[PATCH v1 3/3] arm: dts: rockchip: rk3288: partial sync from Linux
Partial sync of rk3288.dtsi from Linux version 5.18
Changed: only properties and functions that are not yet included swap some clocks positions fix some irq numbers style and sort nodes
Signed-off-by: Johan Jonker jbx6244@gmail.com --- arch/arm/dts/rk3288-veyron-jerry.dts | 6 - arch/arm/dts/rk3288-veyron.dtsi | 4 - arch/arm/dts/rk3288.dtsi | 368 ++++++++++++++++++++++----- 3 files changed, 304 insertions(+), 74 deletions(-)
diff --git a/arch/arm/dts/rk3288-veyron-jerry.dts b/arch/arm/dts/rk3288-veyron-jerry.dts index ff7669eb..40fee55c 100644 --- a/arch/arm/dts/rk3288-veyron-jerry.dts +++ b/arch/arm/dts/rk3288-veyron-jerry.dts @@ -137,12 +137,6 @@ }; };
- edp { - edp_hpd: edp_hpd { - rockchip,pins = <7 11 RK_FUNC_2 &pcfg_pull_down>; - }; - }; - emmc { /* Make sure eMMC is not in reset */ emmc_deassert_reset: emmc-deassert-reset { diff --git a/arch/arm/dts/rk3288-veyron.dtsi b/arch/arm/dts/rk3288-veyron.dtsi index 4a9c27a4..35db8827 100644 --- a/arch/arm/dts/rk3288-veyron.dtsi +++ b/arch/arm/dts/rk3288-veyron.dtsi @@ -560,10 +560,6 @@ status = "okay"; };
-&hdmi_audio { - status = "okay"; -}; - &gpu { status = "okay"; }; diff --git a/arch/arm/dts/rk3288.dtsi b/arch/arm/dts/rk3288.dtsi index 6b03a63c..8c394c1e 100644 --- a/arch/arm/dts/rk3288.dtsi +++ b/arch/arm/dts/rk3288.dtsi @@ -15,6 +15,7 @@
interrupt-parent = <&gic>; aliases { + ethernet0 = &gmac; i2c0 = &i2c0; i2c1 = &i2c1; i2c2 = &i2c2; @@ -35,6 +36,15 @@ spi2 = &spi2; };
+ arm-pmu { + compatible = "arm,cortex-a12-pmu"; + interrupts = <GIC_SPI 151 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>; + interrupt-affinity = <&cpu0>, <&cpu1>, <&cpu2>, <&cpu3>; + }; + cpus { #address-cells = <1>; #size-cells = <0>; @@ -141,6 +151,26 @@ }; };
+ reserved-memory { + #address-cells = <1>; + #size-cells = <1>; + ranges; + + /* + * The rk3288 cannot use the memory area above 0xfe000000 + * for dma operations for some reason. While there is + * probably a better solution available somewhere, we + * haven't found it yet and while devices with 2GB of ram + * are not affected, this issue prevents 4GB from booting. + * So to make these devices at least bootable, block + * this area for the time being until the real solution + * is found. + */ + dma-unusable@fe000000 { + reg = <0xfe000000 0x1000000>; + }; + }; + xin24m: oscillator { compatible = "fixed-clock"; clock-frequency = <24000000>; @@ -149,14 +179,22 @@ };
timer { - arm,use-physical-timer; compatible = "arm,armv7-timer"; + arm,cpu-registers-not-fw-configured; interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>, <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>, <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>, <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; clock-frequency = <24000000>; - always-on; + arm,no-tick-in-suspend; + }; + + timer: timer@ff810000 { + compatible = "rockchip,rk3288-timer"; + reg = <0x0 0xff810000 0x0 0x20>; + interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru PCLK_TIMER>, <&xin24m>; + clock-names = "pclk", "timer"; };
display-subsystem { @@ -164,51 +202,59 @@ ports = <&vopl_out>, <&vopb_out>; };
- sdmmc: dwmmc@ff0c0000 { + sdmmc: mmc@ff0c0000 { compatible = "rockchip,rk3288-dw-mshc"; max-frequency = <150000000>; clocks = <&cru HCLK_SDMMC>, <&cru SCLK_SDMMC>, <&cru SCLK_SDMMC_DRV>, <&cru SCLK_SDMMC_SAMPLE>; - clock-names = "biu", "ciu", "ciu_drv", "ciu_sample"; + clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; fifo-depth = <0x100>; interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; reg = <0xff0c0000 0x4000>; + resets = <&cru SRST_MMC0>; + reset-names = "reset"; status = "disabled"; };
