (void *)&env_new, sizeof(env_t)); + err = ext4fs_write(CONFIG_ENV_EXT4_FILE, (void *)&env_new, sizeof(env_t)); ext4fs_close();
if (err == -1) { printf("\n** Unable to write "%s" from %s%d:%d **\n", - EXT4_ENV_FILE, EXT4_ENV_INTERFACE, dev, part); + CONFIG_ENV_EXT4_FILE, CONFIG_ENV_EXT4_INTERFACE, dev, part); return 1; }
@@ -84,8 +84,8 @@ static int env_ext4_load(void) int err; loff_t off;
- part = blk_get_device_part_str(EXT4_ENV_INTERFACE, - EXT4_ENV_DEVICE_AND_PART, + part = blk_get_device_part_str(CONFIG_ENV_EXT4_INTERFACE, + CONFIG_ENV_EXT4_DEVICE_AND_PART, &dev_desc, &info, 1); if (part < 0) goto err_env_relocate; @@ -95,16 +95,16 @@ static int env_ext4_load(void)
if (!ext4fs_mount(info.size)) { printf("\n** Unable to use %s %s for loading the env **\n", - EXT4_ENV_INTERFACE, EXT4_ENV_DEVICE_AND_PART); + CONFIG_ENV_EXT4_INTERFACE, CONFIG_ENV_EXT4_DEVICE_AND_PART); goto err_env_relocate; }
- err = ext4_read_file(EXT4_ENV_FILE, buf, 0, CONFIG_ENV_SIZE, &off); + err = ext4_read_file(CONFIG_ENV_EXT4_FILE, buf, 0, CONFIG_ENV_SIZE, &off); ext4fs_close();
if (err == -1) { printf("\n** Unable to read "%s" from %s%d:%d **\n", - EXT4_ENV_FILE, EXT4_ENV_INTERFACE, dev, part); + CONFIG_ENV_EXT4_FILE, CONFIG_ENV_EXT4_INTERFACE, dev, part); goto err_env_relocate; }
Signed-off-by: Jorge Ramirez-Ortiz jorge.ramirez-ortiz@linaro.org --- drivers/spmi/spmi-msm.c | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/drivers/spmi/spmi-msm.c b/drivers/spmi/spmi-msm.c index c226913..e9bfbb0 100644 --- a/drivers/spmi/spmi-msm.c +++ b/drivers/spmi/spmi-msm.c @@ -17,6 +17,11 @@
DECLARE_GLOBAL_DATA_PTR;
+ +/* PMIC Arbiter configuration registers */ +#define PMIC_ARB_VERSION 0x0000 +#define PMIC_ARB_VERSION_V2_MIN 0x20010000 + #define ARB_CHANNEL_OFFSET(n) (0x4 * (n)) #define SPMI_CH_OFFSET(chnl) ((chnl) * 0x8000)
@@ -148,6 +153,8 @@ static int msm_spmi_probe(struct udevice *dev) struct udevice *parent = dev->parent; struct msm_spmi_priv *priv = dev_get_priv(dev); int node = dev_of_offset(dev); + u32 hw_ver; + bool is_v1; int i;
priv->arb_chnl = devfdt_get_addr(dev); @@ -155,6 +162,12 @@ static int msm_spmi_probe(struct udevice *dev) dev_of_offset(parent), node, "reg", 1, NULL, false); priv->spmi_obs = fdtdec_get_addr_size_auto_parent(gd->fdt_blob, dev_of_offset(parent), node, "reg", 2, NULL, false); + + hw_ver = readl(priv->arb_chnl + PMIC_ARB_VERSION - 0x800); + is_v1 = (hw_ver < PMIC_ARB_VERSION_V2_MIN); + + dev_dbg(dev, "PMIC Arb Version-%d (0x%x)\n", (is_v1 ? 1 : 2), hw_ver); + if (priv->arb_chnl == FDT_ADDR_T_NONE || priv->spmi_core == FDT_ADDR_T_NONE || priv->spmi_obs == FDT_ADDR_T_NONE)
In preparation to add support for the Dragonboard820c (APQ8096), refactor the current Snapdragon clock driver.
No new functionality has been added.
Signed-off-by: Jorge Ramirez-Ortiz jorge.ramirez-ortiz@linaro.org --- arch/arm/mach-snapdragon/Makefile | 6 +- arch/arm/mach-snapdragon/clock-apq8016.c | 181 ++------------------- arch/arm/mach-snapdragon/clock-snapdragon.c | 134 +++++++++++++++ arch/arm/mach-snapdragon/clock-snapdragon.h | 40 +++++ .../mach-snapdragon/include/mach/sysmap-apq8016.h | 29 +++- 5 files changed, 217 insertions(+), 173 deletions(-) create mode 100644 arch/arm/mach-snapdragon/clock-snapdragon.c create mode 100644 arch/arm/mach-snapdragon/clock-snapdragon.h
diff --git a/arch/arm/mach-snapdragon/Makefile b/arch/arm/mach-snapdragon/Makefile index d82a04d..74f90dc 100644 --- a/arch/arm/mach-snapdragon/Makefile +++ b/arch/arm/mach-snapdragon/Makefile @@ -4,5 +4,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-y += clock-apq8016.o -obj-y += sysmap-apq8016.o +obj-$(CONFIG_TARGET_DRAGONBOARD410C) += clock-apq8016.o +obj-$(CONFIG_TARGET_DRAGONBOARD410C) += sysmap-apq8016.o +obj-y += clock-snapdragon.o + diff --git a/arch/arm/mach-snapdragon/clock-apq8016.c b/arch/arm/mach-snapdragon/clock-apq8016.c index da05015..a242417 100644 --- a/arch/arm/mach-snapdragon/clock-apq8016.c +++ b/arch/arm/mach-snapdragon/clock-apq8016.c @@ -14,146 +14,12 @@ #include <errno.h> #include <asm/io.h> #include <linux/bitops.h> +#include "clock-snapdragon.h"
/* GPLL0 clock control registers */ -#define GPLL0_STATUS 0x2101C #define GPLL0_STATUS_ACTIVE BIT(17) - -#define APCS_GPLL_ENA_VOTE 0x45000 #define APCS_GPLL_ENA_VOTE_GPLL0 BIT(0)
-/* vote reg for blsp1 clock */ -#define APCS_CLOCK_BRANCH_ENA_VOTE 0x45004 -#define APCS_CLOCK_BRANCH_ENA_VOTE_BLSP1 BIT(10) - -/* SDC(n) clock control registers; n=1,2 */ - -/* block control register */ -#define SDCC_BCR(n) ((n * 0x1000) + 0x41000) -/* cmd */ -#define SDCC_CMD_RCGR(n) ((n * 0x1000) + 0x41004) -/* cfg */ -#define SDCC_CFG_RCGR(n) ((n * 0x1000) + 0x41008) -/* m */ -#define SDCC_M(n) ((n * 0x1000) + 0x4100C) -/* n */ -#define SDCC_N(n) ((n * 0x1000) + 0x41010) -/* d */ -#define SDCC_D(n) ((n * 0x1000) + 0x41014) -/* branch control */ -#define SDCC_APPS_CBCR(n) ((n * 0x1000) + 0x41018) -#define SDCC_AHB_CBCR(n) ((n * 0x1000) + 0x4101C) - -/* BLSP1 AHB clock (root clock for BLSP) */ -#define BLSP1_AHB_CBCR 0x1008 - -/* Uart clock control registers */ -#define BLSP1_UART2_BCR 0x3028 -#define BLSP1_UART2_APPS_CBCR 0x302C -#define BLSP1_UART2_APPS_CMD_RCGR 0x3034 -#define BLSP1_UART2_APPS_CFG_RCGR 0x3038 -#define BLSP1_UART2_APPS_M 0x303C -#define BLSP1_UART2_APPS_N 0x3040 -#define BLSP1_UART2_APPS_D 0x3044 - -/* CBCR register fields */ -#define CBCR_BRANCH_ENABLE_BIT BIT(0) -#define CBCR_BRANCH_OFF_BIT BIT(31) - -struct msm_clk_priv { - phys_addr_t base; -}; - -/* Enable clock controlled by CBC soft macro */ -static void clk_enable_cbc(phys_addr_t cbcr) -{ - setbits_le32(cbcr, CBCR_BRANCH_ENABLE_BIT); - - while (readl(cbcr) & CBCR_BRANCH_OFF_BIT) - ; -} - -/* clock has 800MHz */ -static void clk_enable_gpll0(phys_addr_t base) -{ - if (readl(base + GPLL0_STATUS) & GPLL0_STATUS_ACTIVE) - return; /* clock already enabled */ - - setbits_le32(base + APCS_GPLL_ENA_VOTE, APCS_GPLL_ENA_VOTE_GPLL0); - - while ((readl(base + GPLL0_STATUS) & GPLL0_STATUS_ACTIVE) == 0) - ; -} - -#define APPS_CMD_RGCR_UPDATE BIT(0) - -/* Update clock command via CMD_RGCR */ -static void clk_bcr_update(phys_addr_t apps_cmd_rgcr) -{ - setbits_le32(apps_cmd_rgcr, APPS_CMD_RGCR_UPDATE); - - /* Wait for frequency to be updated. */ - while (readl(apps_cmd_rgcr) & APPS_CMD_RGCR_UPDATE) - ; -} - -struct bcr_regs { - uintptr_t cfg_rcgr; - uintptr_t cmd_rcgr; - uintptr_t M; - uintptr_t N; - uintptr_t D; -}; - -/* RCGR_CFG register fields */ -#define CFG_MODE_DUAL_EDGE (0x2 << 12) /* Counter mode */ - -/* sources */ -#define CFG_CLK_SRC_CXO (0 << 8) -#define CFG_CLK_SRC_GPLL0 (1 << 8) -#define CFG_CLK_SRC_MASK (7 << 8) - -/* Mask for supported fields */ -#define CFG_MASK 0x3FFF - -#define CFG_DIVIDER_MASK 0x1F - -/* root set rate for clocks with half integer and MND divider */ -static void clk_rcg_set_rate_mnd(phys_addr_t base, const struct bcr_regs *regs, - int div, int m, int n, int source) -{ - uint32_t cfg; - /* M value for MND divider. */ - uint32_t m_val = m; - /* NOT(N-M) value for MND divider. */ - uint32_t n_val = ~((n)-(m)) * !!(n); - /* NOT 2D value for MND divider. */ - uint32_t d_val = ~(n); - - /* Program MND values */ - writel(m_val, base + regs->M); - writel(n_val, base + regs->N); - writel(d_val, base + regs->D); - - /* setup src select and divider */ - cfg = readl(base + regs->cfg_rcgr); - cfg &= ~CFG_MASK; - cfg |= source & CFG_CLK_SRC_MASK; /* Select clock source */ - - /* Set the divider; HW permits fraction dividers (+0.5), but - for simplicity, we will support integers only */ - if (div) - cfg |= (2 * div - 1) & CFG_DIVIDER_MASK; - - if (n_val) - cfg |= CFG_MODE_DUAL_EDGE; - - writel(cfg, base + regs->cfg_rcgr); /* Write new clock configuration */ - - /* Inform h/w to start using the new config. */ - clk_bcr_update(base + regs->cmd_rcgr); -} - static const struct bcr_regs sdc_regs[] = { { .cfg_rcgr = SDCC_CFG_RCGR(1), @@ -171,7 +37,14 @@ static const struct bcr_regs sdc_regs[] = { } };
