[U-Boot] [PATCH v6 7/8] board: intel: Add new slimbootloader board
Add slimbootloader board to run U-boot as a Slim Bootloader payload - Add new board/intel/slimbootloader directory with minimum codes - Add slimbootloader configuration files - Add doc/board/intel/slimbootloader.rst
Signed-off-by: Aiden Park aiden.park@intel.com Reviewed-by: Bin Meng bmeng.cn@gmail.com ---
Changes in v6: * Select CONFIG_SYS_SLIMBOOTLOADER in board Kconfig * Move USB_STORAGE and USB_KEYBOARD to board Kconfig * Convert README to reST doc/board/intel/slimbootloader.rst
Changes in v5: * Remove X86_LOAD_FROM_32_BIT from slimbootloader_defconfig
Changes in v3: * Remove VENDOR_SLIMBOOTLOADER * Use VENDOR_INTEL * Move slimbootloader under board/intel/ * Enable generic CONFIGs in slimbootloader_defconfig * Add more description in board/intel/slimbootloader/README
board/intel/Kconfig | 14 ++ board/intel/slimbootloader/Kconfig | 28 ++++ board/intel/slimbootloader/Makefile | 5 + board/intel/slimbootloader/slimbootloader.c | 21 +++ board/intel/slimbootloader/start.S | 9 ++ configs/slimbootloader_defconfig | 22 +++ doc/board/intel/slimbootloader.rst | 166 ++++++++++++++++++++ include/configs/slimbootloader.h | 62 ++++++++ 8 files changed, 327 insertions(+) create mode 100644 board/intel/slimbootloader/Kconfig create mode 100644 board/intel/slimbootloader/Makefile create mode 100644 board/intel/slimbootloader/slimbootloader.c create mode 100644 board/intel/slimbootloader/start.S create mode 100644 configs/slimbootloader_defconfig create mode 100644 doc/board/intel/slimbootloader.rst create mode 100644 include/configs/slimbootloader.h
diff --git a/board/intel/Kconfig b/board/intel/Kconfig index 5131836cb0..10859b5f08 100644 --- a/board/intel/Kconfig +++ b/board/intel/Kconfig @@ -73,6 +73,19 @@ config TARGET_MINNOWMAX Note that PCIE_ECAM_BASE is set up by the FSP so the value used by U-Boot matches that value.
+config TARGET_SLIMBOOTLOADER + bool "slimbootloader" + help + This target is used for running U-Boot on top of Slim Bootloader + boot firmware as a payload. Slim Bootloader does memory initialization + and silicon initialization, and it passes necessary information in + HOB(Hand Off Block) to a payload. The payload consumes HOB data + which is generated by Slim Bootloader for its driver initialization. + Slim Bootloader consumes FSP and its HOB, but FSP HOB is cleared + Before launching a payload. Instead, Slim Bootloader generates its + HOB data such as memory info, serial port info and so on. + Refer to doc/board/intel/slimbootloader.rst for the details. + endchoice
source "board/intel/bayleybay/Kconfig" @@ -82,5 +95,6 @@ source "board/intel/crownbay/Kconfig" source "board/intel/edison/Kconfig" source "board/intel/galileo/Kconfig" source "board/intel/minnowmax/Kconfig" +source "board/intel/slimbootloader/Kconfig"
endif diff --git a/board/intel/slimbootloader/Kconfig b/board/intel/slimbootloader/Kconfig new file mode 100644 index 0000000000..8c7e22cc33 --- /dev/null +++ b/board/intel/slimbootloader/Kconfig @@ -0,0 +1,28 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2019 Intel Corporation <www.intel.com> + +if TARGET_SLIMBOOTLOADER + +config SYS_BOARD + default "slimbootloader" + +config SYS_VENDOR + default "intel" + +config SYS_SOC + default "slimbootloader" + +config SYS_CONFIG_NAME + default "slimbootloader" + +config SYS_TEXT_BASE + default 0x00100000 + +config BOARD_SPECIFIC_OPTIONS + def_bool y + select SYS_SLIMBOOTLOADER + select USB_STORAGE + select USB_KEYBOARD + +endif diff --git a/board/intel/slimbootloader/Makefile b/board/intel/slimbootloader/Makefile new file mode 100644 index 0000000000..fd8fa98a8d --- /dev/null +++ b/board/intel/slimbootloader/Makefile @@ -0,0 +1,5 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2019 Intel Corporation <www.intel.com> + +obj-y += start.o slimbootloader.o diff --git a/board/intel/slimbootloader/slimbootloader.c b/board/intel/slimbootloader/slimbootloader.c new file mode 100644 index 0000000000..f50eeb823f --- /dev/null +++ b/board/intel/slimbootloader/slimbootloader.c @@ -0,0 +1,21 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Intel Corporation <www.intel.com> + */ + +#include <common.h> + +int board_early_init_r(void) +{ + /* + * Make sure PCI bus is enumerated so that peripherals on the PCI bus + * can be discovered by their drivers. + * + * Slim Bootloader has already done PCI bus enumeration before loading + * U-Boot, so U-Boot needs to preserve PCI configuration. + * Therefore, '# CONFIG_PCI_PNP is not set' is included in defconfig. + */ + pci_init(); + + return 0; +} diff --git a/board/intel/slimbootloader/start.S b/board/intel/slimbootloader/start.S new file mode 100644 index 0000000000..5c3f3df09e --- /dev/null +++ b/board/intel/slimbootloader/start.S @@ -0,0 +1,9 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2019 Intel Corporation <www.intel.com> + */ + +/* board early initialization */ +.globl early_board_init +early_board_init: + jmp early_board_init_ret diff --git a/configs/slimbootloader_defconfig b/configs/slimbootloader_defconfig new file mode 100644 index 0000000000..b16ed71469 --- /dev/null +++ b/configs/slimbootloader_defconfig @@ -0,0 +1,22 @@ +CONFIG_X86=y +CONFIG_VENDOR_INTEL=y +CONFIG_TARGET_SLIMBOOTLOADER=y +CONFIG_DEFAULT_DEVICE_TREE="slimbootloader" +CONFIG_REGMAP=y +CONFIG_SYSCON=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_LAST_STAGE_INIT=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y +CONFIG_CMD_USB=y +CONFIG_DOS_PARTITION=y +CONFIG_EFI_PARTITION=y +CONFIG_OF_CONTROL=y +CONFIG_BOOTSTAGE=y +CONFIG_BOOTSTAGE_REPORT=y +CONFIG_BOOTDELAY=10 +CONFIG_CONSOLE_SCROLL_LINES=5 +# CONFIG_PCI_PNP is not set diff --git a/doc/board/intel/slimbootloader.rst b/doc/board/intel/slimbootloader.rst new file mode 100644 index 0000000000..a9048473c3 --- /dev/null +++ b/doc/board/intel/slimbootloader.rst @@ -0,0 +1,166 @@ +.. SPDX-License-Identifier: GPL-2.0+ +.. sectionauthor:: Aiden Park aiden.park@intel.com + +U-Boot as a Slim Bootloader payload +=================================== + +Introduction +------------ + +This target is to enable U-Boot_ as a payload of `Slim Bootloader`_ (a.k.a SBL) +boot firmware which currently supports QEMU, Apollolake, Whiskeylake, +Coffeelake-R platforms. + +The `Slim Bootloader`_ is designed with multi-stages(Stage1A/B, Stage2, Payload) +architecture to cover from reset vector to OS booting and it consumes +`Intel FSP`_ for silicon initialization. + +* Stage1A: Reset vector, CAR init with FSP-T +* Stage1B: Memory init with FSP-M, CAR teardown, Continue execution in memory +* Stage2 : Rest of Silicon init with FSP-S, Create HOB, Hand-off to Payload +* Payload: Payload init with HOB, Load OS from media, Booting OS + +Build Instruction for U-Boot as a Slim Bootloader payload +--------------------------------------------------------- + +Build U-Boot and obtain u-boot-dtb.bin:: + + $ make distclean + $ make slimbootloader_defconfig + $ make all + +Prepare Slim Bootloader +----------------------- + +1. Setup Build Environment for Slim Bootloader. + + Refer to `Getting Started`_ page in `Slim Bootloader`_ document site. + +2. Get source code. Let's simply clone the repo:: + + $ git clone https://github.com/slimbootloader/slimbootloader.git + +3. Copy u-boot-dtb.bin to Slim Bootloader. + Slim Bootloader looks for a payload from the specific