- sdio0: dwmmc@ff0d0000 { + sdio0: mmc@ff0d0000 { compatible = "rockchip,rk3288-dw-mshc"; max-frequency = <150000000>; clocks = <&cru HCLK_SDIO0>, <&cru SCLK_SDIO0>, <&cru SCLK_SDIO0_DRV>, <&cru SCLK_SDIO0_SAMPLE>; - clock-names = "biu", "ciu", "ciu_drv", "ciu_sample"; + clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; fifo-depth = <0x100>; interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; reg = <0xff0d0000 0x4000>; + resets = <&cru SRST_SDIO0>; + reset-names = "reset"; status = "disabled"; };
- sdio1: dwmmc@ff0e0000 { + sdio1: mmc@ff0e0000 { compatible = "rockchip,rk3288-dw-mshc"; max-frequency = <150000000>; clocks = <&cru HCLK_SDIO1>, <&cru SCLK_SDIO1>, <&cru SCLK_SDIO1_DRV>, <&cru SCLK_SDIO1_SAMPLE>; - clock-names = "biu", "ciu", "ciu_drv", "ciu_sample"; + clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; fifo-depth = <0x100>; interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>; reg = <0xff0e0000 0x4000>; + resets = <&cru SRST_SDIO1>; + reset-names = "reset"; status = "disabled"; };
- emmc: dwmmc@ff0f0000 { + emmc: mmc@ff0f0000 { compatible = "rockchip,rk3288-dw-mshc"; max-frequency = <150000000>; clocks = <&cru HCLK_EMMC>, <&cru SCLK_EMMC>, <&cru SCLK_EMMC_DRV>, <&cru SCLK_EMMC_SAMPLE>; - clock-names = "biu", "ciu", "ciu_drv", "ciu_sample"; + clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; fifo-depth = <0x100>; interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>; reg = <0xff0f0000 0x4000>; + resets = <&cru SRST_EMMC>; + reset-names = "reset"; status = "disabled"; };
@@ -219,6 +265,8 @@ #io-channel-cells = <1>; clocks = <&cru SCLK_SARADC>, <&cru PCLK_SARADC>; clock-names = "saradc", "apb_pclk"; + resets = <&cru SRST_SARADC>; + reset-names = "saradc-apb"; status = "disabled"; };
@@ -318,6 +366,7 @@ pinctrl-0 = <&i2c5_xfer>; status = "disabled"; }; + uart0: serial@ff180000 { compatible = "rockchip,rk3288-uart", "snps,dw-apb-uart"; reg = <0xff180000 0x100>; @@ -326,6 +375,8 @@ reg-io-width = <4>; clocks = <&cru SCLK_UART0>, <&cru PCLK_UART0>; clock-names = "baudclk", "apb_pclk"; + dmas = <&dmac_peri 1>, <&dmac_peri 2>; + dma-names = "tx", "rx"; pinctrl-names = "default"; pinctrl-0 = <&uart0_xfer>; status = "disabled"; @@ -339,6 +390,8 @@ reg-io-width = <4>; clocks = <&cru SCLK_UART1>, <&cru PCLK_UART1>; clock-names = "baudclk", "apb_pclk"; + dmas = <&dmac_peri 3>, <&dmac_peri 4>; + dma-names = "tx", "rx"; pinctrl-names = "default"; pinctrl-0 = <&uart1_xfer>; status = "disabled"; @@ -356,6 +409,7 @@ pinctrl-0 = <&uart2_xfer>; status = "disabled"; }; + uart3: serial@ff1b0000 { compatible = "rockchip,rk3288-uart", "snps,dw-apb-uart"; reg = <0xff1b0000 0x100>; @@ -364,6 +418,8 @@ reg-io-width = <4>; clocks = <&cru SCLK_UART3>, <&cru PCLK_UART3>; clock-names = "baudclk", "apb_pclk"; + dmas = <&dmac_peri 7>, <&dmac_peri 8>; + dma-names = "tx", "rx"; pinctrl-names = "default"; pinctrl-0 = <&uart3_xfer>; status = "disabled"; @@ -377,6 +433,8 @@ reg-io-width = <4>; clocks = <&cru SCLK_UART4>, <&cru PCLK_UART4>; clock-names = "baudclk", "apb_pclk"; + dmas = <&dmac_peri 9>, <&dmac_peri 10>; + dma-names = "tx", "rx"; pinctrl-names = "default"; pinctrl-0 = <&uart4_xfer>; status = "disabled"; @@ -388,7 +446,8 @@ interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>; #dma-cells = <1>; - broken-no-flushp; + arm,pl330-broken-no-flushp; + arm,pl330-periph-burst; clocks = <&cru ACLK_DMAC2>; clock-names = "apb_pclk"; }; @@ -503,6 +562,8 @@ "mac_clk_rx", "mac_clk_tx", "clk_mac_ref", "clk_mac_refout", "aclk_mac", "pclk_mac"; + resets = <&cru SRST_MAC>; + reset-names = "stmmaceth"; };
