[PATCH] Kconfig: distro: Use imply instead of select for CMD_FAT
Using imply instead of select for CMD_FAT so overwritten is allowed in later configuration.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/Kconfig b/Kconfig index 991b260182..71374980e9 100644 --- a/Kconfig +++ b/Kconfig @@ -201,7 +201,7 @@ config DISTRO_DEFAULTS select CMD_ENV_EXISTS select CMD_EXT2 select CMD_EXT4 - select CMD_FAT + imply CMD_FAT select CMD_FS_GENERIC select CMD_PART if PARTITIONS select CMD_PING if CMD_NET
- select CMD_FAT
- imply CMD_FAT select CMD_FS_GENERIC select CMD_PART if PARTITIONS select CMD_PING if CMD_NET
NAK, at least without explaining what the use case here is. A big part of generic distro work is "oh, you have that FAT32 ESP to use".
Hi Tom,
select CMD_FAT
Isn't that just for EFI?
In general I try to use 'imply' so it is possible for a board to disable the option.
On Wed, Oct 12, 2022 at 07:04:24AM -0600, Simon Glass wrote:
Hi Tom,
select CMD_FAT
Calling it an ESP? Yes. Expecting the first partition to be FAT? No, that's a forever-and-ever thing distros have been expecting on x86 and want to see everyone else do too (so their installer logic doesn't have to get further complex).
Hi Tom,
Hi Tom,
select CMD_FAT
OK I See. Well, 'imply' is more friendly since it allows the choice, if the function is not used. In fact 'DISTRO_DEFAULTS' is mostly DISTRO_REQUIRED at this point :-)
On Fri, Oct 14, 2022 at 09:55:47AM -0600, Simon Glass wrote:
Hi Tom,
Hi Tom,
select CMD_FAT
Well, yes. It's supposed to be thee option that you set and then all of the common general Linux distros (and the BSD families have adopted this as well) Just Work, so it needs to be selecting.
Jit Loon Lim
