[U-Boot] [PATCH 1/3][v3] powerpc/common/vsc3316: remove const from vsc3316_config parameter define
Since the parameters need to be modified according to different Serdes protocols at runtime, the const will block this. Also remove const from arrays define used by vsc3316_config.
Signed-off-by: Shaohui Xie Shaohui.Xie@freescale.com --- changes for V3: 1. rebased on top of master branch.
changes for V2: 1. changed subject; 2. fix broken on B4xxx boards;
board/freescale/b4860qds/b4860qds_crossbar_con.h | 12 ++++++------ board/freescale/common/vsc3316_3308.c | 2 +- board/freescale/common/vsc3316_3308.h | 2 +- board/freescale/t4qds/t4240qds.c | 8 ++++---- 4 files changed, 12 insertions(+), 12 deletions(-)
diff --git a/board/freescale/b4860qds/b4860qds_crossbar_con.h b/board/freescale/b4860qds/b4860qds_crossbar_con.h index 6e64745..db0cf28 100644 --- a/board/freescale/b4860qds/b4860qds_crossbar_con.h +++ b/board/freescale/b4860qds/b4860qds_crossbar_con.h @@ -13,10 +13,10 @@ static const int8_t vsc16_tx_amc[8][2] = { {15, 3}, {0, 2}, {7, 4}, {9, 10}, {5, 11}, {4, 5}, {2, 6}, {12, 9} };
-static const int8_t vsc16_tx_sfp[8][2] = { {15, 7}, {0, 1}, {7, 8}, {9, 0}, +static int8_t vsc16_tx_sfp[8][2] = { {15, 7}, {0, 1}, {7, 8}, {9, 0}, {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1} };
-static const int8_t vsc16_tx_4sfp_sgmii_12_56[8][2] = { {15, 7}, {0, 1}, +static int8_t vsc16_tx_4sfp_sgmii_12_56[8][2] = { {15, 7}, {0, 1}, {7, 8}, {9, 0}, {2, 14}, {12, 15}, {-1, -1}, {-1, -1} };
@@ -25,7 +25,7 @@ static const int8_t vsc16_tx_4sfp_sgmii_34[8][2] = { {15, 7}, {0, 1}, {-1, -1}, {-1, -1} };
#ifdef CONFIG_PPC_B4420 -static const int8_t vsc16_tx_sgmii_lane_cd[8][2] = { {5, 14}, {4, 15}, +static int8_t vsc16_tx_sgmii_lane_cd[8][2] = { {5, 14}, {4, 15}, {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1} }; #endif
@@ -35,10 +35,10 @@ static const int8_t vsc16_tx_aurora[8][2] = { {2, 13}, {12, 12}, {-1, -1}, static const int8_t vsc16_rx_amc[8][2] = { {3, 15}, {2, 1}, {4, 8}, {10, 9}, {11, 11}, {5, 10}, {6, 3}, {9, 12} };
-static const int8_t vsc16_rx_sfp[8][2] = { {8, 15}, {0, 1}, {7, 8}, {1, 9}, +static int8_t vsc16_rx_sfp[8][2] = { {8, 15}, {0, 1}, {7, 8}, {1, 9}, {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1} };
-static const int8_t vsc16_rx_4sfp_sgmii_12_56[8][2] = { {8, 15}, {0, 1}, +static int8_t vsc16_rx_4sfp_sgmii_12_56[8][2] = { {8, 15}, {0, 1}, {7, 8}, {1, 9}, {14, 3}, {15, 12}, {-1, -1}, {-1, -1} };
@@ -47,7 +47,7 @@ static const int8_t vsc16_rx_4sfp_sgmii_34[8][2] = { {8, 15}, {0, 1}, {-1, -1}, {-1, -1} };
#ifdef CONFIG_PPC_B4420 -static const int8_t vsc16_rx_sgmii_lane_cd[8][2] = { {14, 11}, {15, 10}, +static int8_t vsc16_rx_sgmii_lane_cd[8][2] = { {14, 11}, {15, 10}, {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1}, {-1, -1} }; #endif
diff --git a/board/freescale/common/vsc3316_3308.c b/board/freescale/common/vsc3316_3308.c index 8a3dc33..97a25e8 100644 --- a/board/freescale/common/vsc3316_3308.c +++ b/board/freescale/common/vsc3316_3308.c @@ -31,7 +31,7 @@ int vsc_if_enable(unsigned int vsc_addr) return i2c_write(vsc_addr, INTERFACE_MODE_REG, 1, &data, 1); }
-int vsc3316_config(unsigned int vsc_addr, const int8_t con_arr[][2], +int vsc3316_config(unsigned int vsc_addr, int8_t con_arr[][2], unsigned int num_con) { unsigned int i; diff --git a/board/freescale/common/vsc3316_3308.h b/board/freescale/common/vsc3316_3308.h index 4003fcd..2a49187 100644 --- a/board/freescale/common/vsc3316_3308.h +++ b/board/freescale/common/vsc3316_3308.h @@ -12,7 +12,7 @@ #include <errno.h>
int vsc_if_enable(unsigned int vsc_addr); -int vsc3316_config(unsigned int vsc_addr, const int8_t con_arr[][2], +int vsc3316_config(unsigned int vsc_addr, int8_t con_arr[][2], unsigned int num_con); int vsc3308_config(unsigned int vsc_addr, const int8_t con_arr[][2], unsigned int num_con); diff --git a/board/freescale/t4qds/t4240qds.c b/board/freescale/t4qds/t4240qds.c index 7ee0f54..c3f6247 100644 --- a/board/freescale/t4qds/t4240qds.c +++ b/board/freescale/t4qds/t4240qds.c @@ -26,16 +26,16 @@
DECLARE_GLOBAL_DATA_PTR;
-static const int8_t vsc3316_fsm1_tx[8][2] = { {0, 0}, {1, 1}, {6, 6}, {7, 7}, +static int8_t vsc3316_fsm1_tx[8][2] = { {0, 0}, {1, 1}, {6, 6}, {7, 7}, {8, 8}, {9, 9}, {14, 14}, {15, 15} };
-static const int8_t vsc3316_fsm2_tx[8][2] = { {2, 2}, {3, 3}, {4, 4}, {5, 5}, +static int8_t vsc3316_fsm2_tx[8][2] = { {2, 2}, {3, 3}, {4, 4}, {5, 5}, {10, 10}, {11, 11}, {12, 12}, {13, 13} };
-static const int8_t vsc3316_fsm1_rx[8][2] = { {2, 12}, {3, 13}, {4, 5}, {5, 4}, +static int8_t vsc3316_fsm1_rx[8][2] = { {2, 12}, {3, 13}, {4, 5}, {5, 4}, {10, 11}, {11, 10}, {12, 2}, {13, 3} };
-static const int8_t vsc3316_fsm2_rx[8][2] = { {0, 15}, {1, 14}, {6, 7}, {7, 6}, +static int8_t vsc3316_fsm2_rx[8][2] = { {0, 15}, {1, 14}, {6, 7}, {7, 6}, {8, 9}, {9, 8}, {14, 1}, {15, 0} };
int checkboard(void)
changes for V3:
- rebased on top of master branch.
changes for V2:
- changed subject;
- fix broken on B4xxx boards;
Applied to u-boot-mpc85xx/master.
BTW, very confusing when you submit patches with your name but with another email address Shengzhou.Liu@freescale.com.
York
Shaohui Xie
York Sun