-/* Init clock for SDHCI controller */ +static struct gpll0_ctrl gpll0_ctrl = { + .status = GPLL0_STATUS, + .status_bit = GPLL0_STATUS_ACTIVE, + .ena_vote = APCS_GPLL_ENA_VOTE, + .vote_bit = APCS_GPLL_ENA_VOTE_GPLL0, +}; + +/* SDHCI */ static int clk_init_sdc(struct msm_clk_priv *priv, int slot, uint rate) { int div = 8; /* 100MHz default */ @@ -183,7 +56,7 @@ static int clk_init_sdc(struct msm_clk_priv *priv, int slot, uint rate) /* 800Mhz/div, gpll0 */ clk_rcg_set_rate_mnd(priv->base, &sdc_regs[slot], div, 0, 0, CFG_CLK_SRC_GPLL0); - clk_enable_gpll0(priv->base); + clk_enable_gpll0(priv->base, &gpll0_ctrl); clk_enable_cbc(priv->base + SDCC_APPS_CBCR(slot));
return rate; @@ -197,7 +70,7 @@ static const struct bcr_regs uart2_regs = { .D = BLSP1_UART2_APPS_D, };
-/* Init UART clock, 115200 */ +/* UART: 115200 */ static int clk_init_uart(struct msm_clk_priv *priv) { /* Enable iface clk */ @@ -205,7 +78,7 @@ static int clk_init_uart(struct msm_clk_priv *priv) /* 7372800 uart block clock @ GPLL0 */ clk_rcg_set_rate_mnd(priv->base, &uart2_regs, 1, 144, 15625, CFG_CLK_SRC_GPLL0); - clk_enable_gpll0(priv->base); + clk_enable_gpll0(priv->base, &gpll0_ctrl); /* Enable core clk */ clk_enable_cbc(priv->base + BLSP1_UART2_APPS_CBCR);
@@ -230,33 +103,3 @@ ulong msm_set_rate(struct clk *clk, ulong rate) return 0; } } - -static int msm_clk_probe(struct udevice *dev) -{ - struct msm_clk_priv *priv = dev_get_priv(dev); - - priv->base = devfdt_get_addr(dev); - if (priv->base == FDT_ADDR_T_NONE) - return -EINVAL; - - return 0; -} - -static struct clk_ops msm_clk_ops = { - .set_rate = msm_set_rate, -}; - -static const struct udevice_id msm_clk_ids[] = { - { .compatible = "qcom,gcc-msm8916" }, - { .compatible = "qcom,gcc-apq8016" }, - { } -}; - -U_BOOT_DRIVER(clk_msm) = { - .name = "clk_msm", - .id = UCLASS_CLK, - .of_match = msm_clk_ids, - .ops = &msm_clk_ops, - .priv_auto_alloc_size = sizeof(struct msm_clk_priv), - .probe = msm_clk_probe, -}; diff --git a/arch/arm/mach-snapdragon/clock-snapdragon.c b/arch/arm/mach-snapdragon/clock-snapdragon.c new file mode 100644 index 0000000..da44544 --- /dev/null +++ b/arch/arm/mach-snapdragon/clock-snapdragon.c @@ -0,0 +1,134 @@ +/* + * Clock drivers for Qualcomm APQ8016, APQ8096 + * + * (C) Copyright 2015 Mateusz Kulikowski mateusz.kulikowski@gmail.com + * + * Based on Little Kernel driver, simplified + * + * SPDX-License-Identifier: BSD-3-Clause + */ + +#include <common.h> +#include <clk-uclass.h> +#include <dm.h> +#include <errno.h> +#include <asm/io.h> +#include <linux/bitops.h> +#include "clock-snapdragon.h" + +/* CBCR register fields */ +#define CBCR_BRANCH_ENABLE_BIT BIT(0) +#define CBCR_BRANCH_OFF_BIT BIT(31) + +extern ulong msm_set_rate(struct clk *clk, ulong rate); + +/* Enable clock controlled by CBC soft macro */ +void clk_enable_cbc(phys_addr_t cbcr) +{ + setbits_le32(cbcr, CBCR_BRANCH_ENABLE_BIT); + + while (readl(cbcr) & CBCR_BRANCH_OFF_BIT) + ; +} + +void clk_enable_gpll0(phys_addr_t base, const struct gpll0_ctrl *gpll0) +{ + if (readl(base + gpll0->status) & gpll0->status_bit) + return; /* clock already enabled */ + + setbits_le32(base + gpll0->ena_vote, gpll0->vote_bit); + + while ((readl(base + gpll0->status) & gpll0->status_bit) == 0) + ; +} + +#define APPS_CMD_RGCR_UPDATE BIT(0) + +/* Update clock command via CMD_RGCR */ +void clk_bcr_update(phys_addr_t apps_cmd_rgcr) +{ + setbits_le32(apps_cmd_rgcr, APPS_CMD_RGCR_UPDATE); + + /* Wait for frequency to be updated. */ + while (readl(apps_cmd_rgcr) & APPS_CMD_RGCR_UPDATE) + ; +} + +#define CFG_MODE_DUAL_EDGE (0x2 << 12) /* Counter mode */ + +#define CFG_MASK 0x3FFF + +#define CFG_DIVIDER_MASK 0x1F + +/* root set rate for clocks with half integer and MND divider */ +void clk_rcg_set_rate_mnd(phys_addr_t base, const struct bcr_regs *regs, + int div, int m, int n, int source) +{ + uint32_t cfg; + /* M value for MND divider. */ + uint32_t m_val = m; + /* NOT(N-M) value for MND divider. */ + uint32_t n_val = ~((n)-(m)) * !!(n); + /* NOT 2D value for MND divider. */ + uint32_t d_val = ~(n); + + /* Program MND values */ + writel(m_val, base + regs->M); + writel(n_val, base + regs->N); + writel(d_val, base + regs->D); + + /* setup src select and divider */ + cfg = readl(base + regs->cfg_rcgr); + cfg &= ~CFG_MASK; + cfg |= source & CFG_CLK_SRC_MASK; /* Select clock source */ + + /* Set the divider; HW permits fraction dividers (+0.5), but + for simplicity, we will support integers only */ + if (div) + cfg |= (2 * div - 1) & CFG_DIVIDER_MASK; + + if (n_val) + cfg |= CFG_MODE_DUAL_EDGE; + + writel(cfg, base + regs->cfg_rcgr); /* Write new clock configuration */ + + /* Inform h/w to start using the new config. */ + clk_bcr_update(base + regs->cmd_rcgr); +} + +static int msm_clk_probe(struct udevice *dev) +{ + struct msm_clk_priv *priv = dev_get_priv(dev); + + priv->base = devfdt_get_addr(dev); + if (priv->base == FDT_ADDR_T_NONE) + return -EINVAL; + + return 0; +} + +static ulong msm_clk_set_rate(struct clk *clk, ulong rate) +{ + return msm_set_rate(clk, rate); +} + +static struct clk_ops msm_clk_ops = { + .set_rate = msm_clk_set_rate, +}; + +static const struct udevice_id msm_clk_ids[] = { + { .compatible = "qcom,gcc-msm8916" }, + { .compatible = "qcom,gcc-apq8016" }, + { .compatible = "qcom,gcc-msm8996" }, + { .compatible = "qcom,gcc-apq8096" }, + { } +}; + +U_BOOT_DRIVER(clk_msm) = { + .name = "clk_msm", + .id = UCLASS_CLK, + .of_match = msm_clk_ids, + .ops = &msm_clk_ops, + .priv_auto_alloc_size = sizeof(struct msm_clk_priv), + .probe = msm_clk_probe, +}; diff --git a/arch/arm/mach-snapdragon/clock-snapdragon.h b/arch/arm/mach-snapdragon/clock-snapdragon.h new file mode 100644 index 0000000..c087eb9 --- /dev/null +++ b/arch/arm/mach-snapdragon/clock-snapdragon.h @@ -0,0 +1,40 @@ +/* + * Qualcomm APQ8016, APQ8096 + * + * (C) Copyright 2017 Jorge Ramirez-Ortiz jorge.ramirez-ortiz@linaro.org + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#ifndef _CLOCK_SNAPDRAGON_H +#define _CLOCK_SNAPDRAGON_H + +#define CFG_CLK_SRC_CXO (0 << 8) +#define CFG_CLK_SRC_GPLL0 (1 << 8) +#define CFG_CLK_SRC_MASK (7 << 8) + +struct gpll0_ctrl { + uintptr_t status; + int status_bit; + uintptr_t ena_vote; + int vote_bit; +}; + +struct bcr_regs { + uintptr_t cfg_rcgr; + uintptr_t cmd_rcgr; + uintptr_t M; + uintptr_t N; + uintptr_t D; +}; + +struct msm_clk_priv { + phys_addr_t base; +}; + +void clk_enable_gpll0(phys_addr_t base, const struct gpll0_ctrl *pll0); +void clk_bcr_update(phys_addr_t apps_cmd_rgcr); +void clk_enable_cbc(phys_addr_t cbcr); +void clk_rcg_set_rate_mnd(phys_addr_t base, const struct bcr_regs *regs, + int div, int m, int n, int source); + +#endif diff --git a/arch/arm/mach-snapdragon/include/mach/sysmap-apq8016.h b/arch/arm/mach-snapdragon/include/mach/sysmap-apq8016.h index cdbfad0..1094b14 100644 --- a/arch/arm/mach-snapdragon/include/mach/sysmap-apq8016.h +++ b/arch/arm/mach-snapdragon/include/mach/sysmap-apq8016.h @@ -8,7 +8,32 @@ #ifndef _MACH_SYSMAP_APQ8016_H #define _MACH_SYSMAP_APQ8016_H
-#define GICD_BASE 0x0b000000 -#define GICC_BASE 0x0a20c000 +#define GICD_BASE (0x0b000000) +#define GICC_BASE (0x0a20c000) + +/* Clocks: (from CLK_CTL_BASE) */ +#define GPLL0_STATUS (0x2101C) +#define APCS_GPLL_ENA_VOTE (0x45000) + +#define SDCC_BCR(n) ((n * 0x1000) + 0x41000) +#define SDCC_CMD_RCGR(n) ((n * 0x1000) + 0x41004) +#define SDCC_CFG_RCGR(n) ((n * 0x1000) + 0x41008) +#define SDCC_M(n) ((n * 0x1000) + 0x4100C) +#define SDCC_N(n) ((n * 0x1000) + 0x41010) +#define SDCC_D(n) ((n * 0x1000) + 0x41014) +#define SDCC_APPS_CBCR(n) ((n * 0x1000) + 0x41018) +#define SDCC_AHB_CBCR(n) ((n * 0x1000) + 0x4101C) + +/* BLSP1 AHB clock (root clock for BLSP) */ +#define BLSP1_AHB_CBCR 0x1008 + +/* Uart clock control registers */ +#define BLSP1_UART2_BCR (0x3028) +#define BLSP1_UART2_APPS_CBCR (0x302C) +#define BLSP1_UART2_APPS_CMD_RCGR (0x3034) +#define BLSP1_UART2_APPS_CFG_RCGR (0x3038) +#define BLSP1_UART2_APPS_M (0x303C) +#define BLSP1_UART2_APPS_N (0x3040) +#define BLSP1_UART2_APPS_D (0x3044)
#endif
This commit adds support for 96Boards Dragonboard820C.
