[PATCH] configs: imx8m: Prepare imx8m-beacon boards for HAB support
In order to enable HAB, FSL_CAAM, ARCH_MISC_INIT and SPL_CRYPTO should be enabled in Kconfig like other i.MX8M boards.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index a0715e8091..eadb2234b0 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -233,6 +233,9 @@ config TARGET_IMX8MM_BEACON select IMX8MM select SUPPORT_SPL select IMX8M_LPDDR4 + select FSL_CAAM + select ARCH_MISC_INIT + select SPL_CRYPTO if SPL
config TARGET_IMX8MN_BEACON bool "imx8mn Beacon Embedded devkit" @@ -240,6 +243,9 @@ config TARGET_IMX8MN_BEACON select IMX8MN select SUPPORT_SPL select IMX8M_LPDDR4 + select FSL_CAAM + select ARCH_MISC_INIT + select SPL_CRYPTO if SPL
config TARGET_PHYCORE_IMX8MM bool "PHYTEC PHYCORE i.MX8MM"
In order to enable HAB, FSL_CAAM, ARCH_MISC_INIT and SPL_CRYPTO should be enabled in Kconfig like other i.MX8M boards. Signed-off-by: Adam Ford aford173@gmail.com diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index a0715e8091..eadb2234b0 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -233,6 +233,9 @@ config TARGET_IMX8MM_BEACON select IMX8MM select SUPPORT_SPL select IMX8M_LPDDR4
- select FSL_CAAM
- select ARCH_MISC_INIT
- select SPL_CRYPTO if SPL
- select FSL_CAAM
Best regards, Stefano Babic
Adam Ford
sbabic@denx.de
