Re: [U-Boot] [PATCH] net/phy: refactor RTL8211F initialization
Hi Shengzhou Liu,
On Wed, Apr 22, 2015 at 5:22 AM, Shengzhou Liu Shengzhou.Liu@freescale.com wrote:
RTL8211F needs to enalbe TXDLY for RGMII during phy initialization, so move it to rtl8211f_config for early initialization.
Signed-off-by: Shengzhou Liu Shengzhou.Liu@freescale.com cc: Joe Hershberger joe.hershberger@gmail.com
drivers/net/phy/realtek.c | 25 +++++++++++++++++-------- 1 file changed, 17 insertions(+), 8 deletions(-)
diff --git a/drivers/net/phy/realtek.c b/drivers/net/phy/realtek.c index 3917c82..d48095b 100644 --- a/drivers/net/phy/realtek.c +++ b/drivers/net/phy/realtek.c @@ -43,6 +43,22 @@ static int rtl8211x_config(struct phy_device *phydev) return 0; }
+static int rtl8211f_config(struct phy_device *phydev) +{
phy_write(phydev, MDIO_DEVAD_NONE, MII_BMCR, BMCR_RESET);
Do you not need to disable the phy interrupt here?
if (phydev->interface == PHY_INTERFACE_MODE_RGMII) {
/* enable TXDLY */
MIIM_RTL8211F_PAGE_SELECT, 0xd08);
Why do you not need to change the page back to default? Does it only apply to one following command or something? I haven't read the data sheet for this phy to understand its behavior, but want to make sure it's clear here. Please at least add a comment describing why the page need not be changed back.
phy_write(phydev, MDIO_DEVAD_NONE, 0x11, 0x109);
Is this TX delay board specific? Seems like it would be. Should it be parameterized to come from a board CONFIG_? If not, at least add a comment describing these magic numbers.
genphy_config_aneg(phydev);
static int rtl8211x_parse_status(struct phy_device *phydev) { unsigned int speed; @@ -142,13 +158,6 @@ static int rtl8211f_parse_status(struct phy_device *phydev) phydev->speed = SPEED_10; }
/* enable TXDLY */
@@ -209,7 +218,7 @@ static struct phy_driver RTL8211F_driver = { .uid = 0x1cc916, .mask = 0xffffff, .features = PHY_GBIT_FEATURES,
.config = &rtl8211x_config,
.config = &rtl8211f_config, .startup = &rtl8211f_startup, .shutdown = &genphy_shutdown,
2.1.0.27.g96db324
-----Original Message----- From: Joe Hershberger [mailto:joe.hershberger@gmail.com] Sent: Thursday, April 23, 2015 10:42 PM To: Liu Shengzhou-B36685 Cc: u-boot Subject: Re: [PATCH] net/phy: refactor RTL8211F initialization
Hi Shengzhou Liu,
+static int rtl8211f_config(struct phy_device *phydev) {
No need, It's disabled by default.
/* enable TXDLY */
There is no other command, so it's working without back to default. To avoid potential problem if one not set expected page, will have the page back to default 0 in v2.
It is not board specific. Will replace the magic number.
Joe Hershberger
Shengzhou.Liuļ¼ freescale.com
