[U-Boot] [PATCH] imx8mq_evk_defconfig: Move file system options to Kconfig
Chris Spencer reports that when enabling ext4 read support without also enabling write support the following error is seen:
fs/fs.c:198:12: error: 'ext4_write_file' undeclared here (not in a function); did you mean 'ext4_read_file'? .write = ext4_write_file, ^~~~~~~~~~~~~~~ Fix this problem by moving these options to Kconfig.
Reported-by: Chris Spencer spencercw@gmail.com Signed-off-by: Fabio Estevam festevam@gmail.com --- configs/imx8mq_evk_defconfig | 5 +++++ include/configs/imx8mq_evk.h | 6 ------ 2 files changed, 5 insertions(+), 6 deletions(-)
diff --git a/configs/imx8mq_evk_defconfig b/configs/imx8mq_evk_defconfig index f216d46a8f..b473fcd61b 100644 --- a/configs/imx8mq_evk_defconfig +++ b/configs/imx8mq_evk_defconfig @@ -15,6 +15,11 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_SPL=y CONFIG_SPL_BOARD_INIT=y CONFIG_HUSH_PARSER=y +CONFIG_DOS_PARTITION=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT= CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_CACHE=y diff --git a/include/configs/imx8mq_evk.h b/include/configs/imx8mq_evk.h index 35f81152f2..f0430224cb 100644 --- a/include/configs/imx8mq_evk.h +++ b/include/configs/imx8mq_evk.h @@ -226,12 +226,6 @@ #define CONFIG_SYS_FSL_USDHC_NUM 2 #define CONFIG_SYS_FSL_ESDHC_ADDR 0
-#define CONFIG_DOS_PARTITION -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_EXT4 -#define CONFIG_CMD_EXT4_WRITE -#define CONFIG_CMD_FAT - #define CONFIG_SUPPORT_EMMC_BOOT /* eMMC specific */ #define CONFIG_SYS_MMC_IMG_LOAD_PART 1
-----Original Message----- From: Fabio Estevam [mailto:festevam@gmail.com] Sent: 2018年12月28日 3:14 To: sbabic@denx.de Cc: dl-uboot-imx uboot-imx@nxp.com; u-boot@lists.denx.de; spencercw@gmail.com; Fabio Estevam festevam@gmail.com Subject: [PATCH] imx8mq_evk_defconfig: Move file system options to Kconfig
Acked-by: Peng Fan peng.fan@nxp.com
-- 2.17.1
Hi Fabio,
Joris Offouga
You forgot "y" to this line, correct this in CONFIG_CMD_FAT=y
-- 2.17.1
Hi Joris,
Thanks! I have just sent a corrected v2.
Fabio Estevam
Offouga Joris
Peng Fan
