[U-Boot] SPI question
Hello,
Veteran developer, new to Linux internals. I'm working with the BeagleBone and need three SPI ports. I'm now working to enable the second chip select on the second port. I need some basic information to get started.
Is the port initialization done in u-boot or in the kernel? In beagle/beagle.h I found the pins nicely enumerated but that file is apparently for the BeagleBoard, as it doesn't get built during a bone build.
If the initialization is done in u-boot, could someone suggest the file to look at?
Thanks,
John
On Tue, Feb 19, 2013 at 5:12 PM, NeonJohn jgd@neon-john.com wrote:
Hello,
I haven't yet used the Beagle Bone (though I have one on my desk), but I have used SPI on a Blackfin target with U-Boot and Linux. On that target, the Blackfin's built-in first-stage bootloader uses SPI to load U-Boot into memory from flash and runs it. U-Boot then reads the Linux kernel image into RAM from the SPI flash and boots it. Those things probably don't apply in your case, unless your flash uses an SPI interface.
Then everything else SPI related is done in Linux. Specifically there is a "board" file where the peripherals are set up. On my target there is both a hardware-assisted SPI bus with several attached chips and a "bitbanged" SPI bus. Those buses (including the pin assignments) are set up in the board file and the peripherals are attached to the buses and assigned chip select pins. I don't know if those things are handled the same way for the Beagle Bone or not; I use a custom Linux distribution for Blackfin that may work differently.
This is straying off topic for the U-Boot list, but if you want more info about how it works on my target, email me directly.
Steve
NeonJohn
Steve Strobel
