[U-Boot] [PATCH v4 1/2] sunxi: Serial number support, obtained from SID bits
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- board/sunxi/board.c | 33 ++++++++++++++++++++++----------- 1 file changed, 22 insertions(+), 11 deletions(-)
diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 01b654e..79516bf 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -372,20 +372,31 @@ int g_dnl_board_usb_cable_connected(void) #ifdef CONFIG_MISC_INIT_R int misc_init_r(void) { + char serial_string[17] = { 0 }; unsigned int sid[4]; + uint8_t mac_addr[6]; + int ret; + + ret = sunxi_get_sid(sid); + if (ret == 0 && sid[0] != 0 && sid[3] != 0) { + if (!getenv("ethaddr")) { + /* Non OUI / registered MAC address */ + mac_addr[0] = 0x02; + mac_addr[1] = (sid[0] >> 0) & 0xff; + mac_addr[2] = (sid[3] >> 24) & 0xff; + mac_addr[3] = (sid[3] >> 16) & 0xff; + mac_addr[4] = (sid[3] >> 8) & 0xff; + mac_addr[5] = (sid[3] >> 0) & 0xff; + + eth_setenv_enetaddr("ethaddr", mac_addr); + }
- if (!getenv("ethaddr") && sunxi_get_sid(sid) == 0 && - sid[0] != 0 && sid[3] != 0) { - uint8_t mac_addr[6]; - - mac_addr[0] = 0x02; /* Non OUI / registered MAC address */ - mac_addr[1] = (sid[0] >> 0) & 0xff; - mac_addr[2] = (sid[3] >> 24) & 0xff; - mac_addr[3] = (sid[3] >> 16) & 0xff; - mac_addr[4] = (sid[3] >> 8) & 0xff; - mac_addr[5] = (sid[3] >> 0) & 0xff; + if (!getenv("serial#")) { + snprintf(serial_string, sizeof(serial_string), + "%08x%08x", sid[0], sid[3]);
- eth_setenv_enetaddr("ethaddr", mac_addr); + setenv("serial#", serial_string); + } }
#if defined(CONFIG_MUSB_HOST) || defined(CONFIG_MUSB_GADGET)
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- board/sunxi/board.c | 20 ++++++++++++++++++++ include/configs/sunxi-common.h | 1 + 2 files changed, 21 insertions(+)
diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 79516bf..d1b3c5e 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -369,6 +369,26 @@ int g_dnl_board_usb_cable_connected(void) } #endif
+#ifdef CONFIG_SERIAL_TAG +void get_board_serial(struct tag_serialnr *serialnr) +{ + char *serial_string; + unsigned long long serial; + + serial_string = getenv("serial#"); + + if (serial_string) { + serial = simple_strtoull(serial_string, NULL, 16); + + serialnr->high = (unsigned int) (serial >> 32); + serialnr->low = (unsigned int) (serial & 0xffffffff); + } else { + serialnr->high = 0; + serialnr->low = 0; + } +} +#endif + #ifdef CONFIG_MISC_INIT_R int misc_init_r(void) { diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 1f7a1cb..b9bb971 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -98,6 +98,7 @@ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_CMDLINE_TAG #define CONFIG_INITRD_TAG +#define CONFIG_SERIAL_TAG
/* mmc config */ #if !defined(CONFIG_UART0_PORT_F)
Thanks, I've added this to my personal git repo, sunxi-wip branch. I'll move it over to u-boot-sunxi/next once it is clear that the kernel patch to show the devicetree serial-number string /proc/cpuinfo is going to be accepted.
Regards,
Hans
- char *serial_string;
- unsigned long long serial;
- serial_string = getenv("serial#");
- if (serial_string) {
- } else {
serialnr->high = 0;
serialnr->low = 0;
+} +#endif
- #ifdef CONFIG_MISC_INIT_R int misc_init_r(void) {
Thanks, I'm currently busy merging some more patches, once that is done this patch should show up in u-boot-sunxi/next, and it will be included in u-boot/master once the merge window for v2015.07 opens.
Regards,
Hans
- char serial_string[17] = { 0 }; unsigned int sid[4];
- int ret;
- ret = sunxi_get_sid(sid);
- if (ret == 0 && sid[0] != 0 && sid[3] != 0) {
mac_addr[0] = 0x02;
Hans de Goede
Paul Kocialkowski
