[U-Boot-Users] [GIT PULL] 85xx updates
The following changes since commit 9045f33c023f698660a2e45d1b2194c0711abebc: Wolfgang Denk (1): Fix config problems on SC3 board; make ide_reset_timeout work.
are found in the git repository at:
git://www.denx.de/git/u-boot-mpc85xx.git
Andy Fleming (6): Fix Marvell 88e1145 PHY init code Add support for CPM device tree configuration to 8560 ADS tsec: Fix PHY code to match first driver Polished the 85xx ADS config files From: eran liberty eran.liberty@gmail.com Remove erroneous errata code from Marvel 88E1111S driver
Ed Swarthout (1): 8544ds: Fix Makefile after moving pixis to board/freescale.
board/freescale/mpc8544ds/Makefile | 6 ++-- board/mpc8560ads/mpc8560ads.c | 26 +++++++++++++++++++++++++ drivers/tsec.c | 15 ++++++------- include/asm-ppc/immap_85xx.h | 4 ++- include/configs/MPC8540ADS.h | 4 +- include/configs/MPC8560ADS.h | 37 +++++++++++++++++++++++------------ 6 files changed, 65 insertions(+), 27 deletions(-) commit 92696b49ed48a99ed975d58ef02ff22ab16215ee Author: Andy Fleming afleming@freescale.com Date: Fri Jun 8 16:41:18 2007 -0500
The Marvel 88E1111S driver for the TSEC was copied from the 88E1101 driver, and included a fix for an erratum which does not exist on that part. Now it is removed
Signed-off-by: Andy Fleming afleming@freescale.com
diff --git a/drivers/tsec.c b/drivers/tsec.c index 31a0aba..3032a39 100644 --- a/drivers/tsec.c +++ b/drivers/tsec.c @@ -968,11 +968,6 @@ struct phy_info phy_info_M88E1111S = { (struct phy_cmd[]){ /* config */ /* Reset and configure the PHY */ {MIIM_CONTROL, MIIM_CONTROL_RESET, NULL}, - {0x1d, 0x1f, NULL}, - {0x1e, 0x200c, NULL}, - {0x1d, 0x5, NULL}, - {0x1e, 0x0, NULL}, - {0x1e, 0x100, NULL}, {0x14, 0x0cd2, NULL}, /* Delay RGMII TX and RX */ {MIIM_GBIT_CONTROL, MIIM_GBIT_CONTROL_INIT, NULL}, {MIIM_ANAR, MIIM_ANAR_INIT, NULL},
commit 279095536580ab11b1dda45af93c648ce5f938a0 Author: Andy Fleming afleming@freescale.com Date: Tue Jun 5 16:38:44 2007 -0500
adds the reset register to 85xx immap
Signed-off-by: Eran Liberty eran.liberty@gmail.com Signed-off-by: Andy Fleming afleming@freescale.com
diff --git a/include/asm-ppc/immap_85xx.h b/include/asm-ppc/immap_85xx.h index 5377c2e..e002d28 100644 --- a/include/asm-ppc/immap_85xx.h +++ b/include/asm-ppc/immap_85xx.h @@ -1548,7 +1548,9 @@ typedef struct ccsr_gur { char res9[12]; uint pvr; /* 0xe00a0 - Processor version register */ uint svr; /* 0xe00a4 - System version register */ - char res10[3416]; + char res10a[8]; + uint rstcr; /* 0xe00b0 - Reset control register */ + char res10b[3404]; uint clkocr; /* 0xe0e00 - Clock out select register */ char res11[12]; uint ddrdllcr; /* 0xe0e10 - DDR DLL control register */
commit 4404fbec2ea482b60a4f32f9ca4050d1b9d1ba7d Author: Andy Fleming afleming@freescale.com Date: Thu May 10 17:50:01 2007 -0500
Made the boot commands use device trees by default. Also moved the ramdisk to 1000000 (I think the previous address was getting overridden during boot).
