[U-Boot] [PULL] u-boot-usb/master
The following changes since commit f933e84e3497bddf29b8183ca6ee37a7a12e9ac3:
bootstage: arm: Add bootstage calls in board and bootm (2012-03-18 21:43:17 +0100)
git://git.denx.de/u-boot-usb.git master
for you to fetch changes up to dbb87bbd8eff11cf974caa2b5cc397aea444bc5a:
Armada100: gplugD: Add FAT & EXT2 command support (2012-03-19 00:08:26 +0100)
---------------------------------------------------------------- Ajay Bhargav (4): USB: Armada100: Add UTMI PHY interface driver USB: Armada100: EHCI Driver for Armada100 SOCs Armada100: gplugD: Add USB command support Armada100: gplugD: Add FAT & EXT2 command support
Amit Virdi (1): USB:gadget:designware Make locally used functions static
Mike Frysinger (3): usb: musb: fix printf warning usb: replace wait_ms() with mdelay() git-mailrc: change usb maintainer to Marek
Shiraz Hashim (1): USB:gadget:designware Fix memory nonalignment issue
Vipin KUMAR (3): USB:gadget:designware USB device controller (UDC) implementation USB:gadget:designware Device controller bugfixes USB:gadget:designware Support high speed
Łukasz Majewski (1): usb:udc:samsung:fix Remove the req_config flag
arch/arm/cpu/arm920t/s3c24x0/usb_ohci.c | 28 ++-- arch/arm/cpu/pxa/usb.c | 2 +- arch/arm/include/asm/arch-armada100/armada100.h | 9 ++ .../include/asm/arch-armada100/utmi-armada100.h | 79 +++++++++++ arch/mips/cpu/mips32/au1x00/au1x00_usb_ohci.c | 28 ++-- arch/powerpc/cpu/mpc5xxx/usb_ohci.c | 6 +- arch/powerpc/cpu/ppc4xx/usb_ohci.c | 6 +- arch/sparc/cpu/leon3/usb_uhci.c | 8 +- board/efikamx/efikamx-usb.c | 2 +- board/mcc200/auto_update.c | 4 +- board/mpl/common/usb_uhci.c | 8 +- board/renesas/sh7785lcr/selfcheck.c | 10 +- common/usb.c | 16 +-- common/usb_hub.c | 10 +- common/usb_storage.c | 16 +- doc/git-mailrc | 2 +- drivers/serial/usbtty.h | 4 +- drivers/usb/gadget/Makefile | 2 +- drivers/usb/gadget/{spr_udc.c => designware_udc.c} | 138 ++++++++++++------- drivers/usb/gadget/s3c_udc_otg_xfer_dma.c | 18 +-- drivers/usb/host/Makefile | 1 + drivers/usb/host/ehci-armada100.c | 64 +++++++++ drivers/usb/host/ehci-hcd.c | 4 +- drivers/usb/host/isp116x-hcd.c | 12 +- drivers/usb/host/ohci-hcd.c | 28 ++-- drivers/usb/host/r8a66597-hcd.c | 14 +- drivers/usb/host/utmi-armada100.c | 96 ++++++++++++++ drivers/usb/musb/musb_hcd.c | 2 +- include/configs/gplugd.h | 14 ++ include/configs/spear-common.h | 4 +- include/usb.h | 1 - include/usb/{spr_udc.h => designware_udc.h} | 7 +- include/usb/s3c_udc.h | 2 +- 33 files changed, 461 insertions(+), 184 deletions(-) create mode 100644 arch/arm/include/asm/arch-armada100/utmi-armada100.h rename drivers/usb/gadget/{spr_udc.c => designware_udc.c} (89%) create mode 100644 drivers/usb/host/ehci-armada100.c create mode 100644 drivers/usb/host/utmi-armada100.c rename include/usb/{spr_udc.h => designware_udc.h} (98%)
Dear Marek Vasut,
bootstage: arm: Add bootstage calls in board and bootm (2012-03-18 21:43:> 17 +0100)
Armada100: gplugD: Add FAT & EXT2 command support (2012-03-19 00:08:26 +0> 100)
arch/arm/cpu/arm920t/s3c24x0/usb_ohci.c | 28 ++-- arch/arm/cpu/pxa/usb.c | 2 +- arch/arm/include/asm/arch-armada100/armada100.h | 9 ++ .../include/asm/arch-armada100/utmi-armada100.h | 79 +++++++++++ arch/mips/cpu/mips32/au1x00/au1x00_usb_ohci.c | 28 ++-- arch/powerpc/cpu/mpc5xxx/usb_ohci.c | 6 +- arch/powerpc/cpu/ppc4xx/usb_ohci.c | 6 +- arch/sparc/cpu/leon3/usb_uhci.c | 8 +- board/efikamx/efikamx-usb.c | 2 +- board/mcc200/auto_update.c | 4 +- board/mpl/common/usb_uhci.c | 8 +- board/renesas/sh7785lcr/selfcheck.c | 10 +- common/usb.c | 16 +-- common/usb_hub.c | 10 +- common/usb_storage.c | 16 +- doc/git-mailrc | 2 +- drivers/serial/usbtty.h | 4 +- drivers/usb/gadget/Makefile | 2 +- drivers/usb/gadget/{spr_udc.c => designware_udc.c} | 138 ++++++++++++--> ----- drivers/usb/gadget/s3c_udc_otg_xfer_dma.c | 18 +-- drivers/usb/host/Makefile | 1 + drivers/usb/host/ehci-armada100.c | 64 +++++++++ drivers/usb/host/ehci-hcd.c | 4 +- drivers/usb/host/isp116x-hcd.c | 12 +- drivers/usb/host/ohci-hcd.c | 28 ++-- drivers/usb/host/r8a66597-hcd.c | 14 +- drivers/usb/host/utmi-armada100.c | 96 ++++++++++++++ drivers/usb/musb/musb_hcd.c | 2 +- include/configs/gplugd.h | 14 ++ include/configs/spear-common.h | 4 +- include/usb.h | 1 - include/usb/{spr_udc.h => designware_udc.h} | 7 +- include/usb/s3c_udc.h | 2 +- 33 files changed, 461 insertions(+), 184 deletions(-) create mode 100644 arch/arm/include/asm/arch-armada100/utmi-armada100.h rename drivers/usb/gadget/{spr_udc.c => designware_udc.c} (89%) create mode 100644 drivers/usb/host/ehci-armada100.c create mode 100644 drivers/usb/host/utmi-armada100.c rename include/usb/{spr_udc.h => designware_udc.h} (98%)
Applied, thanks.
