[PATCH 0/4] sunxi: devicetree updates plus new boards
This updates the Allwinner related devicetree files from the Linux kernel repository. The files were taken from Linux v6.9-rc4, and adjusted to increase compatibility with older kernels.
This also adds board support for two new devices: the old Remix Mini PC, a TV box like "Android desktop" device from 2015, and the Tanix TX1, which is a tiny TV box with an H313 SoC. The DT for the latter is preliminary for now, as it hasn't been merged into Linus' tree yet - though that's supposed to happen in about a few weeks time.
Please have a look!
Cheers, Andre
Andre Przywara (4): sunxi: dts: arm/arm64: update devicetree files from Linux-v6.9-rc4 sunxi: a64: Add Remix Mini PC support [DO NOT MERGE] sunxi: dts: arm64: add Tanix TX1 DT from Linux sunxi: H616: add Tanix TX1 support
arch/arm/dts/Makefile | 4 +- arch/arm/dts/sun50i-h313-tanix-tx1.dts | 183 +++++++++ arch/arm/dts/sun50i-h6-beelink-gs1.dts | 2 + arch/arm/dts/sun50i-h6-tanix.dtsi | 2 + arch/arm/dts/sun50i-h6.dtsi | 7 +- .../dts/sun50i-h616-bigtreetech-cb1-manta.dts | 2 +- arch/arm/dts/sun50i-h616-bigtreetech-cb1.dtsi | 4 +- arch/arm/dts/sun50i-h616-bigtreetech-pi.dts | 2 +- arch/arm/dts/sun50i-h616.dtsi | 155 ++++++++ .../arm/dts/sun50i-h618-longan-module-3h.dtsi | 75 ++++ arch/arm/dts/sun50i-h618-longanpi-3h.dts | 144 +++++++ .../arm/dts/sun50i-h618-transpeed-8k618-t.dts | 23 ++ arch/arm/dts/sun50i-h64-remix-mini-pc.dts | 356 ++++++++++++++++++ arch/arm/dts/sun8i-r40-feta40i.dtsi | 7 + configs/remix-mini-pc_defconfig | 14 + configs/tanix_tx1_defconfig | 25 ++ 16 files changed, 996 insertions(+), 9 deletions(-) create mode 100644 arch/arm/dts/sun50i-h313-tanix-tx1.dts create mode 100644 arch/arm/dts/sun50i-h618-longan-module-3h.dtsi create mode 100644 arch/arm/dts/sun50i-h618-longanpi-3h.dts create mode 100644 arch/arm/dts/sun50i-h64-remix-mini-pc.dts create mode 100644 configs/remix-mini-pc_defconfig create mode 100644 configs/tanix_tx1_defconfig
Sync the devicetree files from the official Linux kernel tree, v6.9-rc4. This is covering Allwinner SoCs with 32-bit and 64-bit ARM cores.
Besides some cosmectic changes, this adds S/PDIF, DMA, and thermal support to the H616 .dtsi. Nothing that U-Boot needs for itself, but helpful to pass on to kernels. This also adds new devicetrees, for some LonganPi H616 board, and the Remix Mini PC. The latter will get a defconfig next.
As before, this omits the non-backwards compatible changes to the R_INTC controller, to remain compatible with older kernels.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/dts/sun50i-h6-beelink-gs1.dts | 2 + arch/arm/dts/sun50i-h6-tanix.dtsi | 2 + arch/arm/dts/sun50i-h6.dtsi | 7 +- .../dts/sun50i-h616-bigtreetech-cb1-manta.dts | 2 +- arch/arm/dts/sun50i-h616-bigtreetech-cb1.dtsi | 4 +- arch/arm/dts/sun50i-h616-bigtreetech-pi.dts | 2 +- arch/arm/dts/sun50i-h616.dtsi | 155 ++++++++ .../arm/dts/sun50i-h618-longan-module-3h.dtsi | 75 ++++ arch/arm/dts/sun50i-h618-longanpi-3h.dts | 144 +++++++ .../arm/dts/sun50i-h618-transpeed-8k618-t.dts | 23 ++ arch/arm/dts/sun50i-h64-remix-mini-pc.dts | 356 ++++++++++++++++++ arch/arm/dts/sun8i-r40-feta40i.dtsi | 7 + 12 files changed, 771 insertions(+), 8 deletions(-) create mode 100644 arch/arm/dts/sun50i-h618-longan-module-3h.dtsi create mode 100644 arch/arm/dts/sun50i-h618-longanpi-3h.dts create mode 100644 arch/arm/dts/sun50i-h64-remix-mini-pc.dts
diff --git a/arch/arm/dts/sun50i-h6-beelink-gs1.dts b/arch/arm/dts/sun50i-h6-beelink-gs1.dts index d6897ec9799..87432c4f1ff 100644 --- a/arch/arm/dts/sun50i-h6-beelink-gs1.dts +++ b/arch/arm/dts/sun50i-h6-beelink-gs1.dts @@ -291,6 +291,8 @@ };
&spdif { + pinctrl-names = "default"; + pinctrl-0 = <&spdif_tx_pin>; status = "okay"; };
diff --git a/arch/arm/dts/sun50i-h6-tanix.dtsi b/arch/arm/dts/sun50i-h6-tanix.dtsi index 4903d635811..855b7d43bc5 100644 --- a/arch/arm/dts/sun50i-h6-tanix.dtsi +++ b/arch/arm/dts/sun50i-h6-tanix.dtsi @@ -166,6 +166,8 @@ };
diff --git a/arch/arm/dts/sun50i-h6.dtsi b/arch/arm/dts/sun50i-h6.dtsi index 3c85c8cc8ea..09e21689284 100644 --- a/arch/arm/dts/sun50i-h6.dtsi +++ b/arch/arm/dts/sun50i-h6.dtsi @@ -405,6 +405,7 @@ function = "spi1"; };