diff --git a/include/configs/MPC8540ADS.h b/include/configs/MPC8540ADS.h index 5aeea58..3d5588a 100644 --- a/include/configs/MPC8540ADS.h +++ b/include/configs/MPC8540ADS.h @@ -520,7 +520,7 @@ #define CONFIG_EXTRA_ENV_SETTINGS \ "netdev=eth0\0" \ "consoledev=ttyS0\0" \ - "ramdiskaddr=600000\0" \ + "ramdiskaddr=1000000\0" \ "ramdiskfile=your.ramdisk.u-boot\0" \ "fdtaddr=400000\0" \ "fdtfile=your.fdt.dtb\0" @@ -540,7 +540,7 @@ "tftp $ramdiskaddr $ramdiskfile;" \ "tftp $loadaddr $bootfile;" \ "tftp $fdtaddr $fdtfile;" \ - "bootm $loadaddr $ramdiskaddr" + "bootm $loadaddr $ramdiskaddr $fdtaddr"
#define CONFIG_BOOTCOMMAND CONFIG_NFSBOOTCOMMAND
diff --git a/include/configs/MPC8560ADS.h b/include/configs/MPC8560ADS.h index f16e39d..010736f 100644 --- a/include/configs/MPC8560ADS.h +++ b/include/configs/MPC8560ADS.h @@ -560,8 +560,8 @@
#define CONFIG_EXTRA_ENV_SETTINGS \ "netdev=eth0\0" \ - "consoledev=ttyS0\0" \ - "ramdiskaddr=600000\0" \ + "consoledev=ttyCPM\0" \ + "ramdiskaddr=1000000\0" \ "ramdiskfile=your.ramdisk.u-boot\0" \ "fdtaddr=400000\0" \ "fdtfile=mpc8560ads.dtb\0" @@ -580,7 +580,8 @@ "console=$consoledev,$baudrate $othbootargs;" \ "tftp $ramdiskaddr $ramdiskfile;" \ "tftp $loadaddr $bootfile;" \ - "bootm $loadaddr $ramdiskaddr" + "tftp $fdtaddr $fdtfile;" \ + "bootm $loadaddr $ramdiskaddr $fdtaddr"
commit 213efb8403284372f5e3806fac222b7aa0a4996c Author: Ed Swarthout Ed.Swarthout@freescale.com Date: Wed May 9 11:03:32 2007 -0500
The OBJTREE != SRCTREE build scenario was broken. This fixes it.
Signed-off-by: Ed Swarthout Ed.Swarthout@freescale.com Signed-off-by: Jon Loeliger jdl@freescale.com
diff --git a/board/freescale/mpc8544ds/Makefile b/board/freescale/mpc8544ds/Makefile index bec2168..308f707 100644 --- a/board/freescale/mpc8544ds/Makefile +++ b/board/freescale/mpc8544ds/Makefile @@ -24,9 +24,9 @@
include $(TOPDIR)/config.mk
-# ifneq ($(OBJTREE),$(SRCTREE)) -# $(shell mkdir -p $(obj)./common) -# endif +ifneq ($(OBJTREE),$(SRCTREE)) +$(shell mkdir -p $(obj)../common) +endif
LIB = $(obj)lib$(BOARD).a
commit ffe8c7488c9d0cdfcc52b83aa1bb655768fc9783 Author: Andy Fleming afleming@freescale.com Date: Wed May 9 00:54:20 2007 -0500
Jarrold Wen noticed that the generic PHY code always matches under the current implementation. Change it so the first match wins, and *only* unknown PHYs trigger the generic driver
diff --git a/drivers/tsec.c b/drivers/tsec.c index 693328d..31a0aba 100644 --- a/drivers/tsec.c +++ b/drivers/tsec.c @@ -1327,8 +1327,10 @@ struct phy_info *get_phy_info(struct eth_device *dev) /* loop through all the known PHY types, and find one that */ /* matches the ID we read from the PHY. */ for (i = 0; phy_info[i]; i++) { - if (phy_info[i]->id == (phy_ID >> phy_info[i]->shift)) + if (phy_info[i]->id == (phy_ID >> phy_info[i]->shift)) { theInfo = phy_info[i]; + break; + } }
