[U-Boot] [PATCH] powerpc/p3060qds: Add board related support for P3060QDS platform
The P3060QDS is a Freescale reference board for the six-core P3060 SOC.
P3060QDS Board Overview: Memory subsystem: - 2G Bytes unbuffered DDR3 SDRAM SO-DIMM(64bit bus) - 128M Bytes NOR flash single-chip memory - 16M Bytes SPI flash - 8K Bytes AT24C64 I2C EEPROM for RCW Ethernet: - Eight Ethernet controllers (4x1G + 4x1G/2.5G) - Three VSC8641 PHYs on board (2xRGMII + 1xMII) - Suport multiple Vitesse VSC8234 SGMII Cards in Slot1/2/3 PCIe: Two PCI Express 2.0 controllers/ports USB: Two USB2.0, USB1(TYPE-A) and USB2(TYPE-AB) on board I2C: Four I2C controllers UART: Supports two dUARTs up to 115200 bps for console RapidIO: Two RapidIO, sRIO1 and sRIO2
Signed-off-by: Shengzhou Liu Shengzhou.Liu@freescale.com Signed-off-by: Kumar Gala galak@kernel.crashing.org --- board/freescale/common/Makefile | 3 + board/freescale/common/ics307_clk.c | 21 +- board/freescale/common/qixis.c | 151 ++++++++++++ board/freescale/common/qixis.h | 101 ++++++++ board/freescale/p3060qds/Makefile | 54 ++++ board/freescale/p3060qds/ddr.c | 281 ++++++++++++++++++++++ board/freescale/p3060qds/eth.c | 440 ++++++++++++++++++++++++++++++++++ board/freescale/p3060qds/fixed_ddr.c | 214 +++++++++++++++++ board/freescale/p3060qds/p3060qds.c | 239 ++++++++++++++++++ board/freescale/p3060qds/p3060qds.h | 30 +++ boards.cfg | 2 + doc/README.p3060qds | 111 +++++++++ include/configs/P3060QDS.h | 39 +++ include/configs/corenet_ds.h | 4 + 14 files changed, 1682 insertions(+), 8 deletions(-) create mode 100644 board/freescale/common/qixis.c create mode 100644 board/freescale/common/qixis.h create mode 100644 board/freescale/p3060qds/Makefile create mode 100644 board/freescale/p3060qds/ddr.c create mode 100644 board/freescale/p3060qds/eth.c create mode 100644 board/freescale/p3060qds/fixed_ddr.c create mode 100644 board/freescale/p3060qds/p3060qds.c create mode 100644 board/freescale/p3060qds/p3060qds.h create mode 100644 doc/README.p3060qds create mode 100644 include/configs/P3060QDS.h
diff --git a/board/freescale/common/Makefile b/board/freescale/common/Makefile index b27f054..2b9cc3f 100644 --- a/board/freescale/common/Makefile +++ b/board/freescale/common/Makefile @@ -34,6 +34,7 @@ COBJS-$(CONFIG_FSL_VIA) += cds_via.o COBJS-$(CONFIG_FMAN_ENET) += fman.o COBJS-$(CONFIG_FSL_PIXIS) += pixis.o COBJS-$(CONFIG_FSL_NGPIXIS) += ngpixis.o +COBJS-$(CONFIG_FSL_QIXIS) += qixis.o COBJS-$(CONFIG_PQ_MDS_PIB) += pq-mds-pib.o COBJS-$(CONFIG_ID_EEPROM) += sys_eeprom.o COBJS-$(CONFIG_FSL_SGMII_RISER) += sgmii_riser.o @@ -50,12 +51,14 @@ COBJS-$(CONFIG_MPC8572DS) += ics307_clk.o COBJS-$(CONFIG_P1022DS) += ics307_clk.o COBJS-$(CONFIG_P2020DS) += ics307_clk.o COBJS-$(CONFIG_P3041DS) += ics307_clk.o +COBJS-$(CONFIG_P3060QDS) += ics307_clk.o COBJS-$(CONFIG_P4080DS) += ics307_clk.o COBJS-$(CONFIG_P5020DS) += ics307_clk.o
# deal with common files for P-series corenet based devices SUBLIB-$(CONFIG_P2041RDB) += p_corenet/libp_corenet.o SUBLIB-$(CONFIG_P3041DS) += p_corenet/libp_corenet.o +SUBLIB-$(CONFIG_P3060QDS) += p_corenet/libp_corenet.o SUBLIB-$(CONFIG_P4080DS) += p_corenet/libp_corenet.o SUBLIB-$(CONFIG_P5020DS) += p_corenet/libp_corenet.o
diff --git a/board/freescale/common/ics307_clk.c b/board/freescale/common/ics307_clk.c index 89d8810..596ed3a 100644 --- a/board/freescale/common/ics307_clk.c +++ b/board/freescale/common/ics307_clk.c @@ -1,5 +1,5 @@ /* - * Copyright 2010 Freescale Semiconductor, Inc. + * Copyright 2010-2011 Freescale Semiconductor, Inc. * * See file CREDITS for list of people who contributed to this * project. @@ -25,10 +25,15 @@
#include "ics307_clk.h"
-#ifdef CONFIG_FSL_NGPIXIS +#if defined(CONFIG_FSL_NGPIXIS) #include "ngpixis.h" +#define fpga_reg pixis +#elif defined(CONFIG_FSL_QIXIS) +#include "qixis.h" +#define fpga_reg ((struct qixis *)QIXIS_BASE) #else #include "pixis.h" +#define fpga_reg pixis #endif
/* decode S[0-2] to Output Divider (OD) */ @@ -74,15 +79,15 @@ static unsigned long ics307_clk_freq(u8 cw0, u8 cw1, u8 cw2) unsigned long get_board_sys_clk(void) { return ics307_clk_freq( - in_8(&pixis->sclk[0]), - in_8(&pixis->sclk[1]), - in_8(&pixis->sclk[2])); + in_8(&fpga_reg->sclk[0]), + in_8(&fpga_reg->sclk[1]), + in_8(&fpga_reg->sclk[2])); }
unsigned long get_board_ddr_clk(void) { return ics307_clk_freq( - in_8(&pixis->dclk[0]), - in_8(&pixis->dclk[1]), - in_8(&pixis->dclk[2])); + in_8(&fpga_reg->dclk[0]), + in_8(&fpga_reg->dclk[1]), + in_8(&fpga_reg->dclk[2])); } diff --git a/board/freescale/common/qixis.c b/board/freescale/common/qixis.c new file mode 100644 index 0000000..6cd7e51 --- /dev/null +++ b/board/freescale/common/qixis.c @@ -0,0 +1,151 @@ +/* + * Copyright 2011 Freescale Semiconductor + * Author: Shengzhou Liu Shengzhou.Liu@freescale.com + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the Free + * Software Foundation; either version 2 of the License, or (at your option) + * any later version. + * + * This file provides support for the QIXIS of some Freescale reference boards. + * + */ + +#include <common.h> +#include <command.h> +#include <asm/io.h> +#include "qixis.h" + +u8 qixis_read(unsigned int reg) +{ + void *p = (void *)QIXIS_BASE; + + return in_8(p + reg); +} + +void qixis_write(unsigned int reg, u8 value) +{ + void *p = (void *)QIXIS_BASE; + + out_8(p + reg, value); +} + +void qixis_reset(void) +{ + QIXIS_WRITE(rst_ctl, 0x83); +} + +void qixis_bank_reset(void) +{ + QIXIS_WRITE(rcfg_ctl, 0x20); + QIXIS_WRITE(rcfg_ctl, 0x21); +} + +/* Set the boot bank to the power-on default bank0 */ +void clear_altbank(void) +{ + u8 reg; + + reg = QIXIS_READ(brdcfg[0]); + reg = reg & ~QIXIS_LBMAP_MASK; + QIXIS_WRITE(brdcfg[0], reg); +} + +/* Set the boot bank to the alternate bank */ +void set_altbank(void) +{ + u8 reg; + + reg = QIXIS_READ(brdcfg[0]); + reg = (reg & ~QIXIS_LBMAP_MASK) | QIXIS_LBMAP_ALTBANK; + QIXIS_WRITE(brdcfg[0], reg); +} + +#ifdef DEBUG +static void qixis_dump_regs(void) +{ + int i; + + printf("id = %02x\n", QIXIS_READ(id)); + printf("arch = %02x\n", QIXIS_READ(arch)); + printf("scver = %02x\n", QIXIS_READ(scver)); + printf("model = %02x\n", QIXIS_READ(model)); + printf("rst_ctl = %02x\n", QIXIS_READ(rst_ctl)); + printf("aux = %02x\n", QIXIS_READ(aux)); + for (i = 0; i < 16; i++) + printf("brdcfg%02d = %02x\n", i, QIXIS_READ(brdcfg[i])); + for (i = 0; i < 16; i++) + printf("dutcfg%02d = %02x\n", i, QIXIS_READ(dutcfg[i])); + printf("sclk = %02x%02x%02x\n", QIXIS_READ(sclk[0]), + QIXIS_READ(sclk[1]), QIXIS_READ(sclk[2])); + printf("dclk = %02x%02x%02x\n", QIXIS_READ(dclk[0]), + QIXIS_READ(dclk[1]), QIXIS_READ(dclk[2])); + printf("aux = %02x\n", QIXIS_READ(aux)); + printf("watch = %02x\n", QIXIS_READ(watch)); + printf("ctl_sys = %02x\n", QIXIS_READ(ctl_sys)); + printf("rcw_ctl = %02x\n", QIXIS_READ(rcw_ctl)); + printf("present = %02x\n", QIXIS_READ(present)); + printf("clk_spd = %02x\n", QIXIS_READ(clk_spd)); + printf("stat_dut = %02x\n", QIXIS_READ(stat_dut)); + printf("stat_sys = %02x\n", QIXIS_READ(stat_sys)); + printf("stat_alrm = %02x\n", QIXIS_READ(stat_alrm)); + printf("ctl_sys2 = %02x\n", QIXIS_READ(ctl_sys2)); +} +#endif + +int qixis_reset_cmd(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + int i; + + if (argc <= 1) { + clear_altbank(); + qixis_reset(); + } else if (strcmp(argv[1], "altbank") == 0) { + set_altbank(); + qixis_bank_reset(); + } else if (strcmp(argv[1], "watchdog") == 0) { + static char *period[9] = {"2s", "4s", "8s", "16s", "32s", + "1min", "2min", "4min", "8min"}; + u8 rcfg = QIXIS_READ(rcfg_ctl); + + if (argv[2] == NULL) { + printf("qixis watchdog <watchdog_period>\n"); + return 0; + } + for (i = 0; i < ARRAY_SIZE(period); i++) { + if (strcmp(argv[2], period[i]) == 0) { + /* disable watchdog */ + QIXIS_WRITE(rcfg_ctl, rcfg & ~0x08); + QIXIS_WRITE(watch, ((i<<2) - 1)); + QIXIS_WRITE(rcfg_ctl, rcfg); + return 0; + } + } + } + +#ifdef DEBUG + else if (strcmp(argv[1], "dump") == 0) { + qixis_dump_regs(); + return 0; + } +#endif + + else { + printf("Invalid option: %s\n", argv[1]); + return 1; + } + + return 0; +} + +U_BOOT_CMD( + qixis_reset, CONFIG_SYS_MAXARGS, 1, qixis_reset_cmd, + "Reset the board using the FPGA sequencer", + "- hard reset to default bank\n" + "qixis_reset altbank - reset to alternate bank\n" + "qixis watchdog <watchdog_period> - set the watchdog period\n" + " period: 1s 2s 4s 8s 16s 32s 1min 2min 4min 8min\n" +#ifdef DEBUG + "qixis_reset dump - display the QIXIS registers\n" +#endif + ); diff --git a/board/freescale/common/qixis.h b/board/freescale/common/qixis.h new file mode 100644 index 0000000..7a0268a --- /dev/null +++ b/board/freescale/common/qixis.h @@ -0,0 +1,101 @@ +/* + * Copyright 2011 Freescale Semiconductor + * Author: Shengzhou Liu Shengzhou.Liu@freescale.com + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the Free + * Software Foundation; either version 2 of the License, or (at your option) + * any later version. + * + * This file provides support for the QIXIS of some Freescale reference boards. + */ + +#ifndef __QIXIS_H_ +#define __QIXIS_H_ + +struct qixis { + u8 id; /* ID value uniquely identifying each QDS board type */ + u8 arch; /* Board version information */ + u8 scver; /* QIXIS Version Register */ + u8 model; /* Information of software programming model version */ + u8 tagdata; + u8 ctl_sys; + u8 aux; /* Auxiliary Register,0x06 */ + u8 clk_spd; + u8 stat_dut; + u8 stat_sys; + u8 stat_alrm; + u8 present; + u8 ctl_sys2; + u8 rcw_ctl; + u8 ctl_led; + u8 i2cblk; + u8 rcfg_ctl; /* Reconfig Control Register,0x10 */ + u8 rcfg_st; + u8 dcm_ad; + u8 dcm_da; + u8 dcmd; + u8 dmsg; + u8 gdc; + u8 gdd; /* DCM Debug Data Register,0x17 */ + u8 dmack; + u8 res1[6]; + u8 watch; /* Watchdog Register,0x1F */ + u8 pwr_ctl[2]; /* Power Control Register,0x20 */ + u8 res2[2]; + u8 pwr_stat[4]; /* Power Status Register,0x24 */ + u8 res3[8]; + u8 clk_spd2[2]; /* SYSCLK clock Speed Register,0x30 */ + u8 res4[2]; + u8 sclk[3]; /* Clock Configuration Registers,0x34 */ + u8 res5; + u8 dclk[3]; + u8 res6; + u8 clk_dspd[3]; + u8 res7; + u8 rst_ctl; /* Reset Control Register,0x40 */ + u8 rst_stat; /* Reset Status Register */ + u8 rst_rsn; /* Reset Reason Register */ + u8 rst_frc[2]; /* Reset Force Registers,0x43 */ + u8 res8[11]; + u8 brdcfg[16]; /* Board Configuration Register,0x50 */ + u8 dutcfg[16]; + u8 rcw_ad[2]; /* RCW SRAM Address Registers,0x70 */ + u8 rcw_data; + u8 res9[5]; + u8 post_ctl; + u8 post_stat; + u8 post_dat[2]; + u8 pi_d[4]; + u8 gpio_io[4]; + u8 gpio_dir[4]; + u8 res10[20]; + u8 rjtag_ctl; + u8 rjtag_dat; + u8 res11[2]; + u8 trig_src[4]; + u8 trig_dst[4]; + u8 trig_stat; + u8 res12[3]; + u8 trig_ctr[4]; + u8 res13[48]; + u8 aux2[4]; /* Auxiliary Registers,0xE0 */ + u8 res14[10]; + u8 aux_ad; + u8 aux_da; + u8 res15[16]; +}; + +#define QIXIS_BASE 0xffdf0000 +#define QIXIS_LBMAP_SWITCH 7 +#define QIXIS_LBMAP_MASK 0x0f +#define QIXIS_LBMAP_SHIFT 0 +#define QIXIS_LBMAP_ALTBANK 0x04 + +u8 qixis_read(unsigned int reg); +void qixis_write(unsigned int reg, u8 value); + +#define QIXIS_READ(reg) qixis_read(offsetof(struct qixis, reg)) +#define QIXIS_WRITE(reg, value) qixis_write(offsetof(struct qixis, reg), value) + +#endif diff --git a/board/freescale/p3060qds/Makefile b/board/freescale/p3060qds/Makefile new file mode 100644 index 0000000..ae136f4 --- /dev/null +++ b/board/freescale/p3060qds/Makefile @@ -0,0 +1,54 @@ +# +# Copyright 2011 Freescale Semiconductor, Inc. +# (C) Copyright 2001-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS-y += $(BOARD).o +COBJS-y += ddr.o +COBJS-y += eth.o +COBJS-y += fixed_ddr.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS)) + +clean: + rm -f $(OBJS) $(SOBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/freescale/p3060qds/ddr.c b/board/freescale/p3060qds/ddr.c new file mode 100644 index 0000000..8d0e714 --- /dev/null +++ b/board/freescale/p3060qds/ddr.c @@ -0,0 +1,281 @@ +/* + * Copyright 2009-2011 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * Version 2 as published by the Free Software Foundation. + */ + +#include <common.h> +#include <i2c.h> +#include <hwconfig.h> +#include <asm/mmu.h> +#include <asm/fsl_ddr_sdram.h> +#include <asm/fsl_ddr_dimm_params.h> +#include <asm/fsl_law.h> + +#include "p3060qds.h" + +/* + * Fixed sdram init -- doesn't use serial presence detect. + */ + +phys_size_t fixed_sdram(void) +{ + int i; + char buf[32]; + fsl_ddr_cfg_regs_t ddr_cfg_regs; + phys_size_t ddr_size; + unsigned int lawbar1_target_id; + ulong ddr_freq, ddr_freq_mhz; + + ddr_freq = get_ddr_freq(0); + ddr_freq_mhz = ddr_freq / 1000000; + + printf("Configuring