[U-Boot] pre_probe under struct driver
Hi Simon/Tom,
I am looking at the device_probe function in drivers/core/device.c
ret = uclass_pre_probe_device(dev); if (ret) goto fail;
if (dev->parent && dev->parent->driver->child_pre_probe) { ret = dev->parent->driver->child_pre_probe(dev); if (ret) goto fail; }
if (drv->ofdata_to_platdata && dev_has_of_node(dev)) { ret = drv->ofdata_to_platdata(dev); if (ret) goto fail; }
/* Process 'assigned-{clocks/clock-parents/clock-rates}' properties */ ret = clk_set_defaults(dev);
In case of a device like MPU we would like setup voltage before setting the clocks and i was looking if we can have a pre_probe for a driver to do things before driver gets probed. Neither uclass_pre_probe_device nor dev->parent->driver->child_pre_probe benefit me in this case.
Does my situation warrant adding a new hook to struct driver? Or are there instances of such handling already in u-boot.
Thanks in Advance, Keerthy
Hi Keerthy,
On Tue, 4 Jun 2019 at 14:01, Keerthy j-keerthy@ti.com wrote:
Hi Simon/Tom,
if (dev->parent && dev->parent->driver->child_pre_probe) { ret = dev->parent->driver->child_pre_probe(dev); if (ret) goto fail; } if (drv->ofdata_to_platdata && dev_has_of_node(dev)) { ret = drv->ofdata_to_platdata(dev); if (ret) goto fail; } /* Process 'assigned-{clocks/clock-parents/clock-rates}'
For now, is it enough to probe the power driver from the clock driver?
On 23/06/19 12:40 AM, Simon Glass wrote:
Hi Keerthy,
Hi Simon/Tom,
Simon,
Thanks for your response. We came up with clock driver notifying the voltage driver before changing the frequency. So this particular case is resolved with it.
- Keerthy
Keerthy