usb_host0_ehci: usb@ff500000 { @@ -516,7 +577,7 @@ status = "disabled"; };
- /* NOTE: doesn't work on RK3288, but fixed on RK3288W */ + /* NOTE: doesn't work on RK3288, but was fixed on RK3288W */ usb_host0_ohci: usb@ff520000 { compatible = "generic-ohci"; reg = <0x0 0xff520000 0x0 0x100>; @@ -534,8 +595,10 @@ interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru HCLK_USBHOST1>; clock-names = "otg"; + dr_mode = "host"; phys = <&usbphy2>; phy-names = "usb2-phy"; + snps,reset-phy-on-wake; status = "disabled"; };
@@ -547,6 +610,9 @@ clocks = <&cru HCLK_OTG0>; clock-names = "otg"; dr_mode = "otg"; + g-np-tx-fifo-size = <16>; + g-rx-fifo-size = <275>; + g-tx-fifo-size = <256 128 128 64 64 32>; phys = <&usbphy0>; phy-names = "usb2-phy"; status = "disabled"; @@ -567,7 +633,8 @@ interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; #dma-cells = <1>; - broken-no-flushp; + arm,pl330-broken-no-flushp; + arm,pl330-periph-burst; clocks = <&cru ACLK_DMAC1>; clock-names = "apb_pclk"; status = "disabled"; @@ -647,7 +714,7 @@ status = "disabled"; };
- bus_intmem: bus_intmem@ff700000 { + bus_intmem: sram@ff700000 { compatible = "mmio-sram"; reg = <0xff700000 0x18000>; #address-cells = <1>; @@ -659,7 +726,7 @@ }; };
- sram@ff720000 { + pmu_sram: sram@ff720000 { compatible = "rockchip,rk3288-pmu-sram", "mmio-sram"; reg = <0xff720000 0x1000>; }; @@ -701,7 +768,7 @@ compatible = "rockchip,rk3288-wdt", "snps,dw-wdt"; reg = <0xff800000 0x100>; clocks = <&cru PCLK_WDT>; - interrupts = <GIC_SPI 111 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <GIC_SPI 79 IRQ_TYPE_LEVEL_HIGH>; status = "disabled"; };
@@ -709,11 +776,11 @@ compatible = "rockchip,rk3288-spdif", "rockchip,rk3066-spdif"; reg = <0xff8b0000 0x10000>; #sound-dai-cells = <0>; - clock-names = "hclk", "mclk"; - clocks = <&cru HCLK_SPDIF8CH>, <&cru SCLK_SPDIF8CH>; + clocks = <&cru SCLK_SPDIF8CH>, <&cru HCLK_SPDIF8CH>; + clock-names = "mclk", "hclk"; dmas = <&dmac_bus_s 3>; dma-names = "tx"; - interrupts = <GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&spdif_tx>; rockchip,grf = <&grf>; @@ -723,50 +790,97 @@ i2s: i2s@ff890000 { compatible = "rockchip,rk3288-i2s", "rockchip,rk3066-i2s"; reg = <0xff890000 0x10000>; - interrupts = <GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - #sound-dai-cells = <1>; + #sound-dai-cells = <0>; + interrupts = <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru SCLK_I2S0>, <&cru HCLK_I2S0>; + clock-names = "i2s_clk", "i2s_hclk"; dmas = <&dmac_bus_s 0>, <&dmac_bus_s 1>; dma-names = "tx", "rx"; - clock-names = "i2s_hclk", "i2s_clk"; - clocks = <&cru HCLK_I2S0>, <&cru SCLK_I2S0>; pinctrl-names = "default"; pinctrl-0 = <&i2s0_bus>; + rockchip,playback-channels = <8>; + rockchip,capture-channels = <2>; + status = "disabled"; + }; + + crypto: crypto@ff8a0000 { + compatible = "rockchip,rk3288-crypto"; + reg = <0xff8a0000 0x4000>; + interrupts = <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru ACLK_CRYPTO>, <&cru HCLK_CRYPTO>, + <&cru SCLK_CRYPTO>, <&cru ACLK_DMAC1>; + clock-names = "aclk", "hclk", "sclk", "apb_pclk"; + resets = <&cru SRST_CRYPTO>; + reset-names = "crypto-rst"; + }; + + iep_mmu: iommu@ff900800 { + compatible = "rockchip,iommu"; + reg = <0xff900800 0x40>; + interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru ACLK_IEP>, <&cru HCLK_IEP>; + clock-names = "aclk", "iface"; + #iommu-cells = <0>; status = "disabled"; };
