[U-Boot] [PATCH 3/9] x86: dm: Clean up cpu drivers
This commit does the following to clean up x86 cpu dm drivers: - Move cpu_x86 driver codes from arch/x86/cpu/cpu.c to a dedicated file arch/x86/cpu/cpu_x86.c - Rename x86_cpu_get_desc() to cpu_x86_get_desc() to keep consistent naming with other dm drivers - Add a new cpu_x86_bind() in the cpu_x86 driver which does exactly the same as the one in the intel baytrail cpu driver - Update intel baytrail cpu driver to use cpu_x86_get_desc() and cpu_x86_bind()
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
arch/x86/cpu/Makefile | 2 +- arch/x86/cpu/baytrail/cpu.c | 15 +++---------- arch/x86/cpu/cpu.c | 28 ------------------------ arch/x86/cpu/cpu_x86.c | 48 ++++++++++++++++++++++++++++++++++++++++++ arch/x86/include/asm/cpu.h | 14 ------------ arch/x86/include/asm/cpu_x86.h | 34 ++++++++++++++++++++++++++++++ 6 files changed, 86 insertions(+), 55 deletions(-) create mode 100644 arch/x86/cpu/cpu_x86.c create mode 100644 arch/x86/include/asm/cpu_x86.h
diff --git a/arch/x86/cpu/Makefile b/arch/x86/cpu/Makefile index 7ff05e6..48197fb 100644 --- a/arch/x86/cpu/Makefile +++ b/arch/x86/cpu/Makefile @@ -10,7 +10,7 @@
extra-y = start.o obj-$(CONFIG_X86_RESET_VECTOR) += resetvec.o start16.o -obj-y += interrupts.o cpu.o call64.o +obj-y += interrupts.o cpu.o cpu_x86.o call64.o
obj-$(CONFIG_INTEL_BAYTRAIL) += baytrail/ obj-$(CONFIG_SYS_COREBOOT) += coreboot/ diff --git a/arch/x86/cpu/baytrail/cpu.c b/arch/x86/cpu/baytrail/cpu.c index 1d48206..05156a5 100644 --- a/arch/x86/cpu/baytrail/cpu.c +++ b/arch/x86/cpu/baytrail/cpu.c @@ -10,6 +10,7 @@ #include <cpu.h> #include <dm.h> #include <asm/cpu.h> +#include <asm/cpu_x86.h> #include <asm/lapic.h> #include <asm/mp.h> #include <asm/msr.h> @@ -175,18 +176,8 @@ static int baytrail_get_info(struct udevice *dev, struct cpu_info *info) return 0; }
-static int cpu_x86_baytrail_bind(struct udevice *dev) -{ - struct cpu_platdata *plat = dev_get_parent_platdata(dev); - - plat->cpu_id = fdtdec_get_int(gd->fdt_blob, dev->of_offset, - "intel,apic-id", -1); - - return 0; -} - static const struct cpu_ops cpu_x86_baytrail_ops = { - .get_desc = x86_cpu_get_desc, + .get_desc = cpu_x86_get_desc, .get_info = baytrail_get_info, };
@@ -199,7 +190,7 @@ U_BOOT_DRIVER(cpu_x86_baytrail_drv) = { .name = "cpu_x86_baytrail", .id = UCLASS_CPU, .of_match = cpu_x86_baytrail_ids, - .bind = cpu_x86_baytrail_bind, + .bind = cpu_x86_bind, .probe = cpu_x86_baytrail_probe, .ops = &cpu_x86_baytrail_ops, }; diff --git a/arch/x86/cpu/cpu.c b/arch/x86/cpu/cpu.c index bb4a110..ffb6e43 100644 --- a/arch/x86/cpu/cpu.c +++ b/arch/x86/cpu/cpu.c @@ -21,8 +21,6 @@
#include <common.h> #include <command.h> -#include <cpu.h> -#include <dm.h> #include <errno.h> #include <malloc.h> #include <asm/control_regs.h> @@ -520,16 +518,6 @@ char *cpu_get_name(char *name) return ptr; }