+ /omit-if-no-ref/ spdif_tx_pin: spdif-tx-pin { pins = "PH7"; function = "spdif"; @@ -654,10 +655,8 @@ clocks = <&ccu CLK_BUS_SPDIF>, <&ccu CLK_SPDIF>; clock-names = "apb", "spdif"; resets = <&ccu RST_BUS_SPDIF>; - dmas = <&dma 2>; - dma-names = "tx"; - pinctrl-names = "default"; - pinctrl-0 = <&spdif_tx_pin>; + dmas = <&dma 2>, <&dma 2>; + dma-names = "rx", "tx"; status = "disabled"; };
diff --git a/arch/arm/dts/sun50i-h616-bigtreetech-cb1-manta.dts b/arch/arm/dts/sun50i-h616-bigtreetech-cb1-manta.dts index dbce61b355d..4bfb52609c9 100644 --- a/arch/arm/dts/sun50i-h616-bigtreetech-cb1-manta.dts +++ b/arch/arm/dts/sun50i-h616-bigtreetech-cb1-manta.dts @@ -1,4 +1,4 @@ -// SPDX-License-Identifier: (GPL-2.0+ or MIT) +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* * Copyright (C) 2023 Martin Botka martin.botka@somainline.org. */ diff --git a/arch/arm/dts/sun50i-h616-bigtreetech-cb1.dtsi b/arch/arm/dts/sun50i-h616-bigtreetech-cb1.dtsi index 1fed2b46cfe..af421ba24ce 100644 --- a/arch/arm/dts/sun50i-h616-bigtreetech-cb1.dtsi +++ b/arch/arm/dts/sun50i-h616-bigtreetech-cb1.dtsi @@ -1,4 +1,4 @@ -// SPDX-License-Identifier: (GPL-2.0+ or MIT) +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* * Copyright (C) 2023 Martin Botka martin.botka@somainline.org. */ @@ -93,7 +93,7 @@ interrupt-controller; #interrupt-cells = <1>;
- regulators{ + regulators { reg_dcdc1: dcdc1 { regulator-name = "vdd-gpu-sys"; regulator-min-microvolt = <810000>; diff --git a/arch/arm/dts/sun50i-h616-bigtreetech-pi.dts b/arch/arm/dts/sun50i-h616-bigtreetech-pi.dts index 832f08b2b26..ff84a379447 100644 --- a/arch/arm/dts/sun50i-h616-bigtreetech-pi.dts +++ b/arch/arm/dts/sun50i-h616-bigtreetech-pi.dts @@ -1,4 +1,4 @@ -// SPDX-License-Identifier: (GPL-2.0+ or MIT) +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) /* * Copyright (C) 2023 Martin Botka martin@biqu3d.com. */ diff --git a/arch/arm/dts/sun50i-h616.dtsi b/arch/arm/dts/sun50i-h616.dtsi index d549d277d97..b2e85e52d1a 100644 --- a/arch/arm/dts/sun50i-h616.dtsi +++ b/arch/arm/dts/sun50i-h616.dtsi @@ -9,6 +9,7 @@ #include <dt-bindings/clock/sun6i-rtc.h> #include <dt-bindings/reset/sun50i-h616-ccu.h> #include <dt-bindings/reset/sun50i-h6-r-ccu.h> +#include <dt-bindings/thermal/thermal.h>
/ { interrupt-parent = <&gic>; @@ -133,11 +134,28 @@ #reset-cells = <1>; };
+ dma: dma-controller@3002000 { + compatible = "allwinner,sun50i-h616-dma", + "allwinner,sun50i-a100-dma"; + reg = <0x03002000 0x1000>; + interrupts = <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_DMA>, <&ccu CLK_MBUS_DMA>; + clock-names = "bus", "mbus"; + dma-channels = <16>; + dma-requests = <49>; + resets = <&ccu RST_BUS_DMA>; + #dma-cells = <1>; + }; + sid: efuse@3006000 { compatible = "allwinner,sun50i-h616-sid", "allwinner,sun50i-a64-sid"; reg = <0x03006000 0x1000>; #address-cells = <1>; #size-cells = <1>; + + ths_calibration: thermal-sensor-calibration@14 { + reg = <0x14 0x8>; + }; };
watchdog: watchdog@30090a0 { @@ -240,6 +258,11 @@ function = "spi1"; };
+ spdif_tx_pin: spdif-tx-pin { + pins = "PH4"; + function = "spdif"; + }; + uart0_ph_pins: uart0-ph-pins { pins = "PH0", "PH1"; function = "uart0"; @@ -256,6 +279,12 @@ pins = "PG8", "PG9"; function = "uart1"; }; + + /omit-if-no-ref/ + x32clk_fanout_pin: x32clk-fanout-pin { + pins = "PG10"; + function = "clock"; + }; };
gic: interrupt-controller@3021000 { @@ -339,6 +368,8 @@ reg-shift = <2>; reg-io-width = <4>; clocks = <&ccu CLK_BUS_UART0>; + dmas = <&dma 14>, <&dma 14>; + dma-names = "tx", "rx"; resets = <&ccu RST_BUS_UART0>; status = "disabled"; }; @@ -350,6 +381,8 @@ reg-shift = <2>; reg-io-width = <4>; clocks = <&ccu CLK_BUS_UART1>; + dmas = <&dma 15>, <&dma 15>; + dma-names = "tx", "rx"; resets = <&ccu RST_BUS_UART1>; status = "disabled"; }; @@ -361,6 +394,8 @@ reg-shift = <2>; reg-io-width = <4>; clocks = <&ccu CLK_BUS_UART2>; + dmas = <&dma 16>, <&dma 16>; + dma-names = "tx", "rx"; resets = <&ccu RST_BUS_UART2>; status = "disabled"; }; @@ -372,6 +407,8 @@ reg-shift = <2>; reg-io-width = <4>; clocks = <&ccu CLK_BUS_UART3>; + dmas = <&dma 17>, <&dma 17>; + dma-names = "tx", "rx"; resets = <&ccu RST_BUS_UART3>; status = "disabled"; }; @@ -383,6 +420,8 @@ reg-shift = <2>; reg-io-width = <4>; clocks = <&ccu CLK_BUS_UART4>; + dmas = <&dma 18>, <&dma 18>; + dma-names = "tx", "rx"; resets = <&ccu RST_BUS_UART4>; status = "disabled"; }; @@ -394,6 +433,8 @@ reg-shift = <2>; reg-io-width = <4>; clocks = <&ccu CLK_BUS_UART5>; + dmas = <&dma 19>, <&dma 19>; + dma-names = "tx", "rx"; resets = <&ccu RST_BUS_UART5>; status = "disabled"; }; @@ -405,6 +446,8 @@ reg = <0x05002000 0x400>; interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_I2C0>; + dmas = <&dma 43>, <&dma 43>; + dma-names = "rx", "tx"; resets = <&ccu RST_BUS_I2C0>; pinctrl-names = "default"; pinctrl-0 = <&i2c0_pins>; @@ -420,6 +463,8 @@ reg = <0x05002400 0x400>; interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_I2C1>; + dmas = <&dma 44>, <&dma 44>; + dma-names = "rx", "tx"; resets = <&ccu RST_BUS_I2C1>; status = "disabled"; #address-cells = <1>; @@ -433,6 +478,8 @@ reg = <0x05002800 0x400>; interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_I2C2>; + dmas = <&dma 45>, <&dma 45>; + dma-names = "rx", "tx"; resets = <&ccu RST_BUS_I2C2>; status = "disabled"; #address-cells = <1>; @@ -446,6 +493,8 @@ reg = <0x05002c00 0x400>; interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_I2C3>; + dmas = <&dma 46>, <&dma 46>; + dma-names = "rx", "tx"; resets = <&ccu RST_BUS_I2C3>; status = "disabled"; #address-cells = <1>; @@ -459,6 +508,8 @@ reg = <0x05003000 0x400>; interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_I2C4>; + dmas = <&dma 47>, <&dma 47>; + dma-names = "rx", "tx"; resets = <&ccu RST_BUS_I2C4>; status = "disabled"; #address-cells = <1>; @@ -472,6 +523,8 @@ interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_SPI0>, <&ccu CLK_SPI0>; clock-names = "ahb", "mod"; + dmas = <&dma 22>, <&dma 22>; + dma-names = "rx", "tx"; resets = <&ccu RST_BUS_SPI0>; status = "disabled"; #address-cells = <1>; @@ -485,6 +538,8 @@ interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_BUS_SPI1>, <&ccu CLK_SPI1>; clock-names = "ahb", "mod"; + dmas = <&dma 23>, <&dma 23>; + dma-names = "rx", "tx"; resets = <&ccu RST_BUS_SPI1>; status = "disabled"; #address-cells = <1>; @@ -511,6 +566,34 @@ }; };
+ spdif: spdif@5093000 { + compatible = "allwinner,sun50i-h616-spdif"; + reg = <0x05093000 0x400>; + interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_SPDIF>, <&ccu CLK_SPDIF>; + clock-names = "apb", "spdif"; + resets = <&ccu RST_BUS_SPDIF>; + dmas = <&dma 2>; + dma-names = "tx"; + pinctrl-names = "default"; + pinctrl-0 = <&spdif_tx_pin>; + #sound-dai-cells = <0>; + status = "disabled"; + }; + + ths: thermal-sensor@5070400 { + compatible = "allwinner,sun50i-h616-ths"; + reg = <0x05070400 0x400>; + interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_THS>; + clock-names = "bus"; + resets = <&ccu RST_BUS_THS>; + nvmem-cells = <&ths_calibration>; + nvmem-cell-names = "calibration"; + allwinner,sram = <&syscon>; + #thermal-sensor-cells = <1>; + }; + usbotg: usb@5100000 { compatible = "allwinner,sun50i-h616-musb", "allwinner,sun8i-h3-musb"; @@ -734,6 +817,8 @@ reg = <0x07081400 0x400>; interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>; clocks = <&r_ccu CLK_R_APB2_I2C>; + dmas = <&dma 48>, <&dma 48>; + dma-names = "rx", "tx"; resets = <&r_ccu RST_R_APB2_I2C>; status = "disabled"; #address-cells = <1>; @@ -755,4 +840,74 @@ #size-cells = <0>; }; }; + + thermal-zones { + cpu-thermal { + polling-delay-passive = <500>; + polling-delay = <1000>; + thermal-sensors = <&ths 2>; + sustainable-power = <1000>; + + trips { + cpu_threshold: cpu-trip-0 { + temperature = <60000>; + type = "passive"; + hysteresis = <0>; + }; + cpu_target: cpu-trip-1 { + temperature = <70000>; + type = "passive"; + hysteresis = <0>; + }; + cpu_critical: cpu-trip-2 { + temperature = <110000>; + type = "critical"; + hysteresis = <0>; + }; + }; + }; + + gpu-thermal { + polling-delay-passive = <500>; + polling-delay = <1000>; + thermal-sensors = <&ths 0>; + sustainable-power = <1100>; + + trips { + gpu_temp_critical: gpu-trip-0 { + temperature = <110000>; + type = "critical"; + hysteresis = <0>; + }; + }; + }; + + ve-thermal { + polling-delay-passive = <0>; + polling-delay = <0>; + thermal-sensors = <&ths 1>; + + trips { + ve_temp_critical: ve-trip-0 { + temperature = <110000>; + type = "critical"; + hysteresis = <0>; + }; + }; + }; + + ddr-thermal { + polling-delay-passive = <0>; + polling-delay = <0>; + thermal-sensors = <&ths 3>; + + trips { + ddr_temp_critical: ddr-trip-0 { + temperature = <110000>; + type = "critical"; + hysteresis = <0>; + }; + }; + }; + }; }; diff --git a/arch/arm/dts/sun50i-h618-longan-module-3h.dtsi b/arch/arm/dts/sun50i-h618-longan-module-3h.dtsi new file mode 100644 index 00000000000..8c1263a3939 --- /dev/null +++ b/arch/arm/dts/sun50i-h618-longan-module-3h.dtsi @@ -0,0 +1,75 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (C) Jisheng Zhang jszhang@kernel.org + */ + +#include "sun50i-h616.dtsi" + +&mmc2 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc2_pins>; + vmmc-supply = <®_dldo1>; + vqmmc-supply = <®_aldo1>; + bus-width = <8>; + non-removable; + cap-mmc-hw-reset; + mmc-ddr-1_8v; + mmc-hs200-1_8v; + status = "okay"; +}; + +&r_i2c { + status = "okay"; + + axp313: pmic@36 { + compatible = "x-powers,axp313a"; + reg = <0x36>; + #interrupt-cells = <1>; + interrupt-controller; + + regulators { + reg_aldo1: aldo1 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc-1v8-pll"; + }; + + reg_dldo1: dldo1 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-3v3-io"; + }; + + reg_dcdc1: dcdc1 { + regulator-always-on; + regulator-min-microvolt = <810000>; + regulator-max-microvolt = <990000>; + regulator-name = "vdd-gpu-sys"; + }; + + reg_dcdc2: dcdc2 { + regulator-always-on; + regulator-min-microvolt = <810000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-cpu"; + }; + + reg_dcdc3: dcdc3 { + regulator-always-on; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-dram"; + }; + }; + }; +}; + +&pio { + vcc-pc-supply = <®_dldo1>; + vcc-pf-supply = <®_dldo1>; + vcc-pg-supply = <®_aldo1>; + vcc-ph-supply = <®_dldo1>; + vcc-pi-supply = <®_dldo1>; +}; diff --git a/arch/arm/dts/sun50i-h618-longanpi-3h.dts b/arch/arm/dts/sun50i-h618-longanpi-3h.dts new file mode 100644 index 00000000000..18b29c6b867 --- /dev/null +++ b/arch/arm/dts/sun50i-h618-longanpi-3h.dts @@ -0,0 +1,144 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (C) Jisheng Zhang jszhang@kernel.org + */ + +/dts-v1/; + +#include "sun50i-h618-longan-module-3h.dtsi" + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/leds/common.h> + +/ { + model = "Sipeed Longan Pi 3H"; + compatible = "sipeed,longan-pi-3h", "sipeed,longan-module-3h", "allwinner,sun50i-h618"; + + aliases { + ethernet0 = &emac0; + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + leds { + compatible = "gpio-leds"; + + led-0 { + color = <LED_COLOR_ID_ORANGE>; + function = LED_FUNCTION_INDICATOR; + function-enumerator = <0>; + gpios = <&pio 6 2 GPIO_ACTIVE_LOW>; /* PG2 */ + }; + + led-1 { + color = <LED_COLOR_ID_ORANGE>; + function = LED_FUNCTION_INDICATOR; + function-enumerator = <1>; + gpios = <&pio 6 4 GPIO_ACTIVE_LOW>; /* PG4 */ + }; + }; + + reg_vcc5v: regulator-vcc5v { + /* board wide 5V supply directly from the USB-C socket */ + compatible = "regulator-fixed"; + regulator-name = "vcc-5v"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + }; + + reg_vcc3v3: regulator-vcc3v3 { + compatible = "regulator-fixed"; + regulator-name = "vcc-3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + vin-supply = <®_vcc5v>; + }; +}; + +&axp313 { + vin1-supply = <®_vcc5v>; + vin2-supply = <®_vcc5v>; + vin3-supply = <®_vcc5v>; +}; + +&ehci1 { + status = "okay"; +}; + +&ohci1 { + status = "okay"; +}; + +&ehci2 { + status = "okay"; +}; + +&ohci2 { + status = "okay"; +}; + +/* WiFi & BT combo module is connected to this Host */ +&ehci3 { + status = "okay"; +}; + +&ohci3 { + status = "okay"; +}; + +&emac0 { + pinctrl-names = "default"; + pinctrl-0 = <&ext_rgmii_pins>; + phy-mode = "rgmii"; + phy-handle = <&ext_rgmii_phy>; + allwinner,rx-delay-ps = <3100>; + allwinner,tx-delay-ps = <700>; + phy-supply = <®_vcc3v3>; + status = "okay"; +}; + +&mdio0 { + ext_rgmii_phy: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <1>; + }; +}; + +&mmc0 { + bus-width = <4>; + cd-gpios = <&pio 5 6 GPIO_ACTIVE_HIGH>; /* PF6 */ + vmmc-supply = <®_vcc3v3>; + status = "okay"; +}; + +&uart0 { + status = "okay"; +}; + +&usbotg { + /* + * PHY0 pins are connected to a USB-C socket, but a role switch + * is not implemented: both CC pins are pulled to GND. + * The VBUS pins power the device, so a fixed peripheral mode + * is the best choice. + * The board can be powered via GPIOs, in this case port0 *can* + * act as a host (with a cable/adapter ignoring CC), as VBUS is + * then provided by the GPIOs. Any user of this setup would + * need to adjust the DT accordingly: dr_mode set to "host", + * enabling OHCI0 and EHCI0. + */ + dr_mode = "peripheral"; + status = "okay"; +}; + +&usbphy { + usb1_vbus-supply = <®_vcc5v>; + usb2_vbus-supply = <®_vcc5v>; + status = "okay"; +}; diff --git a/arch/arm/dts/sun50i-h618-transpeed-8k618-t.dts b/arch/arm/dts/sun50i-h618-transpeed-8k618-t.dts index 8ea1fd41aeb..ac0a2b7ea6f 100644 --- a/arch/arm/dts/sun50i-h618-transpeed-8k618-t.dts +++ b/arch/arm/dts/sun50i-h618-transpeed-8k618-t.dts @@ -15,6 +15,7 @@ compatible = "transpeed,8k618-t", "allwinner,sun50i-h618";
aliases { + ethernet1 = &sdio_wifi; serial0 = &uart0; };
@@ -39,6 +40,15 @@ regulator-max-microvolt = <3300000>; regulator-always-on; }; + + wifi_pwrseq: wifi_pwrseq { + compatible = "mmc-pwrseq-simple"; + clocks = <&rtc CLK_OSC32K_FANOUT>; + clock-names = "ext_clock"; + pinctrl-0 = <&x32clk_fanout_pin>; + pinctrl-names = "default"; + reset-gpios = <&pio 6 18 GPIO_ACTIVE_LOW>; /* PG18 */ + }; };
&ehci0 { @@ -60,6 +70,19 @@ status = "okay"; };
+&mmc1 { + vmmc-supply = <®_dldo1>; + vqmmc-supply = <®_aldo1>; + mmc-pwrseq = <&wifi_pwrseq>; + bus-width = <4>; + non-removable; + status = "okay"; + + sdio_wifi: wifi@1 { + reg = <1>; + }; +}; + &mmc2 { vmmc-supply = <®_dldo1>; vqmmc-supply = <®_aldo1>; diff --git a/arch/arm/dts/sun50i-h64-remix-mini-pc.dts b/arch/arm/dts/sun50i-h64-remix-mini-pc.dts new file mode 100644 index 00000000000..b6e3c169797 --- /dev/null +++ b/arch/arm/dts/sun50i-h64-remix-mini-pc.dts @@ -0,0 +1,356 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +// Copyright (c) 2023 ARM Ltd. + +/dts-v1/; + +#include "sun50i-a64.dtsi" +#include "sun50i-a64-cpu-opp.dtsi" + +#include <dt-bindings/gpio/gpio.h> + +/ { + model = "Remix Mini PC"; + compatible = "jide,remix-mini-pc", "allwinner,sun50i-h64", + "allwinner,sun50i-a64"; + + aliases { + ethernet1 = &rtl8723bs; + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + hdmi-connector { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_con_in: endpoint { + remote-endpoint = <&hdmi_out_con>; + }; + }; + }; + + reg_vcc5v: regulator-5v { + /* board wide 5V supply directly from the DC input */ + compatible = "regulator-fixed"; + regulator-name = "vcc-5v"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + }; + + wifi_pwrseq: wifi_pwrseq { + compatible = "mmc-pwrseq-simple"; + reset-gpios = <&r_pio 0 2 GPIO_ACTIVE_LOW>; /* PL2 */ + post-power-on-delay-ms = <200>; + }; +}; + +&codec { + status = "okay"; +}; + +&codec_analog { + cpvdd-supply = <®_eldo1>; + status = "okay"; +}; + +&cpu0 { + cpu-supply = <®_dcdc2>; +}; + +&cpu1 { + cpu-supply = <®_dcdc2>; +}; + +&cpu2 { + cpu-supply = <®_dcdc2>; +}; + +&cpu3 { + cpu-supply = <®_dcdc2>; +}; + +&dai { + status = "okay"; +}; + +&de { + status = "okay"; +}; + +&ehci0 { + status = "okay"; +}; + +&ehci1 { + status = "okay"; +}; + +&hdmi { + hvcc-supply = <®_dldo1>; + status = "okay"; +}; + +&hdmi_out { + hdmi_out_con: endpoint { + remote-endpoint = <&hdmi_con_in>; + }; +}; + +/* Connects to the AC200 chip */ +&i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c0_pins>; + status = "okay"; +}; + +&i2c0_pins { + bias-pull-up; +}; + +&mmc0 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins>; + vmmc-supply = <®_dcdc1>; + cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; + disable-wp; + bus-width = <4>; + status = "okay"; +}; + +&mmc1 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc1_pins>; + vmmc-supply = <®_aldo1>; + vqmmc-supply = <®_dldo4>; + mmc-pwrseq = <&wifi_pwrseq>; + bus-width = <4>; + non-removable; + status = "okay"; + + rtl8723bs: wifi@1 { + reg = <1>; + interrupt-parent = <&r_pio>; + interrupts = <0 3 IRQ_TYPE_LEVEL_LOW>; /* PL3 */ + interrupt-names = "host-wake"; + }; +}; + +&mmc2 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc2_pins>, <&mmc2_ds_pin>; + vmmc-supply = <®_dcdc1>; + vqmmc-supply = <®_eldo1>; + bus-width = <8>; + non-removable; + mmc-hs200-1_8v; + mmc-hs400-1_8v; + cap-mmc-hw-reset; + status = "okay"; +}; + +&ohci0 { + status = "okay"; +}; + +&ohci1 { + status = "okay"; +}; + +&pio { + vcc-pb-supply = <®_dcdc1>; + vcc-pc-supply = <®_dcdc1>; + vcc-pd-supply = <®_dcdc1>; + vcc-pe-supply = <®_dcdc1>; + vcc-pf-supply = <®_dcdc1>; + vcc-pg-supply = <®_dldo4>; + vcc-ph-supply = <®_dcdc1>; +}; + +&r_ir { + status = "okay"; +}; + +&r_pio { + /* + * We cannot add that supply for now since it would create a circular + * dependency between pinctrl, the regulator and the RSB Bus. + * + * vcc-pl-supply = <®_aldo2>; + */ +}; + +&r_rsb { + status = "okay"; + + axp803: pmic@3a3 { + compatible = "x-powers,axp803"; + reg = <0x3a3>; + interrupt-parent = <&r_intc>; + interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_LOW>; + x-powers,drive-vbus-en; + + vin1-supply = <®_vcc5v>; + vin2-supply = <®_vcc5v>; + vin3-supply = <®_vcc5v>; + vin5-supply = <®_vcc5v>; + vin6-supply = <®_vcc5v>; + aldoin-supply = <®_vcc5v>; + dldoin-supply = <®_vcc5v>; + eldoin-supply = <®_vcc5v>; + fldoin-supply = <®_vcc5v>; + drivevbus-supply = <®_vcc5v>; + ips-supply = <®_vcc5v>; + + status = "okay"; + }; +}; + +#include "axp803.dtsi" + +&ac_power_supply { + status = "okay"; +}; + +®_dcdc1 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-3v3"; +}; + +®_dcdc2 { + regulator-always-on; + regulator-min-microvolt = <1040000>; + regulator-max-microvolt = <1300000>; + regulator-name = "vdd-cpux"; +}; + +/* DCDC3 is polyphased with DCDC2 */ + +®_dcdc5 { + regulator-always-on; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + regulator-name = "vcc-dram"; +}; + +/* Deviates from the reset default of 1.1V. */ +®_dcdc6 { + regulator-always-on; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-name = "vdd-sys"; +}; + +®_aldo1 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-wifi"; +}; + +®_aldo2 { + /* Specifying R_PIO consumer would create circular dependency. */ + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-pl"; +}; + +®_aldo3 { + regulator-always-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-name = "vcc-pll-avcc"; +}; + +/* AC200 power supply */ +®_dldo1 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-ave-33"; +}; + +®_dldo4 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-wifi-io"; +}; + +®_drivevbus { + regulator-name = "usb0-vbus"; + status = "okay"; +}; + +®_eldo1 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc-cpvdd-dram-emmc"; +}; + +/* Supplies the arisc management core, needed by TF-A to power off cores. */ +®_fldo2 { + regulator-always-on; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-cpus"; +}; + +®_rtc_ldo { + regulator-name = "vcc-rtc"; +}; + +&simplefb_hdmi { + vcc-hdmi-supply = <®_dcdc1>; +}; + +&sound { + simple-audio-card,aux-devs = <&codec_analog>; + simple-audio-card,widgets = "Microphone", "Microphone Jack", + "Headphone", "Headphone Jack"; + simple-audio-card,routing = + "Left DAC", "DACL", + "Right DAC", "DACR", + "Headphone Jack", "HP", + "ADCL", "Left ADC", + "ADCR", "Right ADC", + "MIC2", "Microphone Jack"; + status = "okay"; +}; + +/* On the (unpopulated) UART pads. */ +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pb_pins>; + status = "okay"; +}; + +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&uart1_pins>, <&uart1_rts_cts_pins>; + uart-has-rtscts; + status = "okay"; + + bluetooth { + compatible = "realtek,rtl8723bs-bt"; + enable-gpios = <&r_pio 0 4 GPIO_ACTIVE_HIGH>; /* PL4 */ + max-speed = <1500000>; + }; +}; + +&usb_otg { + dr_mode = "host"; + status = "okay"; +}; + +&usbphy { + usb0_vbus-supply = <®_drivevbus>; + usb1_vbus-supply = <®_drivevbus>; + status = "okay"; +}; diff --git a/arch/arm/dts/sun8i-r40-feta40i.dtsi b/arch/arm/dts/sun8i-r40-feta40i.dtsi index 9f39b5a2bb3..c12361d0317 100644 --- a/arch/arm/dts/sun8i-r40-feta40i.dtsi +++ b/arch/arm/dts/sun8i-r40-feta40i.dtsi @@ -42,6 +42,13 @@ vcc-pg-supply = <®_dldo1>; };
+®_aldo1 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-3v3-tv-usb"; +}; + ®_aldo2 { regulator-always-on; regulator-min-microvolt = <1800000>;
The Remix Mini PC is a "mini computer" using the Allwinner H64 SoC, which appears to be just a relabelled A64. It was launched in 2015 by the now defunct company Jide, and shipped with a desktop optimised version of Android. Its appearance and feature set is close to a typical TV box.
