[U-Boot] [PATCH] configs: sunxi: fix device tree name for Pine64+
Fix the device tree name for the Pine64+ for the naming that's going into the upstream kernel.
Signed-off-by: Peter Robinson pbrobinson@gmail.com --- configs/pine64_plus_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/pine64_plus_defconfig b/configs/pine64_plus_defconfig index 0494a9f..0977334 100644 --- a/configs/pine64_plus_defconfig +++ b/configs/pine64_plus_defconfig @@ -4,7 +4,7 @@ CONFIG_MACH_SUN50I=y CONFIG_DRAM_CLK=672 CONFIG_DRAM_ZQ=3881915 # CONFIG_VIDEO is not set -CONFIG_DEFAULT_DEVICE_TREE="pine64_plus" +CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-pine64-plus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set
Hi Peter,
While this is a proper observation, it will not help just to fix the name, as U-Boot's build process will look for matching files in the U-Boot tree as well. And the DT is obsolete as well.
I have patches ready to fix this properly and will send them later today.
Cheers, Andre.
Andre Przywara
Peter Robinson
