[U-Boot] [PATCH] freescale; Ensure common commands are not included in SPL binary
Both the "qixis_reset" and esbc_validate" commands can only be used in full U-Boot so do not build them in SPL. As part of this rework the qixis code to declare things as static and make use of __weak for function aliases.
Cc; York Sun york.sun@nxp.com Signed-off-by: Tom Rini trini@konsulko.com --- board/freescale/common/cmd_esbc_validate.c | 2 ++ board/freescale/common/qixis.c | 14 +++++++------- 2 files changed, 9 insertions(+), 7 deletions(-)
diff --git a/board/freescale/common/cmd_esbc_validate.c b/board/freescale/common/cmd_esbc_validate.c index b3e5f019b87b..f45e2249fbac 100644 --- a/board/freescale/common/cmd_esbc_validate.c +++ b/board/freescale/common/cmd_esbc_validate.c @@ -23,6 +23,7 @@ loop: return 0; }
+#ifndef CONFIG_SPL_BUILD static int do_esbc_validate(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { @@ -82,3 +83,4 @@ U_BOOT_CMD( "Put the core in spin loop (Secure Boot Only)", "" ); +#endif diff --git a/board/freescale/common/qixis.c b/board/freescale/common/qixis.c index 0db0ed667002..24459f863578 100644 --- a/board/freescale/common/qixis.c +++ b/board/freescale/common/qixis.c @@ -10,6 +10,7 @@ #include <common.h> #include <command.h> #include <asm/io.h> +#include <linux/compiler.h> #include <linux/time.h> #include <i2c.h> #include "qixis.h" @@ -136,12 +137,13 @@ void board_deassert_mem_reset(void) } #endif
-void qixis_reset(void) +#ifndef CONFIG_SPL_BUILD +static void qixis_reset(void) { QIXIS_WRITE(rst_ctl, QIXIS_RST_CTL_RESET); }
-void qixis_bank_reset(void) +static void qixis_bank_reset(void) { QIXIS_WRITE(rcfg_ctl, QIXIS_RCFG_CTL_RECONFIG_IDLE); QIXIS_WRITE(rcfg_ctl, QIXIS_RCFG_CTL_RECONFIG_START); @@ -196,15 +198,12 @@ static void qixis_dump_regs(void) printf("stat_alrm = %02x\n", QIXIS_READ(stat_alrm)); }
-static void __qixis_dump_switch(void) +void __weak qixis_dump_switch(void) { puts("Reverse engineering switch is not implemented for this board\n"); }
-void qixis_dump_switch(void) - __attribute__((weak, alias("__qixis_dump_switch"))); - -int qixis_reset_cmd(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +static int qixis_reset_cmd(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { int i;
@@ -305,3 +304,4 @@ U_BOOT_CMD( "qixis_reset dump - display the QIXIS registers\n" "qixis_reset switch - display switch\n" ); +#endif
Minor change to subject. Applied to fsl-qoriq master. Thanks.
York
York Sun