if (theInfo == NULL) {
commit 2bd7d99282b788b2139213217c0982f11c542e62 Author: Andy Fleming afleming@freescale.com Date: Tue May 8 17:27:43 2007 -0500
* Adds code to modify CPM frequencies * Cleans up the config file to #define TSEC and (for now) #undef FCC * Adds the MII command for all 8560 ADS configurations * Updates config file to provide convenience commands for booting with a device tree
Signed-off-by: Vitaly Bordug vbordug@ru.mvista.com Signed-off-by: Andy Fleming afleming@freescale.com
diff --git a/board/mpc8560ads/mpc8560ads.c b/board/mpc8560ads/mpc8560ads.c index d19bad6..41acb97 100644 --- a/board/mpc8560ads/mpc8560ads.c +++ b/board/mpc8560ads/mpc8560ads.c @@ -550,8 +550,34 @@ pci_init_board(void)
#if defined(CONFIG_OF_FLAT_TREE) && defined(CONFIG_OF_BOARD_SETUP) void +ft_soc_setup(void *blob, bd_t *bd) +{ + u32 *p; + int len; + ulong data; + + p = ft_get_prop(blob, "/" OF_SOC "/cpm@e0000000/brg-frequency", &len); + + if (p != NULL) + *p = cpu_to_be32(bd->bi_brgfreq); + + p = ft_get_prop(blob, + "/" OF_SOC "/cpm@e0000000/scc@91a00/current-speed", + &len); + if (p != NULL) + *p = cpu_to_be32(bd->bi_baudrate); + + p = ft_get_prop(blob, + "/" OF_SOC "/cpm@e0000000/scc@91a20/current-speed", + &len); + if (p != NULL) + *p = cpu_to_be32(bd->bi_baudrate); +} + +void ft_board_setup(void *blob, bd_t *bd) { ft_cpu_setup(blob, bd); + ft_soc_setup(blob, bd); } #endif diff --git a/include/configs/MPC8560ADS.h b/include/configs/MPC8560ADS.h index 21e6637..f16e39d 100644 --- a/include/configs/MPC8560ADS.h +++ b/include/configs/MPC8560ADS.h @@ -43,9 +43,7 @@
#define CONFIG_PCI #define CONFIG_TSEC_ENET /* tsec ethernet support */ -#undef CONFIG_TSEC_ENET /* tsec ethernet support */ -#undef CONFIG_ETHER_ON_FCC /* cpm FCC ethernet support */ -#define CONFIG_ETHER_ON_FCC /* cpm FCC ethernet support */ +#undef CONFIG_ETHER_ON_FCC /* cpm FCC ethernet support */ #define CONFIG_ENV_OVERWRITE #define CONFIG_SPD_EEPROM /* Use SPD EEPROM for DDR setup*/ #define CONFIG_DDR_DLL /* possible DLL fix needed */ @@ -349,13 +347,16 @@ #endif /* CONFIG_PCI */
-#if defined(CONFIG_TSEC_ENET) +#ifdef CONFIG_TSEC_ENET
#ifndef CONFIG_NET_MULTI #define CONFIG_NET_MULTI 1 #endif
+#ifndef CONFIG_MII #define CONFIG_MII 1 /* MII PHY management */ +#endif + #define CONFIG_MPC85XX_TSEC1 1 #define CONFIG_MPC85XX_TSEC1_NAME "TSEC0" #define CONFIG_MPC85XX_TSEC2 1 @@ -369,9 +370,10 @@ /* Options are: TSEC[0-1] */ #define CONFIG_ETHPRIME "TSEC0"