The board is based on APQ8086 Qualcomm Soc, complying with the 96Boards specification.
Features - 4x Kyro CPU (64 bit) up to 2.15GHz - USB2.0 - USB3.0 - ISP - Qualcomm Hexagon DSP - SD 3.0 (UHS-I) - UFS 2.0 - Qualcomm Adreno 530 GPU - GPS - BT 4.2 - Wi-Fi 2.4GHz, 5GHz (802.11ac) - PCIe 2.0 - MIPI-CSI, MIPI-DSI - I2S
U-Boot boots chained from LK (LK implements the fastboot protocol) in 64-bit mode.
For detailed build instructions see readme.txt in the board directory.
Signed-off-by: Jorge Ramirez-Ortiz jorge.ramirez-ortiz@linaro.org --- arch/arm/dts/Makefile | 3 +- arch/arm/dts/dragonboard820c.dts | 65 +++ arch/arm/mach-snapdragon/Kconfig | 10 + arch/arm/mach-snapdragon/Makefile | 2 + arch/arm/mach-snapdragon/clock-apq8096.c | 62 +++ .../mach-snapdragon/include/mach/sysmap-apq8096.h | 29 ++ arch/arm/mach-snapdragon/sysmap-apq8096.c | 32 ++ board/qualcomm/dragonboard820c/Kconfig | 15 + board/qualcomm/dragonboard820c/MAINTAINERS | 6 + board/qualcomm/dragonboard820c/Makefile | 8 + board/qualcomm/dragonboard820c/dragonboard820c.c | 128 ++++++ board/qualcomm/dragonboard820c/head.S | 34 ++ board/qualcomm/dragonboard820c/readme.txt | 463 +++++++++++++++++++++ board/qualcomm/dragonboard820c/u-boot.lds | 106 +++++ configs/dragonboard820c_defconfig | 37 ++ include/configs/dragonboard820c.h | 72 ++++ 16 files changed, 1071 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/dragonboard820c.dts create mode 100644 arch/arm/mach-snapdragon/clock-apq8096.c create mode 100644 arch/arm/mach-snapdragon/include/mach/sysmap-apq8096.h create mode 100644 arch/arm/mach-snapdragon/sysmap-apq8096.c create mode 100644 board/qualcomm/dragonboard820c/Kconfig create mode 100644 board/qualcomm/dragonboard820c/MAINTAINERS create mode 100644 board/qualcomm/dragonboard820c/Makefile create mode 100644 board/qualcomm/dragonboard820c/dragonboard820c.c create mode 100644 board/qualcomm/dragonboard820c/head.S create mode 100644 board/qualcomm/dragonboard820c/readme.txt create mode 100644 board/qualcomm/dragonboard820c/u-boot.lds create mode 100644 configs/dragonboard820c_defconfig create mode 100644 include/configs/dragonboard820c.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index ed85349..df85e71 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -211,7 +211,8 @@ dtb-$(CONFIG_FSL_LSCH2) += fsl-ls1043a-qds-duart.dtb \ fsl-ls1012a-rdb.dtb \ fsl-ls1012a-frdm.dtb
-dtb-$(CONFIG_ARCH_SNAPDRAGON) += dragonboard410c.dtb +dtb-$(CONFIG_TARGET_DRAGONBOARD410C) += dragonboard410c.dtb +dtb-$(CONFIG_TARGET_DRAGONBOARD820C) += dragonboard820c.dtb
dtb-$(CONFIG_STM32F7) += stm32f746-disco.dtb \ stm32f769-disco.dtb diff --git a/arch/arm/dts/dragonboard820c.dts b/arch/arm/dts/dragonboard820c.dts new file mode 100644 index 0000000..bad5a1e --- /dev/null +++ b/arch/arm/dts/dragonboard820c.dts @@ -0,0 +1,65 @@ +/* + * Qualcomm APQ8096 based Dragonboard 820C board device tree source + * + * (C) Copyright 2017 Jorge Ramirez-Ortiz jorge.ramirez-ortiz@linaro.org + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; + +#include "skeleton64.dtsi" + +/ { + model = "Qualcomm Technologies, Inc. DB820c"; + compatible = "arrow,apq8096-db820c", "qcom,apq8096-sbc"; + #address-cells = <2>; + #size-cells = <2>; + + aliases { + serial0 = &blsp2_uart1; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + memory { + device_type = "memory"; + reg = <0 0x80000000 0 0xc0000000>; + }; + + psci { + compatible = "arm,psci-1.0"; + method = "smc"; + }; + + soc: soc { + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0 0xffffffff>; + compatible = "simple-bus"; + + gcc: clock-controller@300000 { + compatible = "qcom,gcc-msm8996"; + #clock-cells = <1>; + #reset-cells = <1>; + #power-domain-cells = <1>; + reg = <0x300000 0x90000>; + }; + + blsp2_uart1: serial@75b0000 { + compatible = "qcom,msm-uartdm-v1.4", "qcom,msm-uartdm"; + reg = <0x75b0000 0x1000>; + }; + + sdhc2: sdhci@74a4900 { + compatible = "qcom,sdhci-msm-v4"; + reg = <0x74a4900 0x314>, <0x74a4000 0x800>; + index = <0x0>; + bus-width = <4>; + clock = <&gcc 0>; + clock-frequency = <200000000>; + }; + }; +}; diff --git a/arch/arm/mach-snapdragon/Kconfig b/arch/arm/mach-snapdragon/Kconfig index dc7ba21..d55dc1a 100644 --- a/arch/arm/mach-snapdragon/Kconfig +++ b/arch/arm/mach-snapdragon/Kconfig @@ -19,8 +19,18 @@ config TARGET_DRAGONBOARD410C - HDMI - 20-pin low speed and 40-pin high speed expanders, 4 LED, 3 buttons
+config TARGET_DRAGONBOARD820C + bool "96Boards Dragonboard 820C" + help + Support for 96Boards Dragonboard 820C. This board complies with + 96Board Open Platform Specifications. Features: + - Qualcomm Snapdragon 820C SoC - APQ8096 (4xKyro CPU) + - 3GiB RAM + - 32GiB UFS drive + endchoice
source "board/qualcomm/dragonboard410c/Kconfig" +source "board/qualcomm/dragonboard820c/Kconfig"
endif diff --git a/arch/arm/mach-snapdragon/Makefile b/arch/arm/mach-snapdragon/Makefile index 74f90dc..7f35c79 100644 --- a/arch/arm/mach-snapdragon/Makefile +++ b/arch/arm/mach-snapdragon/Makefile @@ -4,6 +4,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
+obj-$(CONFIG_TARGET_DRAGONBOARD820C) += clock-apq8096.o +obj-$(CONFIG_TARGET_DRAGONBOARD820C) += sysmap-apq8096.o obj-$(CONFIG_TARGET_DRAGONBOARD410C) += clock-apq8016.o obj-$(CONFIG_TARGET_DRAGONBOARD410C) += sysmap-apq8016.o obj-y += clock-snapdragon.o diff --git a/arch/arm/mach-snapdragon/clock-apq8096.c b/arch/arm/mach-snapdragon/clock-apq8096.c new file mode 100644 index 0000000..3224812 --- /dev/null +++ b/arch/arm/mach-snapdragon/clock-apq8096.c @@ -0,0 +1,62 @@ +/* + * Clock drivers for Qualcomm APQ8096 + * + * (C) Copyright 2017 Jorge Ramirez Ortiz jorge.ramirez-ortiz@linaro.org + * + * Based on Little Kernel driver, simplified + * + * SPDX-License-Identifier: BSD-3-Clause + */ + +#include <common.h> +#include <clk-uclass.h> +#include <dm.h> +#include <errno.h> +#include <asm/io.h> +#include <linux/bitops.h> +#include "clock-snapdragon.h" + +/* GPLL0 clock control registers */ +#define GPLL0_STATUS_ACTIVE BIT(30) +#define APCS_GPLL_ENA_VOTE_GPLL0 BIT(0) + +static const struct bcr_regs sdc_regs = { + .cfg_rcgr = SDCC2_CFG_RCGR, + .cmd_rcgr = SDCC2_CMD_RCGR, + .M = SDCC2_M, + .N = SDCC2_N, + .D = SDCC2_D, +}; + +static const struct gpll0_ctrl gpll0_ctrl = { + .status = GPLL0_STATUS, + .status_bit = GPLL0_STATUS_ACTIVE, + .ena_vote = APCS_GPLL_ENA_VOTE, + .vote_bit = APCS_GPLL_ENA_VOTE_GPLL0, +}; + +static int clk_init_sdc(struct msm_clk_priv *priv, uint rate) +{ + int div = 3; + + clk_enable_cbc(priv->base + SDCC2_AHB_CBCR); + clk_rcg_set_rate_mnd(priv->base, &sdc_regs, div, 0, 0, + CFG_CLK_SRC_GPLL0); + clk_enable_gpll0(priv->base, &gpll0_ctrl); + clk_enable_cbc(priv->base + SDCC2_APPS_CBCR); + + return rate; +} + +ulong msm_set_rate(struct clk *clk, ulong rate) +{ + struct msm_clk_priv *priv = dev_get_priv(clk->dev); + + switch (clk->id) { + case 0: /* SDC1 */ + return clk_init_sdc(priv, rate); + break; + default: + return 0; + } +} diff --git a/arch/arm/mach-snapdragon/include/mach/sysmap-apq8096.h b/arch/arm/mach-snapdragon/include/mach/sysmap-apq8096.h new file mode 100644 index 0000000..fb89de2 --- /dev/null +++ b/arch/arm/mach-snapdragon/include/mach/sysmap-apq8096.h @@ -0,0 +1,29 @@ +/* + * Qualcomm APQ8096 sysmap + * + * (C) Copyright 2017 Jorge Ramirez-Ortiz jorge.ramirez-ortiz@linaro.org + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#ifndef _MACH_SYSMAP_APQ8096_H +#define _MACH_SYSMAP_APQ8096_H + +#define TLMM_BASE_ADDR (0x1010000) + +/* Strength (sdc1) */ +#define SDC1_HDRV_PULL_CTL_REG (TLMM_BASE_ADDR + 0x0012D000) + +/* Clocks: (from CLK_CTL_BASE) */ +#define GPLL0_STATUS (0x0000) +#define APCS_GPLL_ENA_VOTE (0x52000) + +#define SDCC2_BCR (0x14000) /* block reset */ +#define SDCC2_APPS_CBCR (0x14004) /* branch control */ +#define SDCC2_AHB_CBCR (0x14008) +#define SDCC2_CMD_RCGR (0x14010) +#define SDCC2_CFG_RCGR (0x14014) +#define SDCC2_M (0x14018) +#define SDCC2_N (0x1401C) +#define SDCC2_D (0x14020) + +#endif diff --git a/arch/arm/mach-snapdragon/sysmap-apq8096.c b/arch/arm/mach-snapdragon/sysmap-apq8096.c new file mode 100644 index 0000000..cb6d1e4 --- /dev/null +++ b/arch/arm/mach-snapdragon/sysmap-apq8096.c @@ -0,0 +1,32 @@ +/* + * Qualcomm APQ8096 memory map + * + * (C) Copyright 2017 Jorge Ramirez Ortiz jorge.ramirez-ortiz@linaro.org + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/armv8/mmu.h> + +static struct mm_region apq8096_mem_map[] = { + { + .virt = 0x0UL, /* Peripheral block */ + .phys = 0x0UL, /* Peripheral block */ + .size = 0x10000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN + }, { + .virt = 0x80000000UL, /* DDR */ + .phys = 