[PATCH v2 0/2] serial_mxc: fixing reception
while writing to a imx-serial device is probably thoroughly tested - and obviosly works for the debug-serial - using a serial driver to read data received over the serial interface does not work reliably.
the patches in this series address issues found during the implementation of a custom uboot-command to query a coprocessor, connected to an imx8mm over uart4, for mainboard-identification strings
(no changes since v1)
Johannes Schneider (2): serial: mxc: enable the RX pipeline serial: mxc: have putc use the TXFIFO
drivers/serial/serial_mxc.c | 13 ++++++++++++- 1 file changed, 12 insertions(+), 1 deletion(-)
on imx8(mm) the RXDMUXSEL needs to be set for data going over the wire (as observable on a connected 'scope) to actually make it into the RXFIFO
the reference manual is not overly clear about this, and only mentiones that "UCR3_RXDMUXSEL should always be set." - and since the CR3 register reverts to its reset values after setting the baudrate, setting this bit is done during '_mxc_serial_setbgr'
Signed-off-by: Johannes Schneider johannes.schneider@leica-geosystems.com
drivers/serial/serial_mxc.c | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/drivers/serial/serial_mxc.c b/drivers/serial/serial_mxc.c index 70a0e5e919..5f283cc635 100644 --- a/drivers/serial/serial_mxc.c +++ b/drivers/serial/serial_mxc.c @@ -61,6 +61,11 @@ #define UCR3_AWAKEN (1<<4) /* Async wake interrupt enable */ #define UCR3_REF25 (1<<3) /* Ref freq 25 MHz */ #define UCR3_REF30 (1<<2) /* Ref Freq 30 MHz */ + +//imx8 names these bitsfields instead: +#define UCR3_DTRDEN BIT(3) /* bit not used in this chip */ +#define UCR3_RXDMUXSEL BIT(2) /* RXD muxed input selected; 'should always be set' */ + #define UCR3_INVT (1<<1) /* Inverted Infrared transmission */ #define UCR3_BPEN (1<<0) /* Preset registers enable */ #define UCR4_CTSTL_32 (32<<10) /* CTS trigger level (32 chars) */ @@ -176,6 +181,12 @@ static void _mxc_serial_setbrg(struct mxc_uart *base, unsigned long clk,
writel(UCR2_WS | UCR2_IRTS | UCR2_RXEN | UCR2_TXEN | UCR2_SRST, &base->cr2); + + // setting the baudrate triggers a reset, returning cr3 to its + // reset value but UCR3_RXDMUXSEL "should always be set." + // according to the imx8 reference-manual + writel(readl(&base->cr3) | UCR3_RXDMUXSEL, &base->cr3); + writel(UCR1_UARTEN, &base->cr1); }
- #define UCR3_INVT (1<<1) /* Inverted Infrared transmission */ #define UCR3_BPEN (1<<0) /* Preset registers enable */ #define UCR4_CTSTL_32 (32<<10) /* CTS trigger level (32 chars) */
- // setting the baudrate triggers a reset, returning cr3 to its
- // reset value but UCR3_RXDMUXSEL "should always be set."
- // according to the imx8 reference-manual
- writel(readl(&base->cr3) | UCR3_RXDMUXSEL, &base->cr3);
Please fix comment format.
I just give a look at i.MX6QDL, i.MX7D, i.MX8M*, this bit should be set for them all.
Thanks, Peng.
- writel(UCR1_UARTEN, &base->cr1); }
@@ -176,6 +181,12 @@ static void _mxc_serial_setbrg(struct mxc_uart *base, unsigned long clk, writel(UCR2_WS | UCR2_IRTS | UCR2_RXEN | UCR2_TXEN | UCR2_SRST, &base->cr2);
We allow '//' style comments, just like the linux kernel does these days. There should be a space before the "imx8" in the first hunk here.
Yes, // style comments are allowed, but for consistency with the other comments in this file, it would be better to keep using the /* style.
Mixing the two styles in the same file makes it confusing.
only waiting for TXEMPTY leads to corrupted messages going over the wire - which is fixed by making use of the FIFO
Signed-off-by: Johannes Schneider johannes.schneider@leica-geosystems.com ---
drivers/serial/serial_mxc.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/serial/serial_mxc.c b/drivers/serial/serial_mxc.c index 5f283cc635..1e0add7281 100644 --- a/drivers/serial/serial_mxc.c +++ b/drivers/serial/serial_mxc.c @@ -309,7 +309,7 @@ static int mxc_serial_putc(struct udevice *dev, const char ch) struct mxc_serial_plat *plat = dev_get_plat(dev); struct mxc_uart *const uart = plat->reg;
- if (!(readl(&uart->ts) & UTS_TXEMPTY)) + if (readl(&uart->ts) & UTS_TXFULL) return -EAGAIN;
writel(ch, &uart->txd);
Could you please explain a bit more, why waiting TXEMPTY could lead to corrupted message?
Thanks, Peng.
Hi Peng Fan,
... well i'm actually not sure why the messages get corrupted; it's just what i observed on a connected oscilloscope :-s the code that does uses the transmit functions is making use of the returned -EAGAIN and retries - and even strewing in some delays to wait for the buffer or checking the status register didn't resolve the issue -- switching the serical driver from locking onto the single send-register to actually checking the fifo fixed it though.
i can put these "vague reasons" in the commit message... but i dont/didn't think theyd help much (?)
regards ________________________________ From: Peng Fan peng.fan@oss.nxp.com Sent: Tuesday, September 6, 2022 02:54 To: SCHNEIDER Johannes johannes.schneider@leica-geosystems.com; u-boot@lists.denx.de u-boot@lists.denx.de Cc: trini trini@konsulko.com; GEO-CHHER-bsp-development bsp-development.geo@leica-geosystems.com; festevam@denx.de festevam@denx.de; sbabic@denx.de sbabic@denx.de; Pali Rohár pali@kernel.org Subject: Re: [PATCH v2 2/2] serial: mxc: have putc use the TXFIFO
This email is not from Hexagon’s Office 365 instance. Please be careful while clicking links, opening attachments, or replying to this email.
Thanks, Peng.
if (readl(&uart->ts) & UTS_TXFULL) return -EAGAIN; writel(ch, &uart->txd);
On 9/6/2022 11:38 AM, SCHNEIDER Johannes wrote:
Hi Peng Fan,
That's fine, I just wanna know more details. Maybe add one line "followling linux kernel i.MX8M* uart driver, check UTS_TXFULL, not UTS_EMPTY."
Regards, Peng.
Thanks, Peng.
and thanks, that reference in the kernel uart driver is/might be actually better - my "reference" was the barebox sourcecode - which also checks the TXFULL instead
i'll update the message and send out a v3
regards
________________________________ From: Peng Fan peng.fan@oss.nxp.com Sent: Tuesday, September 6, 2022 07:15 To: SCHNEIDER Johannes johannes.schneider@leica-geosystems.com; u-boot@lists.denx.de u-boot@lists.denx.de Cc: trini trini@konsulko.com; GEO-CHHER-bsp-development bsp-development.geo@leica-geosystems.com; festevam@denx.de festevam@denx.de; sbabic@denx.de sbabic@denx.de; Pali Rohár pali@kernel.org Subject: Re: [PATCH v2 2/2] serial: mxc: have putc use the TXFIFO
[You don't often get email from peng.fan@oss.nxp.com. Learn why this is important at https://aka.ms/LearnAboutSenderIdentification ]
Hi Peng Fan,
Regards, Peng.
Thanks, Peng.
participants (5)
Fabio Estevam
Johannes Schneider
Peng Fan
SCHNEIDER Johannes
