[U-Boot] [patch] rm9200 ethernet driver: board-specific quirk (csb337)
CSB337 boards originally shipped with MicroMonitor, not U-Boot; and with a version using a different convention for recording Ethernet addresses than anyone else. To avoid breaking Linux when it uses U-Boot, have it use the same convention on that hardware.
Signed-off-by: David Brownell dbrownell@users.sourceforge.net --- cpu/arm920t/at91rm9200/ether.c | 22 ++++++++++++++++++---- 1 file changed, 18 insertions(+), 4 deletions(-)
--- a/cpu/arm920t/at91rm9200/ether.c +++ b/cpu/arm920t/at91rm9200/ether.c @@ -24,6 +24,7 @@ #include <at91rm9200_net.h> #include <net.h> #include <miiphy.h> +#include <asm/mach-types.h>
/* ----- Ethernet Buffer definitions ----- */
@@ -184,7 +185,7 @@ int eth_init (bd_t * bd)
p_mac->EMAC_CFG |= AT91C_EMAC_CSR; /* Clear statistics */
- /* Init Ehternet buffers */ + /* Init Ethernet buffers */ for (i = 0; i < RBF_FRAMEMAX; i++) { rbfdt[i].addr = (unsigned long)rbf_framebuf[i]; rbfdt[i].size = 0; @@ -193,9 +194,22 @@ int eth_init (bd_t * bd) rbfp = &rbfdt[0];
eth_getenv_enetaddr("ethaddr", enetaddr); - p_mac->EMAC_SA2L = (enetaddr[3] << 24) | (enetaddr[2] << 16) - | (enetaddr[1] << 8) | (enetaddr[0]); - p_mac->EMAC_SA2H = (enetaddr[5] << 8) | (enetaddr[4]); + + /* The CSB337 originally used a version of the MicroMonitor bootloader + * which saved Ethernet addresses in the "wrong" order. Operating + * systems (like Linux) know this, and apply a workaround. Replicate + * that MicroMonitor behavior so we avoid needing to make such OS code + * care about which bootloader was used. + */ + if (machine_is_csb337()) { + p_mac->EMAC_SA2H = (enetaddr[0] << 8) | (enetaddr[1]); + p_mac->EMAC_SA2L = (enetaddr[2] << 24) | (enetaddr[3] << 16) + | (enetaddr[4] << 8) | (enetaddr[5]); + } else { + p_mac->EMAC_SA2L = (enetaddr[3] << 24) | (enetaddr[2] << 16) + | (enetaddr[1] << 8) | (enetaddr[0]); + p_mac->EMAC_SA2H = (enetaddr[5] << 8) | (enetaddr[4]); + }
p_mac->EMAC_RBQP = (long) (&rbfdt[0]); p_mac->EMAC_RSR &= ~(AT91C_EMAC_RSR_OVR | AT91C_EMAC_REC | AT91C_EMAC_BNA);
I'm not really a fan of this but ok if I see the csn337 board patch
Ben what do you think?
- /* Init Ethernet buffers */ for (i = 0; i < RBF_FRAMEMAX; i++) { rbfdt[i].addr = (unsigned long)rbf_framebuf[i]; rbfdt[i].size = 0;
- /* The CSB337 originally used a version of the MicroMonitor bootloader
- if (machine_is_csb337()) {
please use ifdef to avoid other people size impact due this
- } else {
Best Regards, J.
I meant to send that in before, thanks for the reminder. The email I just sent has that.
If you don't like it, what would you propose instead? Remember that *EVERY* Linux kernel (for example) is expecting these boards to work this way. I don't think it's realistic, or desirable, to change Linux in this way. It's not supposed to matter what boot loader gets used.
The machine_is_X() macros are automatically #ifdeffed in the header; no size impact. Read <asm/mach-types.h> ...
- } else {
Best Regards, J.
Actually I've no better idea and as Ben If we have the csb337 mainline we will accept it
If I use this pacth on the rm9200ek the u-boot.bin size will increase for nothing If I was able to detect dynamicly on which board I will run ok but it's not the case here so please use #ifdef CONFIG_MACH_xxx #else #endif
Best Regards, J.
I'm not following you. The lines are:
#ifdef CONFIG_MACH_CSB337 # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else # define machine_arch_type MACH_TYPE_CSB337 # endif # define machine_is_csb337() (machine_arch_type == MACH_TYPE_CSB337) #else # define machine_is_csb337() (0) #endif
... and similar for EK. The csb337 config file sets CONFIG_MACH_CSB337, and nothing else does. Result: on rm9200ek, that test becomes if(0), while on csb337 it becomes if (X == X), where X == MACH_TYPE_CSB337.
See above. There already *IS* such an #ifdef, but it's just not cluttering up the guts of that driver.
you adding MUST have NO size impact on other board
if we apply you code as it we will increase the size of u-boot for every rm9200 board that use the ethernet
so please do the ifdef on the ether driver
Best Regards, J.
i dont get it. the CPP expands into if(0) and unless you have a completely shitty compiler, gcc will do dead code elimination on it resulting in the same binary size. -mike
I've seen to much "shitty version" that does not do it correctly so I prefer ot avoid the problem
Best Regards, J.
i'm pretty sure we're already relying on this behavior. so you've got a bigger problem that needs addressing (i.e. shit can that compiler) than what David is proposing. -mike
Not on any compiler I've used for at least the past dozen years or so.
Which compiler versions are that broken? And are used regularly to build rm9200 U-Boot code? At normal optimization levels? (We know that disabling optimization puts out all kinds of crap.)
This is really basic stuff: "if (0) { dead } else { live }" and the converse.
I know that when Linux started relying on that type of dead-code elimination quite a few years back, nobody thought this was a real issue. And Linux is, on the whole, far more demanding of compilers than U-Boot.
Dear Jean-Christophe PLAGNIOL-VILLARD,
There are zillions of places that rely on the compiler optimizing away "if (0) ..." stuff. It is a valid and even recommended C programming technique.
This is definitely no reason to reject a patch.
Not a big fan either, but if we include this board I guess there's not much of an alternative.
regards, Ben
David,
Applied to net repo.
thanks, Ben
Thanks. Random question: is that driver going to move into drivers/net or will it stay in cpu/arm920t? I thought I saw you moving things out of cpu/* a while back.
- Dave
Good question. I'd like to move it to drivers/net, as well as modify it to use the newer API. Time willing... :)
regards, Ben
- Dave
I'll prefer you do not move it as it's plan to drop it soon and swithc the rm9200 to the at91 api and now stop to double implement the driver as serial, spi as example
Best Regards, J.
participants (5)
Ben Warren
David Brownell
Mike Frysinger