0x80000000UL, /* DDR */ + .size = 0xC0000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE + }, { + /* List terminator */ + 0, + } +}; + +struct mm_region *mem_map = apq8096_mem_map; diff --git a/board/qualcomm/dragonboard820c/Kconfig b/board/qualcomm/dragonboard820c/Kconfig new file mode 100644 index 0000000..aff9af5 --- /dev/null +++ b/board/qualcomm/dragonboard820c/Kconfig @@ -0,0 +1,15 @@ +if TARGET_DRAGONBOARD820C + +config SYS_BOARD + default "dragonboard820c" + +config SYS_VENDOR + default "qualcomm" + +config SYS_SOC + default "apq8096" + +config SYS_CONFIG_NAME + default "dragonboard820c" + +endif diff --git a/board/qualcomm/dragonboard820c/MAINTAINERS b/board/qualcomm/dragonboard820c/MAINTAINERS new file mode 100644 index 0000000..a157033 --- /dev/null +++ b/board/qualcomm/dragonboard820c/MAINTAINERS @@ -0,0 +1,6 @@ +DRAGONBOARD820C BOARD +M: Jorge Ramirez-Ortiz jorge.ramirez-ortiz@linaro.org +S: Maintained +F: board/qualcomm/dragonboard820c/ +F: include/configs/dragonboard820c.h +F: configs/dragonboard820c_defconfig diff --git a/board/qualcomm/dragonboard820c/Makefile b/board/qualcomm/dragonboard820c/Makefile new file mode 100644 index 0000000..a1ce4b2 --- /dev/null +++ b/board/qualcomm/dragonboard820c/Makefile @@ -0,0 +1,8 @@ +# +# (C) Copyright 2017 Jorge Ramirez-Ortiz jorge.ramirez-ortiz@gmail.com +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := dragonboard820c.o +extra-y += head.o diff --git a/board/qualcomm/dragonboard820c/dragonboard820c.c b/board/qualcomm/dragonboard820c/dragonboard820c.c new file mode 100644 index 0000000..8f40ba4 --- /dev/null +++ b/board/qualcomm/dragonboard820c/dragonboard820c.c @@ -0,0 +1,128 @@ +/* + * Board init file for Dragonboard 820C + * + * (C) Copyright 2017 Jorge Ramirez-Ortiz jorge.ramirez-ortiz@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <asm/arch/sysmap-apq8096.h> +#include <linux/arm-smccc.h> +#include <linux/psci.h> +#include <common.h> +#include <dm.h> +#include <asm/io.h> +#include <linux/bitops.h> +#include <asm/psci.h> + +DECLARE_GLOBAL_DATA_PTR; + +int dram_init(void) +{ + gd->ram_size = PHYS_SDRAM_SIZE; + + return 0; +} + +int dram_init_banksize(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + + gd->bd->bi_dram[1].start = PHYS_SDRAM_2; + gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE; + + return 0; +} + +static void sdhci_power_init(void) +{ + const uint32_t TLMM_PULL_MASK = 0x3; + const uint32_t TLMM_HDRV_MASK = 0x7; + + struct tlmm_cfg { + uint32_t bit; /* bit in the register */ + uint8_t mask; /* mask clk/dat/cmd control */ + uint8_t val; + }; + + /* bit offsets in the sdc tlmm register */ + enum { SDC1_DATA_HDRV = 0, + SDC1_CMD_HDRV = 3, + SDC1_CLK_HDRV = 6, + SDC1_DATA_PULL = 9, + SDC1_CMD_PULL = 11, + SDC1_CLK_PULL = 13, + SDC1_RCLK_PULL = 15, + }; + + enum { TLMM_PULL_DOWN = 0x1, + TLMM_PULL_UP = 0x3, + TLMM_NO_PULL = 0x0, + }; + + enum { TLMM_CUR_VAL_10MA = 0x04, + TLMM_CUR_VAL_16MA = 0x07, + }; + int i; + + /* drive strength configs for sdhc pins */ + const struct tlmm_cfg hdrv[] = + { + { SDC1_CLK_HDRV, TLMM_CUR_VAL_16MA, TLMM_HDRV_MASK, }, + { SDC1_CMD_HDRV, TLMM_CUR_VAL_10MA, TLMM_HDRV_MASK, }, + { SDC1_DATA_HDRV, TLMM_CUR_VAL_10MA, TLMM_HDRV_MASK, }, + }; + + /* pull configs for sdhc pins */ + const struct tlmm_cfg pull[] = + { + { SDC1_CLK_PULL, TLMM_NO_PULL, TLMM_PULL_MASK, }, + { SDC1_CMD_PULL, TLMM_PULL_UP, TLMM_PULL_MASK, }, + { SDC1_DATA_PULL, TLMM_PULL_UP, TLMM_PULL_MASK, }, + }; + + const struct tlmm_cfg rclk[] = + { + { SDC1_RCLK_PULL, TLMM_PULL_DOWN, TLMM_PULL_MASK,}, + }; + + for (i = 0; i < ARRAY_SIZE(hdrv); i++) + clrsetbits_le32(SDC1_HDRV_PULL_CTL_REG, + hdrv[i].mask << hdrv[i].bit, + hdrv[i].val << hdrv[i].bit); + + for (i = 0; i < ARRAY_SIZE(pull); i++) + clrsetbits_le32(SDC1_HDRV_PULL_CTL_REG, + pull[i].mask << pull[i].bit, + pull[i].val << pull[i].bit); + + for (i = 0; i < ARRAY_SIZE(rclk); i++) + clrsetbits_le32(SDC1_HDRV_PULL_CTL_REG, + rclk[i].mask << rclk[i].bit, + rclk[i].val << rclk[i].bit); +} + +static void show_psci_version(void) +{ + struct arm_smccc_res res; + + arm_smccc_smc(ARM_PSCI_0_2_FN_PSCI_VERSION, 0, 0, 0, 0, 0, 0, 0, &res); + + printf("PSCI: v%ld.%ld\n", + PSCI_VERSION_MAJOR(res.a0), + PSCI_VERSION_MINOR(res.a0)); +} + +int board_init(void) +{ + sdhci_power_init(); + show_psci_version(); + + return 0; +} + +void reset_cpu(ulong addr) +{ + psci_system_reset(); +} diff --git a/board/qualcomm/dragonboard820c/head.S b/board/qualcomm/dragonboard820c/head.S new file mode 100644 index 0000000..06d82d5 --- /dev/null +++ b/board/qualcomm/dragonboard820c/head.S @@ -0,0 +1,34 @@ +/* + * ARM64 header for proper chain-loading with Little Kernel. + * + * Little Kernel shipped with Dragonboard820C boots standard Linux images for + * ARM64. This file adds header that is required to boot U-Boot properly. + * + * For details see: + * https://www.kernel.org/doc/Documentation/arm64/booting.txt + * + * (C) Copyright 2015 Mateusz Kulikowski mateusz.kulikowski@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <config.h> + +/* + * per document in linux/Doc/arm64/booting.text + */ +.global _arm64_header +_arm64_header: + b _start + .word 0 + .quad CONFIG_SYS_TEXT_BASE-PHYS_SDRAM_1 /* Image load offset, LE */ + .quad 0 /* Effective size of kernel image, little-endian */ + .quad 0 /* kernel flags, little-endian */ + .quad 0 /* reserved */ + .quad 0 /* reserved */ + .quad 0 /* reserved */ + .byte 0x41 /* Magic number, "ARM\x64" */ + .byte 0x52 + .byte 0x4d + .byte 0x64 + .word 0 /* reserved (used for PE COFF offset) */ diff --git a/board/qualcomm/dragonboard820c/readme.txt b/board/qualcomm/dragonboard820c/readme.txt new file mode 100644 index 0000000..88adb85 --- /dev/null +++ b/board/qualcomm/dragonboard820c/readme.txt @@ -0,0 +1,463 @@ +# +# (C) Copyright 2017 Jorge Ramirez-Ortiz jorge.ramirez-ortiz@linaro.org +# +# SPDX-License-Identifier: GPL-2.0+ +# + +================================================================================ + What is working (enough to boot a distro from SD card) +================================================================================ + - UART + - SD card + - PSCI reset + - Environment in EXT4 partition 1 in SD card (check defconfig for details) + dont forget to insert the card in the SD slot before booting if you + are going to make mods to the environment + +================================================================================ + Build & Run instructions +================================================================================ + +1) Install mkbootimg and dtbTool from Codeaurora: + + git://codeaurora.org/quic/kernel/skales + commit 8492547e404e969262d9070dee9bdd15668bb70f worked for me. + +2) Setup CROSS_COMPILE to aarch64 compiler or if you use ccache just do + CROSS_COMPILE="ccache aarch64-linux-gnu-" + +3) cd to the u-boot tree + + $ make dragonboard820c_config + $ make -j `nproc` + +4) generate fake, empty ramdisk (can have 0 bytes) + + $ touch rd + +5) Generate qualcomm device tree table with dtbTool + + $ dtbTool -o dt.img arch/arm/dts + +6) Generate Android boot image with mkbootimg: + + $ mkbootimg --kernel=u-boot-dtb.bin \ + --output=u-boot.img \ + --dt=dt.img \ + --pagesize 4096 \ + --base 0x80000000 \ + --ramdisk=rd \ + --cmdline="" + +7) Reboot the board into fastboot mode + - plug the board micro-usb to your laptop usb host. + - reboot the board with vol- button pressed + +8) Boot the uboot image using fastboot + + $ fastboot boot u-boot.img + + or flash it to the UFS drive boot partition: + + $ fastboot flash boot u-boot.img + $ fastboot reboot + + +================================================================================ + To boot a linux kernel from SDHCI with the ROOTFS on an NFS share: +================================================================================ + +1) create an EXT4 partition on the SD card (must be partition #1) + +2) build the kernel image and dtb (documented extensively somewhere else) + +3) copy the drivers to the NFS partition (ie: 192.168.1.2 /exports/db820c-rootfs) + +4) add the u-boot headers to the image: + + $ mkimage -A arm64 \ + -O linux \ + -C none \ + -T kernel \ + -a 0x80080000 \ + -e 0x80080000 \ + -n Dragonboard820c \ + -d $kernel/arch/arm64/boot/Image \ + uImage + +5) copy the generated uImage and the device tree binary to the SD card EXT4 + partition + + $ cp uImage /mnt/boot/ + $ cp apq8096-db820c.dtb /mnt/boot/ + +6) on the SD card create /extlinux/extlinux.conf as follows: + + default nfs + prompt 1 + timeout 10 + + LABEL nfs + MENU NFS entry + LINUX /uImage + FDT /apq8096-db820c.dtb + APPEND root=/dev/nfs rw \ + nfsroot=192.168.1.2:/exports/db829c-rootfs,v3,tcp \ + rootwait \ + ip=dhcp consoleblank=0 \ + console=tty0 \ + console=ttyMSM0,115200n8 \ + earlyprintk earlycon=msm_serial_dm,0x75b0000 \ + androidboot.bootdevice=624000.ufshc \ + androidboot.verifiedbootstate=orange \ + androidboot.ver0 + +7) remove the SD card from the laptop and insert it back to the db820 board. + the SD card EXT4 partition#1 should contain: + /uImage + /apq8096-db820c.dtb + /extlinux/extlinux.conf + +8) reboot the db820 board + +================================================================================ + Successful boot sequence +================================================================================ + +Format: Log Type - Time(microsec) - Message - Optional Info +Log Type: B - Since Boot(Power On Reset), D - Delta, S - Statistic +S - QC_IMAGE_VERSION_STRING=BOOT.XF.1.0-00301 +S - IMAGE_VARIANT_STRING=M8996LAB +S - OEM_IMAGE_VERSION_STRING=crm-ubuntu68 +S - Boot Interface: UFS +S - Secure Boot: Off +S - Boot Config @ 0x00076044 = 0x000001c9 +S - JTAG ID @ 0x000760f4 = 0x4003e0e1 +S - OEM ID @ 0x000760f8 = 0x00000000 +S - Serial Number @ 0x00074138 = 0x2e8844ce +S - OEM Config Row 0 @ 0x00074188 = 0x0000000000000000 +S - OEM Config Row 1 @ 0x00074190 = 0x0000000000000000 +S - Feature Config Row 0 @ 0x000741a0 = 0x0050000010000100 +S - Feature Config Row 1 @ 0x000741a8 = 0x00fff00001ffffff +S - Core 0 Frequency, 1228 MHz +B - 0 - PBL, Start +B - 10412 - bootable_media_detect_entry, Start +B - 47480 - bootable_media_detect_success, Start +B - 47481 - elf_loader_entry, Start +B - 49027 - auth_hash_seg_entry, Start +B - 49129 - auth_hash_seg_exit, Start +B - 82403 - elf_segs_hash_verify_entry, Start +B - 84905 - PBL, End +B - 86955 - SBL1, Start +B - 182969 - usb: hs_phy_nondrive_start +B - 183305 - usb: PLL lock success - 0x3 +B - 186294 - usb: hs_phy_nondrive_finish +B - 190442 - boot_flash_init, Start +D - 30 - boot_flash_init, Delta +B - 197548 - sbl1_ddr_set_default_params, Start +D - 30 - sbl1_ddr_set_default_params, Delta +B - 205509 - boot_config_data_table_init, Start +D - 200659 - boot_config_data_table_init, Delta - (60 Bytes) +B - 410713 - CDT Version:3,Platform ID:24,Major ID:1,Minor ID:0,Subtype:0 +B - 415410 - Image Load, Start +D - 22570 - PMIC Image Loaded, Delta - (37272 Bytes) +B - 437980 - pm_device_init, Start +B - 443744 - PON REASON:PM0:0x200000061 PM1:0x200000021 +B - 480161 - PM_SET_VAL:Skip +D - 40016 - pm_device_init, Delta +B - 482083 - pm_driver_init, Start +D - 2928 - pm_driver_init, Delta +B - 488671 - pm_sbl_chg_init, Start +D - 91 - pm_sbl_chg_init, Delta +B - 495442 - vsense_init, Start +D - 0 - vsense_init, Delta +B - 505171 - Pre_DDR_clock_init, Start +D - 396 - Pre_DDR_clock_init, Delta +B - 509045 - ddr_initialize_device, Start +B - 512766 - 8996 v3.x detected, Max frequency = 1.8 GHz +B - 522373 - ddr_initialize_device, Delta +B - 522404 - DDR ID, Rank 0, Rank 1, 0x6, 0x300, 0x300 +B - 526247 - Basic DDR tests done +B - 594994 - clock_init, Start +D - 274 - clock_init, Delta +B - 598349 - Image Load, Start +D - 4331 - QSEE Dev Config Image Loaded, Delta - (46008 Bytes) +B - 603808 - Image Load, Start +D - 5338 - APDP Image Loaded, Delta - (0 Bytes) +B - 612409 - usb: UFS Serial - 2f490ecf +B - 616801 - usb: fedl, vbus_low +B - 620431 - Image Load, Start +D - 55418 - QSEE Image Loaded, Delta - (1640572 Bytes) +B - 675849 - Image Load, Start +D - 2013 - SEC Image Loaded, Delta - (4096 Bytes) +B - 683413 - sbl1_efs_handle_cookies, Start +D - 457 - sbl1_efs_handle_cookies, Delta +B - 691892 - Image Load, Start +D - 14396 - QHEE Image Loaded, Delta - (254184 Bytes) +B - 706319 - Image Load, Start +D - 14061 - RPM Image Loaded, Delta - (223900 Bytes) +B - 721111 - Image Load, Start +D - 3233 - STI Image Loaded, Delta - (0 Bytes) +B - 727913 - Image Load, Start +D - 34709 - APPSBL Image Loaded, Delta - (748716 Bytes) +B - 762713 - SBL1, End +D - 680028 - SBL1, Delta +S - Flash Throughput, 94000 KB/s (2959024 Bytes, 31250 us) +S - DDR Frequency, 1017 MHz +Android Bootloader - UART_DM Initialized!!! + +[0] BUILD_VERSION= +[0] BUILD_DATE=16:07:51 - Nov 17 2017 +[0] welcome to lk +[10] platform_init() +[10] target_init() +[10] RPM GLink Init +[10] Opening RPM Glink Port success +[10] Opening SSR Glink Port success +[20] Glink Connection between APPS and RPM established +[20] Glink Connection between APPS and RPM established +[40] UFS init success +[80] Qseecom Init Done in Appsbl +[80] secure app region addr=0x86600000 size=0x2200000[90] TZ App region notif returned with status:0 addr:86600000 size:35651584 +[100] TZ App log region register returned with status:0 addr:916d4000 size:4096 +[100] Qseecom TZ Init Done in Appsbl +[120] Loading cmnlib done +[120] qseecom_start_app: Loading app keymaster for the first time +[150] <8>keymaster: ""KEYMASTER Init "" +[160] Selected panel: none +Skip panel configuration +[160] pm8x41_get_is_cold_boot: cold boot +[170] boot_verifier: Device is in ORANGE boot state. +[180] Device is unlocked! Skipping verification... +[180] Loading (boot) image (348160): start +[190] Loading (boot) image (348160): done +[190] use_signed_kernel=1, is_unlocked=1, is_tampered=0. +[200] Your device has been unlocked and cant be trusted. +Wait for 5 seconds before proceeding + +[5200] mdtp: mdtp_img loaded +[5210] mdtp: is_test_mode: test mode is set to 1 +[5210] mdtp: read_metadata: SUCCESS +[5230] LK SEC APP Handle: 0x1 +[5230] Return value from recv_data: 14 +[5240] Return value from recv_data: 14 +[5250] Return value from recv_data: 14 +[5260] DTB Total entry: 1, DTB version: 3 +[5260] Using DTB entry 0x00000123/00000000/0x00000018/0 for device 0x00000123/00030001/0x00010018/0 +[5270] cmdline: androidboot.bootdevice=624000.ufshc androidboot.verifiedbootstate=orange androidboot.veritymode=enforcing androidboot.serialno=2f490ecf androidboot.baseband=apq mdss_mdp.panel=0 +[5290] Updating device tree: start +[5290] Updating device tree: done +[5290] Return value from recv_data: 14 +[5300] RPM GLINK UnInit +[5300] Qseecom De-Init Done in Appsbl +[5300] booting linux @ 0x80080000, ramdisk @ 0x82200000 (0), tags/device tree @ 0x82000000 +[5310] Jumping to kernel via monitor + +U-Boot 2017.11-00145-ge895117 (Nov 29 2017 - 10:04:06 +0100) +Qualcomm-DragonBoard 820C + +DRAM: 3 GiB +PSCI: v1.0 +MMC: sdhci@74a4900: 0 +In: serial@75b0000 +Out: serial@75b0000 +Err: serial@75b0000 +Net: Net Initialization Skipped +No ethernet found. +Hit any key to stop autoboot: 0 +switch to partitions #0, OK +mmc0 is current device +Scanning mmc 0:1... +Found /extlinux/extlinux.conf +Retrieving file: /extlinux/extlinux.conf +433 bytes read in 71 ms (5.9 KiB/s) +1: nfs root + +Retrieving file: /uImage +19397184 bytes read in 2024 ms (9.1 MiB/s) +append: root=/dev/nfs rw nfsroot=192.168.1.2:/db820c/rootfs,v3,tcp rootwait ip=dhcp consoleblank=0 console=tty0 console=ttyMSM0,115200n8 earlyprintk earlycon=msm_serial_dm,0x75b0000 androidboot.bootdevice=624000.ufshc androidboot.verifiedbootstate=orange androidboot.ver0 + +Retrieving file: /apq8096-db820c.dtb +38134 bytes read in 37 ms (1005.9 KiB/s) + +## Booting kernel from Legacy Image at 95000000 ... + Image Name: Dragonboard820c + Image Type: AArch64 Linux Kernel Image (uncompressed) + Data Size: 19397120 Bytes = 18.5 MiB + Load Address: 80080000 + Entry Point: 80080000 + Verifying Checksum ... OK +## Flattened Device Tree blob at 93000000 + Booting using the fdt blob at 0x93000000 + Loading Kernel Image ... OK + Using Device Tree in place at 0000000093000000, end 000000009300c4f5 + +Starting kernel ... + +[ 0.000000] Booting Linux on physical CPU 0x0 +[ 0.000000] Linux version 4.11.3-30039-g5a922a1 (jramirez@igloo) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #1 SMP PREEMPT Wed Oct 18 10:21:11 CEST 2017 +[ 0.000000] Boot CPU: AArch64 Processor [511f2112] +[ 0.000000] earlycon: msm_serial_dm0 at MMIO 0x00000000075b0000 (options '') +[ 0.000000] bootconsole [msm_serial_dm0] enabled +[ 0.000000] efi: Getting EFI parameters from FDT: +[ 0.000000] efi: UEFI not found. +[ 0.000000] OF: reserved mem: OVERLAP DETECTED! +[ 0.000000] adsp@8ea00000 (0x000000008ea00000--0x0000000090400000) overlaps with gpu@8f200000 (0x000000008f200000--0x000000008f300000) +[ 0.000000] Reserved memory: created DMA memory pool at 0x000000008f200000, size 1 MiB +[ 0.000000] OF: reserved mem: initialized node gpu@8f200000, compatible id shared-dma-pool +[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000090400000, size 8 MiB +[ 0.000000] OF: reserved mem: initialized node