+ isp_mmu: iommu@ff914000 { + compatible = "rockchip,iommu"; + reg = <0xff914000 0x100>, <0xff915000 0x100>; + interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru ACLK_ISP>, <&cru HCLK_ISP>; + clock-names = "aclk", "iface"; + #iommu-cells = <0>; + rockchip,disable-mmu-reset; + status = "disabled"; + }; + + rga: rga@ff920000 { + compatible = "rockchip,rk3288-rga"; + reg = <0xff920000 0x180>; + interrupts = <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru ACLK_RGA>, <&cru HCLK_RGA>, <&cru SCLK_RGA>; + clock-names = "aclk", "hclk", "sclk"; + power-domains = <&power RK3288_PD_VIO>; + resets = <&cru SRST_RGA_CORE>, <&cru SRST_RGA_AXI>, <&cru SRST_RGA_AHB>; + reset-names = "core", "axi", "ahb"; + }; + vopb: vop@ff930000 { compatible = "rockchip,rk3288-vop"; reg = <0xff930000 0x19c>; interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru ACLK_VOP0>, <&cru DCLK_VOP0>, <&cru HCLK_VOP0>; clock-names = "aclk_vop", "dclk_vop", "hclk_vop"; + power-domains = <&power RK3288_PD_VIO>; resets = <&cru SRST_LCDC0_AXI>, <&cru SRST_LCDC0_AHB>, <&cru SRST_LCDC0_DCLK>; reset-names = "axi", "ahb", "dclk"; iommus = <&vopb_mmu>; - power-domains = <&power RK3288_PD_VIO>; status = "disabled"; + vopb_out: port { #address-cells = <1>; #size-cells = <0>; + vopb_out_edp: endpoint@0 { reg = <0>; remote-endpoint = <&edp_in_vopb>; }; + vopb_out_hdmi: endpoint@1 { reg = <1>; remote-endpoint = <&hdmi_in_vopb>; }; + vopb_out_lvds: endpoint@2 { reg = <2>; remote-endpoint = <&lvds_in_vopb>; }; + vopb_out_mipi: endpoint@3 { reg = <3>; remote-endpoint = <&mipi_in_vopb>; }; - }; };
@@ -774,7 +888,8 @@ compatible = "rockchip,iommu"; reg = <0xff930300 0x100>; interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "vopb_mmu"; + clocks = <&cru ACLK_VOP0>, <&cru HCLK_VOP0>; + clock-names = "aclk", "iface"; power-domains = <&power RK3288_PD_VIO>; #iommu-cells = <0>; status = "disabled"; @@ -786,31 +901,35 @@ interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru ACLK_VOP1>, <&cru DCLK_VOP1>, <&cru HCLK_VOP1>; clock-names = "aclk_vop", "dclk_vop", "hclk_vop"; + power-domains = <&power RK3288_PD_VIO>; resets = <&cru SRST_LCDC1_AXI>, <&cru SRST_LCDC1_AHB>, <&cru SRST_LCDC1_DCLK>; reset-names = "axi", "ahb", "dclk"; iommus = <&vopl_mmu>; - power-domains = <&power RK3288_PD_VIO>; status = "disabled"; + vopl_out: port { #address-cells = <1>; #size-cells = <0>; + vopl_out_edp: endpoint@0 { reg = <0>; remote-endpoint = <&edp_in_vopl>; }; + vopl_out_hdmi: endpoint@1 { reg = <1>; remote-endpoint = <&hdmi_in_vopl>; }; + vopl_out_lvds: endpoint@2 { reg = <2>; remote-endpoint = <&lvds_in_vopl>; }; + vopl_out_mipi: endpoint@3 { reg = <3>; remote-endpoint = <&mipi_in_vopl>; }; - }; };
@@ -818,7 +937,8 @@ compatible = "rockchip,iommu"; reg = <0xff940300 0x100>; interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "vopl_mmu"; + clocks = <&cru ACLK_VOP1>, <&cru HCLK_VOP1>; + clock-names = "aclk", "iface"; power-domains = <&power RK3288_PD_VIO>; #iommu-cells = <0>; status = "disabled"; @@ -827,16 +947,14 @@ mipi_dsi: mipi@ff960000 { compatible = "rockchip,rk3288_mipi_dsi"; reg = <0xff960000 0x4000>; + interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru PCLK_MIPI_DSI0>; clock-names = "pclk_mipi"; - /*pinctrl-names = "default"; - pinctrl-0 = <&lcdc0_ctl>;*/ + power-domains = <&power RK3288_PD_VIO>; rockchip,grf = <&grf>; - #address-cells = <1>; - #size-cells = <0>; status = "disabled"; + ports { - reg = <1>; mipi_in: port { #address-cells = <1>; #size-cells = <0>; @@ -858,16 +976,21 @@ clocks = <&cru PCLK_LVDS_PHY>; clock-names = "pclk_lvds"; pinctrl-names = "default"; - pinctrl-0 = <&lcdc0_ctl>; + pinctrl-0 = <&lcdc_ctl>; + power-domains = <&power RK3288_PD_VIO>; rockchip,grf = <&grf>; status = "disabled"; + ports { #address-cells = <1>; #size-cells = <0>; + lvds_in: port@0 { reg = <0>; + #address-cells = <1>; #size-cells = <0>; + lvds_in_vopb: endpoint@0 { reg = <0>; remote-endpoint = <&vopb_out_lvds>; @@ -885,12 +1008,13 @@ reg = <0xff970000 0x4000>; interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru SCLK_EDP>, <&cru SCLK_EDP_24M>, <&cru PCLK_EDP_CTRL>; - rockchip,grf = <&grf>; clock-names = "clk_edp", "clk_edp_24m", "pclk_edp"; - resets = <&cru 111>; + resets = <&cru SRST_EDP>; reset-names = "edp"; + rockchip,grf = <&grf>; power-domains = <&power RK3288_PD_VIO>; status = "disabled"; + ports { edp_in: port { #address-cells = <1>; @@ -911,12 +1035,14 @@ compatible = "rockchip,rk3288-dw-hdmi"; reg = <0xff980000 0x20000>; reg-io-width = <4>; - ddc-i2c-bus = <&i2c5>; + #sound-dai-cells = <0>; rockchip,grf = <&grf>; interrupts = <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru PCLK_HDMI_CTRL>, <&cru SCLK_HDMI_HDCP>; clock-names = "iahb", "isfr"; + power-domains = <&power RK3288_PD_VIO>; status = "disabled"; + ports { hdmi_in: port { #address-cells = <1>; @@ -933,31 +1059,36 @@ }; };
- hdmi_audio: hdmi_audio { - compatible = "rockchip,rk3288-hdmi-audio"; - i2s-controller = <&i2s>; - status = "disable"; - }; - vpu: video-codec@ff9a0000 { compatible = "rockchip,rk3288-vpu"; reg = <0xff9a0000 0x800>; interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; + <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "vepu", "vdpu"; clocks = <&cru ACLK_VCODEC>, <&cru HCLK_VCODEC>; - clock-names = "aclk_vcodec", "hclk_vcodec"; - power-domains = <&power RK3288_PD_VIDEO>; + clock-names = "aclk", "hclk"; iommus = <&vpu_mmu>; + power-domains = <&power RK3288_PD_VIDEO>; };
vpu_mmu: iommu@ff9a0800 { compatible = "rockchip,iommu"; reg = <0xff9a0800 0x100>; interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "vpu_mmu"; + clocks = <&cru ACLK_VCODEC>, <&cru HCLK_VCODEC>; + clock-names = "aclk", "iface"; + #iommu-cells = <0>; power-domains = <&power RK3288_PD_VIDEO>; + }; + + hevc_mmu: iommu@ff9c0440 { + compatible = "rockchip,iommu"; + reg = <0xff9c0440 0x40>, <0xff9c0480 0x40>; + interrupts = <GIC_SPI 111 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru ACLK_HEVC>, <&cru HCLK_HEVC>; + clock-names = "aclk", "iface"; #iommu-cells = <0>; + status = "disabled"; };
gpu: gpu@ffa30000 { @@ -999,13 +1130,84 @@ }; };
+ qos_gpu_r: qos@ffaa0000 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0xffaa0000 0x20>; + }; + + qos_gpu_w: qos@ffaa0080 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0xffaa0080 0x20>; + }; + + qos_vio1_vop: qos@ffad0000 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0xffad0000 0x20>; + }; + + qos_vio1_isp_w0: qos@ffad0100 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0xffad0100 0x20>; + }; + + qos_vio1_isp_w1: qos@ffad0180 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0x0 0xffad0180 0x0 0x20>; + }; + + qos_vio0_vop: qos@ffad0400 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0x0 0xffad0400 0x0 0x20>; + }; + + qos_vio0_vip: qos@ffad0480 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0xffad0480 0x20>; + }; + + qos_vio0_iep: qos@ffad0500 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0xffad0500 0x20>; + }; + + qos_vio2_rga_r: qos@ffad0800 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0xffad0800 0x20>; + }; + + qos_vio2_rga_w: qos@ffad0880 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0xffad0880 0x20>; + }; + + qos_vio1_isp_r: qos@ffad0900 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0xffad0900 0x20>; + }; + + qos_video: qos@ffae0000 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0xffae0000 0x20>; + }; + + qos_hevc_r: qos@ffaf0000 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0xffaf0000 0x20>; + }; + + qos_hevc_w: qos@ffaf0080 { + compatible = "rockchip,rk3288-qos", "syscon"; + reg = <0xffaf0080 0x20>; + }; + dmac_bus_s: dma-controller@ffb20000 { compatible = "arm,pl330", "arm,primecell"; reg = <0xffb20000 0x4000>; interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; #dma-cells = <1>; - broken-no-flushp; + arm,pl330-broken-no-flushp; + arm,pl330-periph-burst; clocks = <&cru ACLK_DMAC1>; clock-names = "apb_pclk"; }; @@ -1013,7 +1215,17 @@ efuse: efuse@ffb40000 { compatible = "rockchip,rk3288-efuse"; reg = <0xffb40000 0x10000>; - status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + clocks = <&cru PCLK_EFUSE256>; + clock-names = "pclk_efuse"; + + cpu_id: cpu-id@7 { + reg = <0x07 0x10>; + }; + cpu_leakage: cpu_leakage@17 { + reg = <0x17 0x1>; + }; };
gic: interrupt-controller@ffc01000 { @@ -1072,7 +1284,7 @@
gpio0: gpio0@ff750000 { compatible = "rockchip,gpio-bank"; - reg = <0xff750000 0x100>; + reg = <0xff750000 0x100>; interrupts = <GIC_SPI 81 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru PCLK_GPIO0>;
@@ -1191,6 +1403,24 @@ hdmi_cec_c0: hdmi-cec-c0 { rockchip,pins = <7 RK_PC0 2 &pcfg_pull_none>; }; + + hdmi_cec_c7: hdmi-cec-c7 { + rockchip,pins = <7 RK_PC7 4 &pcfg_pull_none>; + }; + + hdmi_ddc: hdmi-ddc { + rockchip,pins = <7 RK_PC3 2 &pcfg_pull_none>, + <7 RK_PC4 2 &pcfg_pull_none>; + }; + + hdmi_ddc_unwedge: hdmi-ddc-unwedge { + rockchip,pins = <7 RK_PC3 RK_FUNC_GPIO &pcfg_output_low>, + <7 RK_PC4 2 &pcfg_pull_none>; + }; + }; + + pcfg_output_low: pcfg-output-low { + output-low; };
pcfg_pull_up: pcfg-pull-up { @@ -1210,7 +1440,7 @@ drive-strength = <12>; };
- sleep { + suspend { global_pwroff: global-pwroff { rockchip,pins = <0 RK_PA0 1 &pcfg_pull_none>; }; @@ -1228,6 +1458,12 @@ }; };
+ edp { + edp_hpd: edp-hpd { + rockchip,pins = <7 RK_PB3 2 &pcfg_pull_down>; + }; + }; + i2c0 { i2c0_xfer: i2c0-xfer { rockchip,pins = <0 RK_PB7 1 &pcfg_pull_none>, @@ -1281,8 +1517,8 @@ }; };
- lcdc0 { - lcdc0_ctl: lcdc0-ctl { + lcdc { + lcdc_ctl: lcdc-ctl { rockchip,pins = <1 RK_PD0 1 &pcfg_pull_none>, <1 RK_PD1 1 &pcfg_pull_none>, <1 RK_PD2 1 &pcfg_pull_none>, @@ -1299,7 +1535,7 @@ rockchip,pins = <6 RK_PC5 1 &pcfg_pull_up>; };
- sdmmc_cd: sdmcc-cd { + sdmmc_cd: sdmmc-cd { rockchip,pins = <6 RK_PC6 1 &pcfg_pull_up>; };
@@ -1490,7 +1726,7 @@ };
uart0_cts: uart0-cts { - rockchip,pins = <4 RK_PC2 1 &pcfg_pull_none>; + rockchip,pins = <4 RK_PC2 1 &pcfg_pull_up>; };
uart0_rts: uart0-rts { @@ -1505,7 +1741,7 @@ };
uart1_cts: uart1-cts { - rockchip,pins = <5 RK_PB2 1 &pcfg_pull_none>; + rockchip,pins = <5 RK_PB2 1 &pcfg_pull_up>; };
uart1_rts: uart1-rts { @@ -1528,7 +1764,7 @@ };
uart3_cts: uart3-cts { - rockchip,pins = <7 RK_PB1 1 &pcfg_pull_none>; + rockchip,pins = <7 RK_PB1 1 &pcfg_pull_up>; };
uart3_rts: uart3-rts { @@ -1538,20 +1774,24 @@
uart4 { uart4_xfer: uart4-xfer { - rockchip,pins = <5 RK_PB4 3 &pcfg_pull_up>, - <5 RK_PB5 3 &pcfg_pull_none>; + rockchip,pins = <5 RK_PB7 3 &pcfg_pull_up>, + <5 RK_PB6 3 &pcfg_pull_none>; };
uart4_cts: uart4-cts { - rockchip,pins = <5 RK_PB6 3 &pcfg_pull_none>; + rockchip,pins = <5 RK_PB4 3 &pcfg_pull_up>; };
uart4_rts: uart4-rts { - rockchip,pins = <5 RK_PB7 3 &pcfg_pull_none>; + rockchip,pins = <5 RK_PB5 3 &pcfg_pull_none>; }; };
tsadc { + otp_pin: otp-pin { + rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + otp_out: otp-out { rockchip,pins = <0 RK_PB2 1 &pcfg_pull_none>; };
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- edp {
edp_hpd: edp_hpd {
-&hdmi_audio {
- status = "okay";
i2c0 = &i2c0; i2c1 = &i2c1; i2c2 = &i2c2;ethernet0 = &gmac;
- arm-pmu {
- cpus { #address-cells = <1>; #size-cells = <0>;
- reserved-memory {
#size-cells = <1>;
ranges;
* is found.
