[U-Boot] u-boot-arm pull request
Hi Wolfgang, please pull The following changes since commit 33aa4eac66b71c797bbc13b3afe432a2132947d4: Wolfgang Denk (1): Merge branch 'master' of /home/wd/git/u-boot/custodians
git://git.denx.de/u-boot-arm.git master
Guennadi Liakhovetski (7): ARM: Add arm1176 core with S3C6400 SoC USB: Add support for OHCI controller on S3C6400 serial: add S3C64XX serial driver S3C64XX: remove broken HWFLOW support from the serial driver NAND: add NAND driver for S3C64XX ARM: Add support for S3C6400 based SMDK6400 board smdk6400: remove redundant bootargs definition
Gururaja Hebbar K R (1): Integrator[AP/CP] - Remove unused file memsetup.S
Hugo Villeneuve (2): ARM DaVinci: Move common functions to board/davinci/common ARM DaVinci: Standardize names of directories/files
Jean-Christophe PLAGNIOL-VILLARD (3): smdk6400: Use CONFIG_FLASH_CFI_DRIVER smdk6400: add gitignore davinci: fix remaining dm644x_eth
Sandeep Paulraj (1): ARM DaVinci: Changing function names for EMAC driver
MAINTAINERS | 1 + MAKEALL | 1 + Makefile | 19 +- board/davinci/{dv-evm => common}/Makefile | 13 +- board/davinci/common/misc.c | 126 +++ board/davinci/common/misc.h | 32 + board/davinci/common/psc.c | 117 +++ .../memsetup.S => davinci/common/psc.h} | 27 +- board/davinci/dv-evm/dv_board.c | 202 ----- board/davinci/{dv-evm => dvevm}/Makefile | 2 +- board/davinci/{dv-evm => dvevm}/board_init.S | 0 board/davinci/{dv-evm => dvevm}/config.mk | 0 board/davinci/dvevm/dvevm.c | 103 +++ board/davinci/{dv-evm => dvevm}/u-boot.lds | 0 board/davinci/schmoogie/Makefile | 2 +- .../davinci/schmoogie/{dv_board.c => schmoogie.c} | 103 +--- board/davinci/sffsdr/sffsdr.c | 158 +---- board/davinci/sonata/Makefile | 2 +- board/davinci/sonata/dv_board.c | 199 ----- board/davinci/sonata/sonata.c | 97 +++ board/integratorap/Makefile | 2 +- board/integratorcp/Makefile | 2 +- board/samsung/smdk6400/.gitignore | 5 + .../{davinci/dv-evm => samsung/smdk6400}/Makefile | 18 +- board/samsung/smdk6400/config.mk | 30 + board/samsung/smdk6400/lowlevel_init.S | 316 +++++++ board/samsung/smdk6400/smdk6400.c | 130 +++ .../smdk6400/u-boot-nand.lds} | 18 +- {board/davinci/dv-evm => cpu/arm1176}/Makefile | 30 +- .../dv-evm/Makefile => cpu/arm1176/config.mk | 45 +- cpu/arm1176/cpu.c | 188 ++++ .../dv-evm => cpu/arm1176/s3c64xx}/Makefile | 29 +- .../Makefile => cpu/arm1176/s3c64xx/config.mk | 44 +- cpu/arm1176/s3c64xx/cpu_init.S | 142 ++++ cpu/arm1176/s3c64xx/interrupts.c | 174 ++++ cpu/arm1176/s3c64xx/speed.c | 145 ++++ .../memsetup.S => cpu/arm1176/s3c64xx/usb.c | 32 +- cpu/arm1176/start.S | 469 ++++++++++ cpu/arm926ejs/davinci/dp83848.c | 24 +- cpu/arm926ejs/davinci/ether.c | 114 ++-- cpu/arm926ejs/davinci/lxt972.c | 20 +- drivers/mtd/nand/Makefile | 1 + drivers/mtd/nand/s3c64xx.c | 319 +++++++ drivers/serial/Makefile | 1 + drivers/serial/s3c64xx.c | 172 ++++ drivers/usb/usb_ohci.c | 1 + include/asm-arm/arch-davinci/emac_defs.h | 4 +- include/asm-arm/arch-s3c64xx/hardware.h | 63 ++ include/common.h | 3 +- include/configs/smdk6400.h | 307 +++++++ include/s3c6400.h | 894 ++++++++++++++++++++ include/s3c64x0.h | 90 ++ lib_arm/board.c | 4 +- nand_spl/board/samsung/smdk6400/Makefile | 106 +++ .../board/samsung/smdk6400/config.mk | 44 +- .../board/samsung/smdk6400}/u-boot.lds | 17 +- net/eth.c | 4 +- 57 files changed, 4314 insertions(+), 897 deletions(-) copy board/davinci/{dv-evm => common}/Makefile (89%) create mode 100644 board/davinci/common/misc.c create mode 100644 board/davinci/common/misc.h create mode 100644 board/davinci/common/psc.c rename board/{integratorap/memsetup.S => davinci/common/psc.h} (56%) delete mode 100644 board/davinci/dv-evm/dv_board.c copy board/davinci/{dv-evm => dvevm}/Makefile (98%) rename board/davinci/{dv-evm => dvevm}/board_init.S (100%) rename board/davinci/{dv-evm => dvevm}/config.mk (100%) create mode 100644 board/davinci/dvevm/dvevm.c copy board/davinci/{dv-evm => dvevm}/u-boot.lds (100%) rename board/davinci/schmoogie/{dv_board.c => schmoogie.c} (67%) delete mode 100644 board/davinci/sonata/dv_board.c create mode 100644 board/davinci/sonata/sonata.c create mode 100644 board/samsung/smdk6400/.gitignore copy board/{davinci/dv-evm => samsung/smdk6400}/Makefile (79%) create mode 100644 board/samsung/smdk6400/config.mk create mode 100644 board/samsung/smdk6400/lowlevel_init.S create mode 100644 board/samsung/smdk6400/smdk6400.c copy board/{davinci/dv-evm/u-boot.lds => samsung/smdk6400/u-boot-nand.lds} (84%) copy {board/davinci/dv-evm => cpu/arm1176}/Makefile (69%) copy board/davinci/dv-evm/Makefile => cpu/arm1176/config.mk (50%) create mode 100644 cpu/arm1176/cpu.c copy {board/davinci/dv-evm => cpu/arm1176/s3c64xx}/Makefile (69%) copy board/davinci/dv-evm/Makefile => cpu/arm1176/s3c64xx/config.mk (50%) create mode 100644 cpu/arm1176/s3c64xx/cpu_init.S create mode 100644 cpu/arm1176/s3c64xx/interrupts.c create mode 100644 cpu/arm1176/s3c64xx/speed.c rename board/integratorcp/memsetup.S => cpu/arm1176/s3c64xx/usb.c (66%) create mode 100644 cpu/arm1176/start.S create mode 100644 drivers/mtd/nand/s3c64xx.c create mode 100644 drivers/serial/s3c64xx.c create mode 100644 include/asm-arm/arch-s3c64xx/hardware.h create mode 100644 include/configs/smdk6400.h create mode 100644 include/s3c6400.h create mode 100644 include/s3c64x0.h create mode 100644 nand_spl/board/samsung/smdk6400/Makefile rename board/davinci/dv-evm/Makefile => nand_spl/board/samsung/smdk6400/config.mk (52%) rename {board/davinci/dv-evm => nand_spl/board/samsung/smdk6400}/u-boot.lds (86%)
Best Regards, J.
Dear Jean-Christophe PLAGNIOL-VILLARD,
Applied, thanks.
Just tested on smdk6400 with the current arm/master HEAD - not good, the board just reboots somewhere near / after NAND-probe.
Thanks Guennadi --- Guennadi Liakhovetski, Ph.D.
DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-0 Fax: +49-8142-66989-80 Email: office@denx.de
