[U-Boot] [PATCH v1 0/2] Fix USB port indexes for USB gadget commands
The USB gadget commands take the USB port index as a parameter. This is not playing well with the current DM support for gadget when USB0 is dedicated to host and USB1 dedicated to gadget. This problem has been reported by Sam Protsenko semen.protsenko@linaro.org
This patch fixes this by using the aliases provided by the DT to get the port index right.
Tested on: - dra76 evm - am572 evm
Jean-Jacques Hiblot (2): dm: usb: udc: Use SEQ_ALIAS to index the USB gadget ports ARM: dts: define USB aliases for all omap5 platforms
arch/arm/dts/omap5-u-boot.dtsi | 5 +++++ drivers/usb/gadget/udc/udc-uclass.c | 5 +++-- 2 files changed, 8 insertions(+), 2 deletions(-)
dfu, fastbot and other usb gadget commands take the USB port index as a parameter. Currently this index is assigned in the order of the driver bindings. Changing this behavior using the SEQ_ALIAS feature. This option assign to the device a SEQ number based on its alias (if it exists)
To use it we must set the DM_UC_FLAG_SEQ_ALIAS flag and follow the existing naming convention: use "usb" for the name of the gadget UCLASS_DRIVER (same as for the UCLASS_USB).
If no alias is provided, then the index falls back to the order in which the bindings took place.
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com Reported-by: Sam Protsenko semen.protsenko@linaro.org ---
drivers/usb/gadget/udc/udc-uclass.c | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/drivers/usb/gadget/udc/udc-uclass.c b/drivers/usb/gadget/udc/udc-uclass.c index 0620518..e9f8f5f 100644 --- a/drivers/usb/gadget/udc/udc-uclass.c +++ b/drivers/usb/gadget/udc/udc-uclass.c @@ -20,7 +20,7 @@ int usb_gadget_initialize(int index) return -EINVAL; if (dev_array[index]) return 0; - ret = uclass_get_device(UCLASS_USB_GADGET_GENERIC, index, &dev); + ret = uclass_get_device_by_seq(UCLASS_USB_GADGET_GENERIC, index, &dev); if (!dev || ret) { pr_err("No USB device found\n"); return -ENODEV; @@ -54,5 +54,6 @@ int usb_gadget_handle_interrupts(int index)
UCLASS_DRIVER(usb_gadget_generic) = { .id = UCLASS_USB_GADGET_GENERIC, - .name = "usb_gadget_generic", + .name = "usb", + .flags = DM_UC_FLAG_SEQ_ALIAS, };
fastboot.
Looks good to me, I expect Lukasz to pick it, test it and send me a PR.
- ret = uclass_get_device_by_seq(UCLASS_USB_GADGET_GENERIC, index, &dev); if (!dev || ret) { pr_err("No USB device found\n"); return -ENODEV;
- .name = "usb",
- .flags = DM_UC_FLAG_SEQ_ALIAS,
Hi Marek, Jean-Jacques,
fastboot.
I must admit that this change fixes a long standing problem with the usb number assignment.
Great job. I will test and send it in a few days time.
&dev);
- .name = "usb",
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
Tested on BeagleBoard X15, works fine. Thanks, Jean-Jacques!
Lukasz, is there any way this series can make it to v2019.01 release? Like to see it there, for stability/consistence reasons.
Reviewed-by: Sam Protsenko semen.protsenko@linaro.org Tested-by: Sam Protsenko semen.protsenko@linaro.org
Thanks!
fastboot.
&dev);
- .name = "usb",
Lukasz Majewski
This allows us to properly map the USB controller indexes
Tested on dra76 evm, am572 evm
arch/arm/dts/omap5-u-boot.dtsi | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/arm/dts/omap5-u-boot.dtsi b/arch/arm/dts/omap5-u-boot.dtsi index 1eb50cd..54a7285 100644 --- a/arch/arm/dts/omap5-u-boot.dtsi +++ b/arch/arm/dts/omap5-u-boot.dtsi @@ -12,6 +12,11 @@ tick-timer = &timer2; };
+ aliases { + usb0 = &usb1; + usb1 = &usb2; + }; + ocp { u-boot,dm-spl;
Jean-Jacques Hiblot
Lukasz Majewski
Sam Protsenko