DDR for %s MT/s data rate\n", + strmhz(buf, ddr_freq)); + + for (i = 0; fixed_ddr_parm_0[i].max_freq > 0; i++) { + if ((ddr_freq_mhz > fixed_ddr_parm_0[i].min_freq) && + (ddr_freq_mhz <= fixed_ddr_parm_0[i].max_freq)) { + memcpy(&ddr_cfg_regs, + fixed_ddr_parm_0[i].ddr_settings, + sizeof(ddr_cfg_regs)); + break; + } + } + + if (fixed_ddr_parm_0[i].max_freq == 0) + panic("Unsupported DDR data rate %s MT/s data rate\n", + strmhz(buf, ddr_freq)); + + ddr_size = (phys_size_t) CONFIG_SYS_SDRAM_SIZE * 1024 * 1024; + ddr_cfg_regs.ddr_cdr1 = DDR_CDR1_DHC_EN; + fsl_ddr_set_memctl_regs(&ddr_cfg_regs, 0); + + /* + * setup laws for DDR. If not interleaving, presuming half memory on + * DDR1 and the other half on DDR2 + */ + if (fixed_ddr_parm_0[i].ddr_settings->cs[0].config & 0x20000000) { + if (set_ddr_laws(CONFIG_SYS_DDR_SDRAM_BASE, + ddr_size, + LAW_TRGT_IF_DDR_INTRLV) < 0) { + printf("ERROR setting Local Access Windows for DDR\n"); + return 0; + } + } else { + lawbar1_target_id = LAW_TRGT_IF_DDR_1; + if (set_ddr_laws(CONFIG_SYS_DDR_SDRAM_BASE, + ddr_size, + lawbar1_target_id) < 0) { + printf("ERROR setting Local Access Windows for DDR\n"); + return 0; + } + } + return ddr_size; +} + +struct board_specific_params { + u32 datarate_mhz_low; + u32 datarate_mhz_high; + u32 n_ranks; + u32 clk_adjust; + u32 wrlvl_start; + u32 cpo; + u32 write_data_delay; + u32 force_2T; +}; + +const struct board_specific_params board_specific_parameters_udimm[][30] = { + { + /* + * memory controller 0 + * lo| hi| num| clk| wrlvl | cpo |wrdata|2T + * mhz| mhz|ranks|adjst| start | |delay | + */ + { 0, 850, 4, 4, 6, 0xff, 2, 0}, + {851, 950, 4, 5, 7, 0xff, 2, 0}, + {951, 1050, 4, 5, 8, 0xff, 2, 0}, + {1051, 1250, 4, 5, 10, 0xff, 2, 0}, + {1251, 1350, 4, 5, 11, 0xff, 2, 0}, + {1351, 1666, 4, 5, 12, 0xff, 2, 0}, + { 0, 850, 2, 5, 6, 0xff, 2, 0}, + {851, 950, 2, 5, 7, 0xff, 2, 0}, + {951, 1050, 2, 4, 4, 0xff, 2, 0}, + {1051, 1250, 2, 4, 6, 0xff, 2, 0}, + {1251, 1350, 2, 5, 7, 0xff, 2, 0}, + {1351, 1666, 2, 5, 8, 0xff, 2, 0}, + { 0, 850, 1, 4, 5, 0xff, 2, 0}, + {851, 950, 1, 4, 7, 0xff, 2, 0}, + {951, 1050, 1, 4, 8, 0xff, 2, 0}, + {1051, 1250, 1, 4, 8, 0xff, 2, 0}, + {1251, 1350, 1, 4, 8, 0xff, 2, 0}, + {1351, 1666, 1, 4, 8, 0xff, 2, 0}, + }, + + { + /* + * memory controller 1 + * lo| hi| num| clk| wrlvl | cpo |wrdata|2T + * mhz| mhz|ranks|adjst| start | |delay | + */ + { 0, 850, 4, 4, 6, 0xff, 2, 0}, + {851, 950, 4, 5, 7, 0xff, 2, 0}, + {951, 1050, 4, 5, 8, 0xff, 2, 0}, + {1051, 1250, 4, 5, 10, 0xff, 2, 0}, + {1251, 1350, 4, 5, 11, 0xff, 2, 0}, + {1351, 1666, 4, 5, 12, 0xff, 2, 0}, + { 0, 850, 2, 5, 6, 0xff, 2, 0}, + {851, 950, 2, 5, 7, 0xff, 2, 0}, + {951, 1050, 2, 4, 4, 0xff, 2, 0}, + {1051, 1250, 2, 4, 6, 0xff, 2, 0}, + {1251, 1350, 2, 5, 7, 0xff, 2, 0}, + {1351, 1666, 2, 5, 8, 0xff, 2, 0}, + { 0, 850, 1, 4, 5, 0xff, 2, 0}, + {851, 950, 1, 4, 7, 0xff, 2, 0}, + {951, 1050, 1, 4, 8, 0xff, 2, 0}, + {1051, 1250, 1, 4, 8, 0xff, 2, 0}, + {1251, 1350, 1, 4, 8, 0xff, 2, 0}, + {1351, 1666, 1, 4, 8, 0xff, 2, 0}, + } +}; + +const struct board_specific_params board_specific_parameters_rdimm[][30] = { + { + /* + * memory controller 0 + * lo| hi| num| clk| wrlvl | cpo |wrdata|2T + * mhz| mhz|ranks|adjst| start | |delay | + */ + { 0, 850, 4, 4, 6, 0xff, 2, 0}, + {851, 950, 4, 5, 7, 0xff, 2, 0}, + {951, 1050, 4, 5, 8, 0xff, 2, 0}, + {1051, 1250, 4, 5, 10, 0xff, 2, 0}, + {1251, 1350, 4, 5, 11, 0xff, 2, 0}, + {1351, 1666, 4, 5, 12, 0xff, 2, 0}, + { 0, 850, 2, 4, 6, 0xff, 2, 0}, + {851, 950, 2, 4, 7, 0xff, 2, 0}, + {951, 1050, 2, 4, 7, 0xff, 2, 0}, + {1051, 1250, 2, 4, 8, 0xff, 2, 0}, + {1251, 1350, 2, 4, 8, 0xff, 2, 0}, + {1351, 1666, 2, 4, 8, 0xff, 2, 0}, + { 0, 850, 1, 4, 5, 0xff, 2, 0}, + {851, 950, 1, 4, 7, 0xff, 2, 0}, + {951, 1050, 1, 4, 8, 0xff, 2, 0}, + {1051, 1250, 1, 4, 8, 0xff, 2, 0}, + {1251, 1350, 1, 4, 8, 0xff, 2, 0}, + {1351, 1666, 1, 4, 8, 0xff, 2, 0}, + }, + + { + /* + * memory controller 1 + * lo| hi| num| clk| wrlvl | cpo |wrdata|2T + * mhz| mhz|ranks|adjst| start | |delay | + */ + { 0, 850, 4, 4, 6, 0xff, 2, 0}, + {851, 950, 4, 5, 7, 0xff, 2, 0}, + {951, 1050, 4, 5, 8, 0xff, 2, 0}, + {1051, 1250, 4, 5, 10, 0xff, 2, 0}, + {1251, 1350, 4, 5, 11, 0xff, 2, 0}, + {1351, 1666, 4, 5, 12, 0xff, 2, 0}, + { 0, 850, 2, 4, 6, 0xff, 2, 0}, + {851, 950, 2, 4, 7, 0xff, 2, 0}, + {951, 1050, 2, 4, 7, 0xff, 2, 0}, + {1051, 1250, 2, 4, 8, 0xff, 2, 0}, + {1251, 1350, 2, 4, 8, 0xff, 2, 0}, + {1351, 1666, 2, 4, 8, 0xff, 2, 0}, + { 0, 850, 1, 4, 5, 0xff, 2, 0}, + {851, 950, 1, 4, 7, 0xff, 2, 0}, + {951, 1050, 1, 4, 8, 0xff, 2, 0}, + {1051, 1250, 1, 4, 8, 0xff, 2, 0}, + {1251, 1350, 1, 4, 8, 0xff, 2, 0}, + {1351, 1666, 1, 4, 8, 0xff, 2, 0}, + } +}; + +void fsl_ddr_board_options(memctl_options_t *popts, + dimm_params_t *pdimm, + unsigned int ctrl_num) +{ + const struct board_specific_params *pbsp; + u32 num_params; + u32 i; + ulong ddr_freq; + + if (popts->registered_dimm_en) { + pbsp = &(board_specific_parameters_rdimm[ctrl_num][0]); + num_params = sizeof(board_specific_parameters_rdimm[ctrl_num]) / + sizeof(board_specific_parameters_rdimm[0][0]); + } else { + pbsp = &(board_specific_parameters_udimm[ctrl_num][0]); + num_params = sizeof(board_specific_parameters_udimm[ctrl_num]) / + sizeof(board_specific_parameters_udimm[0][0]); + } + /* Get clk_adjust, cpo, write_data_delay,2T, according to the board ddr + * freqency and n_banks specified in board_specific_parameters table. + */ + ddr_freq = get_ddr_freq(0) / 1000000; + for (i = 0; i < num_params; i++) { + if (ddr_freq >= pbsp->datarate_mhz_low && + ddr_freq <= pbsp->datarate_mhz_high && + pdimm[0].n_ranks == pbsp->n_ranks) { + popts->cpo_override = pbsp->cpo; + popts->write_data_delay = pbsp->write_data_delay; + popts->clk_adjust = pbsp->clk_adjust; + popts->wrlvl_start = pbsp->wrlvl_start; + popts->twoT_en = pbsp->force_2T; + break; + } + pbsp++; + } + + if (i == num_params) { + printf("Warning: board specific timing not found " + "for data rate %lu MT/s!