[PATCH v2] FWU: developerbox: read boot index from NOR flash
The FWU Multi Bank Update feature allows the platform to boot the firmware images from one of the partitions(banks). On the Developerbox, SCP-firmware running on the SCB(Cortex-M3) passes the value of the boot index on the NOR flash. Add a function to read the boot index value from the NOR flash.
Signed-off-by: Masahisa Kojima kojima.masahisa@socionext.com --- v1 -> v2 - update my email address
board/socionext/developerbox/fwu_plat.c | 31 +++++++++++++++++++++++++ include/configs/synquacer.h | 1 + 2 files changed, 32 insertions(+)
diff --git a/board/socionext/developerbox/fwu_plat.c b/board/socionext/developerbox/fwu_plat.c index e724e702bd..26031795b0 100644 --- a/board/socionext/developerbox/fwu_plat.c +++ b/board/socionext/developerbox/fwu_plat.c @@ -35,3 +35,34 @@ void set_dfu_alt_info(char *interface, char *devstr)
env_set("dfu_alt_info", buf); } + +/** + * fwu_plat_get_bootidx() - Get the value of the boot index + * @boot_idx: Boot index value + * + * Get the value of the bank(partition) from which the platform + * has booted. This value is passed to U-Boot from the earlier + * stage bootloader which loads and boots all the relevant + * firmware images + */ +void fwu_plat_get_bootidx(uint *boot_idx) +{ + int ret; + u32 buf; + size_t readlen; + struct mtd_info *mtd; + + *boot_idx = 0; + + mtd_probe_devices(); + mtd = get_mtd_device_nm("nor1"); + if (IS_ERR_OR_NULL(mtd)) + return; + + ret = mtd_read(mtd, SCB_PLAT_METADATA_OFFSET, sizeof(buf), + &readlen, (u_char *)&buf); + if (ret < 0) + return; + + *boot_idx = buf; +} diff --git a/include/configs/synquacer.h b/include/configs/synquacer.h index e36e63e81e..f0867227ac 100644 --- a/include/configs/synquacer.h +++ b/include/configs/synquacer.h @@ -21,6 +21,7 @@ /* * Boot info */ +#define SCB_PLAT_METADATA_OFFSET (0x510000)
/* * Hardware drivers support
On Tue, 27 Feb 2024 at 23:53, Masahisa Kojima kojima.masahisa@socionext.com wrote:
Acked-by: Jassi Brar jaswinder.singh@linaro.org
Jassi Brar
Masahisa Kojima