The devicetree file has been imported from the Linux tree already, so just add a defconfig and enable the DTB build in the Makefile. The SoC has the "secure boot" fuse burnt, so we need to generate a TOC0 image instead of the standard Allwinner eGON image format for the SPL.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/dts/Makefile | 3 ++- configs/remix-mini-pc_defconfig | 14 ++++++++++++++ 2 files changed, 16 insertions(+), 1 deletion(-) create mode 100644 configs/remix-mini-pc_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index b1c9c6222e5..127345975ef 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -801,7 +801,8 @@ dtb-$(CONFIG_MACH_SUN50I) += \ sun50i-a64-pinephone-1.2.dtb \ sun50i-a64-pinetab.dtb \ sun50i-a64-sopine-baseboard.dtb \ - sun50i-a64-teres-i.dtb + sun50i-a64-teres-i.dtb \ + sun50i-h64-remix-mini-pc.dtb dtb-$(CONFIG_MACH_SUN9I) += \ sun9i-a80-optimus.dtb \ sun9i-a80-cubieboard4.dtb \ diff --git a/configs/remix-mini-pc_defconfig b/configs/remix-mini-pc_defconfig new file mode 100644 index 00000000000..fa427a027f8 --- /dev/null +++ b/configs/remix-mini-pc_defconfig @@ -0,0 +1,14 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_DEFAULT_DEVICE_TREE="sun50i-h64-remix-mini-pc" +CONFIG_SPL=y +CONFIG_MACH_SUN50I=y +CONFIG_DRAM_CLK=672 +CONFIG_DRAM_ZQ=4013533 +CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_SPL_IMAGE_TYPE_SUNXI_TOC0=y +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_CMD_POWEROFF=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_OHCI_HCD=y
Add the board DT file for the Tanix TX1 TV box, with the H313 SoC. This has been taken from the sunxi/for-next tree, though it has not been merged into any other tree yet. So this is a placeholder for now, to enable the board support, and will be superseded by the regular sync of the DT files later.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/dts/sun50i-h313-tanix-tx1.dts | 183 +++++++++++++++++++++++++ 1 file changed, 183 insertions(+) create mode 100644 arch/arm/dts/sun50i-h313-tanix-tx1.dts
diff --git a/arch/arm/dts/sun50i-h313-tanix-tx1.dts b/arch/arm/dts/sun50i-h313-tanix-tx1.dts new file mode 100644 index 00000000000..bb2cde59bd0 --- /dev/null +++ b/arch/arm/dts/sun50i-h313-tanix-tx1.dts @@ -0,0 +1,183 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (C) 2024 Arm Ltd. + */ + +/dts-v1/; + +#include "sun50i-h616.dtsi" + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/input/linux-event-codes.h> +#include <dt-bindings/leds/common.h> + +/ { + model = "Tanix TX1"; + compatible = "oranth,tanix-tx1", "allwinner,sun50i-h616"; + + aliases { + serial0 = &uart0; + ethernet0 = &sdio_wifi; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + gpio-keys { + compatible = "gpio-keys"; + + key { + label = "hidden"; + linux,code = <BTN_0>; + gpios = <&pio 7 9 GPIO_ACTIVE_LOW>; /* PH9 */ + }; + }; + + leds { + compatible = "gpio-leds"; + + led-0 { + function = LED_FUNCTION_POWER; + color = <LED_COLOR_ID_BLUE>; + gpios = <&pio 7 6 GPIO_ACTIVE_HIGH>; /* PH6 */ + default-state = "on"; + }; + }; + + wifi_pwrseq: pwrseq { + compatible = "mmc-pwrseq-simple"; + clocks = <&rtc CLK_OSC32K_FANOUT>; + clock-names = "ext_clock"; + pinctrl-0 = <&x32clk_fanout_pin>; + pinctrl-names = "default"; + reset-gpios = <&pio 6 18 GPIO_ACTIVE_LOW>; /* PG18 */ + }; + + reg_vcc5v: vcc5v { + /* board wide 5V supply directly from the DC input */ + compatible = "regulator-fixed"; + regulator-name = "vcc-5v"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + }; +}; + +&cpu0 { + cpu-supply = <®_dcdc2>; +}; + +&ehci0 { + status = "okay"; +}; + +&ir { + status = "okay"; +}; + +&mmc1 { + vmmc-supply = <®_dldo1>; + vqmmc-supply = <®_aldo1>; + mmc-pwrseq = <&wifi_pwrseq>; + bus-width = <4>; + non-removable; + status = "okay"; + + sdio_wifi: wifi@1 { + reg = <1>; + }; +}; + +&mmc2 { + vmmc-supply = <®_dldo1>; + vqmmc-supply = <®_aldo1>; + bus-width = <8>; + non-removable; + max-frequency = <100000000>; + cap-mmc-hw-reset; + mmc-ddr-1_8v; + status = "okay"; +}; + +&ohci0 { + status = "okay"; +}; + +&pio { + vcc-pc-supply = <®_aldo1>; + vcc-pf-supply = <®_dldo1>; + vcc-pg-supply = <®_aldo1>; + vcc-ph-supply = <®_dldo1>; + vcc-pi-supply = <®_dldo1>; +}; + +&r_i2c { + status = "okay"; + + axp313: pmic@36 { + compatible = "x-powers,axp313a"; + reg = <0x36>; + #interrupt-cells = <1>; + interrupt-controller; + + vin1-supply = <®_vcc5v>; + vin2-supply = <®_vcc5v>; + vin3-supply = <®_vcc5v>; + + regulators { + /* Supplies VCC-PLL, so needs to be always on. */ + reg_aldo1: aldo1 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc1v8"; + }; + + /* Supplies VCC-IO, so needs to be always on. */ + reg_dldo1: dldo1 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc3v3"; + }; + + reg_dcdc1: dcdc1 { + regulator-always-on; + regulator-min-microvolt = <810000>; + regulator-max-microvolt = <990000>; + regulator-name = "vdd-gpu-sys"; + }; + + reg_dcdc2: dcdc2 { + regulator-always-on; + regulator-min-microvolt = <810000>; + regulator-max-microvolt = <1120000>; + regulator-name = "vdd-cpu"; + }; + + reg_dcdc3: dcdc3 { + regulator-always-on; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-name = "vdd-dram"; + }; + }; + }; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_ph_pins>; + status = "okay"; +}; + +&usbotg { + dr_mode = "host"; /* USB A type receptable */ + status = "okay"; +}; + +&usbphy { + status = "okay"; +};
The Tanix TX1 is a tiny TV box, featuring the Allwinner H313 SoC with up to 2GB of DRAM and 16GB of eMMC. There is no SD card or Ethernet port on this small device, but it can be booted via the USB debug "FEL" mode. The bootloader could then be written to the eMMC.
Add the defconfig for that board, and add the devicetree file to the Makefile, for it to be built. The DRAM parameters were taken from the vendor firmware on the eMMC.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/dts/Makefile | 1 + configs/tanix_tx1_defconfig | 25 +++++++++++++++++++++++++ 2 files changed, 26 insertions(+) create mode 100644 configs/tanix_tx1_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 127345975ef..69b0d6a9ad7 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -779,6 +779,7 @@ dtb-$(CONFIG_MACH_SUN50I_H6) += \ sun50i-h6-tanix-tx6.dtb \ sun50i-h6-tanix-tx6-mini.dtb dtb-$(CONFIG_MACH_SUN50I_H616) += \ + sun50i-h313-tanix-tx1.dtb \ sun50i-h616-orangepi-zero2.dtb \ sun50i-h618-orangepi-zero2w.dtb \ sun50i-h618-orangepi-zero3.dtb \ diff --git a/configs/tanix_tx1_defconfig b/configs/tanix_tx1_defconfig new file mode 100644 index 00000000000..9915fff4a00 --- /dev/null +++ b/configs/tanix_tx1_defconfig @@ -0,0 +1,25 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_DEFAULT_DEVICE_TREE="sun50i-h313-tanix-tx1" +CONFIG_SPL=y +CONFIG_DRAM_SUN50I_H616_DX_ODT=0x06060606 +CONFIG_DRAM_SUN50I_H616_DX_DRI=0x0d0d0d0d +CONFIG_DRAM_SUN50I_H616_CA_DRI=0x1919 +CONFIG_DRAM_SUN50I_H616_ODT_EN=0x9988eeee +CONFIG_DRAM_SUN50I_H616_TPR6=0x2fb08080 +CONFIG_DRAM_SUN50I_H616_TPR10=0x402f4469 +CONFIG_DRAM_SUN50I_H616_TPR11=0x0e0f0d0d +CONFIG_DRAM_SUN50I_H616_TPR12=0x11131213 +CONFIG_MACH_SUN50I_H616=y +CONFIG_SUNXI_DRAM_H616_LPDDR3=y +CONFIG_R_I2C_ENABLE=y +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_I2C=y +CONFIG_SPL_SYS_I2C_LEGACY=y +CONFIG_SYS_I2C_MVTWSI=y +CONFIG_SYS_I2C_SLAVE=0x7f +CONFIG_SYS_I2C_SPEED=400000 +CONFIG_AXP313_POWER=y +CONFIG_AXP_DCDC3_VOLT=1200 +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_OHCI_HCD=y
Andre Przywara
