[PATCH] imx: power-domain: Add i.MX8MP support
Add i.MX8MP power domain handling into the driver. This is based on the Linux GPCv2 driver state which is soon to be in Linux next.
Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam festevam@gmail.com Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de --- drivers/power/domain/imx8m-power-domain.c | 79 +++++++++++++++++++++++ include/dt-bindings/power/imx8mp-power.h | 46 +++++++++++++ 2 files changed, 125 insertions(+) create mode 100644 include/dt-bindings/power/imx8mp-power.h
diff --git a/drivers/power/domain/imx8m-power-domain.c b/drivers/power/domain/imx8m-power-domain.c index e2e41cf5fee..145f6ec0cd3 100644 --- a/drivers/power/domain/imx8m-power-domain.c +++ b/drivers/power/domain/imx8m-power-domain.c @@ -20,11 +20,13 @@
#include <dt-bindings/power/imx8mm-power.h> #include <dt-bindings/power/imx8mn-power.h> +#include <dt-bindings/power/imx8mp-power.h> #include <dt-bindings/power/imx8mq-power.h>
DECLARE_GLOBAL_DATA_PTR;
#define GPC_PGC_CPU_MAPPING 0x0ec +#define IMX8MP_GPC_PGC_CPU_MAPPING 0x1cc
#define IMX8M_PCIE2_A53_DOMAIN BIT(15) #define IMX8M_OTG2_A53_DOMAIN BIT(5) @@ -38,6 +40,14 @@ DECLARE_GLOBAL_DATA_PTR; #define IMX8MN_OTG1_A53_DOMAIN BIT(4) #define IMX8MN_MIPI_A53_DOMAIN BIT(2)
+#define IMX8MP_HSIOMIX_A53_DOMAIN BIT(19) +#define IMX8MP_USB2_PHY_A53_DOMAIN BIT(5) +#define IMX8MP_USB1_PHY_A53_DOMAIN BIT(4) +#define IMX8MP_PCIE_PHY_A53_DOMAIN BIT(3) + +#define IMX8MP_GPC_PU_PGC_SW_PUP_REQ 0x0d8 +#define IMX8MP_GPC_PU_PGC_SW_PDN_REQ 0x0e4 + #define GPC_PU_PGC_SW_PUP_REQ 0x0f8 #define GPC_PU_PGC_SW_PDN_REQ 0x104
@@ -53,8 +63,14 @@ DECLARE_GLOBAL_DATA_PTR; #define IMX8MN_OTG1_SW_Pxx_REQ BIT(2) #define IMX8MN_MIPI_SW_Pxx_REQ BIT(0)
+#define IMX8MP_HSIOMIX_Pxx_REQ BIT(17) +#define IMX8MP_USB2_PHY_Pxx_REQ BIT(3) +#define IMX8MP_USB1_PHY_Pxx_REQ BIT(2) +#define IMX8MP_PCIE_PHY_SW_Pxx_REQ BIT(1) + #define GPC_M4_PU_PDN_FLG 0x1bc
+#define IMX8MP_GPC_PU_PWRHSK 0x190 #define GPC_PU_PWRHSK 0x1fc
#define IMX8MM_HSIO_HSK_PWRDNACKN (BIT(23) | BIT(24)) @@ -63,6 +79,9 @@ DECLARE_GLOBAL_DATA_PTR; #define IMX8MN_HSIO_HSK_PWRDNACKN BIT(23) #define IMX8MN_HSIO_HSK_PWRDNREQN BIT(5)
+#define IMX8MP_HSIOMIX_PWRDNACKN BIT(28) +#define IMX8MP_HSIOMIX_PWRDNREQN BIT(12) + /* * The PGC offset values in Reference Manual * (Rev. 1, 01/2018 and the older ones) GPC chapter's @@ -80,6 +99,11 @@ DECLARE_GLOBAL_DATA_PTR;
#define IMX8MN_PGC_OTG1 18
+#define IMX8MP_PGC_PCIE 13 +#define IMX8MP_PGC_USB1 14 +#define IMX8MP_PGC_USB2 15 +#define IMX8MP_PGC_HSIOMIX 29 + #define GPC_PGC_CTRL(n) (0x800 + (n) * 0x40) #define GPC_PGC_SR(n) (GPC_PGC_CTRL(n) + 0xc)