location. + Copy the build u-boot-dtb.bin to the expected location:: + + $ mkdir -p <Slim Bootloader Dir>/PayloadPkg/PayloadBins/ + $ cp <U-Boot Dir>/u-boot-dtb.bin <Slim Bootloader Dir>/PayloadPkg/PayloadBins/u-boot-dtb.bin + +Build Instruction for Slim Bootloader for QEMU target +----------------------------------------------------- + +Slim Bootloader supports multiple payloads, and a board of Slim Bootloader +detects its target payload by PayloadId in board configuration. +The PayloadId can be any 4 Bytes value. + +1. Update PayloadId. Let's use 'U-BT' as an example:: + + $ vi Platform/QemuBoardPkg/CfgData/CfgDataExt_Brd1.dlt + -GEN_CFG_DATA.PayloadId | 'AUTO' + +GEN_CFG_DATA.PayloadId | 'U-BT' + +2. Update payload text base. PAYLOAD_EXE_BASE must be the same as U-Boot + CONFIG_SYS_TEXT_BASE in board/intel/slimbootloader/Kconfig. + PAYLOAD_LOAD_HIGH must be 0:: + + $ vi Platform/QemuBoardPkg/BoardConfig.py + + self.PAYLOAD_LOAD_HIGH = 0 + + self.PAYLOAD_EXE_BASE = 0x00100000 + +3. Build QEMU target. Make sure u-boot-dtb.bin and U-BT PayloadId + in build command. The output is Outputs/qemu/SlimBootloader.bin:: + + $ python BuildLoader.py build qemu -p "OsLoader.efi:LLDR:Lz4;u-boot-dtb.bin:U-BT:Lzma" + +4. Launch Slim Bootloader on QEMU. + You should reach at U-Boot serial console:: + + $ qemu-system-x86_64 -machine q35 -nographic -serial mon:stdio -pflash Outputs/qemu/SlimBootloader.bin + +Build Instruction for Slim Bootloader for LeafHill(APL) target +-------------------------------------------------------------- + +LeafHill is using PCI UART2 device as a serial port. +For MEM32 serial port, CONFIG_SYS_NS16550_MEM32 needs to be enabled in U-Boot. + +1. Enable CONFIG_SYS_NS16550_MEM32 in U-Boot:: + + $ vi include/configs/slimbootloader.h + +#define CONFIG_SYS_NS16550_MEM32 + #ifdef CONFIG_SYS_NS16550_MEM3 + +2. Build U-Boot:: + + $ make disclean + $ make slimbootloader_defconfig + $ make all + +3. Copy u-boot-dtb.bin to Slim Bootloader. + Slim Bootloader looks for a payload from the specific location. + Copy the build u-boot-dtb.bin to the expected location:: + + $ mkdir -p <Slim Bootloader Dir>/PayloadPkg/PayloadBins/ + $ cp <U-Boot Dir>/u-boot-dtb.bin <Slim Bootloader Dir>/PayloadPkg/PayloadBins/u-boot-dtb.bin + +4. Update PayloadId. Let's use 'U-BT' as an example:: + + $ vi Platform/ApollolakeBoardPkg/CfgData/CfgData_Int_LeafHill.dlt + -GEN_CFG_DATA.PayloadId | 'AUTO + +GEN_CFG_DATA.PayloadId | 'U-BT' + +5. Update payload text base. + +* PAYLOAD_EXE_BASE must be the same as U-Boot CONFIG_SYS_TEXT_BASE + in board/intel/slimbootloader/Kconfig. +* PAYLOAD_LOAD_HIGH must be 0:: + + $ vi Platform/ApollolakeBoardPkg/BoardConfig.py + + self.PAYLOAD_LOAD_HIGH = 0 + + self.PAYLOAD_EXE_BASE = 0x00100000 + +6. Build APL target. Make sure u-boot-dtb.bin and U-BT PayloadId + in build command. The output is Outputs/apl/Stitch_Components.zip:: + + $ python BuildLoader.py build apl -p "OsLoader.efi:LLDR:Lz4;u-boot-dtb.bin:U-BT:Lzma" + +7. Stitch IFWI. + + Refer to Apollolake_ page in Slim Bootloader document site:: + + $ python Platform/ApollolakeBoardPkg/Script/StitchLoader.py -i <Existing IFWI> -s Outputs/apl/Stitch_Components.zip -o <Output IFWI> + +8. Flash IFWI. + + Use DediProg to flash IFWI. You should reach at U-Boot serial console. + + +Build Instruction to use ELF U-Boot +----------------------------------- + +1. Enable CONFIG_OF_EMBED:: + + $ vi configs/slimbootloader_defconfig + +CONFIG_OF_EMBED=y + +2. Build U-Boot:: + + $ make disclean + $ make slimbootloader_defconfig + $ make all + $ strip u-boot (removing symbol for reduced size) + +3. Do same steps as above + +* Copy u-boot(ELF) to PayloadBins directory +* Update PayloadId 