BOOTP_DEFAULT is defined in several boards, but this config option is never checked or used.
This patch removes this config option from config files and the whitelist.txt
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/include/configs/am335x_shc.h b/include/configs/am335x_shc.h index c88067c012..7240ff6901 100644 --- a/include/configs/am335x_shc.h +++ b/include/configs/am335x_shc.h @@ -239,7 +239,6 @@ #undef CONFIG_TIMER #endif
-#define CONFIG_BOOTP_DEFAULT #define CONFIG_NET_RETRY_COUNT 10
/* I2C configuration */ diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index a0d815db32..5d36a1429f 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -34,7 +34,6 @@ /* I2C */
/* Ethernet */ -#define CONFIG_BOOTP_DEFAULT #define CONFIG_NET_RETRY_COUNT 10
/* Board NAND Info. */ diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index 6788cb01f6..8355b4abc0 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -192,7 +192,6 @@
#ifndef CONFIG_SPL_BUILD /* CPSW Ethernet */ -#define CONFIG_BOOTP_DEFAULT #define CONFIG_NET_RETRY_COUNT 10 #endif
diff --git a/include/configs/cm_t43.h b/include/configs/cm_t43.h index 857a5d86dd..73205d0de6 100644 --- a/include/configs/cm_t43.h +++ b/include/configs/cm_t43.h @@ -43,7 +43,6 @@ 50, 51, 52, 53, 54, 55, 56, 57, }
/* CPSW Ethernet support */ -#define CONFIG_BOOTP_DEFAULT #define CONFIG_SYS_RX_ETH_BUFFER 64
/* USB support */ diff --git a/include/configs/omapl138_lcdk.h b/include/configs/omapl138_lcdk.h index 6d552b09d4..a37359e6c3 100644 --- a/include/configs/omapl138_lcdk.h +++ b/include/configs/omapl138_lcdk.h @@ -152,7 +152,6 @@ * Network & Ethernet Configuration */ #ifdef CONFIG_DRIVER_TI_EMAC -#define CONFIG_BOOTP_DEFAULT #define CONFIG_NET_RETRY_COUNT 10 #endif
diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index fc5a8c672b..e48283f685 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -165,7 +165,6 @@ * 0x442000 - 0x800000 : Userland */
/* NAND support */ diff --git a/include/configs/ti_armv7_keystone2.h b/include/configs/ti_armv7_keystone2.h index cb20dc01b7..cfc2be7b9f 100644 --- a/include/configs/ti_armv7_keystone2.h +++ b/include/configs/ti_armv7_keystone2.h @@ -66,7 +66,6 @@ #define CONFIG_SYS_SPI_CLK ks_clk_get_rate(KS2_CLK1_6)
/* Network Configuration */ -#define CONFIG_BOOTP_DEFAULT #define CONFIG_NET_RETRY_COUNT 32 #define CONFIG_SYS_SGMII_REFCLK_MHZ 312 #define CONFIG_SYS_SGMII_LINERATE_MHZ 1250 diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 131678ffb7..b6165c1361 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -126,7 +126,6 @@ CONFIG_BOOTMODE CONFIG_BOOTP_ CONFIG_BOOTP_BOOTFILE CONFIG_BOOTP_BOOTFILESIZE -CONFIG_BOOTP_DEFAULT CONFIG_BOOTP_DHCP_REQUEST_DELAY CONFIG_BOOTP_ID_CACHE_SIZE CONFIG_BOOTP_MAY_FAIL
Adam Ford