venus@90400000, compatible id shared-dma-pool +[ 0.000000] cma: Reserved 128 MiB at 0x00000000b8000000 +[ 0.000000] NUMA: No NUMA configuration found +[ 0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000bfffffff] +[ 0.000000] NUMA: Adding memblock [0x80000000 - 0x857fffff] on node 0 +[ 0.000000] NUMA: Adding memblock [0x91800000 - 0xbfffffff] on node 0 +[ 0.000000] NUMA: Initmem setup node 0 [mem 0x80000000-0xbfffffff] +[ 0.000000] NUMA: NODE_DATA [mem 0xb7fb6680-0xb7fb817f] +[ 0.000000] Zone ranges: +[ 0.000000] DMA [mem 0x0000000080000000-0x00000000bfffffff] +[ 0.000000] Normal empty +[ 0.000000] Movable zone start for each node +[ 0.000000] Early memory node ranges +[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000857fffff] +[ 0.000000] node 0: [mem 0x0000000091800000-0x00000000bfffffff] +[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000bfffffff] +[ 0.000000] psci: probing for conduit method from DT. +[ 0.000000] psci: PSCIv1.0 detected in firmware. +[ 0.000000] psci: Using standard PSCI v0.2 function IDs +[ 0.000000] psci: MIGRATE_INFO_TYPE not supported. +[ 0.000000] percpu: Embedded 23 pages/cpu @ffff8000de9a3000 s57240 r8192 d28776 u94208 +[ 0.000000] pcpu-alloc: s57240 r8192 d28776 u94208 alloc=23*4096 +[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 +[ 0.000000] Detected PIPT I-cache on CPU0 +[ 0.000000] Built 1 zonelists in Node order, mobility grouping on. Total pages: 720293 +[ 0.000000] Policy zone: Normal +[ 0.000000] Kernel command line: root=/dev/nfs rw nfsroot=192.168.1.2:/db820c/rootfs,v3,tcp rootwait ip=dhcp consoleblank=0 +console=tty0 console=ttyMSM0,115200n8 earlyprintk earlycon=msm_serial_dm,0x75b0000 androidboot.bootdevice=624000.ufshc androidboot.verifiedbootstate=orange a +ndroidboot.ver0 +[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes) +[ 0.000000] software IO TLB [mem 0xd3fff000-0xd7fff000] (64MB) mapped at [ffff800053fff000-ffff800057ffefff] +[ 0.000000] Memory: 2644172K/2926908K available (11196K kernel code, 1470K rwdata, 5132K rodata, 1088K init, 449K bss, 151664K reserved, 131072K cma-reser +ved) +[ 0.000000] Virtual kernel memory layout: +[ 0.000000] modules : 0xffff000000000000 - 0xffff000008000000 ( 128 MB) +[ 0.000000] vmalloc : 0xffff000008000000 - 0xffff7dffbfff0000 (129022 GB) +[ 0.000000] .text : 0xffff000008080000 - 0xffff000008b70000 ( 11200 KB) +[ 0.000000] .rodata : 0xffff000008b70000 - 0xffff000009080000 ( 5184 KB) +[ 0.000000] .init : 0xffff000009080000 - 0xffff000009190000 ( 1088 KB) +[ 0.000000] .data : 0xffff000009190000 - 0xffff0000092ffa00 ( 1471 KB) +[ 0.000000] .bss : 0xffff0000092ffa00 - 0xffff00000937014c ( 450 KB) +[ 0.000000] fixed : 0xffff7dfffe7fd000 - 0xffff7dfffec00000 ( 4108 KB) +[ 0.000000] PCI I/O : 0xffff7dfffee00000 - 0xffff7dffffe00000 ( 16 MB) +[ 0.000000] vmemmap : 0xffff7e0000000000 - 0xffff800000000000 ( 2048 GB maximum) +[ 0.000000] 0xffff7e0000000000 - 0xffff7e00037a93c0 ( 55 MB actual) +[ 0.000000] memory : 0xffff800000000000 - 0xffff8000dea4f000 ( 3562 MB) +[ 0.000000] SLUB: HWalign=128, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 +[ 0.000000] Preemptible hierarchical RCU implementation. +[ 0.000000] Build-time adjustment of leaf fanout to 64. +[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4. +[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4 +[ 0.000000] NR_IRQS:64 nr_irqs:64 0 +[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000009c00000 +[ 0.000000] GICv2m: range[mem 0x09bd0000-0x09bd0fff], SPI[544:639] +[ 0.000000] arm_arch_timer: Architected cp15 and mmio timer(s) running at 19.20MHz (virt/virt). +[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns +[ 0.000002] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns + +[....] + + +Some kernel information: + +root@linaro-developer:~# cat /proc/cpuinfo +processor : 0 +BogoMIPS : 38.40 +Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid +CPU implementer : 0x51 +CPU architecture: 8 +CPU variant : 0x1 +CPU part : 0x211 +CPU revision : 2 + +processor : 1 +BogoMIPS : 38.40 +Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid +CPU implementer : 0x51 +CPU architecture: 8 +CPU variant : 0x1 +CPU part : 0x211 +CPU revision : 2 + +processor : 2 +BogoMIPS : 38.40 +Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid +CPU implementer : 0x51 +CPU architecture: 8 +CPU variant : 0x1 +CPU part : 0x205 +CPU revision : 2 + +processor : 3 +BogoMIPS : 38.40 +Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid +CPU implementer : 0x51 +CPU architecture: 8 +CPU variant : 0x1 +CPU part : 0x205 +CPU revision : 2 + +root@linaro-developer:~# uname -a +Linux linaro-developer 4.11.3-30039-g5a922a1 #1 SMP PREEMPT Wed Oct 18 10:21:11 CEST 2017 aarch64 GNU/Linux + +root@linaro-developer:~# cat /proc/cmdline +root=/dev/nfs rw nfsroot=192.168.1.2:/db820c/rootfs,v3,tcp rootwait ip=dhcp consoleblank=0 console=tty0 console=ttyMSM0,115200n8 earlyprintk earlycon=msm_serial_dm,0x75b0000 androidboot.bootdevice=624000.ufshc androidboot.verifiedbootstate=orange androidboot.ver0 + +root@linaro-developer:~# cat /proc/meminfo +MemTotal: 2776332 kB +MemFree: 2593696 kB +MemAvailable: 2561432 kB +Buffers: 0 kB +Cached: 94744 kB +SwapCached: 0 kB +Active: 43888 kB +Inactive: 72972 kB +Active(anon): 22968 kB +Inactive(anon): 24616 kB +Active(file): 20920 kB +Inactive(file): 48356 kB +Unevictable: 0 kB +Mlocked: 0 kB +SwapTotal: 0 kB +SwapFree: 0 kB +Dirty: 0 kB +Writeback: 0 kB +AnonPages: 22120 kB +Mapped: 29284 kB +Shmem: 25468 kB +Slab: 32876 kB +SReclaimable: 12924 kB +SUnreclaim: 19952 kB +KernelStack: 2144 kB +PageTables: 928 kB +NFS_Unstable: 0 kB +Bounce: 0 kB +WritebackTmp: 0 kB +CommitLimit: 1388164 kB +Committed_AS: 204192 kB +VmallocTotal: 135290290112 kB +VmallocUsed: 0 kB +VmallocChunk: 0 kB +AnonHugePages: 2048 kB +ShmemHugePages: 0 kB +ShmemPmdMapped: 0 kB +CmaTotal: 131072 kB +CmaFree: 130356 kB +HugePages_Total: 0 +HugePages_Free: 0 +HugePages_Rsvd: 0 +HugePages_Surp: 0 +Hugepagesize: 2048 kB + + + + diff --git a/board/qualcomm/dragonboard820c/u-boot.lds b/board/qualcomm/dragonboard820c/u-boot.lds new file mode 100644 index 0000000..b84b4ac --- /dev/null +++ b/board/qualcomm/dragonboard820c/u-boot.lds @@ -0,0 +1,106 @@ +/* + * Override linker script for fastboot-readable images + * + * (C) Copyright 2015 Mateusz Kulikowski mateusz.kulikowski@gmail.com + * + * Based on arch/arm/cpu/armv8/u-boot.lds (Just add header) + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +OUTPUT_FORMAT("elf64-littleaarch64", "elf64-littleaarch64", "elf64-littleaarch64") +OUTPUT_ARCH(aarch64) +ENTRY(_arm64_header) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(8); + .text : + { + *(.__image_copy_start) + board/qualcomm/dragonboard820c/head.o (.text*) + CPUDIR/start.o (.text*) + *(.text*) + } + + . = ALIGN(8); + .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } + + . = ALIGN(8); + .data : { + *(.data*) + } + + . = ALIGN(8); + + . = .; + + . = ALIGN(8); + .u_boot_list : { + KEEP(*(SORT(.u_boot_list*))); + } + + . = ALIGN(8); + + .efi_runtime : { + __efi_runtime_start = .; + *(efi_runtime_text) + *(efi_runtime_data) + __efi_runtime_stop = .; + } + + .efi_runtime_rel : { + __efi_runtime_rel_start = .; + *(.relaefi_runtime_text) + *(.relaefi_runtime_data) + __efi_runtime_rel_stop = .; + } + + . = ALIGN(8); + + .image_copy_end : + { + *(.__image_copy_end) + } + + . = ALIGN(8); + + .rel_dyn_start : + { + *(.__rel_dyn_start) + } + + .rela.dyn : { + *(.rela*) + } + + .rel_dyn_end : + { + *(.__rel_dyn_end) + } + + _end = .; + + . = ALIGN(8); + + .bss_start : { + KEEP(*(.__bss_start)); + } + + .bss : { + *(.bss*) + . = ALIGN(8); + } + + .bss_end : { + KEEP(*(.