[PATCH v2 10/12] rockchip: rock-pi-n10: Enable PCI/NVME
Enable PCI/NVME for M.2 Slot on RockPI-4 boards.
=> nvme info Device 0: Vendor: 0x144d Rev: 4L1QCXB7 Prod: S35FNX0J623292 Type: Hard Disk Capacity: 122104.3 MB = 119.2 GB (250069680 x 512)
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v2: - none
configs/rock-pi-n10-rk3399pro_defconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/configs/rock-pi-n10-rk3399pro_defconfig b/configs/rock-pi-n10-rk3399pro_defconfig index 895820fbe6..2aa2fafaa4 100644 --- a/configs/rock-pi-n10-rk3399pro_defconfig +++ b/configs/rock-pi-n10-rk3399pro_defconfig @@ -21,6 +21,7 @@ CONFIG_TPL=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIME=y @@ -39,6 +40,8 @@ CONFIG_MMC_SDHCI_ROCKCHIP=y CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y +CONFIG_NVME=y +CONFIG_PCI=y CONFIG_PHY_ROCKCHIP_INNO_USB2=y CONFIG_PHY_ROCKCHIP_TYPEC=y CONFIG_PMIC_RK8XX=y
Add u-boot,spl-boot-order for ROCKPi N10, so-that it can able to boot from eMMC and SDMMC in order.
arch/arm/dts/rk3399pro-rock-pi-n10-u-boot.dtsi | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/arch/arm/dts/rk3399pro-rock-pi-n10-u-boot.dtsi b/arch/arm/dts/rk3399pro-rock-pi-n10-u-boot.dtsi index 946a0230db..7c66e1145a 100644 --- a/arch/arm/dts/rk3399pro-rock-pi-n10-u-boot.dtsi +++ b/arch/arm/dts/rk3399pro-rock-pi-n10-u-boot.dtsi @@ -5,3 +5,9 @@
#include "rk3399pro-u-boot.dtsi" #include "rk3399-sdram-lpddr3-4GB-1600.dtsi" + +/ { + chosen { + u-boot,spl-boot-order = "same-as-spl", &sdhci, &sdmmc; + }; +};
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
Changes for v2:
none
- chosen {
Disable ram rockchip debug driver for ROCKPi N8/N10 boards since we have verified ram in many instances with respective U-Boot versions.
configs/rock-pi-n10-rk3399pro_defconfig | 1 + configs/rock-pi-n8-rk3288_defconfig | 1 + 2 files changed, 2 insertions(+)
diff --git a/configs/rock-pi-n10-rk3399pro_defconfig b/configs/rock-pi-n10-rk3399pro_defconfig index 2aa2fafaa4..4a5bff44ef 100644 --- a/configs/rock-pi-n10-rk3399pro_defconfig +++ b/configs/rock-pi-n10-rk3399pro_defconfig @@ -48,6 +48,7 @@ CONFIG_PMIC_RK8XX=y CONFIG_REGULATOR_PWM=y CONFIG_REGULATOR_RK8XX=y CONFIG_PWM_ROCKCHIP=y +# CONFIG_RAM_ROCKCHIP_DEBUG is not set CONFIG_DM_RESET=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 diff --git a/configs/rock-pi-n8-rk3288_defconfig b/configs/rock-pi-n8-rk3288_defconfig index d218852d79..630ec6e491 100644 --- a/configs/rock-pi-n8-rk3288_defconfig +++ b/configs/rock-pi-n8-rk3288_defconfig @@ -64,6 +64,7 @@ CONFIG_REGULATOR_RK8XX=y CONFIG_PWM_ROCKCHIP=y CONFIG_RAM=y CONFIG_SPL_RAM=y +# CONFIG_RAM_ROCKCHIP_DEBUG is not set CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYSRESET=y CONFIG_USB=y
Thanks, - Kever
Changes for v2:
none
Thanks, - Kever
Changes for v2:
none
Jagan Teki
Kever Yang