@@ -244,6 +268,58 @@ static const struct imx_pgc_domain_data imx8mn_pgc_domain_data = { }; #endif
+#ifdef CONFIG_IMX8MP +static const struct imx_pgc_domain imx8mp_pgc_domains[] = { + [IMX8MP_POWER_DOMAIN_PCIE_PHY] = { + .bits = { + .pxx = IMX8MP_PCIE_PHY_SW_Pxx_REQ, + .map = IMX8MP_PCIE_PHY_A53_DOMAIN, + }, + .pgc = BIT(IMX8MP_PGC_PCIE), + }, + + [IMX8MP_POWER_DOMAIN_USB1_PHY] = { + .bits = { + .pxx = IMX8MP_USB1_PHY_Pxx_REQ, + .map = IMX8MP_USB1_PHY_A53_DOMAIN, + }, + .pgc = BIT(IMX8MP_PGC_USB1), + }, + + [IMX8MP_POWER_DOMAIN_USB2_PHY] = { + .bits = { + .pxx = IMX8MP_USB2_PHY_Pxx_REQ, + .map = IMX8MP_USB2_PHY_A53_DOMAIN, + }, + .pgc = BIT(IMX8MP_PGC_USB2), + }, + + [IMX8MP_POWER_DOMAIN_HSIOMIX] = { + .bits = { + .pxx = IMX8MP_HSIOMIX_Pxx_REQ, + .map = IMX8MP_HSIOMIX_A53_DOMAIN, + .hskreq = IMX8MP_HSIOMIX_PWRDNREQN, + .hskack = IMX8MP_HSIOMIX_PWRDNACKN, + }, + .pgc = BIT(IMX8MP_PGC_HSIOMIX), + .keep_clocks = true, + }, +}; + +static const struct imx_pgc_regs imx8mp_pgc_regs = { + .map = IMX8MP_GPC_PGC_CPU_MAPPING, + .pup = IMX8MP_GPC_PU_PGC_SW_PUP_REQ, + .pdn = IMX8MP_GPC_PU_PGC_SW_PDN_REQ, + .hsk = IMX8MP_GPC_PU_PWRHSK, +}; + +static const struct imx_pgc_domain_data imx8mp_pgc_domain_data = { + .domains = imx8mp_pgc_domains, + .domains_num = ARRAY_SIZE(imx8mp_pgc_domains), + .pgc_regs = &imx8mp_pgc_regs, +}; +#endif + static int imx8m_power_domain_on(struct power_domain *power_domain) { struct udevice *dev = power_domain->dev; @@ -457,6 +533,9 @@ static const struct udevice_id imx8m_power_domain_ids[] = { #endif #ifdef CONFIG_IMX8MN { .compatible = "fsl,imx8mn-gpc", .data = (long)&imx8mn_pgc_domain_data }, +#endif +#ifdef CONFIG_IMX8MP + { .compatible = "fsl,imx8mp-gpc", .data = (long)&imx8mp_pgc_domain_data }, #endif { } }; diff --git a/include/dt-bindings/power/imx8mp-power.h b/include/dt-bindings/power/imx8mp-power.h new file mode 100644 index 00000000000..3f72bf7818f --- /dev/null +++ b/include/dt-bindings/power/imx8mp-power.h @@ -0,0 +1,46 @@ +/* SPDX-License-Identifier: (GPL-2.0 OR MIT) */ +/* + * Copyright (C) 2020 Pengutronix, Sascha Hauer kernel@pengutronix.de + */ + +#ifndef __DT_BINDINGS_IMX8MP_POWER_DOMAIN_POWER_H__ +#define __DT_BINDINGS_IMX8MP_POWER_DOMAIN_POWER_H__ + +#define IMX8MP_POWER_DOMAIN_MIPI_PHY1 0 +#define IMX8MP_POWER_DOMAIN_PCIE_PHY 1 +#define IMX8MP_POWER_DOMAIN_USB1_PHY 2 +#define IMX8MP_POWER_DOMAIN_USB2_PHY 3 +#define IMX8MP_POWER_DOMAIN_MLMIX 4 +#define IMX8MP_POWER_DOMAIN_AUDIOMIX 5 +#define IMX8MP_POWER_DOMAIN_GPU2D 6 +#define IMX8MP_POWER_DOMAIN_GPUMIX 7 +#define IMX8MP_POWER_DOMAIN_VPUMIX 8 +#define