-int x86_cpu_get_desc(struct udevice *dev, char *buf, int size) -{ - if (size < CPU_MAX_NAME_LEN) - return -ENOSPC; - - cpu_get_name(buf); - - return 0; -} - int default_print_cpuinfo(void) { printf("CPU: %s, vendor %s, device %xh\n", @@ -622,19 +610,3 @@ int cpu_init_r(void) { return x86_init_cpus(); } - -static const struct cpu_ops cpu_x86_ops = { - .get_desc = x86_cpu_get_desc, -}; - -static const struct udevice_id cpu_x86_ids[] = { - { .compatible = "cpu-x86" }, - { } -}; - -U_BOOT_DRIVER(cpu_x86_drv) = { - .name = "cpu_x86", - .id = UCLASS_CPU, - .of_match = cpu_x86_ids, - .ops = &cpu_x86_ops, -}; diff --git a/arch/x86/cpu/cpu_x86.c b/arch/x86/cpu/cpu_x86.c new file mode 100644 index 0000000..d32ba66 --- /dev/null +++ b/arch/x86/cpu/cpu_x86.c @@ -0,0 +1,48 @@ +/* + * Copyright (C) 2015, Bin Meng bmeng.cn@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <cpu.h> +#include <dm.h> +#include <errno.h> +#include <asm/cpu.h> + +int cpu_x86_bind(struct udevice *dev) +{ + struct cpu_platdata *plat = dev_get_parent_platdata(dev); + + plat->cpu_id = fdtdec_get_int(gd->fdt_blob, dev->of_offset, + "intel,apic-id", -1); + + return 0; +} + +int cpu_x86_get_desc(struct udevice *dev, char *buf, int size) +{ + if (size < CPU_MAX_NAME_LEN) + return -ENOSPC; + + cpu_get_name(buf); + + return 0; +} + +static const struct cpu_ops cpu_x86_ops = { + .get_desc = cpu_x86_get_desc, +}; + +static const struct udevice_id cpu_x86_ids[] = { + { .compatible = "cpu-x86" }, + { } +}; + +U_BOOT_DRIVER(cpu_x86_drv) = { + .name = "cpu_x86", + .id = UCLASS_CPU, + .of_match = cpu_x86_ids, + .bind = cpu_x86_bind, + .ops = &cpu_x86_ops, +}; diff --git a/arch/x86/include/asm/cpu.h b/arch/x86/include/asm/cpu.h index ebc74ad..08284ee 100644 --- a/arch/x86/include/asm/cpu.h +++ b/arch/x86/include/asm/cpu.h @@ -197,20 +197,6 @@ const char *cpu_vendor_name(int vendor); char *cpu_get_name(char *name);
/** - * -* x86_cpu_get_desc() - Get a description string for an x86 CPU -* -* This uses cpu_get_name() and is suitable to use as the get_desc() method for -* the CPU uclass. -* -* @dev: Device to check (UCLASS_CPU) -* @buf: Buffer to place string -* @size: Size of string space -* @return 0 if OK, -ENOSPC if buffer is too small, other -ve on error -*/ -int x86_cpu_get_desc(struct udevice *dev, char *buf, int size); - -/** * cpu_call64() - Jump to a 64-bit Linux kernel (internal function) * * The kernel is uncompressed and the 64-bit entry point is expected to be diff --git a/arch/x86/include/asm/cpu_x86.h b/arch/x86/include/asm/cpu_x86.h new file mode 100644 index 0000000..1940480 --- /dev/null +++ b/arch/x86/include/asm/cpu_x86.h @@ -0,0 +1,34 @@ +/* + * Copyright (C) 2015, Bin Meng bmeng.cn@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _ASM_CPU_X86_H +#define _ASM_CPU_X86_H + +/** + * cpu_x86_bind() - Bind an x86 CPU with the driver + * + * This updates cpu device's platform data with information from device tree, + * like the processor local apic id. + * + * @dev: Device to check (UCLASS_CPU) + * @return 0 always + */ +int cpu_x86_bind(struct udevice *dev); + +/** + * cpu_x86_get_desc() - Get a description string for an x86 CPU + * + * This uses cpu_get_name() and is suitable to use as the get_desc() method for + * the CPU uclass. + * + * @dev: Device to check (UCLASS_CPU) + * @buf: Buffer to place string + * @size: Size of string space + * @return: 0 if OK, -ENOSPC if buffer is too small, other -ve on error + */ +int cpu_x86_get_desc(struct udevice *dev, char *buf, int size); + +#endif /* _ASM_CPU_X86_H */
Bin Meng
