[U-Boot] [PATCH] ppc4xx: Fix 440EPx bug in reconfigure_pll()
This patch fixes a bug in reconfigure_pll(), where the detection of the current bootstrap option is wrong. The ICS bits where incorrectly shifted. This bug was found on the lwmon5 board, which uses bootstrap option H (I2C bootstrap EEPROM).
Additionally a bit of code was moved into the if statement, since its only used after later on. No need to run this code all the time.
Also, a few empty lines are added to make the code better readable.
Signed-off-by: Stefan Roese sr@denx.de Cc: Rupjyoti Sarmah rsarmah@amcc.com Cc: Victor Gallardo vgallardo@appliedmicro.com --- arch/powerpc/cpu/ppc4xx/cpu_init.c | 27 ++++++++++++++++++--------- include/ppc440.h | 1 + 2 files changed, 19 insertions(+), 9 deletions(-)
diff --git a/arch/powerpc/cpu/ppc4xx/cpu_init.c b/arch/powerpc/cpu/ppc4xx/cpu_init.c index c04eede..b31bd0b 100644 --- a/arch/powerpc/cpu/ppc4xx/cpu_init.c +++ b/arch/powerpc/cpu/ppc4xx/cpu_init.c @@ -142,22 +142,28 @@ void reconfigure_pll(u32 new_cpu_freq) * modify it. */ if (temp == 1) { - mfcpr(CPR0_PLLD, reg); - /* Get current value of fbdv. */ - temp = (reg & PLLD_FBDV_MASK) >> 24; - fbdv = temp ? temp : 32; - /* Get current value of lfbdv. */ - temp = (reg & PLLD_LFBDV_MASK); - lfbdv = temp ? temp : 64; /* * Load register that contains current boot strapping option. */ mfcpr(CPR0_ICFG, reg); - /* Shift strapping option into low 3 bits.*/ - reg = (reg >> 28); + /* + * Strapping option bits (ICS) are already in correct position, + * only masking needed. + */ + reg &= CPR0_ICFG_ICS_MASK;
if ((reg == BOOT_STRAP_OPTION_A) || (reg == BOOT_STRAP_OPTION_B) || (reg == BOOT_STRAP_OPTION_D) || (reg == BOOT_STRAP_OPTION_E)) { + mfcpr(CPR0_PLLD, reg); + + /* Get current value of fbdv. */ + temp = (reg & PLLD_FBDV_MASK) >> 24; + fbdv = temp ? temp : 32; + + /* Get current value of lfbdv. */ + temp = (reg & PLLD_LFBDV_MASK); + lfbdv = temp ? temp : 64; + /* * Get current value of FWDVA. Assign current FWDVA to * new FWDVB. @@ -165,12 +171,14 @@ void reconfigure_pll(u32 new_cpu_freq) mfcpr(CPR0_PLLD, reg); target_fwdvb = (reg & PLLD_FWDVA_MASK) >> 16; fwdvb = target_fwdvb ? target_fwdvb : 8; + /* * Get current value of FWDVB. Assign current FWDVB to * new FWDVA. */ target_fwdva = (reg & PLLD_FWDVB_MASK) >> 8; fwdva = target_fwdva ? target_fwdva : 16; + /* * Update CPR0_PLLD with switched FWDVA and FWDVB. */ @@ -181,6 +189,7 @@ void reconfigure_pll(u32 new_cpu_freq) ((fbdv == 32 ? 0 : fbdv) << 24) | (lfbdv == 64 ? 0 : lfbdv); mtcpr(CPR0_PLLD, reg); + /* Acknowledge that a reset is required. */ reset_needed = 1; } diff --git a/include/ppc440.h b/include/ppc440.h index c807dda..6727753 100644 --- a/include/ppc440.h +++ b/include/ppc440.h @@ -1711,6 +1711,7 @@ #if defined(CONFIG_440EP) || defined(CONFIG_440GR) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) #define CPR0_ICFG_RLI_MASK 0x80000000 +#define CPR0_ICFG_ICS_MASK 0x00000007 #define CPR0_SPCID_SPCIDV0_MASK 0x03000000 #define CPR0_SPCID_SPCIDV0_DIV1 0x01000000 #define CPR0_SPCID_SPCIDV0_DIV2 0x02000000
Hi Stefan,
Look good to me.
-Victor Gallardo
Applied to u-boot-ppc4xx/master. Thanks.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Stefan Roese
Victor Gallardo
