Re: [U-Boot] [PATCH] I2C: Add support for multiple I2C busses for SNTP (effect to RTC)
Hello Heiko, Hello Ben,
Hello Stephan,
added Ben Warren to cc: because this is a change in net, which also falls in his area of responsibility ...
OK, fine ...
Stephan Linz wrote:
This patch switches to the desired I2C bus when the SNTP network service is called. This can be configured using the CONFIG_SYS_RTC_BUS_NUM define.
In my eyes this is a bad and quick hack, but the same as was making for the date and dtt commands (commit: 0dc018e). The right way would be to move all the hardware specific i2c code down to the rtc driver layer.
Yes, thats would the best way, but why you don;t go this way?
It's easy: time .... Joking apart, this patch brings the network layer in harmony to the command layer regardless of how beautiful it is. In one of the next steps I (we) can create a new patch to resolve this unsightly condition and move the hardware specifics into the rtc layer. Even such a patch will grow up and change more than a dozen of files.
I'm a friend of more small steps. So I've changed this small piece. I offer to make the big change in the next few weeks ... ?
Beside of that, this patch look good to me ...
OK. Ben, what do you mean?
Signed-off-by: Stephan Linz linz@li-pro.net
net/sntp.c | 18 ++++++++++++++++++ 1 files changed, 18 insertions(+), 0 deletions(-)
diff --git a/net/sntp.c b/net/sntp.c index 76c10ec..5544570 100644 --- a/net/sntp.c +++ b/net/sntp.c @@ -10,6 +10,14 @@ #include <net.h> #include <rtc.h>
- FIXME: The i2c dependency should move into the RTC drivers itself.
- This higher network layer must not know about hardware specifics!
+#if defined(CONFIG_CMD_DATE) +#include <i2c.h> +#endif
#include "sntp.h"
#define SNTP_TIMEOUT 10000UL @@ -53,6 +61,9 @@ SntpHandler (uchar *pkt, unsigned dest, unsigned src,
unsigned len)
struct sntp_pkt_t *rpktp = (struct sntp_pkt_t *)pkt; struct rtc_time tm; ulong seconds; +#if defined(CONFIG_CMD_DATE)
- int old_bus;
debug("%s\n", __func__);
@@ -66,7 +77,14 @@ SntpHandler (uchar *pkt, unsigned dest, unsigned src,
unsigned len)
to_tm(ntohl(seconds) - 2208988800UL + NetTimeOffset, &tm); #if defined(CONFIG_CMD_DATE)
- /* switch to correct I2C bus */
- old_bus = I2C_GET_BUS();
- I2C_SET_BUS(CONFIG_SYS_RTC_BUS_NUM);
- rtc_set (&tm);
- /* switch back to original I2C bus */
- I2C_SET_BUS(old_bus);
#endif printf ("Date: %4d-%02d-%02d Time: %2d:%02d:%02d\n", tm.tm_year, tm.tm_mon, tm.tm_mday,
bye Heiko -- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany
--- original Nachricht Ende ----
Stephan Linz