\n", ddr_freq); + } + + /* + * Factors to consider for half-strength driver enable: + * - number of DIMMs installed + */ + popts->half_strength_driver_enable = 0; + /* + * Write leveling override + */ + popts->wrlvl_override = 1; + popts->wrlvl_sample = 0xf; + + /* + * Rtt and Rtt_WR override + */ + popts->rtt_override = 0; + + /* Enable ZQ calibration */ + popts->zq_en = 1; + + /* DHC_EN =1, ODT = 60 Ohm */ + popts->ddr_cdr1 = DDR_CDR1_DHC_EN; +} + +phys_size_t initdram(int board_type) +{ + phys_size_t dram_size; + + puts("Initializing...."); + + if (fsl_use_spd()) { + puts("using SPD\n"); + dram_size = fsl_ddr_sdram(); + } else { + puts("using fixed parameters\n"); + dram_size = fixed_sdram(); + } + + dram_size = setup_ddr_tlbs(dram_size / 0x100000); + dram_size *= 0x100000; + + debug(" DDR: "); + return dram_size; +} diff --git a/board/freescale/p3060qds/eth.c b/board/freescale/p3060qds/eth.c new file mode 100644 index 0000000..1d3abef --- /dev/null +++ b/board/freescale/p3060qds/eth.c @@ -0,0 +1,440 @@ +/* + * Copyright 2011 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <netdev.h> +#include <asm/mmu.h> +#include <asm/processor.h> +#include <asm/cache.h> +#include <asm/immap_85xx.h> +#include <asm/fsl_law.h> +#include <asm/fsl_ddr_sdram.h> +#include <asm/fsl_serdes.h> +#include <asm/fsl_portals.h> +#include <asm/fsl_liodn.h> +#include <malloc.h> +#include <fm_eth.h> +#include <fsl_mdio.h> +#include <miiphy.h> +#include <phy.h> +#include <asm/fsl_dtsec.h> + +#include "../common/qixis.h" +#include "../common/fman.h" + +#define EMI_NONE 0xffffffff +#define EMI1_RGMII1 0 +#define EMI1_SLOT1 1 +#define EMI1_SLOT2 2 +#define EMI1_SLOT3 3 +#define EMI1_RGMII2 4 + +#define BRDCFG4_MASK 0xF0 + +static int mdio_mux[NUM_FM_PORTS]; + +static char *mdio_names[5] = { + "P3060QDS_MDIO0", + "P3060QDS_MDIO1", + "P3060QDS_MDIO2", + "P3060QDS_MDIO3", + "P3060QDS_MDIO4", +}; + +/* + * Mapping of all 18 SERDES lanes to board slots. + * A value of '0' here means that the mapping must be determined + * dynamically, Lane 8/9/16/17 map to Slot1 or Aurora debug + */ +static u8 lane_to_slot[] = { + 4, 4, 4, 4, 3, 3, 3, 3, 0, 0, 2, 2, 2, 2, 1, 1, 0, 0 +}; + +static char *p3060qds_mdio_name_for_muxval(u32 muxval) +{ + return mdio_names[muxval]; +} + +struct mii_dev *mii_dev_for_muxval(u32 muxval) +{ + struct mii_dev *bus; + char *name = p3060qds_mdio_name_for_muxval(muxval); + + if (!name) { + printf("No bus for muxval %x\n", muxval); + return NULL; + } + + bus = miiphy_get_dev_by_name(name); + + if (!bus) { + printf("No bus by name %s\n", name); + return NULL; + } + + return bus; +} + +struct p3060qds_mdio { + u32 muxval; + struct mii_dev *realbus; +}; + +static void p3060qds_mux_mdio(u32 muxval) +{ + u8 brdcfg4; + + brdcfg4 = QIXIS_READ(brdcfg[4]); + brdcfg4 &= ~BRDCFG4_MASK; + brdcfg4 |= (muxval << 4); + QIXIS_WRITE(brdcfg[4], brdcfg4); +} + +static int p3060qds_mdio_read(struct mii_dev *bus, int addr, int devad, + int regnum) +{ + struct p3060qds_mdio *priv = bus->priv; + + p3060qds_mux_mdio(priv->muxval); + + return priv->realbus->read(priv->realbus, addr, devad, regnum); +} + +static int p3060qds_mdio_write(struct mii_dev *bus, int addr, int devad, + int regnum, u16 value) +{ + struct p3060qds_mdio *priv = bus->priv; + + p3060qds_mux_mdio(priv->muxval); + + return priv->realbus->write(priv->realbus, addr, devad, regnum, value); +} + +static int p3060qds_mdio_reset(struct mii_dev *bus) +{ + struct p3060qds_mdio *priv = bus->priv; + + return priv->realbus->reset(priv->realbus); +} + +static int p3060qds_mdio_init(char *realbusname, u32 muxval) +{ + struct p3060qds_mdio *pmdio; + struct mii_dev *bus = mdio_alloc(); + + if (!bus) { + printf("Failed to allocate P3060QDS MDIO bus\n"); + return -1; + } + + pmdio = malloc(sizeof(*pmdio)); + if (!pmdio) { + printf("Failed to allocate P3060QDS private data\n"); + free(bus); + return -1; + } + + bus->read = p3060qds_mdio_read; + bus->write = p3060qds_mdio_write; + bus->reset = p3060qds_mdio_reset; + sprintf(bus->name, p3060qds_mdio_name_for_muxval(muxval)); + + pmdio->realbus = miiphy_get_dev_by_name(realbusname); + + if (!pmdio->realbus) { + printf("No bus with name %s\n", realbusname); + free(bus); + free(pmdio); + return -1; + } + + pmdio->muxval = muxval; + bus->priv = pmdio; + + return mdio_register(bus); +} + +static void fdt_set_node_status(void *fdt, const char *alias, + const char *status) +{ + const char *path = fdt_get_alias(fdt, alias); + + if (!path) + path = alias; + + do_fixup_by_path(fdt, path, "status", status, strlen(status) + 1, 1); +} + +void board_ft_fman_fixup_port(void *blob, char * prop, phys_addr_t pa, + enum fm_port port, int offset) +{ + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + int srds_prtcl = (in_be32(&gur->rcwsr[4]) & + FSL_CORENET_RCWSR4_SRDS_PRTCL) >> 26; + + if (mdio_mux[port] == EMI1_RGMII1) + fdt_set_phy_handle(blob, prop, pa, "phy_rgmii1"); + + if (mdio_mux[port] == EMI1_RGMII2) + fdt_set_phy_handle(blob, prop, pa, "phy_rgmii2"); + + if ((mdio_mux[port] == EMI1_SLOT1) && ((srds_prtcl == 0x3) + || (srds_prtcl == 0x6))) { + switch (port) { + case FM2_DTSEC4: + fdt_set_phy_handle(blob, prop, pa, "phy2_slot1"); + break; + case FM1_DTSEC4: + fdt_set_phy_handle(blob, prop, pa, "phy3_slot1"); + break; + default: + break; + } + } + + if (mdio_mux[port] == EMI1_SLOT3) { + switch (port) { + case FM2_DTSEC3: + fdt_set_phy_handle(blob, prop, pa, "phy0_slot3"); + break; + case FM1_DTSEC3: + fdt_set_phy_handle(blob, prop, pa, "phy1_slot3"); + break; + default: + break; + } + } +} + +void fdt_fixup_board_enet(void *fdt) +{ + int i, lane, idx; + + for (i = FM1_DTSEC1; i < FM1_DTSEC1 + CONFIG_SYS_NUM_FM1_DTSEC; i++) { + idx = i - FM1_DTSEC1; + switch (fm_info_get_enet_if(i)) { + case PHY_INTERFACE_MODE_SGMII: + lane = serdes_get_first_lane(SGMII_FM1_DTSEC1 + idx); + if (lane >= 0) { + switch (mdio_mux[i]) { + case EMI1_SLOT1: + if (lane >= 14) + fdt_set_node_status(fdt, + "emi1_slot1", "okay"); + else + fdt_set_node_status(fdt, + "emi1_slot1_bk1", "okay"); + break; + case EMI1_SLOT2: + fdt_set_node_status(fdt, "emi1_slot2", + "okay"); + break; + case EMI1_SLOT3: + fdt_set_node_status(fdt, "emi1_slot3", + "okay"); + break; + } + } + break; + case PHY_INTERFACE_MODE_RGMII: + fdt_set_node_status(fdt, "emi1_rgmii", "okay"); + break; + default: + break; + } + } +#if (CONFIG_SYS_NUM_FMAN == 2) + for (i = FM2_DTSEC1; i < FM2_DTSEC1 + CONFIG_SYS_NUM_FM2_DTSEC; i++) { + idx = i - FM2_DTSEC1; + switch (fm_info_get_enet_if(i)) { + case PHY_INTERFACE_MODE_SGMII: + lane = serdes_get_first_lane(SGMII_FM2_DTSEC1 + idx); + if (lane >= 0) { + switch (mdio_mux[i]) { + case EMI1_SLOT1: + if (lane >= 14) + fdt_set_node_status(fdt, + "emi1_slot1", "okay"); + else + fdt_set_node_status(fdt, + "emi1_slot1_bk1", "okay"); + break; + case EMI1_SLOT2: + fdt_set_node_status(fdt, "emi1_slot2", + "okay"); + break; + case EMI1_SLOT3: + fdt_set_node_status(fdt, "emi1_slot3", + "okay"); + break; + } + } + break; + case PHY_INTERFACE_MODE_RGMII: + fdt_set_node_status(fdt, "emi1_rgmii", "okay"); + break; + default: + break; + } + } +#endif +} + +static void initialize_lane_to_slot(void) +{ + u8 brdcfg6 = QIXIS_READ(brdcfg[6]) & 0xf; + + /* 1:Slot1, 5:Aurora debug */ + lane_to_slot[8] = (brdcfg6 == 0xa) ? 