RE: [U-Boot-Users] LH7A400 Sharp boards running UBoot
Actually, the patches from May 17 should be used, not the ones from May 11. Please ignore the patch(es) from May 11.
Also, attached is a patch for 'board/lpd7a40x/memsetup.S'. This patch fixes the SDRAM device initialization constant definitions (I was apparently thinking in binary but writing in hex). Without it the board will not come up. I had this value hardcoded and the board was working standalone...replaced the hardcoded values with the constant definitions and forgot to check with BDI umbilical unattached before submitting patch.
Wolfgang, I can submit this patch again once the board patch is committed so you don't have to remember. Whatever is easiest for you.
-----Original Message----- From: Wolfgang Denk [mailto:wd@denx.de] Sent: Monday, May 24, 2004 3:40 AM To: lugs@eternitytechnologies.com Cc: u-boot-users@lists.sourceforge.net Subject: Re: [U-Boot-Users] LH7A400 Sharp boards running UBoot
In message 1085366252.648.41.camel@localhost you wrote:
Can anyone please point me to any resources for LH7A400 Sharp boards running U-Boot.
See the patches by Paul Ruhland posted on May 11.
In message 76C7EB7C8500594F9001B118E7E778F48F4DD2@mdsms3.inside.mdsroc.com you wrote:
Added, thanks.
Ruhland, Paul
