[U-Boot-Users] [PATCH] Added ability to specific OF_STDOUT_PATH
Signed-off-by: Kumar Gala galak@kernel.crashing.org
CHANGELOG: * Added ability to specific OF_STDOUT_PATH Allows the kernel to know which device to use for console output
Patch by Kumar Gala 05 Jan 2006
--- commit 3b1cc08e3aed69e2437c9a33d4d0d000d88eda03 tree 57ee8c1fc0da69f731228af597b6e7d867ad8d0d parent 3080d3537d6cb0dbff783c2e7ad4340e1ea37965 author Kumar Gala galak@kernel.crashing.org Thu, 05 Jan 2006 17:04:46 -0600 committer Kumar Gala galak@kernel.crashing.org Thu, 05 Jan 2006 17:04:46 -0600
README | 1 + common/ft_build.c | 3 +++ 2 files changed, 4 insertions(+), 0 deletions(-)
diff --git a/README b/README index ea37dac..ecaef9e 100644 --- a/README +++ b/README @@ -413,6 +413,7 @@ The following options need to be configu OF_CPU - The proper name of the cpus node. OF_SOC - The proper name of the soc node. OF_TBCLK - The timebase frequency. + OF_STDOUT_PATH - The path to the console device
CONFIG_OF_HAS_BD_T
diff --git a/common/ft_build.c b/common/ft_build.c index bebee30..6e4d3de 100644 --- a/common/ft_build.c +++ b/common/ft_build.c @@ -639,6 +639,9 @@ void ft_setup(void *blob, int size, bd_t ft_prop_str(&cxt, "name", "chosen"); ft_prop_str(&cxt, "bootargs", getenv("bootargs")); ft_prop_int(&cxt, "linux,platform", 0x600); /* what is this? */ +#ifdef OF_STDOUT_PATH + ft_prop_str(&cxt, "linux,stdout-path", OF_STDOUT_PATH); +#endif
ft_end_node(&cxt);
In message Pine.LNX.4.44.0601051659520.9053-100000@gate.crashing.org you wrote:
CHANGELOG:
- Added ability to specific OF_STDOUT_PATH Allows the kernel to know which device to use for console output
Dropped because I'll rather pull from your git repo. Thanks.
Kumar Gala