1 : 5; + lane_to_slot[9] = lane_to_slot[8]; + lane_to_slot[16] = (brdcfg6 == 0xa) ? 5 : 1; + lane_to_slot[17] = lane_to_slot[16]; +} + +int board_eth_init(bd_t *bis) +{ +#ifdef CONFIG_FMAN_ENET + struct dtsec *tsec = (void *)CONFIG_SYS_FSL_FM1_DTSEC1_ADDR; + int i; + struct fsl_pq_mdio_info dtsec_mdio_info; + + initialize_lane_to_slot(); + + /* + * Set TBIPA on FM1@DTSEC1. This is needed for configurations + * where FM1@DTSEC1 isn't used directly, since it provides + * MDIO for other ports. + */ + out_be32(&tsec->tbipa, CONFIG_SYS_TBIPA_VALUE); + + /* Initialize the mdio_mux array so we can recognize empty elements */ + for (i = 0; i < NUM_FM_PORTS; i++) + mdio_mux[i] = EMI_NONE; + + dtsec_mdio_info.regs = + (struct tsec_mii_mng *)CONFIG_SYS_FM1_DTSEC1_MDIO_ADDR; + dtsec_mdio_info.name = DEFAULT_FM_MDIO_NAME; + + /* Register the 1G MDIO bus */ + fsl_pq_mdio_init(bis, &dtsec_mdio_info); + + /* Register the 6 muxing front-ends to the MDIO buses */ + p3060qds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_RGMII1); + p3060qds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_SLOT1); + p3060qds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_SLOT2); + p3060qds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_SLOT3); + p3060qds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_RGMII2); + + fm_info_set_phy_address(FM1_DTSEC1, 1); /* RGMII1 */ + fm_info_set_phy_address(FM1_DTSEC2, 2); /* RGMII2 */ + fm_info_set_phy_address(FM2_DTSEC3, CONFIG_SYS_FM1_DTSEC1_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC3, CONFIG_SYS_FM1_DTSEC2_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC4, CONFIG_SYS_FM1_DTSEC3_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC4, CONFIG_SYS_FM1_DTSEC4_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC1, CONFIG_SYS_FM2_DTSEC1_PHY_ADDR); + fm_info_set_phy_address(FM2_DTSEC2, CONFIG_SYS_FM2_DTSEC3_PHY_ADDR); + + for (i = FM1_DTSEC1; i < FM1_DTSEC1 + CONFIG_SYS_NUM_FM1_DTSEC; i++) { + int idx = i - FM1_DTSEC1, lane, slot; + switch (fm_info_get_enet_if(i)) { + case PHY_INTERFACE_MODE_SGMII: + lane = serdes_get_first_lane(SGMII_FM1_DTSEC1 + idx); + if (lane < 0) + break; + slot = lane_to_slot[lane]; + if (QIXIS_READ(present) & (1 << (slot - 1))) + fm_disable_port(i); + switch (slot) { + case 1: + mdio_mux[i] = EMI1_SLOT1; + fm_info_set_mdio(i, + mii_dev_for_muxval(mdio_mux[i])); + break; + case 2: + mdio_mux[i] = EMI1_SLOT2; + fm_info_set_mdio(i, + mii_dev_for_muxval(mdio_mux[i])); + break; + case 3: + mdio_mux[i] = EMI1_SLOT3; + fm_info_set_mdio(i, + mii_dev_for_muxval(mdio_mux[i])); + break; + }; + break; + case PHY_INTERFACE_MODE_RGMII: + if (i == FM1_DTSEC1) { + mdio_mux[i] = EMI1_RGMII1; + fm_info_set_mdio(i, + mii_dev_for_muxval(mdio_mux[i])); + } else if (i == FM1_DTSEC2) { + mdio_mux[i] = EMI1_RGMII2; + fm_info_set_mdio(i, + mii_dev_for_muxval(mdio_mux[i])); + } + break; + default: + break; + } + } + +#if (CONFIG_SYS_NUM_FMAN == 2) + for (i = FM2_DTSEC1; i < FM2_DTSEC1 + CONFIG_SYS_NUM_FM2_DTSEC; i++) { + int idx = i - FM2_DTSEC1, lane, slot; + switch (fm_info_get_enet_if(i)) { + case PHY_INTERFACE_MODE_SGMII: + lane = serdes_get_first_lane(SGMII_FM2_DTSEC1 + idx); + if (lane < 0) + break; + slot = lane_to_slot[lane]; + if (QIXIS_READ(present) & (1 << (slot - 1))) + fm_disable_port(i); + switch (slot) { + case 1: + mdio_mux[i] = EMI1_SLOT1; + fm_info_set_mdio(i, + mii_dev_for_muxval(mdio_mux[i])); + break; + case 2: + mdio_mux[i] = EMI1_SLOT2; + fm_info_set_mdio(i, + mii_dev_for_muxval(mdio_mux[i])); + break; + case 3: + mdio_mux[i] = EMI1_SLOT3; + fm_info_set_mdio(i, + mii_dev_for_muxval(mdio_mux[i])); + break; + }; + break; + default: + break; + } + } +#endif /* CONFIG_SYS_NUM_FMAN */ + + cpu_eth_init(bis); +#endif /* CONFIG_FMAN_ENET */ + + return pci_eth_init(bis); +} diff --git a/board/freescale/p3060qds/fixed_ddr.c b/board/freescale/p3060qds/fixed_ddr.c new file mode 100644 index 0000000..125988d --- /dev/null +++ b/board/freescale/p3060qds/fixed_ddr.c @@ -0,0 +1,214 @@ +/* + * Copyright 2009-2011 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * Version 2 as published by the Free Software Foundation. + */ + +#include <common.h> +#include <asm/fsl_ddr_sdram.h> + +#define CONFIG_SYS_DDR_TIMING_3_1200 0x01030000 +#define CONFIG_SYS_DDR_TIMING_0_1200 0xCC550104 +#define CONFIG_SYS_DDR_TIMING_1_1200 0x868FAA45 +#define CONFIG_SYS_DDR_TIMING_2_1200 0x0FB8A912 +#define CONFIG_SYS_DDR_MODE_1_1200 0x00441A40 +#define CONFIG_SYS_DDR_MODE_2_1200 0x00100000 +#define CONFIG_SYS_DDR_INTERVAL_1200 0x12480100 +#define CONFIG_SYS_DDR_CLK_CTRL_1200 0x02800000 + +#define CONFIG_SYS_DDR_TIMING_3_1000 0x00020000 +#define CONFIG_SYS_DDR_TIMING_0_1000 0xCC440104 +#define CONFIG_SYS_DDR_TIMING_1_1000 0x727DF944 +#define CONFIG_SYS_DDR_TIMING_2_1000 0x0FB088CF +#define CONFIG_SYS_DDR_MODE_1_1000 0x00441830 +#define CONFIG_SYS_DDR_MODE_2_1000 0x00080000 +#define CONFIG_SYS_DDR_INTERVAL_1000 0x0F3C0100 +#define CONFIG_SYS_DDR_CLK_CTRL_1000 0x02800000 + +#define CONFIG_SYS_DDR_TIMING_3_900 0x00020000 +#define CONFIG_SYS_DDR_TIMING_0_900 0xCC440104 +#define CONFIG_SYS_DDR_TIMING_1_900 0x616ba844 +#define CONFIG_SYS_DDR_TIMING_2_900 0x0fb088ce +#define CONFIG_SYS_DDR_MODE_1_900 0x00441620 +#define CONFIG_SYS_DDR_MODE_2_900 0x00080000 +#define CONFIG_SYS_DDR_INTERVAL_900 0x0db60100 +#define CONFIG_SYS_DDR_CLK_CTRL_900 0x02800000 + +#define CONFIG_SYS_DDR_TIMING_3_800 0x00020000 +#define CONFIG_SYS_DDR_TIMING_0_800 0xcc330104 +#define CONFIG_SYS_DDR_TIMING_1_800 0x6f6b4744 +#define CONFIG_SYS_DDR_TIMING_2_800 0x0fa888cc +#define CONFIG_SYS_DDR_MODE_1_800 0x00441420 +#define