IMX8MP_POWER_DOMAIN_GPU3D 9 +#define IMX8MP_POWER_DOMAIN_MEDIAMIX 10 +#define IMX8MP_POWER_DOMAIN_VPU_G1 11 +#define IMX8MP_POWER_DOMAIN_VPU_G2 12 +#define IMX8MP_POWER_DOMAIN_VPU_VC8000E 13 +#define IMX8MP_POWER_DOMAIN_HDMIMIX 14 +#define IMX8MP_POWER_DOMAIN_HDMI_PHY 15 +#define IMX8MP_POWER_DOMAIN_MIPI_PHY2 16 +#define IMX8MP_POWER_DOMAIN_HSIOMIX 17 +#define IMX8MP_POWER_DOMAIN_MEDIAMIX_ISPDWP 18 + +#define IMX8MP_HSIOBLK_PD_USB 0 +#define IMX8MP_HSIOBLK_PD_USB_PHY1 1 +#define IMX8MP_HSIOBLK_PD_USB_PHY2 2 +#define IMX8MP_HSIOBLK_PD_PCIE 3 +#define IMX8MP_HSIOBLK_PD_PCIE_PHY 4 + +#define IMX8MP_MEDIABLK_PD_MIPI_DSI_1 0 +#define IMX8MP_MEDIABLK_PD_MIPI_CSI2_1 1 +#define IMX8MP_MEDIABLK_PD_LCDIF_1 2 +#define IMX8MP_MEDIABLK_PD_ISI 3 +#define IMX8MP_MEDIABLK_PD_MIPI_CSI2_2 4 +#define IMX8MP_MEDIABLK_PD_LCDIF_2 5 +#define IMX8MP_MEDIABLK_PD_ISP2 6 +#define IMX8MP_MEDIABLK_PD_ISP1 7 +#define IMX8MP_MEDIABLK_PD_DWE 8 +#define IMX8MP_MEDIABLK_PD_MIPI_DSI_2 9 + +#endif
Do we really need this in U-Boot? You will also port the blk-ctrl part? That would be lots code!
Thanks, Peng.
- #define GPC_PU_PGC_SW_PUP_REQ 0x0f8 #define GPC_PU_PGC_SW_PDN_REQ 0x104
- #define GPC_M4_PU_PDN_FLG 0x1bc
- The PGC offset values in Reference Manual
- (Rev. 1, 01/2018 and the older ones) GPC chapter's
- #define GPC_PGC_CTRL(n) (0x800 + (n) * 0x40) #define GPC_PGC_SR(n) (GPC_PGC_CTRL(n) + 0xc)
- [IMX8MP_POWER_DOMAIN_PCIE_PHY] = {
.bits = {
- [IMX8MP_POWER_DOMAIN_USB1_PHY] = {
.bits = {
- [IMX8MP_POWER_DOMAIN_USB2_PHY] = {
.bits = {
- [IMX8MP_POWER_DOMAIN_HSIOMIX] = {
.bits = {
- .map = IMX8MP_GPC_PGC_CPU_MAPPING,
- .pup = IMX8MP_GPC_PU_PGC_SW_PUP_REQ,
- .pdn = IMX8MP_GPC_PU_PGC_SW_PDN_REQ,
- .hsk = IMX8MP_GPC_PU_PWRHSK,
- .domains = imx8mp_pgc_domains,
- .domains_num = ARRAY_SIZE(imx8mp_pgc_domains),
- .pgc_regs = &imx8mp_pgc_regs,
+}; +#endif
- static int imx8m_power_domain_on(struct power_domain *power_domain) { struct udevice *dev = power_domain->dev;
- { .compatible = "fsl,imx8mp-gpc", .data = (long)&imx8mp_pgc_domain_data }, #endif { } };
- Copyright (C) 2020 Pengutronix, Sascha Hauer kernel@pengutronix.de
I already did sent HSIOMIX driver too, that's all we need to get USB and PCIe going in U-Boot, and get U-Boot working without running ATF, which makes new platform bring up far easier.
The "lots of code" that's in Linux is for graphics pipeline and we don't need that in U-Boot, so we conveniently avoid it here.
Marek,
Thanks for working on this!
This helps get DWC3 USB working on IMX8MP.
Tested-By: Tim Harvey tharvey@gateworks.com #imx8mp-venice-gw74xx
Best Regards,
Tim
Peng Fan (OSS)
Tim Harvey
