[U-Boot] sunxi: support NanoPi Neo2
this diff adds basic support for the NanoPi Neo2. It's based on the old NanoPi Neo support and the recent commit of the OrangePi PC2 support. I'm not sure it's 100% correct, but it seems to be a good start to me and makes the machine boot. Tested with Andre's SPL FIT patchset.
Patrick
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index f3f53f3..4a36036 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -310,6 +310,7 @@ dtb-$(CONFIG_MACH_SUN8I_R40) += \ dtb-$(CONFIG_MACH_SUN8I_V3S) += \ sun8i-v3s-licheepi-zero.dtb dtb-$(CONFIG_MACH_SUN50I_H5) += \ + sun50i-h5-nanopi-neo2.dtb \ sun50i-h5-orangepi-pc2.dtb dtb-$(CONFIG_MACH_SUN50I) += \ sun50i-a64-pine64-plus.dtb \ diff --git a/arch/arm/dts/sun50i-h5-nanopi-neo2.dts b/arch/arm/dts/sun50i-h5-nanopi-neo2.dts new file mode 100644 index 0000000..4932855 --- /dev/null +++ b/arch/arm/dts/sun50i-h5-nanopi-neo2.dts @@ -0,0 +1,180 @@ +/* + * Copyright (C) 2016 James Pettigrew james@innovum.com.au + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; +#include "sun8i-h3.dtsi" +#include "sunxi-common-regulators.dtsi" + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/pinctrl/sun4i-a10.h> + +/ { + model = "FriendlyARM NanoPi NEO2"; + compatible = "friendlyarm,nanopi-neo2", "allwinner,sun50i-h5"; + + cpus { + cpu@0 { + compatible = "arm,cortex-a53", "arm,armv8"; + enable-method = "psci"; + }; + cpu@1 { + compatible = "arm,cortex-a53", "arm,armv8"; + enable-method = "psci"; + }; + cpu@2 { + compatible = "arm,cortex-a53", "arm,armv8"; + enable-method = "psci"; + }; + cpu@3 { + compatible = "arm,cortex-a53", "arm,armv8"; + enable-method = "psci"; + }; + }; + + psci { + compatible = "arm,psci-0.2"; + method = "smc"; + }; + + timer { + compatible = "arm,armv8-timer"; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + memory { + reg = <0x40000000 0x20000000>; + }; + + aliases { + serial0 = &uart0; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&leds_opc>, <&leds_r_opc>; + + pwr { + label = "nanopi:green:pwr"; + gpios = <&r_pio 0 10 GPIO_ACTIVE_HIGH>; /* PL10 */ + default-state = "on"; + }; + + status { + label = "nanopi:blue:status"; + gpios = <&pio 0 10 GPIO_ACTIVE_HIGH>; /* PA10 */ + }; + }; + + reg_usb0_vbus: usb0-vbus { + compatible = "regulator-fixed"; + regulator-name = "usb0-vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + enable-active-high; + gpio = <&r_pio 0 2 GPIO_ACTIVE_HIGH>; /* PL2 */ + status = "okay"; + }; +}; + +&ehci3 { + status = "okay"; +}; + +&mmc0 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin>; + vmmc-supply = <®_vcc3v3>; + bus-width = <4>; + cd-gpios = <&pio 5 6 GPIO_ACTIVE_HIGH>; /* PF6 */ + cd-inverted; + status = "okay"; +}; + +&ohci3 { + status = "okay"; +}; + +&pio { + leds_opc: led-pins { + allwinner,pins = "PA10"; + allwinner,function = "gpio_out"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + }; +}; + +&r_pio { + leds_r_opc: led-pins { + allwinner,pins = "PL10"; + allwinner,function = "gpio_out"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + }; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pins_a>; + status = "okay"; +}; + +&usbphy { + /* USB Type-A port's VBUS is always on */ + usb0_id_det-gpios = <&pio 6 12 GPIO_ACTIVE_HIGH>; /* PG12 */ + usb0_vbus-supply = <®_usb0_vbus>; + status = "okay"; +}; + +&emac { + phy = <&phy1>; + phy-mode = "mii"; + allwinner,use-internal-phy; + allwinner,leds-active-low; + status = "okay"; + phy1: ethernet-phy@1 { + reg = <1>; + }; +}; diff --git a/configs/nanopi_neo2_defconfig b/configs/nanopi_neo2_defconfig new file mode 100644 index 0000000..74c7d74 --- /dev/null +++ b/configs/nanopi_neo2_defconfig @@ -0,0 +1,19 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_MACH_SUN50I_H5=y +CONFIG_SPL=y +CONFIG_DRAM_CLK=504 +CONFIG_DRAM_ZQ=3881977 +CONFIG_DEFAULT_DEVICE_TREE="sun50i-h5-nanopi-neo2" +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_CONSOLE_MUX=y +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_SUN8I_EMAC=y +CONFIG_USB_EHCI_HCD=y +CONFIG_SPL_SPI_SUNXI=y +CONFIG_SPL_SPI_FLASH_SUPPORT=y
Patrick Wildt