CONFIG_SYS_DDR_MODE_2_800 0x00000000 +#define CONFIG_SYS_DDR_INTERVAL_800 0x0c300100 +#define CONFIG_SYS_DDR_CLK_CTRL_800 0x02800000 + +#define CONFIG_SYS_DDR_CS0_BNDS 0x000000FF +#define CONFIG_SYS_DDR_CS1_BNDS 0x00000000 +#define CONFIG_SYS_DDR_CS2_BNDS 0x000000FF +#define CONFIG_SYS_DDR_CS3_BNDS 0x000000FF +#define CONFIG_SYS_DDR2_CS0_BNDS 0x000000FF +#define CONFIG_SYS_DDR2_CS1_BNDS 0x00000000 +#define CONFIG_SYS_DDR2_CS2_BNDS 0x000000FF +#define CONFIG_SYS_DDR2_CS3_BNDS 0x000000FF +#define CONFIG_SYS_DDR_CS0_CONFIG 0xA0044202 +#define CONFIG_SYS_DDR_CS0_CONFIG_2 0x00000000 +#define CONFIG_SYS_DDR_CS1_CONFIG 0x80004202 +#define CONFIG_SYS_DDR_CS2_CONFIG 0x00000000 +#define CONFIG_SYS_DDR_CS3_CONFIG 0x00000000 +#define CONFIG_SYS_DDR2_CS0_CONFIG 0x80044202 +#define CONFIG_SYS_DDR2_CS1_CONFIG 0x80004202 +#define CONFIG_SYS_DDR2_CS2_CONFIG 0x00000000 +#define CONFIG_SYS_DDR2_CS3_CONFIG 0x00000000 +#define CONFIG_SYS_DDR_INIT_ADDR 0x00000000 +#define CONFIG_SYS_DDR_INIT_EXT_ADDR 0x00000000 +#define CONFIG_SYS_DDR_CS1_CONFIG 0x80004202 +#define CONFIG_SYS_DDR_DATA_INIT 0xdeadbeef +#define CONFIG_SYS_DDR_TIMING_4 0x00000001 +#define CONFIG_SYS_DDR_TIMING_5 0x02401400 +#define CONFIG_SYS_DDR_MODE_CONTROL 0x00000000 +#define CONFIG_SYS_DDR_ZQ_CNTL 0x89080600 +#define CONFIG_SYS_DDR_WRLVL_CNTL 0x8675F607 +#define CONFIG_SYS_DDR_SDRAM_CFG 0xE7044000 +#define CONFIG_SYS_DDR_SDRAM_CFG2 0x24401031 +#define CONFIG_SYS_DDR_RCW_1 0x00000000 +#define CONFIG_SYS_DDR_RCW_2 0x00000000 +#define CONFIG_MEM_INIT_VALUE 0xdeadbeef + +fsl_ddr_cfg_regs_t ddr_cfg_regs_800 = { + .cs[0].bnds = CONFIG_SYS_DDR_CS0_BNDS, + .cs[1].bnds = CONFIG_SYS_DDR_CS1_BNDS, + .cs[2].bnds = CONFIG_SYS_DDR_CS2_BNDS, + .cs[3].bnds = CONFIG_SYS_DDR_CS3_BNDS, + .cs[0].config = CONFIG_SYS_DDR_CS0_CONFIG, + .cs[0].config_2 = CONFIG_SYS_DDR_CS0_CONFIG_2, + .cs[1].config = CONFIG_SYS_DDR_CS1_CONFIG, + .cs[2].config = CONFIG_SYS_DDR_CS2_CONFIG, + .cs[3].config = CONFIG_SYS_DDR_CS3_CONFIG, + .timing_cfg_3 = CONFIG_SYS_DDR_TIMING_3_800, + .timing_cfg_0 = CONFIG_SYS_DDR_TIMING_0_800, + .timing_cfg_1 = CONFIG_SYS_DDR_TIMING_1_800, + .timing_cfg_2 = CONFIG_SYS_DDR_TIMING_2_800, + .ddr_sdram_cfg = CONFIG_SYS_DDR_SDRAM_CFG, + .ddr_sdram_cfg_2 = CONFIG_SYS_DDR_SDRAM_CFG2, + .ddr_sdram_mode = CONFIG_SYS_DDR_MODE_1_800, + .ddr_sdram_mode_2 = CONFIG_SYS_DDR_MODE_2_800, + .ddr_sdram_md_cntl = CONFIG_SYS_DDR_MODE_CONTROL, + .ddr_sdram_interval = CONFIG_SYS_DDR_INTERVAL_800, + .ddr_data_init = CONFIG_MEM_INIT_VALUE, + .ddr_sdram_clk_cntl = CONFIG_SYS_DDR_CLK_CTRL_800, + .ddr_init_addr = CONFIG_SYS_DDR_INIT_ADDR, + .ddr_init_ext_addr = CONFIG_SYS_DDR_INIT_EXT_ADDR, + .timing_cfg_4 = CONFIG_SYS_DDR_TIMING_4, + .timing_cfg_5 = CONFIG_SYS_DDR_TIMING_5, + .ddr_zq_cntl = CONFIG_SYS_DDR_ZQ_CNTL, + .ddr_wrlvl_cntl = CONFIG_SYS_DDR_WRLVL_CNTL, + .ddr_sdram_rcw_1 = CONFIG_SYS_DDR_RCW_1, + .ddr_sdram_rcw_2 = CONFIG_SYS_DDR_RCW_2 +}; + +fsl_ddr_cfg_regs_t ddr_cfg_regs_900 = { + .cs[0].bnds = CONFIG_SYS_DDR_CS0_BNDS, + .cs[1].bnds = CONFIG_SYS_DDR_CS1_BNDS, + .cs[2].bnds = CONFIG_SYS_DDR_CS2_BNDS, + .cs[3].bnds = CONFIG_SYS_DDR_CS3_BNDS, + .cs[0].config = CONFIG_SYS_DDR_CS0_CONFIG, + .cs[0].config_2 = CONFIG_SYS_DDR_CS0_CONFIG_2, + .cs[1].config = CONFIG_SYS_DDR_CS1_CONFIG, + .cs[2].config = CONFIG_SYS_DDR_CS2_CONFIG, + .cs[3].config = CONFIG_SYS_DDR_CS3_CONFIG, + .timing_cfg_3 = CONFIG_SYS_DDR_TIMING_3_900, + .timing_cfg_0 = CONFIG_SYS_DDR_TIMING_0_900, + .timing_cfg_1 = CONFIG_SYS_DDR_TIMING_1_900, + .timing_cfg_2 = CONFIG_SYS_DDR_TIMING_2_900, + .ddr_sdram_cfg = CONFIG_SYS_DDR_SDRAM_CFG, + .ddr_sdram_cfg_2 = CONFIG_SYS_DDR_SDRAM_CFG2, + .ddr_sdram_mode = CONFIG_SYS_DDR_MODE_1_900, + .ddr_sdram_mode_2 = CONFIG_SYS_DDR_MODE_2_900, + .ddr_sdram_md_cntl = CONFIG_SYS_DDR_MODE_CONTROL, + .ddr_sdram_interval = CONFIG_SYS_DDR_INTERVAL_900, + .ddr_data_init = CONFIG_MEM_INIT_VALUE, + .ddr_sdram_clk_cntl = CONFIG_SYS_DDR_CLK_CTRL_900, + .ddr_init_addr = CONFIG_SYS_DDR_INIT_ADDR, + .ddr_init_ext_addr = CONFIG_SYS_DDR_INIT_EXT_ADDR, + .timing_cfg_4 = CONFIG_SYS_DDR_TIMING_4, + .timing_cfg_5 = CONFIG_SYS_DDR_TIMING_5, + .ddr_zq_cntl = CONFIG_SYS_DDR_ZQ_CNTL, + .ddr_wrlvl_cntl = CONFIG_SYS_DDR_WRLVL_CNTL, + .ddr_sdram_rcw_1 = CONFIG_SYS_DDR_RCW_1, + .ddr_sdram_rcw_2 = CONFIG_SYS_DDR_RCW_2 +}; + +fsl_ddr_cfg_regs_t ddr_cfg_regs_1000 = { + .cs[0].bnds = CONFIG_SYS_DDR_CS0_BNDS, + .cs[1].bnds = CONFIG_SYS_DDR_CS1_BNDS, + .cs[2].bnds = CONFIG_SYS_DDR_CS2_BNDS, + .cs[3].bnds = CONFIG_SYS_DDR_CS3_BNDS, + .cs[0].config = CONFIG_SYS_DDR_CS0_CONFIG, + .cs[0].config_2 = CONFIG_SYS_DDR_CS0_CONFIG_2, + .cs[1].config = CONFIG_SYS_DDR_CS1_CONFIG, + .cs[2].config = CONFIG_SYS_DDR_CS2_CONFIG, + .cs[3].config = CONFIG_SYS_DDR_CS3_CONFIG, + .timing_cfg_3 = CONFIG_SYS_DDR_TIMING_3_1000, + .timing_cfg_0 = CONFIG_SYS_DDR_TIMING_0_1000, + .timing_cfg_1 = CONFIG_SYS_DDR_TIMING_1_1000, + .timing_cfg_2 = CONFIG_SYS_DDR_TIMING_2_1000, + .ddr_sdram_cfg = CONFIG_SYS_DDR_SDRAM_CFG, + .ddr_sdram_cfg_2 = CONFIG_SYS_DDR_SDRAM_CFG2, + .ddr_sdram_mode = CONFIG_SYS_DDR_MODE_1_1000, + .ddr_sdram_mode_2 = CONFIG_SYS_DDR_MODE_2_1000, + .ddr_sdram_md_cntl = CONFIG_SYS_DDR_MODE_CONTROL, + .ddr_sdram_interval = CONFIG_SYS_DDR_INTERVAL_1000, + .ddr_data_init = CONFIG_MEM_INIT_VALUE, + .ddr_sdram_clk_cntl = CONFIG_SYS_DDR_CLK_CTRL_1000, + .ddr_init_addr = CONFIG_SYS_DDR_INIT_ADDR, + .ddr_init_ext_addr = CONFIG_SYS_DDR_INIT_EXT_ADDR, + .timing_cfg_4 = CONFIG_SYS_DDR_TIMING_4, + .timing_cfg_5 = CONFIG_SYS_DDR_TIMING_5, + .ddr_zq_cntl = CONFIG_SYS_DDR_ZQ_CNTL, + .ddr_wrlvl_cntl = CONFIG_SYS_DDR_WRLVL_CNTL, + .ddr_sdram_rcw_1 = CONFIG_SYS_DDR_RCW_1, + .ddr_sdram_rcw_2 = CONFIG_SYS_DDR_RCW_2 +}; + +fsl_ddr_cfg_regs_t ddr_cfg_regs_1200 = { + .cs[0].bnds = CONFIG_SYS_DDR_CS0_BNDS, + .cs[1].bnds = CONFIG_SYS_DDR_CS1_BNDS, + .cs[2].bnds = CONFIG_SYS_DDR_CS2_BNDS, + .cs[3].bnds = CONFIG_SYS_DDR_CS3_BNDS, + .cs[0].config = CONFIG_SYS_DDR_CS0_CONFIG, + .cs[0].config_2 = CONFIG_SYS_DDR_CS0_CONFIG_2, + .cs[1].config = CONFIG_SYS_DDR_CS1_CONFIG, + .cs[2].config = CONFIG_SYS_DDR_CS2_CONFIG, + .cs[3].config = CONFIG_SYS_DDR_CS3_CONFIG, + .timing_cfg_3 = CONFIG_SYS_DDR_TIMING_3_1200, + .timing_cfg_0 = CONFIG_SYS_DDR_TIMING_0_1200, + .timing_cfg_1 = CONFIG_SYS_DDR_TIMING_1_1200, + .timing_cfg_2 = CONFIG_SYS_DDR_TIMING_2_1200, + .ddr_sdram_cfg = CONFIG_SYS_DDR_SDRAM_CFG, + .ddr_sdram_cfg_2 = CONFIG_SYS_DDR_SDRAM_CFG2, + .ddr_sdram_mode = CONFIG_SYS_DDR_MODE_1_1200, + .ddr_sdram_mode_2 = CONFIG_SYS_DDR_MODE_2_1200, + .ddr_sdram_md_cntl = CONFIG_SYS_DDR_MODE_CONTROL, + .ddr_sdram_interval = CONFIG_SYS_DDR_INTERVAL_1200, + .ddr_data_init = CONFIG_MEM_INIT_VALUE, + .ddr_sdram_clk_cntl = CONFIG_SYS_DDR_CLK_CTRL_1200, + .ddr_init_addr = CONFIG_SYS_DDR_INIT_ADDR, + .ddr_init_ext_addr = CONFIG_SYS_DDR_INIT_EXT_ADDR, + .timing_cfg_4 = CONFIG_SYS_DDR_TIMING_4, + .timing_cfg_5 = CONFIG_SYS_DDR_TIMING_5, + .ddr_zq_cntl = CONFIG_SYS_DDR_ZQ_CNTL, + .ddr_wrlvl_cntl = CONFIG_SYS_DDR_WRLVL_CNTL, + .ddr_sdram_rcw_1 = CONFIG_SYS_DDR_RCW_1, + .ddr_sdram_rcw_2 = CONFIG_SYS_DDR_RCW_2 +}; + +fixed_ddr_parm_t fixed_ddr_parm_0[] = { + {750, 850, &ddr_cfg_regs_800}, + {850, 950, &ddr_cfg_regs_900}, + {950, 1050, &ddr_cfg_regs_1000}, + {1050, 1250, &ddr_cfg_regs_1200}, + {0, 0, NULL} +}; diff --git a/board/freescale/p3060qds/p3060qds.c b/board/freescale/p3060qds/p3060qds.c new file mode 100644 index 0000000..7482866 --- /dev/null +++ b/board/freescale/p3060qds/p3060qds.c @@ -0,0 +1,239 @@ +/* + * Copyright 2011 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <netdev.h> +#include <linux/compiler.h> +#include <asm/mmu.h> +#include <asm/processor.h> +#include <asm/cache.h> +#include <asm/immap_85xx.h> +#include <asm/fsl_law.h> +#include <asm/fsl_serdes.h> +#include <asm/fsl_portals.h> +#include <asm/fsl_liodn.h> +#include <fm_eth.h> +#include <configs/P3060QDS.h> + +#include "../common/qixis.h" +#include "p3060qds.h" + +DECLARE_GLOBAL_DATA_PTR; + +int checkboard(void) +{ + u8 sw; + struct cpu_type *cpu = gd->cpu; + ccsr_gur_t *gur = (void *)CONFIG_SYS_MPC85xx_GUTS_ADDR; + unsigned int i; + + printf("Board: %s", cpu->name); + puts("QDS, "); + + printf("Sys ID: 0x%02x, Sys Ver: 0x%02x, FPGA Ver: 0x%02x, ", + QIXIS_READ(id), QIXIS_READ(arch), QIXIS_READ(scver)); + + sw = QIXIS_READ(brdcfg[0]); + sw = (sw & QIXIS_LBMAP_MASK) >> QIXIS_LBMAP_SHIFT; + + if (sw < 0x8) + printf("vBank: %d\n", sw); + else if (sw == 0x8) + puts("Promjet\n"); + else if (sw == 0x9) + puts("NAND\n"); + else + printf("invalid setting of SW%u\n", PIXIS_LBMAP_SWITCH); + +#ifdef CONFIG_PHYS_64BIT + puts("36-bit Addressing\n"); +#endif + puts("Reset Configuration Word (RCW):"); + for (i = 0; i < ARRAY_SIZE(gur->rcwsr); i++) { + u32 rcw = in_be32(&gur->rcwsr[i]); + + if ((i % 4) == 0) + printf("\n %08x:", i * 4); + printf(" %08x", rcw); + } + puts("\n"); + + puts("SERDES Reference Clocks: "); + sw = QIXIS_READ(brdcfg[2]); + for (i = 0; i < 3; i++) { + static const char *freq[] = {"100", "125", "Reserved", + "156.25"}; + unsigned int clock = (sw >> (2 * i)) & 3; + + printf("Bank%u=%sMhz ", i+1, freq[clock]); + } + puts("\n"); + + return 0; +} + +int board_early_init_f(void) +{ + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + + /* only single DDR controller on QDS board, disable DDR1_MCK4/5 */ + setbits_be32(&gur->ddrclkdr, 0x00030000); + + return 0; +} + +void board_config_serdes_mux(void) +{ + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + int cfg = (in_be32(&gur->rcwsr[4]) & + FSL_CORENET_RCWSR4_SRDS_PRTCL) >> 26; + + switch (cfg) { + case 0x03: + case 0x06: + /* set Lane I,J as SGMII */ + QIXIS_WRITE(brdcfg[6], 0x0a); + break; + case 0x16: + case 0x19: + case 0x1c: + /* set Lane I,J as Aurora Debug */ + QIXIS_WRITE(brdcfg[6], 0x05); + break; + default: + break; + } +} + +int board_early_init_r(void) +{ + const unsigned int flashbase = CONFIG_SYS_FLASH_BASE; + const u8 flash_esel = find_tlb_idx((void *)flashbase, 1); + + /* + * Remap Boot flash + PROMJET region to caching-inhibited + * so that flash can be erased properly. + */ + + /* Flush d-cache and invalidate i-cache of any FLASH data */ + flush_dcache(); + invalidate_icache(); + + /* invalidate existing TLB entry for flash + promjet */ + disable_tlb(flash_esel); + + set_tlb(1, flashbase, CONFIG_SYS_FLASH_BASE_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, flash_esel, BOOKE_PAGESZ_256M, 1); + + set_liodns(); +#ifdef CONFIG_SYS_DPAA_QBMAN + setup_portals(); +#endif + board_config_serdes_mux(); + + return 0; +} + +static const char *serdes_clock_to_string(u32 clock) +{ + switch (clock) { + case SRDS_PLLCR0_RFCK_SEL_100: + return "100"; + case SRDS_PLLCR0_RFCK_SEL_125: + return "125"; + case SRDS_PLLCR0_RFCK_SEL_156_25: + return "156.25"; + default: + return "150"; + } +} + +#define NUM_SRDS_BANKS 3 + +int misc_init_r(void) +{ + serdes_corenet_t *srds_regs; + u32 actual[NUM_SRDS_BANKS]; + unsigned int i; + u8 sw; + + sw = QIXIS_READ(brdcfg[2]); + for (i = 0; i < 3; i++) { + unsigned int clock = (sw >> (2 * i)) & 3; + switch (clock) { + case 0: + actual[i] = SRDS_PLLCR0_RFCK_SEL_100; + break; + case 1: + actual[i] = SRDS_PLLCR0_RFCK_SEL_125; + break; + case 3: + actual[i] = SRDS_PLLCR0_RFCK_SEL_156_25; + break; + default: + printf("Warning: SDREFCLK%u switch setting of '10' is " + "unsupported\n", i + 1); + break; + } + } + + srds_regs = (void *)CONFIG_SYS_FSL_CORENET_SERDES_ADDR; + for (i = 0; i < NUM_SRDS_BANKS; i++) { + u32 pllcr0 = in_be32(&srds_regs->bank[i].pllcr0); + u32 expected = pllcr0 & SRDS_PLLCR0_RFCK_SEL_MASK; + if (expected != actual[i]) { + printf("Warning: SERDES bank %u expects reference clock" + " %sMHz, but actual is %sMHz\n", i + 1, + serdes_clock_to_string(expected), + serdes_clock_to_string(actual[i])); + } + } + + return 0; +} + +void ft_board_setup(void *blob, bd_t *bd) +{ + phys_addr_t base; + phys_size_t size; + + ft_cpu_setup(blob, bd); + + base = getenv_bootm_low(); + size = getenv_bootm_size(); + + fdt_fixup_memory(blob, (u64)base, (u64)size); + +#ifdef CONFIG_PCI + pci_of_setup(blob, bd); +#endif + + fdt_fixup_liodn(blob); + fdt_fixup_dr_usb(blob, bd); + +#ifdef CONFIG_SYS_DPAA_FMAN + fdt_fixup_fman_ethernet(blob); + fdt_fixup_board_enet(blob); +#endif +} diff --git a/board/freescale/p3060qds/p3060qds.h b/board/freescale/p3060qds/p3060qds.h new file mode 100644 index 0000000..3da6815 --- /dev/null +++ b/board/freescale/p3060qds/p3060qds.h @@ -0,0 +1,30 @@ +/* + * Copyright 2011 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __P3060QDS_H__ +#define __P3060QDS_H__ + +#include <asm/fsl_ddr_sdram.h> +#include <asm/u-boot.h> + +void