[U-Boot] [PATCH] efi_loader: search all possible disk partitions
When searching for partitions don't stop if a partition is not present for a given partition number as there may be valid partitions after.
Search for up to MAX_SEARCH_PARTITIONS matching the other callers of part_get_info().
This allows OpenBSD to boot via the efi_loader on rpi_3 again after changes made after U-Boot 2017.09. With MBR partitioning OpenBSD will by default use the fourth partition for the 0xA6 (OpenBSD) partition.
Signed-off-by: Jonathan Gray jsg@jsg.id.au --- lib/efi_loader/efi_disk.c | 20 ++++++++++++-------- 1 file changed, 12 insertions(+), 8 deletions(-)
diff --git a/lib/efi_loader/efi_disk.c b/lib/efi_loader/efi_disk.c index 47b487aa30..6b192701a8 100644 --- a/lib/efi_loader/efi_disk.c +++ b/lib/efi_loader/efi_disk.c @@ -254,18 +254,19 @@ static int efi_disk_create_eltorito(struct blk_desc *desc, #if CONFIG_IS_ENABLED(ISO_PARTITION) char devname[32] = { 0 }; /* dp->str is u16[32] long */ disk_partition_t info; - int part = 1; + int part;
if (desc->part_type != PART_TYPE_ISO) return 0;
/* and devices for each partition: */ - while (!part_get_info(desc, part, &info)) { + for (part = 1; part <= MAX_SEARCH_PARTITIONS; part++) { + if (part_get_info(desc, part, &info)) + continue; snprintf(devname, sizeof(devname), "%s:%d", pdevname, part); efi_disk_add_dev(devname, if_typename, desc, diskid, info.start, part); - part++; disks++; }
@@ -299,15 +300,16 @@ int efi_disk_register(void) struct blk_desc *desc = dev_get_uclass_platdata(dev); const char *if_typename = dev->driver->name; disk_partition_t info; - int part = 1; + int part;
printf("Scanning disk %s...\n", dev->name);
/* add devices for each partition: */ - while (!part_get_info(desc, part, &info)) { + for (part = 1; part <= MAX_SEARCH_PARTITIONS; part++) { + if (part_get_info(desc, part, &info)) + continue; efi_disk_add_dev(dev->name, if_typename, desc, desc->devnum, 0, part); - part++; }
/* ... and add block device: */ @@ -341,7 +343,7 @@ int efi_disk_register(void) struct blk_desc *desc; char devname[32] = { 0 }; /* dp->str is u16[32] long */ disk_partition_t info; - int part = 1; + int part;
desc = blk_get_devnum_by_type(if_type, i); if (!desc) @@ -353,7 +355,9 @@ int efi_disk_register(void) if_typename, i);
/* add devices for each partition: */ - while (!part_get_info(desc, part, &info)) { + for (part = 1; part <= MAX_SEARCH_PARTITIONS; part++) { + if (part_get_info(desc, part, &info)) + continue; efi_disk_add_dev(devname, if_typename, desc, i, 0, part); part++;
Thanks, applied to efi-next
Alex
Alex
Thanks, looking over it again I realised one of the loops is now incrementing the partition number twice per loop so I have sent a further patch to the list to correct that.
Tested-by: Peter Robinson pbrobinson@gmail.com
Tested on the Pine64, fixes the issues I saw with that device.
int part = 1;
int part; if (desc->part_type != PART_TYPE_ISO) return 0; /* and devices for each partition: */
part++; disks++; }
int part = 1;
int part; printf("Scanning disk %s...\n", dev->name); /* add devices for each partition: */
part++; } /* ... and add block device: */
int part = 1;
int part; desc = blk_get_devnum_by_type(if_type, i); if (!desc)
-- 2.14.2
Alexander Graf
Jonathan Gray
Peter Robinson