- xin24m: oscillator { compatible = "fixed-clock"; clock-frequency = <24000000>;
timer {
compatible = "arm,armv7-timer";arm,use-physical-timer;
interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>, <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>, <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>, <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; clock-frequency = <24000000>;arm,cpu-registers-not-fw-configured;
always-on;
display-subsystem {
- sdmmc: mmc@ff0c0000 { compatible = "rockchip,rk3288-dw-mshc"; max-frequency = <150000000>; clocks = <&cru HCLK_SDMMC>, <&cru SCLK_SDMMC>, <&cru SCLK_SDMMC_DRV>, <&cru SCLK_SDMMC_SAMPLE>;
fifo-depth = <0x100>; interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; reg = <0xff0c0000 0x4000>;clock-names = "biu", "ciu", "ciu-drive", "ciu-sample";
status = "disabled"; };reset-names = "reset";
- sdio0: mmc@ff0d0000 { compatible = "rockchip,rk3288-dw-mshc"; max-frequency = <150000000>; clocks = <&cru HCLK_SDIO0>, <&cru SCLK_SDIO0>, <&cru SCLK_SDIO0_DRV>, <&cru SCLK_SDIO0_SAMPLE>;
fifo-depth = <0x100>; interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; reg = <0xff0d0000 0x4000>;clock-names = "biu", "ciu", "ciu-drive", "ciu-sample";
- sdio1: mmc@ff0e0000 { compatible = "rockchip,rk3288-dw-mshc"; max-frequency = <150000000>; clocks = <&cru HCLK_SDIO1>, <&cru SCLK_SDIO1>, <&cru SCLK_SDIO1_DRV>, <&cru SCLK_SDIO1_SAMPLE>;
fifo-depth = <0x100>; interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>; reg = <0xff0e0000 0x4000>;clock-names = "biu", "ciu", "ciu-drive", "ciu-sample";
- emmc: mmc@ff0f0000 { compatible = "rockchip,rk3288-dw-mshc"; max-frequency = <150000000>; clocks = <&cru HCLK_EMMC>, <&cru SCLK_EMMC>, <&cru SCLK_EMMC_DRV>, <&cru SCLK_EMMC_SAMPLE>;
fifo-depth = <0x100>; interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>; reg = <0xff0f0000 0x4000>;clock-names = "biu", "ciu", "ciu-drive", "ciu-sample";
status = "disabled"; };reset-names = "saradc-apb";
- uart0: serial@ff180000 { compatible = "rockchip,rk3288-uart", "snps,dw-apb-uart"; reg = <0xff180000 0x100>;
pinctrl-names = "default"; pinctrl-0 = <&uart0_xfer>; status = "disabled";dma-names = "tx", "rx";
pinctrl-names = "default"; pinctrl-0 = <&uart1_xfer>; status = "disabled";dma-names = "tx", "rx";
- uart3: serial@ff1b0000 { compatible = "rockchip,rk3288-uart", "snps,dw-apb-uart"; reg = <0xff1b0000 0x100>;
pinctrl-names = "default"; pinctrl-0 = <&uart3_xfer>; status = "disabled";dma-names = "tx", "rx";
pinctrl-names = "default"; pinctrl-0 = <&uart4_xfer>; status = "disabled";dma-names = "tx", "rx";
broken-no-flushp;
clocks = <&cru ACLK_DMAC2>; clock-names = "apb_pclk"; };arm,pl330-periph-burst;
- /* NOTE: doesn't work on RK3288, but was fixed on RK3288W */ usb_host0_ohci: usb@ff520000 { compatible = "generic-ohci"; reg = <0x0 0xff520000 0x0 0x100>;
phys = <&usbphy2>; phy-names = "usb2-phy";dr_mode = "host";
status = "disabled"; };snps,reset-phy-on-wake;
phys = <&usbphy0>; phy-names = "usb2-phy"; status = "disabled";g-tx-fifo-size = <256 128 128 64 64 32>;
broken-no-flushp;
clocks = <&cru ACLK_DMAC1>; clock-names = "apb_pclk"; status = "disabled";arm,pl330-periph-burst;
- bus_intmem: sram@ff700000 { compatible = "mmio-sram"; reg = <0xff700000 0x18000>; #address-cells = <1>;
- sram@ff720000 {
- pmu_sram: sram@ff720000 { compatible = "rockchip,rk3288-pmu-sram", "mmio-sram"; reg = <0xff720000 0x1000>; };