fdt_fixup_board_enet(void *blob); +void pci_of_setup(void *blob, bd_t *bd); +extern fixed_ddr_parm_t fixed_ddr_parm_0[]; + +#endif diff --git a/boards.cfg b/boards.cfg index c673b4f..a39aea0 100644 --- a/boards.cfg +++ b/boards.cfg @@ -677,6 +677,8 @@ P3041DS_NAND powerpc mpc85xx corenet_ds freescale - P3041DS_SDCARD powerpc mpc85xx corenet_ds freescale - P3041DS:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 P3041DS_SECURE_BOOT powerpc mpc85xx corenet_ds freescale - P3041DS:SECURE_BOOT P3041DS_SPIFLASH powerpc mpc85xx corenet_ds freescale - P3041DS:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 +P3060QDS powerpc mpc85xx p3060qds freescale +P3060QDS_SPIFLASH powerpc mpc85xx p3060qds freescale - P3060QDS:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 P4080DS powerpc mpc85xx corenet_ds freescale P4080DS_SDCARD powerpc mpc85xx corenet_ds freescale - P4080DS:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 P4080DS_SECURE_BOOT powerpc mpc85xx corenet_ds freescale - P4080DS:SECURE_BOOT diff --git a/doc/README.p3060qds b/doc/README.p3060qds new file mode 100644 index 0000000..2ed49ca --- /dev/null +++ b/doc/README.p3060qds @@ -0,0 +1,111 @@ +Overview +========= +The P3060QDS is a Freescale reference board that hosts the six-core P3060 SOC. + +The P3060 Processor combines six e500mc Power Architecture processor +cores(1.2GHz) with high-performance datapath acceleration +architecture(DPAA), CoreNet fabric infrastructure, as well as network +and peripheral bus interfaces required for networking, telecom/datacom, +wireless infrastructure, and military/aerospace applications. + + +P3060QDS Board Specifications: +============================== +Memory subsystem: + * 2G Bytes UDIMM DDR3(64bit bus) with ECC on + * 128M Bytes NOR flash single-chip memory + * 16M Bytes SPI flash + * 8K Bytes AT24C64 I2C EEPROM for RCW + +Ethernet(Default SERDES 0x19): + * FM1-dTSEC1: connected to RGMII PHY1 (Vitesse VSC8641 on board,Bottom of dual RJ45) + * FM1-dTSEC2: connected to RGMII PHY2 (Vitesse VSC8641 on board,Top of dual RJ45) + * FM1-dTSEC3: connected to SGMII PHY (Vitesse VSC8234 port1 in slot1) + * FM1-dTSEC4: connected to SGMII PHY (Vitesse VSC8234 port3 in slot1) + * FM2-dTSEC1: connected to SGMII PHY (Vitesse VSC8234 port0 in slot2) + * FM2-dTSEC2: connected to SGMII PHY (Vitesse VSC8234 port2 in slot2) + * FM2-dTSEC3: connected to SGMII PHY (Vitesse VSC8234 port0 in slot1) + * FM2-dTSEC4: connected to SGMII PHY (Vitesse VSC8234 port2 in slot1) + +PCIe: + * PCIe1: Lanes A, B, C and D of Bank1 are connected to one x4 PCIe SLOT4 + * PCIe2: Lanes E, F, G and H of Bank1 are connected to one x4 PCIe SLOT3 + +RapidIO: + * sRIO1: Lanes E, F, G and H of Bank1 are connected to sRIO1 (SLOT3) + * sRIO2: Lanes A, B, C and D of Bank1 are connected to sRIO2 (SLOT4) + +USB: + * USB1: connected via an external ULPI PHY SMC3315 to a TYPE-A interface + * USB2: connected via an external ULPI PHY SMC3315 to a TYPE-AB interface + +I2C: + * I2C1_CH0: EEPROM AT24C64(0x50) RCW, AT24C02(0x51) DDR SPD, + AT24C02(0x53) DDR SPD, AT24C02(0x57) SystemID, RTC DS3232(0x68) + * I2C1_CH1: 1588 RiserCard(0x55), HSLB Testport, TempMon + ADT7461(0x4C), SerDesMux DS64MB201(0x51/59/5C/5D) + * I2C1_CH2: VDD/GVDD/GIDD ZL6100 (0x21/0x22/0x23/0x24/0x40) + * I2C1_CH3: OCM CFG AT24C02(0x55), OCM IPL AT24C64(0x56) + * I2C1_CH4: PCIe SLOT1 + * I2C1_CH5: PCIe SLOT2 + * I2C1_CH6: PCIe SLOT3 + * I2C1_CH7: PCIe SLOT4 + * I2C2: NULL + * I2C3: NULL + +UART: + * Supports two UARTs up to 115200 bps for console + + +Boot from NOR flash +=================== +1. Build image + export ARCH=powerpc + export CROSS_COMPILE=/your_path/gcc-4.5.xx-eglibc-2.11.xx/powerpc-linux-gnu/bin/powerpc-linux-gnu- + make P3060QDS_config + make + +2. Program image + => tftp 1000000 u-boot.bin + => protect off all + => erase eff80000 efffffff + => cp.b 1000000 eff80000 80000 + +3. Program RCW + => tftp 1000000 rcw.bin + => protect off all + => erase e8000000 e801ffff + => cp.b 1000000 e8000000 50 + +4. Program FMAN Firmware ucode + => tftp 1000000 ucode.bin + => protect off all + => erase ef000000 ef0fffff + => cp.b 1000000 ef000000 2000 + +5. Change DIP-switch + RCW Location: SW1[1-5] = 01101 (eLBC 16bit NOR flash) + Note: 1 stands for 'on', 0 stands for 'off' + + +Using the Device Tree Source File +================================= +To create the DTB (Device Tree Binary) image file, use a command +similar to this: + dtc -O dtb -b 0 -p 1024 p3060qds.dts > p3060qds.dtb + +Or use the following command: + {linux-2.6}/make p3060qds.dtb ARCH=powerpc + +then the dtb file will be generated under the following directory: + {linux-2.6}/arch/powerpc/boot/p3060qds.dtb + + +Booting Linux +============= +Place a linux uImage in the TFTP disk area. + tftp 1000000 uImage + tftp 2000000 rootfs.ext2.gz.uboot + tftp 3000000 p3060rdb.dtb + bootm 1000000 2000000 3000000 + diff --git a/include/configs/P3060QDS.h b/include/configs/P3060QDS.h new file mode 100644 index 0000000..bc89b4d --- /dev/null +++ b/include/configs/P3060QDS.h @@ -0,0 +1,39 @@ +/* + * Copyright 2011 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * P3060 QDS board configuration file + */ +#define CONFIG_P3060QDS +#define CONFIG_PHYS_64BIT +#define CONFIG_PPC_P3060 +#define CONFIG_FSL_QIXIS + +#define CONFIG_NAND_FSL_ELBC + +#define CONFIG_ICS307_REFCLK_HZ 25000000 /* ICS307 ref clk freq */ + +#define CONFIG_SPI_FLASH_ATMEL +#define CONFIG_SPI_FLASH_EON +#define CONFIG_SPI_FLASH_SST + +#include "corenet_ds.h" diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 4bbca88..e656f1d 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -168,7 +168,11 @@ #define CONFIG_DDR_SPD #define CONFIG_FSL_DDR3
+#ifdef CONFIG_P3060QDS +#define CONFIG_SYS_SPD_BUS_NUM 0 +#else #define CONFIG_SYS_SPD_BUS_NUM 1 +#endif #define SPD_EEPROM_ADDRESS1 0x51 #define SPD_EEPROM_ADDRESS2 0x52 #define SPD_EEPROM_ADDRESS SPD_EEPROM_ADDRESS1 /* for p3041/p5010 */
Dear Kumar Gala,
In message 1316067470-18992-1-git-send-email-galak@kernel.crashing.org you wrote:
Ethernet:
Checkpatch says:
WARNING: static const char * array should probably be static const char * const #1569: FILE: board/freescale/p3060qds/p3060qds.c:84: + static const char *freq[] = {"100", "125", "Reserved",
Please clean up and resubmit. Thanks.
Kumar Gala