-#elif defined(CONFIG_ETHER_ON_FCC) /* CPM FCC Ethernet */ +#endif /* CONFIG_TSEC_ENET */ + +#ifdef CONFIG_ETHER_ON_FCC /* CPM FCC Ethernet */
-#define CONFIG_ETHER_ON_FCC /* define if ether on FCC */ #undef CONFIG_ETHER_NONE /* define if ether on something else */ #define CONFIG_ETHER_INDEX 2 /* which channel for ether */
@@ -392,7 +394,10 @@ #define FETH3_RST 0x80 #endif /* CONFIG_ETHER_INDEX */
-#define CONFIG_MII /* MII PHY management */ +#ifndef CONFIG_MII +#define CONFIG_MII 1 /* MII PHY management */ +#endif + #define CONFIG_BITBANGMII /* bit-bang MII PHY management */
/* @@ -458,11 +463,13 @@ #define CONFIG_COMMANDS (CONFIG_CMD_DFL \ | CFG_CMD_PCI \ | CFG_CMD_PING \ + | CFG_CMD_MII \ | CFG_CMD_I2C) #elif defined(CONFIG_TSEC_ENET) #define CONFIG_COMMANDS (CONFIG_CMD_DFL \ | CFG_CMD_PING \ - | CFG_CMD_I2C) + | CFG_CMD_I2C \ + | CFG_CMD_MII) #elif defined(CONFIG_ETHER_ON_FCC) #define CONFIG_COMMANDS (CONFIG_CMD_DFL \ | CFG_CMD_MII \ @@ -554,8 +561,10 @@ #define CONFIG_EXTRA_ENV_SETTINGS \ "netdev=eth0\0" \ "consoledev=ttyS0\0" \ - "ramdiskaddr=400000\0" \ - "ramdiskfile=your.ramdisk.u-boot\0" + "ramdiskaddr=600000\0" \ + "ramdiskfile=your.ramdisk.u-boot\0" \ + "fdtaddr=400000\0" \ + "fdtfile=mpc8560ads.dtb\0"
#define CONFIG_NFSBOOTCOMMAND \ "setenv bootargs root=/dev/nfs rw " \ @@ -563,7 +572,8 @@ "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off " \ "console=$consoledev,$baudrate $othbootargs;" \ "tftp $loadaddr $bootfile;" \ - "bootm $loadaddr" + "tftp $fdtaddr $fdtfile;" \ + "bootm $loadaddr - $fdtaddr"
#define CONFIG_RAMBOOTCOMMAND \ "setenv bootargs root=/dev/ram rw " \
commit 56269ccebff1c9db64e28e084e887fc083bf70e6 Author: Andy Fleming afleming@freescale.com Date: Tue May 8 17:23:02 2007 -0500
Fix a bug in the Marvell 88e1145 PHY init code in the TSEC driver where the reset was being done after the errata code instead of before.
Signed-off-by: Haiying Wang haiying.wang@freescale.com Signed-off-by: Andy Fleming afleming@freescale.com
diff --git a/drivers/tsec.c b/drivers/tsec.c index b418773..693328d 100644 --- a/drivers/tsec.c +++ b/drivers/tsec.c @@ -1012,14 +1012,16 @@ static struct phy_info phy_info_M88E1145 = { "Marvell 88E1145", 4, (struct phy_cmd[]){ /* config */ + /* Reset the PHY */ + {MIIM_CONTROL, MIIM_CONTROL_RESET, NULL}, + /* Errata E0, E1 */ {29, 0x001b, NULL}, {30, 0x418f, NULL}, {29, 0x0016, NULL}, {30, 0xa2da, NULL},
- /* Reset and configure the PHY */ - {MIIM_CONTROL, MIIM_CONTROL_RESET, NULL}, + /* Configure the PHY */ {MIIM_GBIT_CONTROL, MIIM_GBIT_CONTROL_INIT, NULL}, {MIIM_ANAR, MIIM_ANAR_INIT, NULL}, {MIIM_88E1011_PHY_SCR, MIIM_88E1011_PHY_MDI_X_AUTO,
Andy Fleming