__bss_end)); + } + + /DISCARD/ : { *(.dynsym) } + /DISCARD/ : { *(.dynstr*) } + /DISCARD/ : { *(.dynamic*) } + /DISCARD/ : { *(.plt*) } + /DISCARD/ : { *(.interp*) } + /DISCARD/ : { *(.gnu*) } +} diff --git a/configs/dragonboard820c_defconfig b/configs/dragonboard820c_defconfig new file mode 100644 index 0000000..788ff28 --- /dev/null +++ b/configs/dragonboard820c_defconfig @@ -0,0 +1,37 @@ +CONFIG_ARM=y +CONFIG_ARM_SMCCC=y +CONFIG_ARCH_SNAPDRAGON=y +CONFIG_TARGET_DRAGONBOARD820C=y +CONFIG_IDENT_STRING="\nQualcomm-DragonBoard 820C" +CONFIG_DEFAULT_DEVICE_TREE="dragonboard820c" +CONFIG_USE_BOOTARGS=y +# CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOOTARGS="console=ttyMSM0,115200n8" +CONFIG_SYS_PROMPT="dragonboard820c => " +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTEFI=y +CONFIG_EFI_LOADER=y +CONFIG_CMD_BOOTEFI_HELLO=y +CONFIG_CMD_PXE=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MD5SUM=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_PART=y +CONFIG_CMD_TIMER=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +CONFIG_OF_CONTROL=y +CONFIG_MSM_SERIAL=y +CONFIG_MMC_SDHCI_MSM=y +CONFIG_MMC_SDHCI=y +CONFIG_DM_MMC=y +CONFIG_CLK=y +CONFIG_PSCI_RESET=y +CONFIG_ENV_IS_IN_EXT4=y +CONFIG_ENV_EXT4_INTERFACE="mmc" +CONFIG_ENV_EXT4_DEVICE_AND_PART="0:1" +CONFIG_ENV_EXT4_FILE="/uboot.env" + diff --git a/include/configs/dragonboard820c.h b/include/configs/dragonboard820c.h new file mode 100644 index 0000000..31a6853 --- /dev/null +++ b/include/configs/dragonboard820c.h @@ -0,0 +1,72 @@ +/* + * Board configuration file for Dragonboard 410C + * + * (C) Copyright 2017 Jorge Ramirez-Ortiz jorge.ramirez-ortiz@linaro.org + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIGS_DRAGONBOARD820C_H +#define __CONFIGS_DRAGONBOARD820C_H + +#include <linux/sizes.h> +#include <asm/arch/sysmap-apq8096.h> + +/* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 2 + +#define PHYS_SDRAM_SIZE 0xC0000000 +#define PHYS_SDRAM_1 0x80000000 +#define PHYS_SDRAM_1_SIZE 0x60000000 +#define PHYS_SDRAM_2 0x100000000 +#define PHYS_SDRAM_2_SIZE 0x5ea4ffff + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_TEXT_BASE 0x80080000 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 0x7fff0) +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x80000) +#define CONFIG_SYS_BOOTM_LEN 0x2000000 +#define CONFIG_SYS_LDSCRIPT "board/qualcomm/dragonboard820c/u-boot.lds" + +/* Generic Timer Definitions */ +#define COUNTER_FREQUENCY 19000000 + +/* Partition table support */ +#define HAVE_BLOCK_DEVICE + +/* BOOTP options */ +#define CONFIG_BOOTP_BOOTFILESIZE + +#ifndef CONFIG_SPL_BUILD +#include <config_distro_defaults.h> +#include <config_distro_bootcmd.h> +#endif + +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "loadaddr=0x95000000\0" \ + "fdt_high=0xffffffffffffffff\0" \ + "initrd_high=0xffffffffffffffff\0" \ + "linux_image=uImage\0" \ + "kernel_addr_r=0x95000000\0"\ + "fdtfile=apq8096-db820c.dtb\0" \ + "fdt_addr_r=0x93000000\0"\ + "ramdisk_addr_r=0x91000000\0"\ + "scriptaddr=0x90000000\0"\ + "pxefile_addr_r=0x90100000\0"\ + BOOTENV + +#define CONFIG_EXT4_WRITE +#define CONFIG_ENV_SIZE 0x4000 +#define CONFIG_ENV_VARS_UBOOT_CONFIG + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + SZ_8M) + +/* Monitor Command Prompt */ +#define CONFIG_SYS_CBSIZE 512 +#define CONFIG_SYS_MAXARGS 64 + +#endif
Signed-off-by: Jorge Ramirez-Ortiz jorge.ramirez-ortiz@linaro.org --- arch/arm/dts/dragonboard820c.dts | 43 +++++++++++++++++++++++++++++++++++++++ configs/dragonboard820c_defconfig | 7 +++++++ drivers/gpio/pm8916_gpio.c | 7 +++++-- 3 files changed, 55 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/dragonboard820c.dts b/arch/arm/dts/dragonboard820c.dts index bad5a1e..3086d60 100644 --- a/arch/arm/dts/dragonboard820c.dts +++ b/arch/arm/dts/dragonboard820c.dts @@ -61,5 +61,48 @@ clock = <&gcc 0>; clock-frequency = <200000000>; }; + + spmi@400f000 { + compatible = "qcom,spmi-pmic-arb"; + reg = <0x400f800 0x200>, + <0x4400000 0x400000>, + <0x4c00000 0x400000>; + #address-cells = <0x1>; + #size-cells = <0x1>; + + pmic0: pm8994@0 { + compatible = "qcom,spmi-pmic"; + reg = <0x0 0x1>; + #address-cells = <0x1>; + #size-cells = <0x1>; + + pm8994_pon: pm8994_pon@800 { + compatible = "qcom,pm8994-pwrkey"; + reg = <0x800 0x96>; + #gpio-cells = <2>; + gpio-controller; + gpio-bank-name="pm8994_key."; + }; + + pm8994_gpios: pm8994_gpios@c000 { + compatible = "qcom,pm8994-gpio"; + reg = <0xc000 0x400>; + gpio-controller; + gpio-count = <24>; + #gpio-cells = <2>; + gpio-bank-name="pm8994."; + }; + }; + + pmic1: pm8994@1 { + compatible = "qcom,spmi-pmic"; + reg = <0x1 0x1>; + #address-cells = <0x1>; + #size-cells = <0x1>; + }; + }; }; + }; + +#include "dragonboard820c-uboot.dtsi" diff --git a/configs/dragonboard820c_defconfig b/configs/dragonboard820c_defconfig index 788ff28..5e25e2e 100644 --- a/configs/dragonboard820c_defconfig +++ b/configs/dragonboard820c_defconfig @@ -23,11 +23,18 @@ CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_PMIC=y CONFIG_OF_CONTROL=y CONFIG_MSM_SERIAL=y +CONFIG_SPMI_MSM=y CONFIG_MMC_SDHCI_MSM=y CONFIG_MMC_SDHCI=y CONFIG_DM_MMC=y +CONFIG_DM_GPIO=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_PM8916=y +CONFIG_PM8916_GPIO=y CONFIG_CLK=y CONFIG_PSCI_RESET=y CONFIG_ENV_IS_IN_EXT4=y diff --git a/drivers/gpio/pm8916_gpio.c b/drivers/gpio/pm8916_gpio.c index 9ec2a24..056b982 100644 --- a/drivers/gpio/pm8916_gpio.c +++ b/drivers/gpio/pm8916_gpio.c @@ -29,7 +29,7 @@ DECLARE_GLOBAL_DATA_PTR; #define REG_STATUS_VAL_MASK 0x1
/* MODE_CTL */ -#define REG_CTL 0x40 +#define REG_CTL 0x40 #define REG_CTL_MODE_MASK 0x70 #define REG_CTL_MODE_INPUT 0x00 #define REG_CTL_MODE_INOUT 0x20 @@ -183,7 +183,7 @@ static int pm8916_gpio_probe(struct udevice *dev) return -ENODEV;
reg = pmic_reg_read(dev->parent, priv->pid + REG_SUBTYPE); - if (reg != 0x5) + if (reg != 0x5 && reg != 0x1) return -ENODEV;
return 0; @@ -203,6 +203,7 @@ static int pm8916_gpio_ofdata_to_platdata(struct udevice *dev)
static const struct udevice_id pm8916_gpio_ids[] = { { .compatible = "qcom,pm8916-gpio" }, + { .compatible = "qcom,pm8994-gpio" }, /* 22 GPIO's */ { } };
@@ -278,6 +279,7 @@ static int pm8941_pwrkey_ofdata_to_platdata(struct udevice *dev) struct gpio_dev_priv *uc_priv = dev_get_uclass_priv(dev);
uc_priv->gpio_count = 2; + uc_priv->bank_name = dev_read_string(dev, "gpio-bank-name"); if (uc_priv->bank_name == NULL) uc_priv->bank_name = "pm8916_key";
@@ -286,6 +288,7 @@ static int pm8941_pwrkey_ofdata_to_platdata(struct udevice *dev)
static const struct udevice_id pm8941_pwrkey_ids[] = { { .compatible = "qcom,pm8916-pwrkey" }, + { .compatible = "qcom,pm8994-pwrkey" }, { } };
Signed-off-by: Jorge Ramirez-Ortiz jorge.ramirez-ortiz@linaro.org --- arch/arm/dts/dragonboard820c-uboot.dtsi | 19 ++++++++++++ board/qualcomm/dragonboard820c/dragonboard820c.c | 37 +++++++++++++++++++++++- include/configs/dragonboard820c.h | 2 ++ 3 files changed, 57 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/dragonboard820c-uboot.dtsi
diff --git a/arch/arm/dts/dragonboard820c-uboot.dtsi b/arch/arm/dts/dragonboard820c-uboot.dtsi new file mode 100644 index 0000000..167e72c --- /dev/null +++ b/arch/arm/dts/dragonboard820c-uboot.dtsi @@ -0,0 +1,19 @@ +/* + * U-Boot addition to handle Dragonboard 820c pins + * + * (C) Copyright 2017 Jorge Ramirez-Ortiz jorge.ramirez-ortiz@linaro.org + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +&pm8994_pon { + key_vol_down { + gpios = <&pm8994_pon 1 0>; + label = "key_vol_down"; + }; + + key_power { + gpios = <&pm8994_pon 0 0>; + label = "key_power"; + }; +}; diff --git a/board/qualcomm/dragonboard820c/dragonboard820c.c b/board/qualcomm/dragonboard820c/dragonboard820c.c index 8f40ba4..d4a20d2 100644 --- a/board/qualcomm/dragonboard820c/dragonboard820c.c +++ b/board/qualcomm/dragonboard820c/dragonboard820c.c @@ -1,7 +1,7 @@ /* * Board init file for Dragonboard 820C * - * (C) Copyright 2017 Jorge Ramirez-Ortiz jorge.ramirez-ortiz@gmail.com + * (C) Copyright 2017 Jorge Ramirez-Ortiz jorge.ramirez-ortiz@linaro.org * * SPDX-License-Identifier: GPL-2.0+ */ @@ -14,6 +14,7 @@ #include <asm/io.h> #include <linux/bitops.h> #include <asm/psci.h> +#include <asm/gpio.h>
@@ -126,3 +127,37 @@ void reset_cpu(ulong addr) { psci_system_reset(); } + +/* Check for vol- button - if pressed - stop autoboot */ +int misc_init_r(void) +{ + struct udevice *pon; + struct gpio_desc resin; + int node, ret; + + ret = uclass_get_device_by_name(UCLASS_GPIO, "pm8994_pon@800", &pon); + if (ret < 0) { + printf("Failed to find PMIC pon node. Check device tree\n"); + return 0; + } + + node = fdt_subnode_offset(gd->fdt_blob, dev_of_offset(pon), + "key_vol_down"); + if (node < 0) { + printf("Failed to find key_vol_down node. Check device tree\n"); + return 0; + } + + if (gpio_request_by_name_nodev(offset_to_ofnode(node), "gpios", 0, + &resin, 0)) { + printf("Failed to request key_vol_down button.\n"); + return 0; + } + + if (dm_gpio_get_value(&resin)) { + env_set("bootdelay", "-1"); + printf("Power button pressed - dropping to console.\n"); + } + + return 0; +} diff --git a/include/configs/dragonboard820c.h b/include/configs/dragonboard820c.h index 31a6853..947674a 100644 --- a/include/configs/dragonboard820c.h +++ b/include/configs/dragonboard820c.h @@ -12,6 +12,8 @@ #include <linux/sizes.h> #include <asm/arch/sysmap-apq8096.h>
+#define CONFIG_MISC_INIT_R /* To stop autoboot */ + /* Physical Memory Map */ #define CONFIG_NR_DRAM_BANKS 2
the kernel fails to boot when it goes over the limit.