status = "disabled"; };interrupts = <GIC_SPI 79 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&dmac_bus_s 3>; dma-names = "tx";clock-names = "mclk", "hclk";
pinctrl-names = "default"; pinctrl-0 = <&spdif_tx>; rockchip,grf = <&grf>;interrupts = <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
dmas = <&dmac_bus_s 0>, <&dmac_bus_s 1>; dma-names = "tx", "rx";clock-names = "i2s_clk", "i2s_hclk";
pinctrl-names = "default"; pinctrl-0 = <&i2s0_bus>;clocks = <&cru HCLK_I2S0>, <&cru SCLK_I2S0>;
#iommu-cells = <0>;
#iommu-cells = <0>;
rga: rga@ff920000 {
status = "disabled";power-domains = <&power RK3288_PD_VIO>;
- vopb_out: port { #address-cells = <1>; #size-cells = <0>;
power-domains = <&power RK3288_PD_VIO>; #iommu-cells = <0>; status = "disabled";clock-names = "aclk", "iface";
resets = <&cru SRST_LCDC1_AXI>, <&cru SRST_LCDC1_AHB>, <&cru SRST_LCDC1_DCLK>; reset-names = "axi", "ahb", "dclk"; iommus = <&vopl_mmu>;power-domains = <&power RK3288_PD_VIO>;
- vopl_out: port { #address-cells = <1>; #size-cells = <0>;
clocks = <&cru PCLK_MIPI_DSI0>; clock-names = "pclk_mipi";interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>;
rockchip,grf = <&grf>;power-domains = <&power RK3288_PD_VIO>;
status = "disabled";#size-cells = <0>;
- ports {
rockchip,grf = <&grf>; status = "disabled";power-domains = <&power RK3288_PD_VIO>;
- ports { #address-cells = <1>; #size-cells = <0>;
clock-names = "clk_edp", "clk_edp_24m", "pclk_edp";rockchip,grf = <&grf>;
reset-names = "edp";resets = <&cru SRST_EDP>;
power-domains = <&power RK3288_PD_VIO>; status = "disabled";rockchip,grf = <&grf>;
- ports { edp_in: port { #address-cells = <1>;
rockchip,grf = <&grf>; interrupts = <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru PCLK_HDMI_CTRL>, <&cru SCLK_HDMI_HDCP>; clock-names = "iahb", "isfr";#sound-dai-cells = <0>;
- ports { hdmi_in: port { #address-cells = <1>;
status = "disable";
interrupt-names = "vepu", "vdpu"; clocks = <&cru ACLK_VCODEC>, <&cru HCLK_VCODEC>;<GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>;
#iommu-cells = <0>;
#iommu-cells = <0>;
gpu: gpu@ffa30000 {
- qos_gpu_r: qos@ffaa0000 {
- qos_gpu_w: qos@ffaa0080 {
- qos_vio1_vop: qos@ffad0000 {
- qos_vio1_isp_w0: qos@ffad0100 {
- qos_vio1_isp_w1: qos@ffad0180 {
- qos_vio0_vop: qos@ffad0400 {
- qos_vio0_vip: qos@ffad0480 {
- qos_vio0_iep: qos@ffad0500 {
- qos_vio2_rga_r: qos@ffad0800 {
- qos_vio2_rga_w: qos@ffad0880 {
- qos_vio1_isp_r: qos@ffad0900 {
- qos_video: qos@ffae0000 {
- qos_hevc_r: qos@ffaf0000 {
- qos_hevc_w: qos@ffaf0080 {
- dmac_bus_s: dma-controller@ffb20000 { compatible = "arm,pl330", "arm,primecell"; reg = <0xffb20000 0x4000>; interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; #dma-cells = <1>;
broken-no-flushp;
clocks = <&cru ACLK_DMAC1>; clock-names = "apb_pclk"; };arm,pl330-periph-burst;
#size-cells = <1>;
cpu_id: cpu-id@7 {
reg = <0x07 0x10>;
reg = <0x17 0x1>;
output-low;
sleep {
edp {
edp_hpd: edp-hpd {
- i2c0 { i2c0_xfer: i2c0-xfer { rockchip,pins = <0 RK_PB7 1 &pcfg_pull_none>,
lcdc0 {
lcdc {
rockchip,pins = <4 RK_PC2 1 &pcfg_pull_up>; }; uart0_rts: uart0-rts {
rockchip,pins = <5 RK_PB2 1 &pcfg_pull_up>; }; uart1_rts: uart1-rts {
rockchip,pins = <7 RK_PB1 1 &pcfg_pull_up>; }; uart3_rts: uart3-rts {
<5 RK_PB6 3 &pcfg_pull_none>; }; uart4_cts: uart4-cts {
rockchip,pins = <5 RK_PB4 3 &pcfg_pull_up>; }; uart4_rts: uart4-rts {
tsadc {
otp_pin: otp-pin {
Johan Jonker
Kever Yang