'U-BT' as above. +* No need to set PAYLOAD_LOAD_HIGH and PAYLOAD_EXE_BASE. +* Build Slim Bootloader. Use u-boot instead of u-boot-dtb.bin:: + + $ python BuildLoader.py build <qemu or apl> -p "OsLoader.efi:LLDR:Lz4;u-boot:U-BT:Lzma" + +.. _U-Boot: https://gitlab.denx.de/ +.. _`Slim Bootloader`: https://github.com/slimbootloader/ +.. _`Intel FSP`: https://github.com/IntelFsp/ +.. _`Getting Started`: https://slimbootloader.github.io/getting-started/ +.. _Apollolake: https://slimbootloader.github.io/supported-hardware/apollo-lake-crb.html#sti... diff --git a/include/configs/slimbootloader.h b/include/configs/slimbootloader.h new file mode 100644 index 0000000000..e0011ed446 --- /dev/null +++ b/include/configs/slimbootloader.h @@ -0,0 +1,62 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2019 Intel Corporation <www.intel.com> + */ + +#ifndef __SLIMBOOTLOADER_CONFIG_H__ +#define __SLIMBOOTLOADER_CONFIG_H__ + +#include <configs/x86-common.h> + +/* + * By default, CONFIG_SYS_NS16550_PORT_MAPPED is enabled for port io serial. + * To use mmio base serial, enable CONFIG_SYS_NS16550_MEM32 and disable + * CONFIG_SYS_NS16550_PORT_MAPPED until ns16550 driver supports serial port + * configuration in run-time. + * + * #define CONFIG_SYS_NS16550_MEM32 + * #undef CONFIG_SYS_NS16550_PORT_MAPPED + */ +#ifdef CONFIG_SYS_NS16550_MEM32 +#undef CONFIG_SYS_NS16550_PORT_MAPPED +#endif + +#define CONFIG_STD_DEVICES_SETTINGS \ + "stdin=serial,i8042-kbd,usbkbd\0" \ + "stdout=serial\0" \ + "stderr=serial\0" + +/* + * Override CONFIG_EXTRA_ENV_SETTINGS in x86-common.h + */ +#undef CONFIG_EXTRA_ENV_SETTINGS +#define CONFIG_EXTRA_ENV_SETTINGS \ + CONFIG_STD_DEVICES_SETTINGS \ + "netdev=eth0\0" \ + "consoledev=ttyS0\0" \ + "ramdiskaddr=0x4000000\0" \ + "ramdiskfile=initrd\0" \ + "bootdev=usb\0" \ + "bootdevnum=0\0" \ + "bootdevpart=0\0" \ + "bootfsload=fatload\0" \ + "bootusb=setenv bootdev usb; boot\0" \ + "bootscsi=setenv bootdev scsi; boot\0" \ + "bootmmc=setenv bootdev mmc; boot\0" \ + "bootargs=console=ttyS0,115200 console=tty0\0" + +/* + * Override CONFIG_BOOTCOMMAND in x86-common.h + */ +#undef CONFIG_BOOTCOMMAND +#define CONFIG_BOOTCOMMAND \ + "if test ${bootdev} = "usb"; then ${bootdev} start; fi; " \ + "if test ${bootdev} = "scsi"; then ${bootdev} scan; fi; " \ + "${bootdev} info; " \ + "${bootfsload} ${bootdev} ${bootdevnum}:${bootdevpart} " \ + "${loadaddr} ${bootfile}; " \ + "${bootfsload} ${bootdev} ${bootdevnum}:${bootdevpart} " \ + "${ramdiskaddr} ${ramdiskfile}; " \ + "zboot ${loadaddr} 0 ${ramdiskaddr} ${filesize}" + +#endif /* __SLIMBOOTLOADER_CONFIG_H__ */
Hi Aiden,
Changes in v6:
- Select CONFIG_SYS_SLIMBOOTLOADER in board Kconfig
- Move USB_STORAGE and USB_KEYBOARD to board Kconfig
- Convert README to reST doc/board/intel/slimbootloader.rst
Changes in v5:
- Remove X86_LOAD_FROM_32_BIT from slimbootloader_defconfig
Changes in v3:
- Remove VENDOR_SLIMBOOTLOADER
- Use VENDOR_INTEL
- Move slimbootloader under board/intel/
- Enable generic CONFIGs in slimbootloader_defconfig
- Add more description in board/intel/slimbootloader/README
Please make sure you also update doc/board/intel/index.rst
Regards, Bin
Hi Bin,
-----Original Message----- From: Bin Meng [mailto:bmeng.cn@gmail.com] Sent: Friday, July 26, 2019 10:00 PM To: Park, Aiden aiden.park@intel.com Cc: Andy Shevchenko andy.shevchenko@gmail.com; U-Boot Mailing List <u- boot@lists.denx.de>; Simon Glass sjg@chromium.org Subject: Re: [PATCH v6 7/8] board: intel: Add new slimbootloader board
Hi Aiden,
Changes in v6:
Changes in v5:
Changes in v3:
- Use VENDOR_INTEL
Thanks a lot for reminding me this! Let me update index.rst as well.
Regards, Bin
Best Regards, Aiden
Bin Meng
Park, Aiden