Signed-off-by: Jorge Ramirez-Ortiz jorge.ramirez-ortiz@linaro.org --- include/configs/dragonboard410c.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/dragonboard410c.h b/include/configs/dragonboard410c.h index d2447b2..fdfac27 100644 --- a/include/configs/dragonboard410c.h +++ b/include/configs/dragonboard410c.h @@ -23,7 +23,7 @@ #define CONFIG_SYS_TEXT_BASE 0x80080000 #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 0x7fff0) #define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x80000) -#define CONFIG_SYS_BOOTM_LEN 0x1000000 /* 16MB max kernel size */ +#define CONFIG_SYS_BOOTM_LEN 0x1400000 /* 20MB max kernel size */
/* UART */
This small of a size tweak is just begging to be hit within a year. Can we raise this to something closer to the aarch64 limit for an Image? Or if not, 32 or 64MB?
yeah I just picked 0x1400000 since that is what I used in poplar as well but sure, I'll set it to 64MB like rockchip and other platforms.
The firmware that runs before u-boot modifies u-boot's device tree adding the local-mac-address and local-bd-address properties for the compatibles "qcom,wcnss-bt" and "qcom,wcnss-wlan".
This commit reads that firmware, retrieves the properties and fixups the device tree that is passed to the kernel before booting.
Signed-off-by: Jorge Ramirez-Ortiz jorge.ramirez-ortiz@linaro.org --- arch/arm/dts/dragonboard410c.dts | 10 +++++ board/qualcomm/dragonboard410c/Makefile | 1 + board/qualcomm/dragonboard410c/dragonboard410c.c | 49 +++++++++++++++++++++--- board/qualcomm/dragonboard410c/lowlevel_init.S | 28 ++++++++++++++ configs/dragonboard410c_defconfig | 1 + 5 files changed, 83 insertions(+), 6 deletions(-) create mode 100644 board/qualcomm/dragonboard410c/lowlevel_init.S
diff --git a/arch/arm/dts/dragonboard410c.dts b/arch/arm/dts/dragonboard410c.dts index 7746622..25aeac4 100644 --- a/arch/arm/dts/dragonboard410c.dts +++ b/arch/arm/dts/dragonboard410c.dts @@ -86,6 +86,16 @@ clock-frequency = <200000000>; };
+ wcnss { + bt { + compatible="qcom,wcnss-bt"; + }; + + wifi { + compatible="qcom,wcnss-wlan"; + }; + }; + spmi@200f000 { compatible = "qcom,spmi-pmic-arb"; reg = <0x200f800 0x200 0x2400000 0x400000 0x2c00000 0x400000>; diff --git a/board/qualcomm/dragonboard410c/Makefile b/board/qualcomm/dragonboard410c/Makefile index cd67808..5082383 100644 --- a/board/qualcomm/dragonboard410c/Makefile +++ b/board/qualcomm/dragonboard410c/Makefile @@ -5,4 +5,5 @@ #
obj-y := dragonboard410c.o +obj-y += lowlevel_init.o extra-y += head.o diff --git a/board/qualcomm/dragonboard410c/dragonboard410c.c b/board/qualcomm/dragonboard410c/dragonboard410c.c index 848e278..99fc91b 100644 --- a/board/qualcomm/dragonboard410c/dragonboard410c.c +++ b/board/qualcomm/dragonboard410c/dragonboard410c.c @@ -10,9 +10,16 @@ #include <dm.h> #include <usb.h> #include <asm/gpio.h> +#include <fdt_support.h>
+/* pointer to the device tree ammended by the firmware */ +extern const void *fw_dtb; + +static char wlan_mac[ARP_HLEN]; +static char bt_mac[ARP_HLEN]; + int dram_init(void) { gd->ram_size = PHYS_SDRAM_1_SIZE; @@ -27,7 +34,6 @@ int dram_init_banksize(void) return 0; }
- int board_prepare_usb(enum usb_init_type type) { static struct udevice *pmic_gpio; @@ -96,11 +102,6 @@ int board_prepare_usb(enum usb_init_type type) return 0; }
-int board_init(void) -{ - return 0; -} - /* Check for vol- button - if pressed - stop autoboot */ int misc_init_r(void) { @@ -134,3 +135,39 @@ int misc_init_r(void)
return 0; } + +int board_init(void) +{ + int offset, len; + const char *mac; + + /* take a copy of the firmware information (the user could unknownly + overwrite that DDR via tftp or other means) */ + + offset = fdt_node_offset_by_compatible(fw_dtb, -1, "qcom,wcnss-wlan"); + if (offset >= 0) { + mac = fdt_getprop(fw_dtb, offset, "local-mac-address", &len); + if (mac) + memcpy(wlan_mac, mac, ARP_HLEN); + } + + offset = fdt_node_offset_by_compatible(fw_dtb, -1, "qcom,wcnss-bt"); + if (offset >= 0) { + mac = fdt_getprop(fw_dtb, offset, "local-bd-address", &len); + if (mac) + memcpy(bt_mac, mac, ARP_HLEN); + } + + return 0; +} + +int ft_board_setup(void *blob, bd_t *bd) +{ + do_fixup_by_compat(blob, "qcom,wcnss-wlan", "local-mac-address", + wlan_mac, ARP_HLEN, 1); + + do_fixup_by_compat(blob, "qcom,wcnss-bt", "local-mac-address", + bt_mac, ARP_HLEN, 1); + + return 0; +} diff --git a/board/qualcomm/dragonboard410c/lowlevel_init.S b/board/qualcomm/dragonboard410c/lowlevel_init.S new file mode 100644 index 0000000..15b2d0c --- /dev/null +++ b/board/qualcomm/dragonboard410c/lowlevel_init.S @@ -0,0 +1,28 @@ +/* + * (C) Copyright 2016 + * Cédric Schieli cschieli@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <config.h> + +.align 8 +.global fw_dtb +fw_dtb: + .dword 0x0 + +/* + * Routine: save_boot_params (called after reset from start.S) + * Description: save ATAG/FDT address provided by the firmware at boot time + */ + +.global save_boot_params +save_boot_params: + + /* The firmware provided ATAG/FDT address can be found in r2/x0 */ + adr x8, fw_dtb + str x0, [x8] + + /* Returns */ + b save_boot_params_ret diff --git a/configs/dragonboard410c_defconfig b/configs/dragonboard410c_defconfig index 4c04544..570ee6d 100644 --- a/configs/dragonboard410c_defconfig +++ b/configs/dragonboard410c_defconfig @@ -45,3 +45,4 @@ CONFIG_USB_ETHER_SMSC95XX=y CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_OF_BOARD_SETUP=y
On 12/14/2017 02:26 PM, Jorge Ramirez-Ortiz wrote:
The following version fixes some nasty compiler warnings present in the previous version. Sorry about it.
just to follow up on the db820c and db410c patchset that I posted a couple of weeks ago (v1 and v2) any feedback will be greatly appreciated!
TIA
On Thu, Dec 21, 2017 at 8:12 AM, Jorge Ramirez jorge.ramirez-ortiz@linaro.org wrote:
Can you also review the various patches that Rob Clark has posted for the 410c and pull those in as well?
hey pete you mean the db410 patches on his db410c-latest tree? https://github.com/robclark/u-boot/commits/db410c-latest
sure, I can pull in those and add them to the v3 patchset once I get some more review comments. in fact I was hoping to get the db820c support merged first before adding 410c stuff but I guess that is no longer the case.
bte I was lookint into this one as well https://patchwork.ozlabs.org/patch/798843/
Yep, he has a couple of different trees I think.
Happy to test.
Well the 410c is easier to assist with as I have one ;-)
Yes, there's that one plus a couple around usb_kbd too
Jorge Ramirez
Jorge Ramirez-Ortiz
Peter Robinson
