[PATCH] xilinx: drivers: Use '_' instead of '-' in driver name
The most of drivers are using '_' instead of '-' in driver name. That's why sync up these names to be aligned. It looks quite bad to see both in use. It is visible via dm tree command.
Simon: Not sure what's the standard here but I have done some greps and it looks like that most of drivers are using _ instead of -. --- drivers/clk/clk_zynqmp.c | 2 +- drivers/firmware/firmware-zynqmp.c | 2 +- drivers/i2c/i2c-cdns.c | 2 +- drivers/mailbox/zynqmp-ipi.c | 2 +- drivers/mtd/nand/raw/arasan_nfc.c | 2 +- drivers/mtd/nand/raw/zynq_nand.c | 2 +- 6 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/drivers/clk/clk_zynqmp.c b/drivers/clk/clk_zynqmp.c index 2313ac0bc044..779511975662 100644 --- a/drivers/clk/clk_zynqmp.c +++ b/drivers/clk/clk_zynqmp.c @@ -710,7 +710,7 @@ static const struct udevice_id zynqmp_clk_ids[] = { };
U_BOOT_DRIVER(zynqmp_clk) = { - .name = "zynqmp-clk", + .name = "zynqmp_clk", .id = UCLASS_CLK, .of_match = zynqmp_clk_ids, .probe = zynqmp_clk_probe, diff --git a/drivers/firmware/firmware-zynqmp.c b/drivers/firmware/firmware-zynqmp.c index 903a8f587820..7583f24a200d 100644 --- a/drivers/firmware/firmware-zynqmp.c +++ b/drivers/firmware/firmware-zynqmp.c @@ -202,6 +202,6 @@ static const struct udevice_id zynqmp_firmware_ids[] = {
U_BOOT_DRIVER(zynqmp_firmware) = { .id = UCLASS_FIRMWARE, - .name = "zynqmp-firmware", + .name = "zynqmp_firmware", .of_match = zynqmp_firmware_ids, }; diff --git a/drivers/i2c/i2c-cdns.c b/drivers/i2c/i2c-cdns.c index 024c63c4eaed..7144d39984ec 100644 --- a/drivers/i2c/i2c-cdns.c +++ b/drivers/i2c/i2c-cdns.c @@ -500,7 +500,7 @@ static const struct udevice_id cdns_i2c_of_match[] = { };
U_BOOT_DRIVER(cdns_i2c) = { - .name = "i2c-cdns", + .name = "i2c_cdns", .id = UCLASS_I2C, .of_match = cdns_i2c_of_match, .ofdata_to_platdata = cdns_i2c_ofdata_to_platdata, diff --git a/drivers/mailbox/zynqmp-ipi.c b/drivers/mailbox/zynqmp-ipi.c index 746377e557cb..9483ed9cefcf 100644 --- a/drivers/mailbox/zynqmp-ipi.c +++ b/drivers/mailbox/zynqmp-ipi.c @@ -133,7 +133,7 @@ struct mbox_ops zynqmp_ipi_mbox_ops = { };
U_BOOT_DRIVER(zynqmp_ipi) = { - .name = "zynqmp-ipi", + .name = "zynqmp_ipi", .id = UCLASS_MAILBOX, .of_match = zynqmp_ipi_ids, .probe = zynqmp_ipi_probe, diff --git a/drivers/mtd/nand/raw/arasan_nfc.c b/drivers/mtd/nand/raw/arasan_nfc.c index 6c1d64054c64..0615e5037809 100644 --- a/drivers/mtd/nand/raw/arasan_nfc.c +++ b/drivers/mtd/nand/raw/arasan_nfc.c @@ -1306,7 +1306,7 @@ static const struct udevice_id arasan_nand_dt_ids[] = { };
U_BOOT_DRIVER(arasan_nand) = { - .name = "arasan-nand", + .name = "arasan_nand", .id = UCLASS_MTD, .of_match = arasan_nand_dt_ids, .probe = arasan_probe, diff --git a/drivers/mtd/nand/raw/zynq_nand.c b/drivers/mtd/nand/raw/zynq_nand.c index fa594552109d..92db2aa19c86 100644 --- a/drivers/mtd/nand/raw/zynq_nand.c +++ b/drivers/mtd/nand/raw/zynq_nand.c @@ -1282,7 +1282,7 @@ static const struct udevice_id zynq_nand_dt_ids[] = { };
U_BOOT_DRIVER(zynq_nand) = { - .name = "zynq-nand", + .name = "zynq_nand", .id = UCLASS_MTD, .of_match = zynq_nand_dt_ids, .probe = zynq_nand_probe,
Bonus points if you can update checkpatch.pl to catch it
po 24. 8. 2020 v 14:15 odesÃlatel Michal Simek michal.simek@xilinx.com napsal:
.name = "i2c-cdns",
-- 2.28.0
Applied. M
Michal Simek
Michal Simek
