[U-Boot] Problems porting new u-boot
Hi all,
Im having problems porting u-boot-2009.03 to a MPC8541 board.
In u-boot-1.2.0, if I use TEXT_BASE = 0xfff00000, u-boot.bin is created with 1MB size.
But in u-boot-2009.03 it's created with only 516kB.
In cpu/mpc85xx/start.S says:
"The processor starts at 0xfffffffc and the code is first executed in the last 4K page(0xfffff000-0xffffffff) in flash/rom."
So I think there's nothing in 0xfffffffc, using u-boot.bin from u-boot-2009.03, cause it only has 516kB.
Do I have to set TEXT_BASE with the exact u-boot.bin size?
Or am I missing something?
Cheers,
-- Alemao
Dear Alemao,
In message d970ff420908060500j77fb4ea3kcd93f611269208b2@mail.gmail.com you wrote:
Sounds like a waste of flash memoory ?
Looks incorrect.
No.
Obviously yes.
But as you share no relevant information, it's impossible even to guess what might be wrong in your configuration.
Hi Alemao,
Alemao wrote:
Hi all,
The .bin file is a binary image from the first location 0xfff00000 *contiguously filled* to the last location (the start vector at 0xfffffffc). U-Boot isn't that big, most of it is empty space, but your creation of a 0xFF-filled .bin file fills in the empty spaces.
Your text base was probably 0xfff80000.
* Don't use a .bin file (use the linker elf output directly)? * Does it matter?
Do you need to set your text base to 0xfff00000? You are better off setting your text base so that your u-boot and reset vector are close together. You did not say what processor you are using, but it sounds like a MPC74xx or MPC86xx or MPC85xx? I played with a MPC8548 and reconfigured it so that my u-boot was the last two sectors of flash and the env variables were saved in the sector *preceding* the u-boot image. That worked very nicely.
The typical u-boot places the env sector after the u-boot image, which works in most cases but doesn't work well where the top page/bytes of the memory are the reset vector. In those cases, it is better to have U-Boot and the reset vector/page at the top of memory and the env sector below U-Boot, otherwise you end up with the env taking a whole sector out of the middle plus waste another whole sector just to hold your reset vector/page.
Cheers,
-- Alemao
Best regards, gvb
Jerry Van Baren wrote:
Hi Alemao,
Alemao wrote:
Hi all,
^^^^^^^ [snip]
Argh, some days I read. Other days... <rolls eyes>
gvb
Dear Jerry Van Baren,
With a little training you probably can learn to read _while_ rolling your eyes :-)
Thanks for the quick responses.
Actually it doesn't need to be so big, to justify use TEXT_BASE 0xfff00000. Im really wasting flash memory.
The problem is that in U-Boot-1.2.0, u-boot.bin gets filled, and in U-Boot-2009.03 seems that objcopy doesn't fill the right size.
I tried just change TEXT_BASE for MPC8541CDS board, setting it to 0xfff00000. In U-Boot-1.2.0 was ok, but in U-Boot-2009.03 u-boot.bin was only 512kB, and it should be 1MB
Then I tried TEXT_BASE = 0xffb00000:
U-Boot-1.2.0 -> u-boot.bin 5MB U-Boot-2009.03 -> u-boot.bin 512kB
It seems that another variable is limiting the size to 512kB.
Cheers,
-- Alemao
Alemao
Jerry Van Baren
