[U-Boot-Users] [PATCH v2] ppc: Add CFG_MEM_TOP_HIDE option to hide memory area that doesn't get "touched"
If CFG_MEM_TOP_HIDE is defined in the board config header, this specified memory area will get subtracted from the top (end) of ram and won't get "touched" at all by U-Boot. By fixing up gd->ram_size the Linux kernel should gets passed the now "corrected" memory size and won't touch it either. This should work for arch/ppc and arch/powerpc. Only Linux board ports in arch/powerpc with bootwrapper support, that recalculate the memory size from the SDRAM controller setup will have to get fixed.
This patch enables this config option on some PPC440EPx boards as a workaround for the CHIP 11 errata. Here the description from the AMCC documentation:
CHIP_11: End of memory range area restricted access. Category: 3
Overview: The 440EPx DDR controller does not acknowledge any transaction which is determined to be crossing over the end-of-memory-range boundary, even if the starting address is within valid memory space. Any such transaction from any PLB4 master will result in a PLB time-out on PLB4 bus.
Impact: In case of such misaligned bursts, PLB4 masters will not retrieve any data at all, just the available data up to the end of memory, especially the 440 CPU. For example, if a CPU instruction required an operand located in memory within the last 7 words of memory, the DCU master would burst read 8 words to update the data cache and cross over the end-of-memory-range boundary. Such a DCU read would not be answered by the DDR controller, resulting in a PLB4 time-out and ultimately in a Machine Check interrupt. The data would be inaccessible to the CPU.
Workaround: Forbid any application to access the last 256 bytes of DDR memory. For example, make your operating system believe that the last 256 bytes of DDR memory are absent. AMCC has a patch that does this, available for Linux.
This patch sets CFG_MEM_TOP_HIDE for the following 440EPx boards: lwmon5, korat, sequoia
The other remaining 440EPx board were intentionally not included since it is not clear to me, if they use the end of ram for some other purpose. This is unclear, since these boards have CONFIG_PRAM defined and even comments like this:
PMC440.h: /* esd expects pram at end of physical memory. * So no logbuffer at the moment. */
It is strongly recommendet to not use the last 256 bytes on those boards too. Patches from the board maintainers are welcome.
Signed-off-by: Stefan Roese sr@denx.de --- Changes in this version v2:
- Changed name of define to CFG_MEM_TOP_HIDE
include/configs/korat.h | 2 ++ include/configs/lwmon5.h | 2 ++ include/configs/sequoia.h | 4 +++- lib_ppc/board.c | 17 +++++++++++++++++ 4 files changed, 24 insertions(+), 1 deletions(-)
diff --git a/include/configs/korat.h b/include/configs/korat.h index dcec9b0..c215c63 100644 --- a/include/configs/korat.h +++ b/include/configs/korat.h @@ -144,6 +144,8 @@ #define SPD_EEPROM_ADDRESS {0x50} #define CONFIG_PROG_SDRAM_TLB #define CFG_DRAM_TEST +#define CFG_MEM_TOP_HIDE 256 /* don't use last 256 bytes */ + /* 440EPx errata CHIP 11 */
/* * I2C diff --git a/include/configs/lwmon5.h b/include/configs/lwmon5.h index c3f10c7..f573730 100644 --- a/include/configs/lwmon5.h +++ b/include/configs/lwmon5.h @@ -85,6 +85,8 @@ #define CFG_INIT_SP_OFFSET CFG_GBL_DATA_OFFSET #define CFG_POST_ALT_WORD_ADDR (CFG_PERIPHERAL_BASE + GPT0_COMP6) /* unused GPT0 COMP reg */ +#define CFG_MEM_TOP_HIDE 256 /* don't use last 256 bytes */ + /* 440EPx errata CHIP 11 */
/*----------------------------------------------------------------------- * Serial Port diff --git a/include/configs/sequoia.h b/include/configs/sequoia.h index dfa8779..0188234 100644 --- a/include/configs/sequoia.h +++ b/include/configs/sequoia.h @@ -221,6 +221,8 @@ #if !defined(CONFIG_NAND_U_BOOT) && !defined(CONFIG_NAND_SPL) #define CONFIG_DDR_DATA_EYE /* use DDR2 optimization */ #endif +#define CFG_MEM_TOP_HIDE 256 /* don't use last 256 bytes */ + /* 440EPx errata CHIP 11 */
/* * I2C @@ -275,7 +277,7 @@ "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}" \ ":${hostname}:${netdev}:off panic=1\0" \ "addtty=setenv bootargs ${bootargs} console=ttyS0,${baudrate}\0"\ - "addmisc=setenv bootargs ${bootargs} mem=${mem}\0" \ + "addmisc=setenv bootargs ${bootargs}\0" \ "flash_nfs=run nfsargs addip addtty addmisc;" \ "bootm ${kernel_addr}\0" \ "flash_self=run ramargs addip addtty addmisc;" \ diff --git a/lib_ppc/board.c b/lib_ppc/board.c index fbf1c5d..13b6f54 100644 --- a/lib_ppc/board.c +++ b/lib_ppc/board.c @@ -117,6 +117,10 @@ DECLARE_GLOBAL_DATA_PTR; #define TOTAL_MALLOC_LEN CFG_MALLOC_LEN #endif
+#if !defined(CFG_MEM_TOP_HIDE) +#define CFG_MEM_TOP_HIDE 0 +#endif + extern ulong __init_end; extern ulong _end; ulong monitor_flash_len; @@ -425,6 +429,7 @@ void board_init_f (ulong bootflag) * relocate the code and continue running from DRAM. * * Reserve memory at end of RAM for (top down in that order): + * - area that won't get touched by U-Boot and Linux (optional) * - kernel log buffer * - protected RAM * - LCD framebuffer @@ -433,6 +438,18 @@ void board_init_f (ulong bootflag) */ len = (ulong)&_end - CFG_MONITOR_BASE;
+ /* + * Subtract specified amount of memory to hide so that it won't + * get "touched" at all by U-Boot. By fixing up gd->ram_size + * the Linux kernel should now get passed the now "corrected" + * memory size and won't touch it either. This should work + * for arch/ppc and arch/powerpc. Only Linux board ports in + * arch/powerpc with bootwrapper support, that recalculate the + * memory size from the SDRAM controller setup will have to + * get fixed. + */ + gd->ram_size -= CFG_MEM_TOP_HIDE; + addr = CFG_SDRAM_BASE + get_effective_memsize();
#ifdef CONFIG_LOGBUFFER
Stefan Roese
