[U-Boot] Please pull u-boot-ti/master
The following changes since commit 06194b6b65f701a9d6ef2d9b4123c4afe57d8783: Nagabhushana Netagunte (1): da850: add new config file for AM18xx
git://git.denx.de/u-boot-ti.git master
Heiko Schocher (3): arm, davinci: da850/dm365 lowlevel cleanup arm, davinci_emac: fix driver bug if more then 3 PHYs are detected arm, davinci: add DAVINCI_MMC_CLKID
Sricharan (7): omap4: make omap4 code common for future reuse omap: Checkpatch fixes omap5: Add minimal support for omap5430. omap5: clocks: Add clocks support for omap5 platform. omap5: emif: Add emif/ddr configurations required for omap5 evm omap4/5: Add support for booting with CH. omap5: Add omap5_evm board build support.
MAINTAINERS | 1 + Makefile | 9 +- README | 6 + arch/arm/cpu/arm926ejs/davinci/da850_lowlevel.c | 122 +-- arch/arm/cpu/arm926ejs/davinci/dm365_lowlevel.c | 73 +- arch/arm/cpu/armv7/omap-common/Makefile | 13 + arch/arm/cpu/armv7/omap-common/clocks-common.c | 609 +++++++++++ arch/arm/cpu/armv7/omap-common/emif-common.c | 1140 ++++++++++++++++++++ arch/arm/cpu/armv7/omap-common/hwinit-common.c | 267 +++++ .../armv7/{omap4 => omap-common}/lowlevel_init.S | 37 +- .../{omap4/mem.c => omap-common/mem-common.c} | 0 arch/arm/cpu/armv7/omap-common/spl.c | 9 +- arch/arm/cpu/armv7/omap4/Makefile | 11 +- arch/arm/cpu/armv7/omap4/board.c | 384 ------- arch/arm/cpu/armv7/omap4/clocks.c | 628 ++--------- arch/arm/cpu/armv7/omap4/emif.c | 1135 +------------------- arch/arm/cpu/armv7/omap4/hwinit.c | 167 +++ arch/arm/cpu/armv7/omap4/omap4_mux_data.h | 83 -- arch/arm/cpu/armv7/omap4/sdram_elpida.c | 2 +- arch/arm/cpu/armv7/omap4/sys_info.c | 53 - arch/arm/cpu/armv7/omap5/Makefile | 48 + arch/arm/cpu/armv7/omap5/clocks.c | 432 ++++++++ arch/arm/cpu/armv7/omap5/config.mk | 28 + arch/arm/cpu/armv7/omap5/emif.c | 105 ++ arch/arm/cpu/armv7/omap5/hwinit.c | 78 ++ arch/arm/cpu/armv7/omap5/sdram_elpida.c | 178 +++ arch/arm/include/asm/arch-davinci/aintc_defs.h | 2 + arch/arm/include/asm/arch-davinci/da850_lowlevel.h | 2 +- arch/arm/include/asm/arch-davinci/ddr2_defs.h | 4 + arch/arm/include/asm/arch-davinci/emif_defs.h | 1 + arch/arm/include/asm/arch-davinci/hardware.h | 21 + arch/arm/include/asm/arch-davinci/pll_defs.h | 14 + arch/arm/include/asm/arch-omap3/mmc_host_def.h | 11 +- arch/arm/include/asm/arch-omap4/clocks.h | 23 + arch/arm/include/asm/arch-omap4/emif.h | 1021 ------------------ arch/arm/include/asm/arch-omap4/mmc_host_def.h | 11 +- .../arm/include/asm/arch-omap4/{omap4.h => omap.h} | 46 +- arch/arm/include/asm/arch-omap4/sys_proto.h | 38 +- arch/arm/include/asm/arch-omap5/clocks.h | 722 +++++++++++++ arch/arm/include/asm/arch-omap5/cpu.h | 175 +++ arch/arm/include/asm/arch-omap5/gpio.h | 50 + arch/arm/include/asm/arch-omap5/i2c.h | 74 ++ arch/arm/include/asm/arch-omap5/mmc_host_def.h | 174 +++ arch/arm/include/asm/arch-omap5/mux_omap5.h | 344 ++++++ .../asm/{arch-omap4/omap4.h => arch-omap5/omap.h} | 104 +- arch/arm/include/asm/arch-omap5/sys_proto.h | 122 +++ arch/arm/include/asm/armv7.h | 3 + arch/arm/include/asm/emif.h | 1035 ++++++++++++++++++ arch/arm/include/asm/mach-types.h | 13 + arch/arm/include/asm/omap_common.h | 31 +- board/ti/omap5_evm/Makefile | 49 + board/ti/omap5_evm/evm.c | 101 ++ board/ti/omap5_evm/mux_data.h | 275 +++++ board/ti/panda/Makefile | 2 - board/ti/panda/panda.c | 27 +- board/ti/panda/panda_mux_data.h | 54 +- board/ti/sdp4430/Makefile | 4 +- board/ti/sdp4430/sdp.c | 27 +- board/ti/sdp4430/sdp4430_mux_data.h | 53 +- boards.cfg | 1 + drivers/mmc/omap_hsmmc.c | 26 +- drivers/net/davinci_emac.c | 24 +- include/configs/omap4_common.h | 7 +- include/configs/omap5_evm.h | 284 +++++ spl/Makefile | 3 + 65 files changed, 7108 insertions(+), 3488 deletions(-) create mode 100644 arch/arm/cpu/armv7/omap-common/clocks-common.c create mode 100644 arch/arm/cpu/armv7/omap-common/emif-common.c create mode 100644 arch/arm/cpu/armv7/omap-common/hwinit-common.c rename arch/arm/cpu/armv7/{omap4 => omap-common}/lowlevel_init.S (76%) rename arch/arm/cpu/armv7/{omap4/mem.c => omap-common/mem-common.c} (100%) delete mode 100644 arch/arm/cpu/armv7/omap4/board.c create mode 100644 arch/arm/cpu/armv7/omap4/hwinit.c delete mode 100644 arch/arm/cpu/armv7/omap4/omap4_mux_data.h delete mode 100644 arch/arm/cpu/armv7/omap4/sys_info.c create mode 100644 arch/arm/cpu/armv7/omap5/Makefile create mode 100644 arch/arm/cpu/armv7/omap5/clocks.c create mode 100644 arch/arm/cpu/armv7/omap5/config.mk create mode 100644 arch/arm/cpu/armv7/omap5/emif.c create mode 100644 arch/arm/cpu/armv7/omap5/hwinit.c create mode 100644 arch/arm/cpu/armv7/omap5/sdram_elpida.c delete mode 100644 arch/arm/include/asm/arch-omap4/emif.h copy arch/arm/include/asm/arch-omap4/{omap4.h => omap.h} (87%) create mode 100644 arch/arm/include/asm/arch-omap5/clocks.h create mode 100644 arch/arm/include/asm/arch-omap5/cpu.h create mode 100644 arch/arm/include/asm/arch-omap5/gpio.h create mode 100644 arch/arm/include/asm/arch-omap5/i2c.h create mode 100644 arch/arm/include/asm/arch-omap5/mmc_host_def.h create mode 100644 arch/arm/include/asm/arch-omap5/mux_omap5.h rename arch/arm/include/asm/{arch-omap4/omap4.h => arch-omap5/omap.h} (65%) create mode 100644 arch/arm/include/asm/arch-omap5/sys_proto.h create mode 100644 arch/arm/include/asm/emif.h create mode 100644 board/ti/omap5_evm/Makefile create mode 100644 board/ti/omap5_evm/evm.c create mode 100644 board/ti/omap5_evm/mux_data.h create mode 100644 include/configs/omap5_evm.h
Hi Sandeep,
Applied to u-boot-arm/master, thanks.
Amicalement,
Albert ARIBAUD
s-paulraj@ti.com
